[U-Boot] [PATCH v5] serial: uartlite: Support for SERIAL_MULTI
Add support for SERIAL MULTI for uartlite.
Signed-off-by: Michal Simek monstr@monstr.eu
--- v2: Use in/out_be32 functions
v3: Clean coding style
v4: Simplify userial_ports array initialization
v5: const userial_ports Do not use u32 Separate declarations and code by a single blank line Update copyright --- common/serial.c | 14 ++++ drivers/serial/serial_xuartlite.c | 140 ++++++++++++++++++++++++++++++++----- include/serial.h | 7 ++ 3 files changed, 142 insertions(+), 19 deletions(-)
diff --git a/common/serial.c b/common/serial.c index 995d268..df02fa5 100644 --- a/common/serial.c +++ b/common/serial.c @@ -108,6 +108,20 @@ void serial_initialize (void) #if defined(CONFIG_SYS_BFIN_UART) serial_register_bfin_uart(); #endif +#if defined(CONFIG_XILINX_UARTLITE) +# ifdef XILINX_UARTLITE_BASEADDR + serial_register(&uartlite_serial0_device); +# endif /* XILINX_UARTLITE_BASEADDR */ +# ifdef XILINX_UARTLITE_BASEADDR1 + serial_register(&uartlite_serial1_device); +# endif /* XILINX_UARTLITE_BASEADDR1 */ +# ifdef XILINX_UARTLITE_BASEADDR2 + serial_register(&uartlite_serial2_device); +# endif /* XILINX_UARTLITE_BASEADDR2 */ +# ifdef XILINX_UARTLITE_BASEADDR3 + serial_register(&uartlite_serial3_device); +# endif /* XILINX_UARTLITE_BASEADDR3 */ +#endif /* CONFIG_XILINX_UARTLITE */ serial_assign (default_serial_console ()->name); }
diff --git a/drivers/serial/serial_xuartlite.c b/drivers/serial/serial_xuartlite.c index 00d0eaa..2dc6bd1 100644 --- a/drivers/serial/serial_xuartlite.c +++ b/drivers/serial/serial_xuartlite.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2008 Michal Simek monstr@monstr.eu + * (C) Copyright 2008-2011 Michal Simek monstr@monstr.eu * Clean driver and add xilinx constant from header file * * (C) Copyright 2004 Atmark Techno, Inc. @@ -25,20 +25,71 @@ */
#include <config.h> +#include <common.h> #include <asm/io.h> - -#define RX_FIFO_OFFSET 0 /* receive FIFO, read only */ -#define TX_FIFO_OFFSET 4 /* transmit FIFO, write only */ -#define STATUS_REG_OFFSET 8 /* status register, read only */ +#include <linux/compiler.h> +#include <serial.h>
#define SR_TX_FIFO_FULL 0x08 /* transmit FIFO full */ #define SR_RX_FIFO_VALID_DATA 0x01 /* data in receive FIFO */ #define SR_RX_FIFO_FULL 0x02 /* receive FIFO full */
-#define UARTLITE_STATUS (CONFIG_SERIAL_BASE + STATUS_REG_OFFSET) -#define UARTLITE_TX_FIFO (CONFIG_SERIAL_BASE + TX_FIFO_OFFSET) -#define UARTLITE_RX_FIFO (CONFIG_SERIAL_BASE + RX_FIFO_OFFSET) +struct uartlite { + unsigned int rx_fifo; + unsigned int tx_fifo; + unsigned int status; +}; + +static const struct uartlite *userial_ports[4] = { +#ifdef XILINX_UARTLITE_BASEADDR + [0] = (struct uartlite *)XILINX_UARTLITE_BASEADDR, +#endif +#ifdef XILINX_UARTLITE_BASEADDR1 + [1] = (struct uartlite *)XILINX_UARTLITE_BASEADDR1, +#endif +#ifdef XILINX_UARTLITE_BASEADDR2 + [2] = (struct uartlite *)XILINX_UARTLITE_BASEADDR2, +#endif +#ifdef XILINX_UARTLITE_BASEADDR3 + [3] = (struct uartlite *)XILINX_UARTLITE_BASEADDR3 +#endif +}; + +void uartlite_serial_putc(const char c, const int port) +{ + struct uartlite *regs = userial_ports[port]; + + if (c == '\n') + uartlite_serial_putc('\r', port); + + while (in_be32(®s->status) & SR_TX_FIFO_FULL) + ; + out_be32(®s->tx_fifo, c & 0xff); +} + +void uartlite_serial_puts(const char *s, const int port) +{ + while (*s) + uartlite_serial_putc(*s++, port); +} + +int uartlite_serial_getc(const int port) +{ + struct uartlite *regs = userial_ports[port]; + + while (!(in_be32(®s->status) & SR_RX_FIFO_VALID_DATA)) + ; + return in_be32(®s->rx_fifo) & 0xff; +} + +int uartlite_serial_tstc(const int port) +{ + struct uartlite *regs = userial_ports[port];
+ return in_be32(®s->status) & SR_RX_FIFO_VALID_DATA; +} + +#if !defined(CONFIG_SERIAL_MULTI) int serial_init(void) { /* FIXME: Nothing for now. We should initialize fifo, etc */ @@ -52,26 +103,77 @@ void serial_setbrg(void)
