[PATCH 1/2] arm: omap3: Make secureworld_exit() static
secureworld_exit() is only used in one file, so make it static to that file and remove it from sys_proto.h. This may help with some further optimization in the future.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/include/asm/arch-omap3/sys_proto.h b/arch/arm/include/asm/arch-omap3/sys_proto.h index 656f848a73..a6e9ff84aa 100644 --- a/arch/arm/include/asm/arch-omap3/sys_proto.h +++ b/arch/arm/include/asm/arch-omap3/sys_proto.h @@ -59,7 +59,6 @@ u32 is_running_in_sdram(void); u32 is_running_in_sram(void); u32 is_running_in_flash(void); u32 get_device_type(void); -void secureworld_exit(void); u32 get_boot_type(void); void invalidate_dcache(u32); u32 wait_on_value(u32, u32, void *, u32); diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index c621177580..87dddd9b0f 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -114,7 +114,7 @@ void secure_unlock_mem(void) * configure secure registers and exit secure world * general use. *****************************************************************************/ -void secureworld_exit(void) +static void secureworld_exit(void) { unsigned long i;
secure_unlock_mem() is only used in one file, so make it static in that file. This may help with some further optimization in the future.
diff --git a/arch/arm/mach-omap2/omap3/board.c b/arch/arm/mach-omap2/omap3/board.c index 87dddd9b0f..74b5a4b111 100644 --- a/arch/arm/mach-omap2/omap3/board.c +++ b/arch/arm/mach-omap2/omap3/board.c @@ -76,7 +76,7 @@ const struct gpio_bank *const omap_gpio_bank = gpio_bank_34xx; * Description: Setup security registers for access * (GP Device only) *****************************************************************************/ -void secure_unlock_mem(void) +static void secure_unlock_mem(void) { struct pm *pm_rt_ape_base = (struct pm *)PM_RT_APE_BASE_ADDR_ARM; struct pm *pm_gpmc_base = (struct pm *)PM_GPMC_BASE_ADDR_ARM;
Lokesh,
Is this patch ok as-is, or do you want me to re-post it as V2 with no changes when I redo patch 2/2?
adam
general use.
-- 2.25.1
Lokesh,
Patch is okay. Please re-post it as V2 as a series.
Thanks and regards, Lokesh
adam
general use.
-- 2.25.1
Adam Ford
Lokesh Vutla
