[U-Boot] [PATCH 1/5] arm: dts: sync dts for i.MX6UL
Sync kernel dts for i.MX6UL from commit <0a8ad0ffa4d8> ("Merge tag 'for-linus-5.3-ofs1' of git://git.kernel.org/pub/scm/linux/kernel/git/hubcap/linux")
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx6ul-14x14-evk.dts | 422 +----------------------- arch/arm/dts/imx6ul-14x14-evk.dtsi | 531 +++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-pinfunc.h | 175 +++++----- arch/arm/dts/imx6ul.dtsi | 301 ++++++++++++------ include/dt-bindings/clock/imx6ul-clock.h | 50 +-- 5 files changed, 863 insertions(+), 616 deletions(-) create mode 100644 arch/arm/dts/imx6ul-14x14-evk.dtsi
diff --git a/arch/arm/dts/imx6ul-14x14-evk.dts b/arch/arm/dts/imx6ul-14x14-evk.dts index a642d77654..2438669f14 100644 --- a/arch/arm/dts/imx6ul-14x14-evk.dts +++ b/arch/arm/dts/imx6ul-14x14-evk.dts @@ -1,427 +1,13 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2015 Freescale Semiconductor, Inc. - * Copyright 2017-2018 NXP - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2015 Freescale Semiconductor, Inc.
/dts-v1/;
#include "imx6ul.dtsi" +#include "imx6ul-14x14-evk.dtsi"
/ { model = "Freescale i.MX6 UltraLite 14x14 EVK Board"; compatible = "fsl,imx6ul-14x14-evk", "fsl,imx6ul"; - - aliases { - spi5 = &soft_spi; - }; - - chosen { - stdout-path = &uart1; - }; - - memory { - reg = <0x80000000 0x20000000>; - }; - - regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; - - reg_sd1_vmmc: regulator@1 { - compatible = "regulator-fixed"; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio1 9 GPIO_ACTIVE_HIGH>; - off-on-delay = <20000>; - enable-active-high; - }; - - reg_can_3v3: regulator@0 { - compatible = "regulator-fixed"; - reg = <0>; - regulator-name = "can-3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpios = <&gpio_spi 3 GPIO_ACTIVE_LOW>; - }; - - reg_gpio_dvfs: regulator-gpio { - compatible = "regulator-gpio"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_dvfs>; - regulator-min-microvolt = <1300000>; - regulator-max-microvolt = <1400000>; - regulator-name = "gpio_dvfs"; - regulator-type = "voltage"; - gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>; - states = <1300000 0x1 1400000 0x0>; - }; - }; - - soft_spi: soft-spi { - compatible = "spi-gpio"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_spi4>; - pinctrl-assert-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>; - status = "okay"; - gpio-sck = <&gpio5 11 0>; - gpio-mosi = <&gpio5 10 0>; - cs-gpios = <&gpio5 7 0>; - num-chipselects = <1>; - #address-cells = <1>; - #size-cells = <0>; - - gpio_spi: gpio_spi@0 { - compatible = "fairchild,74hc595"; - gpio-controller; - #gpio-cells = <2>; - reg = <0>; - registers-number = <1>; - registers-default = /bits/ 8 <0x57>; - spi-max-frequency = <100000>; - }; - }; -}; - -&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_enet1>; - phy-mode = "rmii"; - phy-handle = <ðphy0>; - status = "okay"; -}; - -&fec2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_enet2>; - phy-mode = "rmii"; - phy-handle = <ðphy1>; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@2 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <2>; - }; - - ethphy1: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; - }; -}; - -&i2c1 { - clock-frequency = <100000>; - pinctrl-names = "default", "gpio"; - pinctrl-0 = <&pinctrl_i2c1>; - pinctrl-1 = <&pinctrl_i2c1_gpio>; - scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; - sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>; - status = "okay"; - - mag3110@0e { - compatible = "fsl,mag3110"; - reg = <0x0e>; - position = <2>; - }; - - fxls8471@1e { - compatible = "fsl,fxls8471"; - reg = <0x1e>; - position = <0>; - interrupt-parent = <&gpio5>; - interrupts = <0 8>; - }; -}; - -&i2c2 { - clock_frequency = <100000>; - pinctrl-names = "default", "gpio"; - pinctrl-0 = <&pinctrl_i2c2>; - pinctrl-1 = <&pinctrl_i2c2_gpio>; - scl-gpios = <&gpio1 30 GPIO_ACTIVE_HIGH>; - sda-gpios = <&gpio1 31 GPIO_ACTIVE_HIGH>; - status = "okay"; -}; - -&iomuxc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog_1>; - imx6ul-evk { - pinctrl_hog_1: hoggrp-1 { - fsl,pins = < - MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 /* SD1 CD */ - MX6UL_PAD_GPIO1_IO05__USDHC1_VSELECT 0x17059 /* SD1 VSELECT */ - MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x17059 /* SD1 RESET */ - MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x80000000 - >; - }; - - pinctrl_dvfs: dvfsgrp { - fsl,pins = < - MX6UL_PAD_SNVS_TAMPER3__GPIO5_IO03 0x79 - >; - }; - - pinctrl_enet1: enet1grp { - fsl,pins = < - MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 - MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 - MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 - MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 - MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 - MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 - MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 - MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 - >; - }; - - pinctrl_enet2: enet2grp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 - MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 - MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 - MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 - MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 - MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 - MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 - MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 - MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 - MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 - MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 - >; - }; - - pinctrl_i2c1_gpio: i2c1grp_gpio { - fsl,pins = < - MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x1b8b0 - MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x1b8b0 - >; - }; - - pinctrl_i2c2: i2c2grp { - fsl,pins = < - MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0 - MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0 - >; - }; - - pinctrl_i2c2_gpio: i2c2grp_gpio { - fsl,pins = < - MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30 0x1b8b0 - MX6UL_PAD_UART5_RX_DATA__GPIO1_IO31 0x1b8b0 - >; - }; - - pinctrl_qspi: qspigrp { - fsl,pins = < - MX6UL_PAD_NAND_WP_B__QSPI_A_SCLK 0x70a1 - MX6UL_PAD_NAND_READY_B__QSPI_A_DATA00 0x70a1 - MX6UL_PAD_NAND_CE0_B__QSPI_A_DATA01 0x70a1 - MX6UL_PAD_NAND_CE1_B__QSPI_A_DATA02 0x70a1 - MX6UL_PAD_NAND_CLE__QSPI_A_DATA03 0x70a1 - MX6UL_PAD_NAND_DQS__QSPI_A_SS0_B 0x70a1 - >; - }; - - pinctrl_spi4: spi4grp { - fsl,pins = < - MX6UL_PAD_BOOT_MODE0__GPIO5_IO10 0x70a1 - MX6UL_PAD_BOOT_MODE1__GPIO5_IO11 0x70a1 - MX6UL_PAD_SNVS_TAMPER7__GPIO5_IO07 0x70a1 - MX6UL_PAD_SNVS_TAMPER8__GPIO5_IO08 0x80000000 - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 - MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 - >; - }; - - pinctrl_usb_otg1_id: usbotg1idgrp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO00__ANATOP_OTG1_ID 0x17059 - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 - MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10071 - MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 - MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 - MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 - MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 - >; - }; - - pinctrl_usdhc1_100mhz: usdhc1grp100mhz { - fsl,pins = < - MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x170b9 - MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x100b9 - MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170b9 - MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170b9 - MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170b9 - MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170b9 - >; - }; - - pinctrl_usdhc1_200mhz: usdhc1grp200mhz { - fsl,pins = < - MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x170f9 - MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x100f9 - MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170f9 - MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170f9 - MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170f9 - MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170f9 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x10069 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059 - >; - }; - - pinctrl_usdhc2_8bit: usdhc2grp_8bit { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x10069 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059 - MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x17059 - MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x17059 - MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x17059 - MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x17059 - >; - }; - - pinctrl_usdhc2_8bit_100mhz: usdhc2grp_8bit_100mhz { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x100b9 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x170b9 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x170b9 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x170b9 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x170b9 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x170b9 - MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x170b9 - MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x170b9 - MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x170b9 - MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x170b9 - >; - }; - - pinctrl_usdhc2_8bit_200mhz: usdhc2grp_8bit_200mhz { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x100f9 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x170f9 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x170f9 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x170f9 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x170f9 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x170f9 - MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x170f9 - MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x170f9 - MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x170f9 - MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x170f9 - >; - }; - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX6UL_PAD_LCD_RESET__WDOG1_WDOG_ANY 0x30b0 - >; - }; - }; -}; - -&qspi { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi>; - status = "okay"; - ddrsmp=<0>; - - flash0: n25q256a@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "micron,n25q256a"; - spi-max-frequency = <29000000>; - spi-nor,ddr-quad-read-dummy = <6>; - reg = <0>; - }; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&usbotg1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usb_otg1_id>; - dr_mode = "otg"; - srp-disable; - hnp-disable; - adp-disable; - status = "okay"; -}; - -&usbotg2 { - dr_mode = "host"; - disable-over-current; - status = "okay"; -}; - -&usbphy1 { - tx-d-cal = <0x5>; -}; - -&usbphy2 { - tx-d-cal = <0x5>; -}; - -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1_100mhz>; - pinctrl-2 = <&pinctrl_usdhc1_200mhz>; - cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; - keep-power-in-suspend; - wakeup-source; - vmmc-supply = <®_sd1_vmmc>; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc2>; - non-removable; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; }; diff --git a/arch/arm/dts/imx6ul-14x14-evk.dtsi b/arch/arm/dts/imx6ul-14x14-evk.dtsi new file mode 100644 index 0000000000..d1baf0f081 --- /dev/null +++ b/arch/arm/dts/imx6ul-14x14-evk.dtsi @@ -0,0 +1,531 @@ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2015 Freescale Semiconductor, Inc. + +/ { + aliases { + spi5 = &{/spi4}; + }; + + chosen { + stdout-path = &uart1; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x20000000>; + }; + + backlight_display: backlight-display { + compatible = "pwm-backlight"; + pwms = <&pwm1 0 5000000>; + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <6>; + status = "okay"; + }; + + + reg_sd1_vmmc: regulator-sd1-vmmc { + compatible = "regulator-fixed"; + regulator-name = "VSD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 9 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + reg_can_3v3: regulator-can-3v3 { + compatible = "regulator-fixed"; + regulator-name = "can-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpios = <&gpio_spi 3 GPIO_ACTIVE_LOW>; + }; + + spi4 { + compatible = "spi-gpio"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi4>; + status = "okay"; + gpio-sck = <&gpio5 11 0>; + gpio-mosi = <&gpio5 10 0>; + cs-gpios = <&gpio5 7 0>; + num-chipselects = <1>; + #address-cells = <1>; + #size-cells = <0>; + + gpio_spi: gpio@0 { + compatible = "fairchild,74hc595"; + gpio-controller; + #gpio-cells = <2>; + reg = <0>; + registers-number = <1>; + spi-max-frequency = <100000>; + }; + }; + + panel { + compatible = "innolux,at043tn24"; + backlight = <&backlight_display>; + + port { + panel_in: endpoint { + remote-endpoint = <&display_out>; + }; + }; + }; +}; + +&clks { + assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>; + assigned-clock-rates = <786432000>; +}; + +&i2c2 { + clock_frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + codec: wm8960@1a { + #sound-dai-cells = <0>; + compatible = "wlf,wm8960"; + reg = <0x1a>; + wlf,shared-lrclk; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet1>; + phy-mode = "rmii"; + phy-handle = <ðphy0>; + status = "okay"; +}; + +&fec2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet2>; + phy-mode = "rmii"; + phy-handle = <ðphy1>; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@2 { + reg = <2>; + micrel,led-mode = <1>; + clocks = <&clks IMX6UL_CLK_ENET_REF>; + clock-names = "rmii-ref"; + }; + + ethphy1: ethernet-phy@1 { + reg = <1>; + micrel,led-mode = <1>; + clocks = <&clks IMX6UL_CLK_ENET2_REF>; + clock-names = "rmii-ref"; + }; + }; +}; + +&can1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan1>; + xceiver-supply = <®_can_3v3>; + status = "okay"; +}; + +&can2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_flexcan2>; + xceiver-supply = <®_can_3v3>; + status = "okay"; +}; + +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c1>; + pinctrl-1 = <&pinctrl_i2c1_gpio>; + scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>; + status = "okay"; + + mag3110@e { + compatible = "fsl,mag3110"; + reg = <0x0e>; + }; +}; + +&lcdif { + assigned-clocks = <&clks IMX6UL_CLK_LCDIF_PRE_SEL>; + assigned-clock-parents = <&clks IMX6UL_CLK_PLL5_VIDEO_DIV>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcdif_dat + &pinctrl_lcdif_ctrl>; + status = "okay"; + + port { + display_out: endpoint { + remote-endpoint = <&panel_in>; + }; + }; +}; + +&pwm1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm1>; + status = "okay"; +}; + +&qspi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi>; + status = "okay"; + + flash0: n25q256a@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "micron,n25q256a"; + spi-max-frequency = <29000000>; + spi-rx-bus-width = <4>; + spi-tx-bus-width = <4>; + reg = <0>; + }; +}; + +&sai2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sai2>; + assigned-clocks = <&clks