[U-Boot] [PATCH] ARMv7: LS102xA: Move two macros from header files to Kconfig
ARMV7_PSCI depends on ARMV7_NONSEC && ARCH_SUPPORT_PSCI, and ARMV7_NONSEC depends on CPU_V7_HAS_NONSEC, LS102XA didn't enable CPU_V7_HAS_NONSEC, but defined ARMV7_NONSEC in a internal header file, this cannot be recognized by Kconfig, so ARMV7_PSCI isn't defined at last. This patch selects CPU_V7_HAS_NONSEC in Kconfig, and remove ARMV7_NONSEC in header file, and meanwhile selects CPU_V7_HAS_VIRT in Kconfig and remove CONFIG_ARMV7_VIRT in header file too.
Signed-off-by: Hongbo Zhang hongbo.zhang@nxp.com --- arch/arm/Kconfig | 4 ++++ include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 2 -- 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 1560bcc..7fcb1cb 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -818,12 +818,16 @@ config TARGET_LS1021AQDS select CPU_V7 select SUPPORT_SPL select ARCH_SUPPORT_PSCI + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT
config TARGET_LS1021ATWR bool "Support ls1021atwr" select CPU_V7 select SUPPORT_SPL select ARCH_SUPPORT_PSCI + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT
config TARGET_LS1043AQDS bool "Support ls1043aqds" diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 5aaecc7..7b608c1 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -563,8 +563,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMDLINE_TAG #define CONFIG_CMDLINE_EDITING
-#define CONFIG_ARMV7_NONSEC -#define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN #define CONFIG_LAYERSCAPE_NS_ACCESS #define CONFIG_SMP_PEN_ADDR 0x01ee0200 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index ef238a4..d946224 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -425,8 +425,6 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_CMDLINE_EDITING
Detail explanation in commit message helps us to understand why the change. But for this case, it may be too verbose. I would say following commits xxxxxx and xxxxxx, these two config options are moved to Kconfig, for correctly select ARMV7_PSCI.
York
Thanks.
I've sent a v2 with commit comments updated.
York
Hongbo Zhang
york sun
