[U-Boot] [PATCH 1/2] ata: fsl_sata: Add sata DM support for Freescale powerpc
T series socs
This patch is to support Freescale sata driver with dts initialized. We needed to enable CONFIG_BLK on this platform. It adds the SATA controller as AHCI device, which is strictly speaking not correct, as the controller is not AHCI compatible. But the U-Boot AHCI uclass interface enables the usage of this DM driver. Also resolved the following problems.
===================== WARNING ======================" This board does use CONFIG_LIBATA but has CONFIG_AHCI not" enabled. Please update the storage controller driver to use" CONFIG_AHCI before the v2019.07 release." Failure to update by the deadline may result in board removal." See doc/driver-model/MIGRATION.txt for more info." ===================================================="
Signed-off-by: Peng Ma peng.ma@nxp.com --- drivers/ata/Kconfig | 1 + drivers/ata/fsl_sata.c | 296 +++++++++++++++++++++++++++++++++++-------------- drivers/ata/fsl_sata.h | 10 ++ 3 files changed, 222 insertions(+), 85 deletions(-)
diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 87636ae..57121f6 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -87,6 +87,7 @@ config DWC_AHSATA_AHCI config FSL_SATA bool "Enable Freescale SATA controller driver support" select LIBATA + select AHCI if BLK help Enable this driver to support the SATA controller found in some Freescale PowerPC SoCs. diff --git a/drivers/ata/fsl_sata.c b/drivers/ata/fsl_sata.c index e70a515..986e44e 100644 --- a/drivers/ata/fsl_sata.c +++ b/drivers/ata/fsl_sata.c @@ -16,6 +16,11 @@ #include <sata.h> #include "fsl_sata.h"
+#if CONFIG_IS_ENABLED(BLK) +#include <dm.h> +#include <ahci.h> +#include <blk.h> +#else #ifndef CONFIG_SYS_SATA1_FLAGS #define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA #endif @@ -35,6 +40,7 @@ static struct fsl_sata_info fsl_sata_info[] = { {0, 0}, #endif }; +#endif
static inline void sdelay(unsigned long sec) { @@ -74,7 +80,11 @@ static int ata_wait_register(unsigned __iomem *addr, u32 mask, return (i < timeout_msec) ? 0 : -1; }
+#if !CONFIG_IS_ENABLED(BLK) int init_sata(int dev) +#else +static int init_sata(struct fsl_ata_priv *priv, int dev) +#endif { u32 length, align; cmd_hdr_tbl_t *cmd_hdr; @@ -110,13 +120,18 @@ int init_sata(int dev) /* Zero all of the device driver struct */ memset((void *)sata, 0, sizeof(fsl_sata_t));
- /* Save the private struct to block device struct */ - sata_dev_desc[dev].priv = (void *)sata; - - snprintf(sata->name, 12, "SATA%d", dev); + snprintf(sata->name, 12, "SATA%d:\n", dev);
/* Set the controller register base address to device struct */ +#if !CONFIG_IS_ENABLED(BLK) + sata_dev_desc[dev].priv = (void *)sata; reg = (fsl_sata_reg_t *)(fsl_sata_info[dev].sata_reg_base); + sata->dma_flag = fsl_sata_info[dev].flags; +#else + reg = (fsl_sata_reg_t *)(priv->base + priv->offset * dev); + sata->dma_flag = priv->flag; + priv->fsl_sata = sata; +#endif sata->reg_base = reg;
/* Allocate the command header table, 4 bytes aligned */ @@ -479,34 +494,16 @@ static int fsl_sata_exec_cmd(struct fsl_sata *sata, struct sata_fis_h2d *cfis, return -1; }
-static void fsl_sata_identify(int dev, u16 *id) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; - struct sata_fis_h2d h2d, *cfis = &h2d; - - memset(cfis, 0, sizeof(struct sata_fis_h2d)); - - cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; - cfis->pm_port_c = 0x80; /* is command */ - cfis->command = ATA_CMD_ID_ATA; - - fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, (u8 *)id, ATA_ID_WORDS * 2); - ata_swap_buf_le16(id, ATA_ID_WORDS); -} - -static void fsl_sata_xfer_mode(int dev, u16 *id) +static void fsl_sata_xfer_mode(fsl_sata_t *sata, u16 *id) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; - sata->pio = id[ATA_ID_PIO_MODES]; sata->mwdma = id[ATA_ID_MWDMA_MODES]; sata->udma = id[ATA_ID_UDMA_MODES]; debug("pio %04x, mwdma %04x, udma %04x\n\r", sata->pio, sata->mwdma, sata->udma); }
-static void fsl_sata_set_features(int dev) +static void fsl_sata_set_features(fsl_sata_t *sata) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; struct sata_fis_h2d h2d, *cfis = &h2d; u8 udma_cap;
@@ -533,9 +530,9 @@ static void fsl_sata_set_features(int dev) fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); }
-static u32 fsl_sata_rw_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_write) +static u32 fsl_sata_rw_cmd(fsl_sata_t *sata, u32 start, u32 blkcnt, u8 *buffer, + int is_write) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; struct sata_fis_h2d h2d, *cfis = &h2d; u32 block;
@@ -558,9 +555,8 @@ static u32 fsl_sata_rw_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_wr return blkcnt; }
-static void fsl_sata_flush_cache(int dev) +static void fsl_sata_flush_cache(fsl_sata_t *sata) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; struct sata_fis_h2d h2d, *cfis = &h2d;
memset(cfis, 0, sizeof(struct sata_fis_h2d)); @@ -572,9 +568,9 @@ static void fsl_sata_flush_cache(int dev) fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); }
-static u32 fsl_sata_rw_cmd_ext(int dev, u32 start, u32 blkcnt, u8 *buffer, int is_write) +static u32 fsl_sata_rw_cmd_ext(fsl_sata_t *sata, u32 start, u32 blkcnt, + u8 *buffer, int is_write) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; struct sata_fis_h2d h2d, *cfis = &h2d; u64 block;
