[U-Boot-Users] [PATCH 1/2] add Kendein/Micrel KS8695P CPU support
Hi All,
Attached is a patch that adds support to u-boot for the Kendin/Micrel KS8695P CPU. It is an ARM9 based SoC type device, used in a lot of little routers.
This patch was originally generated against u-boot 1.1.1.
I am following up this patch with a couple of more patches that add support for the OpenGear CM4008 and CM4116/CM4148 console manager boards (that use the KS8695P CPU).
Regards Greg
Sorry, but your source base is just too old, and the patch as is is not usable any more. Please note that there has been a major reorganisation to better support SoC systems like yours, too. Instead of duplicationg the same code again and again we now share the common parts.
Please rework your patch; do not create a new cpu/ directory, but instead a new SoC-specific subdirectory like those already present for at91rm9200 or s3c24x0 systems.
And please don't forget to include the required entries to the CHANGELOG, MAINTAINERS and CREDITS files.
Actually the order was different, but this doesn't matter: all your patches share the same problem. Please fix, and resubmit.
Hi Wolfgang,
Here is a reworked patch, this time against the current CVS code. How does this look?
I put it under the arm920t, though technicaly it is a 922t. Seemed to fit in nicely in any case.
The first email (the ks8695 cpu support) bounced, it was larger than 40k. So I had to split it and resend. Otherwise they would have been in order :-)
Regards Greg
diff -Naur --exclude=CVS u-boot.cvs/CHANGELOG u-boot/CHANGELOG --- u-boot.cvs/CHANGELOG 2005-05-19 20:57:30.000000000 +1000 +++ u-boot/CHANGELOG 2005-05-19 23:56:42.000000000 +1000 @@ -422,6 +422,10 @@
* Fix problem with protected sector detection in driver/cfi_flash.c
+* Patch by Greg Ungerer, 19 May 2005: + - add support for the KS8695P (ARM 922 based) CPU + - add support for the OpenGear CM4008, CM4116 and CM4148 boards + ====================================================================== Changes for U-Boot 1.1.2: ====================================================================== diff -Naur --exclude=CVS u-boot.cvs/cpu/arm920t/ks8695/interrupts.c u-boot/cpu/arm920t/ks8695/interrupts.c --- u-boot.cvs/cpu/arm920t/ks8695/interrupts.c 1970-01-01 10:00:00.000000000 +1000 +++ u-boot/cpu/arm920t/ks8695/interrupts.c 2005-05-19 21:45:57.000000000 +1000 @@ -0,0 +1,113 @@ +/* + * (C) Copyright 2004-2005, Greg Ungerer greg.ungerer@opengear.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/platform.h> + +/* + * Handy KS8695 register access functions. + */ +#define ks8695_read(a) *((volatile ulong *) (KS8695_IO_BASE + (a))) +#define ks8695_write(a,v) *((volatile ulong *) (KS8695_IO_BASE + (a))) = (v) + +int timer_inited; +ulong timer_ticks; + +int interrupt_init (void) +{ + /* nothing happens here - we don't setup any IRQs */ + return (0); +} + +/* + * Initial timer set constants. Nothing complicated, just set for a 1ms + * tick. + */ +#define TIMER_INTERVAL (TICKS_PER_uSEC * mSEC_1) +#define TIMER_COUNT (TIMER_INTERVAL / 2) +#define TIMER_PULSE TIMER_COUNT + +void reset_timer_masked(void) +{ + /* Set the hadware timer for 1ms */ + ks8695_write(KS8695_TIMER1, TIMER_COUNT); + ks8695_write(KS8695_TIMER1_PCOUNT, TIMER_PULSE); + ks8695_write(KS8695_TIMER_CTRL, 0x2); + timer_ticks = 0; + timer_inited++; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer_masked(void) +{ + /* Check for timer wrap */ + if (ks8695_read(KS8695_INT_STATUS) & KS8695_INTMASK_TIMERINT1) { + /* Clear interrupt condition */ + ks8695_write(KS8695_INT_STATUS, KS8695_INTMASK_TIMERINT1); + timer_ticks++; + } + return timer_ticks; +} + +ulong get_timer(ulong base) +{ + return (get_timer_masked() - base); +} + +void set_timer(ulong t) +{ + timer_ticks = t; +} + +void udelay(ulong usec) +{ + ulong start = get_timer_masked(); + ulong end; + + if (!timer_inited) + reset_timer(); + + /* Only 1ms resolution :-( */ + end = usec / 1000; + while (get_timer(start) < end) + ; +} + +void reset_cpu (ulong ignored) +{ + ulong tc; + + /* Set timer0 to watchdog, and let it timeout */ + tc = ks8695_read(KS8695_TIMER_CTRL) & 0x2; + ks8695_write(KS8695_TIMER_CTRL, tc); + ks8695_write(KS8695_TIMER0, ((10 << 8) | 0xff)); + ks8695_write(KS8695_TIMER_CTRL, (tc | 0x1)); + + /* Should only wait here till watchdog resets */ + for (;;) + ; +} + diff -Naur --exclude=CVS u-boot.cvs/cpu/arm920t/ks8695/lowlevel_init.S u-boot/cpu/arm920t/ks8695/lowlevel_init.S --- u-boot.cvs/cpu/arm920t/ks8695/lowlevel_init.S 1970-01-01 10:00:00.000000000 +1000 +++ u-boot/cpu/arm920t/ks8695/lowlevel_init.S 2005-05-19 23:23:54.000000000 +1000 @@ -0,0 +1,205 @@ +/* + * lowlevel_init.S - basic hardware initialization for the KS8695 CPU + * + * Copyright (c) 2004-2005, Greg Ungerer greg.ungerer@opengear.