[U-Boot] [PATCH 01/13] imx: arch-mx6: add is_soc_type helper macro
Add helper macro is_soc_type to identify iMX SoC family
Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Rework for common sys_proto header file
arch/arm/include/asm/arch-imx/cpu.h | 2 ++ arch/arm/include/asm/imx-common/sys_proto.h | 3 +++ 2 files changed, 5 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index be13b96..708f13d 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -22,6 +22,8 @@ #define MXC_CPU_MX6DP 0x68 #define MXC_CPU_MX6QP 0x69
+#define MXC_SOC_MX6 0x60 + #define CS0_128 0 #define CS0_64M_CS1_64M 1 #define CS0_64M_CS1_32M_CS2_32M 2 diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index 6954ee9..c0a37e1 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -17,9 +17,12 @@
/* returns MXC_CPU_ value */ #define cpu_type(rev) (((rev) >> 12) & 0xff) +#define soc_type(rev) (((rev) >> 12) & 0xf0) /* both macros return/take MXC_CPU_ constants */ #define get_cpu_type() (cpu_type(get_cpu_rev())) +#define get_soc_type() (soc_type(get_cpu_rev())) #define is_cpu_type(cpu) (get_cpu_type() == cpu) +#define is_soc_type(soc) (get_soc_type() == soc)
#define is_mx6dqp() (is_cpu_type(MXC_CPU_MX6QP) || is_cpu_type(MXC_CPU_MX6DP))
Rework imx_thermal driver to be used across i.MX processor that support thermal sensor
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- Changes for V2: Rename read_cpu_temperature to read_cpu_temperature_mx6 use is_soc_type macro to identify iMX SoC family to call the correspondind read_cpu_temperature function per iMX SoC family. Changes for V3: Rework path for git://git.denx.de/u-boot-imx.git (master)
arch/arm/cpu/armv7/mx6/soc.c | 2 +- arch/arm/imx-common/cpu.c | 10 ++++------ drivers/thermal/Makefile | 2 +- drivers/thermal/imx_thermal.c | 18 +++++++++++------- include/configs/cgtqmx6eval.h | 4 ++-- include/configs/embestmx6boards.h | 2 +- include/configs/gw_ventana.h | 2 +- include/configs/mx6cuboxi.h | 2 +- include/configs/mx6sabre_common.h | 2 +- include/configs/mx6slevk.h | 2 +- include/configs/mx6sxsabresd.h | 2 +- include/configs/mx6ul_14x14_evk.h | 2 +- include/configs/tbs2910.h | 2 +- 13 files changed, 27 insertions(+), 25 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 8ad8da8..5110112 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -38,7 +38,7 @@ struct scu_regs { u32 fpga_rev; };
-#if defined(CONFIG_IMX6_THERMAL) +#if defined(CONFIG_IMX_THERMAL) static const struct imx_thermal_plat imx6_thermal_plat = { .regs = (void *)ANATOP_BASE_ADDR, .fuse_bank = 1, diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index e27546c..38cd0c8 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -154,14 +154,12 @@ int print_cpuinfo(void) u32 cpurev; __maybe_unused u32 max_freq;
-#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) + cpurev = get_cpu_rev(); + +#if defined(CONFIG_IMX_THERMAL) struct udevice *thermal_dev; int cpu_tmp, minc, maxc, ret; -#endif
- cpurev = get_cpu_rev(); - -#if defined(CONFIG_MX6) printf("CPU: Freescale i.MX%s rev%d.%d", get_imx_type((cpurev & 0xFF000) >> 12), (cpurev & 0x000F0) >> 4, @@ -181,7 +179,7 @@ int print_cpuinfo(void) mxc_get_clock(MXC_ARM_CLK) / 1000000); #endif
-#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) +#if defined(CONFIG_IMX_THERMAL) puts("CPU: "); switch (get_cpu_temp_grade(&minc, &maxc)) { case TEMP_AUTOMOTIVE: diff --git a/drivers/thermal/Makefile b/drivers/thermal/Makefile index 6d4cacd..d768f5e 100644 --- a/drivers/thermal/Makefile +++ b/drivers/thermal/Makefile @@ -6,4 +6,4 @@ #
obj-$(CONFIG_DM_THERMAL) += thermal-uclass.o -obj-$(CONFIG_IMX6_THERMAL) += imx_thermal.o +obj-$(CONFIG_IMX_THERMAL) += imx_thermal.o diff --git a/drivers/thermal/imx_thermal.c b/drivers/thermal/imx_thermal.c index 3c6c967..d90874e 100644 --- a/drivers/thermal/imx_thermal.c +++ b/drivers/thermal/imx_thermal.c @@ -41,7 +41,7 @@ struct thermal_data { int maxc; };
-static int read_cpu_temperature(struct udevice *dev) +static int read_cpu_temperature_mx6(struct udevice *dev) { int temperature; unsigned int reg, n_meas; @@ -129,13 +129,15 @@ int imx_thermal_get_temp(struct udevice *dev, int *temp) struct thermal_data *priv = dev_get_priv(dev); int cpu_tmp = 0;
- cpu_tmp = read_cpu_temperature(dev); + if (is_soc_type(MXC_SOC_MX6)) + cpu_tmp = read_cpu_temperature_mx6(dev); while (cpu_tmp >= priv->critical) { printf("CPU Temperature (%dC) too close to max (%dC)", cpu_tmp, priv->maxc); puts(" waiting...\n"); udelay(5000000); - cpu_tmp = read_cpu_temperature(dev); + if (is_soc_type(MXC_SOC_MX6)) + cpu_tmp = read_cpu_temperature_mx6(dev); }
*temp = cpu_tmp; @@ -157,10 +159,12 @@ static int imx_thermal_probe(struct udevice *dev) /* Read Temperature calibration data fuse */ fuse_read(pdata->fuse_bank, pdata->fuse_word, &fuse);
- /* Check for valid fuse */ - if (fuse == 0 || fuse == ~0) { - printf("CPU: Thermal invalid data, fuse: 0x%x\n", fuse); - return -EPERM; + if (is_soc_type(MXC_SOC_MX6)) { + /* Check for valid fuse */ + if (fuse == 0 || fuse == ~0) { + printf("CPU: Thermal invalid data, fuse: 0x%x\n", fuse); + return -EPERM; + } }
/* set critical cooling temp */ diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 92930c8..55a0664 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -33,10 +33,10 @@ #define CONFIG_CMD_BMODE
/* Thermal support */ -#define CONFIG_IMX6_THERMAL +#define CONFIG_IMX_THERMAL
#define CONFIG_CMD_FUSE -#if defined(CONFIG_CMD_FUSE) || defined(CONFIG_IMX6_THERMAL) +#if defined(CONFIG_CMD_FUSE) || defined(CONFIG_IMX_THERMAL) #define CONFIG_MXC_OCOTP #endif
diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 12744a6..58cee96 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -19,7 +19,7 @@
#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 7c90812..397a5ab 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -57,7 +57,7 @@ #define CONFIG_CMD_GPIO
/* Thermal */ -#define CONFIG_IMX6_THERMAL +#define CONFIG_IMX_THERMAL
/* Serial */ #define CONFIG_MXC_UART diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 634a09f..6e89dd1 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -14,7 +14,7 @@ #define CONFIG_SPL_MMC_SUPPORT #include "imx6_spl.h"
#define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) #define CONFIG_BOARD_EARLY_INIT_F diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 6a57841..98eb042 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -11,7 +11,7 @@
#include "mx6_common.h"
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (10 * SZ_1M) diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 04d53a7..0a641c2 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -197,6 +197,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 1 /* SDHC2*/ #endif
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 74d04a0..f30c148 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -177,7 +177,7 @@ #define CONFIG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) #endif
#define CONFIG_CMD_TIME
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index f643e4d..7850e68 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -242,6 +242,6 @@ #define CONFIG_FEC_DMA_MINALIGN 64 #endif
#endif diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 14985f8..4f390c3 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -21,7 +21,7 @@ #define CONFIG_SYS_PROMPT "Matrix U-Boot> " #define CONFIG_SYS_HZ 1000
/* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1
Rework cache settings for imx6, move cache configuration to imx-common/cache.c so it can be reused for newer SoC
Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Resend
arch/arm/cpu/armv7/mx6/soc.c | 95 --------------------------------------- arch/arm/imx-common/Makefile | 1 + arch/arm/imx-common/cache.c | 103 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 104 insertions(+), 95 deletions(-) create mode 100644 arch/arm/imx-common/cache.c
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 5110112..2f7d5c8 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -8,9 +8,6 @@ */
#include <common.h> -#include <asm/armv7.h> -#include <asm/bootm.h> -#include <asm/pl310.h> #include <asm/errno.h> #include <asm/io.h> #include <asm/arch/imx-regs.h> @@ -440,31 +437,6 @@ int board_postclk_init(void) return 0; }
-#ifndef CONFIG_SYS_DCACHE_OFF -void enable_caches(void) -{ -#if defined(CONFIG_SYS_ARM_CACHE_WRITETHROUGH) - enum dcache_option option = DCACHE_WRITETHROUGH; -#else - enum dcache_option option = DCACHE_WRITEBACK; -#endif - - /* Avoid random hang when download by usb */ - invalidate_dcache_all(); - - /* Enable D-cache. I-cache is already enabled in start.S */ - dcache_enable(); - - /* Enable caching on OCRAM and ROM */ - mmu_set_region_dcache_behaviour(ROMCP_ARB_BASE_ADDR, - ROMCP_ARB_END_ADDR, - option); - mmu_set_region_dcache_behaviour(IRAM_BASE_ADDR, - IRAM_SIZE, - option); -} -#endif - #if defined(CONFIG_FEC_MXC) void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) { @@ -605,70 +577,3 @@ void imx_setup_hdmi(void) writel(reg, &mxc_ccm->chsccdr); } #endif - -#ifndef CONFIG_SYS_L2CACHE_OFF -#define IOMUXC_GPR11_L2CACHE_AS_OCRAM 0x00000002 -void v7_outer_cache_enable(void) -{ - struct pl310_regs *const pl310 = (struct pl310_regs *)L2_PL310_BASE; - unsigned int val; - - - /* - * Set bit 22 in the auxiliary control register. If this bit - * is cleared, PL310 treats Normal Shared Non-cacheable - * accesses as Cacheable no-allocate. - */ - setbits_le32(&pl310->pl310_aux_ctrl, L310_SHARED_ATT_OVERRIDE_ENABLE); - -#if defined CONFIG_MX6SL - struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; - val = readl(&iomux->gpr[11]); - if (val & IOMUXC_GPR11_L2CACHE_AS_OCRAM) { - /* L2 cache configured as OCRAM, reset it */ - val &= ~IOMUXC_GPR11_L2CACHE_AS_OCRAM; - writel(val, &iomux->gpr[11]); - } -#endif - - /* Must disable the L2 before changing the latency parameters */ - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); - - writel(0x132, &pl310->pl310_tag_latency_ctrl); - writel(0x132, &pl310->pl310_data_latency_ctrl); - - val = readl(&pl310->pl310_prefetch_ctrl); - - /* Turn on the L2 I/D prefetch */ - val |= 0x30000000; - - /* - * The L2 cache controller(PL310) version on the i.MX6D/Q is r3p1-50rel0 - * The L2 cache controller(PL310) version on the i.MX6DL/SOLO/SL is r3p2 - * But according to ARM PL310 errata: 752271 - * ID: 752271: Double linefill feature can cause data corruption - * Fault Status: Present in: r3p0, r3p1, r3p1-50rel0. Fixed in r3p2 - * Workaround: The only workaround to this erratum is to disable the - * double linefill feature. This is the default behavior. - */ - -#ifndef CONFIG_MX6Q - val |= 0x40800000; -#endif - writel(val, &pl310->pl310_prefetch_ctrl); - - val = readl(&pl310->pl310_power_ctrl); - val |= L2X0_DYNAMIC_CLK_GATING_EN; - val |= L2X0_STNDBY_MODE_EN; - writel(val, &pl310->pl310_power_ctrl); - - setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); -} - -void v7_outer_cache_disable(void) -{ - struct pl310_regs *const pl310 = (struct pl310_regs *)L2_PL310_BASE; - - clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); -} -#endif /* !CONFIG_SYS_L2CACHE_OFF */ diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index b9f1ca4..3b034e1 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -19,6 +19,7 @@ obj-y += misc.o obj-$(CONFIG_SPL_BUILD) += spl.o endif ifeq ($(SOC),$(filter $(SOC),mx6)) +obj-y += cache.o obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o endif diff --git a/arch/arm/imx-common/cache.c b/arch/arm/imx-common/cache.c new file mode 100644 index 0000000..54b021c --- /dev/null +++ b/arch/arm/imx-common/cache.c @@ -0,0 +1,103 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/armv7.h> +#include <asm/pl310.h> +#include <asm/io.h> + +#ifndef CONFIG_SYS_DCACHE_OFF +void enable_caches(void) +{ +#if defined(CONFIG_SYS_ARM_CACHE_WRITETHROUGH) + enum dcache_option option = DCACHE_WRITETHROUGH; +#else + enum dcache_option option = DCACHE_WRITEBACK; +#endif + /* Avoid random hang when download by usb */ + invalidate_dcache_all(); + + /* Enable D-cache. I-cache is already enabled in start.S */ + dcache_enable(); + + /* Enable caching on OCRAM and ROM */ + mmu_set_region_dcache_behaviour(ROMCP_ARB_BASE_ADDR, + ROMCP_ARB_END_ADDR, + option); + mmu_set_region_dcache_behaviour(IRAM_BASE_ADDR, + IRAM_SIZE, + option); +} +#endif + +#ifndef CONFIG_SYS_L2CACHE_OFF +#ifdef CONFIG_SYS_L2_PL310 +#define IOMUXC_GPR11_L2CACHE_AS_OCRAM 0x00000002 +void v7_outer_cache_enable(void) +{ + struct pl310_regs *const pl310 = (struct pl310_regs *)L2_PL310_BASE; + unsigned int val; + + + /* + * Set bit 22 in the auxiliary control register. If this bit + * is cleared, PL310 treats Normal Shared Non-cacheable + * accesses as Cacheable no-allocate. + */ + setbits_le32(&pl310->pl310_aux_ctrl, L310_SHARED_ATT_OVERRIDE_ENABLE); + +#if defined CONFIG_MX6SL + struct iomuxc *iomux = (struct iomuxc *)IOMUXC_BASE_ADDR; + val = readl(&iomux->gpr[11]); + if (val & IOMUXC_GPR11_L2CACHE_AS_OCRAM) { + /* L2 cache configured as OCRAM, reset it */ + val &= ~IOMUXC_GPR11_L2CACHE_AS_OCRAM; + writel(val, &iomux->gpr[11]); + } +#endif + + /* Must disable the L2 before changing the latency parameters */ + clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); + + writel(0x132, &pl310->pl310_tag_latency_ctrl); + writel(0x132, &pl310->pl310_data_latency_ctrl); + + val = readl(&pl310->pl310_prefetch_ctrl); + + /* Turn on the L2 I/D prefetch */ + val |= 0x30000000; + + /* + * The L2 cache controller(PL310) version on the i.MX6D/Q is r3p1-50rel0 + * The L2 cache controller(PL310) version on the i.MX6DL/SOLO/SL is r3p2 + * But according to ARM PL310 errata: 752271 + * ID: 752271: Double linefill feature can cause data corruption + * Fault Status: Present in: r3p0, r3p1, r3p1-50rel0. Fixed in r3p2 + * Workaround: The only workaround to this erratum is to disable the + * double linefill feature. This is the default behavior. + */ + +#ifndef CONFIG_MX6Q + val |= 0x40800000; +#endif + writel(val, &pl310->pl310_prefetch_ctrl); + + val = readl(&pl310->pl310_power_ctrl); + val |= L2X0_DYNAMIC_CLK_GATING_EN; + val |= L2X0_STNDBY_MODE_EN; + writel(val, &pl310->pl310_power_ctrl); + + setbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); +} + +void v7_outer_cache_disable(void) +{ + struct pl310_regs *const pl310 = (struct pl310_regs *)L2_PL310_BASE; + + clrbits_le32(&pl310->pl310_ctrl, L2X0_CTRL_EN); +} +#endif /* !CONFIG_SYS_L2_PL310 */ +#endif /* !CONFIG_SYS_L2CACHE_OFF */
Move common imx6 arch init setup, init.c can be extended and reused to support imx7 SoC keeping init arch common code.
arch/arm/cpu/armv7/mx6/soc.c | 87 ------------------------ arch/arm/imx-common/Makefile | 2 +- arch/arm/imx-common/init.c | 100 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/imx-regs.h | 4 ++ arch/arm/include/asm/imx-common/sys_proto.h | 3 + 5 files changed, 108 insertions(+), 88 deletions(-) create mode 100644 arch/arm/imx-common/init.c
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 2f7d5c8..06f63da 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -183,65 +183,6 @@ u32 __weak get_board_rev(void) } #endif
-void init_aips(void) -{ - struct aipstz_regs *aips1, *aips2; -#ifdef CONFIG_MX6SX - struct aipstz_regs *aips3; -#endif - - aips1 = (struct aipstz_regs *)AIPS1_BASE_ADDR; - aips2 = (struct aipstz_regs *)AIPS2_BASE_ADDR; -#ifdef CONFIG_MX6SX - aips3 = (struct aipstz_regs *)AIPS3_CONFIG_BASE_ADDR; -#endif - - /* - * Set all MPROTx to be non-bufferable, trusted for R/W, - * not forced to user-mode. - */ - writel(0x77777777, &aips1->mprot0); - writel(0x77777777, &aips1->mprot1); - writel(0x77777777, &aips2->mprot0); - writel(0x77777777, &aips2->mprot1); - - /* - * Set all OPACRx to be non-bufferable, not require - * supervisor privilege level for access,allow for - * write access and untrusted master access. - */ - writel(0x00000000, &aips1->opacr0); - writel(0x00000000, &aips1->opacr1); - writel(0x00000000, &aips1->opacr2); - writel(0x00000000, &aips1->opacr3); - writel(0x00000000, &aips1->opacr4); - writel(0x00000000, &aips2->opacr0); - writel(0x00000000, &aips2->opacr1); - writel(0x00000000, &aips2->opacr2); - writel(0x00000000, &aips2->opacr3); - writel(0x00000000, &aips2->opacr4); - -#ifdef CONFIG_MX6SX - /* - * Set all MPROTx to be non-bufferable, trusted for R/W, - * not forced to user-mode. - */ - writel(0x77777777, &aips3->mprot0); - writel(0x77777777, &aips3->mprot1); - - /* - * Set all OPACRx to be non-bufferable, not require - * supervisor privilege level for access,allow for - * write access and untrusted master access. - */ - writel(0x00000000, &aips3->opacr0); - writel(0x00000000, &aips3->opacr1); - writel(0x00000000, &aips3->opacr2); - writel(0x00000000, &aips3->opacr3); - writel(0x00000000, &aips3->opacr4); -#endif -} - static void clear_ldo_ramp(void) { struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; @@ -375,22 +316,6 @@ static void set_preclk_from_osc(void) } #endif
-#define SRC_SCR_WARM_RESET_ENABLE 0 - -static void init_src(void) -{ - struct src *src_regs = (struct src *)SRC_BASE_ADDR; - u32 val; - - /* - * force warm reset sources to generate cold reset - * for a more reliable restart - */ - val = readl(&src_regs->scr); - val &= ~(1 << SRC_SCR_WARM_RESET_ENABLE); - writel(val, &src_regs->scr); -} - int arch_cpu_init(void) { init_aips(); @@ -458,18 +383,6 @@ void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) } #endif
-void boot_mode_apply(unsigned cfg_val) -{ - unsigned reg; - struct src *psrc = (struct src *)SRC_BASE_ADDR; - writel(cfg_val, &psrc->gpr9); - reg = readl(&psrc->gpr10); - if (cfg_val) - reg |= 1 << 28; - else - reg &= ~(1 << 28); - writel(reg, &psrc->gpr10); -} /* * cfg_val will be used for * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 3b034e1..d77a236 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -19,7 +19,7 @@ obj-y += misc.o obj-$(CONFIG_SPL_BUILD) += spl.o endif ifeq ($(SOC),$(filter $(SOC),mx6)) -obj-y += cache.o +obj-y += cache.o init.o obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o endif diff --git a/arch/arm/imx-common/init.c b/arch/arm/imx-common/init.c new file mode 100644 index 0000000..f7ed038 --- /dev/null +++ b/arch/arm/imx-common/init.c @@ -0,0 +1,100 @@ +/* + * Copyright 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/arch/crm_regs.h> + +void init_aips(void) +{ + struct aipstz_regs *aips1, *aips2; +#ifdef CONFIG_MX6SX + struct aipstz_regs *aips3; +#endif + + aips1 = (struct aipstz_regs *)AIPS1_BASE_ADDR; + aips2 = (struct aipstz_regs *)AIPS2_BASE_ADDR; +#ifdef CONFIG_MX6SX + aips3 = (struct aipstz_regs *)AIPS3_BASE_ADDR; +#endif + + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + writel(0x77777777, &aips1->mprot0); + writel(0x77777777, &aips1->mprot1); + writel(0x77777777, &aips2->mprot0); + writel(0x77777777, &aips2->mprot1); + + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips1->opacr0); + writel(0x00000000, &aips1->opacr1); + writel(0x00000000, &aips1->opacr2); + writel(0x00000000, &aips1->opacr3); + writel(0x00000000, &aips1->opacr4); + writel(0x00000000, &aips2->opacr0); + writel(0x00000000, &aips2->opacr1); + writel(0x00000000, &aips2->opacr2); + writel(0x00000000, &aips2->opacr3); + writel(0x00000000, &aips2->opacr4); + +#ifdef CONFIG_MX6SX + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + writel(0x77777777, &aips3->mprot0); + writel(0x77777777, &aips3->mprot1); + + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips3->opacr0); + writel(0x00000000, &aips3->opacr1); + writel(0x00000000, &aips3->opacr2); + writel(0x00000000, &aips3->opacr3); + writel(0x00000000, &aips3->opacr4); +#endif +} + +#define SRC_SCR_WARM_RESET_ENABLE 0 + +void init_src(void) +{ + struct src *src_regs = (struct src *)SRC_BASE_ADDR; + u32 val; + + /* + * force warm reset sources to generate cold reset + * for a more reliable restart + */ + val = readl(&src_regs->scr); + val &= ~(1 << SRC_SCR_WARM_RESET_ENABLE); + writel(val, &src_regs->scr); +} + +void boot_mode_apply(unsigned cfg_val) +{ + unsigned reg; + struct src *psrc = (struct src *)SRC_BASE_ADDR; + writel(cfg_val, &psrc->gpr9); + reg = readl(&psrc->gpr10); + if (cfg_val) + reg |= 1 << 28; + else + reg &= ~(1 << 28); + writel(reg, &psrc->gpr10); +} diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index a685ed2..74512ac 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -137,8 +137,10 @@ /* Defines for Blocks connected via AIPS (SkyBlue) */ #define ATZ1_BASE_ADDR AIPS1_ARB_BASE_ADDR #define ATZ2_BASE_ADDR AIPS2_ARB_BASE_ADDR +#define ATZ3_BASE_ADDR AIPS3_ARB_BASE_ADDR #define AIPS1_BASE_ADDR AIPS1_ON_BASE_ADDR #define AIPS2_BASE_ADDR AIPS2_ON_BASE_ADDR +#define AIPS3_BASE_ADDR AIPS3_ON_BASE_ADDR
#define SPDIF_BASE_ADDR (ATZ1_BASE_ADDR + 0x04000) #define ECSPI1_BASE_ADDR (ATZ1_BASE_ADDR + 0x08000) @@ -219,6 +221,8 @@
#define AIPS2_ON_BASE_ADDR (ATZ2_BASE_ADDR + 0x7C000) #define AIPS2_OFF_BASE_ADDR (ATZ2_BASE_ADDR + 0x80000) +#define AIPS3_ON_BASE_ADDR (ATZ3_BASE_ADDR + 0x7C000) +#define AIPS3_OFF_BASE_ADDR (ATZ3_BASE_ADDR + 0x80000) #define CAAM_BASE_ADDR (ATZ2_BASE_ADDR) #define ARM_BASE_ADDR (ATZ2_BASE_ADDR + 0x40000)
diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index c0a37e1..fda126b 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -35,6 +35,9 @@ u32 imx_ddr_size(void); void sdelay(unsigned long); void set_chipselect_size(int const);
+void init_aips(void); +void init_src(void); + /* * Initializes on-chip ethernet controllers. * to override, implement board_eth_init()
Add system counter driver for imx7d and mx6ul imx7 and imx6ul supports system counter timer as well as GPT timer (arch/arm/imx-common/timer.c); The default for imx7 is systemcounter timer.
Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2 to V5: Resend Changes for V6: - Update comit log description - Drop change set on mx6_common.h Changes for V7: Resend
arch/arm/imx-common/syscounter.c | 126 +++++++++++++++++++++++++++ arch/arm/include/asm/imx-common/syscounter.h | 29 ++++++ 2 files changed, 155 insertions(+) create mode 100644 arch/arm/imx-common/syscounter.c create mode 100644 arch/arm/include/asm/imx-common/syscounter.h
diff --git a/arch/arm/imx-common/syscounter.c b/arch/arm/imx-common/syscounter.c new file mode 100644 index 0000000..e00fef2 --- /dev/null +++ b/arch/arm/imx-common/syscounter.c @@ -0,0 +1,126 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * The file use ls102xa/timer.c as a reference. + */ + +#include <common.h> +#include <asm/io.h> +#include <div64.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/syscounter.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * This function is intended for SHORT delays only. + * It will overflow at around 10 seconds @ 400MHz, + * or 20 seconds @ 200MHz. + */ +unsigned long usec2ticks(unsigned long usec) +{ + ulong ticks; + + if (usec < 1000) + ticks = ((usec * (get_tbclk()/1000)) + 500) / 1000; + else + ticks = ((usec / 10) * (get_tbclk() / 100000)); + + return ticks; +} + +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + tick *= CONFIG_SYS_HZ; + do_div(tick, freq); + + return tick; +} + +static inline unsigned long long us_to_tick(unsigned long long usec) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + usec = usec * freq + 999999; + do_div(usec, 1000000); + + return usec; +} + +int timer_init(void) +{ + struct sctr_regs *sctr = (struct sctr_regs *)SCTR_BASE_ADDR; + unsigned long val, freq; + + freq = CONFIG_SC_TIMER_CLK; + asm("mcr p15, 0, %0, c14, c0, 0" : : "r" (freq)); + + writel(freq, &sctr->cntfid0); + + /* Enable system counter */ + val = readl(&sctr->cntcr); + val &= ~(SC_CNTCR_FREQ0 | SC_CNTCR_FREQ1); + val |= SC_CNTCR_FREQ0 | SC_CNTCR_ENABLE | SC_CNTCR_HDBG; + writel(val, &sctr->cntcr); + + gd->arch.tbl = 0; + gd->arch.tbu = 0; + + return 0; +} + +unsigned long long get_ticks(void) +{ + unsigned long long now; + + asm("mrrc p15, 0, %Q0, %R0, c14" : "=r" (now)); + + gd->arch.tbl = (unsigned long)(now & 0xffffffff); + gd->arch.tbu = (unsigned long)(now >> 32); + + return now; +} + +ulong get_timer_masked(void) +{ + return tick_to_time(get_ticks()); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void __udelay(unsigned long usec) +{ + unsigned long long tmp; + ulong tmo; + + tmo = us_to_tick(usec); + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp) /* loop till event */ + /*NOP*/; +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + unsigned long freq; + + asm volatile("mrc p15, 0, %0, c14, c0, 0" : "=r" (freq)); + + return freq; +} diff --git a/arch/arm/include/asm/imx-common/syscounter.h b/arch/arm/include/asm/imx-common/syscounter.h new file mode 100644 index 0000000..bdbe26c --- /dev/null +++ b/arch/arm/include/asm/imx-common/syscounter.h @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_SYSTEM_COUNTER_H +#define _ASM_ARCH_SYSTEM_COUNTER_H + +/* System Counter */ +struct sctr_regs { + u32 cntcr; + u32 cntsr; + u32 cntcv1; + u32 cntcv2; + u32 resv1[4]; + u32 cntfid0; + u32 cntfid1; + u32 cntfid2; + u32 resv2[1001]; + u32 counterid[1]; +}; + +#define SC_CNTCR_ENABLE (1 << 0) +#define SC_CNTCR_HDBG (1 << 1) +#define SC_CNTCR_FREQ0 (1 << 8) +#define SC_CNTCR_FREQ1 (1 << 9) + +#endif
* Add system arch level header files - imx-regs.h: iMX7D SoC system architecture registers - crm_regs.h: Clock control module registers - sys_proto.h: helper callback function for SoC setup
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Split patch to easier review process - Add system arch register definitions Changes for V3: Resend Changes for V4: Resend Changes for V5: Resend Changes for V6: Add common settings helper function definitions in sys_proto.h Changes for V7: Rework patch for git://git.denx.de/u-boot-imx.git (master)
arch/arm/include/asm/arch-mx7/crm_regs.h | 2813 +++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx7/imx-regs.h | 1307 ++++++++++++++ arch/arm/include/asm/arch-mx7/sys_proto.h | 7 + 3 files changed, 4127 insertions(+) create mode 100644 arch/arm/include/asm/arch-mx7/crm_regs.h create mode 100644 arch/arm/include/asm/arch-mx7/imx-regs.h create mode 100644 arch/arm/include/asm/arch-mx7/sys_proto.h
diff --git a/arch/arm/include/asm/arch-mx7/crm_regs.h b/arch/arm/include/asm/arch-mx7/crm_regs.h new file mode 100644 index 0000000..d65d4d9 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/crm_regs.h @@ -0,0 +1,2813 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_ARM_MACH_MX7_CCM_REGS_H__ +#define __ARCH_ARM_MACH_MX7_CCM_REGS_H__ + +#include <asm/arch/imx-regs.h> +#include <asm/io.h> + +#define CCM_GPR0_OFFSET 0x0 +#define CCM_OBSERVE0_OFFSET 0x0400 +#define CCM_SCTRL0_OFFSET 0x0800 +#define CCM_CCGR0_OFFSET 0x4000 +#define CCM_ROOT0_TARGET_OFFSET 0x8000 + +#ifndef __ASSEMBLY__ + +struct mxc_ccm_ccgr { + uint32_t ccgr; + uint32_t ccgr_set; + uint32_t ccgr_clr; + uint32_t ccgr_tog; +}; + +struct mxc_ccm_root_slice { + uint32_t target_root; + uint32_t target_root_set; + uint32_t target_root_clr; + uint32_t target_root_tog; + uint32_t reserved_0[4]; + uint32_t post; + uint32_t post_root_set; + uint32_t post_root_clr; + uint32_t post_root_tog; + uint32_t pre; + uint32_t pre_root_set; + uint32_t pre_root_clr; + uint32_t pre_root_tog; + uint32_t reserved_1[12]; + uint32_t access_ctrl; + uint32_t access_ctrl_root_set; + uint32_t access_ctrl_root_clr; + uint32_t access_ctrl_root_tog; +}; + +/** CCM - Peripheral register structure */ +struct mxc_ccm_reg { + uint32_t gpr0; + uint32_t gpr0_set; + uint32_t gpr0_clr; + uint32_t gpr0_tog; + uint32_t reserved_0[4092]; + struct mxc_ccm_ccgr ccgr_array[191]; /* offset 0x4000 */ + uint32_t reserved_1[3332]; + struct mxc_ccm_root_slice root[121]; /* offset 0x8000 */ + +}; + +struct mxc_ccm_anatop_reg { + uint32_t ctrl_24m; /* offset 0x0000 */ + uint32_t ctrl_24m_set; + uint32_t ctrl_24m_clr; + uint32_t ctrl_24m_tog; + uint32_t rcosc_config0; /* offset 0x0010 */ + uint32_t rcosc_config0_set; + uint32_t rcosc_config0_clr; + uint32_t rcosc_config0_tog; + uint32_t rcosc_config1; /* offset 0x0020 */ + uint32_t rcosc_config1_set; + uint32_t rcosc_config1_clr; + uint32_t rcosc_config1_tog; + uint32_t rcosc_config2; /* offset 0x0030 */ + uint32_t rcosc_config2_set; + uint32_t rcosc_config2_clr; + uint32_t rcosc_config2_tog; + uint8_t reserved_0[16]; + uint32_t osc_32k; /* offset 0x0050 */ + uint32_t osc_32k_set; + uint32_t osc_32k_clr; + uint32_t osc_32k_tog; + uint32_t pll_arm; /* offset 0x0060 */ + uint32_t pll_arm_set; + uint32_t pll_arm_clr; + uint32_t pll_arm_tog; + uint32_t pll_ddr; /* offset 0x0070 */ + uint32_t pll_ddr_set; + uint32_t pll_ddr_clr; + uint32_t pll_ddr_tog; + uint32_t pll_ddr_ss; /* offset 0x0080 */ + uint8_t reserved_1[12]; + uint32_t pll_ddr_num; /* offset 0x0090 */ + uint8_t reserved_2[12]; + uint32_t pll_ddr_denom; /* offset 0x00a0 */ + uint8_t reserved_3[12]; + uint32_t pll_480; /* offset 0x00b0 */ + uint32_t pll_480_set; + uint32_t pll_480_clr; + uint32_t pll_480_tog; + uint32_t pfd_480a; /* offset 0x00c0 */ + uint32_t pfd_480a_set; + uint32_t pfd_480a_clr; + uint32_t pfd_480a_tog; + uint32_t pfd_480b; /* offset 0x00d0 */ + uint32_t pfd_480b_set; + uint32_t pfd_480b_clr; + uint32_t pfd_480b_tog; + uint32_t pll_enet; /* offset 0x00e0 */ + uint32_t pll_enet_set; + uint32_t pll_enet_clr; + uint32_t pll_enet_tog; + uint32_t pll_audio; /* offset 0x00f0 */ + uint32_t pll_audio_set; + uint32_t pll_audio_clr; + uint32_t pll_audio_tog; + uint32_t pll_audio_ss; /* offset 0x0100 */ + uint8_t reserved_4[12]; + uint32_t pll_audio_num; /* offset 0x0110 */ + uint8_t reserved_5[12]; + uint32_t pll_audio_denom; /* offset 0x0120 */ + uint8_t reserved_6[12]; + uint32_t pll_video; /* offset 0x0130 */ + uint32_t pll_video_set; + uint32_t pll_video_clr; + uint32_t pll_video_tog; + uint32_t pll_video_ss; /* offset 0x0140 */ + uint8_t reserved_7[12]; + uint32_t pll_video_num; /* offset 0x0150 */ + uint8_t reserved_8[12]; + uint32_t pll_video_denom; /* offset 0x0160 */ + uint8_t reserved_9[12]; + uint32_t clk_misc0; /* offset 0x0170 */ + uint32_t clk_misc0_set; + uint32_t clk_misc0_clr; + uint32_t clk_misc0_tog; + uint32_t clk_rsvd; /* offset 0x0180 */ + uint8_t reserved_10[124]; + uint32_t reg_1p0a; /* offset 0x0200 */ + uint32_t reg_1p0a_set; + uint32_t reg_1p0a_clr; + uint32_t reg_1p0a_tog; + uint32_t reg_1p0d; /* offsest 0x0210 */ + uint32_t reg_1p0d_set; + uint32_t reg_1p0d_clr; + uint32_t reg_1p0d_tog; + uint32_t reg_hsic_1p2; /* offset 0x0220 */ + uint32_t reg_hsic_1p2_set; + uint32_t reg_hsic_1p2_clr; + uint32_t reg_hsic_1p2_tog; + uint32_t reg_lpsr_1p0; /* offset 0x0230 */ + uint32_t reg_lpsr_1p0_set; + uint32_t reg_lpsr_1p0_clr; + uint32_t reg_lpsr_1p0_tog; + uint32_t reg_3p0; /* offset 0x0240 */ + uint32_t reg_3p0_set; + uint32_t reg_3p0_clr; + uint32_t reg_3p0_tog; + uint32_t reg_snvs; /* offset 0x0250 */ + uint32_t reg_snvs_set; + uint32_t reg_snvs_clr; + uint32_t reg_snvs_tog; + uint32_t analog_debug_misc0; /* offset 0x0260 */ + uint32_t analog_debug_misc0_set; + uint32_t analog_debug_misc0_clr; + uint32_t analog_debug_misc0_tog; + uint32_t ref; /* offset 0x0270 */ + uint32_t ref_set; + uint32_t ref_clr; + uint32_t ref_tog; + uint8_t reserved_11[128]; + uint32_t tempsense0; /* offset 0x0300 */ + uint32_t tempsense0_set; + uint32_t tempsense0_clr; + uint32_t tempsense0_tog; + uint32_t tempsense1; /* offset 0x0310 */ + uint32_t tempsense1_set; + uint32_t tempsense1_clr; + uint32_t tempsense1_tog; + uint32_t tempsense_trim; /* offset 0x0320 */ + uint32_t tempsense_trim_set; + uint32_t tempsense_trim_clr; + uint32_t tempsense_trim_tog; + uint32_t lowpwr_ctrl; /* offset 0x0330 */ + uint32_t lowpwr_ctrl_set; + uint32_t lowpwr_ctrl_clr; + uint32_t lowpwr_ctrl_tog; + uint32_t snvs_tamper_offset_ctrl; /* offset 0x0340 */ + uint32_t snvs_tamper_offset_ctrl_set; + uint32_t snvs_tamper_offset_ctrl_clr; + uint32_t snvs_tamper_offset_ctrl_tog; + uint32_t snvs_tamper_pull_ctrl; /* offset 0x0350 */ + uint32_t snvs_tamper_pull_ctrl_set; + uint32_t snvs_tamper_pull_ctrl_clr; + uint32_t snvs_tamper_pull_ctrl_tog; + uint32_t snvs_test; /* offset 0x0360 */ + uint32_t snvs_test_set; + uint32_t snvs_test_clr; + uint32_t snvs_test_tog; + uint32_t snvs_tamper_trim_ctrl; /* offset 0x0370 */ + uint32_t snvs_tamper_trim_ctrl_set; + uint32_t snvs_tamper_trim_ctrl_ctrl; + uint32_t snvs_tamper_trim_ctrl_tog; + uint32_t snvs_misc_ctrl; /* offset 0x0380 */ + uint32_t snvs_misc_ctrl_set; + uint32_t snvs_misc_ctrl_clr; + uint32_t snvs_misc_ctrl_tog; + uint8_t reserved_12[112]; + uint32_t misc; /* offset 0x0400 */ + uint8_t reserved_13[252]; + uint32_t adc0; /* offset 0x0500 */ + uint8_t reserved_14[12]; + uint32_t adc1; /* offset 0x0510 */ + uint8_t reserved_15[748]; + uint32_t digprog; /* offset 0x0800 */ +}; +#endif + +#define ANADIG_CLK_MISC0_PFD_480_AUTOGATE_EN_MASK (0x01 << 17) + +#define ANADIG_PLL_LOCK 0x80000000 + +#define ANADIG_PLL_ARM_PWDN_MASK (0x01 << 12) +#define ANADIG_PLL_480_PWDN_MASK (0x01 << 12) +#define ANADIG_PLL_DDR_PWDN_MASK (0x01 << 20) +#define ANADIG_PLL_ENET_PWDN_MASK (0x01 << 5) +#define ANADIG_PLL_VIDEO_PWDN_MASK (0x01 << 12) + + +#define ANATOP_PFD480B_PFD4_FRAC_MASK 0x0000003f +#define ANATOP_PFD480B_PFD4_FRAC_320M_VAL 0x0000001B +#define ANATOP_PFD480B_PFD4_FRAC_392M_VAL 0x00000016 +#define ANATOP_PFD480B_PFD4_FRAC_432M_VAL 0x00000014 + +/* PLL_ARM Bit Fields */ +#define CCM_ANALOG_PLL_ARM_DIV_SELECT_MASK 0x7F +#define CCM_ANALOG_PLL_ARM_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_ARM_HALF_LF_MASK 0x80 +#define CCM_ANALOG_PLL_ARM_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_ARM_DOUBLE_LF_MASK 0x100 +#define CCM_ANALOG_PLL_ARM_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_ARM_HALF_CP_MASK 0x200 +#define CCM_ANALOG_PLL_ARM_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_ARM_DOUBLE_CP_MASK 0x400 +#define CCM_ANALOG_PLL_ARM_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_ARM_HOLD_RING_OFF_MASK 0x800 +#define CCM_ANALOG_PLL_ARM_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_ARM_POWERDOWN_MASK 0x1000 +#define CCM_ANALOG_PLL_ARM_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_ARM_ENABLE_CLK_MASK 0x2000 +#define CCM_ANALOG_PLL_ARM_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_ARM_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_ARM_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_ARM_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_ARM_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_ARM_LVDS_SEL_MASK 0x20000 +#define CCM_ANALOG_PLL_ARM_LVDS_SEL_SHIFT 17 +#define CCM_ANALOG_PLL_ARM_LVDS_24MHZ_SEL_MASK 0x40000 +#define CCM_ANALOG_PLL_ARM_LVDS_24MHZ_SEL_SHIFT 18 +#define CCM_ANALOG_PLL_ARM_PLL_SEL_MASK 0x80000 +#define CCM_ANALOG_PLL_ARM_PLL_SEL_SHIFT 19 +#define CCM_ANALOG_PLL_ARM_PLL_ARM_OVERRIDE_MASK 0x100000 +#define CCM_ANALOG_PLL_ARM_PLL_ARM_OVERRIDE_SHIFT 20 +#define CCM_ANALOG_PLL_ARM_RSVD0_MASK 0x7FE00000 +#define CCM_ANALOG_PLL_ARM_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_ARM_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_ARM_LOCK_SHIFT 31 + +/* PLL_DDR Bit Fields */ +#define CCM_ANALOG_PLL_DDR_DIV_SELECT_MASK 0x7F +#define CCM_ANALOG_PLL_DDR_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_DDR_HALF_LF_MASK 0x80 +#define CCM_ANALOG_PLL_DDR_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_DDR_DOUBLE_LF_MASK 0x100 +#define CCM_ANALOG_PLL_DDR_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_DDR_HALF_CP_MASK 0x200 +#define CCM_ANALOG_PLL_DDR_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_DDR_DOUBLE_CP_MASK 0x400 +#define CCM_ANALOG_PLL_DDR_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_DDR_HOLD_RING_OFF_MASK 0x800 +#define CCM_ANALOG_PLL_DDR_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_DDR_DIV2_ENABLE_CLK_MASK 0x1000 +#define CCM_ANALOG_PLL_DDR_DIV2_ENABLE_CLK_SHIFT 12 +#define CCM_ANALOG_PLL_DDR_ENABLE_CLK_MASK 0x2000 +#define CCM_ANALOG_PLL_DDR_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_DDR_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_DDR_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_DDR_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_DDR_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_DDR_DITHER_ENABLE_MASK 0x20000 +#define CCM_ANALOG_PLL_DDR_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_DDR_PFD_OFFSET_EN_MASK 0x40000 +#define CCM_ANALOG_PLL_DDR_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_DDR_PLL_DDR_OVERRIDE_MASK 0x80000 +#define CCM_ANALOG_PLL_DDR_PLL_DDR_OVERRIDE_SHIFT 19 +#define CCM_ANALOG_PLL_DDR_POWERDOWN_MASK 0x100000 +#define CCM_ANALOG_PLL_DDR_POWERDOWN_SHIFT 20 +#define CCM_ANALOG_PLL_DDR_TEST_DIV_SELECT_MASK 0x600000 +#define CCM_ANALOG_PLL_DDR_TEST_DIV_SELECT_SHIFT 21 +#define CCM_ANALOG_PLL_DDR_RSVD1_MASK 0x7F800000 +#define CCM_ANALOG_PLL_DDR_RSVD1_SHIFT 23 +#define CCM_ANALOG_PLL_DDR_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_DDR_LOCK_SHIFT 31 + +/* PLL_480 Bit Fields */ +#define CCM_ANALOG_PLL_480_DIV_SELECT_MASK 0x1 +#define CCM_ANALOG_PLL_480_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_480_RSVD0_MASK 0xE +#define CCM_ANALOG_PLL_480_RSVD0_SHIFT 1 +#define CCM_ANALOG_PLL_480_MAIN_DIV1_CLKGATE_MASK 0x10 +#define CCM_ANALOG_PLL_480_MAIN_DIV1_CLKGATE_SHIFT 4 +#define CCM_ANALOG_PLL_480_MAIN_DIV2_CLKGATE_MASK 0x20 +#define CCM_ANALOG_PLL_480_MAIN_DIV2_CLKGATE_SHIFT 5 +#define CCM_ANALOG_PLL_480_MAIN_DIV4_CLKGATE_MASK 0x40 +#define CCM_ANALOG_PLL_480_MAIN_DIV4_CLKGATE_SHIFT 6 +#define CCM_ANALOG_PLL_480_HALF_LF_MASK 0x80 +#define CCM_ANALOG_PLL_480_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_480_DOUBLE_LF_MASK 0x100 +#define CCM_ANALOG_PLL_480_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_480_HALF_CP_MASK 0x200 +#define CCM_ANALOG_PLL_480_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_480_DOUBLE_CP_MASK 0x400 +#define CCM_ANALOG_PLL_480_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_480_HOLD_RING_OFF_MASK 0x800 +#define CCM_ANALOG_PLL_480_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_480_POWERDOWN_MASK 0x1000 +#define CCM_ANALOG_PLL_480_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_480_ENABLE_CLK_MASK 0x2000 +#define CCM_ANALOG_PLL_480_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_480_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_480_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_480_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_480_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_480_PLL_480_OVERRIDE_MASK 0x20000 +#define CCM_ANALOG_PLL_480_PLL_480_OVERRIDE_SHIFT 17 +#define CCM_ANALOG_PLL_480_PFD0_OVERRIDE_MASK 0x40000 +#define CCM_ANALOG_PLL_480_PFD0_OVERRIDE_SHIFT 18 +#define CCM_ANALOG_PLL_480_PFD1_OVERRIDE_MASK 0x80000 +#define CCM_ANALOG_PLL_480_PFD1_OVERRIDE_SHIFT 19 +#define CCM_ANALOG_PLL_480_PFD2_OVERRIDE_MASK 0x100000 +#define CCM_ANALOG_PLL_480_PFD2_OVERRIDE_SHIFT 20 +#define CCM_ANALOG_PLL_480_PFD3_OVERRIDE_MASK 0x200000 +#define CCM_ANALOG_PLL_480_PFD3_OVERRIDE_SHIFT 21 +#define