@@ -602,10 +598,9 @@ static u32 fsl_sata_rw_cmd_ext(int dev, u32 start, u32 blkcnt, u8 *buffer, int i return blkcnt; }
-static u32 fsl_sata_rw_ncq_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, - int is_write) +static u32 fsl_sata_rw_ncq_cmd(fsl_sata_t *sata, u32 start, u32 blkcnt, + u8 *buffer, int is_write) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; struct sata_fis_h2d h2d, *cfis = &h2d; int ncq_channel; u64 block; @@ -646,9 +641,8 @@ static u32 fsl_sata_rw_ncq_cmd(int dev, u32 start, u32 blkcnt, u8 *buffer, return blkcnt; }
-static void fsl_sata_flush_cache_ext(int dev) +static void fsl_sata_flush_cache_ext(fsl_sata_t *sata) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; struct sata_fis_h2d h2d, *cfis = &h2d;
memset(cfis, 0, sizeof(struct sata_fis_h2d)); @@ -660,10 +654,8 @@ static void fsl_sata_flush_cache_ext(int dev) fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, NULL, 0); }
-static void fsl_sata_init_wcache(int dev, u16 *id) +static void fsl_sata_init_wcache(fsl_sata_t *sata, u16 *id) { - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; - if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id)) sata->wcache = 1; if (ata_id_has_flush(id)) @@ -672,26 +664,8 @@ static void fsl_sata_init_wcache(int dev, u16 *id) sata->flush_ext = 1; }
-static int fsl_sata_get_wcache(int dev) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; - return sata->wcache; -} - -static int fsl_sata_get_flush(int dev) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; - return sata->flush; -} - -static int fsl_sata_get_flush_ext(int dev) -{ - fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; - return sata->flush_ext; -} - -static u32 ata_low_level_rw_lba48(int dev, u32 blknr, lbaint_t blkcnt, - const void *buffer, int is_write) +static u32 ata_low_level_rw_lba48(fsl_sata_t *sata, u32 blknr, lbaint_t blkcnt, + const void *buffer, int is_write) { u32 start, blks; u8 *addr; @@ -704,18 +678,22 @@ static u32 ata_low_level_rw_lba48(int dev, u32 blknr, lbaint_t blkcnt, max_blks = ATA_MAX_SECTORS_LBA48; do { if (blks > max_blks) { - if (fsl_sata_info[dev].flags != FLAGS_FPDMA) - fsl_sata_rw_cmd_ext(dev, start, max_blks, addr, is_write); + if (sata->dma_flag != FLAGS_FPDMA) + fsl_sata_rw_cmd_ext(sata, start, max_blks, addr, + is_write); else - fsl_sata_rw_ncq_cmd(dev, start, max_blks, addr, is_write); + fsl_sata_rw_ncq_cmd(sata, start, max_blks, addr, + is_write); start += max_blks; blks -= max_blks; addr += ATA_SECT_SIZE * max_blks; } else { - if (fsl_sata_info[dev].flags != FLAGS_FPDMA) - fsl_sata_rw_cmd_ext(dev, start, blks, addr, is_write); + if (sata->dma_flag != FLAGS_FPDMA) + fsl_sata_rw_cmd_ext(sata, start, blks, addr, + is_write); else - fsl_sata_rw_ncq_cmd(dev, start, blks, addr, is_write); + fsl_sata_rw_ncq_cmd(sata, start, blks, addr, + is_write); start += blks; blks = 0; addr += ATA_SECT_SIZE * blks; @@ -725,7 +703,7 @@ static u32 ata_low_level_rw_lba48(int dev, u32 blknr, lbaint_t blkcnt, return blkcnt; }
-static u32 ata_low_level_rw_lba28(int dev, u32 blknr, u32 blkcnt, +static u32 ata_low_level_rw_lba28(fsl_sata_t *sata, u32 blknr, u32 blkcnt, const void *buffer, int is_write) { u32 start, blks; @@ -739,12 +717,12 @@ static u32 ata_low_level_rw_lba28(int dev, u32 blknr, u32 blkcnt, max_blks = ATA_MAX_SECTORS; do { if (blks > max_blks) { - fsl_sata_rw_cmd(dev, start, max_blks, addr, is_write); + fsl_sata_rw_cmd(sata, start, max_blks, addr, is_write); start += max_blks; blks -= max_blks; addr += ATA_SECT_SIZE * max_blks; } else { - fsl_sata_rw_cmd(dev, start, blks, addr, is_write); + fsl_sata_rw_cmd(sata, start, blks, addr, is_write); start += blks; blks = 0; addr += ATA_SECT_SIZE * blks; @@ -757,38 +735,81 @@ static u32 ata_low_level_rw_lba28(int dev, u32 blknr, u32 blkcnt, /* * SATA interface between low level driver and command layer */ +#if !CONFIG_IS_ENABLED(BLK) ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer) { - u32 rc; fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; +#else +static ulong sata_read(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, + void *buffer) +{ + struct fsl_ata_priv *priv = dev_get_platdata(dev); + fsl_sata_t *sata = priv->fsl_sata; +#endif + u32 rc;
if (sata->lba48) - rc = ata_low_level_rw_lba48(dev, blknr, blkcnt, buffer, READ_CMD); + rc = ata_low_level_rw_lba48(sata, blknr, blkcnt, buffer, + READ_CMD); else - rc = ata_low_level_rw_lba28(dev, blknr, blkcnt, buffer, READ_CMD); + rc = ata_low_level_rw_lba28(sata, blknr, blkcnt, buffer, + READ_CMD); return rc; }
+#if !CONFIG_IS_ENABLED(BLK) ulong sata_write(int dev, ulong blknr, lbaint_t blkcnt, const void *buffer) { - u32 rc; fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; +#else +static ulong sata_write(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, + const void *buffer) +{ + struct fsl_ata_priv *priv = dev_get_platdata(dev); + fsl_sata_t *sata = priv->fsl_sata; +#endif + u32 rc;
if (sata->lba48) { - rc = ata_low_level_rw_lba48(dev, blknr, blkcnt, buffer, WRITE_CMD); - if (fsl_sata_get_wcache(dev) && fsl_sata_get_flush_ext(dev)) - fsl_sata_flush_cache_ext(dev); + rc = ata_low_level_rw_lba48(sata, blknr, blkcnt, buffer, + WRITE_CMD); + if (sata->wcache && sata->flush_ext) + fsl_sata_flush_cache_ext(sata); } else { - rc = ata_low_level_rw_lba28(dev, blknr, blkcnt, buffer, WRITE_CMD); - if (fsl_sata_get_wcache(dev) && fsl_sata_get_flush(dev)) - fsl_sata_flush_cache(dev); + rc = ata_low_level_rw_lba28(sata, blknr, blkcnt, buffer, + WRITE_CMD); + if (sata->wcache && sata->flush) + fsl_sata_flush_cache(sata); } return rc; }