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/platform.h> + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + +/* + ************************************************************************* + * + * Handy dandy macros + * + ************************************************************************* + */ + +/* Delay a bit */ +.macro DELAY_FOR cycles, reg0 + ldr \reg0, =\cycles + subs \reg0, \reg0, #1 + subne pc, pc, #0xc +.endm + +/* + ************************************************************************* + * + * Some local storage. + * + ************************************************************************* + */ + +/* Should we boot with an interactive console or not */ +.globl serial_console + +/* + ************************************************************************* + * + * Raw hardware initialization code. The important thing is to get + * SDRAM setup and running. We do some other basic things here too, + * like getting the PLL set for high speed, and init the LEDs. + * + ************************************************************************* + */ + +.globl lowlevel_init +lowlevel_init: + +#if DEBUG + /* + * enable UART for early debug trace + */ + ldr r1, =(KS8695_IO_BASE+KS8695_UART_DIVISOR) + mov r2, #0xd9 + str r2, [r1] /* 115200 baud */ + ldr r1, =(KS8695_IO_BASE+KS8695_UART_LINE_CTRL) + mov r2, #0x03 + str r2, [r1] /* 8 data bits, no parity, 1 stop */ + ldr r1, =(KS8695_IO_BASE+KS8695_UART_TX_HOLDING) + mov r2, #0x41 + str r2, [r1] /* write 'A' */ +#endif +#if DEBUG + ldr r1, =(KS8695_IO_BASE+KS8695_UART_TX_HOLDING) + mov r2, #0x42 + str r2, [r1] +#endif + + /* + * remap the memory and flash regions. we want to end up with + * ram from address 0, and flash at 32MB. + */ + ldr r1, =(KS8695_IO_BASE+KS8695_MEM_CTRL0) + ldr r2, =0xbfc00040 + str r2, [r1] /* large flash map */ + ldr pc, =(highflash+0x02000000-0x00f00000) /* jump to high flash address */ +highflash: + ldr r2, =0x8fe00040 + str r2, [r1] /* remap flash range */ + + /* + * remap the second select region to the 4MB immediately after + * the first region. This way if you have a larger flash (say 8Mb) + * then you can have it all mapped nicely. Has no effect if you + * only have a 4Mb or smaller flash. + */ + ldr r1, =(KS8695_IO_BASE+KS8695_MEM_CTRL1) + ldr r2, =0x9fe40040 + str r2, [r1] /* remap flash2 region, contiguous */ + ldr r1, =(KS8695_IO_BASE+KS8695_MEM_GENERAL) + ldr r2, =0x30000005 + str r2, [r1] /* enable both flash selects */ + +#ifdef CONFIG_CM41xx + /* + * map the second flash chip, using the external IO lines. + */ + ldr r1, =(KS8695_IO_BASE+KS8695_IO_CTRL0) + ldr r2, =0xafe80b6d + str r2, [r1] /* remap io0 region, contiguous */ + ldr r1, =(KS8695_IO_BASE+KS8695_IO_CTRL1) + ldr r2, =0xbfec0b6d + str r2, [r1] /* remap io1 region, contiguous */ + ldr r1, =(KS8695_IO_BASE+KS8695_MEM_GENERAL) + ldr r2, =0x30050005 + str r2, [r1] /* enable second flash */ +#endif + + /* + * before relocating, we have to setup RAM timing + */ + ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_CTRL0) +#if (PHYS_SDRAM_1_SIZE == 0x02000000) + ldr r2, =0x7fc0000e /* 32MB */ +#else + ldr r2, =0x3fc0000e /* 16MB */ +#endif + str r2, [r1] /* configure sdram bank0 setup */ + ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_CTRL1) + mov r2, #0 + str r2, [r1] /* configure sdram bank1 setup */ + + ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_GENERAL) + ldr r2, =0x0000000a + str r2, [r1] /* set RAS/CAS timing */ + + ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_BUFFER) + ldr r2, =0x00030000 + str r2, [r1] /* send NOP command */ + DELAY_FOR 0x100, r0 + ldr r2, =0x00010000 + str r2, [r1] /* send PRECHARGE-ALL */ + DELAY_FOR 0x100, r0 + + ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_REFRESH) + ldr r2, =0x00000020 + str r2, [r1] /* set for fast refresh */ + DELAY_FOR 0x100, r0 + ldr r2, =0x00000190 + str r2, [r1] /* set normal refresh timing */ + + ldr r1, =(KS8695_IO_BASE+KS8695_SDRAM_BUFFER) + ldr r2, =0x00020033 + str r2, [r1] /* send mode command */ + DELAY_FOR 0x100, r0 + ldr r2, =0x01f00000 + str r2, [r1] /* enable sdram fifos */ + + /* + * set pll to top speed + */ + ldr r1, =(KS8695_IO_BASE+KS8695_SYSTEN_BUS_CLOCK) + mov r2, #0 + str r2, [r1] /* set pll clock to 166MHz */ + + ldr r1, =(KS8695_IO_BASE+KS8695_SWITCH_CTRL0) + ldr r2, [r1] /* Get switch ctrl0 register */ + and r2, r2, #0x0fc00000 /* Mask out LED control bits */ + orr r2, r2, #0x01800000 /* Set Link/activity/speed actions */ + str r2, [r1] + +#ifdef CONFIG_CM4008 + ldr r1, =(KS8695_IO_BASE+KS8695_GPIO_MODE) + ldr r2, =0x0000fe30 + str r2, [r1] /* enable LED's as outputs */ + ldr r1, =(KS8695_IO_BASE+KS8695_GPIO_DATA) + ldr r2, =0x0000fe20 + str r2, [r1] /* turn on power LED */ +#endif +#if