[RFC PATCH 0/2] Update reserved memory for simple framebuffer
Reserved memory for simple frame buffer should be created in a different way:
+ aliases { + display0 = &lcdif; + }; + + reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + display_reserved: framebuffer@86fa2000 { + reg = <0x86fa2000 0x80000>; + no-map; + }; + + };
We add a function to change the loaded dts and inject those information. I have added another patch for meson. Right now I'm testing on tinker-s board
Michael Trimarchi (2): common: fdt: Add a function for reserving memory without kernel linear mapping video: meson: Use reserving memory function without kernel linear mapping
common/fdt_support.c | 40 +++++++++++++++++++++++++++++++++ drivers/video/meson/meson_vpu.c | 6 ++--- include/fdt_support.h | 11 +++++++++ 3 files changed, 54 insertions(+), 3 deletions(-)
We need to reserve memory and not put in kernel linear mapping. This avoid problem during memory remapping from the simple frame buffer in linux kernel
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- common/fdt_support.c | 40 ++++++++++++++++++++++++++++++++++++++++ include/fdt_support.h | 11 +++++++++++ 2 files changed, 51 insertions(+)
diff --git a/common/fdt_support.c b/common/fdt_support.c index 02cf5c6241..a3662f4358 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -410,6 +410,46 @@ static int fdt_pack_reg(const void *fdt, void *buf, u64 *address, u64 *size, return p - (char *)buf; }
+int fdt_fixup_reserved_memory(void *blob, const char *area, u64 start[], u64 size[]) +{ + int offs, len; + const char *subpath; + const char *path = "/reserved-memory"; + fdt32_t address_cells = cpu_to_fdt32(fdt_address_cells(blob, 0)); + fdt32_t size_cells = cpu_to_fdt32(fdt_size_cells(blob, 0)); + u8 temp[16]; /* Up to 64-bit address + 64-bit size */ + + offs = fdt_path_offset(blob, path); + if (offs < 0) { + debug("Node %s not found\n", path); + path = "/"; + subpath = "reserved-memory"; + offs = fdt_path_offset(blob, path); + offs = fdt_add_subnode(blob, offs, subpath); + if (offs < 0) { + printf("Could not create %s%s node.\n", path, subpath); + return -1; + } + path = "/reserved-memory"; + offs = fdt_path_offset(blob, path); + + fdt_setprop(blob, offs, "#address-cells", &address_cells, sizeof(address_cells)); + fdt_setprop(blob, offs, "#size-cells", &size_cells, sizeof(size_cells)); + fdt_setprop(blob, offs, "ranges", NULL, 0); + } + + offs = fdt_add_subnode(blob, offs, area ? : "private"); + if (offs < 0) { + printf("Could not create %s%s node.\n", path, subpath); + return -1; + } + + fdt_setprop(blob, offs, "no-map", NULL, 0); + len = fdt_pack_reg(blob, temp, start, size, 1); + fdt_setprop(blob, offs, "reg", temp, len); + return 0; +} + #if CONFIG_NR_DRAM_BANKS > 4 #define MEMORY_BANKS_MAX CONFIG_NR_DRAM_BANKS #else diff --git a/include/fdt_support.h b/include/fdt_support.h index ba14acd7f6..7c8a280f53 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -93,6 +93,17 @@ void do_fixup_by_compat_u32(void *fdt, const char *compat, */ int fdt_fixup_memory(void *blob, u64 start, u64 size);
+/** + * Setup the memory reserved node in the DT. Creates one if none was existing before. + * + * @param blob FDT blob to update + * @param area Reserved area name + * @param start Begin of DRAM mapping in physical memory + * @param size Size of the single memory bank + * @return 0 if ok, or -1 or -FDT_ERR_... on error + */ +int fdt_fixup_reserved_memory(void *blob, const char *area, u64 start[], u64 size[]); + /** * Fill the DT memory node with multiple memory banks. * Creates the node if none was existing before.
Hi Michael,
On Wed, 19 Feb 2020 at 11:43, Michael Trimarchi michael@amarulasolutions.com wrote:
nits below
int offs, len;
if (offs < 0) {
path = "/";
This is always 0 by definition.
if (offs < 0) {
return -1;
This is -EPERM. I think it would be better to return ofs.
if (offs < 0) {
return -1;
and here
blank line before return
- Setup the memory reserved node in the DT. Creates one if none was existing before.
- @param blob FDT blob to update
- @param area Reserved area name
- @param start Begin of DRAM mapping in physical memory
- @param size Size of the single memory bank
- @return 0 if ok, or -1 or -FDT_ERR_... on error
check this
- Fill the DT memory node with multiple memory banks.
- Creates the node if none was existing before.
-- 2.17.1
Memory reserved for the simple framebuffer should not be used and part of memory linear mapping
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- drivers/video/meson/meson_vpu.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/video/meson/meson_vpu.c b/drivers/video/meson/meson_vpu.c index 4eb66398d0..134e011b82 100644 --- a/drivers/video/meson/meson_vpu.c +++ b/drivers/video/meson/meson_vpu.c @@ -173,9 +173,9 @@ static void meson_vpu_setup_simplefb(void *fdt) * at the end of the RAM and we strip this portion from the kernel * allowed region */ - mem_start = gd->bd->bi_dram[0].start; - mem_size = gd->bd->bi_dram[0].size - meson_fb.fb_size; - ret = fdt_fixup_memory_banks(fdt, &mem_start, &mem_size, 1); + mem_start = meson_fb.base; + mem_size = meson_fb.fb_size; + ret = fdt_fixup_reserved_memory(blob, "display_reserved", &mem_start, &mem_size); if (ret) { eprintf("Cannot setup simplefb: Error reserving memory\n"); return;
Hi Michael,
Is there a binding file for this? Please add it to a patch.
Odd that this uses underscore...normally bindings use hyphen.
-- 2.17.1
Hi
On Thu, Feb 20, 2020 at 4:05 AM Simon Glass sjg@chromium.org wrote:
Hi Michael,
This is an example how to use it. I need to repost it. There is a compilation issue later. I need only to have some feedback from Neil because I can not test this board
Will fix. There are few things that I need to change here because sunxi, meson use simpleframe buffer but they have some code duplication
Micheal
-- 2.17.1
Michael Nazzareno Trimarchi
Michael Trimarchi
