[U-Boot-Users] questions regarding support for new command (getspr/setspr)
I was wondering if it was considered useful to extend the CFG_CMD_SETGETDCR done by Erik Theisen for DCR registers on the 4xx family to all PowerPC products for SPRs (CFG_CMD_SETGETSPR).
This is rather simple but can be a useful command.
If, so I had a few questions:
1. Is it ok that the command does not do any checking on the SPR number. This is quick difficult and would have to be done per processor since what SPRs exists is implementation specific. If the user gives the commands an SPR that does not exist the result is going to be some exception (is this ok) 2. What numerical format should the spr number for the command be taken in? My think is decimal 3. For setspr what numerical format should the spr value be taken in? My thinking is hex 4. For getspr what numerical format should the spr be printed in? My thinking is hex
If so, I will fixup my working patch and submit it once I get answers to the questions.
thanks
- kumar
That would be useful.
- Is it ok that the command does not do any checking on the SPR
IMHO only valid SPRs should be accepted. Yes, this requires processor specific code.
- What numerical format should the spr number for the command be taken
The format should be string (i. e. register NAME). For SPRs without a name and/or alternatively a decimal number is ok. Without a register name/number the "get" command should print all known SPR's on that processor.
- For setspr what numerical format should the spr value be taken in?
My thinking is hex
Hex like all standard input data in U-Boot.
- For getspr what numerical format should the spr be printed in? My
thinking is hex
The register name should be string plus decimal number; the value should be hex.
Thanks in advance.
Kumar Gala