IMX6UL_CLK_SAI2_SEL>, + <&clks IMX6UL_CLK_SAI2>; + assigned-clock-parents = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>; + assigned-clock-rates = <0>, <12288000>; + fsl,sai-mclk-direction-output; + status = "okay"; +}; + +&snvs_poweroff { + status = "okay"; +}; + +&tsc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_tsc>; + xnur-gpio = <&gpio1 3 GPIO_ACTIVE_LOW>; + measure-delay-time = <0xffff>; + pre-charge-time = <0xfff>; + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + uart-has-rtscts; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "otg"; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + disable-over-current; + status = "okay"; +}; + +&usbphy1 { + fsl,tx-d-cal = <106>; +}; + +&usbphy2 { + fsl,tx-d-cal = <106>; +}; + +&usdhc1 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; + keep-power-in-suspend; + wakeup-source; + vmmc-supply = <®_sd1_vmmc>; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2>; + no-1-8-v; + keep-power-in-suspend; + wakeup-source; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; +}; + +&iomuxc { + pinctrl-names = "default"; + + pinctrl_csi1: csi1grp { + fsl,pins = < + MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088 + MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088 + MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088 + MX6UL_PAD_CSI_HSYNC__CSI_HSYNC 0x1b088 + MX6UL_PAD_CSI_DATA00__CSI_DATA02 0x1b088 + MX6UL_PAD_CSI_DATA01__CSI_DATA03 0x1b088 + MX6UL_PAD_CSI_DATA02__CSI_DATA04 0x1b088 + MX6UL_PAD_CSI_DATA03__CSI_DATA05 0x1b088 + MX6UL_PAD_CSI_DATA04__CSI_DATA06 0x1b088 + MX6UL_PAD_CSI_DATA05__CSI_DATA07 0x1b088 + MX6UL_PAD_CSI_DATA06__CSI_DATA08 0x1b088 + MX6UL_PAD_CSI_DATA07__CSI_DATA09 0x1b088 + >; + }; + + pinctrl_enet1: enet1grp { + fsl,pins = < + MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 + MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 + MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 + MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 + MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 + >; + }; + + pinctrl_enet2: enet2grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 + MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 + MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 + MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 + MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 + MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 + MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 + MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 + MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031 + >; + }; + + pinctrl_flexcan1: flexcan1grp{ + fsl,pins = < + MX6UL_PAD_UART3_RTS_B__FLEXCAN1_RX 0x1b020 + MX6UL_PAD_UART3_CTS_B__FLEXCAN1_TX 0x1b020 + >; + }; + + pinctrl_flexcan2: flexcan2grp{ + fsl,pins = < + MX6UL_PAD_UART2_RTS_B__FLEXCAN2_RX 0x1b020 + MX6UL_PAD_UART2_CTS_B__FLEXCAN2_TX 0x1b020 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 + MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 + >; + }; + + pinctrl_i2c1_gpio: i2c1grp_gpio { + fsl,pins = < + MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x1b8b0 + MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x1b8b0 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0 + MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0 + >; + }; + + pinctrl_lcdif_dat: lcdifdatgrp { + fsl,pins = < + MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x79 + MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x79 + MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x79 + MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x79 + MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x79 + MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x79 + MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x79 + MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x79 + MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x79 + MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x79 + MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x79 + MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x79 + MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x79 + MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x79 + MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x79 + MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x79 + MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x79 + MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x79 + MX6UL_PAD_LCD_DATA18__LCDIF_DATA18 0x79 + MX6UL_PAD_LCD_DATA19__LCDIF_DATA19 0x79 + MX6UL_PAD_LCD_DATA20__LCDIF_DATA20 0x79 + MX6UL_PAD_LCD_DATA21__LCDIF_DATA21 0x79 + MX6UL_PAD_LCD_DATA22__LCDIF_DATA22 0x79 + MX6UL_PAD_LCD_DATA23__LCDIF_DATA23 0x79 + >; + }; + + pinctrl_lcdif_ctrl: lcdifctrlgrp { + fsl,pins = < + MX6UL_PAD_LCD_CLK__LCDIF_CLK 0x79 + MX6UL_PAD_LCD_ENABLE__LCDIF_ENABLE 0x79 + MX6UL_PAD_LCD_HSYNC__LCDIF_HSYNC 0x79 + MX6UL_PAD_LCD_VSYNC__LCDIF_VSYNC 0x79 + /* used for lcd reset */ + MX6UL_PAD_SNVS_TAMPER9__GPIO5_IO09 0x79 + >; + }; + + pinctrl_qspi: qspigrp { + fsl,pins = < + MX6UL_PAD_NAND_WP_B__QSPI_A_SCLK 0x70a1 + MX6UL_PAD_NAND_READY_B__QSPI_A_DATA00 0x70a1 + MX6UL_PAD_NAND_CE0_B__QSPI_A_DATA01 0x70a1 + MX6UL_PAD_NAND_CE1_B__QSPI_A_DATA02 0x70a1 + MX6UL_PAD_NAND_CLE__QSPI_A_DATA03 0x70a1 + MX6UL_PAD_NAND_DQS__QSPI_A_SS0_B 0x70a1 + >; + }; + + pinctrl_sai2: sai2grp { + fsl,pins = < + MX6UL_PAD_JTAG_TDI__SAI2_TX_BCLK 0x17088 + MX6UL_PAD_JTAG_TDO__SAI2_TX_SYNC 0x17088 + MX6UL_PAD_JTAG_TRST_B__SAI2_TX_DATA 0x11088 + MX6UL_PAD_JTAG_TCK__SAI2_RX_DATA 0x11088 + MX6UL_PAD_JTAG_TMS__SAI2_MCLK 0x17088 + MX6UL_PAD_SNVS_TAMPER4__GPIO5_IO04 0x17059 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO08__PWM1_OUT 0x110b0 + >; + }; + + pinctrl_sim2: sim2grp { + fsl,pins = < + MX6UL_PAD_CSI_DATA03__SIM2_PORT1_PD 0xb808 + MX6UL_PAD_CSI_DATA04__SIM2_PORT1_CLK 0x31 + MX6UL_PAD_CSI_DATA05__SIM2_PORT1_RST_B 0xb808 + MX6UL_PAD_CSI_DATA06__SIM2_PORT1_SVEN 0xb808 + MX6UL_PAD_CSI_DATA07__SIM2_PORT1_TRXD 0xb809 + MX6UL_PAD_CSI_DATA02__GPIO4_IO23 0x3008 + >; + }; + + pinctrl_spi4: spi4grp { + fsl,pins = < + MX6UL_PAD_BOOT_MODE0__GPIO5_IO10 0x70a1 + MX6UL_PAD_BOOT_MODE1__GPIO5_IO11 0x70a1 + MX6UL_PAD_SNVS_TAMPER7__GPIO5_IO07 0x70a1 + MX6UL_PAD_SNVS_TAMPER8__GPIO5_IO08 0x80000000 + >; + }; + + pinctrl_tsc: tscgrp { + fsl,pins = < + MX6UL_PAD_GPIO1_IO01__GPIO1_IO01 0xb0 + MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0xb0 + MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0xb0 + MX6UL_PAD_GPIO1_IO04__GPIO1_IO04 0xb0 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 + MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX6UL_PAD_UART2_TX_DATA__UART2_DCE_TX 0x1b0b1 + MX6UL_PAD_UART2_RX_DATA__UART2_DCE_RX 0x1b0b1 + MX6UL_PAD_UART3_RX_DATA__UART2_DCE_RTS 0x1b0b1 + MX6UL_PAD_UART3_TX_DATA__UART2_DCE_CTS 0x1b0b1 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10059 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 + MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 /* SD1 CD */ + MX6UL_PAD_GPIO1_IO05__USDHC1_VSELECT 0x17059 /* SD1 VSELECT */ + MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x17059 /* SD1 RESET */ + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1grp100mhz { + fsl,pins = < + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x170b9 + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x100b9 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170b9 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170b9 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170b9 