CCM_ANALOG_PLL_480_PFD4_OVERRIDE_MASK 0x400000 +#define CCM_ANALOG_PLL_480_PFD4_OVERRIDE_SHIFT 22 +#define CCM_ANALOG_PLL_480_PFD5_OVERRIDE_MASK 0x800000 +#define CCM_ANALOG_PLL_480_PFD5_OVERRIDE_SHIFT 23 +#define CCM_ANALOG_PLL_480_PFD6_OVERRIDE_MASK 0x1000000 +#define CCM_ANALOG_PLL_480_PFD6_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_480_PFD7_OVERRIDE_MASK 0x2000000 +#define CCM_ANALOG_PLL_480_PFD7_OVERRIDE_SHIFT 25 +#define CCM_ANALOG_PLL_480_PFD0_DIV2_CLKGATE_MASK 0x4000000 +#define CCM_ANALOG_PLL_480_PFD0_DIV2_CLKGATE_SHIFT 26 +#define CCM_ANALOG_PLL_480_PFD1_DIV2_CLKGATE_MASK 0x8000000 +#define CCM_ANALOG_PLL_480_PFD1_DIV2_CLKGATE_SHIFT 27 +#define CCM_ANALOG_PLL_480_PFD2_DIV2_CLKGATE_MASK 0x10000000 +#define CCM_ANALOG_PLL_480_PFD2_DIV2_CLKGATE_SHIFT 28 +#define CCM_ANALOG_PLL_480_RSVD1_MASK 0x60000000 +#define CCM_ANALOG_PLL_480_RSVD1_SHIFT 29 +#define CCM_ANALOG_PLL_480_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_480_LOCK_SHIFT 31 + +/* PFD_480A Bit Fields */ +#define CCM_ANALOG_PFD_480A_PFD0_FRAC_MASK 0x3F +#define CCM_ANALOG_PFD_480A_PFD0_FRAC_SHIFT 0 +#define CCM_ANALOG_PFD_480A_PFD0_STABLE_MASK 0x40 +#define CCM_ANALOG_PFD_480A_PFD0_STABLE_SHIFT 6 +#define CCM_ANALOG_PFD_480A_PFD0_DIV1_CLKGATE_MASK 0x80 +#define CCM_ANALOG_PFD_480A_PFD0_DIV1_CLKGATE_SHIFT 7 +#define CCM_ANALOG_PFD_480A_PFD1_FRAC_MASK 0x3F00 +#define CCM_ANALOG_PFD_480A_PFD1_FRAC_SHIFT 8 +#define CCM_ANALOG_PFD_480A_PFD1_STABLE_MASK 0x4000 +#define CCM_ANALOG_PFD_480A_PFD1_STABLE_SHIFT 14 +#define CCM_ANALOG_PFD_480A_PFD1_DIV1_CLKGATE_MASK 0x8000 +#define CCM_ANALOG_PFD_480A_PFD1_DIV1_CLKGATE_SHIFT 15 +#define CCM_ANALOG_PFD_480A_PFD2_FRAC_MASK 0x3F0000 +#define CCM_ANALOG_PFD_480A_PFD2_FRAC_SHIFT 16 +#define CCM_ANALOG_PFD_480A_PFD2_STABLE_MASK 0x400000 +#define CCM_ANALOG_PFD_480A_PFD2_STABLE_SHIFT 22 +#define CCM_ANALOG_PFD_480A_PFD2_DIV1_CLKGATE_MASK 0x800000 +#define CCM_ANALOG_PFD_480A_PFD2_DIV1_CLKGATE_SHIFT 23 +#define CCM_ANALOG_PFD_480A_PFD3_FRAC_MASK 0x3F000000 +#define CCM_ANALOG_PFD_480A_PFD3_FRAC_SHIFT 24 +#define CCM_ANALOG_PFD_480A_PFD3_STABLE_MASK 0x40000000 +#define CCM_ANALOG_PFD_480A_PFD3_STABLE_SHIFT 30 +#define CCM_ANALOG_PFD_480A_PFD3_DIV1_CLKGATE_MASK 0x80000000 +#define CCM_ANALOG_PFD_480A_PFD3_DIV1_CLKGATE_SHIFT 31 +/* PFD_480B Bit Fields */ +#define CCM_ANALOG_PFD_480B_PFD4_FRAC_MASK 0x3F +#define CCM_ANALOG_PFD_480B_PFD4_FRAC_SHIFT 0 +#define CCM_ANALOG_PFD_480B_PFD4_STABLE_MASK 0x40 +#define CCM_ANALOG_PFD_480B_PFD4_STABLE_SHIFT 6 +#define CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_MASK 0x80 +#define CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_SHIFT 7 +#define CCM_ANALOG_PFD_480B_PFD5_FRAC_MASK 0x3F00 +#define CCM_ANALOG_PFD_480B_PFD5_FRAC_SHIFT 8 +#define CCM_ANALOG_PFD_480B_PFD5_STABLE_MASK 0x4000 +#define CCM_ANALOG_PFD_480B_PFD5_STABLE_SHIFT 14 +#define CCM_ANALOG_PFD_480B_PFD5_DIV1_CLKGATE_MASK 0x8000 +#define CCM_ANALOG_PFD_480B_PFD5_DIV1_CLKGATE_SHIFT 15 +#define CCM_ANALOG_PFD_480B_PFD6_FRAC_MASK 0x3F0000 +#define CCM_ANALOG_PFD_480B_PFD6_FRAC_SHIFT 16 +#define CCM_ANALOG_PFD_480B_PFD6_STABLE_MASK 0x400000 +#define CCM_ANALOG_PFD_480B_PFD6_STABLE_SHIFT 22 +#define CCM_ANALOG_PFD_480B_PFD6_DIV1_CLKGATE_MASK 0x800000 +#define CCM_ANALOG_PFD_480B_PFD6_DIV1_CLKGATE_SHIFT 23 +#define CCM_ANALOG_PFD_480B_PFD7_FRAC_MASK 0x3F000000 +#define CCM_ANALOG_PFD_480B_PFD7_FRAC_SHIFT 24 +#define CCM_ANALOG_PFD_480B_PFD7_STABLE_MASK 0x40000000 +#define CCM_ANALOG_PFD_480B_PFD7_STABLE_SHIFT 30 +#define CCM_ANALOG_PFD_480B_PFD7_DIV1_CLKGATE_MASK 0x80000000 +#define CCM_ANALOG_PFD_480B_PFD7_DIV1_CLKGATE_SHIFT 31 + +/* PLL_ENET Bit Fields */ +#define CCM_ANALOG_PLL_ENET_HALF_LF_MASK 0x1 +#define CCM_ANALOG_PLL_ENET_HALF_LF_SHIFT 0 +#define CCM_ANALOG_PLL_ENET_DOUBLE_LF_MASK 0x2 +#define CCM_ANALOG_PLL_ENET_DOUBLE_LF_SHIFT 1 +#define CCM_ANALOG_PLL_ENET_HALF_CP_MASK 0x4 +#define CCM_ANALOG_PLL_ENET_HALF_CP_SHIFT 2 +#define CCM_ANALOG_PLL_ENET_DOUBLE_CP_MASK 0x8 +#define CCM_ANALOG_PLL_ENET_DOUBLE_CP_SHIFT 3 +#define CCM_ANALOG_PLL_ENET_HOLD_RING_OFF_MASK 0x10 +#define CCM_ANALOG_PLL_ENET_HOLD_RING_OFF_SHIFT 4 +#define CCM_ANALOG_PLL_ENET_POWERDOWN_MASK 0x20 +#define CCM_ANALOG_PLL_ENET_POWERDOWN_SHIFT 5 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_MASK 0x40 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_SHIFT 6 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_MASK 0x80 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_SHIFT 7 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_MASK 0x100 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_SHIFT 8 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_MASK 0x200 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_SHIFT 9 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_MASK 0x400 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_SHIFT 10 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_MASK 0x800 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_SHIFT 11 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_MASK 0x1000 +#define CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_SHIFT 12 +#define CCM_ANALOG_PLL_ENET_PLL_ENET_OVERRIDE_MASK 0x2000 +#define CCM_ANALOG_PLL_ENET_PLL_ENET_OVERRIDE_SHIFT 13 +#define CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_MASK 0xC000 +#define CCM_ANALOG_PLL_ENET_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_ENET_BYPASS_MASK 0x10000 +#define CCM_ANALOG_PLL_ENET_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_ENET_DITHER_ENABLE_MASK 0x20000 +#define CCM_ANALOG_PLL_ENET_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN_MASK 0x40000 +#define CCM_ANALOG_PLL_ENET_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_ENET_RSVD1_MASK 0x7FF80000 +#define CCM_ANALOG_PLL_ENET_RSVD1_SHIFT 19 +#define CCM_ANALOG_PLL_ENET_LOCK_MASK 0x80000000 +#define CCM_ANALOG_PLL_ENET_LOCK_SHIFT 31 + +/* PLL_AUDIO Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_LOCK_SHIFT 31 +/* PLL_AUDIO_SET Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_SET_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_SET_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_SET_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_SET_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_SET_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_SET_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_SET_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_SET_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_SET_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_SET_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_SET_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_SET_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_SET_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_SET_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SET_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_SET_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_SET_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_SET_LOCK_SHIFT 31 +/* PLL_AUDIO_CLR Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_CLR_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_CLR_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_CLR_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_CLR_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_CLR_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_CLR_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_CLR_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_CLR_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_CLR_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_CLR_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_CLR_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_CLR_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_CLR_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_CLR_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_CLR_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_CLR_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_CLR_LOCK_SHIFT 31 +/* PLL_AUDIO_TOG Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_AUDIO_TOG_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_AUDIO_TOG_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_AUDIO_TOG_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_AUDIO_TOG_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_AUDIO_TOG_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_AUDIO_TOG_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_AUDIO_TOG_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_AUDIO_TOG_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_AUDIO_TOG_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_TOG_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_AUDIO_TOG_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_AUDIO_TOG_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_AUDIO_TOG_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_PLL_AUDIO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_AUDIO_TOG_PLL_AUDIO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_AUDIO_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_SHIFT))&CCM_ANALOG_PLL_AUDIO_TOG_RSVD1_MASK) +#define CCM_ANALOG_PLL_AUDIO_TOG_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_AUDIO_TOG_LOCK_SHIFT 31 +/* PLL_AUDIO_SS Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_SS_STEP_MASK 0x7FFFu +#define CCM_ANALOG_PLL_AUDIO_SS_STEP_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_SS_STEP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SS_STEP_SHIFT))&CCM_ANALOG_PLL_AUDIO_SS_STEP_MASK) +#define CCM_ANALOG_PLL_AUDIO_SS_ENABLE_MASK 0x8000u +#define CCM_ANALOG_PLL_AUDIO_SS_ENABLE_SHIFT 15 +#define CCM_ANALOG_PLL_AUDIO_SS_STOP_MASK 0xFFFF0000u +#define CCM_ANALOG_PLL_AUDIO_SS_STOP_SHIFT 16 +#define CCM_ANALOG_PLL_AUDIO_SS_STOP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_SS_STOP_SHIFT))&CCM_ANALOG_PLL_AUDIO_SS_STOP_MASK) +/* PLL_AUDIO_NUM Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_NUM_A_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_AUDIO_NUM_A_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_NUM_A(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_NUM_A_SHIFT))&CCM_ANALOG_PLL_AUDIO_NUM_A_MASK) +#define CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_AUDIO_NUM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_SHIFT))&CCM_ANALOG_PLL_AUDIO_NUM_RSVD0_MASK) +/* PLL_AUDIO_DENOM Bit Fields */ +#define CCM_ANALOG_PLL_AUDIO_DENOM_B_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_AUDIO_DENOM_B_SHIFT 0 +#define CCM_ANALOG_PLL_AUDIO_DENOM_B(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_DENOM_B_SHIFT))&CCM_ANALOG_PLL_AUDIO_DENOM_B_MASK) +#define CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_SHIFT))&CCM_ANALOG_PLL_AUDIO_DENOM_RSVD0_MASK) +/* PLL_VIDEO Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_LOCK_SHIFT 31 +/* PLL_VIDEO_SET Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_SET_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_SET_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_SET_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_SET_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_SET_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_SET_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_SET_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_SET_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_SET_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_SET_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_SET_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_SET_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_SET_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_SET_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SET_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_SET_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_SET_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_SET_LOCK_SHIFT 31 +/* PLL_VIDEO_CLR Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_CLR_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_CLR_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_CLR_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_CLR_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_CLR_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_CLR_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_CLR_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_CLR_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_CLR_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_CLR_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_CLR_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_CLR_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_CLR_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_CLR_LOCK_SHIFT 31 +/* PLL_VIDEO_TOG Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_MASK 0x7Fu +#define CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_LF_MASK 0x80u +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_LF_SHIFT 7 +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_LF_MASK 0x100u +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_LF_SHIFT 8 +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_CP_MASK 0x200u +#define CCM_ANALOG_PLL_VIDEO_TOG_HALF_CP_SHIFT 9 +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_CP_MASK 0x400u +#define CCM_ANALOG_PLL_VIDEO_TOG_DOUBLE_CP_SHIFT 10 +#define CCM_ANALOG_PLL_VIDEO_TOG_HOLD_RING_OFF_MASK 0x800u +#define CCM_ANALOG_PLL_VIDEO_TOG_HOLD_RING_OFF_SHIFT 11 +#define CCM_ANALOG_PLL_VIDEO_TOG_POWERDOWN_MASK 0x1000u +#define CCM_ANALOG_PLL_VIDEO_TOG_POWERDOWN_SHIFT 12 +#define CCM_ANALOG_PLL_VIDEO_TOG_ENABLE_CLK_MASK 0x2000u +#define CCM_ANALOG_PLL_VIDEO_TOG_ENABLE_CLK_SHIFT 13 +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_MASK 0xC000u +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_SHIFT 14 +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_CLK_SRC_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_MASK 0x10000u +#define CCM_ANALOG_PLL_VIDEO_TOG_BYPASS_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_TOG_DITHER_ENABLE_MASK 0x20000u +#define CCM_ANALOG_PLL_VIDEO_TOG_DITHER_ENABLE_SHIFT 17 +#define CCM_ANALOG_PLL_VIDEO_TOG_PFD_OFFSET_EN_MASK 0x40000u +#define CCM_ANALOG_PLL_VIDEO_TOG_PFD_OFFSET_EN_SHIFT 18 +#define CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_MASK 0x180000u +#define CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_SHIFT 19 +#define CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_TEST_DIV_SELECT_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD0_MASK 0x200000u +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD0_SHIFT 21 +#define CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_MASK 0xC00000u +#define CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_SHIFT 22 +#define CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_POST_DIV_SEL_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_PLL_VIDEO_OVERRIDE_MASK 0x1000000u +#define CCM_ANALOG_PLL_VIDEO_TOG_PLL_VIDEO_OVERRIDE_SHIFT 24 +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_MASK 0x7E000000u +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_SHIFT 25 +#define CCM_ANALOG_PLL_VIDEO_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_SHIFT))&CCM_ANALOG_PLL_VIDEO_TOG_RSVD1_MASK) +#define CCM_ANALOG_PLL_VIDEO_TOG_LOCK_MASK 0x80000000u +#define CCM_ANALOG_PLL_VIDEO_TOG_LOCK_SHIFT 31 +/* PLL_VIDEO_SS Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_SS_STEP_MASK 0x7FFFu +#define CCM_ANALOG_PLL_VIDEO_SS_STEP_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_SS_STEP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SS_STEP_SHIFT))&CCM_ANALOG_PLL_VIDEO_SS_STEP_MASK) +#define CCM_ANALOG_PLL_VIDEO_SS_ENABLE_MASK 0x8000u +#define CCM_ANALOG_PLL_VIDEO_SS_ENABLE_SHIFT 15 +#define CCM_ANALOG_PLL_VIDEO_SS_STOP_MASK 0xFFFF0000u +#define CCM_ANALOG_PLL_VIDEO_SS_STOP_SHIFT 16 +#define CCM_ANALOG_PLL_VIDEO_SS_STOP(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_SS_STOP_SHIFT))&CCM_ANALOG_PLL_VIDEO_SS_STOP_MASK) +/* PLL_VIDEO_NUM Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_NUM_A_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_VIDEO_NUM_A_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_NUM_A(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_NUM_A_SHIFT))&CCM_ANALOG_PLL_VIDEO_NUM_A_MASK) +#define CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_VIDEO_NUM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_SHIFT))&CCM_ANALOG_PLL_VIDEO_NUM_RSVD0_MASK) +/* PLL_VIDEO_DENOM Bit Fields */ +#define CCM_ANALOG_PLL_VIDEO_DENOM_B_MASK 0x3FFFFFFFu +#define CCM_ANALOG_PLL_VIDEO_DENOM_B_SHIFT 0 +#define CCM_ANALOG_PLL_VIDEO_DENOM_B(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_DENOM_B_SHIFT))&CCM_ANALOG_PLL_VIDEO_DENOM_B_MASK) +#define CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_MASK 0xC0000000u +#define CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_SHIFT 30 +#define CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_SHIFT))&CCM_ANALOG_PLL_VIDEO_DENOM_RSVD0_MASK) +/* CLK_MISC0 Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_RSVD0_MASK) +/* CLK_MISC0_SET Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_SET_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_SET_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_SET_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_SET_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_SET_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_SET_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_SET_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_SET_RSVD0_MASK) +/* CLK_MISC0_CLR Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_CLR_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_CLR_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_CLR_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_CLR_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_CLR_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_CLR_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_CLR_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_CLR_RSVD0_MASK) +/* CLK_MISC0_TOG Bit Fields */ +#define CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_MASK 0x1Fu +#define CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_SHIFT 0 +#define CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_SHIFT))&CCM_ANALOG_CLK_MISC0_TOG_LVDS1_CLK_SEL_MASK) +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_OBEN_MASK 0x20u +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_OBEN_SHIFT 5 +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_IBEN_MASK 0x40u +#define CCM_ANALOG_CLK_MISC0_TOG_LVDSCLK1_IBEN_SHIFT 6 +#define CCM_ANALOG_CLK_MISC0_TOG_ACLK2_PREDIV_MASK 0x80u +#define CCM_ANALOG_CLK_MISC0_TOG_ACLK2_PREDIV_SHIFT 7 +#define CCM_ANALOG_CLK_MISC0_TOG_RSVD0_MASK 0xFFFFFF00u +#define CCM_ANALOG_CLK_MISC0_TOG_RSVD0_SHIFT 8 +#define CCM_ANALOG_CLK_MISC0_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<CCM_ANALOG_CLK_MISC0_TOG_RSVD0_SHIFT))&CCM_ANALOG_CLK_MISC0_TOG_RSVD0_MASK) + +/* REG_1P0A Bit Fields */ +#define PMU_REG_1P0A_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_BO_OFFSET_SHIFT))&PMU_REG_1P0A_BO_OFFSET_MASK) +#define PMU_REG_1P0A_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_RSVD0_SHIFT))&PMU_REG_1P0A_RSVD0_MASK) +#define PMU_REG_1P0A_BO_MASK 0x10000u +#define PMU_REG_1P0A_BO_SHIFT 16 +#define PMU_REG_1P0A_OK_MASK 0x20000u +#define PMU_REG_1P0A_OK_SHIFT 17 +#define PMU_REG_1P0A_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_REG_TEST_SHIFT))&PMU_REG_1P0A_REG_TEST_MASK) +#define PMU_REG_1P0A_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_RSVD1_SHIFT))&PMU_REG_1P0A_RSVD1_MASK) +/* REG_1P0A_SET Bit Fields */ +#define PMU_REG_1P0A_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_BO_OFFSET_SHIFT))&PMU_REG_1P0A_SET_BO_OFFSET_MASK) +#define PMU_REG_1P0A_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_SET_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_SET_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_SET_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_RSVD0_SHIFT))&PMU_REG_1P0A_SET_RSVD0_MASK) +#define PMU_REG_1P0A_SET_BO_MASK 0x10000u +#define PMU_REG_1P0A_SET_BO_SHIFT 16 +#define PMU_REG_1P0A_SET_OK_MASK 0x20000u +#define PMU_REG_1P0A_SET_OK_SHIFT 17 +#define PMU_REG_1P0A_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_SET_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_REG_TEST_SHIFT))&PMU_REG_1P0A_SET_REG_TEST_MASK) +#define PMU_REG_1P0A_SET_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_SET_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_SET_RSVD1_SHIFT))&PMU_REG_1P0A_SET_RSVD1_MASK) +/* REG_1P0A_CLR Bit Fields */ +#define PMU_REG_1P0A_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_BO_OFFSET_SHIFT))&PMU_REG_1P0A_CLR_BO_OFFSET_MASK) +#define PMU_REG_1P0A_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_CLR_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_RSVD0_SHIFT))&PMU_REG_1P0A_CLR_RSVD0_MASK) +#define PMU_REG_1P0A_CLR_BO_MASK 0x10000u +#define PMU_REG_1P0A_CLR_BO_SHIFT 16 +#define PMU_REG_1P0A_CLR_OK_MASK 0x20000u +#define PMU_REG_1P0A_CLR_OK_SHIFT 17 +#define PMU_REG_1P0A_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_REG_TEST_SHIFT))&PMU_REG_1P0A_CLR_REG_TEST_MASK) +#define PMU_REG_1P0A_CLR_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_CLR_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_CLR_RSVD1_SHIFT))&PMU_REG_1P0A_CLR_RSVD1_MASK) +/* REG_1P0A_TOG Bit Fields */ +#define PMU_REG_1P0A_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0A_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0A_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0A_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0A_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0A_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0A_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0A_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0A_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0A_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0A_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_BO_OFFSET_SHIFT))&PMU_REG_1P0A_TOG_BO_OFFSET_MASK) +#define PMU_REG_1P0A_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0A_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0A_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0A_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0A_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_1P0A_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_1P0A_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_1P0A_TOG_RSVD0_SHIFT 13 +#define PMU_REG_1P0A_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_RSVD0_SHIFT))&PMU_REG_1P0A_TOG_RSVD0_MASK) +#define PMU_REG_1P0A_TOG_BO_MASK 0x10000u +#define PMU_REG_1P0A_TOG_BO_SHIFT 16 +#define PMU_REG_1P0A_TOG_OK_MASK 0x20000u +#define PMU_REG_1P0A_TOG_OK_SHIFT 17 +#define PMU_REG_1P0A_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0A_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0A_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0A_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0A_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0A_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_1P0A_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_REG_TEST_SHIFT))&PMU_REG_1P0A_TOG_REG_TEST_MASK) +#define PMU_REG_1P0A_TOG_RSVD1_MASK 0xFF000000u +#define PMU_REG_1P0A_TOG_RSVD1_SHIFT 24 +#define PMU_REG_1P0A_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0A_TOG_RSVD1_SHIFT))&PMU_REG_1P0A_TOG_RSVD1_MASK) +/* REG_1P0D Bit Fields */ +#define PMU_REG_1P0D_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_BO_OFFSET_SHIFT))&PMU_REG_1P0D_BO_OFFSET_MASK) +#define PMU_REG_1P0D_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_RSVD0_SHIFT))&PMU_REG_1P0D_RSVD0_MASK) +#define PMU_REG_1P0D_BO_MASK 0x10000u +#define PMU_REG_1P0D_BO_SHIFT 16 +#define PMU_REG_1P0D_OK_MASK 0x20000u +#define PMU_REG_1P0D_OK_SHIFT 17 +#define PMU_REG_1P0D_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_REG_TEST_SHIFT))&PMU_REG_1P0D_REG_TEST_MASK) +#define PMU_REG_1P0D_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_RSVD1_SHIFT))&PMU_REG_1P0D_RSVD1_MASK) +#define PMU_REG_1P0D_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_OVERRIDE_SHIFT 31 +/* REG_1P0D_SET Bit Fields */ +#define PMU_REG_1P0D_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_BO_OFFSET_SHIFT))&PMU_REG_1P0D_SET_BO_OFFSET_MASK) +#define PMU_REG_1P0D_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_SET_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_SET_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_SET_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_RSVD0_SHIFT))&PMU_REG_1P0D_SET_RSVD0_MASK) +#define PMU_REG_1P0D_SET_BO_MASK 0x10000u +#define PMU_REG_1P0D_SET_BO_SHIFT 16 +#define PMU_REG_1P0D_SET_OK_MASK 0x20000u +#define PMU_REG_1P0D_SET_OK_SHIFT 17 +#define PMU_REG_1P0D_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_SET_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_REG_TEST_SHIFT))&PMU_REG_1P0D_SET_REG_TEST_MASK) +#define PMU_REG_1P0D_SET_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_SET_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_SET_RSVD1_SHIFT))&PMU_REG_1P0D_SET_RSVD1_MASK) +#define PMU_REG_1P0D_SET_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_SET_OVERRIDE_SHIFT 31 +/* REG_1P0D_CLR Bit Fields */ +#define PMU_REG_1P0D_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_BO_OFFSET_SHIFT))&PMU_REG_1P0D_CLR_BO_OFFSET_MASK) +#define PMU_REG_1P0D_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_CLR_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_RSVD0_SHIFT))&PMU_REG_1P0D_CLR_RSVD0_MASK) +#define PMU_REG_1P0D_CLR_BO_MASK 0x10000u +#define PMU_REG_1P0D_CLR_BO_SHIFT 16 +#define PMU_REG_1P0D_CLR_OK_MASK 0x20000u +#define PMU_REG_1P0D_CLR_OK_SHIFT 17 +#define PMU_REG_1P0D_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_REG_TEST_SHIFT))&PMU_REG_1P0D_CLR_REG_TEST_MASK) +#define PMU_REG_1P0D_CLR_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_CLR_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_CLR_RSVD1_SHIFT))&PMU_REG_1P0D_CLR_RSVD1_MASK) +#define PMU_REG_1P0D_CLR_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_CLR_OVERRIDE_SHIFT 31 +/* REG_1P0D_TOG Bit Fields */ +#define PMU_REG_1P0D_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_1P0D_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_1P0D_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_1P0D_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_1P0D_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_1P0D_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_1P0D_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_1P0D_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_1P0D_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_1P0D_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_1P0D_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_BO_OFFSET_SHIFT))&PMU_REG_1P0D_TOG_BO_OFFSET_MASK) +#define PMU_REG_1P0D_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_1P0D_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_1P0D_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_1P0D_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_1P0D_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_1P0D_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_1P0D_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_1P0D_TOG_RSVD0_SHIFT 13 +#define PMU_REG_1P0D_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_RSVD0_SHIFT))&PMU_REG_1P0D_TOG_RSVD0_MASK) +#define PMU_REG_1P0D_TOG_BO_MASK 0x10000u +#define PMU_REG_1P0D_TOG_BO_SHIFT 16 +#define PMU_REG_1P0D_TOG_OK_MASK 0x20000u +#define PMU_REG_1P0D_TOG_OK_SHIFT 17 +#define PMU_REG_1P0D_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_1P0D_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_1P0D_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_1P0D_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_1P0D_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_1P0D_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_1P0D_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_REG_TEST_SHIFT))&PMU_REG_1P0D_TOG_REG_TEST_MASK) +#define PMU_REG_1P0D_TOG_RSVD1_MASK 0x7F000000u +#define PMU_REG_1P0D_TOG_RSVD1_SHIFT 24 +#define PMU_REG_1P0D_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_1P0D_TOG_RSVD1_SHIFT))&PMU_REG_1P0D_TOG_RSVD1_MASK) +#define PMU_REG_1P0D_TOG_OVERRIDE_MASK 0x80000000u +#define PMU_REG_1P0D_TOG_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2 Bit Fields */ +#define PMU_REG_HSIC_1P2_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2_SET Bit Fields */ +#define PMU_REG_HSIC_1P2_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_SET_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_SET_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_SET_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_SET_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_SET_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_SET_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_SET_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_SET_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_SET_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_SET_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_SET_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_SET_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_SET_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_SET_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_SET_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_SET_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_SET_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2_CLR Bit Fields */ +#define PMU_REG_HSIC_1P2_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_CLR_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_CLR_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_CLR_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_CLR_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_CLR_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_CLR_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_CLR_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_CLR_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_CLR_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_CLR_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_CLR_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_CLR_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_CLR_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_CLR_OVERRIDE_SHIFT 31 +/* REG_HSIC_1P2_TOG Bit Fields */ +#define PMU_REG_HSIC_1P2_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_HSIC_1P2_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_HSIC_1P2_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_HSIC_1P2_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_BO_OFFSET_SHIFT))&PMU_REG_HSIC_1P2_TOG_BO_OFFSET_MASK) +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_HSIC_1P2_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_HSIC_1P2_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_HSIC_1P2_TOG_RSVD0_SHIFT 13 +#define PMU_REG_HSIC_1P2_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_RSVD0_SHIFT))&PMU_REG_HSIC_1P2_TOG_RSVD0_MASK) +#define PMU_REG_HSIC_1P2_TOG_BO_MASK 0x10000u +#define PMU_REG_HSIC_1P2_TOG_BO_SHIFT 16 +#define PMU_REG_HSIC_1P2_TOG_OK_MASK 0x20000u +#define PMU_REG_HSIC_1P2_TOG_OK_SHIFT 17 +#define PMU_REG_HSIC_1P2_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_HSIC_1P2_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_HSIC_1P2_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_HSIC_1P2_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_HSIC_1P2_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_HSIC_1P2_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_HSIC_1P2_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_REG_TEST_SHIFT))&PMU_REG_HSIC_1P2_TOG_REG_TEST_MASK) +#define PMU_REG_HSIC_1P2_TOG_RSVD1_MASK 0x7F000000u +#define PMU_REG_HSIC_1P2_TOG_RSVD1_SHIFT 24 +#define PMU_REG_HSIC_1P2_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_HSIC_1P2_TOG_RSVD1_SHIFT))&PMU_REG_HSIC_1P2_TOG_RSVD1_MASK) +#define PMU_REG_HSIC_1P2_TOG_OVERRIDE_MASK 0x80000000u +#define PMU_REG_HSIC_1P2_TOG_OVERRIDE_SHIFT 31 +/* REG_LPSR_1P0 Bit Fields */ +#define PMU_REG_LPSR_1P0_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_RSVD1_MASK) +/* REG_LPSR_1P0_SET Bit Fields */ +#define PMU_REG_LPSR_1P0_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_SET_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_SET_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_SET_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_SET_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_SET_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_SET_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_SET_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_SET_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_SET_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_SET_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_SET_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_SET_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_SET_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_SET_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_SET_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_SET_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_SET_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_SET_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_SET_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_SET_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_SET_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_SET_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_SET_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_SET_RSVD1_MASK) +/* REG_LPSR_1P0_CLR Bit Fields */ +#define PMU_REG_LPSR_1P0_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_CLR_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_CLR_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_CLR_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_CLR_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_CLR_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_CLR_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_CLR_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_CLR_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_CLR_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_CLR_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_CLR_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_CLR_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_CLR_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_CLR_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_CLR_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_CLR_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_CLR_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_CLR_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_CLR_RSVD1_MASK) +/* REG_LPSR_1P0_TOG Bit Fields */ +#define PMU_REG_LPSR_1P0_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PULLDOWN_MASK 0x8u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PULLDOWN_SHIFT 3 +#define PMU_REG_LPSR_1P0_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_LPSR_1P0_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_LPSR_1P0_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_BO_OFFSET_SHIFT))&PMU_REG_LPSR_1P0_TOG_BO_OFFSET_MASK) +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PWRUPLOAD_MASK 0x80u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_PWRUPLOAD_SHIFT 7 +#define PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_LPSR_1P0_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_LPSR_1P0_TOG_RSVD0_MASK 0xE000u +#define PMU_REG_LPSR_1P0_TOG_RSVD0_SHIFT 13 +#define PMU_REG_LPSR_1P0_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_RSVD0_SHIFT))&PMU_REG_LPSR_1P0_TOG_RSVD0_MASK) +#define PMU_REG_LPSR_1P0_TOG_BO_MASK 0x10000u +#define PMU_REG_LPSR_1P0_TOG_BO_SHIFT 16 +#define PMU_REG_LPSR_1P0_TOG_OK_MASK 0x20000u +#define PMU_REG_LPSR_1P0_TOG_OK_SHIFT 17 +#define PMU_REG_LPSR_1P0_TOG_ENABLE_WEAK_LINREG_MASK 0x40000u +#define PMU_REG_LPSR_1P0_TOG_ENABLE_WEAK_LINREG_SHIFT 18 +#define PMU_REG_LPSR_1P0_TOG_SELREF_WEAK_LINREG_MASK 0x80000u +#define PMU_REG_LPSR_1P0_TOG_SELREF_WEAK_LINREG_SHIFT 19 +#define PMU_REG_LPSR_1P0_TOG_REG_TEST_MASK 0xF00000u +#define PMU_REG_LPSR_1P0_TOG_REG_TEST_SHIFT 20 +#define PMU_REG_LPSR_1P0_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_REG_TEST_SHIFT))&PMU_REG_LPSR_1P0_TOG_REG_TEST_MASK) +#define PMU_REG_LPSR_1P0_TOG_RSVD1_MASK 0xFF000000u +#define PMU_REG_LPSR_1P0_TOG_RSVD1_SHIFT 24 +#define PMU_REG_LPSR_1P0_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_LPSR_1P0_TOG_RSVD1_SHIFT))&PMU_REG_LPSR_1P0_TOG_RSVD1_MASK) +/* REG_3P0 Bit Fields */ +#define PMU_REG_3P0_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_RSVD0_MASK 0x8u +#define PMU_REG_3P0_RSVD0_SHIFT 3 +#define PMU_REG_3P0_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_BO_OFFSET_SHIFT))&PMU_REG_3P0_BO_OFFSET_MASK) +#define PMU_REG_3P0_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_RSVD1_SHIFT 13 +#define PMU_REG_3P0_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_RSVD1_SHIFT))&PMU_REG_3P0_RSVD1_MASK) +#define PMU_REG_3P0_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_REG_TEST_SHIFT))&PMU_REG_3P0_REG_TEST_MASK) +#define PMU_REG_3P0_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_RSVD2_SHIFT 22 +#define PMU_REG_3P0_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_RSVD2_SHIFT))&PMU_REG_3P0_RSVD2_MASK) +/* REG_3P0_SET Bit Fields */ +#define PMU_REG_3P0_SET_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_SET_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_SET_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_SET_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_SET_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_SET_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_SET_RSVD0_MASK 0x8u +#define PMU_REG_3P0_SET_RSVD0_SHIFT 3 +#define PMU_REG_3P0_SET_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_SET_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_SET_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_BO_OFFSET_SHIFT))&PMU_REG_3P0_SET_BO_OFFSET_MASK) +#define PMU_REG_3P0_SET_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_SET_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_SET_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_SET_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_SET_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_SET_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_SET_RSVD1_SHIFT 