defined(CONFIG_CM4008) || defined(CONFIG_CM41xx) + ldr r2, [r1] /* get current GPIO input data */ + tst r2, #0x8 /* check if "erase" depressed */ + beq nobutton + mov r2, #0 /* be quiet on boot, no console */ + ldr r1, =serial_console + str r2, [r1] +nobutton: +#endif + + add lr, lr, #0x02000000 /* flash is now mapped high */ + add ip, ip, #0x02000000 /* this is a hack */ + mov pc, lr /* all done, return */ + +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ diff -Naur --exclude=CVS u-boot.cvs/cpu/arm920t/ks8695/Makefile u-boot/cpu/arm920t/ks8695/Makefile --- u-boot.cvs/cpu/arm920t/ks8695/Makefile 1970-01-01 10:00:00.000000000 +1000 +++ u-boot/cpu/arm920t/ks8695/Makefile 2005-05-19 21:46:13.000000000 +1000 @@ -0,0 +1,43 @@ +# +# (C) Copyright 2000-2005 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = lib$(SOC).a + +OBJS = interrupts.o serial.o +SOBJS = lowlevel_init.o + +all: .depend $(LIB) + +$(LIB): $(OBJS) $(SOBJS) + $(AR) crv $@ $(OBJS) $(SOBJS) + +######################################################################### + +.depend: Makefile $(OBJS:.o=.c) + $(CC) -M $(CFLAGS) $(OBJS:.o=.c) > $@ + +sinclude .depend + +######################################################################### diff -Naur --exclude=CVS u-boot.cvs/cpu/arm920t/ks8695/serial.c u-boot/cpu/arm920t/ks8695/serial.c --- u-boot.cvs/cpu/arm920t/ks8695/serial.c 1970-01-01 10:00:00.000000000 +1000 +++ u-boot/cpu/arm920t/ks8695/serial.c 2005-05-19 22:38:26.000000000 +1000 @@ -0,0 +1,116 @@ +/* + * serial.c -- KS8695 serial driver + * + * (C) Copyright 2004, Greg Ungerer greg.ungerer@opengear.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/platform.h> + +#ifndef CONFIG_SERIAL1 +#error "Bad: you didn't configure serial ..." +#endif + +/* + * Define the UART hardware register access structure. + */ +struct ks8695uart { + unsigned int RX; /* 0x00 - Receive data (r) */ + unsigned int TX; /* 0x04 - Transmit data (w) */ + unsigned int FCR; /* 0x08 - Fifo Control (r/w) */ + unsigned int LCR; /* 0x0c - Line Control (r/w) */ + unsigned int MCR; /* 0x10 - Modem Control (r/w) */ + unsigned int LSR; /* 0x14 - Line Status (r/w) */ + unsigned int MSR; /* 0x18 - Modem Status (r/w) */ + unsigned int BD; /* 0x1c - Baud Rate (r/w) */ + unsigned int SR; /* 0x20 - Status (r/w) */ +}; + +#define KS8695_UART_ADDR ((void *) (KS8695_IO_BASE + KS8695_UART_RX_BUFFER)) +#define KS8695_UART_CLK 25000000 + + +/* + * Under some circumstances we want to be "quiet" and not issue any + * serial output - though we want u-boot to otherwise work and behave + * the same. By default be noisy. + */ +int serial_console = 1; + + +void serial_setbrg(void) +{ + DECLARE_GLOBAL_DATA_PTR; + volatile struct ks8695uart *uartp = KS8695_UART_ADDR; + + /* Set to global baud rate and 8 data bits, no parity, 1 stop bit*/ + uartp->BD = KS8695_UART_CLK / gd->baudrate; + uartp->LCR = KS8695_UART_LINEC_WLEN8; +} + +int serial_init(void) +{ + serial_console = 1; + serial_setbrg(); + return 0; +} + +void serial_raw_putc(const char c) +{ + volatile struct ks8695uart *uartp = KS8695_UART_ADDR; + int i; + + for (i = 0; (i < 0x100000); i++) { + if (uartp->LSR & KS8695_UART_LINES_TXFE) + break; + } + + uartp->TX = c; +} + +void serial_putc(const char c) +{ + if (serial_console) { + serial_raw_putc(c); + if (c == '\n') + serial_raw_putc('\r'); + } +} + +int serial_tstc(void) +{ + volatile struct ks8695uart *uartp = KS8695_UART_ADDR; + if (serial_console) + return ((uartp->LSR & KS8695_UART_LINES_RXFE) ? 1 : 0); + return 0; +} + +void serial_puts(const char *s) +{ + char c; + while ((c = *s++) != 0) + serial_putc(c); +} + +int serial_getc(void) +{ + volatile struct ks8695uart *uartp = KS8695_UART_ADDR; + + while ((uartp->LSR & KS8695_UART_LINES_RXFE) == 0) + ; + return (uartp->RX); +} diff -Naur --exclude=CVS u-boot.cvs/CREDITS u-boot/CREDITS --- u-boot.cvs/CREDITS 2005-05-19 20:57:30.000000000 +1000 +++ u-boot/CREDITS 2005-05-20 00:00:53.000000000 +1000 @@ -394,6 +394,10 @@ E: runet@innovsys.com D: Support for Motorola MPC8266ADS board
+N: Greg Ungerer +E: greg.ungerer@opengear.com +D: Support for ks8695 CPU, and OpenGear cmXXXX boards + N: David Updegraff E: dave@cray.com D: Port to Cray L1 board; DHCP vendor extensions diff -Naur --exclude=CVS u-boot.cvs/drivers/ks8695eth.c u-boot/drivers/ks8695eth.c --- u-boot.cvs/drivers/ks8695eth.c 1970-01-01 10:00:00.000000000 +1000 +++ u-boot/drivers/ks8695eth.c 2005-05-19 21:07:01.000000000 +1000 @@ -0,0 +1,244 @@ +/* + * ks8695eth.c -- KS8695 ethernet driver + * + * (C) Copyright 2004-2005, Greg Ungerer greg.ungerer@opengear.