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170b9 + + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1grp200mhz { + fsl,pins = < + MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x170f9 + MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x100f9 + MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170f9 + MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170f9 + MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170f9 + MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170f9 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x17059 + MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059 + MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059 + MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059 + MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059 + MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX6UL_PAD_LCD_RESET__WDOG1_WDOG_ANY 0x30b0 + >; + }; +}; diff --git a/arch/arm/dts/imx6ul-pinfunc.h b/arch/arm/dts/imx6ul-pinfunc.h index 0034eeb845..380d2db13a 100644 --- a/arch/arm/dts/imx6ul-pinfunc.h +++ b/arch/arm/dts/imx6ul-pinfunc.h @@ -1,10 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* - * Copyright (C) 2015 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * + * Copyright 2014 - 2015 Freescale Semiconductor, Inc. */
#ifndef __DTS_IMX6UL_PINFUNC_H @@ -34,14 +30,14 @@ #define MX6UL_PAD_JTAG_MOD__ENET1_REF_CLK_25M 0x0044 0x02d0 0x0000 3 0 #define MX6UL_PAD_JTAG_MOD__CCM_PMIC_RDY 0x0044 0x02d0 0x04c0 4 0 #define MX6UL_PAD_JTAG_MOD__GPIO1_IO10 0x0044 0x02d0 0x0000 5 0 -#define MX6UL_PAD_JTAG_MOD__SDMA_EXT_EVENT00 0x0044 0x02d0 0x0000 6 0 +#define MX6UL_PAD_JTAG_MOD__SDMA_EXT_EVENT00 0x0044 0x02d0 0x0610 6 0 #define MX6UL_PAD_JTAG_TMS__SJC_TMS 0x0048 0x02d4 0x0000 0 0 #define MX6UL_PAD_JTAG_TMS__GPT2_CAPTURE1 0x0048 0x02d4 0x0598 1 0 -#define MX6UL_PAD_JTAG_TMS__SAI2_MCLK 0x0048 0x02d4 0x0000 2 0 +#define MX6UL_PAD_JTAG_TMS__SAI2_MCLK 0x0048 0x02d4 0x05f0 2 0 #define MX6UL_PAD_JTAG_TMS__CCM_CLKO1 0x0048 0x02d4 0x0000 3 0 #define MX6UL_PAD_JTAG_TMS__CCM_WAIT 0x0048 0x02d4 0x0000 4 0 #define MX6UL_PAD_JTAG_TMS__GPIO1_IO11 0x0048 0x02d4 0x0000 5 0 -#define MX6UL_PAD_JTAG_TMS__SDMA_EXT_EVENT01 0x0048 0x02d4 0x0000 6 0 +#define MX6UL_PAD_JTAG_TMS__SDMA_EXT_EVENT01 0x0048 0x02d4 0x0614 6 0 #define MX6UL_PAD_JTAG_TMS__EPIT1_OUT 0x0048 0x02d4 0x0000 8 0 #define MX6UL_PAD_JTAG_TDO__SJC_TDO 0x004c 0x02d8 0x0000 0 0 #define MX6UL_PAD_JTAG_TDO__GPT2_CAPTURE2 0x004c 0x02d8 0x059c 1 0 @@ -63,12 +59,14 @@ #define MX6UL_PAD_JTAG_TCK__SAI2_RX_DATA 0x0054 0x02e0 0x05f4 2 0 #define MX6UL_PAD_JTAG_TCK__PWM7_OUT 0x0054 0x02e0 0x0000 4 0 #define MX6UL_PAD_JTAG_TCK__GPIO1_IO14 0x0054 0x02e0 0x0000 5 0 +#define MX6UL_PAD_JTAG_TCK__OSC32K_32K_OUT 0x0054 0x02e0 0x0000 6 0 #define MX6UL_PAD_JTAG_TCK__SIM2_POWER_FAIL 0x0054 0x02e0 0x0000 8 0 #define MX6UL_PAD_JTAG_TRST_B__SJC_TRSTB 0x0058 0x02e4 0x0000 0 0 #define MX6UL_PAD_JTAG_TRST_B__GPT2_COMPARE3 0x0058 0x02e4 0x0000 1 0 #define MX6UL_PAD_JTAG_TRST_B__SAI2_TX_DATA 0x0058 0x02e4 0x0000 2 0 #define MX6UL_PAD_JTAG_TRST_B__PWM8_OUT 0x0058 0x02e4 0x0000 4 0 #define MX6UL_PAD_JTAG_TRST_B__GPIO1_IO15 0x0058 0x02e4 0x0000 5 0 +#define MX6UL_PAD_JTAG_TRST_B__REF_CLK_24M 0x0058 0x02e4 0x0000 6 0 #define MX6UL_PAD_JTAG_TRST_B__CAAM_RNG_OSC_OBS 0x0058 0x02e4 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO00__I2C2_SCL 0x005c 0x02e8 0x05ac 0 1 #define MX6UL_PAD_GPIO1_IO00__GPT1_CAPTURE1 0x005c 0x02e8 0x058c 1 0 @@ -94,22 +92,24 @@ #define MX6UL_PAD_GPIO1_IO02__ENET1_REF_CLK_25M 0x0064 0x02f0 0x0000 3 0 #define MX6UL_PAD_GPIO1_IO02__USDHC1_WP 0x0064 0x02f0 0x066c 4 0 #define MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0x0064 0x02f0 0x0000 5 0 -#define MX6UL_PAD_GPIO1_IO02__SDMA_EXT_EVENT00 0x0064 0x02f0 0x0000 6 0 +#define MX6UL_PAD_GPIO1_IO02__SDMA_EXT_EVENT00 0x0064 0x02f0 0x0610 6 1 #define MX6UL_PAD_GPIO1_IO02__SRC_ANY_PU_RESET 0x0064 0x02f0 0x0000 7 0 #define MX6UL_PAD_GPIO1_IO02__UART1_DCE_TX 0x0064 0x02f0 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO02__UART1_DTE_RX 0x0064 0x02f0 0x0624 8 0 #define MX6UL_PAD_GPIO1_IO03__I2C1_SDA 0x0068 0x02f4 0x05a8 0 1 #define MX6UL_PAD_GPIO1_IO03__GPT1_COMPARE3 0x0068 0x02f4 0x0000 1 0 #define MX6UL_PAD_GPIO1_IO03__USB_OTG2_OC 0x0068 0x02f4 0x0660 2 0 +#define MX6UL_PAD_GPIO1_IO03__OSC32K_32K_OUT 0x0068 0x02f4 0x0000 3 0 #define MX6UL_PAD_GPIO1_IO03__USDHC1_CD_B 0x0068 0x02f4 0x0668 4 0 #define MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0x0068 0x02f4 0x0000 5 0 -#define MX6UL_PAD_GPIO1_IO03__CCM_DI0_eXT_CLK 0x0068 0x02f4 0x0000 6 0 +#define MX6UL_PAD_GPIO1_IO03__CCM_DI0_EXT_CLK 0x0068 0x02f4 0x0000 6 0 #define MX6UL_PAD_GPIO1_IO03__SRC_TESTER_ACK 0x0068 0x02f4 0x0000 7 0 -#define MX6UL_PAD_GPIO1_IO03__UART1_DTE_TX 0x0068 0x02f4 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO03__UART1_DCE_RX 0x0068 0x02f4 0x0624 8 1 +#define MX6UL_PAD_GPIO1_IO03__UART1_DTE_TX 0x0068 0x02f4 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO04__ENET1_REF_CLK1 0x006c 0x02f8 0x0574 0 1 #define MX6UL_PAD_GPIO1_IO04__PWM3_OUT 0x006c 0x02f8 0x0000 1 0 #define MX6UL_PAD_GPIO1_IO04__USB_OTG1_PWR 0x006c 0x02f8 0x0000 2 0 +#define MX6UL_PAD_GPIO1_IO04__REF_CLK_24M 0x006c 0x02f8 0x0000 3 0 #define MX6UL_PAD_GPIO1_IO04__USDHC1_RESET_B 0x006c 0x02f8 0x0000 4 0 #define MX6UL_PAD_GPIO1_IO04__GPIO1_IO04 0x006c 0x02f8 0x0000 5 0 #define MX6UL_PAD_GPIO1_IO04__ENET2_1588_EVENT0_IN 0x006c 0x02f8 0x0000 6 0 @@ -200,7 +200,7 @@ #define MX6UL_PAD_UART2_TX_DATA__CSI_DATA06 0x0094 0x0320 0x04dc 3 0 #define MX6UL_PAD_UART2_TX_DATA__GPT1_CAPTURE1 0x0094 0x0320 0x058c 4 1 #define MX6UL_PAD_UART2_TX_DATA__GPIO1_IO20 0x0094 0x0320 0x0000 5 0 -#define MX6UL_PAD_UART2_TX_DATA__ECSPI3_SS0 0x0094 0x0320 0x0000 8 0 +#define MX6UL_PAD_UART2_TX_DATA__ECSPI3_SS0 0x0094 0x0320 0x0560 8 0 #define MX6UL_PAD_UART2_RX_DATA__UART2_DCE_RX 0x0098 0x0324 0x062c 0 1 #define MX6UL_PAD_UART2_RX_DATA__UART2_DTE_TX 0x0098 0x0324 0x0000 0 0 #define MX6UL_PAD_UART2_RX_DATA__ENET1_TDATA03 0x0098 0x0324 0x0000 1 0 @@ -232,7 +232,7 @@ #define MX6UL_PAD_UART3_TX_DATA__UART3_DTE_RX 0x00a4 0x0330 0x0634 0 0 #define MX6UL_PAD_UART3_TX_DATA__ENET2_RDATA02 0x00a4 0x0330 0x0000 1 0 #define MX6UL_PAD_UART3_TX_DATA__SIM1_PORT0_PD 0x00a4 0x0330 0x0000 2 0 -#define MX6UL_PAD_UART3_TX_DATA__CSI_DATA01 0x00a4 0x0330 0x0000 3 0 +#define MX6UL_PAD_UART3_TX_DATA__CSI_DATA01 0x00a4 0x0330 0x04d4 3 0 #define MX6UL_PAD_UART3_TX_DATA__UART2_DCE_CTS 0x00a4 0x0330 0x0000 4 0 #define MX6UL_PAD_UART3_TX_DATA__UART2_DTE_RTS 0x00a4 0x0330 0x0628 4 2 #define MX6UL_PAD_UART3_TX_DATA__GPIO1_IO24 0x00a4 0x0330 0x0000 5 0 @@ -242,7 +242,7 @@ #define MX6UL_PAD_UART3_RX_DATA__UART3_DTE_TX 0x00a8 0x0334 0x0000 0 0 #define MX6UL_PAD_UART3_RX_DATA__ENET2_RDATA03 0x00a8 0x0334 0x0000 1 0 #define MX6UL_PAD_UART3_RX_DATA__SIM2_PORT0_PD 0x00a8 0x0334 0x0000 2 0 -#define MX6UL_PAD_UART3_RX_DATA__CSI_DATA00 0x00a8 0x0334 0x0000 3 0 +#define MX6UL_PAD_UART3_RX_DATA__CSI_DATA00 0x00a8 0x0334 0x04d0 3 0 #define MX6UL_PAD_UART3_RX_DATA__UART2_DCE_RTS 0x00a8 0x0334 0x0628 4 3 #define MX6UL_PAD_UART3_RX_DATA__UART2_DTE_CTS 0x00a8 0x0334 0x0000 4 0 #define MX6UL_PAD_UART3_RX_DATA__GPIO1_IO25 0x00a8 0x0334 0x0000 5 0 @@ -251,7 +251,7 @@ #define MX6UL_PAD_UART3_CTS_B__UART3_DTE_RTS 0x00ac 0x0338 0x0630 0 0 #define MX6UL_PAD_UART3_CTS_B__ENET2_RX_CLK 0x00ac 0x0338 0x0000 1 0 #define MX6UL_PAD_UART3_CTS_B__FLEXCAN1_TX 0x00ac 0x0338 0x0000 2 0 -#define MX6UL_PAD_UART3_CTS_B__CSI_DATA10 0x00ac 0x0338 0x0000 3 0 +#define MX6UL_PAD_UART3_CTS_B__CSI_DATA10 0x00ac 