13 +#define PMU_REG_3P0_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_RSVD1_SHIFT))&PMU_REG_3P0_SET_RSVD1_MASK) +#define PMU_REG_3P0_SET_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_SET_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_SET_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_SET_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_SET_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_SET_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_SET_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_REG_TEST_SHIFT))&PMU_REG_3P0_SET_REG_TEST_MASK) +#define PMU_REG_3P0_SET_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_SET_RSVD2_SHIFT 22 +#define PMU_REG_3P0_SET_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_SET_RSVD2_SHIFT))&PMU_REG_3P0_SET_RSVD2_MASK) +/* REG_3P0_CLR Bit Fields */ +#define PMU_REG_3P0_CLR_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_CLR_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_CLR_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_CLR_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_CLR_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_CLR_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_CLR_RSVD0_MASK 0x8u +#define PMU_REG_3P0_CLR_RSVD0_SHIFT 3 +#define PMU_REG_3P0_CLR_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_CLR_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_CLR_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_BO_OFFSET_SHIFT))&PMU_REG_3P0_CLR_BO_OFFSET_MASK) +#define PMU_REG_3P0_CLR_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_CLR_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_CLR_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_CLR_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_CLR_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_CLR_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_CLR_RSVD1_SHIFT 13 +#define PMU_REG_3P0_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_RSVD1_SHIFT))&PMU_REG_3P0_CLR_RSVD1_MASK) +#define PMU_REG_3P0_CLR_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_CLR_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_CLR_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_CLR_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_CLR_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_CLR_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_CLR_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_REG_TEST_SHIFT))&PMU_REG_3P0_CLR_REG_TEST_MASK) +#define PMU_REG_3P0_CLR_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_CLR_RSVD2_SHIFT 22 +#define PMU_REG_3P0_CLR_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_CLR_RSVD2_SHIFT))&PMU_REG_3P0_CLR_RSVD2_MASK) +/* REG_3P0_TOG Bit Fields */ +#define PMU_REG_3P0_TOG_ENABLE_LINREG_MASK 0x1u +#define PMU_REG_3P0_TOG_ENABLE_LINREG_SHIFT 0 +#define PMU_REG_3P0_TOG_ENABLE_BO_MASK 0x2u +#define PMU_REG_3P0_TOG_ENABLE_BO_SHIFT 1 +#define PMU_REG_3P0_TOG_ENABLE_ILIMIT_MASK 0x4u +#define PMU_REG_3P0_TOG_ENABLE_ILIMIT_SHIFT 2 +#define PMU_REG_3P0_TOG_RSVD0_MASK 0x8u +#define PMU_REG_3P0_TOG_RSVD0_SHIFT 3 +#define PMU_REG_3P0_TOG_BO_OFFSET_MASK 0x70u +#define PMU_REG_3P0_TOG_BO_OFFSET_SHIFT 4 +#define PMU_REG_3P0_TOG_BO_OFFSET(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_BO_OFFSET_SHIFT))&PMU_REG_3P0_TOG_BO_OFFSET_MASK) +#define PMU_REG_3P0_TOG_VBUS_SEL_MASK 0x80u +#define PMU_REG_3P0_TOG_VBUS_SEL_SHIFT 7 +#define PMU_REG_3P0_TOG_OUTPUT_TRG_MASK 0x1F00u +#define PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT 8 +#define PMU_REG_3P0_TOG_OUTPUT_TRG(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_OUTPUT_TRG_SHIFT))&PMU_REG_3P0_TOG_OUTPUT_TRG_MASK) +#define PMU_REG_3P0_TOG_RSVD1_MASK 0xE000u +#define PMU_REG_3P0_TOG_RSVD1_SHIFT 13 +#define PMU_REG_3P0_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_RSVD1_SHIFT))&PMU_REG_3P0_TOG_RSVD1_MASK) +#define PMU_REG_3P0_TOG_BO_VDD3P0_MASK 0x10000u +#define PMU_REG_3P0_TOG_BO_VDD3P0_SHIFT 16 +#define PMU_REG_3P0_TOG_OK_VDD3P0_MASK 0x20000u +#define PMU_REG_3P0_TOG_OK_VDD3P0_SHIFT 17 +#define PMU_REG_3P0_TOG_REG_TEST_MASK 0x3C0000u +#define PMU_REG_3P0_TOG_REG_TEST_SHIFT 18 +#define PMU_REG_3P0_TOG_REG_TEST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_REG_TEST_SHIFT))&PMU_REG_3P0_TOG_REG_TEST_MASK) +#define PMU_REG_3P0_TOG_RSVD2_MASK 0xFFC00000u +#define PMU_REG_3P0_TOG_RSVD2_SHIFT 22 +#define PMU_REG_3P0_TOG_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<PMU_REG_3P0_TOG_RSVD2_SHIFT))&PMU_REG_3P0_TOG_RSVD2_MASK) +/* REF Bit Fields */ +#define PMU_REF_REFTOP_PWD_MASK 0x1u +#define PMU_REF_REFTOP_PWD_SHIFT 0 +#define PMU_REF_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_REFTOP_VBGADJ_SHIFT))&PMU_REF_REFTOP_VBGADJ_MASK) +#define PMU_REF_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_REFTOP_BIAS_TST_SHIFT))&PMU_REF_REFTOP_BIAS_TST_MASK) +#define PMU_REF_LPBG_SEL_MASK 0x400u +#define PMU_REF_LPBG_SEL_SHIFT 10 +#define PMU_REF_LPBG_TEST_MASK 0x800u +#define PMU_REF_LPBG_TEST_SHIFT 11 +#define PMU_REF_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_RSVD1_SHIFT 14 +#define PMU_REF_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_RSVD1_SHIFT))&PMU_REF_RSVD1_MASK) +/* REF_SET Bit Fields */ +#define PMU_REF_SET_REFTOP_PWD_MASK 0x1u +#define PMU_REF_SET_REFTOP_PWD_SHIFT 0 +#define PMU_REF_SET_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_SET_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_SET_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_SET_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_SET_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_SET_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_SET_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_SET_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_SET_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_SET_REFTOP_VBGADJ_SHIFT))&PMU_REF_SET_REFTOP_VBGADJ_MASK) +#define PMU_REF_SET_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_SET_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_SET_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_SET_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_SET_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_SET_REFTOP_BIAS_TST_SHIFT))&PMU_REF_SET_REFTOP_BIAS_TST_MASK) +#define PMU_REF_SET_LPBG_SEL_MASK 0x400u +#define PMU_REF_SET_LPBG_SEL_SHIFT 10 +#define PMU_REF_SET_LPBG_TEST_MASK 0x800u +#define PMU_REF_SET_LPBG_TEST_SHIFT 11 +#define PMU_REF_SET_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_SET_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_SET_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_SET_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_SET_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_SET_RSVD1_SHIFT 14 +#define PMU_REF_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_SET_RSVD1_SHIFT))&PMU_REF_SET_RSVD1_MASK) +/* REF_CLR Bit Fields */ +#define PMU_REF_CLR_REFTOP_PWD_MASK 0x1u +#define PMU_REF_CLR_REFTOP_PWD_SHIFT 0 +#define PMU_REF_CLR_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_CLR_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_CLR_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_CLR_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_CLR_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_CLR_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_CLR_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_CLR_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_CLR_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_CLR_REFTOP_VBGADJ_SHIFT))&PMU_REF_CLR_REFTOP_VBGADJ_MASK) +#define PMU_REF_CLR_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_CLR_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_CLR_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_CLR_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_CLR_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_CLR_REFTOP_BIAS_TST_SHIFT))&PMU_REF_CLR_REFTOP_BIAS_TST_MASK) +#define PMU_REF_CLR_LPBG_SEL_MASK 0x400u +#define PMU_REF_CLR_LPBG_SEL_SHIFT 10 +#define PMU_REF_CLR_LPBG_TEST_MASK 0x800u +#define PMU_REF_CLR_LPBG_TEST_SHIFT 11 +#define PMU_REF_CLR_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_CLR_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_CLR_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_CLR_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_CLR_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_CLR_RSVD1_SHIFT 14 +#define PMU_REF_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_CLR_RSVD1_SHIFT))&PMU_REF_CLR_RSVD1_MASK) +/* REF_TOG Bit Fields */ +#define PMU_REF_TOG_REFTOP_PWD_MASK 0x1u +#define PMU_REF_TOG_REFTOP_PWD_SHIFT 0 +#define PMU_REF_TOG_REFTOP_PWDVBGUP_MASK 0x2u +#define PMU_REF_TOG_REFTOP_PWDVBGUP_SHIFT 1 +#define PMU_REF_TOG_REFTOP_LOWPOWER_MASK 0x4u +#define PMU_REF_TOG_REFTOP_LOWPOWER_SHIFT 2 +#define PMU_REF_TOG_REFTOP_SELFBIASOFF_MASK 0x8u +#define PMU_REF_TOG_REFTOP_SELFBIASOFF_SHIFT 3 +#define PMU_REF_TOG_REFTOP_VBGADJ_MASK 0x70u +#define PMU_REF_TOG_REFTOP_VBGADJ_SHIFT 4 +#define PMU_REF_TOG_REFTOP_VBGADJ(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_TOG_REFTOP_VBGADJ_SHIFT))&PMU_REF_TOG_REFTOP_VBGADJ_MASK) +#define PMU_REF_TOG_REFTOP_VBGUP_MASK 0x80u +#define PMU_REF_TOG_REFTOP_VBGUP_SHIFT 7 +#define PMU_REF_TOG_REFTOP_BIAS_TST_MASK 0x300u +#define PMU_REF_TOG_REFTOP_BIAS_TST_SHIFT 8 +#define PMU_REF_TOG_REFTOP_BIAS_TST(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_TOG_REFTOP_BIAS_TST_SHIFT))&PMU_REF_TOG_REFTOP_BIAS_TST_MASK) +#define PMU_REF_TOG_LPBG_SEL_MASK 0x400u +#define PMU_REF_TOG_LPBG_SEL_SHIFT 10 +#define PMU_REF_TOG_LPBG_TEST_MASK 0x800u +#define PMU_REF_TOG_LPBG_TEST_SHIFT 11 +#define PMU_REF_TOG_REFTOP_IBIAS_OFF_MASK 0x1000u +#define PMU_REF_TOG_REFTOP_IBIAS_OFF_SHIFT 12 +#define PMU_REF_TOG_REFTOP_LINREGREF_EN_MASK 0x2000u +#define PMU_REF_TOG_REFTOP_LINREGREF_EN_SHIFT 13 +#define PMU_REF_TOG_RSVD1_MASK 0xFFFFC000u +#define PMU_REF_TOG_RSVD1_SHIFT 14 +#define PMU_REF_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<PMU_REF_TOG_RSVD1_SHIFT))&PMU_REF_TOG_RSVD1_MASK) +/* LOWPWR_CTRL Bit Fields */ +#define PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_CONTROL1_MASK) +/* LOWPWR_CTRL_SET Bit Fields */ +#define PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_SET_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_SET_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_SET_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_SET_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_SET_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_SET_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_SET_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_SET_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_SET_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_SET_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_SET_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_SET_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_SET_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_SET_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_SET_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_SET_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_SET_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_SET_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_SET_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_SET_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_SET_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_SET_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_SET_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_SET_CONTROL1_MASK) +/* LOWPWR_CTRL_CLR Bit Fields */ +#define PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_CLR_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_CLR_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_CLR_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_CLR_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_CLR_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_CLR_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_CLR_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_CLR_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_CLR_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_CLR_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_CLR_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_CLR_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_CLR_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_CLR_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_CLR_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_CLR_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_CLR_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_CLR_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_CLR_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_CLR_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_CLR_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_CLR_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_CLR_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_CLR_CONTROL1_MASK) +/* LOWPWR_CTRL_TOG Bit Fields */ +#define PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_MASK 0x3u +#define PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_SHIFT 0 +#define PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_SHIFT))&PMU_LOWPWR_CTRL_TOG_STOP_MODE_CONFIG_MASK) +#define PMU_LOWPWR_CTRL_TOG_RSVD0_MASK 0xFCu +#define PMU_LOWPWR_CTRL_TOG_RSVD0_SHIFT 2 +#define PMU_LOWPWR_CTRL_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_RSVD0_SHIFT))&PMU_LOWPWR_CTRL_TOG_RSVD0_MASK) +#define PMU_LOWPWR_CTRL_TOG_L1_PWRGATE_MASK 0x100u +#define PMU_LOWPWR_CTRL_TOG_L1_PWRGATE_SHIFT 8 +#define PMU_LOWPWR_CTRL_TOG_L2_PWRGATE_MASK 0x200u +#define PMU_LOWPWR_CTRL_TOG_L2_PWRGATE_SHIFT 9 +#define PMU_LOWPWR_CTRL_TOG_CPU_PWRGATE_MASK 0x400u +#define PMU_LOWPWR_CTRL_TOG_CPU_PWRGATE_SHIFT 10 +#define PMU_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_MASK 0x800u +#define PMU_LOWPWR_CTRL_TOG_DISPLAY_PWRGATE_SHIFT 11 +#define PMU_LOWPWR_CTRL_TOG_MIX_PWRGATE_MASK 0x1000u +#define PMU_LOWPWR_CTRL_TOG_MIX_PWRGATE_SHIFT 12 +#define PMU_LOWPWR_CTRL_TOG_GPU_PWRGATE_MASK 0x2000u +#define PMU_LOWPWR_CTRL_TOG_GPU_PWRGATE_SHIFT 13 +#define PMU_LOWPWR_CTRL_TOG_CONTROL0_MASK 0xFFC000u +#define PMU_LOWPWR_CTRL_TOG_CONTROL0_SHIFT 14 +#define PMU_LOWPWR_CTRL_TOG_CONTROL0(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_CONTROL0_SHIFT))&PMU_LOWPWR_CTRL_TOG_CONTROL0_MASK) +#define PMU_LOWPWR_CTRL_TOG_CONTROL1_MASK 0xFF000000u +#define PMU_LOWPWR_CTRL_TOG_CONTROL1_SHIFT 24 +#define PMU_LOWPWR_CTRL_TOG_CONTROL1(x) (((uint32_t)(((uint32_t)(x))<<PMU_LOWPWR_CTRL_TOG_CONTROL1_SHIFT))&PMU_LOWPWR_CTRL_TOG_CONTROL1_MASK) + + +/* HW_ANADIG_TEMPSENSE0 Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE0_SET Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_SET_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE0_CLR Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_CLR_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE0_TOG Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_LOW_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_MASK 0x3FE00u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_HIGH_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_MASK 0x7FC0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_SHIFT 18 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_PANIC_ALARM_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_MASK 0xF8000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_SHIFT 27 +#define TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE0_TOG_RSVD1_MASK) +/* HW_ANADIG_TEMPSENSE1 Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE1_SET Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_SET_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_SET_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_SET_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE1_CLR Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_CLR_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE1_TOG Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_MASK 0x1FFu +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_TEMP_VALUE_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_POWER_DOWN_MASK 0x200u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_POWER_DOWN_SHIFT 9 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_TEMP_MASK 0x400u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_TEMP_SHIFT 10 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_FINISHED_MASK 0x800u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_FINISHED_SHIFT 11 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_MASK 0xF000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_SHIFT 12 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_MASK 0xFFFF0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_SHIFT 16 +#define TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE1_TOG_MEASURE_FREQ_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_T_MUX_ADDR_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM_SET Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_SET_T_MUX_ADDR_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM_CLR Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_CLR_T_MUX_ADDR_MASK) +/* HW_ANADIG_TEMPSENSE_TRIM_TOG Bit Fields */ +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_MASK 0x1Fu +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_SHIFT 0 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_VREF_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_MASK 0x60u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_SHIFT 5 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD0_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_EN_READ_MASK 0x80u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_EN_READ_SHIFT 7 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_MASK 0x1FF00u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_SHIFT 8 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_VREF_VBE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_MASK 0xE0000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_SHIFT 17 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD1_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_MASK 0xF00000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_SHIFT 20 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_BUF_SLOPE_SEL_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_MASK 0x1F000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_SHIFT 24 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_RSVD2_MASK) +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_MASK 0xE0000000u +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_SHIFT 29 +#define TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR(x) (((uint32_t)(((uint32_t)(x))<<TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_SHIFT))&TEMPMON_HW_ANADIG_TEMPSENSE_TRIM_TOG_T_MUX_ADDR_MASK) + + +#define CCM_GPR(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i)) +#define CCM_OBSERVE(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i)) +#define CCM_SCTRL(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i)) +#define CCM_CCGR(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i)) +#define CCM_ROOT_TARGET(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i)) + +#define CCM_GPR_SET(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i) + 4) +#define CCM_OBSERVE_SET(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i) + 4) +#define CCM_SCTRL_SET(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i) + 4) +#define CCM_CCGR_SET(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i) + 4) +#define CCM_ROOT_TARGET_SET(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i) + 4) + +#define CCM_GPR_CLR(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i) + 8) +#define CCM_OBSERVE_CLR(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i) + 8) +#define CCM_SCTRL_CLR(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i) + 8) +#define CCM_CCGR_CLR(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i) + 8) +#define CCM_ROOT_TARGET_CLR(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i) + 8) + +#define CCM_GPR_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_GPR0_OFFSET + 0x10 * (i) + 12) +#define CCM_OBSERVE_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_OBSERVE0_OFFSET + 0x10 * (i) + 12) +#define CCM_SCTRL_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_SCTRL0_OFFSET + 0x10 * (i) + 12) +#define CCM_CCGR_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_CCGR0_OFFSET + 0x10 * (i) + 12) +#define CCM_ROOT_TARGET_TOGGLE(i) (CCM_BASE_ADDRESS + CCM_ROOT0_TARGET_OFFSET + 0x80 * (i) + 12) + +#define HW_CCM_GPR_WR(i, v) writel((v), CCM_GPR(i)) +#define HW_CCM_CCM_OBSERVE_WR(i, v) writel((v), CCM_OBSERVE(i)) +#define HW_CCM_SCTRL_WR(i, v) writel((v), CCM_SCTRL(i)) +#define HW_CCM_CCGR_WR(i, v) writel((v), CCM_CCGR(i)) +#define HW_CCM_ROOT_TARGET_WR(i, v) writel((v), CCM_ROOT_TARGET(i)) + +#define HW_CCM_GPR_RD(i) readl(CCM_GPR(i)) +#define HW_CCM_CCM_OBSERVE_RD(i) readl(CCM_OBSERVE(i)) +#define HW_CCM_SCTRL_RD(i) readl(CCM_SCTRL(i)) +#define HW_CCM_CCGR_RD(i) readl(CCM_CCGR(i)) +#define HW_CCM_ROOT_TARGET_RD(i) readl(CCM_ROOT_TARGET(i)) + +#define HW_CCM_GPR_SET(i, v) writel((v), CCM_GPR_SET(i)) +#define HW_CCM_CCM_OBSERVE_SET(i, v) writel((v), CCM_CCM_OBSERVE_SET(i)) +#define HW_CCM_SCTRL_SET(i, v) writel((v), CCM_SCTRL_SET(i)) +#define HW_CCM_CCGR_SET(i, v) writel((v), CCM_CCGR_SET(i)) +#define HW_CCM_ROOT_TARGET_SET(i, v) writel((v), CCM_ROOT_TARGET_SET(i)) + +#define HW_CCM_GPR_CLR(i, v) writel((v), CCM_GPR_CLR(i)) +#define HW_CCM_CCM_OBSERVE_CLR(i, v) writel((v), CCM_CCM_OBSERVE_CLR(i)) +#define HW_CCM_SCTRL_CLR(i, v) writel((v), CCM_SCTRL_CLR(i)) +#define HW_CCM_CCGR_CLR(i, v) writel((v), CCM_CCGR_CLR(i)) +#define HW_CCM_ROOT_TARGET_CLR(i, v) writel((v), CCM_ROOT_TARGET_CLR(i)) + +#define HW_CCM_GPR_TOGGLE(i, v) writel((v), CCM_GPR_TOGGLE(i)) +#define HW_CCM_CCM_OBSERVE_TOGGLE(i, v) writel((v), CCM_CCM_OBSERVE_TOGGLE(i)) +#define HW_CCM_SCTRL_TOGGLE(i, v) writel((v), CCM_SCTRL_TOGGLE(i)) +#define HW_CCM_CCGR_TOGGLE(i, v) writel((v), CCM_CCGR_TOGGLE(i)) +#define HW_CCM_ROOT_TARGET_TOGGLE(i, v) writel((v), CCM_ROOT_TARGET_TOGGLE(i)) + +#define CCM_CLK_ON_MSK 0x03 + +#define CCM_ROOT_TGT_POST_DIV_SHIFT 0 +#define CCM_ROOT_TGT_PRE_DIV_SHIFT 15 +#define CCM_ROOT_TGT_MUX_SHIFT 24 +#define CCM_ROOT_TGT_ENABLE_SHIFT 28 +#define CCM_ROOT_TGT_POST_DIV_MSK 0x3F +#define CCM_ROOT_TGT_PRE_DIV_MSK (0x07 << CCM_ROOT_TGT_PRE_DIV_SHIFT) +#define CCM_ROOT_TGT_MUX_MSK (0x07 << CCM_ROOT_TGT_MUX_SHIFT) +#define CCM_ROOT_TGT_ENABLE_MSK (0x01 << CCM_ROOT_TGT_ENABLE_SHIFT) + +#define CCM_ROOT_TGT_POST_DIV(x) ((((x) - 1) << CCM_ROOT_TGT_POST_DIV_SHIFT) & CCM_ROOT_TGT_POST_DIV_MSK) +#define CCM_ROOT_TGT_PRE_DIV(x) ((((x) - 1) << CCM_ROOT_TGT_PRE_DIV_SHIFT) & CCM_ROOT_TGT_PRE_DIV_MSK) +#define CCM_ROOT_TGT_MUX_TO(x) ((((x) - 1) << CCM_ROOT_TGT_MUX_SHIFT) & CCM_ROOT_TGT_MUX_MSK) + +/* + * Field values definition for clock slice TARGET register + */ + +#define CLK_ROOT_ON 0x10000000 +#define CLK_ROOT_OFF 0x0 +#define CLK_ROOT_ENABLE_MASK 0x10000000 +#define CLK_ROOT_ENABLE_SHIFT 28 + +#define CLK_ROOT_ALT0 0x00000000 +#define CLK_ROOT_ALT1 0x01000000 +#define CLK_ROOT_ALT2 0x02000000 +#define CLK_ROOT_ALT3 0x03000000 +#define CLK_ROOT_ALT4 0x04000000 +#define CLK_ROOT_ALT5 0x05000000 +#define CLK_ROOT_ALT6 0x06000000 +#define CLK_ROOT_ALT7 0x07000000 + + +#define DRAM_CLK_ROOT_POST_DIV_MASK 0x00000007 +#define CLK_ROOT_POST_DIV_MASK 0x0000003f +#define CLK_ROOT_POST_DIV_SHIFT 0 +#define CLK_ROOT_POST_DIV(n) ((n << CLK_ROOT_POST_DIV_SHIFT) & CLK_ROOT_POST_DIV_MASK) + +#define CLK_ROOT_AUTO_DIV_MASK 0x00000700 +#define CLK_ROOT_AUTO_DIV_SHIFT 8 +#define CLK_ROOT_AUTO_DIV(n) ((n << CLK_ROOT_AUTO_DIV_SHIFT) & CLK_ROOT_AUTO_DIV_MASK) + +#define CLK_ROOT_AUTO_EN_MASK 0x00001000 +#define CLK_ROOT_AUTO_EN 0x00001000 + +#define CLK_ROOT_PRE_DIV_MASK 0x00070000 +#define CLK_ROOT_PRE_DIV_SHIFT 16 +#define CLK_ROOT_PRE_DIV(n) ((n << CLK_ROOT_PRE_DIV_SHIFT) & CLK_ROOT_PRE_DIV_MASK) + +#define CLK_ROOT_MUX_MASK 0x07000000 +#define CLK_ROOT_MUX_SHIFT 24 + +#define CLK_ROOT_EN_MASK 0x10000000 + +#define CLK_ROOT_AUTO_ON 0x00001000 +#define CLK_ROOT_AUTO_OFF 0x0 + +/* ARM_A7_CLK_ROOT */ +#define ARM_A7_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_ARM_MAIN_800M_CLK 0x01000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_DRAM_MAIN_1066M_CLK 0x03000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x05000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x02000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define ARM_A7_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ARM_M4_CLK_ROOT */ +#define ARM_M4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x03000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x02000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ARM_M4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ARM_M0_CLK_ROOT */ +#define ARM_M0_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x03000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x02000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ARM_M0_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* MAIN_AXI_CLK_ROOT */ +#define MAIN_AXI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x01000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x04000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x03000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define MAIN_AXI_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* DISP_AXI_CLK_ROOT */ +#define DISP_AXI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x01000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x04000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x05000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x03000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define DISP_AXI_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 + +/* ENET_AXI_CLK_ROOT */ +#define ENET_AXI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x04000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x01000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x07000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x03000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET_AXI_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* NAND_USDHC_BUS_CLK_ROOT */ +#define NAND_USDHC_BUS_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x03000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x01000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x04000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x05000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define NAND_USDHC_BUS_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x07000000 + +/* AHB_CLK_ROOT */ +#define AHB_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define AHB_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define AHB_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x03000000 +#define AHB_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define AHB_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define AHB_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define AHB_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define AHB_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 + +/* DRAM_PHYM_CLK_ROOT */ +#define DRAM_PHYM_CLK_ROOT_FROM_PLL_DRAM_MAIN_1066M_CLK 0x00000000 +#define DRAM_PHYM_CLK_ROOT_FROM_PLL_DRAM_PHYM_ALT_CLK_ROOT 0x01000000 + +/* DRAM_CLK_ROOT */ +#define DRAM_CLK_ROOT_FROM_PLL_DRAM_MAIN_1066M_CLK 0x00000000 +#define DRAM_CLK_ROOT_FROM_PLL_DRAM_ALT_CLK_ROOT 0x01000000 + +/* DRAM_PHYM_ALT_CLK_ROOT */ +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x01000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x02000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x05000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define DRAM_PHYM_ALT_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x04000000 + +/* DRAM_ALT_CLK_ROOT */ +#define DRAM_ALT_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x01000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x02000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x05000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x07000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x04000000 +#define DRAM_ALT_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 + +/* USB_HSIC_CLK_ROOT */ +#define USB_HSIC_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x01000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x03000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x05000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USB_HSIC_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x02000000 + +/* PCIE_CTRL_CLK_ROOT */ +#define PCIE_CTRL_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x02000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x06000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x03000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x07000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x05000000 +#define PCIE_CTRL_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x01000000 + +/* PCIE_PHY_CLK_ROOT */ +#define PCIE_PHY_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PCIE_PHY_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x07000000 +#define PCIE_PHY_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x02000000 +#define PCIE_PHY_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_1 0x03000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_2 0x04000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 +#define PCIE_PHY_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* EPDC_PIXEL_CLK_ROOT */ +#define EPDC_PIXEL_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD1_332M_CLK 0x01000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x04000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x05000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x06000000 +#define EPDC_PIXEL_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 + +/* LCDIF_PIXEL_CLK_ROOT */ +#define LCDIF_PIXEL_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x01000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define LCDIF_PIXEL_CLK_ROOT_FROM_EXT_CLK_3 0x03000000 + +/* MIPI_DSI_EXTSER_CLK_ROOT */ +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x05000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_PFD0_196M_CLK 0x04000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x02000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x01000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x07000000 +#define MIPI_DSI_EXTSER_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* MIPI_CSI_WARP_CLK_ROOT */ +#define MIPI_CSI_WARP_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x05000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_PFD0_196M_CLK 0x04000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x02000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x01000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x07000000 +#define MIPI_CSI_WARP_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* MIPI_DPHY_REF_CLK_ROOT */ +#define MIPI_DPHY_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_SYS_PFD5_CLK 0x03000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_REF_1M_CLK 0x04000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define MIPI_DPHY_REF_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* SAI1_CLK_ROOT */ +#define SAI1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SAI1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SAI1_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SAI1_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SAI1_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SAI1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SAI1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SAI1_CLK_ROOT_FROM_EXT_CLK_2 0x07000000 + +/* SAI2_CLK_ROOT */ +#define SAI2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SAI2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SAI2_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SAI2_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SAI2_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SAI2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SAI2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SAI2_CLK_ROOT_FROM_EXT_CLK_2 0x07000000 + +/* SAI3_CLK_ROOT */ +#define SAI3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SAI3_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SAI3_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SAI3_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SAI3_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SAI3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SAI3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SAI3_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* SPDIF_CLK_ROOT */ +#define SPDIF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SPDIF_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SPDIF_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SPDIF_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define SPDIF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SPDIF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define SPDIF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define SPDIF_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* ENET1_REF_CLK_ROOT */ +#define ENET1_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x04000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x01000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK 0x03000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET1_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ENET1_REF_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* ENET1_TIME_CLK_ROOT */ +#define ENET1_TIME_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET1_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define ENET1_TIME_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define ENET1_TIME_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_1 0x03000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_2 0x04000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 +#define ENET1_TIME_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* ENET2_REF_CLK_ROOT */ +#define ENET2_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x04000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x01000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK 0x03000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET2_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define ENET2_REF_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* ENET2_TIME_CLK_ROOT */ +#define ENET2_TIME_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET2_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define ENET2_TIME_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x02000000 +#define ENET2_TIME_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_1 0x03000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_2 0x04000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 +#define ENET2_TIME_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* ENET_PHY_REF_CLK_ROOT */ +#define ENET_PHY_REF_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x04000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x07000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x03000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK 0x01000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define ENET_PHY_REF_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 + +/* EIM_CLK_ROOT */ +#define EIM_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define EIM_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x04000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define EIM_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x05000000 +#define EIM_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define EIM_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* NAND_CLK_ROOT */ +#define NAND_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define NAND_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define NAND_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x01000000 +#define NAND_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x03000000 +#define NAND_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x04000000 +#define NAND_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x05000000 +#define NAND_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define NAND_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 + +/* QSPI_CLK_ROOT */ +#define QSPI_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define QSPI_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD3_CLK 0x04000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x01000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define QSPI_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define QSPI_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* USDHC1_CLK_ROOT */ +#define USDHC1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USDHC1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x01000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USDHC1_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* USDHC2_CLK_ROOT */ +#define USDHC2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USDHC2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x01000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USDHC2_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USDHC2_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* USDHC3_CLK_ROOT */ +#define USDHC3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define USDHC3_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x01000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD6_CLK 0x06000000 +#define USDHC3_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define USDHC3_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x03000000 + +/* CAN1_CLK_ROOT */ +#define CAN1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define CAN1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define CAN1_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define CAN1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define CAN1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x04000000 +#define CAN1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define CAN1_CLK_ROOT_FROM_EXT_CLK_1 0x06000000 +#define CAN1_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* CAN2_CLK_ROOT */ +#define CAN2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define CAN2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define CAN2_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x03000000 +#define CAN2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define CAN2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x04000000 +#define CAN2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define CAN2_CLK_ROOT_FROM_EXT_CLK_1 0x06000000 +#define CAN2_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* I2C1_CLK_ROOT */ +#define I2C1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C1_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C1_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* I2C2_CLK_ROOT */ +#define I2C2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C2_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C2_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* I2C3_CLK_ROOT */ +#define I2C3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C3_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C3_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C3_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C3_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C3_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* I2C4_CLK_ROOT */ +#define I2C4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define I2C4_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define I2C4_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x01000000 +#define I2C4_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x07000000 +#define I2C4_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK 0x02000000 +#define I2C4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define I2C4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define I2C4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x06000000 + +/* UART1_CLK_ROOT */ +#define UART1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART1_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART1_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART1_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART1_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* UART2_CLK_ROOT */ +#define UART2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART2_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART2_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART2_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART2_CLK_ROOT_FROM_EXT_CLK_3 0x06000000 + +/* UART3_CLK_ROOT */ +#define UART3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART3_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART3_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART3_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART3_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART3_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART3_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* UART4_CLK_ROOT */ +#define UART4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART4_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART4_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART4_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART4_CLK_ROOT_FROM_EXT_CLK_3 0x06000000 + +/* UART5_CLK_ROOT */ +#define UART5_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART5_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART5_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART5_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART5_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART5_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART5_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART5_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* UART6_CLK_ROOT */ +#define UART6_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART6_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART6_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART6_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART6_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART6_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART6_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART6_CLK_ROOT_FROM_EXT_CLK_3 0x06000000 + +/* UART7_CLK_ROOT */ +#define UART7_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define UART7_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define UART7_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define UART7_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x03000000 +#define UART7_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define UART7_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 +#define UART7_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 +#define UART7_CLK_ROOT_FROM_EXT_CLK_4 0x06000000 + +/* ECSPI1_CLK_ROOT */ +#define ECSPI1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ECSPI2_CLK_ROOT */ +#define ECSPI2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ECSPI3_CLK_ROOT */ +#define ECSPI3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI3_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* ECSPI4_CLK_ROOT */ +#define ECSPI4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK 0x04000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x03000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK 0x05000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_ENET_MAIN_250M_CLK 0x06000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x02000000 +#define ECSPI4_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* PWM1_CLK_ROOT */ +#define PWM1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM1_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM1_CLK_ROOT_FROM_EXT_CLK_1 0x05000000 + +/* PWM2_CLK_ROOT */ +#define PWM2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM2_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM2_CLK_ROOT_FROM_EXT_CLK_1 0x05000000 + +/* PWM3_CLK_ROOT */ +#define PWM3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM3_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM3_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM3_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM3_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 + +/* PWM4_CLK_ROOT */ +#define PWM4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define PWM4_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define PWM4_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define PWM4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define PWM4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define PWM4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define PWM4_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define PWM4_CLK_ROOT_FROM_EXT_CLK_2 0x05000000 + +/* FLEXTIMER1_CLK_ROOT */ +#define FLEXTIMER1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define FLEXTIMER1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define FLEXTIMER1_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define FLEXTIMER1_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 + +/* FLEXTIMER2_CLK_ROOT */ +#define FLEXTIMER2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x04000000 +#define FLEXTIMER2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x07000000 +#define FLEXTIMER2_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 +#define FLEXTIMER2_CLK_ROOT_FROM_EXT_CLK_3 0x05000000 + +/* SIM1_CLK_ROOT */ +#define SIM1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SIM1_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SIM1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define SIM1_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SIM1_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define SIM1_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SIM1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define SIM1_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x04000000 + +/* SIM2_CLK_ROOT */ +#define SIM2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define SIM2_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define SIM2_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define SIM2_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define SIM2_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define SIM2_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x06000000 +#define SIM2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x05000000 +#define SIM2_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x04000000 + +/* GPT1_CLK_ROOT */ +#define GPT1_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT1_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT1_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT1_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT1_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT1_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT1_CLK_ROOT_FROM_EXT_CLK_1 0x07000000 + +/* GPT2_CLK_ROOT */ +#define GPT2_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT2_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT2_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT2_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT2_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT2_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT2_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT2_CLK_ROOT_FROM_EXT_CLK_2 0x07000000 + +/* GPT3_CLK_ROOT */ +#define GPT3_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT3_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT3_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT3_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT3_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT3_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT3_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT3_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* GPT4_CLK_ROOT */ +#define GPT4_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define GPT4_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define GPT4_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK 0x01000000 +#define GPT4_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x03000000 +#define GPT4_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x06000000 +#define GPT4_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x04000000 +#define GPT4_CLK_ROOT_FROM_REF_1M_CLK 0x05000000 +#define GPT4_CLK_ROOT_FROM_EXT_CLK_4 0x07000000 + +/* TRACE_CLK_ROOT */ +#define TRACE_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define TRACE_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define TRACE_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define TRACE_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define TRACE_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define TRACE_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define TRACE_CLK_ROOT_FROM_EXT_CLK_1 0x06000000 +#define TRACE_CLK_ROOT_FROM_EXT_CLK_3 0x07000000 + +/* WDOG_CLK_ROOT */ +#define WDOG_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define WDOG_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define WDOG_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define WDOG_CLK_ROOT_FROM_PLL_SYS_PFD1_166M_CLK 0x07000000 +#define WDOG_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define WDOG_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define WDOG_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x05000000 +#define WDOG_CLK_ROOT_FROM_REF_1M_CLK 0x06000000 + +/* CSI_MCLK_CLK_ROOT */ +#define CSI_MCLK_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define CSI_MCLK_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* AUDIO_MCLK_CLK_ROOT */ +#define AUDIO_MCLK_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x03000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK 0x02000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_SYS_PFD2_135M_CLK 0x01000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK 0x04000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define AUDIO_MCLK_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x07000000 + +/* WRCLK_CLK_ROOT */ +#define WRCLK_CLK_ROOT_FROM_OSC_24M_CLK 0x00000000 +#define WRCLK_CLK_ROOT_FROM_PLL_DRAM_MAIN_533M_CLK 0x02000000 +#define WRCLK_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK 0x04000000 +#define WRCLK_CLK_ROOT_FROM_PLL_SYS_PFD2_270M_CLK 0x05000000 +#define WRCLK_CLK_ROOT_FROM_PLL_SYS_PFD7_CLK 0x07000000 +#define WRCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK 0x06000000 +#define WRCLK_CLK_ROOT_FROM_PLL_ENET_MAIN_40M_CLK 0x01000000 +#define WRCLK_CLK_ROOT_FROM_PLL_USB_MAIN_480M_CLK 0x03000000 + +/* IPP_DO_CLKO1 */ +#define IPP_DO_CLKO1_FROM_OSC_24M_CLK 0x00000000 +#define IPP_DO_CLKO1_FROM_PLL_DRAM_MAIN_533M_CLK 0x06000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_MAIN_480M_CLK 0x01000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_MAIN_240M_CLK 0x02000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_PFD0_196M_CLK 0x03000000 +#define IPP_DO_CLKO1_FROM_PLL_SYS_PFD3_CLK 0x04000000 +#define IPP_DO_CLKO1_FROM_PLL_ENET_MAIN_500M_CLK 0x05000000 +#define IPP_DO_CLKO1_FROM_REF_1M_CLK 0x07000000 + +/* IPP_DO_CLKO2 */ +#define IPP_DO_CLKO2_FROM_OSC_24M_CLK 0x00000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_MAIN_240M_CLK 0x01000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_PFD0_392M_CLK 0x02000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_PFD1_166M_CLK 0x03000000 +#define IPP_DO_CLKO2_FROM_PLL_SYS_PFD4_CLK 0x04000000 +#define IPP_DO_CLKO2_FROM_PLL_AUDIO_MAIN_CLK 0x05000000 +#define IPP_DO_CLKO2_FROM_PLL_VIDEO_MAIN_CLK 0x06000000 +#define IPP_DO_CLKO2_FROM_OSC_32K_CLK 0x07000000 + +#endif diff --git a/arch/arm/include/asm/arch-mx7/imx-regs.h b/arch/arm/include/asm/arch-mx7/imx-regs.h new file mode 100644 index 0000000..4dc11ee --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/imx-regs.h @@ -0,0 +1,1307 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. All Rights Reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ASM_ARCH_MX7_IMX_REGS_H__ +#define __ASM_ARCH_MX7_IMX_REGS_H__ + +#define ARCH_MXC + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#define ROM_SW_INFO_ADDR 0x000001E8 +#define ROMCP_ARB_BASE_ADDR 0x00000000 +#define ROMCP_ARB_END_ADDR 0x00017FFF +#define BOOT_ROM_BASE_ADDR ROMCP_ARB_BASE_ADDR +#define CAAM_ARB_BASE_ADDR 0x00100000 +#define CAAM_ARB_END_ADDR 0x00107FFF +#define GIC400_ARB_BASE_ADDR 0x31000000 +#define GIC400_ARB_END_ADDR 0x31007FFF +#define APBH_DMA_ARB_BASE_ADDR 0x33000000 +#define APBH_DMA_ARB_END_ADDR 0x33007FFF +#define M4_BOOTROM_BASE_ADDR 0x00180000 + +#define MXS_APBH_BASE APBH_DMA_ARB_BASE_ADDR +#define MXS_GPMI_BASE (APBH_DMA_ARB_BASE_ADDR + 0x02000) +#define MXS_BCH_BASE (APBH_DMA_ARB_BASE_ADDR + 0x04000) + +/* GPV - PL301 configuration ports */ +#define GPV0_BASE_ADDR 0x32000000 +#define GPV1_BASE_ADDR 0x32100000 +#define GPV2_BASE_ADDR 0x32200000 +#define GPV3_BASE_ADDR 0x32300000 +#define GPV4_BASE_ADDR 0x32400000 +#define GPV5_BASE_ADDR 0x32500000 +#define GPV6_BASE_ADDR 0x32600000 +#define GPV7_BASE_ADDR 0x32700000 + +#define OCRAM_ARB_BASE_ADDR 0x00900000 +#define OCRAM_ARB_END_ADDR 0x0091FFFF +#define OCRAM_EPDC_BASE_ADDR 0x00920000 +#define OCRAM_EPDC_END_ADDR 0x0093FFFF +#define OCRAM_PXP_BASE_ADDR 0x00940000 +#define OCRAM_PXP_END_ADDR 0x00947FFF +#define IRAM_BASE_ADDR OCRAM_ARB_BASE_ADDR +#define IRAM_SIZE 0x00020000 + +#define AIPS1_ARB_BASE_ADDR 0x30000000 +#define AIPS1_ARB_END_ADDR 0x303FFFFF +#define AIPS2_ARB_BASE_ADDR 0x30400000 +#define AIPS2_ARB_END_ADDR 0x307FFFFF +#define AIPS3_ARB_BASE_ADDR 0x30800000 +#define AIPS3_ARB_END_ADDR 0x30BFFFFF + +#define WEIM_ARB_BASE_ADDR 0x28000000 +#define WEIM_ARB_END_ADDR 0x2FFFFFFF + +#define QSPI0_ARB_BASE_ADDR 0x60000000 +#define QSPI0_ARB_END_ADDR 0x6FFFFFFF +#define PCIE_ARB_BASE_ADDR 0x40000000 +#define PCIE_ARB_END_ADDR 0x4FFFFFFF +#define PCIE_REG_BASE_ADDR 0x33800000 +#define PCIE_REG_END_ADDR 0x33803FFF + +#define MMDC0_ARB_BASE_ADDR 0x80000000 +#define MMDC0_ARB_END_ADDR 0xBFFFFFFF +#define MMDC1_ARB_BASE_ADDR 0xC0000000 +#define MMDC1_ARB_END_ADDR 0xFFFFFFFF + +/* Cortex-A9 MPCore private memory region */ +#define ARM_PERIPHBASE 0x31000000 +#define SCU_BASE_ADDR ARM_PERIPHBASE +#define GLOBAL_TIMER_BASE_ADDR (ARM_PERIPHBASE + 0x0200) +#define PRIVATE_TIMERS_WD_BASE_ADDR (ARM_PERIPHBASE + 0x0600) + + +/* Defines for Blocks connected via AIPS (SkyBlue) */ +#define AIPS_TZ1_BASE_ADDR AIPS1_ARB_BASE_ADDR +#define AIPS_TZ2_BASE_ADDR AIPS2_ARB_BASE_ADDR +#define AIPS_TZ3_BASE_ADDR AIPS3_ARB_BASE_ADDR + +/* DAP base-address */ +#define ARM_IPS_BASE_ADDR AIPS1_ARB_BASE_ADDR + +/* AIPS_TZ#1- On Platform */ +#define AIPS1_ON_BASE_ADDR (AIPS_TZ1_BASE_ADDR+0x1F0000) +/* AIPS_TZ#1- Off Platform */ +#define AIPS1_OFF_BASE_ADDR (AIPS_TZ1_BASE_ADDR+0x200000) + +#define GPIO1_BASE_ADDR AIPS1_OFF_BASE_ADDR +#define GPIO2_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x10000) +#define GPIO3_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x20000) +#define GPIO4_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x30000) +#define GPIO5_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x40000) +#define GPIO6_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x50000) +#define GPIO7_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x60000) +#define IOMUXC_LPSR_GPR_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x70000) +#define WDOG1_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x80000) +#define WDOG2_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x90000) +#define WDOG3_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xA0000) +#define WDOG4_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xB0000) +#define IOMUXC_LPSR_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xC0000) +#define GPT_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xD0000) +#define GPT1_BASE_ADDR GPT_IPS_BASE_ADDR +#define GPT2_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xE0000) +#define GPT3_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0xF0000) +#define GPT4_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x100000) +#define ROMCP_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x110000) +#define KPP_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x120000) +#define IOMUXC_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x130000) +#define IOMUXC_BASE_ADDR IOMUXC_IPS_BASE_ADDR +#define IOMUXC_GPR_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x140000) +#define OCOTP_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x150000) +#define ANATOP_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x160000) +#define SNVS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x170000) +#define CCM_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x180000) +#define SRC_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x190000) +#define GPC_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1A0000) +#define SEMA41_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1B0000) +#define SEMA42_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1C0000) +#define RDC_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1D0000) +#define CSU_IPS_BASE_ADDR (AIPS1_OFF_BASE_ADDR+0x1E0000) + +/* AIPS_TZ#2- On Platform */ +#define AIPS2_ON_BASE_ADDR (AIPS_TZ2_BASE_ADDR+0x1F0000) +/* AIPS_TZ#2- Off Platform */ +#define AIPS2_OFF_BASE_ADDR (AIPS_TZ2_BASE_ADDR+0x200000) +#define ADC1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x10000) +#define ADC2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x20000) +#define ECSPI4_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x30000) +#define FTM1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x40000) +#define FTM2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x50000) +#define PWM1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x60000) +#define PWM2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x70000) +#define PWM3_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x80000) +#define PWM4_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x90000) +#define SYSCNT_RD_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xA0000) +#define SYSCNT_CMP_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xB0000) +#define SYSCNT_CTRL_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xC0000) +#define PCIE_PHY_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xD0000) +#define EPDC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0xF0000) +#define EPDC_BASE_ADDR EPDC_IPS_BASE_ADDR +#define EPXP_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x100000) +#define CSI1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x110000) +#define ELCDIF1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x130000) +#define MIPI_CSI2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x150000) +#define MIPI_DSI_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x160000) +#define IP2APB_TZASC1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x180000) +#define DDRPHY_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x190000) +#define DDRC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1A0000) +#define IP2APB_PERFMON1_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1C0000) +#define IP2APB_PERFMON2_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1D0000) +#define IP2APB_AXIMON_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1E0000) +#define QOSC_IPS_BASE_ADDR (AIPS2_OFF_BASE_ADDR+0x1F0000) + +/* AIPS_TZ#3 - Global enable (0) */ +#define ECSPI1_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x20000) +#define ECSPI2_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x30000) +#define ECSPI3_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x40000) +#define UART1_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x60000) +#define UART3_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x80000) +#define UART2_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x90000) +#define SAI1_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xA0000) +#define SAI2_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xB0000) +#define SAI3_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xC0000) +#define SPBA_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0xF0000) +#define CAAM_IPS_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x100000) + +/* AIPS_TZ#3- On Platform */ +#define AIPS3_ON_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x1F0000) +/* AIPS_TZ#3- Off Platform */ +#define AIPS3_OFF_BASE_ADDR (AIPS_TZ3_BASE_ADDR+0x200000) +#define CAN1_IPS_BASE_ADDR AIPS3_OFF_BASE_ADDR +#define CAN2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x10000) +#define I2C1_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x20000) +#define I2C2_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x30000) +#define I2C3_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x40000) +#define I2C4_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x50000) +#define UART4_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x60000) +#define UART5_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x70000) +#define UART6_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x80000) +#define UART7_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x90000) +#define MUCPU_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xA0000) +#define MUDSP_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xB0000) +#define HS_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xC0000) +#define USBOH2_PL301_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0xD0000) +#define USBOTG1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x110000) +#define USBOTG2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x120000) +#define USBHSIC_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x130000) +#define USDHC1_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x140000) +#define USDHC2_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x150000) +#define USDHC3_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x160000) +#define EMVSIM1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x190000) +#define EMVSIM2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1A0000) +#define SIM1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x190000) +#define SIM2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1A0000) +#define QSPI1_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1B0000) +#define WEIM_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1C0000) +#define SDMA_PORT_IPS_HOST_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1D0000) +#define ENET_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1E0000) +#define ENET2_IPS_BASE_ADDR (AIPS3_OFF_BASE_ADDR+0x1F0000) + +#define AIPS1_BASE_ADDR AIPS1_ON_BASE_ADDR +#define AIPS2_BASE_ADDR AIPS2_ON_BASE_ADDR +#define AIPS3_BASE_ADDR AIPS3_ON_BASE_ADDR + +#define SDMA_IPS_HOST_BASE_ADDR SDMA_PORT_IPS_HOST_BASE_ADDR +#define SDMA_IPS_HOST_IPS_BASE_ADDR SDMA_PORT_IPS_HOST_BASE_ADDR + +#define SCTR_BASE_ADDR SYSCNT_CTRL_IPS_BASE_ADDR +#define DEBUG_MONITOR_BASE_ADDR IP2APB_AXIMON_IPS_BASE_ADDR + +#define USB_BASE_ADDR USBOTG1_IPS_BASE_ADDR + +#define FEC_QUIRK_ENET_MAC +#define SNVS_LPGPR 0x68 + +#if !(defined(__KERNEL_STRICT_NAMES) || defined(__ASSEMBLY__)) +#include <asm/types.h> + +extern void imx_get_mac_from_fuse(int dev_id, unsigned char *mac); + +/* System Reset Controller (SRC) */ +struct src { + u32 scr; + u32 a7rcr0; + u32 a7rcr1; + u32 m4rcr; + u32 reserved1; + u32 ercr; + u32 reserved2; + u32 hsicphy_rcr; + u32 usbophy1_rcr; + u32 usbophy2_rcr; + u32 mipiphy_rcr; + u32 pciephy_rcr; + u32 reserved3[10]; + u32 sbmr1; + u32 srsr; + u32 reserved4[2]; + u32 sisr; + u32 simr; + u32 sbmr2; + u32 gpr1; + u32 gpr2; + u32 gpr3; + u32 gpr4; + u32 gpr5; + u32 gpr6; + u32 gpr7; + u32 gpr8; + u32 gpr9; + u32 gpr10; + u32 reserved5[985]; + u32 ddrc_rcr; +}; + +/* GPR0 Bit Fields */ +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL0_MASK 0x1u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL0_SHIFT 0 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL1_MASK 0x2u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL1_SHIFT 1 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL2_MASK 0x4u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL2_SHIFT 2 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL3_MASK 0x8u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL3_SHIFT 3 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL4_MASK 0x10u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL4_SHIFT 4 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL5_MASK 0x20u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL5_SHIFT 5 +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL6_MASK 0x40u +#define IOMUXC_GPR_GPR0_DMAREQ_MUX_SEL6_SHIFT 6 +/* GPR1 Bit Fields */ +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS0_MASK 0x1u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS0_SHIFT 0 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_MASK 0x6u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_SHIFT 1 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS0_MASK) +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS1_MASK 0x8u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS1_SHIFT 3 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_MASK 0x30u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_SHIFT 4 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS1_MASK) +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS2_MASK 0x40u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS2_SHIFT 6 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_MASK 0x180u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_SHIFT 7 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS2_MASK) +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS3_MASK 0x200u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ACT_CS3_SHIFT 9 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_MASK 0xC00u +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_SHIFT 10 +#define IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_SHIFT))&IOMUXC_GPR_GPR1_GPR_WEIM_ADDRS3_MASK) +#define IOMUXC_GPR_GPR1_GPR_IRQ_MASK 0x1000u +#define IOMUXC_GPR_GPR1_GPR_IRQ_SHIFT 12 +#define IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK 0x2000u +#define IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_SHIFT 13 +#define IOMUXC_GPR_GPR1_GPR_ENET2_TX_CLK_SEL_MASK 0x4000u +#define IOMUXC_GPR_GPR1_GPR_ENET2_TX_CLK_SEL_SHIFT 14 +#define IOMUXC_GPR_GPR1_GPR_ANATOP_TESTMODE_MASK 0x8000u +#define IOMUXC_GPR_GPR1_GPR_ANATOP_TESTMODE_SHIFT 15 +#define IOMUXC_GPR_GPR1_GPR_PAD_ADD_DS_MASK 0x10000u +#define IOMUXC_GPR_GPR1_GPR_PAD_ADD_DS_SHIFT 16 +#define IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK 0x20000u +#define IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_SHIFT 17 +#define IOMUXC_GPR_GPR1_GPR_ENET2_CLK_DIR_MASK 0x40000u +#define IOMUXC_GPR_GPR1_GPR_ENET2_CLK_DIR_SHIFT 18 +#define IOMUXC_GPR_GPR1_GPR_EXC_ERR_RESP_EN_MASK 0x400000u +#define IOMUXC_GPR_GPR1_GPR_EXC_ERR_RESP_EN_SHIFT 22 +#define IOMUXC_GPR_GPR1_GPR_TZASC1_SECURE_BOOT_LOCK_MASK 0x800000u +#define IOMUXC_GPR_GPR1_GPR_TZASC1_SECURE_BOOT_LOCK_SHIFT 23 +#define IOMUXC_GPR_GPR1_GPR_DBG_ACK_MASK 0x30000000u +#define IOMUXC_GPR_GPR1_GPR_DBG_ACK_SHIFT 28 +#define IOMUXC_GPR_GPR1_GPR_DBG_ACK(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR1_GPR_DBG_ACK_SHIFT))&IOMUXC_GPR_GPR1_GPR_DBG_ACK_MASK) +#define IOMUXC_GPR_GPR1_GPR_ENABLE_OCRAM_EPDC_MASK 0x40000000u +#define IOMUXC_GPR_GPR1_GPR_ENABLE_OCRAM_EPDC_SHIFT 30 +/* GPR2 Bit Fields */ +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LOWPOWER_MASK 0x1u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LOWPOWER_SHIFT 0 +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_SD_MASK 0x2u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_SD_SHIFT 1 +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_DS_MASK 0x4u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_DS_SHIFT 2 +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LS_MASK 0x8u +#define IOMUXC_GPR_GPR2_GPR_MEM_PXP_LS_SHIFT 3 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LOWPOWER_MASK 0x10u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LOWPOWER_SHIFT 4 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_SD_MASK 0x20u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_SD_SHIFT 5 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_DS_MASK 0x40u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_DS_SHIFT 6 +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LS_MASK 0x80u +#define IOMUXC_GPR_GPR2_GPR_MEM_LCDIF_LS_SHIFT 7 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LOWPOWER_MASK 0x100u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LOWPOWER_SHIFT 8 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_SD_MASK 0x200u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_SD_SHIFT 9 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_DS_MASK 0x400u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_DS_SHIFT 10 +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LS_MASK 0x800u +#define IOMUXC_GPR_GPR2_GPR_MEM_EPDC_LS_SHIFT 11 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LOWPOWER_MASK 0x1000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LOWPOWER_SHIFT 12 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_SD_MASK 0x2000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_SD_SHIFT 13 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_DS_MASK 0x4000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_DS_SHIFT 14 +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LS_MASK 0x8000u +#define IOMUXC_GPR_GPR2_GPR_MEM_CPU_LS_SHIFT 15 +#define IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_MASK 0xFF0000u +#define IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_SHIFT 16 +#define IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_SHIFT))&IOMUXC_GPR_GPR2_GPR_MQS_CLK_DIV_MASK) +#define IOMUXC_GPR_GPR2_GPR_MQS_SW_RST_MASK 0x1000000u +#define IOMUXC_GPR_GPR2_GPR_MQS_SW_RST_SHIFT 24 +#define IOMUXC_GPR_GPR2_GPR_MQS_EN_MASK 0x2000000u +#define IOMUXC_GPR_GPR2_GPR_MQS_EN_SHIFT 25 +#define IOMUXC_GPR_GPR2_GPR_MQS_OVERSAMPLE_MASK 0x4000000u +#define IOMUXC_GPR_GPR2_GPR_MQS_OVERSAMPLE_SHIFT 26 +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_BYPASS_MASK 0x8000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_BYPASS_SHIFT 27 +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_MASK 0x10000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_RESET_SHIFT 28 +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE0_MASK 0x20000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE0_SHIFT 29 +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE1_MASK 0x40000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE1_SHIFT 30 +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE_BYPASS_MASK 0x80000000u +#define IOMUXC_GPR_GPR2_GPR_DRAM_CKE_BYPASS_SHIFT 31 +/* GPR3 Bit Fields */ +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_DATA_WAIT_EN_MASK 0x1u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_DATA_WAIT_EN_SHIFT 0 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_ADDR_PIPELINE_EN_MASK 0x2u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_READ_ADDR_PIPELINE_EN_SHIFT 1 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_DATA_PIPELINE_EN_MASK 0x4u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_DATA_PIPELINE_EN_SHIFT 2 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_ADDR_PIPELINE_EN_MASK 0x8u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_WRITE_ADDR_PIPELINE_EN_SHIFT 3 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_DATA_WAIT_EN_MASK 0x10u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_DATA_WAIT_EN_SHIFT 4 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_ADDR_PIPELINE_EN_MASK 0x20u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_READ_ADDR_PIPELINE_EN_SHIFT 5 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_DATA_PIPELINE_EN_MASK 0x40u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_DATA_PIPELINE_EN_SHIFT 6 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_ADDR_PIPELINE_EN_MASK 0x80u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_S_WRITE_ADDR_PIPELINE_EN_SHIFT 7 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_DATA_WAIT_EN_MASK 0x100u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_DATA_WAIT_EN_SHIFT 8 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_ADDR_PIPELINE_EN_MASK 0x200u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_READ_ADDR_PIPELINE_EN_SHIFT 9 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_DATA_PIPELINE_EN_MASK 0x400u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_DATA_PIPELINE_EN_SHIFT 10 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_ADDR_PIPELINE_EN_MASK 0x800u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_EPDC_WRITE_ADDR_PIPELINE_EN_SHIFT 11 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_DATA_WAIT_EN_MASK 0x1000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_DATA_WAIT_EN_SHIFT 12 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_ADDR_PIPELINE_EN_MASK 0x2000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_READ_ADDR_PIPELINE_EN_SHIFT 13 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_DATA_PIPELINE_EN_MASK 0x4000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_DATA_PIPELINE_EN_SHIFT 14 +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_ADDR_PIPELINE_EN_MASK 0x8000u +#define IOMUXC_GPR_GPR3_GPR_OCRAM_CTRL_PXP_WRITE_ADDR_PIPELINE_EN_SHIFT 15 +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_data_wait_en_update_pending_MASK 0x10000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_data_wait_en_update_pending_SHIFT 16 +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_addr_pipeline_en_update_pending_MASK 0x20000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_read_addr_pipeline_en_update_pending_SHIFT 17 +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_data_pipeline_en_update_pending_MASK 0x40000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_data_pipeline_en_update_pending_SHIFT 18 +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_addr_pipeline_en_update_pending_MASK 0x80000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_write_addr_pipeline_en_update_pending_SHIFT 19 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_data_wait_en_update_pending_MASK 0x100000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_data_wait_en_update_pending_SHIFT 20 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_addr_pipeline_en_update_pending_MASK 0x200000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_read_addr_pipeline_en_update_pending_SHIFT 21 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_data_pipeline_en_update_pending_MASK 0x400000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_data_pipeline_en_update_pending_SHIFT 22 +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_addr_pipeline_en_update_pending_MASK 0x800000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_s_write_addr_pipeline_en_update_pending_SHIFT 23 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_data_wait_en_update_pending_MASK 0x1000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_data_wait_en_update_pending_SHIFT 24 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_addr_pipeline_en_update_pending_MASK 0x2000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_read_addr_pipeline_en_update_pending_SHIFT 25 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_data_pipeline_en_update_pending_MASK 0x4000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_data_pipeline_en_update_pending_SHIFT 26 +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_addr_pipeline_en_update_pending_MASK 0x8000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_epdc_write_addr_pipeline_en_update_pending_SHIFT 27 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_data_wait_en_update_pending_MASK 0x10000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_data_wait_en_update_pending_SHIFT 28 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_addr_pipeline_en_update_pending_MASK 0x20000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_read_addr_pipeline_en_update_pending_SHIFT 29 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_data_pipeline_en_update_pending_MASK 0x40000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_data_pipeline_en_update_pending_SHIFT 30 +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_addr_pipeline_en_update_pending_MASK 0x80000000u +#define IOMUXC_GPR_GPR3_ocram_ctrl_pxp_write_addr_pipeline_en_update_pending_SHIFT 31 +/* GPR4 Bit Fields */ +#define IOMUXC_GPR_GPR4_GPR_SDMA_IPG_STOP_MASK 0x1u +#define IOMUXC_GPR_GPR4_GPR_SDMA_IPG_STOP_SHIFT 0 +#define IOMUXC_GPR_GPR4_GPR_CAN1_IPG_STOP_MASK 0x2u +#define