[U-Boot] [PATCH 0/2] Re-add support for 'Standalone Programs'
Re-add logic to start 'Standalone Programs'. Although the code was lifted from a previous code base, I'm not so sure anymore if we handle 'autostart' here correctly. The DULG has no mention of this specific handling. On the other hand I know that this was "creatively misused" to allow for decompression of data blobs - therefore I left it in currently.
En passant, we introduce error checking for unsupported os types, where the previous code happily jumped to a relocated NULL pointer ;)
Detlev Zundel (2): Add error checking for unsupported OS types. Re-add support for image type 'Standalone Program'
common/cmd_bootm.c | 48 ++++++++++++++++++++++++++++++++++++++++++++++-- 1 files changed, 46 insertions(+), 2 deletions(-)
Signed-off-by: Detlev Zundel dzu@denx.de --- common/cmd_bootm.c | 15 +++++++++++++-- 1 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 367d5a7..d0a6bf7 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2000-2006 + * (C) Copyright 2000-2009 * Wolfgang Denk, DENX Software Engineering, wd@denx.de. * * See file CREDITS for list of people who contributed to this @@ -549,7 +549,8 @@ int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) if (!relocated) { int i; for (i = 0; i < ARRAY_SIZE(boot_os); i++) - boot_os[i] += gd->reloc_off; + if (boot_os[i] != NULL) + boot_os[i] += gd->reloc_off; relocated = 1; }
@@ -637,6 +638,16 @@ int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) #endif
boot_fn = boot_os[images.os.os]; + + if (boot_fn == NULL) { + if (iflag) + enable_interrupts(); + printf ("ERROR: booting os '%s' (%d) is not supported\n", + genimg_get_os_name(images.os.os), images.os.os); + show_boot_progress (-8); + return 1; + } + boot_fn(0, argc, argv, &images);
show_boot_progress (-9);
Support for this type was lost during the bootm refactoring.
Signed-off-by: Detlev Zundel dzu@denx.de --- common/cmd_bootm.c | 33 +++++++++++++++++++++++++++++++++ 1 files changed, 33 insertions(+), 0 deletions(-)
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index d0a6bf7..e9389b7 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -418,6 +418,24 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) return 0; }
+static int bootm_start_standalone(ulong iflag, int argc, char *argv[]) +{ + char *s; + int (*appl)(int, char *[]); + + /* Don't start if "autostart" is set to "no" */ + if (((s = getenv("autostart")) != NULL) && (strcmp(s, "no") == 0)) { + char buf[32]; + sprintf(buf, "%lX", images.os.image_len); + setenv("filesize", buf); + return 0; + } + appl = (int (*)(int, char *[]))ntohl(images.ep); + (*appl)(argc-1, &argv[1]); + + return 0; +} + /* we overload the cmd field with our state machine info instead of a * function pointer */ cmd_tbl_t cmd_bootm_sub[] = { @@ -630,6 +648,14 @@ int do_bootm (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
lmb_reserve(&images.lmb, images.os.load, (load_end - images.os.load));
+ if (images.os.type == IH_TYPE_STANDALONE) { + if (iflag) + enable_interrupts(); + /* This may return when 'autostart' is 'no' */ + bootm_start_standalone(iflag, argc, argv); + return 0; + } + show_boot_progress (8);
#ifdef CONFIG_SILENT_CONSOLE @@ -829,6 +855,13 @@ static void *boot_get_kernel (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[] case IH_TYPE_MULTI: image_multi_getimg (hdr, 0, os_data, os_len); break; + case IH_TYPE_STANDALONE: + if (argc >2) { + hdr->ih_load = htonl(simple_strtoul(argv[2], NULL, 16)); + } + *os_data = image_get_data (hdr); + *os_len = image_get_data_size (hdr); + break; default: printf ("Wrong Image Type for %s command\n", cmdtp->name); show_boot_progress (-5);
Dear Detlev Zundel,
Applied, thanks.
Dear Detlev Zundel,
Applied, thanks.
Detlev Zundel
