[U-Boot-Users] Looking for Help booting Kernel
I am trying to boot the latest kernel for a MPC5200B based board from DENX. I built the latest UBoot which seems to run fine on my board.
With the new uboot, my same environment variables, I can still boot my old kernel.
U-Boot 1.3.0-rc2-dirty (Sep 24 2007 - 08:08:49)
CPU: MPC5200 v1.2, Core v1.1 at 462 MHz Bus 132 MHz, IPB 132 MHz, PCI 33 MHz Board: MyBoard MPC5200 Controller I2C: 343 kHz, ready DRAM: 128 MB FLASH: 64 MB In: serial Out: serial Err: serial Net: FEC ETHERNET IDE: Bus 0: not available
Type "run net_nfs" to mount root filesystem over NFS
Hit any key to stop autoboot: 0 Using FEC ETHERNET device TFTP from server 192.168.100.102; our IP address is 192.168.100.11 Filename 'uImage'. Load address: 0x200000 Loading: ################################################################# ############################################# done Bytes transferred = 1612360 (189a48 hex) ## Booting image at 00200000 ... Image Name: Linux-2.6.19.2 Created: 2007-09-21 8:11:59 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1612296 Bytes = 1.5 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK id mach(): done MMU:enter MMU:hw init MMU:mapin MMU:setio MMU:exit setup_arch: enter setup_arch: bootmem arch: exit Linux version 2.6.19.2 (nick@nick_lnx) (gcc version 4.0.0 (DENX ELDK 4.1 4.0.0)) \ #5 Fri Sep 21 04:11:50 EDT 2007 Zone PFN ranges: DMA 0 -> 32768 Normal 32768 -> 32768 early_node_map[1] active PFN ranges 0: 0 -> 32768 Built 1 zonelists. Total pages: 32512 Kernel command line: root=/dev/nfs rw nfsroot=192.168.100.102:/opt/eldk/ppc_6xx \ ip=192.168.100.11:192.168.100.102:192.168.100.102:255.255.255.0:\ MyBoard:eth0:off console=ttyPSC0,115200 panic=1 PID hash table entries: 512 (order: 9, 2048 bytes) I-pipe 1.5-00: pipeline enabled. Console: colour dummy device 80x25
... and the kernel runs fine. With the latest kernel from Denx, I get the following:
Hit any key to stop autoboot: 0 => boot Using FEC ETHERNET device TFTP from server 192.168.100.102; our IP address is 192.168.100.11 Filename 'uImage'. Load address: 0x200000 Loading: ################################################################# ################## done Bytes transferred = 1212323 (127fa3 hex) ## Booting image at 00200000 ... Image Name: Linux-2.6.23-rc6-gea60adb5-dirty Created: 2007-09-26 9:53:02 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1212259 Bytes = 1.2 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Is there anything special I need to pass to the kernel for setting up the console on the MPC5200B? I had to change ttyS0 to ttyPSC0 for the old console to work. Is there anything I need to enable inside the kernel?
The kernel command line is:
Many thanks,
Nick
What are you talking about - is this an arch/ppc or an arch/powerpc configuration? If you use an arch/powerpc configuration, you have to pass a device tree to Linux, too.
Yes this is a arch/powerpc configuration. I got the device tree compiler, copied/configured a .dts file for my board and compiled it to a .dtb file. I still don't see any output on my console.