+static void fsl_sata_identify(fsl_sata_t *sata, u16 *id) +{ + struct sata_fis_h2d h2d, *cfis = &h2d; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_ID_ATA; + + fsl_sata_exec_cmd(sata, cfis, CMD_ATA, 0, (u8 *)id, ATA_ID_WORDS * 2); + ata_swap_buf_le16(id, ATA_ID_WORDS); +} + +#if !CONFIG_IS_ENABLED(BLK) int scan_sata(int dev) { fsl_sata_t *sata = (fsl_sata_t *)sata_dev_desc[dev].priv; +#else +static int scan_sata(struct udevice *dev) +{ + struct blk_desc *desc = dev_get_uclass_platdata(dev); + struct fsl_ata_priv *priv = dev_get_platdata(dev); + fsl_sata_t *sata = priv->fsl_sata; +#endif + unsigned char serial[ATA_ID_SERNO_LEN + 1]; unsigned char firmware[ATA_ID_FW_REV_LEN + 1]; unsigned char product[ATA_ID_PROD_LEN + 1]; @@ -806,23 +827,31 @@ int scan_sata(int dev) }
/* Identify device to get information */ - fsl_sata_identify(dev, id); + fsl_sata_identify(sata, id);
/* Serial number */ ata_id_c_string(id, serial, ATA_ID_SERNO, sizeof(serial)); - memcpy(sata_dev_desc[dev].product, serial, sizeof(serial));
/* Firmware version */ ata_id_c_string(id, firmware, ATA_ID_FW_REV, sizeof(firmware)); - memcpy(sata_dev_desc[dev].revision, firmware, sizeof(firmware));
/* Product model */ ata_id_c_string(id, product, ATA_ID_PROD, sizeof(product)); - memcpy(sata_dev_desc[dev].vendor, product, sizeof(product));
/* Totoal sectors */ n_sectors = ata_id_n_sectors(id); + +#if !CONFIG_IS_ENABLED(BLK) + memcpy(sata_dev_desc[dev].product, serial, sizeof(serial)); + memcpy(sata_dev_desc[dev].revision, firmware, sizeof(firmware)); + memcpy(sata_dev_desc[dev].vendor, product, sizeof(product)); sata_dev_desc[dev].lba = (u32)n_sectors; +#else + memcpy(desc->product, serial, sizeof(serial)); + memcpy(desc->revision, firmware, sizeof(firmware)); + memcpy(desc->vendor, product, sizeof(product)); + desc->lba = n_sectors; +#endif
#ifdef CONFIG_LBA48 /* Check if support LBA48 */ @@ -837,17 +866,114 @@ int scan_sata(int dev) sata->queue_depth = ata_id_queue_depth(id);
/* Get the xfer mode from device */ - fsl_sata_xfer_mode(dev, id); + fsl_sata_xfer_mode(sata, id);
/* Get the write cache status from device */ - fsl_sata_init_wcache(dev, id); + fsl_sata_init_wcache(sata, id);
/* Set the xfer mode to highest speed */ - fsl_sata_set_features(dev); + fsl_sata_set_features(sata); + #ifdef DEBUG - fsl_sata_identify(dev, id); ata_dump_id(id); #endif free((void *)id); return 0; } + +#if CONFIG_IS_ENABLED(BLK) +static const struct blk_ops sata_fsl_blk_ops = { + .read = sata_read, + .write = sata_write, +}; + +U_BOOT_DRIVER(sata_fsl_driver) = { + .name = "sata_fsl_blk", + .id = UCLASS_BLK, + .ops = &sata_fsl_blk_ops, + .platdata_auto_alloc_size = sizeof(struct fsl_ata_priv), +}; + +static int fsl_ata_ofdata_to_platdata(struct udevice *dev) +{ + struct fsl_ata_priv *priv = dev_get_priv(dev); + + priv->number = dev_read_u32_default(dev, "sata-number", -1); + priv->flag = dev_read_u32_default(dev, "sata-fpdma", -1); + priv->offset = dev_read_u32_default(dev, "sata-offset", -1); + + priv->base = dev_read_addr(dev); + if (priv->base == FDT_ADDR_T_NONE) + return -EINVAL; + + return 0; +} + +static int fsl_ata_probe(struct udevice *dev) +{ + struct fsl_ata_priv *blk_priv, *priv; + struct udevice *blk; + char sata_name[10]; + int nr_ports; + int ret; + int i; + + priv = dev_get_priv(dev); + nr_ports = priv->number; + nr_ports = min(nr_ports, CONFIG_SYS_SATA_MAX_DEVICE); + + for (i = 0; i < nr_ports; i++) { + snprintf(sata_name, sizeof(sata_name), "fsl_sata%d", i); + ret = blk_create_devicef(dev, "sata_fsl_blk", sata_name, + IF_TYPE_SATA, -1, 512, 0, &blk); + if (ret) { + debug("Can't create device\n"); + return ret; + } + + /* Init SATA port */ + ret = init_sata(priv, i); + if (ret) { + debug("%s: Failed to init sata\n", __func__); + return ret; + } + + blk_priv = dev_get_platdata(blk); + blk_priv->fsl_sata = priv->fsl_sata; + /* Scan SATA port */ + ret = scan_sata(blk); + if (ret) { + debug("%s: Failed to scan bus\n", __func__); + return ret; + } + } + + return 0; +} + +static int sata_fsl_scan(struct udevice *dev) +{ + /* Nothing to do here */ + + return 0; +} + +struct ahci_ops sata_fsl_ahci_ops = { + .scan = sata_fsl_scan, +}; + +static const struct udevice_id fsl_ata_ids[] = { + { .compatible = "fsl,pq-sata-v2" }, + { } +}; + +U_BOOT_DRIVER(fsl_ahci) = { + .name = "fsl_ahci", + .id = UCLASS_AHCI, + .of_match = fsl_ata_ids, + .ops = &sata_fsl_ahci_ops, + .ofdata_to_platdata = fsl_ata_ofdata_to_platdata, + .probe = fsl_ata_probe, + .priv_auto_alloc_size = sizeof(struct fsl_ata_priv), +}; +#endif diff --git a/drivers/ata/fsl_sata.h b/drivers/ata/fsl_sata.h index a4ee83d..a66006c 100644 --- a/drivers/ata/fsl_sata.h +++ b/drivers/ata/fsl_sata.h @@ -318,4 +318,14 @@ typedef struct fsl_sata { #define READ_CMD 0 #define WRITE_CMD 1
+#if CONFIG_IS_ENABLED(BLK) +struct fsl_ata_priv { + u32 base; + u32 flag; + u32 number; + u32 offset; + fsl_sata_t *fsl_sata; +}; +#endif + #endif /* __FSL_SATA_H__ */
This patch is to support Silicon(SIL3131 / SIL3132 / SIL3124) sata driver with dts initialized. This changed same as fsl_sata.c some of our socs need to use this driver such as P series platforms. Also resolved the following problems.
