[U-Boot] [PATCH] rockchip: rk3036: clock: code clean
Embeded the shift in mask MACRO, and a few fix btw: - hclk/pclk_div range use '<=' instead of '<' - use GPLL for pd_bus - peri HCLK/PCLK clock rate should not bigger than ACLK
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/include/asm/arch-rockchip/cru_rk3036.h | 76 ++++++++++---------- drivers/clk/rockchip/clk_rk3036.c | 93 +++++++++++-------------- 2 files changed, 79 insertions(+), 90 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rk3036.h b/arch/arm/include/asm/arch-rockchip/cru_rk3036.h index aaef4b9..22278e1 100644 --- a/arch/arm/include/asm/arch-rockchip/cru_rk3036.h +++ b/arch/arm/include/asm/arch-rockchip/cru_rk3036.h @@ -16,9 +16,9 @@ #define CORE_PERI_HZ 150000000 #define CORE_ACLK_HZ 300000000
-#define CPU_ACLK_HZ 150000000 -#define CPU_HCLK_HZ 300000000 -#define CPU_PCLK_HZ 300000000 +#define BUS_ACLK_HZ 148500000 +#define BUS_HCLK_HZ 148500000 +#define BUS_PCLK_HZ 74250000
#define PERI_ACLK_HZ 148500000 #define PERI_HCLK_HZ 148500000 @@ -68,102 +68,102 @@ struct pll_div {
enum { /* PLLCON0*/ - PLL_POSTDIV1_MASK = 7, PLL_POSTDIV1_SHIFT = 12, - PLL_FBDIV_MASK = 0xfff, + PLL_POSTDIV1_MASK = 7 << PLL_POSTDIV1_SHIFT, PLL_FBDIV_SHIFT = 0, + PLL_FBDIV_MASK = 0xfff,
/* PLLCON1 */ - PLL_DSMPD_MASK = 1, + PLL_RST_SHIFT = 14, PLL_DSMPD_SHIFT = 12, - PLL_LOCK_STATUS_MASK = 1, + PLL_DSMPD_MASK = 1 << PLL_DSMPD_SHIFT, PLL_LOCK_STATUS_SHIFT = 10, - PLL_POSTDIV2_MASK = 7, + PLL_LOCK_STATUS_MASK = 1 << PLL_LOCK_STATUS_SHIFT, PLL_POSTDIV2_SHIFT = 6, - PLL_REFDIV_MASK = 0x3f, + PLL_POSTDIV2_MASK = 7 << PLL_POSTDIV2_SHIFT, PLL_REFDIV_SHIFT = 0, - PLL_RST_SHIFT = 14, + PLL_REFDIV_MASK = 0x3f,
/* CRU_MODE */ - GPLL_MODE_MASK = 3, GPLL_MODE_SHIFT = 12, + GPLL_MODE_MASK = 3 << GPLL_MODE_SHIFT, GPLL_MODE_SLOW = 0, GPLL_MODE_NORM, GPLL_MODE_DEEP, - DPLL_MODE_MASK = 1, DPLL_MODE_SHIFT = 4, + DPLL_MODE_MASK = 1 << DPLL_MODE_SHIFT, DPLL_MODE_SLOW = 0, DPLL_MODE_NORM, - APLL_MODE_MASK = 1, APLL_MODE_SHIFT = 0, + APLL_MODE_MASK = 1 << APLL_MODE_SHIFT, APLL_MODE_SLOW = 0, APLL_MODE_NORM,
/* CRU_CLK_SEL0_CON */ - CPU_CLK_PLL_SEL_MASK = 3, - CPU_CLK_PLL_SEL_SHIFT = 14, - CPU_CLK_PLL_SEL_APLL = 0, - CPU_CLK_PLL_SEL_DPLL, - CPU_CLK_PLL_SEL_GPLL, - ACLK_CPU_DIV_MASK = 0x1f, - ACLK_CPU_DIV_SHIFT = 8, - CORE_CLK_PLL_SEL_MASK = 1, + BUS_ACLK_PLL_SEL_SHIFT = 14, + BUS_ACLK_PLL_SEL_MASK = 3 << BUS_ACLK_PLL_SEL_SHIFT, + BUS_ACLK_PLL_SEL_APLL = 0, + BUS_ACLK_PLL_SEL_DPLL, + BUS_ACLK_PLL_SEL_GPLL, + BUS_ACLK_DIV_SHIFT = 8, + BUS_ACLK_DIV_MASK = 0x1f << BUS_ACLK_DIV_SHIFT, CORE_CLK_PLL_SEL_SHIFT = 7, + CORE_CLK_PLL_SEL_MASK = 1 << CORE_CLK_PLL_SEL_SHIFT, CORE_CLK_PLL_SEL_APLL = 0, CORE_CLK_PLL_SEL_GPLL, - CORE_DIV_CON_MASK = 0x1f, CORE_DIV_CON_SHIFT = 0, + CORE_DIV_CON_MASK = 0x1f << CORE_DIV_CON_SHIFT,