IOMUXC_GPR_GPR4_GPR_CAN1_IPG_STOP_SHIFT 1 +#define IOMUXC_GPR_GPR4_GPR_CAN2_IPG_STOP_MASK 0x4u +#define IOMUXC_GPR_GPR4_GPR_CAN2_IPG_STOP_SHIFT 2 +#define IOMUXC_GPR_GPR4_GPR_ENET1_IPG_STOP_MASK 0x8u +#define IOMUXC_GPR_GPR4_GPR_ENET1_IPG_STOP_SHIFT 3 +#define IOMUXC_GPR_GPR4_GPR_ENET2_IPG_STOP_MASK 0x10u +#define IOMUXC_GPR_GPR4_GPR_ENET2_IPG_STOP_SHIFT 4 +#define IOMUXC_GPR_GPR4_GPR_SAI1_IPG_STOP_MASK 0x20u +#define IOMUXC_GPR_GPR4_GPR_SAI1_IPG_STOP_SHIFT 5 +#define IOMUXC_GPR_GPR4_GPR_SAI2_IPG_STOP_MASK 0x40u +#define IOMUXC_GPR_GPR4_GPR_SAI2_IPG_STOP_SHIFT 6 +#define IOMUXC_GPR_GPR4_GPR_SAI3_IPG_STOP_MASK 0x80u +#define IOMUXC_GPR_GPR4_GPR_SAI3_IPG_STOP_SHIFT 7 +#define IOMUXC_GPR_GPR4_sdma_ipg_stop_ack_MASK 0x10000u +#define IOMUXC_GPR_GPR4_sdma_ipg_stop_ack_SHIFT 16 +#define IOMUXC_GPR_GPR4_can1_ipg_stop_ack_MASK 0x20000u +#define IOMUXC_GPR_GPR4_can1_ipg_stop_ack_SHIFT 17 +#define IOMUXC_GPR_GPR4_can2_ipg_stop_ack_MASK 0x40000u +#define IOMUXC_GPR_GPR4_can2_ipg_stop_ack_SHIFT 18 +#define IOMUXC_GPR_GPR4_enet1_ipg_stop_ack_MASK 0x80000u +#define IOMUXC_GPR_GPR4_enet1_ipg_stop_ack_SHIFT 19 +#define IOMUXC_GPR_GPR4_enet2_ipg_stop_ack_MASK 0x100000u +#define IOMUXC_GPR_GPR4_enet2_ipg_stop_ack_SHIFT 20 +#define IOMUXC_GPR_GPR4_sai1_ipg_stop_ack_MASK 0x200000u +#define IOMUXC_GPR_GPR4_sai1_ipg_stop_ack_SHIFT 21 +#define IOMUXC_GPR_GPR4_sai2_ipg_stop_ack_MASK 0x400000u +#define IOMUXC_GPR_GPR4_sai2_ipg_stop_ack_SHIFT 22 +#define IOMUXC_GPR_GPR4_sai3_ipg_stop_ack_MASK 0x800000u +#define IOMUXC_GPR_GPR4_sai3_ipg_stop_ack_SHIFT 23 +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFI_MASK 0x6000000u +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFI_SHIFT 25 +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFI(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR4_cpu_STANDBYWFI_SHIFT))&IOMUXC_GPR_GPR4_cpu_STANDBYWFI_MASK) +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFE_MASK 0x18000000u +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFE_SHIFT 27 +#define IOMUXC_GPR_GPR4_cpu_STANDBYWFE(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR4_cpu_STANDBYWFE_SHIFT))&IOMUXC_GPR_GPR4_cpu_STANDBYWFE_MASK) +/* GPR5 Bit Fields */ +#define IOMUXC_GPR_GPR5_GPR_CSI_MUX_CONTROL_MASK 0x10u +#define IOMUXC_GPR_GPR5_GPR_CSI_MUX_CONTROL_SHIFT 4 +#define IOMUXC_GPR_GPR5_GPR_LVDS_MUX_CONTROL_MASK 0x20u +#define IOMUXC_GPR_GPR5_GPR_LVDS_MUX_CONTROL_SHIFT 5 +#define IOMUXC_GPR_GPR5_GPR_WDOG1_MASK_MASK 0x40u +#define IOMUXC_GPR_GPR5_GPR_WDOG1_MASK_SHIFT 6 +#define IOMUXC_GPR_GPR5_GPR_WDOG2_MASK_MASK 0x80u +#define IOMUXC_GPR_GPR5_GPR_WDOG2_MASK_SHIFT 7 +#define IOMUXC_GPR_GPR5_GPR_LCDIF_HANDSHAKE_MASK 0x1000u +#define IOMUXC_GPR_GPR5_GPR_LCDIF_HANDSHAKE_SHIFT 12 +#define IOMUXC_GPR_GPR5_GPR_PCIE_BTNRST_MASK 0x80000u +#define IOMUXC_GPR_GPR5_GPR_PCIE_BTNRST_SHIFT 19 +#define IOMUXC_GPR_GPR5_GPR_WDOG3_MASK_MASK 0x100000u +#define IOMUXC_GPR_GPR5_GPR_WDOG3_MASK_SHIFT 20 +#define IOMUXC_GPR_GPR5_GPR_LCDIF_CSI_VSYNC_SEL_MASK 0x200000u +#define IOMUXC_GPR_GPR5_GPR_LCDIF_CSI_VSYNC_SEL_SHIFT 21 +#define IOMUXC_GPR_GPR5_GPR_WDOG4_MASK_MASK 0x400000u +#define IOMUXC_GPR_GPR5_GPR_WDOG4_MASK_SHIFT 22 +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN1_SEL_MASK 0x1000000u +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN1_SEL_SHIFT 24 +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN2_SEL_MASK 0x2000000u +#define IOMUXC_GPR_GPR5_GPR_GPT4_CAPIN2_SEL_SHIFT 25 +#define IOMUXC_GPR_GPR5_GPR_ENET1_EVENT3IN_SEL_MASK 0x4000000u +#define IOMUXC_GPR_GPR5_GPR_ENET1_EVENT3IN_SEL_SHIFT 26 +#define IOMUXC_GPR_GPR5_GPR_ENET2_EVENT3IN_SEL_MASK 0x8000000u +#define IOMUXC_GPR_GPR5_GPR_ENET2_EVENT3IN_SEL_SHIFT 27 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT1_MASK 0x10000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT1_SHIFT 28 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT2_MASK 0x20000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT2_SHIFT 29 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT3_MASK 0x40000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT3_SHIFT 30 +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT4_MASK 0x80000000u +#define IOMUXC_GPR_GPR5_GPR_REF_1M_CLK_GPT4_SHIFT 31 +/* GPR6 Bit Fields */ +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_MASK 0x1u +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_SHIFT 0 +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_MASK 0x2u +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_SHIFT 1 +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_EN_MASK 0x4u +#define IOMUXC_GPR_GPR6_GPR_ARCACHE_PXP6_EN_SHIFT 2 +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_EN_MASK 0x8u +#define IOMUXC_GPR_GPR6_GPR_AWCACHE_PXP6_EN_SHIFT 3 +/* GPR7 Bit Fields */ +#define IOMUXC_GPR_GPR7_GPR_chd1_pwd_ldo_usb_1p0_MASK 0x1u +#define IOMUXC_GPR_GPR7_GPR_chd1_pwd_ldo_usb_1p0_SHIFT 0 +#define IOMUXC_GPR_GPR7_GPR_chd1_lowpwr_ldo_usb_1p0_MASK 0x2u +#define IOMUXC_GPR_GPR7_GPR_chd1_lowpwr_ldo_usb_1p0_SHIFT 1 +#define IOMUXC_GPR_GPR7_GPR_chd1_en_ilimit_ldo_usb_1p0_MASK 0x4u +#define IOMUXC_GPR_GPR7_GPR_chd1_en_ilimit_ldo_usb_1p0_SHIFT 2 +#define IOMUXC_GPR_GPR7_GPR_chd1_en_pwrupload_ldo_usb_1p0_MASK 0x8u +#define IOMUXC_GPR_GPR7_GPR_chd1_en_pwrupload_ldo_usb_1p0_SHIFT 3 +#define IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_MASK 0x30u +#define IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_SHIFT 4 +#define IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_SHIFT))&IOMUXC_GPR_GPR7_GPR_chd1_chrg_det_test_MASK) +#define IOMUXC_GPR_GPR7_GPR_chd2_pwd_ldo_usb_1p0_MASK 0x40u +#define IOMUXC_GPR_GPR7_GPR_chd2_pwd_ldo_usb_1p0_SHIFT 6 +#define IOMUXC_GPR_GPR7_GPR_chd2_lowpwr_ldo_usb_1p0_MASK 0x80u +#define IOMUXC_GPR_GPR7_GPR_chd2_lowpwr_ldo_usb_1p0_SHIFT 7 +#define IOMUXC_GPR_GPR7_GPR_chd2_en_ilimit_ldo_usb_1p0_MASK 0x100u +#define IOMUXC_GPR_GPR7_GPR_chd2_en_ilimit_ldo_usb_1p0_SHIFT 8 +#define IOMUXC_GPR_GPR7_GPR_chd2_en_pwrupload_ldo_usb_1p0_MASK 0x200u +#define IOMUXC_GPR_GPR7_GPR_chd2_en_pwrupload_ldo_usb_1p0_SHIFT 9 +#define IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_MASK 0xC00u +#define IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_SHIFT 10 +#define IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_SHIFT))&IOMUXC_GPR_GPR7_GPR_chd2_chrg_det_test_MASK) +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_lnkrst_disable_MASK 0x1000u +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_lnkrst_disable_SHIFT 12 +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_perst_disable_MASK 0x2000u +#define IOMUXC_GPR_GPR7_GPR_pcie_clk_rst_fix_perst_disable_SHIFT 13 +/* GPR8 Bit Fields */ +#define IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_MASK 0xF8u +#define IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_SHIFT 3 +#define IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_SHIFT))&IOMUXC_GPR_GPR8_ddr_phy_ctrl_wake_up_MASK) +#define IOMUXC_GPR_GPR8_ddr_phy_dfi_init_start_MASK 0x100u +#define IOMUXC_GPR_GPR8_ddr_phy_dfi_init_start_SHIFT 8 +/* GPR9 Bit Fields */ +#define IOMUXC_GPR_GPR9_GPR_TZASC1_MUX_CONTROL_MASK 0x1u +#define IOMUXC_GPR_GPR9_GPR_TZASC1_MUX_CONTROL_SHIFT 0 +#define IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_MASK 0x3Eu +#define IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_SHIFT 1 +#define IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_SHIFT))&IOMUXC_GPR_GPR9_ddr_phy_ctrl_pd_MASK) +/* GPR10 Bit Fields */ +#define IOMUXC_GPR_GPR10_GPR0_BF0_MASK 0x1u +#define IOMUXC_GPR_GPR10_GPR0_BF0_SHIFT 0 +#define IOMUXC_GPR_GPR10_GPR_DBG_EN_MASK 0x2u +#define IOMUXC_GPR_GPR10_GPR_DBG_EN_SHIFT 1 +#define IOMUXC_GPR_GPR10_GPR_SEC_ERR_RESP_EN_MASK 0x4u +#define IOMUXC_GPR_GPR10_GPR_SEC_ERR_RESP_EN_SHIFT 2 +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION0_MASK 0x8u +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION0_SHIFT 3 +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_MASK 0x3F0u +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_SHIFT 4 +#define IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR10_GPR_OCRAM_CTRL_EPDC_OCRAM_TZ_SECURE_REGION1_MASK) +/* GPR11 Bit Fields */ +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION0_MASK 0x1u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION0_SHIFT 0 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_MASK 0x3Eu +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_SHIFT 1 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_OCRAM_TZ_SECURE_REGION1_MASK) +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION0_MASK 0x40u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION0_SHIFT 6 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_MASK 0x380u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_SHIFT 7 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_PXP_OCRAM_TZ_SECURE_REGION1_MASK) +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION0_MASK 0x400u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION0_SHIFT 10 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_MASK 0x3800u +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_SHIFT 11 +#define IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_SHIFT))&IOMUXC_GPR_GPR11_GPR_OCRAM_CTRL_S_OCRAM_TZ_SECURE_REGION1_MASK) +/* GPR12 Bit Fields */ +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_REG_RST_CH0_MASK 0x1u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_REG_RST_CH0_SHIFT 0 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_RST_CH0_MASK 0x2u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_TRSV_RST_CH0_SHIFT 1 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_SSC_EN_MASK 0x8u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_SSC_EN_SHIFT 3 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_CMN_REG_RST_MASK 0x10u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_CMN_REG_RST_SHIFT 4 +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_REFCLK_SEL_MASK 0x20u +#define IOMUXC_GPR_GPR12_GPR_PCIE_PHY_REFCLK_SEL_SHIFT 5 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_MASK 0xF000u +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_SHIFT 12 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_SHIFT))&IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DEVICE_TYPE_MASK) +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_MASK 0x1E0000u +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_SHIFT 17 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_SHIFT))&IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_STATUS_BUS_SELECT_MASK) +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_MASK 0xE00000u +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_SHIFT 21 +#define IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_SHIFT))&IOMUXC_GPR_GPR12_GPR_PCIE_CTRL_DIAG_CTRL_BUS_MASK) +/* GPR13 Bit Fields */ +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_USDHC_MASK 0x1u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_USDHC_SHIFT 0 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_USDHC_MASK 0x2u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_USDHC_SHIFT 1 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_MASK 0x4u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_SHIFT 2 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_MASK 0x8u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_SHIFT 3 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_MASK 0x10u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_SHIFT 4 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_MASK 0x20u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_SHIFT 5 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_MASK 0x40u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_SHIFT 6 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_MASK 0x80u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_SHIFT 7 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_EN_MASK 0x100u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PXP_EN_SHIFT 8 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_EN_MASK 0x200u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PXP_EN_SHIFT 9 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_EN_MASK 0x400u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_PCIE_EN_SHIFT 10 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_EN_MASK 0x800u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_PCIE_EN_SHIFT 11 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_EN_MASK 0x1000u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_LCDIF_EN_SHIFT 12 +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_EN_MASK 0x2000u +#define IOMUXC_GPR_GPR13_GPR_ARCACHE_EPDC_EN_SHIFT 13 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_MASK 0x4000u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_SHIFT 14 +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_EN_MASK 0x8000u +#define IOMUXC_GPR_GPR13_GPR_AWCACHE_EPDC_EN_SHIFT 15 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_MASK 0xFF0000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_SHIFT 16 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_SHIFT))&IOMUXC_GPR_GPR13_GPR_PCIE_PHY_AFC_CODE_OUT_CH0_MASK) +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_MASK 0xF000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_SHIFT 24 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_SHIFT))&IOMUXC_GPR_GPR13_GPR_PCIE_PHY_VCO_BAND_MASK) +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_CDR_LOCKED_CH0_MASK 0x10000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_CDR_LOCKED_CH0_SHIFT 28 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_RX_PRESENT_CH0_MASK 0x20000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PMA_RX_PRESENT_CH0_SHIFT 29 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_CDR_VCO_MON_CH0_MASK 0x40000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_CDR_VCO_MON_CH0_SHIFT 30 +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PCS_REFCLK_DISABLE_MASK 0x80000000u +#define IOMUXC_GPR_GPR13_GPR_PCIE_PHY_PCS_REFCLK_DISABLE_SHIFT 31 +/* GPR14 Bit Fields */ +#define IOMUXC_GPR_GPR14_GPR_SIM1_SIMV2_EMV_SEL_MASK 0x1u +#define IOMUXC_GPR_GPR14_GPR_SIM1_SIMV2_EMV_SEL_SHIFT 0 +#define IOMUXC_GPR_GPR14_GPR_SIM2_SIMV2_EMV_SEL_MASK 0x2u +#define IOMUXC_GPR_GPR14_GPR_SIM2_SIMV2_EMV_SEL_SHIFT 1 +/* GPR15 Bit Fields */ +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_VBLK_FLAG_MASK 0x1u +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_VBLK_FLAG_SHIFT 0 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_AUTO_SEL_MASK 0x2u +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_AUTO_SEL_SHIFT 1 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_MASK 0x3FFCu +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_SHIFT 2 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_SHIFT))&IOMUXC_GPR_GPR15_GPR_LVDS_I_DESKEW_CNT_SET_MASK) +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_MASK 0x3F0000u +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_SHIFT 16 +#define IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_SHIFT))&IOMUXC_GPR_GPR15_GPR_LVDS_I_LOCK_PPM_SET_MASK) +/* GPR16 Bit Fields */ +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_MASK 0x3u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_SHIFT 0 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_REG_CUR_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_SEL_DATABF_MASK 0x4u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SEL_DATABF_SHIFT 2 +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNTB_TDLY_MASK 0x8u +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNTB_TDLY_SHIFT 3 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_EN_H_MASK 0x10u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEW_EN_H_SHIFT 4 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEWINI_MASK 0x20u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SKEWINI_SHIFT 5 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_MASK 0x3C0u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_SHIFT 6 +#define IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_SK_BIAS_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_AUTO_DSK_SEL_MASK 0x400u +#define IOMUXC_GPR_GPR16_GPR_LVDS_AUTO_DSK_SEL_SHIFT 10 +#define IOMUXC_GPR_GPR16_GPR_LVDS_LOCK_CNT_MASK 0x800u +#define IOMUXC_GPR_GPR16_GPR_LVDS_LOCK_CNT_SHIFT 11 +#define IOMUXC_GPR_GPR16_GPR_LVDS_OUTCON_MASK 0x1000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_OUTCON_SHIFT 12 +#define IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_MASK 0xE000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_SHIFT 13 +#define IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_FC_CODE_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_SRC_TRH_MASK 0x10000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_SRC_TRH_SHIFT 16 +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_HIGH_S_MASK 0x20000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_HIGH_S_SHIFT 17 +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_MASK 0x180000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_SHIFT 19 +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_SHIFT))&IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_CNT_MASK) +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_MODE_SEL_MASK 0x200000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_CNNCT_MODE_SEL_SHIFT 21 +#define IOMUXC_GPR_GPR16_GPR_LVDS_FLT_CNT_MASK 0x400000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_FLT_CNT_SHIFT 22 +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_ONLY_CNT_MASK 0x800000u +#define IOMUXC_GPR_GPR16_GPR_LVDS_VOD_ONLY_CNT_SHIFT 23 +/* GPR17 Bit Fields */ +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_MASK 0xFFu +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_SHIFT 0 +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_SHIFT))&IOMUXC_GPR_GPR17_GPR_LVDS_CNT_PEN_H_MASK) +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_MASK 0xFF00u +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_SHIFT 8 +#define IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_SHIFT))&IOMUXC_GPR_GPR17_GPR_LVDS_CNT_VOD_H_MASK) +/* GPR18 Bit Fields */ +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_MASK 0x7u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_SHIFT 0 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CH_SEL_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_MASK 0x18u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_SHIFT 3 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_DATA_INV_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_MASK 0x60u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_SHIFT 5 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_CLK_INV_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_MASK 0x3F00u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_SHIFT 8 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_SKEW_CTRL_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_FORCE_ERROR_MASK 0x4000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_FORCE_ERROR_SHIFT 14 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_MASK 0x7F0000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_SHIFT 16 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_USER_PATTERN_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_MASK 0x3000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_SHIFT 24 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_SHIFT))&IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_PAT_SEL_MASK) +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_EN_MASK 0x4000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_EN_SHIFT 26 +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_RESETB_MASK 0x8000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_I_BIST_RESETB_SHIFT 27 +#define IOMUXC_GPR_GPR18_GPR_LVDS_DLYS_BST_MASK 0x10000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_DLYS_BST_SHIFT 28 +#define IOMUXC_GPR_GPR18_GPR_LVDS_SKINI_BST_MASK 0x20000000u +#define IOMUXC_GPR_GPR18_GPR_LVDS_SKINI_BST_SHIFT 29 +/* GPR19 Bit Fields */ +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_STATUS_MASK 0x1u +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_STATUS_SHIFT 0 +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_MASK 0xFF00u +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_SHIFT 8 +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_SHIFT))&IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_ERR_COUNT_MASK) +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_SYNC_MASK 0x10000u +#define IOMUXC_GPR_GPR19_GPR_LVDS_O_BIST_SYNC_SHIFT 16 +#define IOMUXC_GPR_GPR19_GPR_LVDS_MON_FOR_CNNCT_MASK 0x20000u +#define IOMUXC_GPR_GPR19_GPR_LVDS_MON_FOR_CNNCT_SHIFT 17 +/* GPR20 Bit Fields */ +#define IOMUXC_GPR_GPR20_GPR_LVDS_P_MASK 0x3Fu +#define IOMUXC_GPR_GPR20_GPR_LVDS_P_SHIFT 0 +#define IOMUXC_GPR_GPR20_GPR_LVDS_P(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_P_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_P_MASK) +#define IOMUXC_GPR_GPR20_GPR_LVDS_M_MASK 0x3F00u +#define IOMUXC_GPR_GPR20_GPR_LVDS_M_SHIFT 8 +#define IOMUXC_GPR_GPR20_GPR_LVDS_M(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_M_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_M_MASK) +#define IOMUXC_GPR_GPR20_GPR_LVDS_S_MASK 0x30000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_S_SHIFT 16 +#define IOMUXC_GPR_GPR20_GPR_LVDS_S(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_S_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_S_MASK) +#define IOMUXC_GPR_GPR20_GPR_LVDS_VSEL_MASK 0x1000000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_VSEL_SHIFT 24 +#define IOMUXC_GPR_GPR20_GPR_LVDS_CK_POL_SEL_MASK 0x2000000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_CK_POL_SEL_SHIFT 25 +#define IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_MASK 0x38000000u +#define IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_SHIFT 27 +#define IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_SHIFT))&IOMUXC_GPR_GPR20_GPR_LVDS_I_TX2801X_DUMMY_MASK) +/* GPR21 Bit Fields */ +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_MASK 0x7u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_SHIFT 0 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC0(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC0_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_MASK 0x38u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_SHIFT 3 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC1(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC1_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_MASK 0x1C0u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_SHIFT 6 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC2(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC2_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_MASK 0xE00u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_SHIFT 9 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKCCK_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_MASK 0x7000u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_SHIFT 12 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC3(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC3_MASK) +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_MASK 0x38000u +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_SHIFT 15 +#define IOMUXC_GPR_GPR21_GPR_LVDS_SKC4(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_SHIFT))&IOMUXC_GPR_GPR21_GPR_LVDS_SKC4_MASK) +#define IOMUXC_GPR_GPR21_SJC_BYPASS_CJTAGC_MASK 0x40000u +#define IOMUXC_GPR_GPR21_SJC_BYPASS_CJTAGC_SHIFT 18 +#define IOMUXC_GPR_GPR21_DAP_BYPASS_CJTAGC_MASK 0x80000u +#define IOMUXC_GPR_GPR21_DAP_BYPASS_CJTAGC_SHIFT 19 +/* GPR22 Bit Fields */ +#define IOMUXC_GPR_GPR22_ddrc_mrr_data_out_MASK 0xFF0000u +#define IOMUXC_GPR_GPR22_ddrc_mrr_data_out_SHIFT 16 +#define IOMUXC_GPR_GPR22_ddrc_mrr_data_out(x) (((uint32_t)(((uint32_t)(x))<<IOMUXC_GPR_GPR22_ddrc_mrr_data_out_SHIFT))&IOMUXC_GPR_GPR22_ddrc_mrr_data_out_MASK) +#define IOMUXC_GPR_GPR22_ddrc_mrr_valid_out_MASK 0x1000000u +#define IOMUXC_GPR_GPR22_ddrc_mrr_valid_out_SHIFT 24 +#define IOMUXC_GPR_GPR22_ddr_phy_dfi_init_complete_MASK 0x2000000u +#define IOMUXC_GPR_GPR22_ddr_phy_dfi_init_complete_SHIFT 25 +#define IOMUXC_GPR_GPR22_GPR_chd2_dvdd_usb_stable_MASK 0x4000000u +#define IOMUXC_GPR_GPR22_GPR_chd2_dvdd_usb_stable_SHIFT 26 +#define IOMUXC_GPR_GPR22_aux_chrg_det_2_usb_iso_enable_1_MASK 0x8000000u +#define IOMUXC_GPR_GPR22_aux_chrg_det_2_usb_iso_enable_1_SHIFT 27 +#define IOMUXC_GPR_GPR22_GPR_chd1_dvdd_usb_stable_MASK 0x10000000u +#define IOMUXC_GPR_GPR22_GPR_chd1_dvdd_usb_stable_SHIFT 28 +#define IOMUXC_GPR_GPR22_aux_chrg_det_1_usb_iso_enable_1_MASK 0x20000000u +#define IOMUXC_GPR_GPR22_aux_chrg_det_1_usb_iso_enable_1_SHIFT 29 +#define IOMUXC_GPR_GPR22_GPR_PCIE_PHY_PLL_LOCKED_MASK 0x80000000u +#define IOMUXC_GPR_GPR22_GPR_PCIE_PHY_PLL_LOCKED_SHIFT 31 + +#define IMX7D_GPR5_CSI1_MUX_CTRL_MASK (0x1 << 4) +#define IMX7D_GPR5_CSI1_MUX_CTRL_PARALLEL_CSI (0x0 << 4) +#define IMX7D_GPR5_CSI1_MUX_CTRL_MIPI_CSI (0x1 << 4) + +struct iomuxc { + u32 gpr[23]; + /* mux and pad registers */ +}; + +struct iomuxc_gpr_base_regs { + u32 gpr[23]; /* 0x000 */ +}; + +/* ECSPI registers */ +struct cspi_regs { + u32 rxdata; + u32 txdata; + u32 ctrl; + u32 cfg; + u32 intr; + u32 dma; + u32 stat; + u32 period; +}; + +/* + * CSPI register definitions + */ +#define MXC_ECSPI +#define MXC_CSPICTRL_EN (1 << 0) +#define MXC_CSPICTRL_MODE (1 << 1) +#define MXC_CSPICTRL_XCH (1 << 2) +#define MXC_CSPICTRL_MODE_MASK (0xf << 4) +#define MXC_CSPICTRL_CHIPSELECT(x) (((x) & 0x3) << 12) +#define MXC_CSPICTRL_BITCOUNT(x) (((x) & 0xfff) << 20) +#define MXC_CSPICTRL_PREDIV(x) (((x) & 0xF) << 12) +#define MXC_CSPICTRL_POSTDIV(x) (((x) & 0xF) << 8) +#define MXC_CSPICTRL_SELCHAN(x) (((x) & 0x3) << 18) +#define MXC_CSPICTRL_MAXBITS 0xfff +#define MXC_CSPICTRL_TC (1 << 7) +#define MXC_CSPICTRL_RXOVF (1 << 6) +#define MXC_CSPIPERIOD_32KHZ (1 << 15) +#define MAX_SPI_BYTES 32 + +/* Bit position inside CTRL register to be associated with SS */ +#define MXC_CSPICTRL_CHAN 18 + +/* Bit position inside CON register to be associated with SS */ +#define MXC_CSPICON_PHA 0 /* SCLK phase control */ +#define MXC_CSPICON_POL 4 /* SCLK polarity */ +#define MXC_CSPICON_SSPOL 12 /* SS polarity */ +#define MXC_CSPICON_CTL 20 /* inactive state of SCLK */ + +#define MXC_SPI_BASE_ADDRESSES \ + ECSPI1_BASE_ADDR, \ + ECSPI2_BASE_ADDR, \ + ECSPI3_BASE_ADDR, \ + ECSPI4_BASE_ADDR + +struct ocotp_regs { + u32 ctrl; + u32 ctrl_set; + u32 ctrl_clr; + u32 ctrl_tog; + u32 timing; + u32 rsvd0[3]; + u32 data0; + u32 rsvd1[3]; + u32 data1; + u32 rsvd2[3]; + u32 data2; + u32 rsvd3[3]; + u32 data3; + u32 rsvd4[3]; + u32 read_ctrl; + u32 rsvd5[3]; + u32 read_fuse_data0; + u32 rsvd6[3]; + u32 read_fuse_data1; + u32 rsvd7[3]; + u32 read_fuse_data2; + u32 rsvd8[3]; + u32 read_fuse_data3; + u32 rsvd9[3]; + u32 sw_sticky; + u32 rsvd10[3]; + u32 scs; + u32 scs_set; + u32 scs_clr; + u32 scs_tog; + u32 crc_addr; + u32 rsvd11[3]; + u32 crc_value; + u32 rsvd12[3]; + u32 version; + u32 rsvd13[0xc3]; + + struct fuse_bank { /* offset 0x400 */ + u32 fuse_regs[0x10]; + } bank[16]; +}; + +struct fuse_bank0_regs { + u32 lock; + u32 rsvd0[3]; + u32 tester0; + u32 rsvd1[3]; + u32 tester1; + u32 rsvd2[3]; + u32 tester2; + u32 rsvd3[3]; +}; + +struct fuse_bank1_regs { + u32 tester3; + u32 rsvd0[3]; + u32 tester4; + u32 rsvd1[3]; + u32 tester5; + u32 rsvd2[3]; + u32 cfg0; + u32 rsvd3[3]; +}; + +struct fuse_bank2_regs { + u32 cfg1; + u32 rsvd0[3]; + u32 cfg2; + u32 rsvd1[3]; + u32 cfg3; + u32 rsvd2[3]; + u32 cfg4; + u32 rsvd3[3]; +}; + +struct fuse_bank3_regs { + u32 mem_trim0; + u32 rsvd0[3]; + u32 mem_trim1; + u32 rsvd1[3]; + u32 ana0; + u32 rsvd2[3]; + u32 ana1; + u32 rsvd3[3]; +}; + +struct fuse_bank8_regs { + u32 sjc_resp_low; + u32 rsvd0[3]; + u32 sjc_resp_high; + u32 rsvd1[3]; + u32 usb_id; + u32 rsvd2[3]; + u32 field_return; + u32 rsvd3[3]; +}; + +struct fuse_bank9_regs { + u32 mac_addr0; + u32 rsvd0[3]; + u32 mac_addr1; + u32 rsvd1[3]; + u32 mac_addr2; + u32 rsvd2[7]; +}; + +struct aipstz_regs { + u32 mprot0; + u32 mprot1; + u32 rsvd[0xe]; + u32 opacr0; + u32 opacr1; + u32 opacr2; + u32 opacr3; + u32 opacr4; +}; + +struct wdog_regs { + u16 wcr; /* Control */ + u16 wsr; /* Service */ + u16 wrsr; /* Reset Status */ + u16 wicr; /* Interrupt Control */ + u16 wmcr; /* Miscellaneous Control */ +}; + +struct dbg_monitor_regs { + u32 ctrl[4]; /* Control */ + u32 master_en[4]; /* Master enable */ + u32 irq[4]; /* IRQ */ + u32 trap_addr_low[4]; /* Trap address low */ + u32 trap_addr_high[4]; /* Trap address high */ + u32 trap_id[4]; /* Trap ID */ + u32 snvs_addr[4]; /* SNVS address */ + u32 snvs_data[4]; /* SNVS data */ + u32 snvs_info[4]; /* SNVS info */ + u32 version[4]; /* Version */ +}; + +struct rdc_regs { + u32 vir; /* Version information */ + u32 reserved1[8]; + u32 stat; /* Status */ + u32 intctrl; /* Interrupt and Control */ + u32 intstat; /* Interrupt Status */ + u32 reserved2[116]; + u32 mda[27]; /* Master Domain Assignment */ + u32 reserved3[101]; + u32 pdap[118]; /* Peripheral Domain Access Permissions */ + u32 reserved4[138]; + struct { + u32 mrsa; /* Memory Region Start Address */ + u32 mrea; /* Memory Region End Address */ + u32 mrc; /* Memory Region Control */ + u32 mrvs; /* Memory Region Violation Status */ + } mem_region[52]; +}; + +struct rdc_sema_regs { + u8 gate[64]; /* Gate */ + u16 rstgt; /* Reset Gate */ +}; + +/* eLCDIF controller registers */ +struct mxs_lcdif_regs { + u32 hw_lcdif_ctrl; /* 0x00 */ + u32 hw_lcdif_ctrl_set; + u32 hw_lcdif_ctrl_clr; + u32 hw_lcdif_ctrl_tog; + u32 hw_lcdif_ctrl1; /* 0x10 */ + u32 hw_lcdif_ctrl1_set; + u32 hw_lcdif_ctrl1_clr; + u32 hw_lcdif_ctrl1_tog; + u32 hw_lcdif_ctrl2; /* 0x20 */ + u32 hw_lcdif_ctrl2_set; + u32 hw_lcdif_ctrl2_clr; + u32 hw_lcdif_ctrl2_tog; + u32 hw_lcdif_transfer_count; /* 0x30 */ + u32 reserved1[3]; + u32 hw_lcdif_cur_buf; /* 0x40 */ + u32 reserved2[3]; + u32 hw_lcdif_next_buf; /* 0x50 */ + u32 reserved3[3]; + u32 hw_lcdif_timing; /* 0x60 */ + u32 reserved4[3]; + u32 hw_lcdif_vdctrl0; /* 0x70 */ + u32 hw_lcdif_vdctrl0_set; + u32 hw_lcdif_vdctrl0_clr; + u32 hw_lcdif_vdctrl0_tog; + u32 hw_lcdif_vdctrl1; /* 0x80 */ + u32 reserved5[3]; + u32 hw_lcdif_vdctrl2; /* 0x90 */ + u32 reserved6[3]; + u32 hw_lcdif_vdctrl3; /* 0xa0 */ + u32 reserved7[3]; + u32 hw_lcdif_vdctrl4; /* 0xb0 */ + u32 reserved8[3]; + u32 hw_lcdif_dvictrl0; /* 0xc0 */ + u32 reserved9[3]; + u32 hw_lcdif_dvictrl1; /* 0xd0 */ + u32 reserved10[3]; + u32 hw_lcdif_dvictrl2; /* 0xe0 */ + u32 reserved11[3]; + u32 hw_lcdif_dvictrl3; /* 0xf0 */ + u32 reserved12[3]; + u32 hw_lcdif_dvictrl4; /* 0x100 */ + u32 reserved13[3]; + u32 hw_lcdif_csc_coeffctrl0; /* 0x110 */ + u32 reserved14[3]; + u32 hw_lcdif_csc_coeffctrl1; /* 0x120 */ + u32 reserved15[3]; + u32 hw_lcdif_csc_coeffctrl2; /* 0x130 */ + u32 reserved16[3]; + u32 hw_lcdif_csc_coeffctrl3; /* 0x140 */ + u32 reserved17[3]; + u32 hw_lcdif_csc_coeffctrl4; /* 0x150 */ + u32 reserved18[3]; + u32 hw_lcdif_csc_offset; /* 0x160 */ + u32 reserved19[3]; + u32 hw_lcdif_csc_limit; /* 0x170 */ + u32 reserved20[3]; + u32 hw_lcdif_data; /* 0x180 */ + u32 reserved21[3]; + u32 hw_lcdif_bm_error_stat; /* 0x190 */ + u32 reserved22[3]; + u32 hw_lcdif_crc_stat; /* 0x1a0 */ + u32 reserved23[3]; + u32 hw_lcdif_lcdif_stat; /* 0x1b0 */ + u32 reserved24[3]; + u32 hw_lcdif_version; /* 0x1c0 */ + u32 reserved25[3]; + u32 hw_lcdif_debug0; /* 0x1d0 */ + u32 reserved26[3]; + u32 hw_lcdif_debug1; /* 0x1e0 */ + u32 reserved27[3]; + u32 hw_lcdif_debug2; /* 0x1f0 */ + u32 reserved28[3]; + u32 hw_lcdif_thres; /* 0x200 */ + u32 reserved29[3]; + u32 hw_lcdif_as_ctrl; /* 0x210 */ + u32 reserved30[3]; + u32 hw_lcdif_as_buf; /* 0x220 */ + u32 reserved31[3]; + u32 hw_lcdif_as_next_buf; /* 0x230 */ + u32 reserved32[3]; + u32 hw_lcdif_as_clrkeylow; /* 0x240 */ + u32 reserved33[3]; + u32 hw_lcdif_as_clrkeyhigh; /* 0x250 */ + u32 reserved34[3]; + u32 hw_lcdif_as_sync_delay; /* 0x260 */ + u32 reserved35[3]; + u32 hw_lcdif_as_debug3; /* 0x270 */ + u32 reserved36[3]; + u32 hw_lcdif_as_debug4; /* 0x280 */ + u32 reserved37[3]; + u32 hw_lcdif_as_debug5; /* 0x290 */ +}; + +#define MXS_LCDIF_BASE ELCDIF1_IPS_BASE_ADDR + +#define LCDIF_CTRL_SFTRST (1 << 31) +#define LCDIF_CTRL_CLKGATE (1 << 30) +#define LCDIF_CTRL_YCBCR422_INPUT (1 << 29) +#define LCDIF_CTRL_READ_WRITEB (1 << 28) +#define LCDIF_CTRL_WAIT_FOR_VSYNC_EDGE (1 << 27) +#define LCDIF_CTRL_DATA_SHIFT_DIR (1 << 26) +#define LCDIF_CTRL_SHIFT_NUM_BITS_MASK (0x1f << 21) +#define LCDIF_CTRL_SHIFT_NUM_BITS_OFFSET 21 +#define LCDIF_CTRL_DVI_MODE (1 << 20) +#define LCDIF_CTRL_BYPASS_COUNT (1 << 19) +#define LCDIF_CTRL_VSYNC_MODE (1 << 18) +#define LCDIF_CTRL_DOTCLK_MODE (1 << 17) +#define LCDIF_CTRL_DATA_SELECT (1 << 16) +#define LCDIF_CTRL_INPUT_DATA_SWIZZLE_MASK (0x3 << 14) +#define LCDIF_CTRL_INPUT_DATA_SWIZZLE_OFFSET 14 +#define LCDIF_CTRL_CSC_DATA_SWIZZLE_MASK (0x3 << 12) +#define LCDIF_CTRL_CSC_DATA_SWIZZLE_OFFSET 12 +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK (0x3 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_OFFSET 10 +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_16BIT (0 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_8BIT (1 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_18BIT (2 << 10) +#define LCDIF_CTRL_LCD_DATABUS_WIDTH_24BIT (3 << 10) +#define LCDIF_CTRL_WORD_LENGTH_MASK (0x3 << 8) +#define LCDIF_CTRL_WORD_LENGTH_OFFSET 8 +#define LCDIF_CTRL_WORD_LENGTH_16BIT (0 << 8) +#define LCDIF_CTRL_WORD_LENGTH_8BIT (1 << 8) +#define LCDIF_CTRL_WORD_LENGTH_18BIT (2 << 8) +#define LCDIF_CTRL_WORD_LENGTH_24BIT (3 << 8) +#define LCDIF_CTRL_RGB_TO_YCBCR422_CSC (1 << 7) +#define LCDIF_CTRL_LCDIF_MASTER (1 << 5) +#define LCDIF_CTRL_DATA_FORMAT_16_BIT (1 << 3) +#define LCDIF_CTRL_DATA_FORMAT_18_BIT (1 << 2) +#define LCDIF_CTRL_DATA_FORMAT_24_BIT (1 << 1) +#define LCDIF_CTRL_RUN (1 << 0) + +#define LCDIF_CTRL1_COMBINE_MPU_WR_STRB (1 << 27) +#define LCDIF_CTRL1_BM_ERROR_IRQ_EN (1 << 26) +#define LCDIF_CTRL1_BM_ERROR_IRQ (1 << 25) +#define LCDIF_CTRL1_RECOVER_ON_UNDERFLOW (1 << 24) +#define LCDIF_CTRL1_INTERLACE_FIELDS (1 << 23) +#define LCDIF_CTRL1_START_INTERLACE_FROM_SECOND_FIELD (1 << 22) +#define LCDIF_CTRL1_FIFO_CLEAR (1 << 21) +#define LCDIF_CTRL1_IRQ_ON_ALTERNATE_FIELDS (1 << 20) +#define LCDIF_CTRL1_BYTE_PACKING_FORMAT_MASK (0xf << 16) +#define LCDIF_CTRL1_BYTE_PACKING_FORMAT_OFFSET 16 +#define LCDIF_CTRL1_OVERFLOW_IRQ_EN (1 << 15) +#define LCDIF_CTRL1_UNDERFLOW_IRQ_EN (1 << 14) +#define LCDIF_CTRL1_CUR_FRAME_DONE_IRQ_EN (1 << 13) +#define LCDIF_CTRL1_VSYNC_EDGE_IRQ_EN (1 << 12) +#define LCDIF_CTRL1_OVERFLOW_IRQ (1 << 11) +#define LCDIF_CTRL1_UNDERFLOW_IRQ (1 << 10) +#define LCDIF_CTRL1_CUR_FRAME_DONE_IRQ (1 << 9) +#define LCDIF_CTRL1_VSYNC_EDGE_IRQ (1 << 8) +#define LCDIF_CTRL1_BUSY_ENABLE (1 << 2) +#define LCDIF_CTRL1_MODE86 (1 << 1) +#define LCDIF_CTRL1_RESET (1 << 0) + +#define LCDIF_CTRL2_OUTSTANDING_REQS_MASK (0x7 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_OFFSET 21 +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_1 (0x0 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_2 (0x1 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_4 (0x2 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_8 (0x3 << 21) +#define LCDIF_CTRL2_OUTSTANDING_REQS_REQ_16 (0x4 << 21) +#define LCDIF_CTRL2_BURST_LEN_8 (1 << 20) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_MASK (0x7 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_OFFSET 16 +#define LCDIF_CTRL2_ODD_LINE_PATTERN_RGB (0x0 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_RBG (0x1 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_GBR (0x2 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_GRB (0x3 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_BRG (0x4 << 16) +#define LCDIF_CTRL2_ODD_LINE_PATTERN_BGR (0x5 << 16) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_MASK (0x7 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_OFFSET 12 +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_RGB (0x0 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_RBG (0x1 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_GBR (0x2 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_GRB (0x3 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_BRG (0x4 << 12) +#define LCDIF_CTRL2_EVEN_LINE_PATTERN_BGR (0x5 << 12) +#define LCDIF_CTRL2_READ_PACK_DIR (1 << 10) +#define LCDIF_CTRL2_READ_MODE_OUTPUT_IN_RGB_FORMAT (1 << 9) +#define LCDIF_CTRL2_READ_MODE_6_BIT_INPUT (1 << 8) +#define LCDIF_CTRL2_READ_MODE_NUM_PACKED_SUBWORDS_MASK (0x7 << 4) +#define LCDIF_CTRL2_READ_MODE_NUM_PACKED_SUBWORDS_OFFSET 4 +#define LCDIF_CTRL2_INITIAL_DUMMY_READ_MASK (0x7 << 1) +#define LCDIF_CTRL2_INITIAL_DUMMY_READ_OFFSET 1 + +#define LCDIF_TRANSFER_COUNT_V_COUNT_MASK (0xffff << 16) +#define LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET 16 +#define LCDIF_TRANSFER_COUNT_H_COUNT_MASK (0xffff << 0) +#define LCDIF_TRANSFER_COUNT_H_COUNT_OFFSET 0 + +#define LCDIF_CUR_BUF_ADDR_MASK 0xffffffff +#define LCDIF_CUR_BUF_ADDR_OFFSET 0 + +#define LCDIF_NEXT_BUF_ADDR_MASK 0xffffffff +#define LCDIF_NEXT_BUF_ADDR_OFFSET 0 + +#define LCDIF_TIMING_CMD_HOLD_MASK (0xff << 24) +#define LCDIF_TIMING_CMD_HOLD_OFFSET 24 +#define LCDIF_TIMING_CMD_SETUP_MASK (0xff << 16) +#define LCDIF_TIMING_CMD_SETUP_OFFSET 16 +#define LCDIF_TIMING_DATA_HOLD_MASK (0xff << 8) +#define LCDIF_TIMING_DATA_HOLD_OFFSET 8 +#define LCDIF_TIMING_DATA_SETUP_MASK (0xff << 0) +#define LCDIF_TIMING_DATA_SETUP_OFFSET 0 + +#define LCDIF_VDCTRL0_VSYNC_OEB (1 << 29) +#define LCDIF_VDCTRL0_ENABLE_PRESENT (1 << 28) +#define LCDIF_VDCTRL0_VSYNC_POL (1 << 27) +#define LCDIF_VDCTRL0_HSYNC_POL (1 << 26) +#define LCDIF_VDCTRL0_DOTCLK_POL (1 << 25) +#define LCDIF_VDCTRL0_ENABLE_POL (1 << 24) +#define LCDIF_VDCTRL0_VSYNC_PERIOD_UNIT (1 << 21) +#define LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_UNIT (1 << 20) +#define LCDIF_VDCTRL0_HALF_LINE (1 << 19) +#define LCDIF_VDCTRL0_HALF_LINE_MODE (1 << 18) +#define LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_MASK 0x3ffff +#define LCDIF_VDCTRL0_VSYNC_PULSE_WIDTH_OFFSET 0 + +#define LCDIF_VDCTRL1_VSYNC_PERIOD_MASK 0xffffffff +#define LCDIF_VDCTRL1_VSYNC_PERIOD_OFFSET 0 + +#define LCDIF_VDCTRL2_HSYNC_PULSE_WIDTH_MASK (0x3fff << 18) +#define LCDIF_VDCTRL2_HSYNC_PULSE_WIDTH_OFFSET 18 +#define LCDIF_VDCTRL2_HSYNC_PERIOD_MASK 0x3ffff +#define LCDIF_VDCTRL2_HSYNC_PERIOD_OFFSET 0 + +#define LCDIF_VDCTRL3_MUX_SYNC_SIGNALS (1 << 29) +#define LCDIF_VDCTRL3_VSYNC_ONLY (1 << 28) +#define LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_MASK (0xfff << 16) +#define LCDIF_VDCTRL3_HORIZONTAL_WAIT_CNT_OFFSET 16 +#define LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_MASK (0xffff << 0) +#define LCDIF_VDCTRL3_VERTICAL_WAIT_CNT_OFFSET 0 + +#define LCDIF_VDCTRL4_DOTCLK_DLY_SEL_MASK (0x7 << 29) +#define LCDIF_VDCTRL4_DOTCLK_DLY_SEL_OFFSET 29 +#define LCDIF_VDCTRL4_SYNC_SIGNALS_ON (1 << 18) +#define LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_MASK 0x3ffff +#define LCDIF_VDCTRL4_DOTCLK_H_VALID_DATA_CNT_OFFSET 0 + + +extern void check_cpu_temperature(void); + +extern void pcie_power_up(void); +extern void pcie_power_off(void); + +/* If ROM fail back to USB recover mode, USBPH0_PWD will be clear to use USB + * If boot from the other mode, USB0_PWD will keep reset value + */ +#define is_boot_from_usb(void) (readl(USBOTG1_IPS_BASE_ADDR + 0x158) || \ + readl(USBOTG2_IPS_BASE_ADDR + 0x158)) +#define disconnect_from_pc(void) writel(0x0, USBOTG1_IPS_BASE_ADDR + 0x140) + +/* Boot device type */ +#define BOOT_TYPE_SD 0x1 +#define BOOT_TYPE_MMC 0x2 +#define BOOT_TYPE_NAND 0x3 +#define BOOT_TYPE_QSPI 0x4 +#define BOOT_TYPE_WEIM 0x5 +#define BOOT_TYPE_SPINOR 0x6 + +struct bootrom_sw_info { + u8 reserved_1; + u8 boot_dev_instance; + u8 boot_dev_type; + u8 reserved_2; + u32 arm_core_freq; + u32 axi_freq; + u32 ddr_freq; + u32 gpt1_freq; + u32 reserved_3[3]; +}; + +#endif /* __ASSEMBLER__*/ +#endif /* __ASM_ARCH_MX7_IMX_REGS_H__ */ diff --git a/arch/arm/include/asm/arch-mx7/sys_proto.h b/arch/arm/include/asm/arch-mx7/sys_proto.h new file mode 100644 index 0000000..f19684b --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/sys_proto.h @@ -0,0 +1,7 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/imx-common/sys_proto.h>