Here are the commands from uboot:
Hit any key to stop autoboot: 0 => tftp 00800000 myboard.dtb Using FEC ETHERNET device TFTP from server 192.168.100.102; our IP address is 192.168.100.11 Filename 'myboard.dtb'. Load address: 0x800000 Loading: # done Bytes transferred = 12288 (3000 hex) => fdt addr 00800000 3000 => fdt boardsetup => tftp 00200000 uImage Using FEC ETHERNET device TFTP from server 192.168.100.102; our IP address is 192.168.100.11 Filename 'uImage'. Load address: 0x200000 Loading: ################################################################# ################## done Bytes transferred = 1212322 (127fa2 hex) => bootm 00200000 - 00800000 ## Booting image at 00200000 ... Image Name: Linux-2.6.23-rc6-gea60adb5-dirty Created: 2007-09-26 23:21:49 UTC Image Type: PowerPC Linux Kernel Image (gzip compressed) Data Size: 1212258 Bytes = 1.2 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK Booting using the fdt at 0x800000 Loading Device Tree to 007fc000, end 007fefff ... OK
I enclosed my .dts file as well
Thanks again,
Nick
/* * Myboard Device Tree Source * * * This program is free software; you can redistribute it and/or modify it * under the terms of the GNU General Public License as published by the * Free Software Foundation; either version 2 of the License, or (at your * option) any later version. */
/* * WARNING: Do not depend on this tree layout remaining static just yet. * The MPC5200 device tree conventions are still in flux * Keep an eye on the linuxppc-dev mailing list for more details */
/ { model = "fsl,myboard"; // revision = "1.0"; compatible = "fsl,bmboard\0generic-mpc5200"; #address-cells = <1>; #size-cells = <1>;
cpus { #address-cells = <1>; #size-cells = <0>;
PowerPC,5200@0 { device_type = "cpu"; reg = <0>; d-cache-line-size = <20>; i-cache-line-size = <20>; d-cache-size = <4000>; // L1, 16K i-cache-size = <4000>; // L1, 16K timebase-frequency = <0>; // from bootloader bus-frequency = <0>; // from bootloader clock-frequency = <0>; // from bootloader 32-bit; }; };
memory { device_type = "memory"; reg = <00000000 8000000>; // 128MB };
soc5200@f0000000 { model = "fsl,mpc5200b"; compatible = "mpc5200"; revision = ""; // from bootloader #interrupt-cells = <3>; device_type = "soc"; ranges = <0 f0000000 f0010000>; reg = <f0000000 00000100>; bus-frequency = <0>; // from bootloader system-frequency = <0>; // from bootloader
cdm@200 { compatible = "mpc5200b-cdm\0mpc5200-cdm"; reg = <200 38>; };
mpc5200_pic: pic@500 { // 5200 interrupts are encoded into two levels; interrupt-controller; #interrupt-cells = <3>; device_type = "interrupt-controller"; compatible = "mpc5200b-pic\0mpc5200-pic"; reg = <500 80>; built-in; };
gpt@600 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <0>; reg = <600 10>; interrupts = <1 9 0>; interrupt-parent = <&mpc5200_pic>; has-wdt; };
gpt@610 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <1>; reg = <610 10>; interrupts = <1 a 0>; interrupt-parent = <&mpc5200_pic>; };
gpt@620 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <2>; reg = <620 10>; interrupts = <1 b 0>; interrupt-parent = <&mpc5200_pic>; };
gpt@630 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <3>; reg = <630 10>; interrupts = <1 c 0>; interrupt-parent = <&mpc5200_pic>; };
gpt@640 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <4>; reg = <640 10>; interrupts = <1 d 0>; interrupt-parent = <&mpc5200_pic>; };
gpt@650 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <5>; reg = <650 10>; interrupts = <1 e 0>; interrupt-parent = <&mpc5200_pic>; };
gpt@660 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <6>; reg = <660 10>; interrupts = <1 f 0>; interrupt-parent = <&mpc5200_pic>; };
