Re: [U-Boot] [PATCH v9 0/31] Create generic board init for ARM, x86, PPC
Hi Tom,
On Mon, Mar 11, 2013 at 10:03 AM, Simon Glass sjg@chromium.org wrote:
This series creates a generic board init implementation which contains the essential functions of the major arch/xxx/lib/board.c files. It is split into two parts: board_f.c for pre-relocation and board_r.c for post-relocation.
What is the motivation for this change?
- There is a lot of repeated code in the board.c files. Any change to
things like setting up the baud rate requires a change in 10 separate places.
- Since there are 14 separate files, adding a new feature which requires
initialisation is painful since it must be independently added in 14 places.
- As time goes by the architectures naturely diverge since there is
limited pressure to compare features or even CONFIG options against simiilar things in other board.c files.
- New architectures must implement all the features all over again, and
sometimes in subtley different ways. This places an unfair burden on getting a new architecture fully functional and running with U-Boot.
- While it is a bit of a tricky change, I believe it is worthwhile and
achievable. There is no requirement that all code be common, only that the code that is common should be located in common/board.c rather than arch/xxx/lib/board.c.
All the functions of board_init_f() and board_init_r() are broken into separate function calls so that they can easily be included or excluded for a particular architecture. It also makes it easier to adopt Graeme's initcall proposal assuming this comes about.
http://lists.denx.de/pipermail/u-boot/2012-January/114499.html
This series is not dependent on generic relocation. So relocation happens as one big chunk and is still completely arch-specific. See the relocation series for a proposed solution to this for ARM:
http://lists.denx.de/pipermail/u-boot/2011-December/112928.html
or x86's implementation which is in mainline. Unifying relocation is probably the next step after this series.
Instead of moving over a whole architecture, this series takes the approach of simply enabling generic board support for an architecture. It is then up to each board to opt in by defining CONFIG_SYS_GENERIC_BOARD in the board config file. If this is not done, then the code will be generated as before. This allows both sets of code to co-exist until we are comfortable with the generic approach, and enough boards run.
ARM is a relatively large board.c file and one which I can test, therefore I think it is a good target for this series. On the other hand, x86 is relatively small and simple, but different enough that it introduces a few issues to be solved. So I have chosen both ARM and x86 for this series. After a suggestion from Wolfgang I have added PPC also. This is the largest and most feature-full board, so hopefully we have all bases covered in this series. Other archs are mostly a subset of these.
A generic global_data structure is now in mainline, and this is required for this series.
Similarly we need a generic bd_info structure, since generic code will be accessing it. I have done this with a simple generic file for now.
There was dicussion on the list about passing gd_t around as a parameter to pre-relocation init functions. I think this makes sense, but it can be done as a separate change, and this series does not require it.
While this series needs to stand on its own, the goal is the unification of the board init code. So I hope we can address issues with this in mind, rather than focusing too narrowly on particular ARM, x86 or PPC issues. I have added TODO markers in places where I think there are opportunities to relationalise the board init now it is all in one place, but these don't need to be addressed for the feature to work, and are best done as smaller patches than can be reviewed by individual arch maintainers, I think.
I have run-tested ARM on Tegra Seaboard and x86/coreboot only. To try it out, define CONFIG_SYS_GENERIC_BOARD in your board file and rebuild. Most likely on PPC at least it will hang, but if you are lucky it will print something first :-) I hope to test an SPL board (snow / exynos5250) when I can get that booting from mainline.
I have run this though buildman with CONFIG_SYS_GENERIC_BOARD on for all ARM, PPC and x86 boards. The only failure is highbank (an ARM board), which seems to use SCSI but scsi_init() is not available.
Code size increases by about 1KB on ARM and about 1.3KB on PPC with generic board enabled. This is mostly due to the move to using separate functions for each part of the init, which will make it easier to move to a pure initcall approach later if we want to.
Since this series was first sent there have been additions to the board code for ARM and PPC. I have added in these additions. This is a manual process, and I expect that people will find problems (and send patches) as they try out their boards.
I have created a branch on x86 for this as follows, in case this helps. But I believe Wolfgang is hoping to look at getting it running on PowerPC, so it might be worth holding off for more news.
