[PATCH 4/5] apalis-imx8: Remove unused function detail_board_ddr_info()
detail_board_ddr_info() is not used anywhere, so simply remove it.
This function is only used by Layerscape, not by i.MX.
This was detected by the following sparse warning:
board/toradex/apalis-imx8/apalis-imx8.c:92:6: warning: no previous prototype for ‘detail_board_ddr_info’ [-Wmissing-prototypes]
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com --- board/toradex/apalis-imx8/apalis-imx8.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/toradex/apalis-imx8/apalis-imx8.c b/board/toradex/apalis-imx8/apalis-imx8.c index 0483041187..a42fbb722a 100644 --- a/board/toradex/apalis-imx8/apalis-imx8.c +++ b/board/toradex/apalis-imx8/apalis-imx8.c @@ -89,11 +89,6 @@ int board_init(void) return 0; }
-void detail_board_ddr_info(void) -{ - puts("\nDDR "); -} - /* * Board specific reset that is system reset. */
board/toradex/colibri-imx8x/colibri-imx8x.c:104:6: warning: no previous prototype for ‘detail_board_ddr_info’ [-Wmissing-prototypes]
Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com --- board/toradex/colibri-imx8x/colibri-imx8x.c | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c index adeee67643..f9e947eede 100644 --- a/board/toradex/colibri-imx8x/colibri-imx8x.c +++ b/board/toradex/colibri-imx8x/colibri-imx8x.c @@ -101,11 +101,6 @@ int board_init(void) return 0; }
detail_board_ddr_info() is not used anywhere, so simply remove it. This function is only used by Layerscape, not by i.MX. This was detected by the following sparse warning: board/toradex/colibri-imx8x/colibri-imx8x.c:104:6: warning: no previous prototype for ‘detail_board_ddr_info’ [-Wmissing-prototypes] Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com
Best regards, Stefano Babic
detail_board_ddr_info() is not used anywhere, so simply remove it. This function is only used by Layerscape, not by i.MX. This was detected by the following sparse warning: board/toradex/apalis-imx8/apalis-imx8.c:92:6: warning: no previous prototype for ‘detail_board_ddr_info’ [-Wmissing-prototypes] Signed-off-by: Alifer Moraes alifer.wsdm@gmail.com
Alifer Moraes
sbabic@denx.de