gpt@670 { // General Purpose Timer compatible = "mpc5200b-gpt\0mpc5200-gpt"; device_type = "gpt"; cell-index = <7>; reg = <670 10>; interrupts = <1 10 0>; interrupt-parent = <&mpc5200_pic>; };
rtc@800 { // Real time clock compatible = "mpc5200b-rtc\0mpc5200-rtc"; device_type = "rtc"; reg = <800 100>; interrupts = <1 5 0 1 6 0>; interrupt-parent = <&mpc5200_pic>; };
mscan@900 { device_type = "mscan"; compatible = "mpc5200b-mscan\0mpc5200-mscan"; cell-index = <0>; interrupts = <2 11 0>; interrupt-parent = <&mpc5200_pic>; reg = <900 80>; };
mscan@980 { device_type = "mscan"; compatible = "mpc5200b-mscan\0mpc5200-mscan"; cell-index = <1>; interrupts = <2 12 0>; interrupt-parent = <&mpc5200_pic>; reg = <980 80>; };
gpio@b00 { compatible = "mpc5200b-gpio\0mpc5200-gpio"; reg = <b00 40>; interrupts = <1 7 0>; interrupt-parent = <&mpc5200_pic>; };
gpio-wkup@c00 { compatible = "mpc5200b-gpio-wkup\0mpc5200-gpio-wkup"; reg = <c00 40>; interrupts = <1 8 0 0 3 0>; interrupt-parent = <&mpc5200_pic>; };
spi@f00 { device_type = "spi"; compatible = "mpc5200b-spi\0mpc5200-spi"; reg = <f00 20>; interrupts = <2 d 0 2 e 0>; interrupt-parent = <&mpc5200_pic>; };
usb@1000 { device_type = "usb-ohci-be"; compatible = "mpc5200b-ohci\0mpc5200-ohci\0ohci-be"; reg = <1000 ff>; interrupts = <2 6 0>; interrupt-parent = <&mpc5200_pic>; };
// bestcomm@1200 { // device_type = "dma-controller"; // compatible = "mpc5200b-bestcomm\0mpc5200-bestcomm"; // reg = <1200 80>; // interrupts = <3 0 0 3 1 0 3 2 0 3 3 0 // 3 4 0 3 5 0 3 6 0 3 7 0 // 3 8 0 3 9 0 3 a 0 3 b 0 // 3 c 0 3 d 0 3 e 0 3 f 0>; // interrupt-parent = <&mpc5200_pic>; // };
xlb@1f00 { compatible = "mpc5200b-xlb\0mpc5200-xlb"; reg = <1f00 100>; };
// PSC1 in uart mode serial@2000 { // PSC1 device_type = "serial"; compatible = "mpc5200b-psc-uart\0mpc5200-psc-uart"; port-number = <0>; // Logical port assignment cell-index = <0>; reg = <2000 100>; interrupts = <2 1 0>; interrupt-parent = <&mpc5200_pic>; };
// PSC2 in uart mode // serial@2200 { // PSC2 // device_type = "serial"; // compatible = "mpc5200b-psc-uart\0mpc5200-psc-uart"; // port-number = <1>; // Logical port assignment // cell-index = <1>; // reg = <2200 100>; // interrupts = <2 2 0>; // interrupt-parent = <&mpc5200_pic>; // };
// PSC3 in uart mode example // serial@2400 { // PSC3 // device_type = "serial"; // compatible = "mpc5200b-psc-uart\0mpc5200-psc-uart"; // cell-index = <2>; // reg = <2400 100>; // interrupts = <2 3 0>; // interrupt-parent = <&mpc5200_pic>; // }; // PSC4 in uart mode example // serial@2600 { // PSC4 // device_type = "serial"; // compatible = "mpc5200b-psc-uart\0mpc5200-psc-uart"; // cell-index = <3>; // reg = <2600 100>; // interrupts = <2 b 0>; // interrupt-parent = <&mpc5200_pic>; // };
ethernet@3000 { device_type = "network"; compatible = "mpc5200b-fec\0mpc5200-fec"; reg = <3000 800>; mac-address = [ 02 03 04 05 06 07 ]; // Bad! interrupts = <2 5 0>; interrupt-parent = <&mpc5200_pic>; };
ata@3a00 { device_type = "ata"; compatible = "mpc5200b-ata\0mpc5200-ata"; reg = <3a00 100>; interrupts = <2 7 0>; interrupt-parent = <&mpc5200_pic>; };
i2c@3d00 { device_type = "i2c"; compatible = "mpc5200b-i2c\0mpc5200-i2c\0fsl-i2c"; cell-index = <0>; reg = <3d00 40>; interrupts = <2 f 0>; interrupt-parent = <&mpc5200_pic>; fsl5200-clocking; };
i2c@3d40 { device_type = "i2c"; compatible = "mpc5200b-i2c\0mpc5200-i2c\0fsl-i2c"; cell-index = <1>; reg = <3d40 40>; interrupts = <2 10 0>; interrupt-parent = <&mpc5200_pic>; fsl5200-clocking; }; sram@8000 { device_type = "sram"; compatible = "mpc5200b-sram\0mpc5200-sram\0sram"; reg = <8000 4000>; }; }; chosen { linux,stdout-path = "/soc5200@f0000000/serial@2000"; bootargs = "console=ttyPSC0,115200 panic=1"; }; };
Nick Droogh