The following changes since commit fc959081d41aab2d6f4614c5fb3dd1b77ffcdcf4:
x86: Enable CONFIG_OF_CONTROL on coreboot (2013-03-04 15:57:52 -0800)
git://git.denx.de/u-boot-x86.git us-board-v10
for you to fetch changes up to 0a2cdf0f505a018e5a781750ada081ac6e81a866:
Use 'unsigned int' for global_data's baudrate (2013-03-11 10:42:20 -0700)
---------------------------------------------------------------- Simon Glass (31): Introduce generic u-boot.h file Replace __bss_end__ with __bss_end Introduce generic link section.h symbol files arm: Use sections header to obtain link symbols Change stub example to use asm-generic/sections.h Introduce a basic initcall implementation __HAVE_ARCH_GENERIC_BOARD controls availabilty of generic board Declare watchdog functions in watchdog.h Introduce generic pre-relocation board_f.c Introduce generic post-relocation board_r.c Add spl load feature arm: Remove use of board_early_init_r/last_stage_init() arm: Enable generic board support Add CONFIG_SYS_SYM_OFFSETS to support offset symbols Adjust board_f.c for ppc Adjust board_r.c for ppc ppc: Enable generic board support x86: Adjust board_f.c for x86 x86: Adjust board_r.c for x86 x86: Use sections header to obtain link symbols tegra: Enable generic board for Tegra x86: Enable generic board support x86: Enable generic board exynos5: Enable generic board for Exynos5 device tree boards blackfin: Fix up board_type global data blackfin: Remove noreturn attribute from cpu_init_f() avr32: Fix cast warning in board.c serial: ns16550: Remove unwanted cast sparc: Fix out-of-tree building sparc: Fix build warnings in serial.c Use 'unsigned int' for global_data's baudrate
README | 17 + arch/arm/config.mk | 3 + arch/arm/cpu/arm1136/start.S | 2 +- arch/arm/cpu/arm1136/u-boot-spl.lds | 2 +- arch/arm/cpu/arm1176/start.S | 2 +- arch/arm/cpu/arm720t/start.S | 2 +- arch/arm/cpu/arm920t/ep93xx/u-boot.lds | 2 +- arch/arm/cpu/arm920t/start.S | 2 +- arch/arm/cpu/arm925t/start.S | 2 +- arch/arm/cpu/arm926ejs/davinci/spl.c | 2 +- arch/arm/cpu/arm926ejs/mxs/start.S | 2 +- arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds | 2 +- arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds | 2 +- arch/arm/cpu/arm926ejs/start.S | 4 +- arch/arm/cpu/arm946es/start.S | 2 +- arch/arm/cpu/arm_intcm/start.S | 2 +- arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 2 +- arch/arm/cpu/armv7/socfpga/u-boot-spl.lds | 2 +- arch/arm/cpu/armv7/start.S | 2 +- arch/arm/cpu/ixp/start.S | 2 +- arch/arm/cpu/ixp/u-boot.lds | 2 +- arch/arm/cpu/pxa/start.S | 2 +- arch/arm/cpu/s3c44b0/start.S | 2 +- arch/arm/cpu/sa1100/start.S | 2 +- arch/arm/cpu/u-boot.lds | 4 +- arch/arm/include/asm/sections.h | 27 + arch/arm/include/asm/spl.h | 2 +- arch/arm/include/asm/u-boot-arm.h | 4 - arch/arm/include/asm/u-boot.h | 9 + arch/arm/lib/Makefile | 3 + arch/arm/lib/board.c | 1 + arch/arm/lib/crt0.S | 4 +- arch/arm/lib/spl.c | 2 +- arch/avr32/cpu/start.S | 2 +- arch/avr32/cpu/u-boot.lds | 2 +- arch/avr32/include/asm/sections.h | 6 +- arch/avr32/lib/board.c | 8 +- arch/blackfin/cpu/cpu.c | 1 - arch/blackfin/include/asm/global_data.h | 1 + arch/blackfin/include/asm/sections.h | 27 + arch/blackfin/lib/board.c | 2 +- arch/m68k/include/asm/sections.h | 27 + arch/m68k/lib/board.c | 5 +- arch/microblaze/include/asm/sections.h | 27 + arch/mips/include/asm/sections.h | 27 + arch/mips/include/asm/u-boot-mips.h | 4 +- arch/nds32/cpu/n1213/start.S | 2 +- arch/nds32/cpu/n1213/u-boot.lds | 2 +- arch/nds32/include/asm/sections.h | 27 + arch/nds32/include/asm/u-boot-nds32.h | 8 +- arch/nds32/lib/board.c | 2 +- arch/nios2/cpu/start.S | 6 +- arch/nios2/cpu/u-boot.lds | 2 +- arch/nios2/include/asm/sections.h | 27 + arch/openrisc/include/asm/sections.h | 27 + arch/powerpc/config.mk | 3 + arch/powerpc/cpu/74xx_7xx/start.S | 4 +- arch/powerpc/cpu/74xx_7xx/u-boot.lds | 2 +- arch/powerpc/cpu/mpc512x/start.S | 4 +- arch/powerpc/cpu/mpc512x/u-boot.lds | 2 +- arch/powerpc/cpu/mpc5xx/start.S | 4 +- arch/powerpc/cpu/mpc5xx/u-boot.lds | 2 +- arch/powerpc/cpu/mpc5xxx/spl_boot.c | 2 +- arch/powerpc/cpu/mpc5xxx/start.S | 4 +- arch/powerpc/cpu/mpc5xxx/u-boot-customlayout.lds | 2 +- arch/powerpc/cpu/mpc5xxx/u-boot-spl.lds | 2 +- arch/powerpc/cpu/mpc5xxx/u-boot.lds | 2 +- arch/powerpc/cpu/mpc8220/start.S | 4 +- arch/powerpc/cpu/mpc8220/u-boot.lds | 2 +- arch/powerpc/cpu/mpc824x/start.S | 4 +- arch/powerpc/cpu/mpc824x/u-boot.lds | 2 +- arch/powerpc/cpu/mpc8260/start.S | 4 +- arch/powerpc/cpu/mpc8260/u-boot.lds | 2 +- arch/powerpc/cpu/mpc83xx/start.S | 4 +- arch/powerpc/cpu/mpc83xx/u-boot-spl.lds | 4 +- arch/powerpc/cpu/mpc83xx/u-boot.lds | 2 +- arch/powerpc/cpu/mpc85xx/start.S | 4 +- arch/powerpc/cpu/mpc85xx/u-boot-nand.lds | 2 +- arch/powerpc/cpu/mpc85xx/u-boot-nand_spl.lds | 2 +- arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 2 +- arch/powerpc/cpu/mpc85xx/u-boot.lds | 2 +- arch/powerpc/cpu/mpc86xx/start.S | 4 +- arch/powerpc/cpu/mpc86xx/u-boot.lds | 2 +- arch/powerpc/cpu/mpc8xx/start.S | 4 +- arch/powerpc/cpu/ppc4xx/start.S | 4 +- arch/powerpc/cpu/ppc4xx/u-boot.lds | 2 +- arch/powerpc/include/asm/sections.h | 27 + arch/powerpc/include/asm/spl.h | 2 +- arch/powerpc/include/asm/u-boot.h | 7 + arch/powerpc/lib/Makefile | 2 + arch/powerpc/lib/board.c | 18 +- arch/sandbox/include/asm/sections.h | 2 + arch/sh/cpu/sh2/u-boot.lds | 2 +- arch/sh/cpu/sh3/u-boot.lds | 2 +- arch/sh/cpu/sh4/u-boot.lds | 2 +- arch/sh/include/asm/sections.h | 27 + arch/sh/lib/board.c | 1 + arch/sparc/cpu/leon2/Makefile | 7 - arch/sparc/cpu/leon2/serial.c | 10 - arch/sparc/cpu/leon3/Makefile | 7 - arch/sparc/cpu/leon3/serial.c | 10 - arch/sparc/include/asm/sections.h | 27 + arch/x86/config.mk | 3 + arch/x86/cpu/coreboot/sdram.c | 1 + arch/x86/cpu/u-boot.lds | 4 +- arch/x86/include/asm/config.h | 1 + arch/x86/include/asm/sections.h | 27 + arch/x86/include/asm/u-boot-x86.h | 9 - arch/x86/include/asm/u-boot.h | 11 + arch/x86/lib/Makefile | 3 + arch/x86/lib/board.c | 3 +- arch/x86/lib/init_helpers.c | 3 +- arch/x86/lib/relocate.c | 9 +- board/BuS/eb_cpu5282/u-boot.lds | 2 +- board/LEOX/elpt860/u-boot.lds | 2 +- board/RPXClassic/u-boot.lds | 2 +- board/RPXlite/u-boot.lds | 2 +- board/RPXlite_dw/u-boot.lds | 2 +- board/RRvision/u-boot.lds | 2 +- board/actux1/u-boot.lds | 2 +- board/actux2/u-boot.lds | 2 +- board/actux3/u-boot.lds | 2 +- board/adder/u-boot.lds | 2 +- board/ait/cam_enc_4xx/u-boot-spl.lds | 2 +- board/altera/nios2-generic/u-boot.lds | 2 +- board/amcc/acadia/u-boot-nand.lds | 2 +- board/amcc/bamboo/u-boot-nand.lds | 2 +- board/amcc/canyonlands/u-boot-nand.lds | 2 +- board/amcc/kilauea/u-boot-nand.lds | 2 +- board/amcc/sequoia/u-boot-nand.lds | 2 +- board/amcc/sequoia/u-boot-ram.lds | 2 +- board/astro/mcf5373l/u-boot.lds | 2 +- board/cm4008/flash.c | 1 + board/cm41xx/flash.c | 1 + board/cobra5272/u-boot.lds | 2 +- board/cogent/u-boot.lds | 2 +- board/dave/PPChameleonEVB/u-boot.lds | 2 +- board/davinci/da8xxevm/u-boot-spl-da850evm.lds | 2 +- board/davinci/da8xxevm/u-boot-spl-hawk.lds | 2 +- board/dvlhost/u-boot.lds | 2 +- board/eltec/mhpc/u-boot.lds | 2 +- board/emk/top860/u-boot.lds | 2 +- board/ep88x/u-boot.lds | 2 +- board/esd/dasa_sim/u-boot.lds | 2 +- board/esd/pmc440/u-boot-nand.lds | 2 +- board/esd/tasreg/u-boot.lds | 2 +- board/esteem192e/u-boot.lds | 2 +- board/evb64260/u-boot.lds | 2 +- board/fads/u-boot.lds | 2 +- board/flagadm/u-boot.lds | 2 +- board/freescale/m5208evbe/u-boot.lds | 2 +- board/freescale/m52277evb/u-boot.lds | 2 +- board/freescale/m5235evb/u-boot.lds | 2 +- board/freescale/m5249evb/u-boot.lds | 2 +- board/freescale/m5253demo/u-boot.lds | 2 +- board/freescale/m5253evbe/u-boot.lds | 2 +- board/freescale/m5271evb/u-boot.lds | 2 +- board/freescale/m5272c3/u-boot.lds | 2 +- board/freescale/m5275evb/u-boot.lds | 2 +- board/freescale/m5282evb/u-boot.lds | 2 +- board/freescale/m53017evb/u-boot.lds | 2 +- board/freescale/m5329evb/u-boot.lds | 2 +- board/freescale/m5373evb/u-boot.lds | 2 +- board/freescale/m54418twr/u-boot.lds | 2 +- board/freescale/m54451evb/u-boot.lds | 2 +- board/freescale/m54455evb/u-boot.lds | 2 +- board/freescale/m547xevb/u-boot.lds | 2 +- board/freescale/m548xevb/u-boot.lds | 2 +- board/freescale/mx31ads/u-boot.lds | 2 +- board/gaisler/gr_cpci_ax2000/u-boot.lds | 2 +- board/gaisler/gr_ep2s60/u-boot.lds | 2 +- board/gaisler/gr_xc3s_1500/u-boot.lds | 2 +- board/gaisler/grsim/u-boot.lds | 2 +- board/gaisler/grsim_leon2/u-boot.lds | 2 +- board/gen860t/u-boot-flashenv.lds | 2 +- board/gen860t/u-boot.lds | 2 +- board/genietv/u-boot.lds | 2 +- board/hermes/u-boot.lds | 2 +- board/hymod/u-boot.lds | 2 +- board/icu862/u-boot.lds | 2 +- board/idmr/u-boot.lds | 2 +- board/ip860/u-boot.lds | 2 +- board/ivm/u-boot.lds | 2 +- board/korat/u-boot-F7FC.lds | 2 +- board/kup/kup4k/u-boot.lds | 2 +- board/kup/kup4x/u-boot.lds | 2 +- board/lwmon/u-boot.lds | 2 +- board/manroland/uc100/u-boot.lds | 2 +- board/matrix_vision/mvsmr/u-boot.lds | 2 +- board/mbx8xx/u-boot.lds | 