Signed-off-by: Peng Ma peng.ma@nxp.com --- drivers/ata/Kconfig | 1 + drivers/ata/sata_sil.c | 538 +++++++++++++++++++++++++++++++------------------ drivers/ata/sata_sil.h | 13 +- 3 files changed, 355 insertions(+), 197 deletions(-)
diff --git a/drivers/ata/Kconfig b/drivers/ata/Kconfig index 57121f6..fe589d3 100644 --- a/drivers/ata/Kconfig +++ b/drivers/ata/Kconfig @@ -110,6 +110,7 @@ config SATA_MV config SATA_SIL bool "Enable Silicon Image SIL3131 / SIL3132 / SIL3124 SATA driver support" select LIBATA + select AHCI if BLK help Enable this driver to support the SIL3131, SIL3132 and SIL3124 SATA controllers. diff --git a/drivers/ata/sata_sil.c b/drivers/ata/sata_sil.c index a8598d9..22e9d0c 100644 --- a/drivers/ata/sata_sil.c +++ b/drivers/ata/sata_sil.c @@ -14,18 +14,29 @@ #include <sata.h> #include <libata.h> #include <sata.h> + +#if CONFIG_IS_ENABLED(BLK) +#include <dm.h> +#include <blk.h> +#endif + #include "sata_sil.h"
-/* Convert sectorsize to wordsize */ -#define ATA_SECTOR_WORDS (ATA_SECT_SIZE/2) #define virt_to_bus(devno, v) pci_virt_to_mem(devno, (void *) (v))
+/* just compatible ahci_ops */ +struct sil_ops { + int *rev0; + int *rev1; + int (*scan)(struct udevice *dev); +}; + static struct sata_info sata_info;
static struct pci_device_id supported[] = { - {PCI_VENDOR_ID_SILICONIMAGE, PCI_DEVICE_ID_SIL3131}, - {PCI_VENDOR_ID_SILICONIMAGE, PCI_DEVICE_ID_SIL3132}, - {PCI_VENDOR_ID_SILICONIMAGE, PCI_DEVICE_ID_SIL3124}, + { PCI_DEVICE(PCI_VENDOR_ID_SILICONIMAGE, PCI_DEVICE_ID_SIL3131) }, + { PCI_DEVICE(PCI_VENDOR_ID_SILICONIMAGE, PCI_DEVICE_ID_SIL3132) }, + { PCI_DEVICE(PCI_VENDOR_ID_SILICONIMAGE, PCI_DEVICE_ID_SIL3124) }, {} };
@@ -113,9 +124,9 @@ static int sil_init_port(void *port) return 0; }
-static void sil_read_fis(int dev, int tag, struct sata_fis_d2h *fis) +static void sil_read_fis(struct sil_sata *sata, int tag, + struct sata_fis_d2h *fis) { - struct sil_sata *sata = sata_dev_desc[dev].priv; void *port = sata->port; struct sil_prb *prb; int i; @@ -128,9 +139,9 @@ static void sil_read_fis(int dev, int tag, struct sata_fis_d2h *fis) *dst++ = readl(src++); }
-static int sil_exec_cmd(int dev, struct sil_cmd_block *pcmd, int tag) +static int sil_exec_cmd(struct sil_sata *sata, struct sil_cmd_block *pcmd, + int tag) { - struct sil_sata *sata = sata_dev_desc[dev].priv; void *port = sata->port; u64 paddr = virt_to_bus(sata->devno, pcmd); u32 irq_mask, irq_stat; @@ -164,9 +175,8 @@ static int sil_exec_cmd(int dev, struct sil_cmd_block *pcmd, int tag) return rc; }
-static int sil_cmd_set_feature(int dev) +static int sil_cmd_set_feature(struct sil_sata *sata) { - struct sil_sata *sata = sata_dev_desc[dev].priv; struct sil_cmd_block cmdb, *pcmd = &cmdb; struct sata_fis_d2h fis; u8 udma_cap; @@ -191,9 +201,9 @@ static int sil_cmd_set_feature(int dev) if (udma_cap == ATA_UDMA3) pcmd->prb.fis.sector_count = XFER_UDMA_3;
- ret = sil_exec_cmd(dev, pcmd, 0); + ret = sil_exec_cmd(sata, pcmd, 0); if (ret) { - sil_read_fis(dev, 0, &fis); + sil_read_fis(sata, 0, &fis); printf("Err: exe cmd(0x%x).\n", readl(sata->port + PORT_SERROR)); sil_sata_dump_fis(&fis); @@ -203,9 +213,34 @@ static int sil_cmd_set_feature(int dev) return 0; }
-static int sil_cmd_identify_device(int dev, u16 *id) +static void sil_sata_init_wcache(struct sil_sata *sata, u16 *id) +{ + if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id)) + sata->wcache = 1; + if (ata_id_has_flush(id)) + sata->flush = 1; + if (ata_id_has_flush_ext(id)) + sata->flush_ext = 1; +} + +static void sil_sata_set_feature_by_id(struct sil_sata *sata, u16 *id) +{ +#ifdef CONFIG_LBA48 + /* Check if support LBA48 */ + if (ata_id_has_lba48(id)) { + sata->lba48 = 1; + debug("Device supports LBA48\n"); + } else { + debug("Device supports LBA28\n"); + } +#endif + + sil_sata_init_wcache(sata, id); + sil_cmd_set_feature(sata); +} + +static int sil_cmd_identify_device(struct sil_sata *sata, u16 *id) { - struct sil_sata *sata = sata_dev_desc[dev].priv; struct sil_cmd_block cmdb, *pcmd = &cmdb; struct sata_fis_d2h fis; int ret; @@ -220,9 +255,9 @@ static int sil_cmd_identify_device(int dev, u16 *id) pcmd->sge.cnt = cpu_to_le32(sizeof(id[0]) * ATA_ID_WORDS); pcmd->sge.flags = cpu_to_le32(SGE_TRM);
- ret = sil_exec_cmd(dev, pcmd, 0); + ret = sil_exec_cmd(sata, pcmd, 0); if (ret) { - sil_read_fis(dev, 0, &fis); + sil_read_fis(sata, 0, &fis); printf("Err: id cmd(0x%x).\n", readl(sata->port + PORT_SERROR)); sil_sata_dump_fis(&fis); return 1; @@ -232,17 +267,16 @@ static int sil_cmd_identify_device(int dev, u16 *id) return 0; }