0x0338 0x04ec 3 0 #define MX6UL_PAD_UART3_CTS_B__ENET1_1588_EVENT1_IN 0x00ac 0x0338 0x0000 4 0 #define MX6UL_PAD_UART3_CTS_B__GPIO1_IO26 0x00ac 0x0338 0x0000 5 0 #define MX6UL_PAD_UART3_CTS_B__EPIT2_OUT 0x00ac 0x0338 0x0000 8 0 @@ -259,7 +259,7 @@ #define MX6UL_PAD_UART3_RTS_B__UART3_DTE_CTS 0x00b0 0x033c 0x0000 0 0 #define MX6UL_PAD_UART3_RTS_B__ENET2_TX_ER 0x00b0 0x033c 0x0000 1 0 #define MX6UL_PAD_UART3_RTS_B__FLEXCAN1_RX 0x00b0 0x033c 0x0584 2 0 -#define MX6UL_PAD_UART3_RTS_B__CSI_DATA11 0x00b0 0x033c 0x0000 3 0 +#define MX6UL_PAD_UART3_RTS_B__CSI_DATA11 0x00b0 0x033c 0x04f0 3 0 #define MX6UL_PAD_UART3_RTS_B__ENET1_1588_EVENT1_OUT 0x00b0 0x033c 0x0000 4 0 #define MX6UL_PAD_UART3_RTS_B__GPIO1_IO27 0x00b0 0x033c 0x0000 5 0 #define MX6UL_PAD_UART3_RTS_B__WDOG1_WDOG_B 0x00b0 0x033c 0x0000 8 0 @@ -267,7 +267,7 @@ #define MX6UL_PAD_UART4_TX_DATA__UART4_DTE_RX 0x00b4 0x0340 0x063c 0 0 #define MX6UL_PAD_UART4_TX_DATA__ENET2_TDATA02 0x00b4 0x0340 0x0000 1 0 #define MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x00b4 0x0340 0x05a4 2 1 -#define MX6UL_PAD_UART4_TX_DATA__CSI_DATA12 0x00b4 0x0340 0x0000 3 0 +#define MX6UL_PAD_UART4_TX_DATA__CSI_DATA12 0x00b4 0x0340 0x04f4 3 0 #define MX6UL_PAD_UART4_TX_DATA__CSU_CSU_ALARM_AUT02 0x00b4 0x0340 0x0000 4 0 #define MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x00b4 0x0340 0x0000 5 0 #define MX6UL_PAD_UART4_TX_DATA__ECSPI2_SCLK 0x00b4 0x0340 0x0544 8 1 @@ -275,23 +275,23 @@ #define MX6UL_PAD_UART4_RX_DATA__UART4_DTE_TX 0x00b8 0x0344 0x0000 0 0 #define MX6UL_PAD_UART4_RX_DATA__ENET2_TDATA03 0x00b8 0x0344 0x0000 1 0 #define MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x00b8 0x0344 0x05a8 2 2 -#define MX6UL_PAD_UART4_RX_DATA__CSI_DATA13 0x00b8 0x0344 0x0000 3 0 +#define MX6UL_PAD_UART4_RX_DATA__CSI_DATA13 0x00b8 0x0344 0x04f8 3 0 #define MX6UL_PAD_UART4_RX_DATA__CSU_CSU_ALARM_AUT01 0x00b8 0x0344 0x0000 4 0 #define MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x00b8 0x0344 0x0000 5 0 -#define MX6UL_PAD_UART4_RX_DATA__ECSPI2_SS0 0x00b8 0x0344 0x0000 8 0 +#define MX6UL_PAD_UART4_RX_DATA__ECSPI2_SS0 0x00b8 0x0344 0x0550 8 1 #define MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30 0x00bc 0x0348 0x0000 5 0 #define MX6UL_PAD_UART5_TX_DATA__ECSPI2_MOSI 0x00bc 0x0348 0x054c 8 0 #define MX6UL_PAD_UART5_TX_DATA__UART5_DCE_TX 0x00bc 0x0348 0x0000 0 0 #define MX6UL_PAD_UART5_TX_DATA__UART5_DTE_RX 0x00bc 0x0348 0x0644 0 4 #define MX6UL_PAD_UART5_TX_DATA__ENET2_CRS 0x00bc 0x0348 0x0000 1 0 #define MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x00bc 0x0348 0x05ac 2 2 -#define MX6UL_PAD_UART5_TX_DATA__CSI_DATA14 0x00bc 0x0348 0x0000 3 0 +#define MX6UL_PAD_UART5_TX_DATA__CSI_DATA14 0x00bc 0x0348 0x04fc 3 0 #define MX6UL_PAD_UART5_TX_DATA__CSU_CSU_ALARM_AUT00 0x00bc 0x0348 0x0000 4 0 #define MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX 0x00c0 0x034c 0x0644 0 5 #define MX6UL_PAD_UART5_RX_DATA__UART5_DTE_TX 0x00c0 0x034c 0x0000 0 0 #define MX6UL_PAD_UART5_RX_DATA__ENET2_COL 0x00c0 0x034c 0x0000 1 0 #define MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x00c0 0x034c 0x05b0 2 2 -#define MX6UL_PAD_UART5_RX_DATA__CSI_DATA15 0x00c0 0x034c 0x0000 3 0 +#define MX6UL_PAD_UART5_RX_DATA__CSI_DATA15 0x00c0 0x034c 0x0500 3 0 #define MX6UL_PAD_UART5_RX_DATA__CSU_CSU_INT_DEB 0x00c0 0x034c 0x0000 4 0 #define MX6UL_PAD_UART5_RX_DATA__GPIO1_IO31 0x00c0 0x034c 0x0000 5 0 #define MX6UL_PAD_UART5_RX_DATA__ECSPI2_MISO 0x00c0 0x034c 0x0548 8 1 @@ -299,59 +299,61 @@ #define MX6UL_PAD_ENET1_RX_DATA0__UART4_DCE_RTS 0x00c4 0x0350 0x0638 1 0 #define MX6UL_PAD_ENET1_RX_DATA0__UART4_DTE_CTS 0x00c4 0x0350 0x0000 1 0 #define MX6UL_PAD_ENET1_RX_DATA0__PWM1_OUT 0x00c4 0x0350 0x0000 2 0 -#define MX6UL_PAD_ENET1_RX_DATA0__CSI_DATA16 0x00c4 0x0350 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_DATA0__CSI_DATA16 0x00c4 0x0350 0x0504 3 0 #define MX6UL_PAD_ENET1_RX_DATA0__FLEXCAN1_TX 0x00c4 0x0350 0x0000 4 0 #define MX6UL_PAD_ENET1_RX_DATA0__GPIO2_IO00 0x00c4 0x0350 0x0000 5 0 -#define MX6UL_PAD_ENET1_RX_DATA0__KPP_ROW00 0x00c4 0x0350 0x0000 6 0 +#define MX6UL_PAD_ENET1_RX_DATA0__KPP_ROW00 0x00c4 0x0350 0x05d0 6 0 #define MX6UL_PAD_ENET1_RX_DATA0__USDHC1_LCTL 0x00c4 0x0350 0x0000 8 0 #define MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x00c8 0x0354 0x0000 0 0 #define MX6UL_PAD_ENET1_RX_DATA1__UART4_DCE_CTS 0x00c8 0x0354 0x0000 1 0 #define MX6UL_PAD_ENET1_RX_DATA1__UART4_DTE_RTS 0x00c8 0x0354 0x0638 1 1 #define MX6UL_PAD_ENET1_RX_DATA1__PWM2_OUT 0x00c8 0x0354 0x0000 2 0 -#define MX6UL_PAD_ENET1_RX_DATA1__CSI_DATA17 0x00c8 0x0354 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_DATA1__CSI_DATA17 0x00c8 0x0354 0x0508 3 0 #define MX6UL_PAD_ENET1_RX_DATA1__FLEXCAN1_RX 0x00c8 0x0354 0x0584 4 1 #define MX6UL_PAD_ENET1_RX_DATA1__GPIO2_IO01 0x00c8 0x0354 0x0000 5 0 -#define MX6UL_PAD_ENET1_RX_DATA1__KPP_COL00 0x00c8 0x0354 0x0000 6 0 +#define MX6UL_PAD_ENET1_RX_DATA1__KPP_COL00 0x00c8 0x0354 0x05c4 6 0 #define MX6UL_PAD_ENET1_RX_DATA1__USDHC2_LCTL 0x00c8 0x0354 0x0000 8 0 #define MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x00cc 0x0358 0x0000 0 0 #define MX6UL_PAD_ENET1_RX_EN__UART5_DCE_RTS 0x00cc 0x0358 0x0640 1 3 #define MX6UL_PAD_ENET1_RX_EN__UART5_DTE_CTS 0x00cc 0x0358 0x0000 1 0 -#define MX6UL_PAD_ENET1_RX_EN__CSI_DATA18 0x00cc 0x0358 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_EN__OSC32K_32K_OUT 0x00cc 0x0358 0x0000 2 0 +#define MX6UL_PAD_ENET1_RX_EN__CSI_DATA18 0x00cc 0x0358 0x050c 3 0 #define MX6UL_PAD_ENET1_RX_EN__FLEXCAN2_TX 0x00cc 0x0358 0x0000 4 0 #define MX6UL_PAD_ENET1_RX_EN__GPIO2_IO02 0x00cc 0x0358 0x0000 5 0 -#define MX6UL_PAD_ENET1_RX_EN__KPP_ROW01 0x00cc 0x0358 0x0000 6 0 +#define MX6UL_PAD_ENET1_RX_EN__KPP_ROW01 0x00cc 0x0358 0x05d4 6 0 #define MX6UL_PAD_ENET1_RX_EN__USDHC1_VSELECT 0x00cc 0x0358 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x00d0 0x035c 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_DATA0__UART5_DCE_CTS 0x00d0 0x035c 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_DATA0__UART5_DTE_RTS 0x00d0 0x035c 0x0640 1 4 -#define MX6UL_PAD_ENET1_TX_DATA0__CSI_DATA19 0x00d0 0x035c 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_DATA0__REF_CLK_24M 0x00d0 0x035c 0x0000 2 0 +#define MX6UL_PAD_ENET1_TX_DATA0__CSI_DATA19 0x00d0 0x035c 0x0510 3 0 #define MX6UL_PAD_ENET1_TX_DATA0__FLEXCAN2_RX 0x00d0 0x035c 0x0588 4 1 #define MX6UL_PAD_ENET1_TX_DATA0__GPIO2_IO03 0x00d0 0x035c 0x0000 5 0 -#define MX6UL_PAD_ENET1_TX_DATA0__KPP_COL01 0x00d0 0x035c 0x0000 6 0 +#define MX6UL_PAD_ENET1_TX_DATA0__KPP_COL01 0x00d0 0x035c 0x05c8 6 0 #define MX6UL_PAD_ENET1_TX_DATA0__USDHC2_VSELECT 0x00d0 0x035c 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x00d4 0x0360 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_DATA1__UART6_DCE_CTS 0x00d4 0x0360 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_DATA1__UART6_DTE_RTS 0x00d4 0x0360 0x0648 1 2 #define MX6UL_PAD_ENET1_TX_DATA1__PWM5_OUT 0x00d4 0x0360 0x0000 2 0 -#define MX6UL_PAD_ENET1_TX_DATA1__CSI_DATA20 0x00d4 0x0360 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_DATA1__CSI_DATA20 0x00d4 0x0360 0x0514 3 0 #define MX6UL_PAD_ENET1_TX_DATA1__ENET2_MDIO 0x00d4 0x0360 0x0580 4 1 #define MX6UL_PAD_ENET1_TX_DATA1__GPIO2_IO04 0x00d4 0x0360 0x0000 5 0 -#define MX6UL_PAD_ENET1_TX_DATA1__KPP_ROW02 0x00d4 0x0360 0x0000 6 0 +#define MX6UL_PAD_ENET1_TX_DATA1__KPP_ROW02 0x00d4 0x0360 0x05d8 6 0 #define MX6UL_PAD_ENET1_TX_DATA1__WDOG1_WDOG_RST_B_DEB 0x00d4 0x0360 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x00d8 0x0364 