[U-Boot] [PATCH 0/2] rockchip: rk3288: Fixes for GMAC
This set of patches contains two fixes. The first one removes the pull up for GPIO4B0 that is the pin for phy-reset. This is already supported by GMAC ("reset-gpio" from DT) and should not be hardcoded in the pinctrl driver. The second one, revert back the removal of the MAX_TCLK pin that was accidentaly removed while re-working commit 2454b719fb87 ("rockchip: rk3288: Add pinctrl support for the...").
Romain Perier (2): rockchip: rk3288: Remove phy reset GPIO pull up rockchip: rk3288: Revert MAC_TXCLK in pinctrl for GMAC
drivers/pinctrl/rockchip/pinctrl_rk3288.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
We should not handle this pin explicitly from pinctrl. GMAC driver takes care of it by using a "reset-gpio" in the DT.
This commit removes pull up for GPIO4B0.
Fixes: 2454b719fb87 ("rockchip: rk3288: Add pinctrl support for the...") Signed-off-by: Romain Perier romain.perier@collabora.com --- drivers/pinctrl/rockchip/pinctrl_rk3288.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3288.c b/drivers/pinctrl/rockchip/pinctrl_rk3288.c index 3c9ae974f4..ba488f7ce6 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3288.c @@ -501,11 +501,9 @@ static void pinctrl_rk3288_gmac_config(struct rk3288_grf *grf, int gmac_id) GPIO_BIAS_MASK << GPIO_BIAS_SHIFT(1), GPIO_BIAS_12MA << GPIO_BIAS_SHIFT(1));
- /* Set pull normal for GPIO4B1, pull up for GPIO4B0 */ + /* Set pull normal for GPIO4B1 */ rk_clrsetreg(&grf->gpio1_p[3][1], - (GPIO_PULL_MASK << GPIO_PULL_SHIFT(0)) | (GPIO_PULL_MASK << GPIO_PULL_SHIFT(1)), - (GPIO_PULL_UP << GPIO_PULL_SHIFT(0)) | (GPIO_PULL_NORMAL << GPIO_PULL_SHIFT(1)));
break;
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Fixes: 2454b719fb87 ("rockchip: rk3288: Add pinctrl support for the...") Signed-off-by: Romain Perier romain.perier@collabora.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Fixes: 2454b719fb87 ("rockchip: rk3288: Add pinctrl support for the...") Signed-off-by: Romain Perier romain.perier@collabora.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
This reverts TXCLK toggling that was accidently dropped while reworking commit 2454b719fb87 ("rockchip: rk3288: Add pinctrl support for the gmac ethernet interface"). So the TX clock is enabled and we can use GMAC_ROCKCHIP in 1Gbps when basic PINCTRL support is enabled (!PINTRL_FULL).
Fixes: 2454b719fb87 ("rockchip: rk3288: Add pinctrl support for the...") Signed-off-by: Romain Perier romain.perier@collabora.com --- drivers/pinctrl/rockchip/pinctrl_rk3288.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/pinctrl/rockchip/pinctrl_rk3288.c b/drivers/pinctrl/rockchip/pinctrl_rk3288.c index ba488f7ce6..47cefc5abf 100644 --- a/drivers/pinctrl/rockchip/pinctrl_rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl_rk3288.c @@ -496,6 +496,10 @@ static void pinctrl_rk3288_gmac_config(struct rk3288_grf *grf, int gmac_id) (GPIO_PULL_NORMAL << GPIO_PULL_SHIFT(6)) | (GPIO_PULL_NORMAL << GPIO_PULL_SHIFT(7)));
+ rk_clrsetreg(&grf->gpio4bl_iomux, + GPIO4B1_MASK << GPIO4B1_SHIFT, + GPIO4B1_MAC_TXCLK << GPIO4B1_SHIFT); + /* switch GPIO4B1 to 12ma drive-strength */ rk_clrsetreg(&grf->gpio1_e[3][1], GPIO_BIAS_MASK << GPIO_BIAS_SHIFT(1),
Philipp Tomsich
Romain Perier