* Add Clock control module (CCM) support * iMX7D SoC introduces 3 main clock sysmtem abstraction for clock root frequency generation denominated clock slices. Core clock slice: hihg speed clock for ARM core Bus clock slice: for bus clocks IP clock slice: Peripheral clocks * At system boot ROM enables PLL_ARM, PLL_DDR, PLL_SYS, PLL_ENET In u-boot, we have to: - Configure PFD3- PFD7 for freq we needed in u-boot - Set clock root for peripherals (ip channel)
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2 - V7: Resend
arch/arm/cpu/armv7/mx7/clock.c | 1127 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx7/clock_slice.c | 757 ++++++++++++++++++ arch/arm/include/asm/arch-mx7/clock.h | 348 +++++++++ arch/arm/include/asm/arch-mx7/clock_slice.h | 116 +++ 4 files changed, 2348 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/clock.c create mode 100644 arch/arm/cpu/armv7/mx7/clock_slice.c create mode 100644 arch/arm/include/asm/arch-mx7/clock.h create mode 100644 arch/arm/include/asm/arch-mx7/clock_slice.h
diff --git a/arch/arm/cpu/armv7/mx7/clock.c b/arch/arm/cpu/armv7/mx7/clock.c new file mode 100644 index 0000000..77db6e8 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/clock.c @@ -0,0 +1,1127 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) + ANATOP_BASE_ADDR; +struct mxc_ccm_reg *ccm_reg = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + +#ifdef CONFIG_FSL_ESDHC +DECLARE_GLOBAL_DATA_PTR; +#endif + +int get_clocks(void) +{ +#ifdef CONFIG_FSL_ESDHC +#if CONFIG_SYS_FSL_ESDHC_ADDR == USDHC2_BASE_ADDR + gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); +#elif CONFIG_SYS_FSL_ESDHC_ADDR == USDHC3_BASE_ADDR + gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); +#else + gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); +#endif +#endif + return 0; +} + +u32 get_ahb_clk(void) +{ + return get_root_clk(AHB_CLK_ROOT); +} + +static u32 get_ipg_clk(void) +{ + /* + * The AHB and IPG are fixed at 2:1 ratio, and synchronized to + * each other. + */ + return get_ahb_clk() / 2; +} + +u32 imx_get_uartclk(void) +{ + return get_root_clk(UART1_CLK_ROOT); +} + +u32 imx_get_fecclk(void) +{ + return get_root_clk(ENET_AXI_CLK_ROOT); +} + +#ifdef CONFIG_MXC_OCOTP +void enable_ocotp_clk(unsigned char enable) +{ + clock_enable(CCGR_OCOTP, enable); +} + +void enable_thermal_clk(void) +{ + enable_ocotp_clk(1); +} +#endif + +void enable_usboh3_clk(unsigned char enable) +{ + u32 target; + + if (enable) { + /* disable the clock gate first */ + clock_enable(CCGR_USB_HSIC, 0); + + /* 120Mhz */ + target = CLK_ROOT_ON | + USB_HSIC_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(USB_HSIC_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_USB_CTRL, 1); + clock_enable(CCGR_USB_HSIC, 1); + clock_enable(CCGR_USB_PHY1, 1); + clock_enable(CCGR_USB_PHY2, 1); + } else { + clock_enable(CCGR_USB_CTRL, 0); + clock_enable(CCGR_USB_HSIC, 0); + clock_enable(CCGR_USB_PHY1, 0); + clock_enable(CCGR_USB_PHY2, 0); + } +} + +static u32 decode_pll(enum pll_clocks pll, u32 infreq) +{ + u32 reg, div_sel; + u32 num, denom; + + /* + * Alought there are four choices for the bypass src, + * we choose OSC_24M which is the default set in ROM. + */ + switch (pll) { + case PLL_CORE: + reg = readl(&ccm_anatop->pll_arm); + + if (reg & CCM_ANALOG_PLL_ARM_POWERDOWN_MASK) + return 0; + + if (reg & CCM_ANALOG_PLL_ARM_BYPASS_MASK) + return MXC_HCLK; + + div_sel = (reg & CCM_ANALOG_PLL_ARM_DIV_SELECT_MASK) >> + CCM_ANALOG_PLL_ARM_DIV_SELECT_SHIFT; + + return (infreq * div_sel) / 2; + + case PLL_SYS: + reg = readl(&ccm_anatop->pll_480); + + if (reg & CCM_ANALOG_PLL_480_POWERDOWN_MASK) + return 0; + + if (reg & CCM_ANALOG_PLL_480_BYPASS_MASK) + return MXC_HCLK; + + if (((reg & CCM_ANALOG_PLL_480_DIV_SELECT_MASK) >> + CCM_ANALOG_PLL_480_DIV_SELECT_SHIFT) == 0) + return 480000000u; + else + return 528000000u; + + case PLL_ENET: + reg = readl(&ccm_anatop->pll_enet); + + if (reg & CCM_ANALOG_PLL_ENET_POWERDOWN_MASK) + return 0; + + if (reg & CCM_ANALOG_PLL_ENET_BYPASS_MASK) + return MXC_HCLK; + + return 1000000000u; + + case PLL_DDR: + reg = readl(&ccm_anatop->pll_ddr); + + if (reg & CCM_ANALOG_PLL_DDR_POWERDOWN_MASK) + return 0; + + num = ccm_anatop->pll_ddr_num; + denom = ccm_anatop->pll_ddr_denom; + + if (reg & CCM_ANALOG_PLL_DDR_BYPASS_MASK) + return MXC_HCLK; + + div_sel = (reg & CCM_ANALOG_PLL_DDR_DIV_SELECT_MASK) >> + CCM_ANALOG_PLL_DDR_DIV_SELECT_SHIFT; + + return infreq * (div_sel + num / denom); + + case PLL_USB: + return 480000000u; + + default: + printf("Unsupported pll clocks %d\n", pll); + break; + } + + return 0; +} + +static u32 mxc_get_pll_sys_derive(int derive) +{ + u32 freq, div, frac; + u32 reg; + + div = 1; + reg = readl(&ccm_anatop->pll_480); + freq = decode_pll(PLL_SYS, MXC_HCLK); + + switch (derive) { + case PLL_SYS_MAIN_480M_CLK: + if (reg & CCM_ANALOG_PLL_480_MAIN_DIV1_CLKGATE_MASK) + return 0; + else + return freq; + case PLL_SYS_MAIN_240M_CLK: + if (reg & CCM_ANALOG_PLL_480_MAIN_DIV2_CLKGATE_MASK) + return 0; + else + return freq / 2; + case PLL_SYS_MAIN_120M_CLK: + if (reg & CCM_ANALOG_PLL_480_MAIN_DIV4_CLKGATE_MASK) + return 0; + else + return freq / 4; + case PLL_SYS_PFD0_392M_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD0_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD0_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD0_FRAC_SHIFT; + break; + case PLL_SYS_PFD0_196M_CLK: + if (reg & CCM_ANALOG_PLL_480_PFD0_DIV2_CLKGATE_MASK) + return 0; + reg = readl(&ccm_anatop->pfd_480a); + frac = (reg & CCM_ANALOG_PFD_480A_PFD0_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD0_FRAC_SHIFT; + div = 2; + break; + case PLL_SYS_PFD1_332M_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD1_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD1_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD1_FRAC_SHIFT; + break; + case PLL_SYS_PFD1_166M_CLK: + if (reg & CCM_ANALOG_PLL_480_PFD1_DIV2_CLKGATE_MASK) + return 0; + reg = readl(&ccm_anatop->pfd_480a); + frac = (reg & CCM_ANALOG_PFD_480A_PFD1_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD1_FRAC_SHIFT; + div = 2; + break; + case PLL_SYS_PFD2_270M_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD2_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD2_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD2_FRAC_SHIFT; + break; + case PLL_SYS_PFD2_135M_CLK: + if (reg & CCM_ANALOG_PLL_480_PFD2_DIV2_CLKGATE_MASK) + return 0; + reg = readl(&ccm_anatop->pfd_480a); + frac = (reg & CCM_ANALOG_PFD_480A_PFD2_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD2_FRAC_SHIFT; + div = 2; + break; + case PLL_SYS_PFD3_CLK: + reg = readl(&ccm_anatop->pfd_480a); + if (reg & CCM_ANALOG_PFD_480A_PFD3_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480A_PFD3_FRAC_MASK) >> + CCM_ANALOG_PFD_480A_PFD3_FRAC_SHIFT; + break; + case PLL_SYS_PFD4_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD4_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD4_FRAC_SHIFT; + break; + case PLL_SYS_PFD5_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD5_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD5_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD5_FRAC_SHIFT; + break; + case PLL_SYS_PFD6_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD6_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD6_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD6_FRAC_SHIFT; + break; + case PLL_SYS_PFD7_CLK: + reg = readl(&ccm_anatop->pfd_480b); + if (reg & CCM_ANALOG_PFD_480B_PFD7_DIV1_CLKGATE_MASK) + return 0; + frac = (reg & CCM_ANALOG_PFD_480B_PFD7_FRAC_MASK) >> + CCM_ANALOG_PFD_480B_PFD7_FRAC_SHIFT; + break; + default: + printf("Error derived pll_sys clock %d\n", derive); + return 0; + } + + return ((freq / frac) * 18) / div; +} + +static u32 mxc_get_pll_enet_derive(int derive) +{ + u32 freq, reg; + + freq = decode_pll(PLL_ENET, MXC_HCLK); + reg = readl(&ccm_anatop->pll_enet); + + switch (derive) { + case PLL_ENET_MAIN_500M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_MASK) + return freq / 2; + break; + case PLL_ENET_MAIN_250M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_MASK) + return freq / 4; + break; + case PLL_ENET_MAIN_125M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_MASK) + return freq / 8; + break; + case PLL_ENET_MAIN_100M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_MASK) + return freq / 10; + break; + case PLL_ENET_MAIN_50M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_MASK) + return freq / 20; + break; + case PLL_ENET_MAIN_40M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_MASK) + return freq / 25; + break; + case PLL_ENET_MAIN_25M_CLK: + if (reg & CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_MASK) + return freq / 40; + break; + default: + printf("Error derived pll_enet clock %d\n", derive); + break; + } + + return 0; +} + +static u32 mxc_get_pll_ddr_derive(int derive) +{ + u32 freq, reg; + + freq = decode_pll(PLL_DDR, MXC_HCLK); + reg = readl(&ccm_anatop->pll_ddr); + + switch (derive) { + case PLL_DRAM_MAIN_1066M_CLK: + return freq; + case PLL_DRAM_MAIN_533M_CLK: + if (reg & CCM_ANALOG_PLL_DDR_DIV2_ENABLE_CLK_MASK) + return freq / 2; + break; + default: + printf("Error derived pll_ddr clock %d\n", derive); + break; + } + + return 0; +} + +static u32 mxc_get_pll_derive(enum pll_clocks pll, int derive) +{ + switch (pll) { + case PLL_SYS: + return mxc_get_pll_sys_derive(derive); + case PLL_ENET: + return mxc_get_pll_enet_derive(derive); + case PLL_DDR: + return mxc_get_pll_ddr_derive(derive); + default: + printf("Error pll.\n"); + return 0; + } +} + +static u32 get_root_src_clk(enum clk_root_src root_src) +{ + switch (root_src) { + case OSC_24M_CLK: + return 24000000u; + case PLL_ARM_MAIN_800M_CLK: + return decode_pll(PLL_CORE, MXC_HCLK); + + case PLL_SYS_MAIN_480M_CLK: + case PLL_SYS_MAIN_240M_CLK: + case PLL_SYS_MAIN_120M_CLK: + case PLL_SYS_PFD0_392M_CLK: + case PLL_SYS_PFD0_196M_CLK: + case PLL_SYS_PFD1_332M_CLK: + case PLL_SYS_PFD1_166M_CLK: + case PLL_SYS_PFD2_270M_CLK: + case PLL_SYS_PFD2_135M_CLK: + case PLL_SYS_PFD3_CLK: + case PLL_SYS_PFD4_CLK: + case PLL_SYS_PFD5_CLK: + case PLL_SYS_PFD6_CLK: + case PLL_SYS_PFD7_CLK: + return mxc_get_pll_derive(PLL_SYS, root_src); + + case PLL_ENET_MAIN_500M_CLK: + case PLL_ENET_MAIN_250M_CLK: + case PLL_ENET_MAIN_125M_CLK: + case PLL_ENET_MAIN_100M_CLK: + case PLL_ENET_MAIN_50M_CLK: + case PLL_ENET_MAIN_40M_CLK: + case PLL_ENET_MAIN_25M_CLK: + return mxc_get_pll_derive(PLL_ENET, root_src); + + case PLL_DRAM_MAIN_1066M_CLK: + case PLL_DRAM_MAIN_533M_CLK: + return mxc_get_pll_derive(PLL_DDR, root_src); + + case PLL_AUDIO_MAIN_CLK: + return decode_pll(PLL_AUDIO, MXC_HCLK); + case PLL_VIDEO_MAIN_CLK: + return decode_pll(PLL_VIDEO, MXC_HCLK); + + case PLL_USB_MAIN_480M_CLK: + return decode_pll(PLL_USB, MXC_HCLK); + + case REF_1M_CLK: + return 1000000; + case OSC_32K_CLK: + return MXC_CLK32; + + case EXT_CLK_1: + case EXT_CLK_2: + case EXT_CLK_3: + case EXT_CLK_4: + printf("No EXT CLK supported??\n"); + break; + }; + + return 0; +} + +u32 get_root_clk(enum clk_root_index clock_id) +{ + enum clk_root_src root_src; + u32 post_podf, pre_podf, auto_podf, root_src_clk; + int auto_en; + + if (clock_root_enabled(clock_id) <= 0) + return 0; + + if (clock_get_prediv(clock_id, &pre_podf) < 0) + return 0; + + if (clock_get_postdiv(clock_id, &post_podf) < 0) + return 0; + + if (clock_get_autopostdiv(clock_id, &auto_podf, &auto_en) < 0) + return 0; + + if (auto_en == 0) + auto_podf = 0; + + if (clock_get_src(clock_id, &root_src) < 0) + return 0; + + root_src_clk = get_root_src_clk(root_src); + + /* + * bypass clk is ignored. + */ + + return root_src_clk / (post_podf + 1) / (pre_podf + 1) / + (auto_podf + 1); +} + +static u32 get_ddrc_clk(void) +{ + u32 reg, freq; + enum root_post_div post_div; + + reg = readl(&ccm_reg->root[DRAM_CLK_ROOT].target_root); + if (reg & CLK_ROOT_MUX_MASK) + /* DRAM_ALT_CLK_ROOT */ + freq = get_root_clk(DRAM_ALT_CLK_ROOT); + else + /* PLL_DRAM_MAIN_1066M_CLK */ + freq = mxc_get_pll_derive(PLL_DDR, PLL_DRAM_MAIN_1066M_CLK); + + post_div = reg & DRAM_CLK_ROOT_POST_DIV_MASK; + + return freq / (post_div + 1) / 2; +} + +unsigned int mxc_get_clock(enum mxc_clock clk) +{ + switch (clk) { + case MXC_ARM_CLK: + return get_root_clk(ARM_A7_CLK_ROOT); + case MXC_AXI_CLK: + return get_root_clk(MAIN_AXI_CLK_ROOT); + case MXC_AHB_CLK: + return get_root_clk(AHB_CLK_ROOT); + case MXC_IPG_CLK: + return get_ipg_clk(); + case MXC_I2C_CLK: + return get_root_clk(I2C1_CLK_ROOT); + case MXC_UART_CLK: + return get_root_clk(UART1_CLK_ROOT); + case MXC_CSPI_CLK: + return get_root_clk(ECSPI1_CLK_ROOT); + case MXC_DDR_CLK: + return get_ddrc_clk(); + case MXC_ESDHC_CLK: + return get_root_clk(USDHC1_CLK_ROOT); + case MXC_ESDHC2_CLK: + return get_root_clk(USDHC2_CLK_ROOT); + case MXC_ESDHC3_CLK: + return get_root_clk(USDHC3_CLK_ROOT); + default: + printf("Unsupported mxc_clock %d\n", clk); + break; + } + + return 0; +} + +#ifdef CONFIG_SYS_I2C_MXC +/* i2c_num can be 0 - 3 */ +int enable_i2c_clk(unsigned char enable, unsigned i2c_num) +{ + u32 target; + + if (i2c_num >= 4) + return -EINVAL; + + if (enable) { + clock_enable(CCGR_I2C1 + i2c_num, 0); + + /* Set i2c root clock to PLL_SYS_MAIN_120M_CLK */ + + target = CLK_ROOT_ON | + I2C1_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(I2C1_CLK_ROOT + i2c_num, target); + + clock_enable(CCGR_I2C1 + i2c_num, 1); + } else { + clock_enable(CCGR_I2C1 + i2c_num, 0); + } + + return 0; +} +#endif + +static void init_clk_esdhc(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_USDHC1, 0); + clock_enable(CCGR_USDHC2, 0); + clock_enable(CCGR_USDHC3, 0); + + /* 196: 392/2 */ + target = CLK_ROOT_ON | USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(USDHC1_CLK_ROOT, target); + + target = CLK_ROOT_ON | USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(USDHC2_CLK_ROOT, target); + + target = CLK_ROOT_ON | USDHC1_CLK_ROOT_FROM_PLL_SYS_PFD0_392M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(USDHC3_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_USDHC1, 1); + clock_enable(CCGR_USDHC2, 1); + clock_enable(CCGR_USDHC3, 1); +} + +static void init_clk_uart(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_UART1, 0); + clock_enable(CCGR_UART2, 0); + clock_enable(CCGR_UART3, 0); + clock_enable(CCGR_UART4, 0); + clock_enable(CCGR_UART5, 0); + clock_enable(CCGR_UART6, 0); + clock_enable(CCGR_UART7, 0); + + /* 24Mhz */ + target = CLK_ROOT_ON | UART1_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART1_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART2_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART2_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART3_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART3_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART4_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART4_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART5_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART5_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART6_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART6_CLK_ROOT, target); + + target = CLK_ROOT_ON | UART7_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(UART7_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_UART1, 1); + clock_enable(CCGR_UART2, 1); + clock_enable(CCGR_UART3, 1); + clock_enable(CCGR_UART4, 1); + clock_enable(CCGR_UART5, 1); + clock_enable(CCGR_UART6, 1); + clock_enable(CCGR_UART7, 1); +} + +static void init_clk_weim(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_WEIM, 0); + + /* 120Mhz */ + target = CLK_ROOT_ON | EIM_CLK_ROOT_FROM_PLL_SYS_MAIN_120M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(EIM_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_WEIM, 1); +} + +static void init_clk_ecspi(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_ECSPI1, 0); + clock_enable(CCGR_ECSPI2, 0); + clock_enable(CCGR_ECSPI3, 0); + clock_enable(CCGR_ECSPI4, 0); + + /* 60Mhz: 240/4 */ + target = CLK_ROOT_ON | ECSPI1_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI1_CLK_ROOT, target); + + target = CLK_ROOT_ON | ECSPI2_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI2_CLK_ROOT, target); + + target = CLK_ROOT_ON | ECSPI3_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI3_CLK_ROOT, target); + + target = CLK_ROOT_ON | ECSPI4_CLK_ROOT_FROM_PLL_SYS_MAIN_240M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ECSPI4_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_ECSPI1, 1); + clock_enable(CCGR_ECSPI2, 1); + clock_enable(CCGR_ECSPI3, 1); + clock_enable(CCGR_ECSPI4, 1); +} + +static void init_clk_wdog(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_WDOG1, 0); + clock_enable(CCGR_WDOG2, 0); + clock_enable(CCGR_WDOG3, 0); + clock_enable(CCGR_WDOG4, 0); + + /* 24Mhz */ + target = CLK_ROOT_ON | WDOG_CLK_ROOT_FROM_OSC_24M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(WDOG_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_WDOG1, 1); + clock_enable(CCGR_WDOG2, 1); + clock_enable(CCGR_WDOG3, 1); + clock_enable(CCGR_WDOG4, 1); +} + +#ifdef CONFIG_MXC_EPDC +static void init_clk_epdc(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_EPDC, 0); + + /* 24Mhz */ + target = CLK_ROOT_ON | EPDC_PIXEL_CLK_ROOT_FROM_PLL_SYS_MAIN_480M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV12); + clock_set_target_val(EPDC_PIXEL_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_EPDC, 1); +} +#endif + +static int enable_pll_enet(void) +{ + u32 reg; + s32 timeout = 100000; + + reg = readl(&ccm_anatop->pll_enet); + /* If pll_enet powered up, no need to set it again */ + if (reg & ANADIG_PLL_ENET_PWDN_MASK) { + reg &= ~ANADIG_PLL_ENET_PWDN_MASK; + writel(reg, &ccm_anatop->pll_enet); + + while (timeout--) { + if (readl(&ccm_anatop->pll_enet) & ANADIG_PLL_LOCK) + break; + } + + if (timeout <= 0) { + /* If timeout, we set pwdn for pll_enet. */ + reg |= ANADIG_PLL_ENET_PWDN_MASK; + return -ETIME; + } + } + + /* Clear bypass */ + writel(CCM_ANALOG_PLL_ENET_BYPASS_MASK, &ccm_anatop->pll_enet_clr); + + writel((CCM_ANALOG_PLL_ENET_ENABLE_CLK_500MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_250MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_125MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_100MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_50MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_40MHZ_MASK + | CCM_ANALOG_PLL_ENET_ENABLE_CLK_25MHZ_MASK), + &ccm_anatop->pll_enet_set); + + return 0; +} +static int enable_pll_video(u32 pll_div, u32 pll_num, u32 pll_denom, + u32 post_div) +{ + u32 reg = 0; + ulong start; + + debug("pll5 div = %d, num = %d, denom = %d\n", + pll_div, pll_num, pll_denom); + + /* Power up PLL5 video and disable its output */ + writel(CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_POWERDOWN_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_BYPASS_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_DIV_SELECT_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_POST_DIV_SEL_MASK | + CCM_ANALOG_PLL_VIDEO_CLR_TEST_DIV_SELECT_MASK, + &ccm_anatop->pll_video_clr); + + /* Set div, num and denom */ + switch (post_div) { + case 1: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x1) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x0), + &ccm_anatop->pll_video_set); + break; + case 2: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x0) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x0), + &ccm_anatop->pll_video_set); + break; + case 3: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x0) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x1), + &ccm_anatop->pll_video_set); + break; + case 4: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x0) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x3), + &ccm_anatop->pll_video_set); + break; + case 0: + default: + writel(CCM_ANALOG_PLL_VIDEO_SET_DIV_SELECT(pll_div) | + CCM_ANALOG_PLL_VIDEO_SET_TEST_DIV_SELECT(0x2) | + CCM_ANALOG_PLL_VIDEO_SET_POST_DIV_SEL(0x0), + &ccm_anatop->pll_video_set); + break; + } + + writel(CCM_ANALOG_PLL_VIDEO_NUM_A(pll_num), + &ccm_anatop->pll_video_num); + + writel(CCM_ANALOG_PLL_VIDEO_DENOM_B(pll_denom), + &ccm_anatop->pll_video_denom); + + /* Wait PLL5 lock */ + start = get_timer(0); /* Get current timestamp */ + + do { + reg = readl(&ccm_anatop->pll_video); + if (reg & CCM_ANALOG_PLL_VIDEO_LOCK_MASK) { + /* Enable PLL out */ + writel(CCM_ANALOG_PLL_VIDEO_CLR_ENABLE_CLK_MASK, + &ccm_anatop->pll_video_set); + return 0; + } + } while (get_timer(0) < (start + 10)); /* Wait 10ms */ + + printf("Lock PLL5 timeout\n"); + + return 1; +} + +int set_clk_qspi(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_QSPI, 0); + + /* 49M: 392/2/4 */ + target = CLK_ROOT_ON | QSPI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(QSPI_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_QSPI, 1); + + return 0; +} + +int set_clk_nand(void) +{ + u32 target; + + /* disable the clock gate first */ + clock_enable(CCGR_RAWNAND, 0); + + enable_pll_enet(); + /* 100: 500/5 */ + target = CLK_ROOT_ON | NAND_CLK_ROOT_FROM_PLL_ENET_MAIN_500M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV5); + clock_set_target_val(NAND_CLK_ROOT, target); + + /* enable the clock gate */ + clock_enable(CCGR_RAWNAND, 1); + + return 0; +} + +void mxs_set_lcdclk(uint32_t base_addr, uint32_t freq) +{ + u32 hck = MXC_HCLK/1000; + u32 min = hck * 27; + u32 max = hck * 54; + u32 temp, best = 0; + u32 i, j, pred = 1, postd = 1; + u32 pll_div, pll_num, pll_denom, post_div = 0; + u32 target; + + debug("mxs_set_lcdclk, freq = %d\n", freq); + + clock_enable(CCGR_LCDIF, 0); + + temp = (freq * 8 * 8); + if (temp < min) { + for (i = 1; i <= 4; i++) { + if ((temp * (1 << i)) > min) { + post_div = i; + freq = (freq * (1 << i)); + break; + } + } + + if (5 == i) { + printf("Fail to set rate to %dkhz", freq); + return; + } + } + + for (i = 1; i <= 8; i++) { + for (j = 1; j <= 8; j++) { + temp = freq * i * j; + if (temp > max || temp < min) + continue; + + if (best == 0 || temp < best) { + best = temp; + pred = i; + postd = j; + } + } + } + + if (best == 0) { + printf("Fail to set rate to %dkhz", freq); + return; + } + + debug("best %d, pred = %d, postd = %d\n", best, pred, postd); + + pll_div = best / hck; + pll_denom = 1000000; + pll_num = (best - hck * pll_div) * pll_denom / hck; + + if (enable_pll_video(pll_div, pll_num, pll_denom, post_div)) + return; + + target = CLK_ROOT_ON | LCDIF_PIXEL_CLK_ROOT_FROM_PLL_VIDEO_MAIN_CLK | + CLK_ROOT_PRE_DIV((pred - 1)) | CLK_ROOT_POST_DIV((postd - 1)); + clock_set_target_val(LCDIF_PIXEL_CLK_ROOT, target); + + clock_enable(CCGR_LCDIF, 1); +} + +#ifdef CONFIG_FEC_MXC +int set_clk_enet(enum enet_freq type) +{ + u32 target; + int ret; + u32 enet1_ref, enet2_ref; + + /* disable the clock first */ + clock_enable(CCGR_ENET1, 0); + clock_enable(CCGR_ENET2, 0); + + switch (type) { + case ENET_125MHz: + enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; + enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_125M_CLK; + break; + case ENET_50MHz: + enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; + enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_50M_CLK; + break; + case ENET_25MHz: + enet1_ref = ENET1_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; + enet2_ref = ENET2_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK; + break; + default: + return -EINVAL; + } + + ret = enable_pll_enet(); + if (ret != 0) + return ret; + + /* set enet axi clock 196M: 392/2 */ + target = CLK_ROOT_ON | ENET_AXI_CLK_ROOT_FROM_PLL_SYS_PFD4_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV2); + clock_set_target_val(ENET_AXI_CLK_ROOT, target); + + target = CLK_ROOT_ON | enet1_ref | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(ENET1_REF_CLK_ROOT, target); + + target = CLK_ROOT_ON | ENET1_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ENET1_TIME_CLK_ROOT, target); + + target = CLK_ROOT_ON | enet2_ref | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(ENET2_REF_CLK_ROOT, target); + + target = CLK_ROOT_ON | ENET2_TIME_CLK_ROOT_FROM_PLL_ENET_MAIN_100M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV4); + clock_set_target_val(ENET2_TIME_CLK_ROOT, target); + +#ifdef CONFIG_FEC_MXC_25M_REF_CLK + target = CLK_ROOT_ON | + ENET_PHY_REF_CLK_ROOT_FROM_PLL_ENET_MAIN_25M_CLK | + CLK_ROOT_PRE_DIV(CLK_ROOT_PRE_DIV1) | + CLK_ROOT_POST_DIV(CLK_ROOT_POST_DIV1); + clock_set_target_val(ENET_PHY_REF_CLK_ROOT, target); +#endif + /* enable clock */ + clock_enable(CCGR_ENET1, 1); + clock_enable(CCGR_ENET2, 1); + + return 0; +} +#endif + +/* Configure PLL/PFD freq */ +void clock_init(void) +{ +/* Rom has enabled PLL_ARM, PLL_DDR, PLL_SYS, PLL_ENET + * In u-boot, we have to: + * 1. Configure PFD3- PFD7 for freq we needed in u-boot + * 2. Set clock root for peripherals (ip channel) used in u-boot but without set rate + * interface. The clocks for these peripherals are enabled after this intialization. + * 3. Other peripherals with set clock rate interface does not be set in this function. + */ + u32 reg; + + /* + * Configure PFD4 to 392M + * 480M * 18 / 0x16 = 392M + */ + reg = readl(&ccm_anatop->pfd_480b); + + reg &= ~(ANATOP_PFD480B_PFD4_FRAC_MASK | + CCM_ANALOG_PFD_480B_PFD4_DIV1_CLKGATE_MASK); + reg |= ANATOP_PFD480B_PFD4_FRAC_392M_VAL; + + writel(reg, &ccm_anatop->pfd_480b); + + init_clk_esdhc(); + init_clk_uart(); + init_clk_weim(); + init_clk_ecspi(); + init_clk_wdog(); +#ifdef CONFIG_MXC_EPDC + init_clk_epdc(); +#endif + + enable_usboh3_clk(1); + + clock_enable(CCGR_SNVS, 1); + +#ifdef CONFIG_NAND_MXS + clock_enable(CCGR_RAWNAND, 1); +#endif +} + +#ifdef CONFIG_SECURE_BOOT +void hab_caam_clock_enable(unsigned char enable) +{ + if (enable) + clock_enable(CCGR_CAAM, 1); + else + clock_enable(CCGR_CAAM, 0); +} +#endif + +#ifdef CONFIG_MXC_EPDC +void epdc_clock_enable(void) +{ + clock_enable(CCGR_EPDC, 1); +} +void epdc_clock_disable(void) +{ + clock_enable(CCGR_EPDC, 0); +} +#endif + +/* + * Dump some core clockes. + */ +int do_mx7_showclocks(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + u32 freq; + freq = decode_pll(PLL_CORE, MXC_HCLK); + printf("PLL_CORE %8d MHz\n", freq / 1000000); + freq = decode_pll(PLL_SYS, MXC_HCLK); + printf("PLL_SYS %8d MHz\n", freq / 1000000); + freq = decode_pll(PLL_ENET, MXC_HCLK); + printf("PLL_NET %8d MHz\n", freq / 1000000); + + printf("\n"); + + printf("IPG %8d kHz\n", mxc_get_clock(MXC_IPG_CLK) / 1000); + printf("UART %8d kHz\n", mxc_get_clock(MXC_UART_CLK) / 1000); +#ifdef CONFIG_MXC_SPI + printf("CSPI %8d kHz\n", mxc_get_clock(MXC_CSPI_CLK) / 1000); +#endif + printf("AHB %8d kHz\n", mxc_get_clock(MXC_AHB_CLK) / 1000); + printf("AXI %8d kHz\n", mxc_get_clock(MXC_AXI_CLK) / 1000); + printf("DDR %8d kHz\n", mxc_get_clock(MXC_DDR_CLK) / 1000); + printf("USDHC1 %8d kHz\n", mxc_get_clock(MXC_ESDHC_CLK) / 1000); + printf("USDHC2 %8d kHz\n", mxc_get_clock(MXC_ESDHC2_CLK) / 1000); + printf("USDHC3 %8d kHz\n", mxc_get_clock(MXC_ESDHC3_CLK) / 1000); + + return 0; +} + +U_BOOT_CMD( + clocks, CONFIG_SYS_MAXARGS, 1, do_mx7_showclocks, + "display clocks", + "" +); diff --git a/arch/arm/cpu/armv7/mx7/clock_slice.c b/arch/arm/cpu/armv7/mx7/clock_slice.c new file mode 100644 index 0000000..ad5d504 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/clock_slice.c @@ -0,0 +1,757 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + +static struct clk_root_map root_array[] = { + {ARM_A7_CLK_ROOT, CCM_CORE_CHANNEL, + {OSC_24M_CLK, PLL_ARM_MAIN_800M_CLK, PLL_ENET_MAIN_500M_CLK, + PLL_DRAM_MAIN_1066M_CLK, PLL_SYS_MAIN_480M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_AUDIO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ARM_M4_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_250M_CLK, + PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ARM_M0_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_125M_CLK, + PLL_SYS_PFD2_135M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {MAIN_AXI_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_SYS_PFD5_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD7_CLK} + }, + {DISP_AXI_CLK_ROOT, CCM_BUS_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK, + PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} + }, + {ENET_AXI_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK} + }, + {NAND_USDHC_BUS_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_240M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_PFD6_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_AUDIO_MAIN_CLK} + }, + {AHB_CLK_ROOT, CCM_AHB_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, + PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} + }, + {DRAM_PHYM_CLK_ROOT, CCM_DRAM_PHYM_CHANNEL, + {PLL_DRAM_MAIN_1066M_CLK, DRAM_PHYM_ALT_CLK_ROOT} + }, + {DRAM_CLK_ROOT, CCM_DRAM_CHANNEL, + {PLL_DRAM_MAIN_1066M_CLK, DRAM_ALT_CLK_ROOT} + }, + {DRAM_PHYM_ALT_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_SYS_MAIN_480M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD7_CLK, + PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK} + }, + {DRAM_ALT_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_SYS_MAIN_480M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_ENET_MAIN_250M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_AUDIO_MAIN_CLK, PLL_SYS_PFD2_270M_CLK} + }, + {USB_HSIC_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_USB_MAIN_480M_CLK, + PLL_SYS_PFD3_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD5_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {PCIE_CTRL_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_250M_CLK, PLL_SYS_MAIN_240M_CLK, + PLL_SYS_PFD2_270M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_SYS_PFD6_CLK} + }, + {PCIE_PHY_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_ENET_MAIN_500M_CLK, + EXT_CLK_1, EXT_CLK_2, EXT_CLK_3, + EXT_CLK_4, PLL_SYS_PFD0_392M_CLK} + }, + {EPDC_PIXEL_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD1_332M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD5_CLK, PLL_SYS_PFD6_CLK, + PLL_SYS_PFD7_CLK, PLL_VIDEO_MAIN_CLK} + }, + {LCDIF_PIXEL_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD5_CLK, PLL_DRAM_MAIN_533M_CLK, + EXT_CLK_3, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {MIPI_DSI_EXTSER_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD5_CLK, PLL_SYS_PFD3_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD0_196M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_VIDEO_MAIN_CLK, PLL_AUDIO_MAIN_CLK} + }, + {MIPI_CSI_WARP_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD3_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD0_196M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_VIDEO_MAIN_CLK, PLL_AUDIO_MAIN_CLK} + }, + {MIPI_DPHY_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_PFD5_CLK, REF_1M_CLK, EXT_CLK_2, + PLL_VIDEO_MAIN_CLK, EXT_CLK_3} + }, + {SAI1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_2} + }, + {SAI2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_2} + }, + {SAI3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_3} + }, + {SPDIF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_125M_CLK, EXT_CLK_3} + }, + {ENET1_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_25M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, EXT_CLK_4} + }, + {ENET1_TIME_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_AUDIO_MAIN_CLK, + EXT_CLK_1, EXT_CLK_2, EXT_CLK_3, + EXT_CLK_4, PLL_VIDEO_MAIN_CLK} + }, + {ENET2_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_25M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, EXT_CLK_4} + }, + {ENET2_TIME_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_AUDIO_MAIN_CLK, + EXT_CLK_1, EXT_CLK_2, EXT_CLK_3, + EXT_CLK_4, PLL_VIDEO_MAIN_CLK} + }, + {ENET_PHY_REF_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_25M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_SYS_PFD3_CLK} + }, + {EIM_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_SYS_PFD2_270M_CLK, PLL_SYS_PFD3_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {NAND_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_PFD0_392M_CLK, PLL_SYS_PFD3_CLK, PLL_ENET_MAIN_500M_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {QSPI_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD4_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD3_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {USDHC1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {USDHC2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {USDHC3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD0_392M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD4_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD6_CLK, PLL_SYS_PFD7_CLK} + }, + {CAN1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_ENET_MAIN_40M_CLK, PLL_USB_MAIN_480M_CLK, + EXT_CLK_1, EXT_CLK_4} + }, + {CAN2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_SYS_MAIN_480M_CLK, PLL_ENET_MAIN_40M_CLK, PLL_USB_MAIN_480M_CLK, + EXT_CLK_1, EXT_CLK_3} + }, + {I2C1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {I2C2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {I2C3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {I2C4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_120M_CLK, PLL_ENET_MAIN_50M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_AUDIO_MAIN_CLK, PLL_VIDEO_MAIN_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_PFD2_135M_CLK} + }, + {UART1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {UART2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_3, PLL_USB_MAIN_480M_CLK} + }, + {UART3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {UART4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_3, PLL_USB_MAIN_480M_CLK} + }, + {UART5_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {UART6_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_3, PLL_USB_MAIN_480M_CLK} + }, + {UART7_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_480M_CLK, EXT_CLK_2, + EXT_CLK_4, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {ECSPI4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_ENET_MAIN_40M_CLK, + PLL_SYS_MAIN_120M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_PFD4_CLK, + PLL_ENET_MAIN_250M_CLK, PLL_USB_MAIN_480M_CLK} + }, + {PWM1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_1, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {PWM2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_1, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {PWM3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_2, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {PWM4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_2, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {FLEXTIMER1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_3, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {FLEXTIMER2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_AUDIO_MAIN_CLK, EXT_CLK_3, + REF_1M_CLK, PLL_VIDEO_MAIN_CLK} + }, + {SIM1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_USB_MAIN_480M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_SYS_PFD7_CLK} + }, + {SIM2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_USB_MAIN_480M_CLK, PLL_VIDEO_MAIN_CLK, + PLL_ENET_MAIN_125M_CLK, PLL_SYS_PFD7_CLK} + }, + {GPT1_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_1} + }, + {GPT2_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_2} + }, + {GPT3_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_3} + }, + {GPT4_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_100M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_ENET_MAIN_40M_CLK, PLL_VIDEO_MAIN_CLK, REF_1M_CLK, + PLL_AUDIO_MAIN_CLK, EXT_CLK_4} + }, + {TRACE_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, + EXT_CLK_1, EXT_CLK_3} + }, + {WDOG_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_USB_MAIN_480M_CLK, + REF_1M_CLK, PLL_SYS_PFD1_166M_CLK} + }, + {CSI_MCLK_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {AUDIO_MCLK_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_PFD2_135M_CLK, PLL_SYS_MAIN_120M_CLK, + PLL_DRAM_MAIN_533M_CLK, PLL_ENET_MAIN_125M_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, PLL_USB_MAIN_480M_CLK} + }, + {WRCLK_CLK_ROOT, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_ENET_MAIN_40M_CLK, PLL_DRAM_MAIN_533M_CLK, + PLL_USB_MAIN_480M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_SYS_PFD2_270M_CLK, + PLL_ENET_MAIN_500M_CLK, PLL_SYS_PFD7_CLK} + }, + {IPP_DO_CLKO1, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_480M_CLK, PLL_SYS_MAIN_240M_CLK, + PLL_SYS_PFD0_196M_CLK, PLL_SYS_PFD3_CLK, PLL_ENET_MAIN_500M_CLK, + PLL_DRAM_MAIN_533M_CLK, REF_1M_CLK} + }, + {IPP_DO_CLKO2, CCM_IP_CHANNEL, + {OSC_24M_CLK, PLL_SYS_MAIN_240M_CLK, PLL_SYS_PFD0_392M_CLK, + PLL_SYS_PFD1_166M_CLK, PLL_SYS_PFD4_CLK, PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, OSC_32K_CLK} + }, +}; + +/* select which entry of root_array */ +static int select(enum clk_root_index clock_id) +{ + int i, size; + struct clk_root_map *p = root_array; + + size = ARRAY_SIZE(root_array); + + for (i = 0; i < size; i++, p++) { + if (clock_id == p->entry) + return i; + } + + return -EINVAL; +} + +static int src_supported(int entry, enum clk_root_src clock_src) +{ + int i, size; + struct clk_root_map *p = &root_array[entry]; + + if ((p->type == CCM_DRAM_PHYM_CHANNEL) || (p->type == CCM_DRAM_CHANNEL)) + size = 2; + else + size = 8; + + for (i = 0; i < size; i++) { + if (p->src_mux[i] == clock_src) + return i; + } + + return -EINVAL; +} + +/* Set src for clock root slice. */ +int clock_set_src(enum clk_root_index clock_id, enum clk_root_src clock_src) +{ + int root_entry, src_entry; + u32 reg; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + src_entry = src_supported(root_entry, clock_src); + if (src_entry < 0) + return -EINVAL; + + reg = __raw_readl(&imx_ccm->root[clock_id].target_root); + reg &= ~CLK_ROOT_MUX_MASK; + reg |= src_entry << CLK_ROOT_MUX_SHIFT; + __raw_writel(reg, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +/* Get src of a clock root slice. */ +int clock_get_src(enum clk_root_index clock_id, enum clk_root_src *p_clock_src) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + val &= CLK_ROOT_MUX_MASK; + val >>= CLK_ROOT_MUX_SHIFT; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + *p_clock_src = p->src_mux[val]; + + return 0; +} + +int clock_set_prediv(enum clk_root_index clock_id, enum root_pre_div pre_div) +{ + int root_entry; + struct clk_root_map *p; + u32 reg; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type == CCM_CORE_CHANNEL) || + (p->type == CCM_DRAM_PHYM_CHANNEL) || + (p->type == CCM_DRAM_CHANNEL)) { + if (pre_div != CLK_ROOT_PRE_DIV1) { + printf("Error pre div!