/* CRU_CLK_SEL1_CON */ - CPU_PCLK_DIV_MASK = 7, - CPU_PCLK_DIV_SHIFT = 12, - CPU_HCLK_DIV_MASK = 3, - CPU_HCLK_DIV_SHIFT = 8, - CORE_ACLK_DIV_MASK = 7, + BUS_PCLK_DIV_SHIFT = 12, + BUS_PCLK_DIV_MASK = 7 << BUS_PCLK_DIV_SHIFT, + BUS_HCLK_DIV_SHIFT = 8, + BUS_HCLK_DIV_MASK = 3 << BUS_HCLK_DIV_SHIFT, CORE_ACLK_DIV_SHIFT = 4, - CORE_PERI_DIV_MASK = 0xf, + CORE_ACLK_DIV_MASK = 7 << CORE_ACLK_DIV_SHIFT, CORE_PERI_DIV_SHIFT = 0, + CORE_PERI_DIV_MASK = 0xf << CORE_PERI_DIV_SHIFT,
/* CRU_CLKSEL10_CON */ - PERI_PLL_SEL_MASK = 3, PERI_PLL_SEL_SHIFT = 14, + PERI_PLL_SEL_MASK = 3 << PERI_PLL_SEL_SHIFT, PERI_PLL_APLL = 0, PERI_PLL_DPLL, PERI_PLL_GPLL, - PERI_PCLK_DIV_MASK = 3, PERI_PCLK_DIV_SHIFT = 12, - PERI_HCLK_DIV_MASK = 3, + PERI_PCLK_DIV_MASK = 3 << PERI_PCLK_DIV_SHIFT, PERI_HCLK_DIV_SHIFT = 8, - PERI_ACLK_DIV_MASK = 0x1f, + PERI_HCLK_DIV_MASK = 3 << PERI_HCLK_DIV_SHIFT, PERI_ACLK_DIV_SHIFT = 0, + PERI_ACLK_DIV_MASK = 0x1f << PERI_ACLK_DIV_SHIFT,
/* CRU_CLKSEL11_CON */ - SDIO_DIV_MASK = 0x7f, SDIO_DIV_SHIFT = 8, - MMC0_DIV_MASK = 0x7f, + SDIO_DIV_MASK = 0x7f << SDIO_DIV_SHIFT, MMC0_DIV_SHIFT = 0, + MMC0_DIV_MASK = 0x7f << MMC0_DIV_SHIFT,
/* CRU_CLKSEL12_CON */ - EMMC_PLL_MASK = 3, EMMC_PLL_SHIFT = 12, + EMMC_PLL_MASK = 3 << EMMC_PLL_SHIFT, EMMC_SEL_APLL = 0, EMMC_SEL_DPLL, EMMC_SEL_GPLL, EMMC_SEL_24M, - SDIO_PLL_MASK = 3, SDIO_PLL_SHIFT = 10, + SDIO_PLL_MASK = 3 << SDIO_PLL_SHIFT, SDIO_SEL_APLL = 0, SDIO_SEL_DPLL, SDIO_SEL_GPLL, SDIO_SEL_24M, - MMC0_PLL_MASK = 3, MMC0_PLL_SHIFT = 8, + MMC0_PLL_MASK = 3 << MMC0_PLL_SHIFT, MMC0_SEL_APLL = 0, MMC0_SEL_DPLL, MMC0_SEL_GPLL, MMC0_SEL_24M, - EMMC_DIV_MASK = 0x7f, EMMC_DIV_SHIFT = 0, + EMMC_DIV_MASK = 0x7f << EMMC_DIV_SHIFT,
/* CRU_SOFTRST5_CON */ DDRCTRL_PSRST_SHIFT = 11, diff --git a/drivers/clk/rockchip/clk_rk3036.c b/drivers/clk/rockchip/clk_rk3036.c index 7e3bf96..1fadb0f 100644 --- a/drivers/clk/rockchip/clk_rk3036.c +++ b/drivers/clk/rockchip/clk_rk3036.c @@ -65,12 +65,11 @@ static int rkclk_set_pll(struct rk3036_cru *cru, enum rk_clk_id clk_id, rk_clrreg(&pll->con1, 1 << PLL_DSMPD_SHIFT);
