[U-Boot] u-boot not giving output in Kermit on startup (OMAP3430 sdp)
Hi I flashed in the u-boot to the H6 omap3430 board, but i get a blank screen on reset; moreover, when I use kermit via Serial port COM1, Im able to connect but I do not get the u-boot shell. (I am a newbie...) Could someone tell me what I am doing wrong or missing here? Thanks in advance for helping me and Best regards Shrikumar Sharma
Maybe you could give more info, like what commit of U-boot are you using, what config file (because I don't know what board is that one). Regards.
Hi Aldo Thanks for your reply. Im using the Omap3430 SDP board, I used the config omap3_sdp3430. I used the following commit of u-boot: 1f241263e088a71b8f33f87b03a37c5418d41e2e
Shrikumar Sharma
screen
Shrikumar Sharma
screen
Hey Shrikumar,
Shrikumar Sharma
I just flashed main branch u-boot with the commit you are telling and it went fine.
And I do get the prompt line from the shell.
Do you get something like this? OMAP34XX SDP #
If you do you are in the shell, try typing printenv to test it.
Best regards. Aldo Brett
Aldo Cedillo
Shrikumar Sharma
