[U-Boot] Please pull u-boot-marvell master (v2)
Hi Tom,
can you please pull the mvebu tree? This series contains mvebu DDR training code and couple of bug fixes. Also, this version of pull request has the correct messages.
Thanks, Luka
PS. It turns out that when you try to download patches from gitolite as email patches the commit message is not sent.
The following changes since commit b217c89e8565ade3aaa9f74c33c93236bf151187:
Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriq (2015-07-20 17:12:52 -0400)
git://git.denx.de/u-boot-marvell.git
for you to fetch changes up to 9e30b31d20f0b793465d07f056b3d9885f578c0d:
arm: mvebu: db-88f6820: Add SPL support with DDR init code (2015-07-23 10:39:35 +0200)
---------------------------------------------------------------- Anton Schubert (1): arm: mvebu: add Armada XP SATA support
Stefan Roese (11): arm: mvebu: Call timer_init early before PHY and DDR init arm: mvebu: Use default reg base address for SPL on A38x arm: mvebu: spl.c: Add call to board_early_init_f() arm: mvebu: Disable MMU before changing register base address Makefile: Fix mvebu build target to use SPL load and exe-address arm: mvebu: serdes: Move Armada XP SERDES / PHY init code into new directory arm: mvebu: Add Armada 38x SERDES / PHY init code from Marvell bin_hdr arm: mvebu: drivers/ddr: Move Armada XP DDR init code into new directory arm: mvebu: Add Armada 38x DDR3 training code from Marvell bin_hdr arm: mvebu: a38x: Use correct PEX register access macros arm: mvebu: db-88f6820: Add SPL support with DDR init code
Makefile | 2 +- arch/arm/mach-mvebu/Makefile | 4 +- arch/arm/mach-mvebu/cpu.c | 18 + arch/arm/mach-mvebu/include/mach/cpu.h | 2 +- arch/arm/mach-mvebu/include/mach/soc.h | 11 + arch/arm/mach-mvebu/serdes/a38x/Makefile | 10 + arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.c | 347 +++ arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h | 86 + .../serdes/a38x/high_speed_env_spec-38x.c | 158 ++ .../mach-mvebu/serdes/a38x/high_speed_env_spec.c | 2228 +++++++++++++++++ .../mach-mvebu/serdes/a38x/high_speed_env_spec.h | 251 ++ .../serdes/a38x/high_speed_topology_spec-38x.c | 1009 ++++++++ .../serdes/a38x/high_speed_topology_spec.h | 124 + arch/arm/mach-mvebu/serdes/a38x/seq_exec.c | 170 ++ arch/arm/mach-mvebu/serdes/a38x/seq_exec.h | 65 + arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c | 388 +++ arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h | 371 +++ arch/arm/mach-mvebu/serdes/{ => axp}/Makefile | 0 .../mach-mvebu/serdes/{ => axp}/board_env_spec.h | 0 .../serdes/{ => axp}/high_speed_env_lib.c | 0 .../serdes/{ => axp}/high_speed_env_spec.c | 0 .../serdes/{ => axp}/high_speed_env_spec.h | 2 +- arch/arm/mach-mvebu/spl.c | 9 + arch/arm/mach-mvebu/timer.c | 7 + board/Marvell/db-88f6820-gp/README | 18 + board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 31 + board/Marvell/db-88f6820-gp/kwbimage.cfg | 2 +- board/maxbcm/maxbcm.c | 4 +- configs/db-88f6820-gp_defconfig | 1 + drivers/block/mvsata_ide.c | 41 + drivers/ddr/marvell/a38x/Makefile | 19 + drivers/ddr/marvell/a38x/ddr3_a38x.c | 741 ++++++ drivers/ddr/marvell/a38x/ddr3_a38x.h | 98 + drivers/ddr/marvell/a38x/ddr3_a38x_mc_static.h | 226 ++ drivers/ddr/marvell/a38x/ddr3_a38x_topology.h | 22 + drivers/ddr/marvell/a38x/ddr3_a38x_training.c | 40 + drivers/ddr/marvell/a38x/ddr3_debug.c | 1551 ++++++++++++ drivers/ddr/marvell/a38x/ddr3_hws_hw_training.c | 148 ++ drivers/ddr/marvell/a38x/ddr3_hws_hw_training.h | 49 + .../ddr/marvell/a38x/ddr3_hws_hw_training_def.h | 467 ++++ drivers/ddr/marvell/a38x/ddr3_hws_sil_training.h | 17 + drivers/ddr/marvell/a38x/ddr3_init.c | 852 +++++++ drivers/ddr/marvell/a38x/ddr3_init.h | 395 +++ drivers/ddr/marvell/a38x/ddr3_logging_def.h | 101 + drivers/ddr/marvell/a38x/ddr3_patterns_64bit.h | 924 +++++++ drivers/ddr/marvell/a38x/ddr3_topology_def.h | 76 + drivers/ddr/marvell/a38x/ddr3_training.c | 2644 ++++++++++++++++++++ drivers/ddr/marvell/a38x/ddr3_training_bist.c | 289 +++ .../marvell/a38x/ddr3_training_centralization.c | 714 ++++++ drivers/ddr/marvell/a38x/ddr3_training_db.c | 652 +++++ drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c | 686 +++++ drivers/ddr/marvell/a38x/ddr3_training_hw_algo.h | 14 + drivers/ddr/marvell/a38x/ddr3_training_ip.h | 180 ++ drivers/ddr/marvell/a38x/ddr3_training_ip_bist.h | 54 + .../marvell/a38x/ddr3_training_ip_centralization.h | 15 + drivers/ddr/marvell/a38x/ddr3_training_ip_db.h | 34 + drivers/ddr/marvell/a38x/ddr3_training_ip_def.h | 173 ++ drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c | 1354 ++++++++++ drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h | 85 + drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h | 349 +++ drivers/ddr/marvell/a38x/ddr3_training_ip_pbs.h | 41 + drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h | 107 + drivers/ddr/marvell/a38x/ddr3_training_ip_static.h | 31 + drivers/ddr/marvell/a38x/ddr3_training_leveling.c | 1836 ++++++++++++++ drivers/ddr/marvell/a38x/ddr3_training_leveling.h | 17 + drivers/ddr/marvell/a38x/ddr3_training_pbs.c | 995 ++++++++ drivers/ddr/marvell/a38x/ddr3_training_static.c | 538 ++++ drivers/ddr/marvell/a38x/ddr_topology_def.h | 112 + drivers/ddr/marvell/a38x/ddr_training_ip_db.h | 16 + drivers/ddr/marvell/a38x/silicon_if.h | 17 + drivers/ddr/marvell/a38x/xor.c | 356 +++ drivers/ddr/marvell/a38x/xor.h | 92 + drivers/ddr/marvell/a38x/xor_regs.h | 236 ++ drivers/ddr/{mvebu => marvell/axp}/Makefile | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_axp.h | 0 .../ddr/{mvebu => marvell/axp}/ddr3_axp_config.h | 0 .../{mvebu => marvell/axp}/ddr3_axp_mc_static.h | 0 .../axp}/ddr3_axp_training_static.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_vars.