\n"); + return -EINVAL; + } + } + + reg = __raw_readl(&imx_ccm->root[clock_id].target_root); + reg &= ~CLK_ROOT_PRE_DIV_MASK; + reg |= pre_div << CLK_ROOT_PRE_DIV_SHIFT; + __raw_writel(reg, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_get_prediv(enum clk_root_index clock_id, enum root_pre_div *pre_div) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type == CCM_CORE_CHANNEL) || + (p->type == CCM_DRAM_PHYM_CHANNEL) || + (p->type == CCM_DRAM_CHANNEL)) { + *pre_div = 0; + return 0; + } + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + val &= CLK_ROOT_PRE_DIV_MASK; + val >>= CLK_ROOT_PRE_DIV_SHIFT; + + *pre_div = val; + + return 0; +} + +int clock_set_postdiv(enum clk_root_index clock_id, enum root_post_div div) +{ + u32 reg; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + if (clock_id == DRAM_PHYM_CLK_ROOT) { + if (div != CLK_ROOT_POST_DIV1) { + printf("Error post div!\n"); + return -EINVAL; + } + } + + /* Only 3 bit post div. */ + if ((clock_id == DRAM_CLK_ROOT) && (div > CLK_ROOT_POST_DIV7)) { + printf("Error post div!\n"); + return -EINVAL; + } + + reg = __raw_readl(&imx_ccm->root[clock_id].target_root); + reg &= ~CLK_ROOT_POST_DIV_MASK; + reg |= div << CLK_ROOT_POST_DIV_SHIFT; + __raw_writel(reg, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_get_postdiv(enum clk_root_index clock_id, enum root_post_div *div) +{ + u32 val; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + if (clock_id == DRAM_PHYM_CLK_ROOT) { + *div = 0; + return 0; + } + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + if (clock_id == DRAM_CLK_ROOT) + val &= DRAM_CLK_ROOT_POST_DIV_MASK; + else + val &= CLK_ROOT_POST_DIV_MASK; + val >>= CLK_ROOT_POST_DIV_SHIFT; + + *div = val; + + return 0; +} + +int clock_set_autopostdiv(enum clk_root_index clock_id, enum root_auto_div div, + int auto_en) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type != CCM_BUS_CHANNEL) && (p->type != CCM_AHB_CHANNEL)) { + printf("Auto postdiv not supported.!\n"); + return -EINVAL; + } + + /* + * Each time only one filed can be changed, no use target_root_set. + */ + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + val &= ~CLK_ROOT_AUTO_DIV_MASK; + val |= (div << CLK_ROOT_AUTO_DIV_SHIFT); + + if (auto_en) + val |= CLK_ROOT_AUTO_EN; + else + val &= ~CLK_ROOT_AUTO_EN; + + __raw_writel(val, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_get_autopostdiv(enum clk_root_index clock_id, enum root_auto_div *div, + int *auto_en) +{ + u32 val; + int root_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + /* + * Only bus/ahb channel supports auto div. + * If unsupported, just set auto_en and div with 0. + */ + if ((p->type != CCM_BUS_CHANNEL) && (p->type != CCM_AHB_CHANNEL)) { + *auto_en = 0; + *div = 0; + return 0; + } + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + if ((val & CLK_ROOT_AUTO_EN_MASK) == 0) + *auto_en = 0; + else + *auto_en = 1; + + val &= CLK_ROOT_AUTO_DIV_MASK; + val >>= CLK_ROOT_AUTO_DIV_SHIFT; + + *div = val; + + return 0; +} + +int clock_get_target_val(enum clk_root_index clock_id, u32 *val) +{ + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + *val = __raw_readl(&imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_set_target_val(enum clk_root_index clock_id, u32 val) +{ + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + __raw_writel(val, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +/* Auto_div and auto_en is ignored, they are rarely used. */ +int clock_root_cfg(enum clk_root_index clock_id, enum root_pre_div pre_div, + enum root_post_div post_div, enum clk_root_src clock_src) +{ + u32 val; + int root_entry, src_entry; + struct clk_root_map *p; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + root_entry = select(clock_id); + if (root_entry < 0) + return -EINVAL; + + p = &root_array[root_entry]; + + if ((p->type == CCM_CORE_CHANNEL) || + (p->type == CCM_DRAM_PHYM_CHANNEL) || + (p->type == CCM_DRAM_CHANNEL)) { + if (pre_div != CLK_ROOT_PRE_DIV1) { + printf("Error pre div!\n"); + return -EINVAL; + } + } + + /* Only 3 bit post div. */ + if (p->type == CCM_DRAM_CHANNEL) { + if (post_div > CLK_ROOT_POST_DIV7) { + printf("Error post div!\n"); + return -EINVAL; + } + } + + if (p->type == CCM_DRAM_PHYM_CHANNEL) { + if (post_div != CLK_ROOT_POST_DIV1) { + printf("Error post div!\n"); + return -EINVAL; + } + } + + src_entry = src_supported(root_entry, clock_src); + if (src_entry < 0) + return -EINVAL; + + val = CLK_ROOT_ON | pre_div << CLK_ROOT_PRE_DIV_SHIFT | + post_div << CLK_ROOT_POST_DIV_SHIFT | + src_entry << CLK_ROOT_MUX_SHIFT; + + __raw_writel(val, &imx_ccm->root[clock_id].target_root); + + return 0; +} + +int clock_root_enabled(enum clk_root_index clock_id) +{ + u32 val; + + if (clock_id >= CLK_ROOT_MAX) + return -EINVAL; + + /* + * No enable bit for DRAM controller and PHY. Just return enabled. + */ + if ((clock_id == DRAM_PHYM_CLK_ROOT) || (clock_id == DRAM_CLK_ROOT)) + return 1; + + val = __raw_readl(&imx_ccm->root[clock_id].target_root); + + return (val & CLK_ROOT_ENABLE_MASK) ? 1 : 0; +} + +/* CCGR gate operation */ +int clock_enable(enum clk_ccgr_index index, bool enable) +{ + if (index >= CCGR_MAX) + return -EINVAL; + + if (enable) + __raw_writel(CCM_CLK_ON_MSK, + &imx_ccm->ccgr_array[index].ccgr_set); + else + __raw_writel(CCM_CLK_ON_MSK, + &imx_ccm->ccgr_array[index].ccgr_clr); + + return 0; +} diff --git a/arch/arm/include/asm/arch-mx7/clock.h b/arch/arm/include/asm/arch-mx7/clock.h new file mode 100644 index 0000000..688d236 --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/clock.h @@ -0,0 +1,348 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_CLOCK_H +#define _ASM_ARCH_CLOCK_H + +#include <common.h> +#include <asm/arch/crm_regs.h> + +#ifdef CONFIG_SYS_MX7_HCLK +#define MXC_HCLK CONFIG_SYS_MX7_HCLK +#else +#define MXC_HCLK 24000000 +#endif + +#ifdef CONFIG_SYS_MX7_CLK32 +#define MXC_CLK32 CONFIG_SYS_MX7_CLK32 +#else +#define MXC_CLK32 32768 +#endif + +/* Mainly for compatible to imx common code. */ +enum mxc_clock { + MXC_ARM_CLK = 0, + MXC_AHB_CLK, + MXC_IPG_CLK, + MXC_UART_CLK, + MXC_CSPI_CLK, + MXC_AXI_CLK, + MXC_DDR_CLK, + MXC_ESDHC_CLK, + MXC_ESDHC2_CLK, + MXC_ESDHC3_CLK, + MXC_I2C_CLK, +}; + +/* PLL supported by i.mx7d */ +enum pll_clocks { + PLL_CORE, /* Core PLL */ + PLL_SYS, /* System PLL*/ + PLL_ENET, /* Enet PLL */ + PLL_AUDIO, /* Audio PLL */ + PLL_VIDEO, /* Video PLL*/ + PLL_DDR, /* Dram PLL */ + PLL_USB, /* USB PLL, fixed at 480MHZ */ +}; + +/* clk src for clock root gen */ +enum clk_root_src { + OSC_24M_CLK, + + PLL_ARM_MAIN_800M_CLK, + + PLL_SYS_MAIN_480M_CLK, + PLL_SYS_MAIN_240M_CLK, + PLL_SYS_MAIN_120M_CLK, + PLL_SYS_PFD0_392M_CLK, + PLL_SYS_PFD0_196M_CLK, + PLL_SYS_PFD1_332M_CLK, + PLL_SYS_PFD1_166M_CLK, + PLL_SYS_PFD2_270M_CLK, + PLL_SYS_PFD2_135M_CLK, + PLL_SYS_PFD3_CLK, + PLL_SYS_PFD4_CLK, + PLL_SYS_PFD5_CLK, + PLL_SYS_PFD6_CLK, + PLL_SYS_PFD7_CLK, + + PLL_ENET_MAIN_500M_CLK, + PLL_ENET_MAIN_250M_CLK, + PLL_ENET_MAIN_125M_CLK, + PLL_ENET_MAIN_100M_CLK, + PLL_ENET_MAIN_50M_CLK, + PLL_ENET_MAIN_40M_CLK, + PLL_ENET_MAIN_25M_CLK, + + PLL_DRAM_MAIN_1066M_CLK, + PLL_DRAM_MAIN_533M_CLK, + + PLL_AUDIO_MAIN_CLK, + PLL_VIDEO_MAIN_CLK, + + PLL_USB_MAIN_480M_CLK, /* fixed at 480MHZ */ + + EXT_CLK_1, + EXT_CLK_2, + EXT_CLK_3, + EXT_CLK_4, + + REF_1M_CLK, + OSC_32K_CLK, +}; + +/* + * Clock root index + */ +enum clk_root_index { + ARM_A7_CLK_ROOT = 0, + ARM_M4_CLK_ROOT = 1, + ARM_M0_CLK_ROOT = 2, + MAIN_AXI_CLK_ROOT = 16, + DISP_AXI_CLK_ROOT = 17, + ENET_AXI_CLK_ROOT = 18, + NAND_USDHC_BUS_CLK_ROOT = 19, + AHB_CLK_ROOT = 32, + DRAM_PHYM_CLK_ROOT = 48, + DRAM_CLK_ROOT = 49, + DRAM_PHYM_ALT_CLK_ROOT = 64, + DRAM_ALT_CLK_ROOT = 65, + USB_HSIC_CLK_ROOT = 66, + PCIE_CTRL_CLK_ROOT = 67, + PCIE_PHY_CLK_ROOT = 68, + EPDC_PIXEL_CLK_ROOT = 69, + LCDIF_PIXEL_CLK_ROOT = 70, + MIPI_DSI_EXTSER_CLK_ROOT = 71, + MIPI_CSI_WARP_CLK_ROOT = 72, + MIPI_DPHY_REF_CLK_ROOT = 73, + SAI1_CLK_ROOT = 74, + SAI2_CLK_ROOT = 75, + SAI3_CLK_ROOT = 76, + SPDIF_CLK_ROOT = 77, + ENET1_REF_CLK_ROOT = 78, + ENET1_TIME_CLK_ROOT = 79, + ENET2_REF_CLK_ROOT = 80, + ENET2_TIME_CLK_ROOT = 81, + ENET_PHY_REF_CLK_ROOT = 82, + EIM_CLK_ROOT = 83, + NAND_CLK_ROOT = 84, + QSPI_CLK_ROOT = 85, + USDHC1_CLK_ROOT = 86, + USDHC2_CLK_ROOT = 87, + USDHC3_CLK_ROOT = 88, + CAN1_CLK_ROOT = 89, + CAN2_CLK_ROOT = 90, + I2C1_CLK_ROOT = 91, + I2C2_CLK_ROOT = 92, + I2C3_CLK_ROOT = 93, + I2C4_CLK_ROOT = 94, + UART1_CLK_ROOT = 95, + UART2_CLK_ROOT = 96, + UART3_CLK_ROOT = 97, + UART4_CLK_ROOT = 98, + UART5_CLK_ROOT = 99, + UART6_CLK_ROOT = 100, + UART7_CLK_ROOT = 101, + ECSPI1_CLK_ROOT = 102, + ECSPI2_CLK_ROOT = 103, + ECSPI3_CLK_ROOT = 104, + ECSPI4_CLK_ROOT = 105, + PWM1_CLK_ROOT = 106, + PWM2_CLK_ROOT = 107, + PWM3_CLK_ROOT = 108, + PWM4_CLK_ROOT = 109, + FLEXTIMER1_CLK_ROOT = 110, + FLEXTIMER2_CLK_ROOT = 111, + SIM1_CLK_ROOT = 112, + SIM2_CLK_ROOT = 113, + GPT1_CLK_ROOT = 114, + GPT2_CLK_ROOT = 115, + GPT3_CLK_ROOT = 116, + GPT4_CLK_ROOT = 117, + TRACE_CLK_ROOT = 118, + WDOG_CLK_ROOT = 119, + CSI_MCLK_CLK_ROOT = 120, + AUDIO_MCLK_CLK_ROOT = 121, + WRCLK_CLK_ROOT = 122, + IPP_DO_CLKO1 = 123, + IPP_DO_CLKO2 = 124, + + CLK_ROOT_MAX, +}; + +struct clk_root_setting { + enum clk_root_index root; + u32 setting; +}; + +/* + * CCGR mapping + */ +enum clk_ccgr_index { + CCGR_CPU = 0, + CCGR_M4 = 1, + CCGR_SIM_MAIN = 4, + CCGR_SIM_DISPLAY = 5, + CCGR_SIM_ENET = 6, + CCGR_SIM_M = 7, + CCGR_SIM_S = 8, + CCGR_SIM_WAKEUP = 9, + CCGR_IPMUX1 = 10, + CCGR_IPMUX2 = 11, + CCGR_IPMUX3 = 12, + CCGR_ROM = 16, + CCGR_OCRAM = 17, + CCGR_OCRAM_S = 18, + CCGR_DRAM = 19, + CCGR_RAWNAND = 20, + CCGR_QSPI = 21, + CCGR_WEIM = 22, + CCGR_ADC = 32, + CCGR_ANATOP = 33, + CCGR_SCTR = 34, + CCGR_OCOTP = 35, + CCGR_CAAM = 36, + CCGR_SNVS = 37, + CCGR_RDC = 38, + CCGR_MU = 39, + CCGR_HS = 40, + CCGR_DVFS = 41, + CCGR_QOS = 42, + CCGR_QOS_DISPMIX = 43, + CCGR_QOS_MEGAMIX = 44, + CCGR_CSU = 45, + CCGR_DBGMON = 46, + CCGR_DEBUG = 47, + CCGR_TRACE = 48, + CCGR_SEC_DEBUG = 49, + CCGR_SEMA1 = 64, + CCGR_SEMA2 = 65, + CCGR_PERFMON1 = 68, + CCGR_PERFMON2 = 69, + CCGR_SDMA = 72, + CCGR_CSI = 73, + CCGR_EPDC = 74, + CCGR_LCDIF = 75, + CCGR_PXP = 76, + CCGR_PCIE = 96, + CCGR_MIPI_CSI = 100, + CCGR_MIPI_DSI = 101, + CCGR_MIPI_MEM_PHY = 102, + CCGR_USB_CTRL = 104, + CCGR_USB_HSIC = 105, + CCGR_USB_PHY1 = 106, + CCGR_USB_PHY2 = 107, + CCGR_USDHC1 = 108, + CCGR_USDHC2 = 109, + CCGR_USDHC3 = 110, + CCGR_ENET1 = 112, + CCGR_ENET2 = 113, + CCGR_CAN1 = 116, + CCGR_CAN2 = 117, + CCGR_ECSPI1 = 120, + CCGR_ECSPI2 = 121, + CCGR_ECSPI3 = 122, + CCGR_ECSPI4 = 123, + CCGR_GPT1 = 124, + CCGR_GPT2 = 125, + CCGR_GPT3 = 126, + CCGR_GPT4 = 127, + CCGR_FTM1 = 128, + CCGR_FTM2 = 129, + CCGR_PWM1 = 132, + CCGR_PWM2 = 133, + CCGR_PWM3 = 134, + CCGR_PWM4 = 135, + CCGR_I2C1 = 136, + CCGR_I2C2 = 137, + CCGR_I2C3 = 138, + CCGR_I2C4 = 139, + CCGR_SAI1 = 140, + CCGR_SAI2 = 141, + CCGR_SAI3 = 142, + CCGR_SIM1 = 144, + CCGR_SIM2 = 145, + CCGR_UART1 = 148, + CCGR_UART2 = 149, + CCGR_UART3 = 150, + CCGR_UART4 = 151, + CCGR_UART5 = 152, + CCGR_UART6 = 153, + CCGR_UART7 = 154, + CCGR_WDOG1 = 156, + CCGR_WDOG2 = 157, + CCGR_WDOG3 = 158, + CCGR_WDOG4 = 159, + CCGR_GPIO1 = 160, + CCGR_GPIO2 = 161, + CCGR_GPIO3 = 162, + CCGR_GPIO4 = 163, + CCGR_GPIO5 = 164, + CCGR_GPIO6 = 165, + CCGR_GPIO7 = 166, + CCGR_IOMUX = 168, + CCGR_IOMUX_LPSR = 169, + CCGR_KPP = 170, + + CCGR_SKIP, + CCGR_MAX, +}; + +/* Clock root channel */ +enum clk_root_type { + CCM_CORE_CHANNEL, + CCM_BUS_CHANNEL, + CCM_AHB_CHANNEL, + CCM_DRAM_PHYM_CHANNEL, + CCM_DRAM_CHANNEL, + CCM_IP_CHANNEL, +}; + +#include <asm/arch/clock_slice.h> + +/* + * entry: the clock root index + * type: ccm channel + * src_mux: each entry corresponding to the clock src, detailed info in CCM RM + */ +struct clk_root_map { + enum clk_root_index entry; + enum clk_root_type type; + uint8_t src_mux[8]; +}; + +enum enet_freq { + ENET_25MHz, + ENET_50MHz, + ENET_125MHz, +}; + +u32 get_root_clk(enum clk_root_index clock_id); +u32 mxc_get_clock(enum mxc_clock clk); +u32 imx_get_uartclk(void); +u32 imx_get_fecclk(void); +void clock_init(void); +#ifdef CONFIG_SYS_I2C_MXC +int enable_i2c_clk(unsigned char enable, unsigned i2c_num); +#endif +#ifdef CONFIG_FEC_MXC +int set_clk_enet(enum enet_freq type); +#endif +int set_clk_qspi(void); +int set_clk_nand(void); +#ifdef CONFIG_MXC_OCOTP +void enable_ocotp_clk(unsigned char enable); +#endif +void enable_usboh3_clk(unsigned char enable); +#ifdef CONFIG_SECURE_BOOT +void hab_caam_clock_enable(unsigned char enable); +#endif +void mxs_set_lcdclk(uint32_t base_addr, uint32_t freq); +void enable_thermal_clk(void); +#endif diff --git a/arch/arm/include/asm/arch-mx7/clock_slice.h b/arch/arm/include/asm/arch-mx7/clock_slice.h new file mode 100644 index 0000000..6ede0cd --- /dev/null +++ b/arch/arm/include/asm/arch-mx7/clock_slice.h @@ -0,0 +1,116 @@ +/* + * Copyright (C) 2014-2015 Freescale Semiconductor, Inc. + * + * Author: + * Peng Fan Peng.Fan@freescale.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_CLOCK_SLICE_H +#define _ASM_ARCH_CLOCK_SLICE_H + +enum root_pre_div { + CLK_ROOT_PRE_DIV1 = 0, + CLK_ROOT_PRE_DIV2, + CLK_ROOT_PRE_DIV3, + CLK_ROOT_PRE_DIV4, + CLK_ROOT_PRE_DIV5, + CLK_ROOT_PRE_DIV6, + CLK_ROOT_PRE_DIV7, + CLK_ROOT_PRE_DIV8, +}; + +enum root_post_div { + CLK_ROOT_POST_DIV1 = 0, + CLK_ROOT_POST_DIV2, + CLK_ROOT_POST_DIV3, + CLK_ROOT_POST_DIV4, + CLK_ROOT_POST_DIV5, + CLK_ROOT_POST_DIV6, + CLK_ROOT_POST_DIV7, + CLK_ROOT_POST_DIV8, + CLK_ROOT_POST_DIV9, + CLK_ROOT_POST_DIV10, + CLK_ROOT_POST_DIV11, + CLK_ROOT_POST_DIV12, + CLK_ROOT_POST_DIV13, + CLK_ROOT_POST_DIV14, + CLK_ROOT_POST_DIV15, + CLK_ROOT_POST_DIV16, + CLK_ROOT_POST_DIV17, + CLK_ROOT_POST_DIV18, + CLK_ROOT_POST_DIV19, + CLK_ROOT_POST_DIV20, + CLK_ROOT_POST_DIV21, + CLK_ROOT_POST_DIV22, + CLK_ROOT_POST_DIV23, + CLK_ROOT_POST_DIV24, + CLK_ROOT_POST_DIV25, + CLK_ROOT_POST_DIV26, + CLK_ROOT_POST_DIV27, + CLK_ROOT_POST_DIV28, + CLK_ROOT_POST_DIV29, + CLK_ROOT_POST_DIV30, + CLK_ROOT_POST_DIV31, + CLK_ROOT_POST_DIV32, + CLK_ROOT_POST_DIV33, + CLK_ROOT_POST_DIV34, + CLK_ROOT_POST_DIV35, + CLK_ROOT_POST_DIV36, + CLK_ROOT_POST_DIV37, + CLK_ROOT_POST_DIV38, + CLK_ROOT_POST_DIV39, + CLK_ROOT_POST_DIV40, + CLK_ROOT_POST_DIV41, + CLK_ROOT_POST_DIV42, + CLK_ROOT_POST_DIV43, + CLK_ROOT_POST_DIV44, + CLK_ROOT_POST_DIV45, + CLK_ROOT_POST_DIV46, + CLK_ROOT_POST_DIV47, + CLK_ROOT_POST_DIV48, + CLK_ROOT_POST_DIV49, + CLK_ROOT_POST_DIV50, + CLK_ROOT_POST_DIV51, + CLK_ROOT_POST_DIV52, + CLK_ROOT_POST_DIV53, + CLK_ROOT_POST_DIV54, + CLK_ROOT_POST_DIV55, + CLK_ROOT_POST_DIV56, + CLK_ROOT_POST_DIV57, + CLK_ROOT_POST_DIV58, + CLK_ROOT_POST_DIV59, + CLK_ROOT_POST_DIV60, + CLK_ROOT_POST_DIV61, + CLK_ROOT_POST_DIV62, + CLK_ROOT_POST_DIV63, + CLK_ROOT_POST_DIV64, +}; + +enum root_auto_div { + CLK_ROOT_AUTO_DIV1 = 0, + CLK_ROOT_AUTO_DIV2, + CLK_ROOT_AUTO_DIV4, + CLK_ROOT_AUTO_DIV8, + CLK_ROOT_AUTO_DIV16, +}; + +int clock_set_src(enum clk_root_index clock_id, enum clk_root_src clock_src); +int clock_get_src(enum clk_root_index clock_id, enum clk_root_src *p_clock_src); +int clock_set_prediv(enum clk_root_index clock_id, enum root_pre_div pre_div); +int clock_get_prediv(enum clk_root_index clock_id, enum root_pre_div *pre_div); +int clock_set_postdiv(enum clk_root_index clock_id, enum root_post_div div); +int clock_get_postdiv(enum clk_root_index clock_id, enum root_post_div *div); +int clock_set_autopostdiv(enum clk_root_index clock_id, enum root_auto_div div, + int auto_en); +int clock_get_autopostdiv(enum clk_root_index clock_id, enum root_auto_div *div, + int *auto_en); +int clock_get_target_val(enum clk_root_index clock_id, u32 *val); +int clock_set_target_val(enum clk_root_index clock_id, u32 val); +int clock_root_cfg(enum clk_root_index clock_id, enum root_pre_div pre_div, + enum root_post_div post_div, enum clk_root_src clock_src); +int clock_root_enabled(enum clk_root_index clock_id); + +int clock_enable(enum clk_ccgr_index index, bool enable); +#endif
Add imx7d basic SoC system support Misc arch dependent functions for system bring up
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Ye.Li B37916@freescale.com --- Changes for V2: Split from patch imx: imx7d: initial arch level support Changes for V3 - V5: Resend Changes for V6: - Remove set_epdc_qos, epdc support to be added in separate patch - Rework to reuse common code (cache settins, common init settings) - Add temp and speed get helper functions Changes for V7: Resend
arch/arm/cpu/armv7/mx7/soc.c | 269 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-imx/cpu.h | 2 + arch/arm/include/asm/imx-common/boot_mode.h | 21 +++ 3 files changed, 292 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/soc.c
diff --git a/arch/arm/cpu/armv7/mx7/soc.c b/arch/arm/cpu/armv7/mx7/soc.c new file mode 100644 index 0000000..8d50149 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/soc.c @@ -0,0 +1,269 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/imx-common/dma.h> +#include <asm/arch/crm_regs.h> +#include <dm.h> +#include <imx_thermal.h> + +struct src *src_reg = (struct src *)SRC_BASE_ADDR; + +#if defined(CONFIG_IMX_THERMAL) +static const struct imx_thermal_plat imx7_thermal_plat = { + .regs = (void *)ANATOP_BASE_ADDR, + .fuse_bank = 3, + .fuse_word = 3, +}; + +U_BOOT_DEVICE(imx7_thermal) = { + .name = "imx_thermal", + .platdata = &imx7_thermal_plat, +}; +#endif + +/* + * OCOTP_TESTER3[9:8] (see Fusemap Description Table offset 0x440) + * defines a 2-bit SPEED_GRADING + */ +#define OCOTP_TESTER3_SPEED_SHIFT 8 +#define OCOTP_TESTER3_SPEED_800MHZ 0 +#define OCOTP_TESTER3_SPEED_850MHZ 1 +#define OCOTP_TESTER3_SPEED_1GHZ 2 + +u32 get_cpu_speed_grade_hz(void) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + uint32_t val; + + val = readl(&fuse->tester3); + val >>= OCOTP_TESTER3_SPEED_SHIFT; + val &= 0x3; + + switch(val) { + case OCOTP_TESTER3_SPEED_800MHZ: + return 792000000; + case OCOTP_TESTER3_SPEED_850MHZ: + return 852000000; + case OCOTP_TESTER3_SPEED_1GHZ: + return 996000000; + } + return 0; +} + +/* + * OCOTP_TESTER3[7:6] (see Fusemap Description Table offset 0x440) + * defines a 2-bit SPEED_GRADING + */ +#define OCOTP_TESTER3_TEMP_SHIFT 6 + +u32 get_cpu_temp_grade(int *minc, int *maxc) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + uint32_t val; + + val = readl(&fuse->tester3); + val >>= OCOTP_TESTER3_TEMP_SHIFT; + val &= 0x3; + + if (minc && maxc) { + if ( val == TEMP_AUTOMOTIVE) { + *minc = -40; + *maxc = 125; + } else if (val == TEMP_INDUSTRIAL) { + *minc = -40; + *maxc = 105; + } else if (val == TEMP_EXTCOMMERCIAL) { + *minc = -20; + *maxc = 105; + } else { + *minc = 0; + *maxc = 95; + } + } + return val; +} + +u32 get_cpu_rev(void) +{ + struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) + ANATOP_BASE_ADDR; + u32 reg = readl(&ccm_anatop->digprog); + u32 type = (reg >> 16) & 0xff; + + reg &= 0xff; + return (type << 12) | reg; +} + +#ifdef CONFIG_REVISION_TAG +u32 __weak get_board_rev(void) +{ + return get_cpu_rev(); +} +#endif + +int arch_cpu_init(void) +{ + init_aips(); + + /* Disable PDE bit of WMCR register */ + imx_set_wdog_powerdown(false); + +#ifdef CONFIG_APBH_DMA + /* Start APBH DMA */ + mxs_dma_init(); +#endif + + return 0; +} + +#ifdef CONFIG_SERIAL_TAG +void get_board_serial(struct tag_serialnr *serialnr) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[0]; + struct fuse_bank0_regs *fuse = + (struct fuse_bank0_regs *)bank->fuse_regs; + + serialnr->low = fuse->tester0; + serialnr->high = fuse->tester1; +} +#endif + +#if defined(CONFIG_FEC_MXC) +void imx_get_mac_from_fuse(int dev_id, unsigned char *mac) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[9]; + struct fuse_bank9_regs *fuse = + (struct fuse_bank9_regs *)bank->fuse_regs; + + if (0 == dev_id) { + u32 value = readl(&fuse->mac_addr1); + mac[0] = (value >> 8); + mac[1] = value; + + value = readl(&fuse->mac_addr0); + mac[2] = value >> 24; + mac[3] = value >> 16; + mac[4] = value >> 8; + mac[5] = value; + } else { + u32 value = readl(&fuse->mac_addr2); + mac[0] = value >> 24; + mac[1] = value >> 16; + mac[2] = value >> 8; + mac[3] = value; + + value = readl(&fuse->mac_addr1); + mac[4] = value >> 24; + mac[5] = value >> 16; + } +} +#endif + +void set_wdog_reset(struct wdog_regs *wdog) +{ + u32 reg = readw(&wdog->wcr); + /* + * Output WDOG_B signal to reset external pmic or POR_B decided by + * the board desgin. Without external reset, the peripherals/DDR/ + * PMIC are not reset, that may cause system working abnormal. + */ + reg = readw(&wdog->wcr); + reg |= 1 << 3; + /* + * WDZST bit is write-once only bit. Align this bit in kernel, + * otherwise kernel code will have no chance to set this bit. + */ + reg |= 1 << 0; + writew(reg, &wdog->wcr); +} + +/* + * cfg_val will be used for + * Boot_cfg4[7:0]:Boot_cfg3[7:0]:Boot_cfg2[7:0]:Boot_cfg1[7:0] + * After reset, if GPR10[28] is 1, ROM will copy GPR9[25:0] + * to SBMR1, which will determine the boot device. + */ +const struct boot_mode soc_boot_modes[] = { + {"ecspi1:0", MAKE_CFGVAL(0x00, 0x60, 0x00, 0x00)}, + {"ecspi1:1", MAKE_CFGVAL(0x40, 0x62, 0x00, 0x00)}, + {"ecspi1:2", MAKE_CFGVAL(0x80, 0x64, 0x00, 0x00)}, + {"ecspi1:3", MAKE_CFGVAL(0xc0, 0x66, 0x00, 0x00)}, + + {"weim", MAKE_CFGVAL(0x00, 0x50, 0x00, 0x00)}, + {"qspi1", MAKE_CFGVAL(0x10, 0x40, 0x00, 0x00)}, + /* 4 bit bus width */ + {"usdhc1", MAKE_CFGVAL(0x10, 0x10, 0x00, 0x00)}, + {"usdhc2", MAKE_CFGVAL(0x10, 0x14, 0x00, 0x00)}, + {"usdhc3", MAKE_CFGVAL(0x10, 0x18, 0x00, 0x00)}, + {"mmc1", MAKE_CFGVAL(0x10, 0x20, 0x00, 0x00)}, + {"mmc2", MAKE_CFGVAL(0x10, 0x24, 0x00, 0x00)}, + {"mmc3", MAKE_CFGVAL(0x10, 0x28, 0x00, 0x00)}, + {NULL, 0}, +}; + +enum boot_device get_boot_device(void) +{ + struct bootrom_sw_info **p = + (struct bootrom_sw_info **)ROM_SW_INFO_ADDR; + + enum boot_device boot_dev = SD1_BOOT; + u8 boot_type = (*p)->boot_dev_type; + u8 boot_instance = (*p)->boot_dev_instance; + + switch (boot_type) { + case BOOT_TYPE_SD: + boot_dev = boot_instance + SD1_BOOT; + break; + case BOOT_TYPE_MMC: + boot_dev = boot_instance + MMC1_BOOT; + break; + case BOOT_TYPE_NAND: + boot_dev = NAND_BOOT; + break; + case BOOT_TYPE_QSPI: + boot_dev = QSPI_BOOT; + break; + case BOOT_TYPE_WEIM: + boot_dev = WEIM_NOR_BOOT; + break; + case BOOT_TYPE_SPINOR: + boot_dev = SPI_NOR_BOOT; + break; + default: + break; + } + + return boot_dev; +} + +void s_init(void) +{ +#if !defined CONFIG_SPL_BUILD + /* Enable SMP mode for CPU0, by setting bit 6 of Auxiliary Ctl reg */ + asm volatile( + "mrc p15, 0, r0, c1, c0, 1\n" + "orr r0, r0, #1 << 6\n" + "mcr p15, 0, r0, c1, c0, 1\n"); +#endif + /* clock configuration. */ + clock_init(); + + return; +} diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index 708f13d..f7451bf 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -21,8 +21,10 @@ #define MXC_CPU_MX6D 0x67 #define MXC_CPU_MX6DP 0x68 #define MXC_CPU_MX6QP 0x69 +#define MXC_CPU_MX7D 0x72
#define MXC_SOC_MX6 0x60 +#define MXC_SOC_MX7 0x70
#define CS0_128 0 #define CS0_64M_CS1_64M 1 diff --git a/arch/arm/include/asm/imx-common/boot_mode.h b/arch/arm/include/asm/imx-common/boot_mode.h index de0205c..a8239f2 100644 --- a/arch/arm/include/asm/imx-common/boot_mode.h +++ b/arch/arm/include/asm/imx-common/boot_mode.h @@ -9,6 +9,27 @@ #define MAKE_CFGVAL(cfg1, cfg2, cfg3, cfg4) \ ((cfg4) << 24) | ((cfg3) << 16) | ((cfg2) << 8) | (cfg1)
+enum boot_device { + WEIM_NOR_BOOT, + ONE_NAND_BOOT, + PATA_BOOT, + SATA_BOOT, + I2C_BOOT, + SPI_NOR_BOOT, + SD1_BOOT, + SD2_BOOT, + SD3_BOOT, + SD4_BOOT, + MMC1_BOOT, + MMC2_BOOT, + MMC3_BOOT, + MMC4_BOOT, + NAND_BOOT, + QSPI_BOOT, + UNKNOWN_BOOT, + BOOT_DEV_NUM = UNKNOWN_BOOT, +}; + struct boot_mode { const char *name; unsigned cfg_val;
Extend init_aips to support imx7 SoC, use is_soc_type and is_cpu_type to resolve at run time aips3 settings
Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Resend
arch/arm/imx-common/init.c | 44 ++++++++++++++++++++------------------------ 1 file changed, 20 insertions(+), 24 deletions(-)
diff --git a/arch/arm/imx-common/init.c b/arch/arm/imx-common/init.c index f7ed038..f1d4314 100644 --- a/arch/arm/imx-common/init.c +++ b/arch/arm/imx-common/init.c @@ -13,16 +13,11 @@
void init_aips(void) { - struct aipstz_regs *aips1, *aips2; -#ifdef CONFIG_MX6SX - struct aipstz_regs *aips3; -#endif + struct aipstz_regs *aips1, *aips2, *aips3;
aips1 = (struct aipstz_regs *)AIPS1_BASE_ADDR; aips2 = (struct aipstz_regs *)AIPS2_BASE_ADDR; -#ifdef CONFIG_MX6SX aips3 = (struct aipstz_regs *)AIPS3_BASE_ADDR; -#endif
/* * Set all MPROTx to be non-bufferable, trusted for R/W, @@ -49,25 +44,26 @@ void init_aips(void) writel(0x00000000, &aips2->opacr3); writel(0x00000000, &aips2->opacr4);
-#ifdef CONFIG_MX6SX - /* - * Set all MPROTx to be non-bufferable, trusted for R/W, - * not forced to user-mode. - */ - writel(0x77777777, &aips3->mprot0); - writel(0x77777777, &aips3->mprot1); + if (is_cpu_type(MXC_CPU_MX6SX) || is_soc_type(MXC_SOC_MX7)) + { + /* + * Set all MPROTx to be non-bufferable, trusted for R/W, + * not forced to user-mode. + */ + writel(0x77777777, &aips3->mprot0); + writel(0x77777777, &aips3->mprot1);
- /* - * Set all OPACRx to be non-bufferable, not require - * supervisor privilege level for access,allow for - * write access and untrusted master access. - */ - writel(0x00000000, &aips3->opacr0); - writel(0x00000000, &aips3->opacr1); - writel(0x00000000, &aips3->opacr2); - writel(0x00000000, &aips3->opacr3); - writel(0x00000000, &aips3->opacr4); -#endif + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips3->opacr0); + writel(0x00000000, &aips3->opacr1); + writel(0x00000000, &aips3->opacr2); + writel(0x00000000, &aips3->opacr3); + writel(0x00000000, &aips3->opacr4); + } }
#define SRC_SCR_WARM_RESET_ENABLE 0
Rework imx_set_wdog_powerdown to be reused by imx6 and imx7
Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Rework for common sys_proto header file
arch/arm/cpu/armv7/mx6/soc.c | 14 -------------- arch/arm/imx-common/init.c | 21 +++++++++++++++++++++ arch/arm/include/asm/imx-common/sys_proto.h | 1 + 3 files changed, 22 insertions(+), 14 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 06f63da..282302b 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -250,20 +250,6 @@ static int set_ldo_voltage(enum ldo_reg ldo, u32 mv) return 0; }
-static void imx_set_wdog_powerdown(bool enable) -{ - struct wdog_regs *wdog1 = (struct wdog_regs *)WDOG1_BASE_ADDR; - struct wdog_regs *wdog2 = (struct wdog_regs *)WDOG2_BASE_ADDR; - struct wdog_regs *wdog3 = (struct wdog_regs *)WDOG3_BASE_ADDR; - - if (is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL)) - writew(enable, &wdog3->wmcr); - - /* Write to the PDE (Power Down Enable) bit */ - writew(enable, &wdog1->wmcr); - writew(enable, &wdog2->wmcr); -} - static void set_ahb_rate(u32 val) { struct mxc_ccm_reg *mxc_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; diff --git a/arch/arm/imx-common/init.c b/arch/arm/imx-common/init.c index f1d4314..56d5010 100644 --- a/arch/arm/imx-common/init.c +++ b/arch/arm/imx-common/init.c @@ -66,6 +66,27 @@ void init_aips(void) } }
+void imx_set_wdog_powerdown(bool enable) +{ + struct wdog_regs *wdog1 = (struct wdog_regs *)WDOG1_BASE_ADDR; + struct wdog_regs *wdog2 = (struct wdog_regs *)WDOG2_BASE_ADDR; + struct wdog_regs *wdog3 = (struct wdog_regs *)WDOG3_BASE_ADDR; +#ifdef CONFIG_MX7D + struct wdog_regs *wdog4 = (struct wdog_regs *)WDOG4_BASE_ADDR; +#endif + + /* Write to the PDE (Power Down Enable) bit */ + writew(enable, &wdog1->wmcr); + writew(enable, &wdog2->wmcr); + + if (is_cpu_type(MXC_CPU_MX6SX) || is_cpu_type(MXC_CPU_MX6UL) || + is_soc_type(MXC_SOC_MX7)) + writew(enable, &wdog3->wmcr); +#ifdef CONFIG_MX7D + writew(enable, &wdog4->wmcr); +#endif +} + #define SRC_SCR_WARM_RESET_ENABLE 0
void init_src(void) diff --git a/arch/arm/include/asm/imx-common/sys_proto.h b/arch/arm/include/asm/imx-common/sys_proto.h index fda126b..1ffdec0 100644 --- a/arch/arm/include/asm/imx-common/sys_proto.h +++ b/arch/arm/include/asm/imx-common/sys_proto.h @@ -37,6 +37,7 @@ void set_chipselect_size(int const);
void init_aips(void); void init_src(void); +void imx_set_wdog_powerdown(bool enable);
/* * Initializes on-chip ethernet controllers.
Add imx7 SoC thermal driver support
Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: Fix build error for missin macro check ;P Changes for V3: Resend
drivers/thermal/imx_thermal.c | 90 ++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 84 insertions(+), 6 deletions(-)
diff --git a/drivers/thermal/imx_thermal.c b/drivers/thermal/imx_thermal.c index d90874e..ca35be8 100644 --- a/drivers/thermal/imx_thermal.c +++ b/drivers/thermal/imx_thermal.c @@ -25,6 +25,9 @@ #define FACTOR1 15976 #define FACTOR2 4297157 #define MEASURE_FREQ 327 +#define TEMPERATURE_MIN -40 +#define TEMPERATURE_HOT 85 +#define TEMPERATURE_MAX 125
#define TEMPSENSE0_TEMP_CNT_SHIFT 8 #define TEMPSENSE0_TEMP_CNT_MASK (0xfff << TEMPSENSE0_TEMP_CNT_SHIFT) @@ -41,7 +44,8 @@ struct thermal_data { int maxc; };
-static int read_cpu_temperature_mx6(struct udevice *dev) +#if defined(CONFIG_MX6) +static int read_cpu_temperature(struct udevice *dev) { int temperature; unsigned int reg, n_meas; @@ -123,21 +127,87 @@ static int read_cpu_temperature_mx6(struct udevice *dev)
return temperature; } +#elif defined(CONFIG_MX7) +static int read_cpu_temperature(struct udevice *dev) +{ + unsigned int reg, tmp, start; + unsigned int raw_25c, te1; + int temperature; + unsigned int *priv = dev_get_priv(dev); + u32 fuse = *priv; + struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) + ANATOP_BASE_ADDR; + /* + * fuse data layout: + * [31:21] sensor value @ 25C + * [20:18] hot temperature value + * [17:9] sensor value of room + * [8:0] sensor value of hot + */ + + raw_25c = fuse >> 21; + if (raw_25c == 0) + raw_25c = 25; + + te1 = (fuse >> 9) & 0x1ff; + + /* + * now we only use single measure, every time we read + * the temperature, we will power on/down anadig thermal + * module + */ + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_MASK, &ccm_anatop->tempsense1_clr); + writel(PMU_REF_REFTOP_SELFBIASOFF_MASK, &ccm_anatop->ref_set); + + /* write measure freq */ + reg = readl(&ccm_anatop->tempsense1); + reg &= ~TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ_MASK; + reg |= TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_FREQ(MEASURE_FREQ); + writel(reg, &ccm_anatop->tempsense1); + + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_MASK, &ccm_anatop->tempsense1_clr); + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_MASK, &ccm_anatop->tempsense1_clr); + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_MEASURE_TEMP_MASK, &ccm_anatop->tempsense1_set); + + start = get_timer(0); + /* Wait max 100ms */ + do { + /* + * Since we can not rely on finish bit, use 1ms delay to get + * temperature. From RM, 17us is enough to get data, but + * to gurantee to get the data, delay 100ms here. + */ + reg = readl(&ccm_anatop->tempsense1); + tmp = (reg & TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_MASK) + >> TEMPMON_HW_ANADIG_TEMPSENSE1_TEMP_VALUE_SHIFT; + } while (get_timer(0) < (start + 100)); + + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_FINISHED_MASK, &ccm_anatop->tempsense1_clr); + + /* power down anatop thermal sensor */ + writel(TEMPMON_HW_ANADIG_TEMPSENSE1_POWER_DOWN_MASK, &ccm_anatop->tempsense1_set); + writel(PMU_REF_REFTOP_SELFBIASOFF_MASK, &ccm_anatop->ref_clr); + + /* Single point */ + temperature = tmp - (te1 - raw_25c); + + return temperature; +} +#endif
int imx_thermal_get_temp(struct udevice *dev, int *temp) { struct thermal_data *priv = dev_get_priv(dev); int cpu_tmp = 0;
- if (is_soc_type(MXC_SOC_MX6)) - cpu_tmp = read_cpu_temperature_mx6(dev); + cpu_tmp = read_cpu_temperature(dev); + while (cpu_tmp >= priv->critical) { printf("CPU Temperature (%dC) too close to max (%dC)", cpu_tmp, priv->maxc); puts(" waiting...\n"); udelay(5000000); - if (is_soc_type(MXC_SOC_MX6)) - cpu_tmp = read_cpu_temperature_mx6(dev); + cpu_tmp = read_cpu_temperature(dev); }
*temp = cpu_tmp; @@ -162,9 +232,17 @@ static int imx_thermal_probe(struct udevice *dev) if (is_soc_type(MXC_SOC_MX6)) { /* Check for valid fuse */ if (fuse == 0 || fuse == ~0) { - printf("CPU: Thermal invalid data, fuse: 0x%x\n", fuse); + printf("CPU: Thermal invalid data, fuse: 0x%x\n", + fuse); return -EPERM; } + } else if (is_soc_type(MXC_SOC_MX7)) { + /* No Calibration data in FUSE? */ + if ((fuse & 0x3ffff) == 0) + return -EPERM; + /* We do not support 105C TE2 */ + if (((fuse & 0x1c0000) >> 18) == 0x6) + return -EPERM; }
/* set critical cooling temp */
Add imx-common cpu support for imx7d SoC - Update reset_cause for imx7d - Enable watchdog driver built for imx7d
Signed-off-by: Adrian Alonso aalonso@freescale.com Signed-off-by: Peng Fan Peng.Fan@freescale.com --- Changes for V2: Split patch to easier review process - Add system arch register definitions Changes for V3: Resend Changes for V4: Resend Changes for V5: Resend Changes for V6: - Rework imx-common Makefile mx7 build options - Remove mx6 CONFIG_GPT_TIMER as is the default option Changes for V7: - Update reset causes for MX7/MX6
arch/arm/Makefile | 4 ++-- arch/arm/cpu/armv7/Makefile | 3 ++- arch/arm/cpu/armv7/mx7/Makefile | 8 ++++++++ arch/arm/imx-common/Makefile | 9 +++++++-- arch/arm/imx-common/cpu.c | 19 +++++++++++++++++++ drivers/watchdog/Makefile | 2 +- 6 files changed, 39 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/armv7/mx7/Makefile
diff --git a/arch/arm/Makefile b/arch/arm/Makefile index 6f30098..6708140 100644 --- a/arch/arm/Makefile +++ b/arch/arm/Makefile @@ -78,11 +78,11 @@ libs-y += arch/arm/cpu/ libs-y += arch/arm/lib/
ifeq ($(CONFIG_SPL_BUILD),y) -ifneq (,$(CONFIG_MX23)$(CONFIG_MX35)$(filter $(SOC), mx25 mx27 mx5 mx6 mx31 mx35)) +ifneq (,$(CONFIG_MX23)$(CONFIG_MX35)$(filter $(SOC), mx25 mx27 mx5 mx6 mx7 mx31 mx35)) libs-y += arch/arm/imx-common/ endif else -ifneq (,$(filter $(SOC), mx25 mx27 mx5 mx6 mx31 mx35 mxs vf610)) +ifneq (,$(filter $(SOC), mx25 mx27 mx5 mx6 mx7 mx31 mx35 mxs vf610)) libs-y += arch/arm/imx-common/ endif endif diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 5a76100..8defb1b 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -12,7 +12,7 @@ obj-y += cache_v7.o obj-y += cpu.o cp15.o obj-y += syslib.o
-ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_SUNXI)$(CONFIG_ARCH_SOCFPGA),) +ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_MX7)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_SUNXI)$(CONFIG_ARCH_SOCFPGA),) ifneq ($(CONFIG_SKIP_LOWLEVEL_INIT),y) obj-y += lowlevel_init.o endif @@ -45,6 +45,7 @@ obj-$(CONFIG_ARCH_EXYNOS) += exynos/ obj-$(if $(filter ls102xa,$(SOC)),y) += ls102xa/ obj-$(if $(filter mx5,$(SOC)),y) += mx5/ obj-$(CONFIG_MX6) += mx6/ +obj-$(CONFIG_MX7) += mx7/ obj-$(CONFIG_OMAP34XX) += omap3/ obj-$(CONFIG_OMAP44XX) += omap4/ obj-$(CONFIG_OMAP54XX) += omap5/ diff --git a/arch/arm/cpu/armv7/mx7/Makefile b/arch/arm/cpu/armv7/mx7/Makefile new file mode 100644 index 0000000..e6ecef0 --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2015 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# +# + +obj-y := soc.o clock.o clock_slice.o diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index d77a236..1698d06 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -7,7 +7,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 vf610)) +ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 mx7 vf610)) obj-y = iomux-v3.o endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) @@ -18,7 +18,12 @@ ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) obj-y += misc.o obj-$(CONFIG_SPL_BUILD) += spl.o endif -ifeq ($(SOC),$(filter $(SOC),mx6)) +ifeq ($(SOC),$(filter $(SOC),mx7)) +obj-y += cpu.o +obj-$(CONFIG_SYS_I2C_MXC) += i2c-mxv7.o +obj-$(CONFIG_SYSCOUNTER_TIMER) += syscounter.o +endif +ifeq ($(SOC),$(filter $(SOC),mx6 mx7)) obj-y += cache.o init.o obj-$(CONFIG_CMD_SATA) += sata.o obj-$(CONFIG_IMX_VIDEO_SKIP) += video.o diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 38cd0c8..dc6d959 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -46,13 +46,28 @@ static char *get_reset_cause(void) case 0x00008: return "IPP USER"; case 0x00010: +#ifdef CONFIG_MX7 + return "WDOG1"; +#else return "WDOG"; +#endif case 0x00020: return "JTAG HIGH-Z"; case 0x00040: return "JTAG SW"; + case 0x00080: + return "WDOG3"; +#ifdef CONFIG_MX7 + case 0x00100: + return "WDOG4"; + case 0x00200: + return "TEMPSENSE"; +#else + case 0x00100: + return "TEMPSENSE"; case 0x10000: return "WARM BOOT"; +#endif default: return "unknown reset"; } @@ -122,6 +137,8 @@ unsigned imx_ddr_size(void) const char *get_imx_type(u32 imxtype) { switch (imxtype) { + case MXC_CPU_MX7D: + return "7D"; /* Dual-core version of the mx7 */ case MXC_CPU_MX6QP: return "6QP"; /* Quad-Plus version of the mx6 */ case MXC_CPU_MX6DP: @@ -236,6 +253,7 @@ int cpu_mmc_init(bd_t *bis) } #endif
+#ifndef CONFIG_MX7 u32 get_ahb_clk(void) { struct mxc_ccm_reg *imx_ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; @@ -247,6 +265,7 @@ u32 get_ahb_clk(void)
return get_periph_clk() / (ahb_podf + 1); } +#endif
void arch_preboot_os(void) { diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 482a4bd..9e9cb55 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -7,7 +7,7 @@
obj-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o obj-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o -ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 vf610 ls102xa)) +ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 mx7 vf610 ls102xa)) obj-y += imx_watchdog.o endif obj-$(CONFIG_S5P) += s5p_wdt.o
* Add i.MX7D SABRESD target board support with enabled modules: UART, PMIC, USB/OTG, SD, eMMC, ENET, I2C, 74LV IOX.