void serial_putc(const char c) { - if (c == '\n') - serial_putc('\r'); - while (in_be32((u32 *) UARTLITE_STATUS) & SR_TX_FIFO_FULL); - out_be32((u32 *) UARTLITE_TX_FIFO, (unsigned char) (c & 0xff)); + uartlite_serial_putc(c, 0); }
-void serial_puts(const char * s) +void serial_puts(const char *s) { - while (*s) { - serial_putc(*s++); - } + uartlite_serial_puts(s, 0); }
int serial_getc(void) { - while (!(in_be32((u32 *) UARTLITE_STATUS) & SR_RX_FIFO_VALID_DATA)); - return in_be32((u32 *) UARTLITE_RX_FIFO) & 0xff; + return uartlite_serial_getc(0); }
int serial_tstc(void) { - return (in_be32((u32 *) UARTLITE_STATUS) & SR_RX_FIFO_VALID_DATA); + return uartlite_serial_tstc(0); +} +#endif + +#if defined(CONFIG_SERIAL_MULTI) +/* Multi serial device functions */ +#define DECLARE_ESERIAL_FUNCTIONS(port) \ + int userial##port##_init(void) \ + { return(0); } \ + void userial##port##_setbrg(void) {} \ + int userial##port##_getc(void) \ + { return uartlite_serial_getc(port); } \ + int userial##port##_tstc(void) \ + { return uartlite_serial_tstc(port); } \ + void userial##port##_putc(const char c) \ + { uartlite_serial_putc(c, port); } \ + void userial##port##_puts(const char *s) \ + { uartlite_serial_puts(s, port); } + +/* Serial device descriptor */ +#define INIT_ESERIAL_STRUCTURE(port, name) {\ + name,\ + userial##port##_init,\ + NULL,\ + userial##port##_setbrg,\ + userial##port##_getc,\ + userial##port##_tstc,\ + userial##port##_putc,\ + userial##port##_puts, } + +DECLARE_ESERIAL_FUNCTIONS(0); +struct serial_device uartlite_serial0_device = + INIT_ESERIAL_STRUCTURE(0, "ttyUL0"); +DECLARE_ESERIAL_FUNCTIONS(1); +struct serial_device uartlite_serial1_device = + INIT_ESERIAL_STRUCTURE(1, "ttyUL1"); +DECLARE_ESERIAL_FUNCTIONS(2); +struct serial_device uartlite_serial2_device = + INIT_ESERIAL_STRUCTURE(2, "ttyUL2"); +DECLARE_ESERIAL_FUNCTIONS(3); +struct serial_device uartlite_serial3_device = + INIT_ESERIAL_STRUCTURE(3, "ttyUL3"); + +__weak struct serial_device *default_serial_console(void) +{ +# ifdef XILINX_UARTLITE_BASEADDR + return &uartlite_serial0_device; +# endif /* XILINX_UARTLITE_BASEADDR */ +# ifdef XILINX_UARTLITE_BASEADDR1 + return &uartlite_serial1_device; +# endif /* XILINX_UARTLITE_BASEADDR1 */ +# ifdef XILINX_UARTLITE_BASEADDR2 + return &uartlite_serial2_device; +# endif /* XILINX_UARTLITE_BASEADDR2 */ +# ifdef XILINX_UARTLITE_BASEADDR3 + return &uartlite_serial3_device; +# endif /* XILINX_UARTLITE_BASEADDR3 */ } +#endif /* CONFIG_SERIAL_MULTI */ diff --git a/include/serial.h b/include/serial.h index 31c1235..f047d2f 100644 --- a/include/serial.h +++ b/include/serial.h @@ -50,6 +50,13 @@ extern struct serial_device serial4_device; extern struct serial_device serial6_device; #endif
+#if defined(CONFIG_XILINX_UARTLITE) +extern struct serial_device uartlite_serial0_device; +extern struct serial_device uartlite_serial1_device; +extern struct serial_device uartlite_serial2_device; +extern struct serial_device uartlite_serial3_device; +#endif + #if defined(CONFIG_S3C2410) extern struct serial_device s3c24xx_serial0_device; extern struct serial_device s3c24xx_serial1_device;
Wolfgang: Can you please comment it or applied?
Thanks, Michal
Dear Michal Simek,
Applied, thanks.
Dear Michal Simek,
This commit causes new warnings for the following boards:
ml507 v5fx30teval_flash xilinx-ppc440-generic ml507_flash xilinx-ppc405-generic xilinx-ppc440-generic_f v5fx30teval xilinx-ppc405-generic_f
For example:
Configuring for xilinx-ppc440-generic - Board: xilinx-ppc440-generic, Options: SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1 serial_xuartlite.c: In function 'uartlite_serial_putc': serial_xuartlite.c:60: warning: initialization discards qualifiers from pointer target type serial_xuartlite.c: In function 'uartlite_serial_getc': serial_xuartlite.c:78: warning: initialization discards qualifiers from pointer target type serial_xuartlite.c: In function 'uartlite_serial_tstc': serial_xuartlite.c:87: warning: initialization discards qualifiers from pointer target type
Please fix.
Michal Simek