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_dfs.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_dqs.c | 0 .../ddr/{mvebu => marvell/axp}/ddr3_hw_training.c | 0 .../ddr/{mvebu => marvell/axp}/ddr3_hw_training.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_init.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_init.h | 0 .../{mvebu => marvell/axp}/ddr3_patterns_64bit.h | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_pbs.c | 0 .../{mvebu => marvell/axp}/ddr3_read_leveling.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_sdram.c | 0 drivers/ddr/{mvebu => marvell/axp}/ddr3_spd.c | 0 .../{mvebu => marvell/axp}/ddr3_write_leveling.c | 0 drivers/ddr/{mvebu => marvell/axp}/xor.c | 0 drivers/ddr/{mvebu => marvell/axp}/xor.h | 0 drivers/ddr/{mvebu => marvell/axp}/xor_regs.h | 0 include/configs/db-88f6820-gp.h | 35 + include/configs/db-mv784mp-gp.h | 31 +- include/configs/maxbcm.h | 2 +- scripts/Makefile.spl | 3 +- 98 files changed, 22783 insertions(+), 10 deletions(-) create mode 100644 arch/arm/mach-mvebu/serdes/a38x/Makefile create mode 100644 arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/ctrl_pex.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec-38x.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_env_spec.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_topology_spec-38x.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/high_speed_topology_spec.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/seq_exec.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/seq_exec.h create mode 100644 arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.c create mode 100644 arch/arm/mach-mvebu/serdes/a38x/sys_env_lib.h rename arch/arm/mach-mvebu/serdes/{ => axp}/Makefile (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/board_env_spec.h (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/high_speed_env_lib.c (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/high_speed_env_spec.c (100%) rename arch/arm/mach-mvebu/serdes/{ => axp}/high_speed_env_spec.h (97%) create mode 100644 board/Marvell/db-88f6820-gp/README create mode 100644 drivers/ddr/marvell/a38x/Makefile create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x_mc_static.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x_topology.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_a38x_training.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_debug.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_hw_training.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_hw_training.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_hw_training_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_hws_sil_training.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_init.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_init.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_logging_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_patterns_64bit.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_bist.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_centralization.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_db.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_hw_algo.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_hw_algo.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_bist.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_centralization.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_db.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_engine.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_engine.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_flow.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_pbs.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_prv_if.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_ip_static.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_leveling.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_leveling.h create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_pbs.c create mode 100644 drivers/ddr/marvell/a38x/ddr3_training_static.c create mode 100644 drivers/ddr/marvell/a38x/ddr_topology_def.h create mode 100644 drivers/ddr/marvell/a38x/ddr_training_ip_db.h create mode 100644 drivers/ddr/marvell/a38x/silicon_if.h create mode 100644 drivers/ddr/marvell/a38x/xor.c create mode 100644 drivers/ddr/marvell/a38x/xor.h create mode 100644 drivers/ddr/marvell/a38x/xor_regs.h rename drivers/ddr/{mvebu => marvell/axp}/Makefile (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_config.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_mc_static.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_training_static.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_axp_vars.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_dfs.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_dqs.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_hw_training.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_hw_training.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_init.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_init.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_patterns_64bit.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_pbs.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_read_leveling.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_sdram.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_spd.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/ddr3_write_leveling.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/xor.c (100%) rename drivers/ddr/{mvebu => marvell/axp}/xor.h (100%) rename drivers/ddr/{mvebu => marvell/axp}/xor_regs.h (100%)
On Thu, Jul 23, 2015 at 08:44:50AM +0000, Luka Perkov wrote:
Hi Tom,
Thanks, Luka
Luka Perkov