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ + +/****************************************************************************/ + +#include <common.h> +#include <malloc.h> +#include <net.h> +#include <asm/io.h> +#include <asm/arch/platform.h> + +/****************************************************************************/ + +/* + * Hardware register access to the KS8695 LAN ethernet port + * (well, it is the 4 port switch really). + */ +#define ks8695_read(a) *((volatile unsigned long *) (KS8695_IO_BASE + (a))) +#define ks8695_write(a,v) *((volatile unsigned long *) (KS8695_IO_BASE + (a))) = (v) + +/****************************************************************************/ + +/* + * Define the descriptor in-memory data structures. + */ +struct ks8695_txdesc { + uint32_t owner; + uint32_t ctrl; + uint32_t addr; + uint32_t next; +}; + +struct ks8695_rxdesc { + uint32_t status; + uint32_t ctrl; + uint32_t addr; + uint32_t next; +}; + +/****************************************************************************/ + +/* + * Allocate local data structures to use for receiving and sending + * packets. Just to keep it all nice and simple. + */ + +#define TXDESCS 4 +#define RXDESCS 4 +#define BUFSIZE 2048 + +volatile struct ks8695_txdesc ks8695_tx[TXDESCS] __attribute__((aligned(256))); +volatile struct ks8695_rxdesc ks8695_rx[RXDESCS] __attribute__((aligned(256))); +volatile uint8_t ks8695_bufs[BUFSIZE*(TXDESCS+RXDESCS)] __attribute__((aligned(2048)));; + +/****************************************************************************/ + +/* + * Ideally we want to use the MAC address stored in flash. + * But we do some sanity checks in case they are not present + * first. + */ +unsigned char eth_mac[] = { + 0x00, 0x13, 0xc6, 0x00, 0x00, 0x00 +}; + +void ks8695_getmac(void) +{ + unsigned char *fp; + int i; + + /* Check if flash MAC is valid */ + fp = (unsigned char *) 0x0201c000; + for (i = 0; (i < 6); i++) { + if ((fp[i] != 0) && (fp[i] != 0xff)) + break; + } + + /* If we found a valid looking MAC address then use it */ + if (i < 6) + memcpy(ð_mac[0], fp, 6); +} + +/****************************************************************************/ + +void eth_reset(bd_t *bd) +{ + int i; + +#if 0 + printf("%s(%d): eth_reset()\n", __FILE__, __LINE__); +#endif + + /* Reset the ethernet engines first */ + ks8695_write(KS8695_LAN_DMA_TX, 0x80000000); + ks8695_write(KS8695_LAN_DMA_RX, 0x80000000); + + ks8695_getmac(); + + /* Set MAC address */ + ks8695_write(KS8695_LAN_MAC_LOW, (eth_mac[5] | (eth_mac[4] << 8) | + (eth_mac[3] << 16) | (eth_mac[2] << 24))); + ks8695_write(KS8695_LAN_MAC_HIGH, (eth_mac[1] | (eth_mac[0] << 8))); + + /* Turn the 4 port switch on */ + i = ks8695_read(KS8695_SWITCH_CTRL0); + ks8695_write(KS8695_SWITCH_CTRL0, (i | 0x1)); + //ks8695_write(KS8695_WAN_CONTROL, 0x3f000066); + + /* Initialize descriptor rings */ + for (i = 0; (i < TXDESCS); i++) { + ks8695_tx[i].owner = 0; + ks8695_tx[i].ctrl = 0; + ks8695_tx[i].addr = (uint32_t) &ks8695_bufs[i*BUFSIZE]; + ks8695_tx[i].next = (uint32_t) &ks8695_tx[i+1]; + } + ks8695_tx[TXDESCS-1].ctrl = 0x02000000; + ks8695_tx[TXDESCS-1].next = (uint32_t) &ks8695_tx[0]; + + for (i = 0; (i < RXDESCS); i++) { + ks8695_rx[i].status = 0x80000000; + ks8695_rx[i].ctrl = BUFSIZE - 4; + ks8695_rx[i].addr = (uint32_t) &ks8695_bufs[(i+TXDESCS)*BUFSIZE]; + ks8695_rx[i].next = (uint32_t) &ks8695_rx[i+1]; + } + ks8695_rx[RXDESCS-1].ctrl |= 0x00080000; + ks8695_rx[RXDESCS-1].next = (uint32_t) &ks8695_rx[0]; + + /* The KS8695 is pretty slow reseting the ethernets... */ + udelay(2000000); + + /* Enable the ethernet engine */ + ks8695_write(KS8695_LAN_TX_LIST, (uint32_t) &ks8695_tx[0]); + ks8695_write(KS8695_LAN_RX_LIST, (uint32_t) &ks8695_rx[0]); + ks8695_write(KS8695_LAN_DMA_TX, 0x3); + ks8695_write(KS8695_LAN_DMA_RX, 0x71); + ks8695_write(KS8695_LAN_DMA_RX_START, 0x1); + + printf("KS8695 ETHERNET: "); + for (i = 0; (i < 5); i++) { + bd->bi_enetaddr[i] = eth_mac[i]; + printf("%02x:", eth_mac[i]); + } + bd->bi_enetaddr[i] = eth_mac[i]; + printf("%02x\n", eth_mac[i]); +} + +/****************************************************************************/ + +int eth_init(bd_t *bd) +{ +#if 0 + printf("%s(%d): eth_init()\n", __FILE__, __LINE__); +#endif + eth_reset(bd); + return 0; +} + +/****************************************************************************/ + +void eth_halt(void) +{ +#if 0 + printf("%s(%d): eth_halt()\n", __FILE__, __LINE__); +#endif + /* Reset the ethernet engines */ + ks8695_write(KS8695_LAN_DMA_TX, 0x80000000); + ks8695_write(KS8695_LAN_DMA_RX, 0x80000000); +} + +/****************************************************************************/ + +int eth_rx(void) +{ + volatile struct ks8695_rxdesc *dp; + int i, len = 0; + +#if 0 + printf("%s(%d): eth_rx()\n", __FILE__, __LINE__); +#endif + + for (i = 0; (i < RXDESCS); i++) { + dp= &ks8695_rx[i]; + if ((dp->status & 0x80000000) == 0) { + len = (dp->status & 0x7ff) - 