-static int sil_cmd_soft_reset(int dev) +static int sil_cmd_soft_reset(struct sil_sata *sata) { struct sil_cmd_block cmdb, *pcmd = &cmdb; - struct sil_sata *sata = sata_dev_desc[dev].priv; struct sata_fis_d2h fis; void *port = sata->port; int ret;
/* put the port into known state */ if (sil_init_port(port)) { - printf("SRST: port %d not ready\n", dev); + printf("SRST: port %d not ready\n", sata->id); return 1; }
@@ -252,9 +286,9 @@ static int sil_cmd_soft_reset(int dev) pcmd->prb.fis.fis_type = SATA_FIS_TYPE_REGISTER_H2D; pcmd->prb.fis.pm_port_c = 0xf;
- ret = sil_exec_cmd(dev, &cmdb, 0); + ret = sil_exec_cmd(sata, &cmdb, 0); if (ret) { - sil_read_fis(dev, 0, &fis); + sil_read_fis(sata, 0, &fis); printf("SRST cmd error.\n"); sil_sata_dump_fis(&fis); return 1; @@ -263,10 +297,9 @@ static int sil_cmd_soft_reset(int dev) return 0; }
-static ulong sil_sata_rw_cmd(int dev, ulong start, ulong blkcnt, - u8 *buffer, int is_write) +static ulong sil_sata_rw_cmd(struct sil_sata *sata, ulong start, ulong blkcnt, + u8 *buffer, int is_write) { - struct sil_sata *sata = sata_dev_desc[dev].priv; struct sil_cmd_block cmdb, *pcmd = &cmdb; struct sata_fis_d2h fis; u64 block; @@ -296,9 +329,9 @@ static ulong sil_sata_rw_cmd(int dev, ulong start, ulong blkcnt, pcmd->sge.cnt = cpu_to_le32(blkcnt * ATA_SECT_SIZE); pcmd->sge.flags = cpu_to_le32(SGE_TRM);
- ret = sil_exec_cmd(dev, pcmd, 0); + ret = sil_exec_cmd(sata, pcmd, 0); if (ret) { - sil_read_fis(dev, 0, &fis); + sil_read_fis(sata, 0, &fis); printf("Err: rw cmd(0x%08x).\n", readl(sata->port + PORT_SERROR)); sil_sata_dump_fis(&fis); @@ -308,10 +341,9 @@ static ulong sil_sata_rw_cmd(int dev, ulong start, ulong blkcnt, return blkcnt; }
-static ulong sil_sata_rw_cmd_ext(int dev, ulong start, ulong blkcnt, - u8 *buffer, int is_write) +static ulong sil_sata_rw_cmd_ext(struct sil_sata *sata, ulong start, + ulong blkcnt, u8 *buffer, int is_write) { - struct sil_sata *sata = sata_dev_desc[dev].priv; struct sil_cmd_block cmdb, *pcmd = &cmdb; struct sata_fis_d2h fis; u64 block; @@ -344,9 +376,9 @@ static ulong sil_sata_rw_cmd_ext(int dev, ulong start, ulong blkcnt, pcmd->sge.cnt = cpu_to_le32(blkcnt * ATA_SECT_SIZE); pcmd->sge.flags = cpu_to_le32(SGE_TRM);
- ret = sil_exec_cmd(dev, pcmd, 0); + ret = sil_exec_cmd(sata, pcmd, 0); if (ret) { - sil_read_fis(dev, 0, &fis); + sil_read_fis(sata, 0, &fis); printf("Err: rw ext cmd(0x%08x).\n", readl(sata->port + PORT_SERROR)); sil_sata_dump_fis(&fis); @@ -356,8 +388,9 @@ static ulong sil_sata_rw_cmd_ext(int dev, ulong start, ulong blkcnt, return blkcnt; }
-static ulong sil_sata_rw_lba28(int dev, ulong blknr, lbaint_t blkcnt, - const void *buffer, int is_write) +static ulong sil_sata_rw_lba28(struct sil_sata *sata, ulong blknr, + lbaint_t blkcnt, const void *buffer, + int is_write) { ulong start, blks, max_blks; u8 *addr; @@ -369,12 +402,12 @@ static ulong sil_sata_rw_lba28(int dev, ulong blknr, lbaint_t blkcnt, max_blks = ATA_MAX_SECTORS; do { if (blks > max_blks) { - sil_sata_rw_cmd(dev, start, max_blks, addr, is_write); + sil_sata_rw_cmd(sata, start, max_blks, addr, is_write); start += max_blks; blks -= max_blks; addr += ATA_SECT_SIZE * max_blks; } else { - sil_sata_rw_cmd(dev, start, blks, addr, is_write); + sil_sata_rw_cmd(sata, start, blks, addr, is_write); start += blks; blks = 0; addr += ATA_SECT_SIZE * blks; @@ -384,8 +417,9 @@ static ulong sil_sata_rw_lba28(int dev, ulong blknr, lbaint_t blkcnt, return blkcnt; }
-static ulong sil_sata_rw_lba48(int dev, ulong blknr, lbaint_t blkcnt, - const void *buffer, int is_write) +static ulong sil_sata_rw_lba48(struct sil_sata *sata, ulong blknr, + lbaint_t blkcnt, const void *buffer, + int is_write) { ulong start, blks, max_blks; u8 *addr; @@ -397,14 +431,14 @@ static ulong sil_sata_rw_lba48(int dev, ulong blknr, lbaint_t blkcnt, max_blks = ATA_MAX_SECTORS_LBA48; do { if (blks > max_blks) { - sil_sata_rw_cmd_ext(dev, start, max_blks, - addr, is_write); + sil_sata_rw_cmd_ext(sata, start, max_blks, + addr, is_write); start += max_blks; blks -= max_blks; addr += ATA_SECT_SIZE * max_blks; } else { - sil_sata_rw_cmd_ext(dev, start, blks, - addr, is_write); + sil_sata_rw_cmd_ext(sata, start, blks, + addr, is_write); start += blks; blks = 0; addr += ATA_SECT_SIZE * blks; @@ -414,7 +448,7 @@ static ulong sil_sata_rw_lba48(int dev, ulong blknr, lbaint_t blkcnt, return blkcnt; }
-static void sil_sata_cmd_flush_cache(int dev) +static void sil_sata_cmd_flush_cache(struct sil_sata *sata) { struct sil_cmd_block cmdb, *pcmd = &cmdb;