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_EN__UART6_DCE_RTS 0x00d8 0x0364 0x0648 1 3 #define MX6UL_PAD_ENET1_TX_EN__UART6_DTE_CTS 0x00d8 0x0364 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_EN__PWM6_OUT 0x00d8 0x0364 0x0000 2 0 -#define MX6UL_PAD_ENET1_TX_EN__CSI_DATA21 0x00d8 0x0364 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_EN__CSI_DATA21 0x00d8 0x0364 0x0518 3 0 #define MX6UL_PAD_ENET1_TX_EN__ENET2_MDC 0x00d8 0x0364 0x0000 4 0 #define MX6UL_PAD_ENET1_TX_EN__GPIO2_IO05 0x00d8 0x0364 0x0000 5 0 -#define MX6UL_PAD_ENET1_TX_EN__KPP_COL02 0x00d8 0x0364 0x0000 6 0 +#define MX6UL_PAD_ENET1_TX_EN__KPP_COL02 0x00d8 0x0364 0x05cc 6 0 #define MX6UL_PAD_ENET1_TX_EN__WDOG2_WDOG_RST_B_DEB 0x00d8 0x0364 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_CLK__ENET1_TX_CLK 0x00dc 0x0368 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_CLK__UART7_DCE_CTS 0x00dc 0x0368 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_CLK__UART7_DTE_RTS 0x00dc 0x0368 0x0650 1 0 #define MX6UL_PAD_ENET1_TX_CLK__PWM7_OUT 0x00dc 0x0368 0x0000 2 0 -#define MX6UL_PAD_ENET1_TX_CLK__CSI_DATA22 0x00dc 0x0368 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_CLK__CSI_DATA22 0x00dc 0x0368 0x051c 3 0 #define MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x00dc 0x0368 0x0574 4 2 #define MX6UL_PAD_ENET1_TX_CLK__GPIO2_IO06 0x00dc 0x0368 0x0000 5 0 #define MX6UL_PAD_ENET1_TX_CLK__KPP_ROW03 0x00dc 0x0368 0x0000 6 0 @@ -360,7 +362,7 @@ #define MX6UL_PAD_ENET1_RX_ER__UART7_DCE_RTS 0x00e0 0x036c 0x0650 1 1 #define MX6UL_PAD_ENET1_RX_ER__UART7_DTE_CTS 0x00e0 0x036c 0x0000 1 0 #define MX6UL_PAD_ENET1_RX_ER__PWM8_OUT 0x00e0 0x036c 0x0000 2 0 -#define MX6UL_PAD_ENET1_RX_ER__CSI_DATA23 0x00e0 0x036c 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_ER__CSI_DATA23 0x00e0 0x036c 0x0520 3 0 #define MX6UL_PAD_ENET1_RX_ER__EIM_CRE 0x00e0 0x036c 0x0000 4 0 #define MX6UL_PAD_ENET1_RX_ER__GPIO2_IO07 0x00e0 0x036c 0x0000 5 0 #define MX6UL_PAD_ENET1_RX_ER__KPP_COL03 0x00e0 0x036c 0x0000 6 0 @@ -377,7 +379,7 @@ #define MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x00e8 0x0374 0x0000 0 0 #define MX6UL_PAD_ENET2_RX_DATA1__UART6_DCE_RX 0x00e8 0x0374 0x064c 1 2 #define MX6UL_PAD_ENET2_RX_DATA1__UART6_DTE_TX 0x00e8 0x0374 0x0000 1 0 -#define MX6UL_PAD_ENET2_RX_DATA1__SIM1_PORT0_cLK 0x00e8 0x0374 0x0000 2 0 +#define MX6UL_PAD_ENET2_RX_DATA1__SIM1_PORT0_CLK 0x00e8 0x0374 0x0000 2 0 #define MX6UL_PAD_ENET2_RX_DATA1__I2C3_SDA 0x00e8 0x0374 0x05b8 3 1 #define MX6UL_PAD_ENET2_RX_DATA1__ENET1_MDC 0x00e8 0x0374 0x0000 4 0 #define MX6UL_PAD_ENET2_RX_DATA1__GPIO2_IO09 0x00e8 0x0374 0x0000 5 0 @@ -400,6 +402,7 @@ #define MX6UL_PAD_ENET2_TX_DATA0__EIM_EB_B02 0x00f0 0x037c 0x0000 4 0 #define MX6UL_PAD_ENET2_TX_DATA0__GPIO2_IO11 0x00f0 0x037c 0x0000 5 0 #define MX6UL_PAD_ENET2_TX_DATA0__KPP_COL05 0x00f0 0x037c 0x0000 6 0 +#define MX6UL_PAD_ENET2_TX_DATA0__REF_CLK_24M 0x00f0 0x037c 0x0000 8 0 #define MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x00f4 0x0380 0x0000 0 0 #define MX6UL_PAD_ENET2_TX_DATA1__UART8_DCE_TX 0x00f4 0x0380 0x0000 1 0 #define MX6UL_PAD_ENET2_TX_DATA1__UART8_DTE_RX 0x00f4 0x0380 0x065c 1 0 @@ -412,7 +415,7 @@ #define MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x00f8 0x0384 0x0000 0 0 #define MX6UL_PAD_ENET2_TX_EN__UART8_DCE_RX 0x00f8 0x0384 0x065c 1 1 #define MX6UL_PAD_ENET2_TX_EN__UART8_DTE_TX 0x00f8 0x0384 0x0000 1 0 -#define MX6UL_PAD_ENET2_TX_EN__SIM2_PORT0_cLK 0x00f8 0x0384 0x0000 2 0 +#define MX6UL_PAD_ENET2_TX_EN__SIM2_PORT0_CLK 0x00f8 0x0384 0x0000 2 0 #define MX6UL_PAD_ENET2_TX_EN__ECSPI4_MOSI 0x00f8 0x0384 0x056c 3 0 #define MX6UL_PAD_ENET2_TX_EN__EIM_ACLK_FREERUN 0x00f8 0x0384 0x0000 4 0 #define MX6UL_PAD_ENET2_TX_EN__GPIO2_IO13 0x00f8 0x0384 0x0000 5 0 @@ -431,7 +434,7 @@ #define MX6UL_PAD_ENET2_RX_ER__UART8_DCE_RTS 0x0100 0x038c 0x0658 1 1 #define MX6UL_PAD_ENET2_RX_ER__UART8_DTE_CTS 0x0100 0x038c 0x0000 1 0 #define MX6UL_PAD_ENET2_RX_ER__SIM2_PORT0_SVEN 0x0100 0x038c 0x0000 2 0 -#define MX6UL_PAD_ENET2_RX_ER__ECSPI4_SS0 0x0100 0x038c 0x0000 3 0 +#define MX6UL_PAD_ENET2_RX_ER__ECSPI4_SS0 0x0100 0x038c 0x0570 3 0 #define MX6UL_PAD_ENET2_RX_ER__EIM_ADDR25 0x0100 0x038c 0x0000 4 0 #define MX6UL_PAD_ENET2_RX_ER__GPIO2_IO15 0x0100 0x038c 0x0000 5 0 #define MX6UL_PAD_ENET2_RX_ER__KPP_COL07 0x0100 0x038c 0x0000 6 0 @@ -440,7 +443,7 @@ #define MX6UL_PAD_LCD_CLK__LCDIF_WR_RWN 0x0104 0x0390 0x0000 1 0 #define MX6UL_PAD_LCD_CLK__UART4_DCE_TX 0x0104 0x0390 0x0000 2 0 #define MX6UL_PAD_LCD_CLK__UART4_DTE_RX 0x0104 0x0390 0x063c 2 2 -#define MX6UL_PAD_LCD_CLK__SAI3_MCLK 0x0104 0x0390 0x0000 3 0 +#define MX6UL_PAD_LCD_CLK__SAI3_MCLK 0x0104 0x0390 0x0600 3 0 #define MX6UL_PAD_LCD_CLK__EIM_CS2_B 0x0104 0x0390 0x0000 4 0 #define MX6UL_PAD_LCD_CLK__GPIO3_IO00 0x0104 0x0390 0x0000 5 0 #define MX6UL_PAD_LCD_CLK__WDOG1_WDOG_RST_B_DEB 0x0104 0x0390 0x0000 8 0 @@ -464,7 +467,7 @@ #define MX6UL_PAD_LCD_VSYNC__LCDIF_BUSY 0x0110 0x039c 0x05dc 1 1 #define MX6UL_PAD_LCD_VSYNC__UART4_DCE_RTS 0x0110 0x039c 0x0638 2 3 #define MX6UL_PAD_LCD_VSYNC__UART4_DTE_CTS 0x0110 0x039c 0x0000 2 0 -#define MX6UL_PAD_LCD_VSYNC__SAI3_RX_DATA 0x0110 0x039c 0x0000 3 0 +#define MX6UL_PAD_LCD_VSYNC__SAI3_RX_DATA 0x0110 0x039c 0x0604 3 0 #define MX6UL_PAD_LCD_VSYNC__WDOG2_WDOG_B 0x0110 0x039c 0x0000 4 0 #define MX6UL_PAD_LCD_VSYNC__GPIO3_IO03 0x0110 0x039c 0x0000 5 0 #define MX6UL_PAD_LCD_VSYNC__ECSPI2_SS2 0x0110 0x039c 0x0000 8 0 @@ -477,13 +480,15 @@ #define MX6UL_PAD_LCD_RESET__ECSPI2_SS3 0x0114 0x03a0 0x0000 8 0 #define MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x0118 0x03a4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA00__PWM1_OUT 0x0118 0x03a4 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA00__CA7_MX6UL_TRACE0 0x0118 0x03a4 0x0000 2 0 #define MX6UL_PAD_LCD_DATA00__ENET1_1588_EVENT2_IN 0x0118 0x03a4 0x0000 3 0 #define MX6UL_PAD_LCD_DATA00__I2C3_SDA 0x0118 0x03a4 0x05b8 4 2 #define MX6UL_PAD_LCD_DATA00__GPIO3_IO05 0x0118 0x03a4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA00__SRC_BT_CFG00 0x0118 0x03a4 0x0000 6 0 -#define MX6UL_PAD_LCD_DATA00__SAI1_MCLK 0x0118 0x03a4 0x0000 8 0 +#define MX6UL_PAD_LCD_DATA00__SAI1_MCLK 0x0118 0x03a4 0x05e0 8 1 #define MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x011c 0x03a8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA01__PWM2_OUT 0x011c 0x03a8 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA01__CA7_MX6UL_TRACE1 0x011c 0x03a8 0x0000 2 0 #define MX6UL_PAD_LCD_DATA01__ENET1_1588_EVENT2_OUT 0x011c 0x03a8 0x0000 3 0 #define MX6UL_PAD_LCD_DATA01__I2C3_SCL 0x011c 0x03a8 0x05b4 4 2 #define MX6UL_PAD_LCD_DATA01__GPIO3_IO06 0x011c 0x03a8 0x0000 5 0 @@ -491,6 +496,7 @@ #define MX6UL_PAD_LCD_DATA01__SAI1_TX_SYNC 0x011c 0x03a8 0x05ec 8 0 #define MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x0120 0x03ac 0x0000 0 0 #define MX6UL_PAD_LCD_DATA02__PWM3_OUT 0x0120 0x03ac 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA02__CA7_MX6UL_TRACE2 0x0120 0x03ac 0x0000 2 0 #define MX6UL_PAD_LCD_DATA02__ENET1_1588_EVENT3_IN 0x0120 0x03ac 0x0000 3 0 #define MX6UL_PAD_LCD_DATA02__I2C4_SDA 0x0120 0x03ac 0x05c0 4 2 #define MX6UL_PAD_LCD_DATA02__GPIO3_IO07 0x0120 0x03ac 0x0000 5 0 @@ -498,14 +504,16 @@ #define MX6UL_PAD_LCD_DATA02__SAI1_TX_BCLK 0x0120 0x03ac 0x05e8 8 0 #define MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x0124 0x03b0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA03__PWM4_OUT 0x0124 0x03b0 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA03__CA7_MX6UL_TRACE3 0x0124 0x03b0 0x0000 2 0 #define