4; + NetReceive((void *) dp->addr, len); + dp->status = 0x80000000; + ks8695_write(KS8695_LAN_DMA_RX_START, 0x1); + break; + } + } + + return len; +} + +/****************************************************************************/ + +int eth_send(volatile void *packet, int len) +{ + volatile struct ks8695_txdesc *dp; + static int next = 0; + +#if 0 + printf("%s(%d): eth_send(packet=%x,len=%d)\n", __FILE__, __LINE__, + packet, len); +#endif + + dp = &ks8695_tx[next]; + memcpy((void *) dp->addr, packet, len); + + if (len < 64) { + memset(dp->addr+len, 0, 64-len); + len = 64; + } + + dp->ctrl = len | 0xe0000000; + dp->owner = 0x80000000; + + ks8695_write(KS8695_LAN_DMA_TX, 0x3); + ks8695_write(KS8695_LAN_DMA_TX_START, 0x1); + + if (++next >= TXDESCS) + next = 0; + + return len; +} + +/****************************************************************************/ diff -Naur --exclude=CVS u-boot.cvs/drivers/Makefile u-boot/drivers/Makefile --- u-boot.cvs/drivers/Makefile 2005-05-19 20:57:36.000000000 +1000 +++ u-boot/drivers/Makefile 2005-05-19 21:08:29.000000000 +1000 @@ -47,7 +47,8 @@ status_led.o sym53c8xx.o \ ti_pci1410a.o tigon3.o \ usbdcore.o usbdcore_ep0.o usbdcore_omap1510.o usbtty.o \ - videomodes.o w83c553f.o + videomodes.o w83c553f.o \ + ks8695eth.o
all: $(LIB)
diff -Naur --exclude=CVS u-boot.cvs/include/asm-arm/arch-ks8695/platform.h u-boot/include/asm-arm/arch-ks8695/platform.h --- u-boot.cvs/include/asm-arm/arch-ks8695/platform.h 1970-01-01 10:00:00.000000000 +1000 +++ u-boot/include/asm-arm/arch-ks8695/platform.h 2005-05-19 21:07:01.000000000 +1000 @@ -0,0 +1,306 @@ +/* + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA + */ +#ifndef __address_h +#define __address_h 1 + +#define KS8695_SDRAM_START 0x00000000 +#define KS8695_SDRAM_SIZE 0x01000000 +#define KS8695_MEM_SIZE KS8695_SDRAM_SIZE +#define KS8695_MEM_START KS8695_SDRAM_START + +#define KS8695_PCMCIA_IO_BASE 0x03800000 +#define KS8695_PCMCIA_IO_SIZE 0x00040000 + +#define KS8695_IO_BASE 0x03FF0000 +#define KS8695_IO_SIZE 0x00010000 + +#define KS8695_SYSTEN_CONFIG 0x00 +#define KS8695_SYSTEN_BUS_CLOCK 0x04 + +#define KS8695_FLASH_START 0x02800000 +#define KS8695_FLASH_SIZE 0x00400000 + +/*i/o control registers offset difinitions*/ +#define KS8695_IO_CTRL0 0x4000 +#define KS8695_IO_CTRL1 0x4004 +#define KS8695_IO_CTRL2 0x4008 +#define KS8695_IO_CTRL3 0x400C + +/*memory control registers offset difinitions*/ +#define KS8695_MEM_CTRL0 0x4010 +#define KS8695_MEM_CTRL1 0x4014 +#define KS8695_MEM_CTRL2 0x4018 +#define KS8695_MEM_CTRL3 0x401C +#define KS8695_MEM_GENERAL 0x4020 +#define KS8695_SDRAM_CTRL0 0x4030 +#define KS8695_SDRAM_CTRL1 0x4034 +#define KS8695_SDRAM_GENERAL 0x4038 +#define KS8695_SDRAM_BUFFER 0x403C +#define KS8695_SDRAM_REFRESH 0x4040 + +/*WAN control registers offset difinitions*/ +#define KS8695_WAN_DMA_TX 0x6000 +#define KS8695_WAN_DMA_RX 0x6004 +#define KS8695_WAN_DMA_TX_START 0x6008 +#define KS8695_WAN_DMA_RX_START 0x600C +#define KS8695_WAN_TX_LIST 0x6010 +#define KS8695_WAN_RX_LIST 0x6014 +#define KS8695_WAN_MAC_LOW 0x6018 +#define KS8695_WAN_MAC_HIGH 0x601C +#define KS8695_WAN_MAC_ELOW 0x6080 +#define KS8695_WAN_MAC_EHIGH 0x6084 + +/*LAN control registers offset difinitions*/ +#define KS8695_LAN_DMA_TX 0x8000 +#define KS8695_LAN_DMA_RX 0x8004 +#define KS8695_LAN_DMA_TX_START 0x8008 +#define KS8695_LAN_DMA_RX_START 0x800C +#define KS8695_LAN_TX_LIST 0x8010 +#define KS8695_LAN_RX_LIST 0x8014 +#define KS8695_LAN_MAC_LOW 0x8018 +#define KS8695_LAN_MAC_HIGH 0x801C +#define KS8695_LAN_MAC_ELOW 0X8080 +#define KS8695_LAN_MAC_EHIGH 0X8084 + +/*HPNA control registers offset difinitions*/ +#define KS8695_HPNA_DMA_TX 0xA000 +#define KS8695_HPNA_DMA_RX 0xA004 +#define KS8695_HPNA_DMA_TX_START 0xA008 +#define KS8695_HPNA_DMA_RX_START 0xA00C +#define KS8695_HPNA_TX_LIST 0xA010 +#define KS8695_HPNA_RX_LIST 0xA014 +#define KS8695_HPNA_MAC_LOW 0xA018 +#define KS8695_HPNA_MAC_HIGH 0xA01C +#define KS8695_HPNA_MAC_ELOW 0xA080 +#define KS8695_HPNA_MAC_EHIGH 0xA084 + +/*UART control registers offset difinitions*/ +#define KS8695_UART_RX_BUFFER 0xE000 +#define KS8695_UART_TX_HOLDING 0xE004 + +#define KS8695_UART_FIFO_CTRL 0xE008 +#define KS8695_UART_FIFO_TRIG01 0x00 +#define KS8695_UART_FIFO_TRIG04 0x80 +#define KS8695_UART_FIFO_TXRST 0x03 +#define KS8695_UART_FIFO_RXRST 0x02 +#define KS8695_UART_FIFO_FEN 0x01 + +#define KS8695_UART_LINE_CTRL 0xE00C +#define KS8695_UART_LINEC_BRK 0x40 +#define KS8695_UART_LINEC_EPS 0x10 +#define KS8695_UART_LINEC_PEN 0x08 +#define KS8695_UART_LINEC_STP2 0x04 +#define KS8695_UART_LINEC_WLEN8 0x03 +#define KS8695_UART_LINEC_WLEN7 0x02 +#define KS8695_UART_LINEC_WLEN6 0x01 +#define KS8695_UART_LINEC_WLEN5 0x00 + +#define KS8695_UART_MODEM_CTRL 0xE010 +#define KS8695_UART_MODEMC_RTS 