@@ -423,10 +457,10 @@ static void sil_sata_cmd_flush_cache(int dev) pcmd->prb.fis.pm_port_c = (1 << 7); pcmd->prb.fis.command = ATA_CMD_FLUSH;
- sil_exec_cmd(dev, pcmd, 0); + sil_exec_cmd(sata, pcmd, 0); }
-static void sil_sata_cmd_flush_cache_ext(int dev) +static void sil_sata_cmd_flush_cache_ext(struct sil_sata *sata) { struct sil_cmd_block cmdb, *pcmd = &cmdb;
@@ -435,54 +469,30 @@ static void sil_sata_cmd_flush_cache_ext(int dev) pcmd->prb.fis.pm_port_c = (1 << 7); pcmd->prb.fis.command = ATA_CMD_FLUSH_EXT;
- sil_exec_cmd(dev, pcmd, 0); -} - -static void sil_sata_init_wcache(int dev, u16 *id) -{ - struct sil_sata *sata = sata_dev_desc[dev].priv; - - if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id)) - sata->wcache = 1; - if (ata_id_has_flush(id)) - sata->flush = 1; - if (ata_id_has_flush_ext(id)) - sata->flush_ext = 1; -} - -static int sil_sata_get_wcache(int dev) -{ - struct sil_sata *sata = sata_dev_desc[dev].priv; - - return sata->wcache; -} - -static int sil_sata_get_flush(int dev) -{ - struct sil_sata *sata = sata_dev_desc[dev].priv; - - return sata->flush; -} - -static int sil_sata_get_flush_ext(int dev) -{ - struct sil_sata *sata = sata_dev_desc[dev].priv; - - return sata->flush_ext; + sil_exec_cmd(sata, pcmd, 0); }
/* * SATA interface between low level driver and command layer */ +#if !CONFIG_IS_ENABLED(BLK) ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer) { - struct sil_sata *sata = sata_dev_desc[dev].priv; + sil_sata_t *sata = (sil_sata_t *)sata_dev_desc[dev].priv; +#else +static ulong sata_read(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, + void *buffer) +{ + struct sil_sata_priv *priv = dev_get_platdata(dev); + int port_number = priv->port_num; + sil_sata_t *sata = priv->sil_sata_desc[port_number]; +#endif ulong rc;
if (sata->lba48) - rc = sil_sata_rw_lba48(dev, blknr, blkcnt, buffer, READ_CMD); + rc = sil_sata_rw_lba48(sata, blknr, blkcnt, buffer, READ_CMD); else - rc = sil_sata_rw_lba28(dev, blknr, blkcnt, buffer, READ_CMD); + rc = sil_sata_rw_lba28(sata, blknr, blkcnt, buffer, READ_CMD);
return rc; } @@ -490,111 +500,48 @@ ulong sata_read(int dev, ulong blknr, lbaint_t blkcnt, void *buffer) /* * SATA interface between low level driver and command layer */ +#if !CONFIG_IS_ENABLED(BLK) ulong sata_write(int dev, ulong blknr, lbaint_t blkcnt, const void *buffer) { - struct sil_sata *sata = sata_dev_desc[dev].priv; + sil_sata_t *sata = (sil_sata_t *)sata_dev_desc[dev].priv; +#else +ulong sata_write(struct udevice *dev, lbaint_t blknr, lbaint_t blkcnt, + const void *buffer) +{ + struct sil_sata_priv *priv = dev_get_platdata(dev); + int port_number = priv->port_num; + sil_sata_t *sata = priv->sil_sata_desc[port_number]; +#endif ulong rc;
if (sata->lba48) { - rc = sil_sata_rw_lba48(dev, blknr, blkcnt, buffer, WRITE_CMD); - if (sil_sata_get_wcache(dev) && sil_sata_get_flush_ext(dev)) - sil_sata_cmd_flush_cache_ext(dev); + rc = sil_sata_rw_lba48(sata, blknr, blkcnt, buffer, WRITE_CMD); + if (sata->wcache && sata->flush_ext) + sil_sata_cmd_flush_cache_ext(sata); } else { - rc = sil_sata_rw_lba28(dev, blknr, blkcnt, buffer, WRITE_CMD); - if (sil_sata_get_wcache(dev) && sil_sata_get_flush(dev)) - sil_sata_cmd_flush_cache(dev); + rc = sil_sata_rw_lba28(sata, blknr, blkcnt, buffer, WRITE_CMD); + if (sata->wcache && sata->flush) + sil_sata_cmd_flush_cache(sata); }
return rc; }
-/* - * SATA interface between low level driver and command layer - */ -int init_sata(int dev) -{ - static int init_done, idx; - pci_dev_t devno; - u16 word; - - if (init_done == 1 && dev < sata_info.maxport) - return 0; - - init_done = 1; - - /* Find PCI device(s) */ - devno = pci_find_devices(supported, idx++); - if (devno == -1) - return 1; - - pci_read_config_word(devno, PCI_DEVICE_ID, &word); - - /* get the port count */ - word &= 0xf; - - sata_info.portbase = sata_info.maxport; - sata_info.maxport = sata_info.portbase + word; - sata_info.devno = devno; - - /* Read out all BARs */ - sata_info.iobase[0] = (ulong)pci_map_bar(devno, - PCI_BASE_ADDRESS_0, PCI_REGION_MEM); - sata_info.iobase[1] = (ulong)pci_map_bar(devno, - PCI_BASE_ADDRESS_2, PCI_REGION_MEM); - sata_info.iobase[2] = (ulong)pci_map_bar(devno, - PCI_BASE_ADDRESS_4, PCI_REGION_MEM); - - /* mask out the unused bits */ - sata_info.iobase[0] &= 0xffffff80; - sata_info.iobase[1] &= 0xfffffc00; - sata_info.iobase[2] &= 0xffffff80; - - /* Enable Bus Mastering and memory region */ - pci_write_config_word(devno, PCI_COMMAND, - PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); - - /* Check if mem accesses and Bus Mastering are enabled. */ - pci_read_config_word(devno, PCI_COMMAND, &word); - if (!