[PATCH] ARM: imx: soc: Select default TEXT_BASE for MX7
Select default U-Boot and SPL text base for the MX7 SoC. The U-Boot text base is picked as the one used by various MX7 boards. The SPL text base however is different.
The SPL text base is set to 0x912000 instead of the usual 0x911000, that is because the 0x911000 value cannot work. Using 0x911000 as a SPL text base will result in the DCD header being placed below the 0x911000 address, which is a reserved SRAM area which must not be used. This will actually trigger eMMC boot failure on MX7D at least. Hence the increment.
Update all boards affected by this SPL problem to the new SPL_TEXT_BASE.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/mach-imx/mx7/Kconfig | 7 +++++++ configs/cl-som-imx7_defconfig | 2 -- configs/pico-dwarf-imx7d_defconfig | 2 -- configs/pico-hobbit-imx7d_defconfig | 2 -- configs/pico-imx7d_defconfig | 2 -- configs/pico-nymph-imx7d_defconfig | 2 -- configs/pico-pi-imx7d_defconfig | 2 -- 7 files changed, 7 insertions(+), 12 deletions(-)
diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index 286d36589d..c8146c3509 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -16,6 +16,13 @@ config MX7D select ROM_UNIFIED_SECTIONS imply CMD_FUSE
+config SYS_TEXT_BASE + default 0x87800000 + +config SPL_TEXT_BASE + depends on SPL + default 0x00912000 + choice prompt "MX7 board select" optional diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index d2766190de..b54048343f 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y -CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -17,7 +16,6 @@ CONFIG_SPL_SPI_SUPPORT=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_TEXT_BASE=0x00911000 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_SPI_BOOT=y CONFIG_BOOTDELAY=3 diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index 8a1e15de65..07b17f52ec 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y -CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -15,7 +14,6 @@ CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_TEXT_BASE=0x00911000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 830fddeee9..d04b0d7dd6 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y -CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -15,7 +14,6 @@ CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_TEXT_BASE=0x00911000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 545acd2c89..f3719187ef 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y -CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -15,7 +14,6 @@ CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_TEXT_BASE=0x00911000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index 8a1e15de65..07b17f52ec 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y -CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -15,7 +14,6 @@ CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_TEXT_BASE=0x00911000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd" diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index c9e6abc7d2..13b6a2f35c 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -1,6 +1,5 @@ CONFIG_ARM=y CONFIG_ARCH_MX7=y -CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y @@ -15,7 +14,6 @@ CONFIG_SPL=y CONFIG_ARMV7_BOOT_SEC_DEFAULT=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y -CONFIG_SPL_TEXT_BASE=0x00911000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTCOMMAND="run findfdt; run finduuid; run distro_bootcmd"
Select default U-Boot and SPL text base for the MX7 SoC. The U-Boot text base is picked as the one used by various MX7 boards. The SPL text base however is different. The SPL text base is set to 0x912000 instead of the usual 0x911000, that is because the 0x911000 value cannot work. Using 0x911000 as a SPL text base will result in the DCD header being placed below the 0x911000 address, which is a reserved SRAM area which must not be used. This will actually trigger eMMC boot failure on MX7D at least. Hence the increment. Update all boards affected by this SPL problem to the new SPL_TEXT_BASE. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: NXP i.MX U-Boot Team uboot-imx@nxp.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