0x02 +#define KS8695_UART_MODEMC_DTR 0x01 + +#define KS8695_UART_LINE_STATUS 0xE014 +#define KS8695_UART_LINES_TXFE 0x20 +#define KS8695_UART_LINES_BE 0x10 +#define KS8695_UART_LINES_FE 0x08 +#define KS8695_UART_LINES_PE 0x04 +#define KS8695_UART_LINES_OE 0x02 +#define KS8695_UART_LINES_RXFE 0x01 +#define KS8695_UART_LINES_ANY (KS8695_UART_LINES_OE|KS8695_UART_LINES_BE|KS8695_UART_LINES_PE|KS8695_UART_LINES_FE) + +#define KS8695_UART_MODEM_STATUS 0xE018 +#define KS8695_UART_MODEM_DCD 0x80 +#define KS8695_UART_MODEM_DSR 0x20 +#define KS8695_UART_MODEM_CTS 0x10 +#define KS8695_UART_MODEM_DDCD 0x08 +#define KS8695_UART_MODEM_DDSR 0x02 +#define KS8695_UART_MODEM_DCTS 0x01 +#define UART8695_MODEM_ANY 0xFF + +#define KS8695_UART_DIVISOR 0xE01C +#define KS8695_UART_STATUS 0xE020 + +/*Interrupt controlller registers offset difinitions*/ +#define KS8695_INT_CONTL 0xE200 +#define KS8695_INT_ENABLE 0xE204 +#define KS8695_INT_ENABLE_MODEM 0x0800 +#define KS8695_INT_ENABLE_ERR 0x0400 +#define KS8695_INT_ENABLE_RX 0x0200 +#define KS8695_INT_ENABLE_TX 0x0100 + +#define KS8695_INT_STATUS 0xE208 +#define KS8695_INT_WAN_PRIORITY 0xE20C +#define KS8695_INT_HPNA_PRIORITY 0xE210 +#define KS8695_INT_LAN_PRIORITY 0xE214 +#define KS8695_INT_TIMER_PRIORITY 0xE218 +#define KS8695_INT_UART_PRIORITY 0xE21C +#define KS8695_INT_EXT_PRIORITY 0xE220 +#define KS8695_INT_CHAN_PRIORITY 0xE224 +#define KS8695_INT_BUSERROR_PRO 0xE228 +#define KS8695_INT_MASK_STATUS 0xE22C +#define KS8695_FIQ_PEND_PRIORITY 0xE230 +#define KS8695_IRQ_PEND_PRIORITY 0xE234 + +/*timer registers offset difinitions*/ +#define KS8695_TIMER_CTRL 0xE400 +#define KS8695_TIMER1 0xE404 +#define KS8695_TIMER0 0xE408 +#define KS8695_TIMER1_PCOUNT 0xE40C +#define KS8695_TIMER0_PCOUNT 0xE410 + +/*GPIO registers offset difinitions*/ +#define KS8695_GPIO_MODE 0xE600 +#define KS8695_GPIO_CTRL 0xE604 +#define KS8695_GPIO_DATA 0xE608 + +/*SWITCH registers offset difinitions*/ +#define KS8695_SWITCH_CTRL0 0xE800 +#define KS8695_SWITCH_CTRL1 0xE804 +#define KS8695_SWITCH_PORT1 0xE808 +#define KS8695_SWITCH_PORT2 0xE80C +#define KS8695_SWITCH_PORT3 0xE810 +#define KS8695_SWITCH_PORT4 0xE814 +#define KS8695_SWITCH_PORT5 0xE818 +#define KS8695_SWITCH_AUTO0 0xE81C +#define KS8695_SWITCH_AUTO1 0xE820 +#define KS8695_SWITCH_LUE_CTRL 0xE824 +#define KS8695_SWITCH_LUE_HIGH 0xE828 +#define KS8695_SWITCH_LUE_LOW 0xE82C +#define KS8695_SWITCH_ADVANCED 0xE830 + +#define KS8695_SWITCH_LPPM12 0xE874 +#define KS8695_SWITCH_LPPM34 0xE878 + +/*host communication registers difinitions*/ +#define KS8695_DSCP_HIGH 0xE834 +#define KS8695_DSCP_LOW 0xE838 +#define KS8695_SWITCH_MAC_HIGH 0xE83C +#define KS8695_SWITCH_MAC_LOW 0xE840 + +/*miscellaneours registers difinitions*/ +#define KS8695_MANAGE_COUNTER 0xE844 +#define KS8695_MANAGE_DATA 0xE848 +#define KS8695_LAN12_POWERMAGR 0xE84C +#define KS8695_LAN34_POWERMAGR 0xE850 + +#define KS8695_DEVICE_ID 0xEA00 +#define KS8695_REVISION_ID 0xEA04 + +#define KS8695_MISC_CONTROL 0xEA08 +#define KS8695_WAN_CONTROL 0xEA0C +#define KS8695_WAN_POWERMAGR 0xEA10 +#define KS8695_WAN_PHY_CONTROL 0xEA14 +#define KS8695_WAN_PHY_STATUS 0xEA18 + +/* bus clock definitions*/ +#define KS8695_BUS_CLOCK_125MHZ 0x0 +#define KS8695_BUS_CLOCK_100MHZ 0x1 +#define KS8695_BUS_CLOCK_62MHZ 0x2 +#define KS8695_BUS_CLOCK_50MHZ 0x3 +#define KS8695_BUS_CLOCK_41MHZ 0x4 +#define KS8695_BUS_CLOCK_33MHZ 0x5 +#define KS8695_BUS_CLOCK_31MHZ 0x6 +#define KS8695_BUS_CLOCK_25MHZ 0x7 + +/* ------------------------------------------------------------------------------- + * definations for IRQ + * -------------------------------------------------------------------------------*/ + +#define KS8695_INT_EXT_INT0 2 +#define KS8695_INT_EXT_INT1 3 +#define KS8695_INT_EXT_INT2 4 +#define KS8695_INT_EXT_INT3 5 +#define KS8695_INT_TIMERINT0 6 +#define KS8695_INT_TIMERINT1 7 +#define KS8695_INT_UART_TX 8 +#define KS8695_INT_UART_RX 9 +#define KS8695_INT_UART_LINE_ERR 10 +#define KS8695_INT_UART_MODEMS 11 +#define KS8695_INT_LAN_STOP_RX 12 +#define KS8695_INT_LAN_STOP_TX 13 +#define KS8695_INT_LAN_BUF_RX_STATUS 14 +#define KS8695_INT_LAN_BUF_TX_STATUS 15 +#define KS8695_INT_LAN_RX_STATUS 16 +#define KS8695_INT_LAN_TX_STATUS 17 +#define KS8695_INT_HPAN_STOP_RX 18 +#define KS8695_INT_HPNA_STOP_TX 19 +#define KS8695_INT_HPNA_BUF_RX_STATUS 20 +#define KS8695_INT_HPNA_BUF_TX_STATUS 21 +#define KS8695_INT_HPNA_RX_STATUS 22 +#define KS8695_INT_HPNA_TX_STATUS 23 +#define KS8695_INT_BUS_ERROR 24 +#define KS8695_INT_WAN_STOP_RX 25 +#define KS8695_INT_WAN_STOP_TX 26 +#define KS8695_INT_WAN_BUF_RX_STATUS 27 +#define KS8695_INT_WAN_BUF_TX_STATUS 28 +#define KS8695_INT_WAN_RX_STATUS 29 +#define KS8695_INT_WAN_TX_STATUS 30 + +#define KS8695_INT_UART KS8695_INT_UART_TX + +/* ------------------------------------------------------------------------------- + * Interrupt bit positions + * + * ------------------------------------------------------------------------------- + */ + +#define KS8695_INTMASK_EXT_INT0 ( 1 << KS8695_INT_EXT_INT0 ) +#define KS8695_INTMASK_EXT_INT1 ( 1 << KS8695_INT_EXT_INT1 ) +#define KS8695_INTMASK_EXT_INT2 ( 1 << KS8695_INT_EXT_INT2 ) +#define KS8695_INTMASK_EXT_INT3 ( 1 << KS8695_INT_EXT_INT3 ) +#define KS8695_INTMASK_TIMERINT0 ( 1 << KS8695_INT_TIMERINT0 ) +#define KS8695_INTMASK_TIMERINT1 ( 1 << KS8695_INT_TIMERINT1 ) +#define KS8695_INTMASK_UART_TX ( 1 << KS8695_INT_UART_TX ) +#define KS8695_INTMASK_UART_RX ( 1 << KS8695_INT_UART_RX ) +#define KS8695_INTMASK_UART_LINE_ERR ( 1 << KS8695_INT_UART_LINE_ERR ) +#define KS8695_INTMASK_UART_MODEMS ( 1 << KS8695_INT_UART_MODEMS ) +#define KS8695_INTMASK_LAN_STOP_RX ( 1 << KS8695_INT_LAN_STOP_RX ) +#define KS8695_INTMASK_LAN_STOP_TX ( 1 << KS8695_INT_LAN_STOP_TX ) +#define KS8695_INTMASK_LAN_BUF_RX_STATUS ( 1 << KS8695_INT_LAN_BUF_RX_STATUS ) +#define KS8695_INTMASK_LAN_BUF_TX_STATUS ( 1 << KS8695_INT_LAN_BUF_TX_STATUS ) +#define KS8695_INTMASK_LAN_RX_STATUS ( 1 << KS8695_INT_LAN_RX_STATUS ) +#define KS8695_INTMASK_LAN_TX_STATUS ( 1 << KS8695_INT_LAN_RX_STATUS ) +#define KS8695_INTMASK_HPAN_STOP_RX ( 1 << KS8695_INT_HPAN_STOP_RX ) +#define KS8695_INTMASK_HPNA_STOP_TX ( 1 << KS8695_INT_HPNA_STOP_TX ) +#define KS8695_INTMASK_HPNA_BUF_RX_STATUS ( 1 << KS8695_INT_HPNA_BUF_RX_STATUS ) +#define KS8695_INTMAKS_HPNA_BUF_TX_STATUS ( 1 << KS8695_INT_HPNA_BUF_TX_STATUS +#define KS8695_INTMASK_HPNA_RX_STATUS ( 1 << KS8695_INT_HPNA_RX_STATUS ) +#define KS8695_INTMASK_HPNA_TX_STATUS ( 1 << KS8695_INT_HPNA_TX_STATUS ) +#define KS8695_INTMASK_BUS_ERROR ( 1 << KS8695_INT_BUS_ERROR ) +#define KS8695_INTMASK_WAN_STOP_RX ( 1 << KS8695_INT_WAN_STOP_RX ) +#define KS8695_INTMASK_WAN_STOP_TX ( 1 << KS8695_INT_WAN_STOP_TX ) +#define KS8695_INTMASK_WAN_BUF_RX_STATUS ( 1 << KS8695_INT_WAN_BUF_RX_STATUS ) +#define KS8695_INTMASK_WAN_BUF_TX_STATUS ( 1 << KS8695_INT_WAN_BUF_TX_STATUS ) +#define KS8695_INTMASK_WAN_RX_STATUS ( 1 << KS8695_INT_WAN_RX_STATUS ) +#define KS8695_INTMASK_WAN_TX_STATUS ( 1 << KS8695_INT_WAN_TX_STATUS ) + +#define KS8695_SC_VALID_INT 0xFFFFFFFF +#define MAXIRQNUM 31 + +/* + * Timer definitions + * + * Use timer 1 & 2 + * (both run at 25MHz). + * + */ +#define TICKS_PER_uSEC 25 +#define mSEC_1 1000 +#define mSEC_10 (mSEC_1 * 10) + +#endif + +/* END */ diff -Naur --exclude=CVS u-boot.cvs/MAINTAINERS u-boot/MAINTAINERS --- u-boot.cvs/MAINTAINERS 2005-05-19 20:57:30.000000000 +1000 +++ u-boot/MAINTAINERS 2005-05-19 23:59:11.000000000 +1000 @@ -413,6 +413,12 @@
B2 ARM7TDMI (S3C44B0X)
+Greg Ungerer greg.ungerer@opengear.com + + cm4008 ks8695p + cm4116 ks8695p + cm4148 ks8695p + Alex Züpke azu@sysgo.de
lart SA1100
Dear Greg,
Much better :-)
The subject ("[PATCH 1/2]") indicates that there is a second part to follow - is there? I don't see any obvious stuff missing?
* Patch by Greg Ungerer, 19 May 2005: - add support for the KS8695P (ARM 922 based) CPU - add support for the OpenGear CM4008, CM4116 and CM4148 boards
Checked in, thanks.
But please stick to the Coding Style: don't add trailing white space to files (cpu/arm920t/ks8695/lowlevel_init.S, include/asm-arm/arch-ks8695/platform.h), don't add trailing empty lines (cpu/arm920t/ks8695/interrupts.c), and don't use C++ comments (drivers/ks8695eth.c).
And instead of
#if 0 printf(...); #endif
you could simply write
debug (...);
which is easier to read and to enable if needed.
Dear Greg,
Much better :-)
Really? (o;
"drivers/ks8695eth.c" includes "asm/arch/platform.h" which not all boards have...especially not with the defines this driver requires...
best regards rick
Dear Greg,
in message <r02010500-1041-5A1EF226C91011D9BF6200039387ACB6@[10.0.1.1]> Richard Klinger wrote:
Much better :-)
Really? (o;
He is right: your code breaks ALL other ARM boards:
-> MAKEALL arm Configuring for assabet board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory Configuring for dnp1110 board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory Configuring for gcplus board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory Configuring for lart board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory Configuring for shannon board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory Configuring for B2 board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory Configuring for ep7312 board... ks8695eth.c:27:31: asm/arch/platform.h: No such file or directory make[1]: *** [.depend] Error 1 make: *** [drivers/libdrivers.a] Error 2 arm-linux-size: u-boot: No such file or directory ...
etc.
Didn't you run MAKEALL before submitting your patches? Grrrrghhh!
Please fix ASAP!!!