(word & PCI_COMMAND_MEMORY) || - (!(word & PCI_COMMAND_MASTER))) { - printf("Error: Can not enable MEM access or Bus Mastering.\n"); - debug("PCI command: %04x\n", word); - return 1; - } - - /* GPIO off */ - writel(0, (void *)(sata_info.iobase[0] + HOST_FLASH_CMD)); - /* clear global reset & mask interrupts during initialization */ - writel(0, (void *)(sata_info.iobase[0] + HOST_CTRL)); - - return 0; -} - -int reset_sata(int dev) +#if !CONFIG_IS_ENABLED(BLK) +static int sil_init_sata(int dev) { - return 0; -} - -/* - * SATA interface between low level driver and command layer - */ -int scan_sata(int dev) +#else +static int sil_init_sata(struct udevice *uc_dev, int dev) { - unsigned char serial[ATA_ID_SERNO_LEN + 1]; - unsigned char firmware[ATA_ID_FW_REV_LEN + 1]; - unsigned char product[ATA_ID_PROD_LEN + 1]; - struct sil_sata *sata; + struct sil_sata_priv *priv = dev_get_platdata(uc_dev); +#endif + sil_sata_t *sata; void *port; - int cnt; - u16 *id; u32 tmp; + int cnt;
- if (dev >= sata_info.maxport) { - printf("SATA#%d is not present\n", dev); - return 1; - } + printf("SATA#%d:\n", dev);
- printf("SATA#%d\n", dev); port = (void *)sata_info.iobase[1] + PORT_REGS_SIZE * (dev - sata_info.portbase);
@@ -646,69 +593,270 @@ int scan_sata(int dev) return 1; }
- sata = (struct sil_sata *)malloc(sizeof(struct sil_sata)); + sata = (sil_sata_t *)malloc(sizeof(struct sil_sata)); if (!sata) { printf("%d no memory.\n", dev); return 1; } memset((void *)sata, 0, sizeof(struct sil_sata));
- /* turn on port interrupt */ - tmp = readl((void *)(sata_info.iobase[0] + HOST_CTRL)); - tmp |= (1 << (dev - sata_info.portbase)); - writel(tmp, (void *)(sata_info.iobase[0] + HOST_CTRL)); - /* Save the private struct to block device struct */ +#if !CONFIG_IS_ENABLED(BLK) sata_dev_desc[dev].priv = (void *)sata; +#else + priv->sil_sata_desc[dev] = sata; + priv->port_num = dev; +#endif + sata->id = dev; sata->port = port; sata->devno = sata_info.devno; sprintf(sata->name, "SATA#%d", dev); - sil_cmd_soft_reset(dev); + sil_cmd_soft_reset(sata); tmp = readl(port + PORT_SSTATUS); tmp = (tmp >> 4) & 0xf; printf(" (%s)\n", sata_spd_string(tmp));
+ return 0; +} + +#if !CONFIG_IS_ENABLED(BLK) +/* + * SATA interface between low level driver and command layer + */ +int init_sata(int dev) +{ + static int init_done, idx; + pci_dev_t devno; + u16 word; + + if (init_done == 1 && dev < sata_info.maxport) + goto init_start; + + init_done = 1; + + /* Find PCI device(s) */ + devno = pci_find_devices(supported, idx++); + if (devno == -1) + return 1; + + pci_read_config_word(devno, PCI_DEVICE_ID, &word); + + /* get the port count */ + word &= 0xf; + + sata_info.portbase = 0; + sata_info.maxport = sata_info.portbase + word; + sata_info.devno = devno; + + /* Read out all BARs */ + sata_info.iobase[0] = (ulong)pci_map_bar(devno, + PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + sata_info.iobase[1] = (ulong)pci_map_bar(devno, + PCI_BASE_ADDRESS_2, PCI_REGION_MEM); + + /* mask out the unused bits */ + sata_info.iobase[0] &= 0xffffff80; + sata_info.iobase[1] &= 0xfffffc00; + + /* Enable Bus Mastering and memory region */ + pci_write_config_word(devno, PCI_COMMAND, + PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); + + /* Check if mem accesses and Bus Mastering are enabled. */ + pci_read_config_word(devno, PCI_COMMAND, &word); + if (!(word & PCI_COMMAND_MEMORY) || + (!(word & PCI_COMMAND_MASTER))) { + printf("Error: Can not enable MEM access or Bus Mastering.\n"); + debug("PCI command: %04x\n", word); + return 1; + } + + /* GPIO off */ + writel(0, (void *)(sata_info.iobase[0] + HOST_FLASH_CMD)); + /* clear global reset & mask interrupts during initialization */ + writel(0, (void *)(sata_info.iobase[0] + HOST_CTRL)); + +init_start: + return sil_init_sata(dev); +} + +int reset_sata(int dev) +{ + return 0; +} + +/* + * SATA interface between low level driver and command layer + */ +int scan_sata(int dev) +{ + sil_sata_t *sata = (sil_sata_t *)sata_dev_desc[dev].priv; +#else +static int scan_sata(struct udevice *blk_dev, int dev) +{ + struct blk_desc *desc = dev_get_uclass_platdata(blk_dev); + struct sil_sata_priv *priv = dev_get_platdata(blk_dev); + sil_sata_t *sata = priv->sil_sata_desc[dev]; +#endif + unsigned char serial[ATA_ID_SERNO_LEN + 1]; + unsigned char firmware[ATA_ID_FW_REV_LEN + 1]; + unsigned char product[ATA_ID_PROD_LEN + 1]; + u16 *id; + id = (u16 *)malloc(ATA_ID_WORDS * 2); if (!id) { printf("Id malloc failed\n"); - free((void *)sata); return 1; } - sil_cmd_identify_device(dev, id); + sil_cmd_identify_device(sata, id);