rk_clrsetreg(&pll->con0, - PLL_POSTDIV1_MASK << PLL_POSTDIV1_SHIFT | PLL_FBDIV_MASK, + PLL_POSTDIV1_MASK | PLL_FBDIV_MASK, (div->postdiv1 << PLL_POSTDIV1_SHIFT) | div->fbdiv); - rk_clrsetreg(&pll->con1, PLL_POSTDIV2_MASK << PLL_POSTDIV2_SHIFT | - PLL_REFDIV_MASK << PLL_REFDIV_SHIFT, - (div->postdiv2 << PLL_POSTDIV2_SHIFT | - div->refdiv << PLL_REFDIV_SHIFT)); + rk_clrsetreg(&pll->con1, PLL_POSTDIV2_MASK | PLL_REFDIV_MASK, + (div->postdiv2 << PLL_POSTDIV2_SHIFT | + div->refdiv << PLL_REFDIV_SHIFT));
/* waiting for pll lock */ while (readl(&pll->con1) & (1 << PLL_LOCK_STATUS_SHIFT)) @@ -87,8 +86,7 @@ static void rkclk_init(struct rk3036_cru *cru)
/* pll enter slow-mode */ rk_clrsetreg(&cru->cru_mode_con, - GPLL_MODE_MASK << GPLL_MODE_SHIFT | - APLL_MODE_MASK << APLL_MODE_SHIFT, + GPLL_MODE_MASK | APLL_MODE_MASK, GPLL_MODE_SLOW << GPLL_MODE_SHIFT | APLL_MODE_SLOW << APLL_MODE_SHIFT);
@@ -97,8 +95,8 @@ static void rkclk_init(struct rk3036_cru *cru) rkclk_set_pll(cru, CLK_GENERAL, &gpll_init_cfg);
/* - * select apll as core clock pll source and - * set up dependent divisors for PCLK/HCLK and ACLK clocks. + * select apll as cpu/core clock pll source and + * set up dependent divisors for PERI and ACLK clocks. * core hz : apll = 1:1 */ aclk_div = APLL_HZ / CORE_ACLK_HZ - 1; @@ -108,44 +106,40 @@ static void rkclk_init(struct rk3036_cru *cru) assert((pclk_div + 1) * CORE_PERI_HZ == APLL_HZ && pclk_div < 0xf);
rk_clrsetreg(&cru->cru_clksel_con[0], - CORE_CLK_PLL_SEL_MASK << CORE_CLK_PLL_SEL_SHIFT | - CORE_DIV_CON_MASK << CORE_DIV_CON_SHIFT, + CORE_CLK_PLL_SEL_MASK | CORE_DIV_CON_MASK, CORE_CLK_PLL_SEL_APLL << CORE_CLK_PLL_SEL_SHIFT | 0 << CORE_DIV_CON_SHIFT);
rk_clrsetreg(&cru->cru_clksel_con[1], - CORE_ACLK_DIV_MASK << CORE_ACLK_DIV_SHIFT | - CORE_PERI_DIV_MASK << CORE_PERI_DIV_SHIFT, + CORE_ACLK_DIV_MASK | CORE_PERI_DIV_MASK, aclk_div << CORE_ACLK_DIV_SHIFT | pclk_div << CORE_PERI_DIV_SHIFT);
/* - * select apll as cpu clock pll source and + * select apll as pd_bus bus clock source and * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ - aclk_div = APLL_HZ / CPU_ACLK_HZ - 1; - assert((aclk_div + 1) * CPU_ACLK_HZ == APLL_HZ && aclk_div < 0x1f); + aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1; + assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f);
- pclk_div = APLL_HZ / CPU_PCLK_HZ - 1; - assert((pclk_div + 1) * CPU_PCLK_HZ == APLL_HZ && pclk_div < 0x7); + pclk_div = GPLL_HZ / BUS_PCLK_HZ - 1; + assert((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7);