Dear Greg,
Much better :-)
Really? (o;
Ok, it makes no sense (at least currently) to be compiling this driver for any configuration not based on the KS8695 CPU. So the simple fix is to define it out.
--- u-boot/drivers/ks8695eth.c.org 2005-05-23 11:02:44.877332792 +1000 +++ u-boot/drivers/ks8695eth.c 2005-05-23 11:02:33.722028656 +1000 @@ -24,6 +24,11 @@ #include <malloc.h> #include <net.h> #include <asm/io.h> + +/****************************************************************************/ +#ifdef CONFIG_KS8695 +/****************************************************************************/ + #include <asm/arch/platform.h>
/****************************************************************************/ @@ -234,3 +239,4 @@ }
/****************************************************************************/ +#endif /* CONFIG_KS8695 */
Well, I don't get clean results for it, and I haven't investiagted why yet... Can I trust it??
Configuring for assabet board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_modsi3.o) uses hardware FP, whereas u-boot uses software FP File in wrong format: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_modsi3.o) make: *** [u-boot] Error 1 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for dnp1110 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for gcplus board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for lart board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for shannon board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for B2 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for ep7312 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for evb4510 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for impa7 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for modnet50 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for at91rm9200dk board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) uses hardware FP, whereas u-boot uses software FP File in wrong format: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) make: *** [u-boot] Error 1 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for cmc_pu2 board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) uses hardware FP, whereas u-boot uses software FP File in wrong format: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) make: *** [u-boot] Error 1 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for integratorcp board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for integratorap board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for lpd7a400 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for mx1ads board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for mx1fs2 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for omap1510inn board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_modsi3.o) uses hardware FP, whereas u-boot uses software FP File in wrong format: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_modsi3.o) make: *** [u-boot] Error 1 ./MAKEALL: line 243: ppc_8xx-size: command not found ... configured for CS3 boot Configuring for omap1610h2 board... ./MAKEALL: line 243: ppc_8xx-size: command not found ... configured for CS3 boot Configuring for omap1610inn board... ./MAKEALL: line 243: ppc_8xx-size: command not found ... configured for CS3 boot Configuring for omap730p2 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for scb9328 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for smdk2400 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for smdk2410 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for trab board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivsi3.o) uses hardware FP, whereas trab_fkt uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivsi3.o) arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_umodsi3.o) uses hardware FP, whereas trab_fkt uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_umodsi3.o) arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_dvmd_lnx.o) uses hardware FP, whereas trab_fkt uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_dvmd_lnx.o) arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivdi3.o) uses hardware FP, whereas trab_fkt uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivdi3.o) arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_clz.o) uses hardware FP, whereas trab_fkt uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_clz.o) make[1]: *** [trab_fkt.srec] Error 1 make: *** [board/trab/libtrab.a] Error 2 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for VCMA9 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for versatile board... ./MAKEALL: line 243: ppc_8xx-size: command not found ... boot from upper flash bank Configuring for voiceblue board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivsi3.o) uses hardware FP, whereas eeprom uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_udivsi3.o) arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_umodsi3.o) uses hardware FP, whereas eeprom uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_umodsi3.o) arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_dvmd_lnx.o) uses hardware FP, whereas eeprom uses software FP Success: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_dvmd_lnx.o) make[1]: *** [eeprom.srec] Error 1 make: *** [board/voiceblue/libvoiceblue.a] Error 2 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for omap2420h4 board... arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) uses FPA instructions, whereas u-boot does not arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) uses hardware FP, whereas u-boot uses software FP File in wrong format: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_divsi3.o) make: *** [u-boot] Error 1 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for adsvix board... pcmcia.c:39:2: warning: #warning "Board will only supply 5V, wait for next HW spin for selectable power" cmd_pcmcia.c: In function `pcmcia_on': cmd_pcmcia.c:343: warning: operation on `i' may be undefined cmd_pcmcia.c: At top level: cmd_pcmcia.c:305: warning: `hardware_disable' defined but not used cmd_pcmcia.c:300: warning: `hardware_enable' defined but not used cmd_pcmcia.c:310: warning: `voltage_set' defined but not used arm-linux-ld: ERROR: /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_modsi3.o) uses hardware FP, whereas u-boot uses software FP File in wrong format: failed to merge target specific data of file /usr/local/lib/gcc-lib/arm-linux/3.3.2/libgcc.a(_modsi3.o) make: *** [u-boot] Error 1 ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for cerf250 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for cradle board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for csb226 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for innokom board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for lubbock board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for wepep250 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for xaeniax board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for xm250 board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for xsengine board... ./MAKEALL: line 243: ppc_8xx-size: command not found Configuring for ixdp425 board... pci_indirect.c: In function `indirect_read_config_byte': pci_indirect.c:94: warning: passing arg 1 of `in_8' from incompatible pointer type pci_indirect.c: In function `indirect_read_config_word': pci_indirect.c:95: warning: passing arg 1 of `in_le16' from incompatible pointer type pci_indirect.c: In function `indirect_write_config_byte': pci_indirect.c:102: warning: passing arg 1 of `out_8' from incompatible pointer type pci_indirect.c: In function `indirect_write_config_word': pci_indirect.c:103: warning: passing arg 1 of `out_le16' from incompatible pointer type ./MAKEALL: line 243: ppc_8xx-size: command not found
Regards Greg
Atually I think it makes sense to compile the driver only for those boards that enable it, as ther ecould be even KS8695 based boards that don't need / want to use this driver.
Fixed that wat. Thanks.
Hi Wolfgang,
Yes, that is true.
BTW, we could split out the defines specific to the ethernet driver from that arch-ks8695/platform.h if that made sense. As it is currently that platform.h is a direct copy of that file from the Linux support for this device. It would be sorta nice if we can keep it that way, no doubt it will get updated over time as KS release new parts in this family (they have 3 in this CPU family currently).
Regards Greg
Hi Wolfgang,
No, that was all the CPU support. I just reply'ed to the first email. The new patch was a bit smaller, and fitted all in that one email.
Sure thing. Old habits :-)
Regards Greg
------------------------------------------------------------------------ Greg Ungerer -- Chief Software Dude EMAIL: gerg@snapgear.com SnapGear -- a CyberGuard Company PHONE: +61 7 3435 2888 825 Stanley St, FAX: +61 7 3891 3630 Woolloongabba, QLD, 4102, Australia WEB: http://www.SnapGear.com
Greg Ungerer
richard@uclinux.net
