[PATCH] ARM: stm32: Allow overriding setup_mac_address()
Let board code override setup_mac_address(), which is useful e.g. if the board derives the MAC address from another source, like an I2C EEPROM.
Signed-off-by: Marek Vasut marex@denx.de Cc: Patrick Delaunay patrick.delaunay@st.com Cc: Patrice Chotard patrice.chotard@st.com --- arch/arm/mach-stm32mp/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index ed7d9f61dc..856c7ced7a 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -449,7 +449,7 @@ static void setup_boot_mode(void) * If there is no MAC address in the environment, then it will be initialized * (silently) from the value in the OTP. */ -static int setup_mac_address(void) +__weak int setup_mac_address(void) { #if defined(CONFIG_NET) int ret;
Hi Marek,
From: Marek Vasut marex@denx.de Sent: mercredi 18 décembre 2019 07:59
Reviewed-by: Patrick Delaunay patrick.delaunay@st.com
- If there is no MAC address in the environment, then it will be initialized
- (silently) from the value in the OTP.
Perhaps add prototype in: arch/arm/mach-stm32mp/include/mach/sys_proto.h
just to avoid the new warning with W=1
warning: no previous prototype for 'setup_mac_address' [-Wmissing-prototypes]
{ #if defined(CONFIG_NET) int ret; -- 2.24.1
But anyway
Regards
Patrick DELAUNAY