Build target: mx7dsabresd_config
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Fugang Duan B38611@freescale.com Signed-off-by: Ye.Li B37916@freescale.com Signed-off-by: Adrian Alonso aalonso@freescale.com --- Changes for V2: - Include arch/arm/Kconfig target config option Changes for V3: - Update target board maintainer contact info Changes for V4: depends on patchs - mmc: fsl_esdhc invalidate dcache before read - imx: usb: ehci-mx6: add usb support for imx7d soc Changes for V5: depends on patchs - imx: usb: ehci-mx6: reg accessor cleanups - imx: usb: ehci-mx6: document board specific functions - imx: usb: ehci-mx6: wait_for_bit to check reg status Changes for V6: - Remove unused macro CONFIG_BOARD_POSTCLK_INIT from mc7_common.h Changes for V7: - Update target config build settings - Update mx7_common.h header file to gropup common build options for iMX7 SoC
arch/arm/Kconfig | 6 + arch/arm/cpu/armv7/mx7/Kconfig | 27 ++ arch/arm/include/asm/arch-mx7/sys_proto.h | 2 + board/freescale/mx7dsabresd/Kconfig | 15 + board/freescale/mx7dsabresd/MAINTAINERS | 6 + board/freescale/mx7dsabresd/Makefile | 6 + board/freescale/mx7dsabresd/imximage.cfg | 105 +++++ board/freescale/mx7dsabresd/mx7dsabresd.c | 642 ++++++++++++++++++++++++++++++ configs/mx7dsabresd_defconfig | 14 + include/configs/mx7_common.h | 95 +++++ include/configs/mx7dsabresd.h | 278 +++++++++++++ 11 files changed, 1196 insertions(+) create mode 100644 arch/arm/cpu/armv7/mx7/Kconfig create mode 100644 board/freescale/mx7dsabresd/Kconfig create mode 100644 board/freescale/mx7dsabresd/MAINTAINERS create mode 100644 board/freescale/mx7dsabresd/Makefile create mode 100644 board/freescale/mx7dsabresd/imximage.cfg create mode 100644 board/freescale/mx7dsabresd/mx7dsabresd.c create mode 100644 configs/mx7dsabresd_defconfig create mode 100644 include/configs/mx7_common.h create mode 100644 include/configs/mx7dsabresd.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ad8f796..129e018 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -469,6 +469,10 @@ config ARCH_KEYSTONE select CPU_V7 select SUPPORT_SPL
+config ARCH_MX7 + bool "Freescale MX7" + select CPU_V7 + config ARCH_MX6 bool "Freescale MX6" select CPU_V7 @@ -736,6 +740,8 @@ source "arch/arm/mach-keystone/Kconfig"
source "arch/arm/mach-kirkwood/Kconfig"
+source "arch/arm/cpu/armv7/mx7/Kconfig" + source "arch/arm/cpu/armv7/mx6/Kconfig"
source "arch/arm/cpu/armv7/mx5/Kconfig" diff --git a/arch/arm/cpu/armv7/mx7/Kconfig b/arch/arm/cpu/armv7/mx7/Kconfig new file mode 100644 index 0000000..892ffae --- /dev/null +++ b/arch/arm/cpu/armv7/mx7/Kconfig @@ -0,0 +1,27 @@ +if ARCH_MX7 + +config MX7 + bool + default y + +config MX7D + bool + +choice + prompt "MX7 board select" + optional + +config TARGET_MX7DSABRESD + bool "mx7dsabresd" + select CPU_V7 + select DM + select DM_THERMAL + +endchoice + +config SYS_SOC + default "mx7" + +source "board/freescale/mx7dsabresd/Kconfig" + +endif diff --git a/arch/arm/include/asm/arch-mx7/sys_proto.h b/arch/arm/include/asm/arch-mx7/sys_proto.h index f19684b..ca7608b 100644 --- a/arch/arm/include/asm/arch-mx7/sys_proto.h +++ b/arch/arm/include/asm/arch-mx7/sys_proto.h @@ -5,3 +5,5 @@ */
#include <asm/imx-common/sys_proto.h> + +void set_wdog_reset(struct wdog_regs *wdog); diff --git a/board/freescale/mx7dsabresd/Kconfig b/board/freescale/mx7dsabresd/Kconfig new file mode 100644 index 0000000..d7c6ae4 --- /dev/null +++ b/board/freescale/mx7dsabresd/Kconfig @@ -0,0 +1,15 @@ +if TARGET_MX7DSABRESD + +config SYS_BOARD + default "mx7dsabresd" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "mx7" + +config SYS_CONFIG_NAME + default "mx7dsabresd" + +endif diff --git a/board/freescale/mx7dsabresd/MAINTAINERS b/board/freescale/mx7dsabresd/MAINTAINERS new file mode 100644 index 0000000..3910ee4 --- /dev/null +++ b/board/freescale/mx7dsabresd/MAINTAINERS @@ -0,0 +1,6 @@ +MX7DSABRESD BOARD +M: Adrian Alonso aalonso@freescale.com +S: Maintained +F: board/freescale/mx7dsabresd +F: include/configs/mx7dsabresd.h +F: configs/mx7dsabresd_defconfig diff --git a/board/freescale/mx7dsabresd/Makefile b/board/freescale/mx7dsabresd/Makefile new file mode 100644 index 0000000..14336ab --- /dev/null +++ b/board/freescale/mx7dsabresd/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2015 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := mx7dsabresd.o diff --git a/board/freescale/mx7dsabresd/imximage.cfg b/board/freescale/mx7dsabresd/imximage.cfg new file mode 100644 index 0000000..073e8af --- /dev/null +++ b/board/freescale/mx7dsabresd/imximage.cfg @@ -0,0 +1,105 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + * + * Refer docs/README.imxmage for more details about how-to configure + * and create imximage boot image + * + * The syntax is taken as close as possible with the kwbimage + */ + +#define __ASSEMBLY__ +#include <config.h> + +/* image version */ + +IMAGE_VERSION 2 + +/* + * Boot Device : one of + * spi/sd/nand/onenand, qspi/nor + */ + +#ifdef CONFIG_SYS_BOOT_QSPI +BOOT_FROM qspi +#elif defined(CONFIG_SYS_BOOT_EIMNOR) +BOOT_FROM nor +#else +BOOT_FROM sd +#endif + +#ifdef CONFIG_SECURE_BOOT +CSF CONFIG_CSF_SIZE +#endif + +/* + * Device Configuration Data (DCD) + * + * Each entry must have the format: + * Addr-type Address Value + * + * where: + * Addr-type register length (1,2 or 4 bytes) + * Address absolute address of the register + * value value to be stored in the register + */ + +DATA 4 0x30340004 0x4F400005 + +DATA 4 0x30391000 0x00000002 +DATA 4 0x307a0000 0x01040001 +DATA 4 0x307a01a0 0x80400003 +DATA 4 0x307a01a4 0x00100020 +DATA 4 0x307a01a8 0x80100004 +DATA 4 0x307a0064 0x00400046 +DATA 4 0x307a0490 0x00000001 +DATA 4 0x307a00d0 0x00020083 +DATA 4 0x307a00d4 0x00690000 +DATA 4 0x307a00dc 0x09300004 +DATA 4 0x307a00e0 0x04080000 +DATA 4 0x307a00e4 0x00100004 +DATA 4 0x307a00f4 0x0000033f +DATA 4 0x307a0100 0x09081109 +DATA 4 0x307a0104 0x0007020d +DATA 4 0x307a0108 0x03040407 +DATA 4 0x307a010c 0x00002006 +DATA 4 0x307a0110 0x04020205 +DATA 4 0x307a0114 0x03030202 +DATA 4 0x307a0120 0x00000803 +DATA 4 0x307a0180 0x00800020 +DATA 4 0x307a0184 0x02000100 +DATA 4 0x307a0190 0x02098204 +DATA 4 0x307a0194 0x00030303 +DATA 4 0x307a0200 0x00000016 +DATA 4 0x307a0204 0x00171717 +DATA 4 0x307a0214 0x04040404 +DATA 4 0x307a0218 0x0f040404 +DATA 4 0x307a0240 0x06000604 +DATA 4 0x307a0244 0x00000001 +DATA 4 0x30391000 0x00000000 +DATA 4 0x30790000 0x17420f40 +DATA 4 0x30790004 0x10210100 +DATA 4 0x30790010 0x00060807 +DATA 4 0x307900b0 0x1010007e +DATA 4 0x3079009c 0x00000d6e +DATA 4 0x30790020 0x08080808 +DATA 4 0x30790030 0x08080808 +DATA 4 0x30790050 0x01000010 +DATA 4 0x30790050 0x00000010 + +DATA 4 0x307900c0 0x0e407304 +DATA 4 0x307900c0 0x0e447304 +DATA 4 0x307900c0 0x0e447306 + +CHECK_BITS_SET 4 0x307900c4 0x1 + +DATA 4 0x307900c0 0x0e447304 +DATA 4 0x307900c0 0x0e407304 + +DATA 4 0x30384130 0x00000000 +DATA 4 0x30340020 0x00000178 +DATA 4 0x30384130 0x00000002 +DATA 4 0x30790018 0x0000000f + +CHECK_BITS_SET 4 0x307a0004 0x1 diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c new file mode 100644 index 0000000..4c1473d --- /dev/null +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -0,0 +1,642 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx7-pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> +#include <asm/imx-common/iomux-v3.h> +#include <asm/imx-common/boot_mode.h> +#include <asm/io.h> +#include <linux/sizes.h> +#include <common.h> +#include <fsl_esdhc.h> +#include <mmc.h> +#include <miiphy.h> +#include <netdev.h> +#include <power/pmic.h> +#include <power/pfuze3000_pmic.h> +#include "../common/pfuze.h" +#include <i2c.h> +#include <asm/imx-common/mxc_i2c.h> +#include <asm/arch/crm_regs.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | \ + PAD_CTL_PUS_PU100KOHM | PAD_CTL_HYS) + +#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ + PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) + +#define ENET_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) +#define ENET_PAD_CTRL_MII (PAD_CTL_DSE_3P3V_32OHM) + +#define ENET_RX_PAD_CTRL (PAD_CTL_PUS_PU100KOHM | PAD_CTL_DSE_3P3V_49OHM) + +#define I2C_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ + PAD_CTL_HYS | PAD_CTL_PUE | PAD_CTL_PUS_PU100KOHM) + +#define LCD_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_PUS_PU100KOHM | \ + PAD_CTL_DSE_3P3V_49OHM) + +#define QSPI_PAD_CTRL \ + (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUE | PAD_CTL_PUS_PU47KOHM) + +#define SPI_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_SLOW | PAD_CTL_HYS) + +#define BUTTON_PAD_CTRL (PAD_CTL_PUS_PU5KOHM | PAD_CTL_DSE_3P3V_98OHM) + +#define NAND_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_SRE_SLOW | PAD_CTL_HYS) + +#define NAND_PAD_READY0_CTRL (PAD_CTL_DSE_3P3V_49OHM | PAD_CTL_PUS_PU5KOHM) + +#ifdef CONFIG_SYS_I2C_MXC +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +/* I2C1 for PMIC */ +struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = MX7D_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = MX7D_PAD_I2C1_SCL__GPIO4_IO8 | PC, + .gp = IMX_GPIO_NR(4, 8), + }, + .sda = { + .i2c_mode = MX7D_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = MX7D_PAD_I2C1_SDA__GPIO4_IO9 | PC, + .gp = IMX_GPIO_NR(4, 9), + }, +}; +#endif + +int dram_init(void) +{ + gd->ram_size = PHYS_SDRAM_SIZE; + + return 0; +} + +static iomux_v3_cfg_t const wdog_pads[] = { + MX7D_PAD_GPIO1_IO00__WDOG1_WDOG_B | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart1_pads[] = { + MX7D_PAD_UART1_TX_DATA__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + MX7D_PAD_UART1_RX_DATA__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc1_pads[] = { + MX7D_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_CMD__SD1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA0__SD1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA1__SD1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA2__SD1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_DATA3__SD1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + MX7D_PAD_SD1_CD_B__GPIO5_IO0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD1_RESET_B__GPIO5_IO2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc3_emmc_pads[] = { + MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_DATA7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX7D_PAD_SD3_STROBE__SD3_STROBE | MUX_PAD_CTRL(USDHC_PAD_CTRL), + + MX7D_PAD_SD3_RESET_B__GPIO6_IO11 | MUX_PAD_CTRL(USDHC_PAD_CTRL), +}; + +#define IOX_SDI IMX_GPIO_NR(1, 9) +#define IOX_STCP IMX_GPIO_NR(1, 12) +#define IOX_SHCP IMX_GPIO_NR(1, 13) + +static iomux_v3_cfg_t const iox_pads[] = { + /* IOX_SDI */ + MX7D_PAD_GPIO1_IO09__GPIO1_IO9 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_STCP */ + MX7D_PAD_GPIO1_IO12__GPIO1_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL), + /* IOX_SHCP */ + MX7D_PAD_GPIO1_IO13__GPIO1_IO13 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +/* + * PCIE_DIS_B --> Q0 + * PCIE_RST_B --> Q1 + * HDMI_RST_B --> Q2 + * PERI_RST_B --> Q3 + * SENSOR_RST_B --> Q4 + * ENET_RST_B --> Q5 + * PERI_3V3_EN --> Q6 + * LCD_PWR_EN --> Q7 + */ +enum qn { + PCIE_DIS_B, + PCIE_RST_B, + HDMI_RST_B, + PERI_RST_B, + SENSOR_RST_B, + ENET_RST_B, + PERI_3V3_EN, + LCD_PWR_EN, +}; + +enum qn_func { + qn_reset, + qn_enable, + qn_disable, +}; + +enum qn_level { + qn_low = 0, + qn_high = 1, +}; + +static enum qn_level seq[3][2] = { + {0, 1}, {1, 1}, {0, 0} +}; + +static enum qn_func qn_output[8] = { + qn_disable, qn_reset, qn_reset, qn_reset, qn_reset, qn_reset, qn_enable, + qn_enable +}; + +void iox74lv_init(void) +{ + int i; + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); +}; + +void iox74lv_set(int index) +{ + int i; + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + + if (i == index) + gpio_direction_output(IOX_SDI, seq[qn_output[i]][0]); + else + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); + + for (i = 7; i >= 0; i--) { + gpio_direction_output(IOX_SHCP, 0); + gpio_direction_output(IOX_SDI, seq[qn_output[i]][1]); + udelay(500); + gpio_direction_output(IOX_SHCP, 1); + udelay(500); + } + + gpio_direction_output(IOX_STCP, 0); + udelay(500); + /* + * shift register will be output to pins + */ + gpio_direction_output(IOX_STCP, 1); +}; + +#ifdef CONFIG_SYS_USE_NAND +static iomux_v3_cfg_t const gpmi_pads[] = { + MX7D_PAD_SD3_DATA0__NAND_DATA00 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA1__NAND_DATA01 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA2__NAND_DATA02 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA3__NAND_DATA03 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA4__NAND_DATA04 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA5__NAND_DATA05 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA6__NAND_DATA06 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_DATA7__NAND_DATA07 | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_CLK__NAND_CLE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_CMD__NAND_ALE | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_STROBE__NAND_RE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SD3_RESET_B__NAND_WE_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_MCLK__NAND_WP_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_RX_BCLK__NAND_CE3_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_RX_SYNC__NAND_CE2_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_RX_DATA__NAND_CE1_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_TX_BCLK__NAND_CE0_B | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_TX_SYNC__NAND_DQS | MUX_PAD_CTRL(NAND_PAD_CTRL), + MX7D_PAD_SAI1_TX_DATA__NAND_READY_B | MUX_PAD_CTRL(NAND_PAD_READY0_CTRL), +}; + +static void setup_gpmi_nand(void) +{ + imx_iomux_v3_setup_multiple_pads(gpmi_pads, ARRAY_SIZE(gpmi_pads)); + + /* + * NAND_USDHC_BUS_CLK is set in rom + */ + + set_clk_nand(); + + /* + * APBH clock root is set in init_esdhc, USDHC3_CLK. + * There is no clk gate for APBHDMA. + * No touch here. + */ +} +#endif + +#ifdef CONFIG_FEC_MXC +static iomux_v3_cfg_t const fec1_pads[] = { + MX7D_PAD_ENET1_RGMII_RX_CTL__ENET1_RGMII_RX_CTL | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD0__ENET1_RGMII_RD0 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD1__ENET1_RGMII_RD1 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD2__ENET1_RGMII_RD2 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RD3__ENET1_RGMII_RD3 | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_RXC__ENET1_RGMII_RXC | MUX_PAD_CTRL(ENET_RX_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TX_CTL__ENET1_RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD0__ENET1_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD1__ENET1_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD2__ENET1_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TD3__ENET1_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_ENET1_RGMII_TXC__ENET1_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX7D_PAD_GPIO1_IO10__ENET1_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), + MX7D_PAD_GPIO1_IO11__ENET1_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL_MII), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_pads, ARRAY_SIZE(fec1_pads)); +} +#endif + +static void setup_iomux_uart(void) +{ + imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); +} + +#ifdef CONFIG_FSL_QSPI +static iomux_v3_cfg_t const quadspi_pads[] = { + MX7D_PAD_EPDC_DATA00__QSPI_A_DATA0 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA01__QSPI_A_DATA1 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA02__QSPI_A_DATA2 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA03__QSPI_A_DATA3 | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA05__QSPI_A_SCLK | MUX_PAD_CTRL(QSPI_PAD_CTRL), + MX7D_PAD_EPDC_DATA06__QSPI_A_SS0_B | MUX_PAD_CTRL(QSPI_PAD_CTRL), +}; + +int board_qspi_init(void) +{ + /* Set the iomux */ + imx_iomux_v3_setup_multiple_pads(quadspi_pads, ARRAY_SIZE(quadspi_pads)); + + /* Set the clock */ + set_clk_qspi(); + + return 0; +} +#endif + +#ifdef CONFIG_FSL_ESDHC + +#define USDHC1_CD_GPIO IMX_GPIO_NR(5, 0) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(5, 2) +#define USDHC3_PWR_GPIO IMX_GPIO_NR(6, 11) + +static struct fsl_esdhc_cfg usdhc_cfg[3] = { + {USDHC1_BASE_ADDR, 0, 4}, + {USDHC3_BASE_ADDR}, +}; + +static int mmc_get_env_devno(void) +{ + struct bootrom_sw_info **p = + (struct bootrom_sw_info **)ROM_SW_INFO_ADDR; + + u8 boot_type = (*p)->boot_dev_type; + u8 dev_no = (*p)->boot_dev_instance; + + /* If not boot from sd/mmc, use default value */ + if ((boot_type != BOOT_TYPE_SD) && (boot_type != BOOT_TYPE_MMC)) + return CONFIG_SYS_MMC_ENV_DEV; + + if (2 == dev_no) + dev_no--; + + return dev_no; +} + +static int mmc_map_to_kernel_blk(int dev_no) +{ + if (1 == dev_no) + dev_no++; + + return dev_no; +} + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = !gpio_get_value(USDHC1_CD_GPIO); + break; + case USDHC3_BASE_ADDR: + ret = 1; /* Assume uSDHC3 emmc is always present */ + break; + } + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc2 USDHC3 (eMMC) + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + imx_iomux_v3_setup_multiple_pads( + usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_CD_GPIO, "usdhc1_cd"); + gpio_direction_input(USDHC1_CD_GPIO); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_pwr"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); + break; + case 1: + imx_iomux_v3_setup_multiple_pads( + usdhc3_emmc_pads, ARRAY_SIZE(usdhc3_emmc_pads)); + gpio_request(USDHC3_PWR_GPIO, "usdhc3_pwr"); + gpio_direction_output(USDHC3_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC3_PWR_GPIO, 1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); + break; + default: + printf("Warning: you configured more USDHC controllers" + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +static int check_mmc_autodetect(void) +{ + char *autodetect_str = getenv("mmcautodetect"); + + if ((autodetect_str != NULL) && + (strcmp(autodetect_str, "yes") == 0)) { + return 1; + } + + return 0; +} + +static void mmc_late_init(void) +{ + char cmd[32]; + char mmcblk[32]; + u32 dev_no = mmc_get_env_devno(); + + if (!check_mmc_autodetect()) + return; + + setenv_ulong("mmcdev", dev_no); + + /* Set mmcblk env */ + sprintf(mmcblk, "/dev/mmcblk%dp2 rootwait rw", + mmc_map_to_kernel_blk(dev_no)); + setenv("mmcroot", mmcblk); + + sprintf(cmd, "mmc dev %d", dev_no); + run_command(cmd, 0); +} + +#endif + +#ifdef CONFIG_FEC_MXC +int board_eth_init(bd_t *bis) +{ + int ret; + + setup_iomux_fec(); + + ret = fecmxc_initialize_multi(bis, 0, + CONFIG_FEC_MXC_PHYADDR, IMX_FEC_BASE); + if (ret) + printf("FEC1 MXC: %s:failed\n", __func__); + + return ret; +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *const iomuxc_gpr_regs + = (struct iomuxc_gpr_base_regs *) IOMUXC_GPR_BASE_ADDR; + + /* Use 125M anatop REF_CLK1 for ENET1, clear gpr1[13], gpr1[17]*/ + clrsetbits_le32(&iomuxc_gpr_regs->gpr[1], + (IOMUXC_GPR_GPR1_GPR_ENET1_TX_CLK_SEL_MASK | + IOMUXC_GPR_GPR1_GPR_ENET1_CLK_DIR_MASK), 0); + + return set_clk_enet(ENET_125MHz); +} + + +int board_phy_config(struct phy_device *phydev) +{ + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x21); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x7ea8); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x2f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1f, 0x71b7); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_early_init_f(void) +{ + setup_iomux_uart(); + + setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM + 0x100; + + imx_iomux_v3_setup_multiple_pads(iox_pads, ARRAY_SIZE(iox_pads)); + + iox74lv_init(); + +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + +#ifdef CONFIG_SYS_USE_NAND + setup_gpmi_nand(); +#endif + +#ifdef CONFIG_FSL_QSPI + board_qspi_init(); +#endif + + return 0; +} + +#ifdef CONFIG_CMD_BMODE +static const struct boot_mode board_boot_modes[] = { + /* 4 bit bus width */ + {"sd1", MAKE_CFGVAL(0x10, 0x10, 0x00, 0x00)}, + {"emmc", MAKE_CFGVAL(0x10, 0x2a, 0x00, 0x00)}, + /* TODO: Nand */ + {"qspi", MAKE_CFGVAL(0x00, 0x40, 0x00, 0x00)}, + {NULL, 0}, +}; +#endif + +#ifdef CONFIG_POWER +#define I2C_PMIC 0 +int power_init_board(void) +{ + struct pmic *p; + int ret; + unsigned int reg, rev_id; + + ret = power_pfuze3000_init(I2C_PMIC); + if (ret) + return ret; + + p = pmic_get("PFUZE3000"); + ret = pmic_probe(p); + if (ret) + return ret; + + pmic_reg_read(p, PFUZE3000_DEVICEID, ®); + pmic_reg_read(p, PFUZE3000_REVID, &rev_id); + printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", reg, rev_id); + + /* disable Low Power Mode during standby mode */ + pmic_reg_read(p, PFUZE3000_LDOGCTL, ®); + reg |= 0x1; + pmic_reg_write(p, PFUZE3000_LDOGCTL, reg); + + return 0; +} +#endif + +int board_late_init(void) +{ +#ifdef CONFIG_CMD_BMODE + add_board_boot_modes(board_boot_modes); +#endif + +#ifdef CONFIG_ENV_IS_IN_MMC + mmc_late_init(); +#endif + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + + set_wdog_reset((struct wdog_regs *)WDOG1_BASE_ADDR); + + return 0; +} + +u32 get_board_rev(void) +{ + return get_cpu_rev(); +} + +int checkboard(void) +{ + puts("Board: i.MX7D SABRESD\n"); + + return 0; +} + +#ifdef CONFIG_USB_EHCI_MX7 +iomux_v3_cfg_t const usb_otg1_pads[] = { + MX7D_PAD_GPIO1_IO05__USB_OTG1_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +iomux_v3_cfg_t const usb_otg2_pads[] = { + MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +int board_ehci_hcd_init(int port) +{ + switch (port) { + case 0: + imx_iomux_v3_setup_multiple_pads(usb_otg1_pads, + ARRAY_SIZE(usb_otg1_pads)); + break; + case 1: + imx_iomux_v3_setup_multiple_pads(usb_otg2_pads, + ARRAY_SIZE(usb_otg2_pads)); + break; + default: + printf("MXC USB port %d not yet supported\n", port); + return -EINVAL; + } + return 0; +} +#endif diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig new file mode 100644 index 0000000..bb95424 --- /dev/null +++ b/configs/mx7dsabresd_defconfig @@ -0,0 +1,14 @@ +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg,MX7D" +CONFIG_ARM=y +CONFIG_ARCH_MX7=y +CONFIG_TARGET_MX7DSABRESD=y +CONFIG_SYS_MALLOC_F=y +CONFIG_SYS_MALLOC_F_LEN=0x400 +CONFIG_CMD_NET=y +CONFIG_CMD_PING=y +CONFIG_CMD_DHCP=y +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h new file mode 100644 index 0000000..ea2be49 --- /dev/null +++ b/include/configs/mx7_common.h @@ -0,0 +1,95 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX7. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MX7_COMMON_H +#define __MX7_COMMON_H + +#include <linux/sizes.h> +#include <asm/arch/imx-regs.h> +#include <asm/imx-common/gpio.h> + +#ifndef CONFIG_MX7 +#define CONFIG_MX7 +#endif + +/* Timer settings */ +#define CONFIG_MXC_GPT_HCLK +#define CONFIG_SYSCOUNTER_TIMER +#define CONFIG_SC_TIMER_CLK 8000000 /* 8Mhz */ + +/* Enable iomux-lpsr support */ +#define CONFIG_IOMUX_LPSR +#define CONFIG_IMX_FIXED_IVT_OFFSET + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M) + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_ROM_UNIFIED_SECTIONS +#define CONFIG_SYS_GENERIC_BOARD +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_LOADADDR 0x80800000 +#define CONFIG_SYS_TEXT_BASE 0x87800000 + +#ifndef CONFIG_BOOTDELAY +#define CONFIG_BOOTDELAY 3 +#endif + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Filesystems and image support */ +#define CONFIG_OF_LIBFDT +#define CONFIG_CMD_BOOTZ +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_EXT4 +#define CONFIG_CMD_EXT4_WRITE +#define CONFIG_CMD_FAT + +/* Miscellaneous configurable options */ +#undef CONFIG_CMD_IMLS +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 512 +#define CONFIG_SYS_MAXARGS 32 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#ifndef CONFIG_SYS_DCACHE_OFF +#define CONFIG_CMD_CACHE +#endif + +/* GPIO */ +#define CONFIG_MXC_GPIO +#define CONFIG_CMD_GPIO + +/* UART */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR + +/* MMC */ +#define CONFIG_MMC +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_FSL_ESDHC +#define CONFIG_FSL_USDHC + +/* Fuses */ +#define CONFIG_CMD_FUSE +#define CONFIG_MXC_OCOTP + +#endif diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h new file mode 100644 index 0000000..3e371a0 --- /dev/null +++ b/include/configs/mx7dsabresd.h @@ -0,0 +1,278 @@ +/* + * Copyright (C) 2015 Freescale Semiconductor, Inc. + * + * Configuration settings for the Freescale i.MX7D SABRESD board. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MX7D_SABRESD_CONFIG_H +#define __MX7D_SABRESD_CONFIG_H + +#include "mx7_common.h" + +#define CONFIG_DBG_MONITOR +#define PHYS_SDRAM_SIZE SZ_1G + +/* Network */ +#define CONFIG_CMD_MII +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 0 + +#define CONFIG_PHYLIB +#define CONFIG_PHY_BROADCOM +#define CONFIG_FEC_DMA_MINALIGN 64 + +/* MMC Config*/ +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +/* ENET1 */ +#define IMX_FEC_BASE ENET_IPS_BASE_ADDR + +/* PMIC */ +#define CONFIG_POWER +#define CONFIG_POWER_I2C +#define CONFIG_POWER_PFUZE3000 +#define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08 + +#undef CONFIG_BOOTM_NETBSD +#undef CONFIG_BOOTM_PLAN9 +#undef CONFIG_BOOTM_RTEMS + +#undef CONFIG_CMD_EXPORTENV +#undef CONFIG_CMD_IMPORTENV + +/* I2C configs */ +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 +#define CONFIG_SYS_I2C_SPEED 100000 + +#define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */ +#define CONFIG_SYS_MMC_IMG_LOAD_PART 1 +#ifdef CONFIG_SYS_BOOT_NAND +#define CONFIG_MFG_NAND_PARTITION "mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs) " +#else +#define CONFIG_MFG_NAND_PARTITION "" +#endif + +#define CONFIG_MFG_ENV_SETTINGS \ + "mfgtool_args=setenv bootargs console=${console},${baudrate} " \ + "rdinit=/linuxrc " \ + "g_mass_storage.stall=0 g_mass_storage.removable=1 " \ + "g_mass_storage.idVendor=0x066F g_mass_storage.idProduct=0x37FF "\ + "g_mass_storage.iSerialNumber="" "\ + CONFIG_MFG_NAND_PARTITION \ + "clk_ignore_unused "\ + "\0" \ + "initrd_addr=0x83800000\0" \ + "initrd_high=0xffffffff\0" \ + "bootcmd_mfg=run mfgtool_args;bootz ${loadaddr} ${initrd_addr} ${fdt_addr};\0" \ + +#if defined(CONFIG_SYS_BOOT_NAND) +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + "fdt_addr=0x83000000\0" \ + "fdt_high=0xffffffff\0" \ + "console=ttymxc0\0" \ + "bootargs=console=ttymxc0,115200 ubi.mtd=3 " \ + "root=ubi0:rootfs rootfstype=ubifs " \ + "mtdparts=gpmi-nand:64m(boot),16m(kernel),16m(dtb),-(rootfs)\0"\ + "bootcmd=nand read ${loadaddr} 0x4000000 0x800000;"\ + "nand read ${fdt_addr} 0x5000000 0x100000;"\ + "bootz ${loadaddr} - ${fdt_addr}\0" + +#else +#define CONFIG_EXTRA_ENV_SETTINGS \ + CONFIG_MFG_ENV_SETTINGS \ + "script=boot.scr\0" \ + "image=zImage\0" \ + "console=ttymxc0\0" \ + "fdt_high=0xffffffff\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_file=imx7d-sdb.dtb\0" \ + "fdt_addr=0x83000000\0" \ + "boot_fdt=try\0" \ + "ip_dyn=yes\0" \ + "mmcdev="__stringify(CONFIG_SYS_MMC_ENV_DEV)"\0" \ + "mmcpart=" __stringify(CONFIG_SYS_MMC_IMG_LOAD_PART) "\0" \ + "mmcroot=" CONFIG_MMCROOT " rootwait rw\0" \ + "mmcautodetect=yes\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} " \ + "root=${mmcroot}\0" \ + "loadbootscript=" \ + "fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ + "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr} ${fdt_file}\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcdev};" \ + "mmc dev ${mmcdev}; if mmc rescan; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loadimage; then " \ + "run mmcboot; " \ + "else run netboot; " \ + "fi; " \ + "fi; " \ + "else run netboot; fi" +#endif + +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x20000000) + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_STACKSIZE SZ_128K + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ENV_SIZE SZ_8K + +#ifdef CONFIG_SYS_BOOT_QSPI +#define CONFIG_SYS_USE_QSPI +#define CONFIG_ENV_IS_IN_SPI_FLASH +#elif defined CONFIG_SYS_BOOT_NAND +#define CONFIG_SYS_USE_NAND +#define CONFIG_ENV_IS_IN_NAND +#else +#define CONFIG_ENV_IS_IN_MMC +#endif + +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_CMD_NAND +#define CONFIG_CMD_NAND_TRIMFFS + +/* NAND stuff */ +#define CONFIG_NAND_MXS +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_BASE 0x40000000 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* DMA stuff, needed for GPMI/MXS NAND support */ +#define CONFIG_APBH_DMA +#define CONFIG_APBH_DMA_BURST +#define CONFIG_APBH_DMA_BURST8 +#endif + +#ifdef CONFIG_SYS_USE_QSPI +#define CONFIG_FSL_QSPI /* enable the QUADSPI driver */ +#define CONFIG_QSPI_BASE QSPI1_IPS_BASE_ADDR +#define CONFIG_QSPI_MEMMAP_BASE QSPI0_ARB_BASE_ADDR + +#define CONFIG_CMD_SF +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_MACRONIX +#define CONFIG_SPI_FLASH_BAR +#define CONFIG_SF_DEFAULT_BUS 0 +#define CONFIG_SF_DEFAULT_CS 0 +#define CONFIG_SF_DEFAULT_SPEED 40000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#endif + +#if defined(CONFIG_ENV_IS_IN_MMC) +#define CONFIG_ENV_OFFSET (8 * SZ_64K) +#elif defined(CONFIG_ENV_IS_IN_SPI_FLASH) +#define CONFIG_ENV_OFFSET (768 * 1024) +#define CONFIG_ENV_SECT_SIZE (64 * 1024) +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_CS CONFIG_SF_DEFAULT_CS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#elif defined(CONFIG_ENV_IS_IN_NAND) +#undef CONFIG_ENV_SIZE +#define CONFIG_ENV_OFFSET (8 << 20) +#define CONFIG_ENV_SECT_SIZE (128 << 10) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#endif + +#ifdef CONFIG_SYS_USE_NAND +#define CONFIG_SYS_FSL_USDHC_NUM 1 +#else +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#endif + +#define CONFIG_SYS_MMC_ENV_DEV 0 /* USDHC1 */ +#define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ +#define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */ + +#define CONFIG_CMD_BMODE + +/* USB Configs */ +#define CONFIG_CMD_USB +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_MX7 +#define CONFIG_USB_STORAGE +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#define CONFIG_MXC_USB_FLAGS 0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 2 + +#define CONFIG_IMX_THERMAL + +#endif /* __CONFIG_H */
On Tue, Sep 1, 2015 at 1:22 PM, Adrian Alonso aalonso@freescale.com wrote:
- Boot Device : one of
- spi/sd/nand/onenand, qspi/nor
This config option does not exist in mainline. Please remove it.
Ditto.
Ditto.
if (2 == dev_no)
dev_no == 2 looks better.
dev_no--;
return dev_no;
if (1 == dev_no)
Same here.
Adrian Alonso
Fabio Estevam