MX6UL_PAD_LCD_DATA03__ENET1_1588_EVENT3_OUT 0x0124 0x03b0 0x0000 3 0 #define MX6UL_PAD_LCD_DATA03__I2C4_SCL 0x0124 0x03b0 0x05bc 4 2 #define MX6UL_PAD_LCD_DATA03__GPIO3_IO08 0x0124 0x03b0 0x0000 5 0 #define MX6UL_PAD_LCD_DATA03__SRC_BT_CFG03 0x0124 0x03b0 0x0000 6 0 -#define MX6UL_PAD_LCD_DATA03__SAI1_RX_DATA 0x0124 0x03b0 0x0000 8 0 +#define MX6UL_PAD_LCD_DATA03__SAI1_RX_DATA 0x0124 0x03b0 0x05e4 8 0 #define MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x0128 0x03b4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA04__UART8_DCE_CTS 0x0128 0x03b4 0x0000 1 0 #define MX6UL_PAD_LCD_DATA04__UART8_DTE_RTS 0x0128 0x03b4 0x0658 1 2 +#define MX6UL_PAD_LCD_DATA04__CA7_MX6UL_TRACE4 0x0128 0x03b4 0x0000 2 0 #define MX6UL_PAD_LCD_DATA04__ENET2_1588_EVENT2_IN 0x0128 0x03b4 0x0000 3 0 #define MX6UL_PAD_LCD_DATA04__SPDIF_SR_CLK 0x0128 0x03b4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA04__GPIO3_IO09 0x0128 0x03b4 0x0000 5 0 @@ -514,6 +522,7 @@ #define MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x012c 0x03b8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA05__UART8_DCE_RTS 0x012c 0x03b8 0x0658 1 3 #define MX6UL_PAD_LCD_DATA05__UART8_DTE_CTS 0x012c 0x03b8 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA05__CA7_MX6UL_TRACE5 0x012c 0x03b8 0x0000 2 0 #define MX6UL_PAD_LCD_DATA05__ENET2_1588_EVENT2_OUT 0x012c 0x03b8 0x0000 3 0 #define MX6UL_PAD_LCD_DATA05__SPDIF_OUT 0x012c 0x03b8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA05__GPIO3_IO10 0x012c 0x03b8 0x0000 5 0 @@ -522,6 +531,7 @@ #define MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x0130 0x03bc 0x0000 0 0 #define MX6UL_PAD_LCD_DATA06__UART7_DCE_CTS 0x0130 0x03bc 0x0000 1 0 #define MX6UL_PAD_LCD_DATA06__UART7_DTE_RTS 0x0130 0x03bc 0x0650 1 2 +#define MX6UL_PAD_LCD_DATA06__CA7_MX6UL_TRACE6 0x0130 0x03bc 0x0000 2 0 #define MX6UL_PAD_LCD_DATA06__ENET2_1588_EVENT3_IN 0x0130 0x03bc 0x0000 3 0 #define MX6UL_PAD_LCD_DATA06__SPDIF_LOCK 0x0130 0x03bc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA06__GPIO3_IO11 0x0130 0x03bc 0x0000 5 0 @@ -530,6 +540,7 @@ #define MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x0134 0x03c0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA07__UART7_DCE_RTS 0x0134 0x03c0 0x0650 1 3 #define MX6UL_PAD_LCD_DATA07__UART7_DTE_CTS 0x0134 0x03c0 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA07__CA7_MX6UL_TRACE7 0x0134 0x03c0 0x0000 2 0 #define MX6UL_PAD_LCD_DATA07__ENET2_1588_EVENT3_OUT 0x0134 0x03c0 0x0000 3 0 #define MX6UL_PAD_LCD_DATA07__SPDIF_EXT_CLK 0x0134 0x03c0 0x061c 4 0 #define MX6UL_PAD_LCD_DATA07__GPIO3_IO12 0x0134 0x03c0 0x0000 5 0 @@ -537,56 +548,64 @@ #define MX6UL_PAD_LCD_DATA07__ECSPI1_SS3 0x0134 0x03c0 0x0000 8 0 #define MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x0138 0x03c4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA08__SPDIF_IN 0x0138 0x03c4 0x0618 1 2 -#define MX6UL_PAD_LCD_DATA08__CSI_DATA16 0x0138 0x03c4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA08__CA7_MX6UL_TRACE8 0x0138 0x03c4 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA08__CSI_DATA16 0x0138 0x03c4 0x0504 3 1 #define MX6UL_PAD_LCD_DATA08__EIM_DATA00 0x0138 0x03c4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA08__GPIO3_IO13 0x0138 0x03c4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA08__SRC_BT_CFG08 0x0138 0x03c4 0x0000 6 0 #define MX6UL_PAD_LCD_DATA08__FLEXCAN1_TX 0x0138 0x03c4 0x0000 8 0 #define MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x013c 0x03c8 0x0000 0 0 -#define MX6UL_PAD_LCD_DATA09__SAI3_MCLK 0x013c 0x03c8 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA09__CSI_DATA17 0x013c 0x03c8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA09__SAI3_MCLK 0x013c 0x03c8 0x0600 1 1 +#define MX6UL_PAD_LCD_DATA09__CA7_MX6UL_TRACE9 0x013c 0x03c8 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA09__CSI_DATA17 0x013c 0x03c8 0x0508 3 1 #define MX6UL_PAD_LCD_DATA09__EIM_DATA01 0x013c 0x03c8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA09__GPIO3_IO14 0x013c 0x03c8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA09__SRC_BT_CFG09 0x013c 0x03c8 0x0000 6 0 #define MX6UL_PAD_LCD_DATA09__FLEXCAN1_RX 0x013c 0x03c8 0x0584 8 2 #define MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x0140 0x03cc 0x0000 0 0 #define MX6UL_PAD_LCD_DATA10__SAI3_RX_SYNC 0x0140 0x03cc 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA10__CSI_DATA18 0x0140 0x03cc 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA10__CA7_MX6UL_TRACE10 0x0140 0x03cc 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA10__CSI_DATA18 0x0140 0x03cc 0x050c 3 1 #define MX6UL_PAD_LCD_DATA10__EIM_DATA02 0x0140 0x03cc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA10__GPIO3_IO15 0x0140 0x03cc 0x0000 5 0 #define MX6UL_PAD_LCD_DATA10__SRC_BT_CFG10 0x0140 0x03cc 0x0000 6 0 #define MX6UL_PAD_LCD_DATA10__FLEXCAN2_TX 0x0140 0x03cc 0x0000 8 0 #define MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x0144 0x03d0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA11__SAI3_RX_BCLK 0x0144 0x03d0 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA11__CSI_DATA19 0x0144 0x03d0 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA11__CA7_MX6UL_TRACE11 0x0144 0x03d0 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA11__CSI_DATA19 0x0144 0x03d0 0x0510 3 1 #define MX6UL_PAD_LCD_DATA11__EIM_DATA03 0x0144 0x03d0 0x0000 4 0 #define MX6UL_PAD_LCD_DATA11__GPIO3_IO16 0x0144 0x03d0 0x0000 5 0 #define MX6UL_PAD_LCD_DATA11__SRC_BT_CFG11 0x0144 0x03d0 0x0000 6 0 #define MX6UL_PAD_LCD_DATA11__FLEXCAN2_RX 0x0144 0x03d0 0x0588 8 2 #define MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x0148 0x03d4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA12__SAI3_TX_SYNC 0x0148 0x03d4 0x060c 1 1 -#define MX6UL_PAD_LCD_DATA12__CSI_DATA20 0x0148 0x03d4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA12__CA7_MX6UL_TRACE12 0x0148 0x03d4 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA12__CSI_DATA20 0x0148 0x03d4 0x0514 3 1 #define MX6UL_PAD_LCD_DATA12__EIM_DATA04 0x0148 0x03d4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA12__GPIO3_IO17 0x0148 0x03d4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA12__SRC_BT_CFG12 0x0148 0x03d4 0x0000 6 0 #define MX6UL_PAD_LCD_DATA12__ECSPI1_RDY 0x0148 0x03d4 0x0000 8 0 #define MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x014c 0x03d8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA13__SAI3_TX_BCLK 0x014c 0x03d8 0x0608 1 1 -#define MX6UL_PAD_LCD_DATA13__CSI_DATA21 0x014c 0x03d8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA13__CA7_MX6UL_TRACE13 0x014c 0x03d8 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA13__CSI_DATA21 0x014c 0x03d8 0x0518 3 1 #define MX6UL_PAD_LCD_DATA13__EIM_DATA05 0x014c 0x03d8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA13__GPIO3_IO18 0x014c 0x03d8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA13__SRC_BT_CFG13 0x014c 0x03d8 0x0000 6 0 #define MX6UL_PAD_LCD_DATA13__USDHC2_RESET_B 0x014c 0x03d8 0x0000 8 0 #define MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x0150 0x03dc 0x0000 0 0 -#define MX6UL_PAD_LCD_DATA14__SAI3_RX_DATA 0x0150 0x03dc 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA14__CSI_DATA22 0x0150 0x03dc 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA14__SAI3_RX_DATA 0x0150 0x03dc 0x0604 1 1 +#define MX6UL_PAD_LCD_DATA14__CA7_MX6UL_TRACE14 0x0150 0x03dc 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA14__CSI_DATA22 0x0150 0x03dc 0x051c 3 1 #define MX6UL_PAD_LCD_DATA14__EIM_DATA06 0x0150 