- hclk_div = APLL_HZ / CPU_HCLK_HZ - 1; - assert((hclk_div + 1) * CPU_HCLK_HZ == APLL_HZ && hclk_div < 0x3); + hclk_div = GPLL_HZ / BUS_HCLK_HZ - 1; + assert((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3);
rk_clrsetreg(&cru->cru_clksel_con[0], - CPU_CLK_PLL_SEL_MASK << CPU_CLK_PLL_SEL_SHIFT | - ACLK_CPU_DIV_MASK << ACLK_CPU_DIV_SHIFT, - CPU_CLK_PLL_SEL_APLL << CPU_CLK_PLL_SEL_SHIFT | - aclk_div << ACLK_CPU_DIV_SHIFT); + BUS_ACLK_PLL_SEL_MASK | BUS_ACLK_DIV_MASK, + BUS_ACLK_PLL_SEL_GPLL << BUS_ACLK_PLL_SEL_SHIFT | + aclk_div << BUS_ACLK_DIV_SHIFT);
rk_clrsetreg(&cru->cru_clksel_con[1], - CPU_PCLK_DIV_MASK << CPU_PCLK_DIV_SHIFT | - CPU_HCLK_DIV_MASK << CPU_HCLK_DIV_SHIFT, - pclk_div << CPU_PCLK_DIV_SHIFT | - hclk_div << CPU_HCLK_DIV_SHIFT); + BUS_PCLK_DIV_MASK | BUS_HCLK_DIV_MASK, + pclk_div << BUS_PCLK_DIV_SHIFT | + hclk_div << BUS_HCLK_DIV_SHIFT);
/* - * select gpll as peri clock pll source and + * select gpll as pd_peri bus clock source and * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / PERI_ACLK_HZ - 1; @@ -153,17 +147,15 @@ static void rkclk_init(struct rk3036_cru *cru)
hclk_div = ilog2(PERI_ACLK_HZ / PERI_HCLK_HZ); assert((1 << hclk_div) * PERI_HCLK_HZ == - PERI_ACLK_HZ && (pclk_div < 0x4)); + PERI_ACLK_HZ && (hclk_div < 0x4));
pclk_div = ilog2(PERI_ACLK_HZ / PERI_PCLK_HZ); assert((1 << pclk_div) * PERI_PCLK_HZ == PERI_ACLK_HZ && pclk_div < 0x8);
rk_clrsetreg(&cru->cru_clksel_con[10], - PERI_PLL_SEL_MASK << PERI_PLL_SEL_SHIFT | - PERI_PCLK_DIV_MASK << PERI_PCLK_DIV_SHIFT | - PERI_HCLK_DIV_MASK << PERI_HCLK_DIV_SHIFT | - PERI_ACLK_DIV_MASK << PERI_ACLK_DIV_SHIFT, + PERI_PLL_SEL_MASK | PERI_PCLK_DIV_MASK | + PERI_HCLK_DIV_MASK | PERI_ACLK_DIV_MASK, PERI_PLL_GPLL << PERI_PLL_SEL_SHIFT | pclk_div << PERI_PCLK_DIV_SHIFT | hclk_div << PERI_HCLK_DIV_SHIFT | @@ -171,8 +163,7 @@ static void rkclk_init(struct rk3036_cru *cru)
/* PLL enter normal-mode */ rk_clrsetreg(&cru->cru_mode_con, - GPLL_MODE_MASK << GPLL_MODE_SHIFT | - APLL_MODE_MASK << APLL_MODE_SHIFT, + GPLL_MODE_MASK | APLL_MODE_MASK, GPLL_MODE_NORM << GPLL_MODE_SHIFT | APLL_MODE_NORM << APLL_MODE_SHIFT); } @@ -189,9 +180,9 @@ static uint32_t rkclk_pll_get_rate(struct rk3036_cru *cru, 0xff, APLL_MODE_SHIFT, DPLL_MODE_SHIFT, 0xff, GPLL_MODE_SHIFT, 0xff }; - static u8 clk_mask[CLK_COUNT] = { - 0xff, APLL_MODE_MASK, DPLL_MODE_MASK, 0xff, - GPLL_MODE_MASK, 0xff + static u32 clk_mask[CLK_COUNT] = { + 0xffffffff, APLL_MODE_MASK, DPLL_MODE_MASK, 0xffffffff, + GPLL_MODE_MASK, 0xffffffff }; uint shift; uint mask; @@ -200,18 +191,18 @@ static uint32_t rkclk_pll_get_rate(struct rk3036_cru *cru, shift = clk_shift[clk_id]; mask = clk_mask[clk_id];