2 +- board/mousse/u-boot.lds | 2 +- board/mvblue/u-boot.lds | 2 +- board/netphone/u-boot.lds | 2 +- board/netta/u-boot.lds | 2 +- board/netta2/u-boot.lds | 2 +- board/netvia/u-boot.lds | 2 +- board/nx823/u-boot.lds | 2 +- board/quantum/u-boot.lds | 2 +- board/r360mpi/u-boot.lds | 2 +- board/rbc823/u-boot.lds | 2 +- board/renesas/sh7752evb/u-boot.lds | 2 +- board/renesas/sh7757lcr/u-boot.lds | 2 +- board/rsdproto/u-boot.lds | 2 +- board/samsung/smdk5250/smdk5250-uboot-spl.lds | 2 +- board/samsung/smdk6400/u-boot-nand.lds | 2 +- board/sandpoint/u-boot.lds | 2 +- board/sixnet/u-boot.lds | 2 +- board/snmc/qs850/u-boot.lds | 2 +- board/snmc/qs860t/u-boot.lds | 2 +- board/spc1920/u-boot.lds | 2 +- board/spd8xx/u-boot.lds | 2 +- board/stx/stxxtc/u-boot.lds | 2 +- board/svm_sc8xx/u-boot.lds | 2 +- board/tqc/tqm8xx/u-boot.lds | 2 +- board/v37/u-boot.lds | 2 +- board/vpac270/u-boot-spl.lds | 2 +- board/woodburn/woodburn.c | 2 +- common/Makefile | 4 + common/board_f.c | 1016 +++++++++++++++++++++++++++++ common/board_r.c | 919 ++++++++++++++++++++++++++ config.mk | 8 + drivers/serial/ns16550.c | 2 +- examples/standalone/stubs.c | 7 +- include/asm-generic/global_data.h | 4 +- include/asm-generic/sections.h | 117 ++++ include/asm-generic/u-boot.h | 162 +++++ include/common.h | 2 + include/configs/exynos5250-dt.h | 1 + include/configs/km/keymile-common.h | 4 - include/configs/km/km-powerpc.h | 4 + include/configs/tegra-common.h | 2 + include/ide.h | 7 + include/initcall.h | 25 + include/watchdog.h | 18 + lib/Makefile | 1 + lib/initcall.c | 39 ++ nand_spl/board/amcc/acadia/u-boot.lds | 2 +- nand_spl/board/amcc/bamboo/u-boot.lds | 2 +- nand_spl/board/amcc/canyonlands/u-boot.lds | 2 +- nand_spl/board/amcc/kilauea/u-boot.lds | 2 +- nand_spl/board/amcc/sequoia/u-boot.lds | 2 +- nand_spl/board/freescale/mpc8315erdb/u-boot.lds | 4 +- nand_spl/board/freescale/mx31pdk/u-boot.lds | 2 +- nand_spl/board/karo/tx25/u-boot.lds | 2 +- nand_spl/board/samsung/smdk6400/u-boot.lds | 2 +- nand_spl/board/sheldon/simpc8313/u-boot.lds | 4 +- 246 files changed, 2958 insertions(+), 294 deletions(-) create mode 100644 arch/arm/include/asm/sections.h create mode 100644 arch/blackfin/include/asm/sections.h create mode 100644 arch/m68k/include/asm/sections.h create mode 100644 arch/microblaze/include/asm/sections.h create mode 100644 arch/mips/include/asm/sections.h create mode 100644 arch/nds32/include/asm/sections.h create mode 100644 arch/nios2/include/asm/sections.h create mode 100644 arch/openrisc/include/asm/sections.h create mode 100644 arch/powerpc/include/asm/sections.h create mode 100644 arch/sh/include/asm/sections.h create mode 100644 arch/sparc/include/asm/sections.h create mode 100644 arch/x86/include/asm/sections.h create mode 100644 common/board_f.c create mode 100644 common/board_r.c create mode 100644 include/asm-generic/sections.h create mode 100644 include/asm-generic/u-boot.h create mode 100644 include/initcall.h create mode 100644 lib/initcall.c