-#ifdef CONFIG_LBA48 - /* Check if support LBA48 */ - if (ata_id_has_lba48(id)) { - sata_dev_desc[dev].lba48 = 1; - sata->lba48 = 1; - debug("Device supports LBA48\n"); - } else - debug("Device supports LBA28\n"); -#endif + sil_sata_set_feature_by_id(sata, id);
+#if !CONFIG_IS_ENABLED(BLK) + memcpy(sata_dev_desc[dev].product, serial, sizeof(serial)); + memcpy(sata_dev_desc[dev].revision, firmware, sizeof(firmware)); + memcpy(sata_dev_desc[dev].vendor, product, sizeof(product)); /* Totoal sectors */ sata_dev_desc[dev].lba = ata_id_n_sectors(id); - - sil_sata_init_wcache(dev, id); - sil_cmd_set_feature(dev); +#ifdef CONFIG_LBA48 + sata_dev_desc[dev].lba48 = sata->lba48; +#endif +#else + memcpy(desc->product, serial, sizeof(serial)); + memcpy(desc->revision, firmware, sizeof(firmware)); + memcpy(desc->vendor, product, sizeof(product)); + desc->lba = ata_id_n_sectors(id); +#ifdef CONFIG_LBA48 + desc->lba48 = sata->lba48; +#endif +#endif
#ifdef DEBUG - sil_cmd_identify_device(dev, id); ata_dump_id(id); #endif free((void *)id);
return 0; } + +#if CONFIG_IS_ENABLED(BLK) +static const struct blk_ops sata_sil_blk_ops = { + .read = sata_read, + .write = sata_write, +}; + +U_BOOT_DRIVER(sata_sil_driver) = { + .name = "sata_sil_blk", + .id = UCLASS_BLK, + .ops = &sata_sil_blk_ops, + .platdata_auto_alloc_size = sizeof(struct sil_sata_priv), +}; + +static int sil_pci_probe(struct udevice *dev) +{ + struct udevice *blk; + char sata_name[10]; + pci_dev_t devno; + u16 word; + int ret; + int i; + + /* Get PCI device number */ + devno = dm_pci_get_bdf(dev); + if (devno == -1) + return 1; + + dm_pci_read_config16(dev, PCI_DEVICE_ID, &word); + + /* get the port count */ + word &= 0xf; + + sata_info.portbase = 0; + sata_info.maxport = sata_info.portbase + word; + sata_info.devno = devno; + + /* Read out all BARs */ + sata_info.iobase[0] = (ulong)dm_pci_map_bar(dev, + PCI_BASE_ADDRESS_0, PCI_REGION_MEM); + sata_info.iobase[1] = (ulong)dm_pci_map_bar(dev, + PCI_BASE_ADDRESS_2, PCI_REGION_MEM); + + /* mask out the unused bits */ + sata_info.iobase[0] &= 0xffffff80; + sata_info.iobase[1] &= 0xfffffc00; + + /* Enable Bus Mastering and memory region */ + dm_pci_write_config16(dev, PCI_COMMAND, + PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); + + /* Check if mem accesses and Bus Mastering are enabled. */ + dm_pci_read_config16(dev, PCI_COMMAND, &word); + if (!(word & PCI_COMMAND_MEMORY) || + (!(word & PCI_COMMAND_MASTER))) { + printf("Error: Can not enable MEM access or Bus Mastering.\n"); + debug("PCI command: %04x\n", word); + return 1; + } + + /* GPIO off */ + writel(0, (void *)(sata_info.iobase[0] + HOST_FLASH_CMD)); + /* clear global reset & mask interrupts during initialization */ + writel(0, (void *)(sata_info.iobase[0] + HOST_CTRL)); + + for (i = sata_info.portbase; i < sata_info.maxport; i++) { + snprintf(sata_name, sizeof(sata_name), "sil_sata%d", i); + ret = blk_create_devicef(dev, "sata_sil_blk", sata_name, + IF_TYPE_SATA, -1, 512, 0, &blk); + if (ret) { + debug("Can't create device\n"); + return ret; + } + + ret = sil_init_sata(blk, i); + if (ret) + return -ENODEV; + + ret = scan_sata(blk, i); + if (ret) + return -ENODEV; + } + + return 0; +} + +static int sata_sil_scan(struct udevice *dev) +{ + /* Nothing to do here */ + + return 0; +} + +struct sil_ops sata_sil_ops = { + .scan = sata_sil_scan, +}; + +static const struct udevice_id sil_pci_ids[] = { + { .compatible = "sil-pci-sample" }, + { } +}; + +U_BOOT_DRIVER(sil_ahci_pci) = { + .name = "sil_ahci_pci", + .id = UCLASS_AHCI, + .of_match = sil_pci_ids, + .ops = &sata_sil_ops, + .probe = sil_pci_probe, + .priv_auto_alloc_size = sizeof(struct sil_sata_priv), +}; + +U_BOOT_PCI_DEVICE(sil_ahci_pci, supported); +#endif diff --git a/drivers/ata/sata_sil.h b/drivers/ata/sata_sil.h index 8b7cbdf..769dd3d 100644 --- a/drivers/ata/sata_sil.h +++ b/drivers/ata/sata_sil.h @@ -13,7 +13,7 @@ /* * SATA device driver struct for each dev */ -struct sil_sata { +typedef struct sil_sata { char name[12]; void *port; /* the port base address */ int lba48; @@ -24,7 +24,8 @@ struct sil_sata { int wcache; int flush; int flush_ext; -}; + int id; +} sil_sata_t;
/* sata info for each controller */ struct sata_info { @@ -210,4 +211,12 @@ enum { CMD_ERR = 0x21, };
+#if CONFIG_IS_ENABLED(BLK) +#define ATA_MAX_PORTS 32 +struct sil_sata_priv { + int port_num; + sil_sata_t *sil_sata_desc[ATA_MAX_PORTS]; +}; +#endif + #endif
Peng Ma