- switch ((con >> shift) & mask) { + switch ((con & mask) >> shift) { case GPLL_MODE_SLOW: return OSC_HZ; case GPLL_MODE_NORM:
/* normal mode */ con = readl(&pll->con0); - postdiv1 = (con >> PLL_POSTDIV1_SHIFT) & PLL_POSTDIV1_MASK; - fbdiv = (con >> PLL_FBDIV_SHIFT) & PLL_FBDIV_MASK; + postdiv1 = (con & PLL_POSTDIV1_MASK) >> PLL_POSTDIV1_SHIFT; + fbdiv = (con & PLL_FBDIV_MASK) >> PLL_FBDIV_SHIFT; con = readl(&pll->con1); - postdiv2 = (con >> PLL_POSTDIV2_SHIFT) & PLL_POSTDIV2_MASK; - refdiv = (con >> PLL_REFDIV_SHIFT) & PLL_REFDIV_MASK; + postdiv2 = (con & PLL_POSTDIV2_MASK) >> PLL_POSTDIV2_SHIFT; + refdiv = (con & PLL_REFDIV_MASK) >> PLL_REFDIV_SHIFT; return (24 * fbdiv / (refdiv * postdiv1 * postdiv2)) * 1000000; case GPLL_MODE_DEEP: default: @@ -229,13 +220,13 @@ static ulong rockchip_mmc_get_clk(struct rk3036_cru *cru, uint clk_general_rate, switch (periph) { case HCLK_EMMC: con = readl(&cru->cru_clksel_con[12]); - mux = (con >> EMMC_PLL_SHIFT) & EMMC_PLL_MASK; - div = (con >> EMMC_DIV_SHIFT) & EMMC_DIV_MASK; + mux = (con & EMMC_PLL_MASK) >> EMMC_PLL_SHIFT; + div = (con & EMMC_DIV_MASK) >> EMMC_DIV_SHIFT; break; case HCLK_SDIO: con = readl(&cru->cru_clksel_con[12]); - mux = (con >> MMC0_PLL_SHIFT) & MMC0_PLL_MASK; - div = (con >> MMC0_DIV_SHIFT) & MMC0_DIV_MASK; + mux = (con & MMC0_PLL_MASK) >> MMC0_PLL_SHIFT; + div = (con & MMC0_DIV_MASK) >> MMC0_DIV_SHIFT; break; default: return -EINVAL; @@ -266,15 +257,13 @@ static ulong rockchip_mmc_set_clk(struct rk3036_cru *cru, uint clk_general_rate, switch (periph) { case HCLK_EMMC: rk_clrsetreg(&cru->cru_clksel_con[12], - EMMC_PLL_MASK << EMMC_PLL_SHIFT | - EMMC_DIV_MASK << EMMC_DIV_SHIFT, + EMMC_PLL_MASK | EMMC_DIV_MASK, mux << EMMC_PLL_SHIFT | (src_clk_div - 1) << EMMC_DIV_SHIFT); break; case HCLK_SDIO: rk_clrsetreg(&cru->cru_clksel_con[11], - MMC0_PLL_MASK << MMC0_PLL_SHIFT | - MMC0_DIV_MASK << MMC0_DIV_SHIFT, + MMC0_PLL_MASK | MMC0_DIV_MASK, mux << MMC0_PLL_SHIFT | (src_clk_div - 1) << MMC0_DIV_SHIFT); break;
Hi Kever,
Can you please split out a patch that changes the shift/mask meaning (and put that patch first)?
Otherwise looks good.
Kever Yang
