[PATCH] board: gateworks: venice: remove redundance adjustment of thermal trip points
commit 0543a1ed2787 ("imx8m: fixup thermal trips") moved updating the thermal trip points to all IMX8M so we can remove it from our board specific dt config.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/venice.c | 16 ---------------- 1 file changed, 16 deletions(-)
diff --git a/board/gateworks/venice/venice.c b/board/gateworks/venice/venice.c index d94f6b8a577d..c4d86c26a9b5 100644 --- a/board/gateworks/venice/venice.c +++ b/board/gateworks/venice/venice.c @@ -179,22 +179,6 @@ int ft_board_setup(void *fdt, struct bd_info *bd) /* set board model dt prop */ fdt_setprop_string(fdt, 0, "board", eeprom_get_model());
- /* update temp thresholds */ - off = fdt_path_offset(fdt, "/thermal-zones/cpu-thermal/trips"); - if (off >= 0) { - int minc, maxc, prop; - - get_cpu_temp_grade(&minc, &maxc); - fdt_for_each_subnode(prop, fdt, off) { - const char *type = fdt_getprop(fdt, prop, "type", NULL); - - if (type && (!strcmp("critical", type))) - fdt_setprop_u32(fdt, prop, "temperature", maxc * 1000); - else if (type && (!strcmp("passive", type))) - fdt_setprop_u32(fdt, prop, "temperature", (maxc - 10) * 1000); - } - } - if (!strncmp(base_model, "GW73", 4)) { pcbrev = get_pcb_rev(base_model);
commit 0543a1ed2787 ("imx8m: fixup thermal trips") moved updating the thermal trip points to all IMX8M so we can remove it from our board specific dt config. Signed-off-by: Tim Harvey tharvey@gateworks.com
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