0x03dc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA14__GPIO3_IO19 0x0150 0x03dc 0x0000 5 0 #define MX6UL_PAD_LCD_DATA14__SRC_BT_CFG14 0x0150 0x03dc 0x0000 6 0 #define MX6UL_PAD_LCD_DATA14__USDHC2_DATA4 0x0150 0x03dc 0x068c 8 0 #define MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x0154 0x03e0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA15__SAI3_TX_DATA 0x0154 0x03e0 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA15__CSI_DATA23 0x0154 0x03e0 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA15__CA7_MX6UL_TRACE15 0x0154 0x03e0 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA15__CSI_DATA23 0x0154 0x03e0 0x0520 3 1 #define MX6UL_PAD_LCD_DATA15__EIM_DATA07 0x0154 0x03e0 0x0000 4 0 #define MX6UL_PAD_LCD_DATA15__GPIO3_IO20 0x0154 0x03e0 0x0000 5 0 #define MX6UL_PAD_LCD_DATA15__SRC_BT_CFG15 0x0154 0x03e0 0x0000 6 0 @@ -594,7 +613,8 @@ #define MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x0158 0x03e4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA16__UART7_DCE_TX 0x0158 0x03e4 0x0000 1 0 #define MX6UL_PAD_LCD_DATA16__UART7_DTE_RX 0x0158 0x03e4 0x0654 1 2 -#define MX6UL_PAD_LCD_DATA16__CSI_DATA01 0x0158 0x03e4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA16__CA7_MX6UL_TRACE_CLK 0x0158 0x03e4 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA16__CSI_DATA01 0x0158 0x03e4 0x04d4 3 1 #define MX6UL_PAD_LCD_DATA16__EIM_DATA08 0x0158 0x03e4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA16__GPIO3_IO21 0x0158 0x03e4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA16__SRC_BT_CFG24 0x0158 0x03e4 0x0000 6 0 @@ -602,7 +622,8 @@ #define MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x015c 0x03e8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA17__UART7_DCE_RX 0x015c 0x03e8 0x0654 1 3 #define MX6UL_PAD_LCD_DATA17__UART7_DTE_TX 0x015c 0x03e8 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA17__CSI_DATA00 0x015c 0x03e8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA17__CA7_MX6UL_TRACE_CTL 0x015c 0x03e8 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA17__CSI_DATA00 0x015c 0x03e8 0x04d0 3 1 #define MX6UL_PAD_LCD_DATA17__EIM_DATA09 0x015c 0x03e8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA17__GPIO3_IO22 0x015c 0x03e8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA17__SRC_BT_CFG25 0x015c 0x03e8 0x0000 6 0 @@ -610,7 +631,7 @@ #define MX6UL_PAD_LCD_DATA18__LCDIF_DATA18 0x0160 0x03ec 0x0000 0 0 #define MX6UL_PAD_LCD_DATA18__PWM5_OUT 0x0160 0x03ec 0x0000 1 0 #define MX6UL_PAD_LCD_DATA18__CA7_MX6UL_EVENTO 0x0160 0x03ec 0x0000 2 0 -#define MX6UL_PAD_LCD_DATA18__CSI_DATA10 0x0160 0x03ec 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA18__CSI_DATA10 0x0160 0x03ec 0x04ec 3 1 #define MX6UL_PAD_LCD_DATA18__EIM_DATA10 0x0160 0x03ec 0x0000 4 0 #define MX6UL_PAD_LCD_DATA18__GPIO3_IO23 0x0160 0x03ec 0x0000 5 0 #define MX6UL_PAD_LCD_DATA18__SRC_BT_CFG26 0x0160 0x03ec 0x0000 6 0 @@ -622,7 +643,7 @@ #define MX6UL_PAD_LCD_DATA19__LCDIF_DATA19 0x0164 0x03f0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA19__PWM6_OUT 0x0164 0x03f0 0x0000 1 0 #define MX6UL_PAD_LCD_DATA19__WDOG1_WDOG_ANY 0x0164 0x03f0 0x0000 2 0 -#define MX6UL_PAD_LCD_DATA19__CSI_DATA11 0x0164 0x03f0 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA19__CSI_DATA11 0x0164 0x03f0 0x04f0 3 1 #define MX6UL_PAD_LCD_DATA20__EIM_DATA12 0x0168 0x03f4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA20__GPIO3_IO25 0x0168 0x03f4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA20__SRC_BT_CFG28 0x0168 0x03f4 0x0000 6 0 @@ -631,12 +652,12 @@ #define MX6UL_PAD_LCD_DATA20__UART8_DCE_TX 0x0168 0x03f4 0x0000 1 0 #define MX6UL_PAD_LCD_DATA20__UART8_DTE_RX 0x0168 0x03f4 0x065c 1 2 #define MX6UL_PAD_LCD_DATA20__ECSPI1_SCLK 0x0168 0x03f4 0x0534 2 0 -#define MX6UL_PAD_LCD_DATA20__CSI_DATA12 0x0168 0x03f4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA20__CSI_DATA12 0x0168 0x03f4 0x04f4 3 1 #define MX6UL_PAD_LCD_DATA21__LCDIF_DATA21 0x016c 0x03f8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA21__UART8_DCE_RX 0x016c 0x03f8 0x065c 1 3 #define MX6UL_PAD_LCD_DATA21__UART8_DTE_TX 0x016c 0x03f8 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA21__ECSPI1_SS0 0x016c 0x03f8 0x0000 2 0 -#define MX6UL_PAD_LCD_DATA21__CSI_DATA13 0x016c 0x03f8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA21__ECSPI1_SS0 0x016c 0x03f8 0x0540 2 0 +#define MX6UL_PAD_LCD_DATA21__CSI_DATA13 0x016c 0x03f8 0x04f8 3 1 #define MX6UL_PAD_LCD_DATA21__EIM_DATA13 0x016c 0x03f8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA21__GPIO3_IO26 0x016c 0x03f8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA21__SRC_BT_CFG29 0x016c 0x03f8 0x0000 6 0 @@ -644,7 +665,7 @@ #define MX6UL_PAD_LCD_DATA22__LCDIF_DATA22 0x0170 0x03fc 0x0000 0 0 #define MX6UL_PAD_LCD_DATA22__MQS_RIGHT 0x0170 0x03fc 0x0000 1 0 #define MX6UL_PAD_LCD_DATA22__ECSPI1_MOSI 0x0170 0x03fc 0x053c 2 0 -#define MX6UL_PAD_LCD_DATA22__CSI_DATA14 0x0170 0x03fc 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA22__CSI_DATA14 0x0170 0x03fc 0x04fc 3 1 #define MX6UL_PAD_LCD_DATA22__EIM_DATA14 0x0170 0x03fc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA22__GPIO3_IO27 0x0170 0x03fc 0x0000 5 0 #define MX6UL_PAD_LCD_DATA22__SRC_BT_CFG30 0x0170 0x03fc 0x0000 6 0 @@ -652,7 +673,7 @@ #define MX6UL_PAD_LCD_DATA23__LCDIF_DATA23 0x0174 0x0400 0x0000 0 0 #define MX6UL_PAD_LCD_DATA23__MQS_LEFT 0x0174 0x0400 0x0000 1 0 #define MX6UL_PAD_LCD_DATA23__ECSPI1_MISO 0x0174 0x0400 0x0538 2 0 -#define MX6UL_PAD_LCD_DATA23__CSI_DATA15 0x0174 0x0400 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA23__CSI_DATA15 0x0174 0x0400 0x0500 3 1 #define MX6UL_PAD_LCD_DATA23__EIM_DATA15 0x0174 0x0400 0x0000 4 0 #define MX6UL_PAD_LCD_DATA23__GPIO3_IO28 0x0174 0x0400 0x0000 5 0 #define MX6UL_PAD_LCD_DATA23__SRC_BT_CFG31 0x0174 0x0400 0x0000 6 0 @@ -660,42 +681,42 @@ #define MX6UL_PAD_NAND_RE_B__RAWNAND_RE_B 0x0178 0x0404 0x0000 0 0 #define MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x0178 0x0404 0x0670 1 2 #define MX6UL_PAD_NAND_RE_B__QSPI_B_SCLK 0x0178 0x0404 0x0000 2 0 -#define MX6UL_PAD_NAND_RE_B__KPP_ROW00 0x0178 0x0404 0x0000 3 0 +#define MX6UL_PAD_NAND_RE_B__KPP_ROW00 0x0178 0x0404 0x05d0 3 1 #define MX6UL_PAD_NAND_RE_B__EIM_EB_B00 0x0178 0x0404 0x0000 4 0 #define MX6UL_PAD_NAND_RE_B__GPIO4_IO00 0x0178 0x0404 0x0000 5 0 #define MX6UL_PAD_NAND_RE_B__ECSPI3_SS2 0x0178 0x0404 0x0000 8 0 #define MX6UL_PAD_NAND_WE_B__RAWNAND_WE_B 0x017c 0x0408 0x0000 0 0 #define MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x017c 0x0408 0x0678 1 2 #define MX6UL_PAD_NAND_WE_B__QSPI_B_SS0_B 0x017c 0x0408 0x0000 2 0 -#define MX6UL_PAD_NAND_WE_B__KPP_COL00 0x017c 0x0408 0x0000 3 0 +#define MX6UL_PAD_NAND_WE_B__KPP_COL00 0x017c 0x0408 0x05c4 3 1 #define MX6UL_PAD_NAND_WE_B__EIM_EB_B01 0x017c 0x0408 0x0000 4 0 #define MX6UL_PAD_NAND_WE_B__GPIO4_IO01 0x017c 0x0408 0x0000 5 0 #define MX6UL_PAD_NAND_WE_B__ECSPI3_SS3 0x017c 0x0408 0x0000 8 0 #define MX6UL_PAD_NAND_DATA00__RAWNAND_DATA00 0x0180 0x040c 0x0000 0 0 #define MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x0180 0x040c 0x067c 1 2 #define MX6UL_PAD_NAND_DATA00__QSPI_B_SS1_B 0x0180 0x040c 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA00__KPP_ROW01 0x0180 0x040c 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA00__KPP_ROW01 0x0180 0x040c 0x05d4 3 1 #define MX6UL_PAD_NAND_DATA00__EIM_AD08 0x0180 0x040c 0x0000 4 0 #define MX6UL_PAD_NAND_DATA00__GPIO4_IO02 0x0180 0x040c 0x0000 5 0 #define MX6UL_PAD_NAND_DATA00__ECSPI4_RDY 0x0180 0x040c 0x0000 8 0 #define MX6UL_PAD_NAND_DATA01__RAWNAND_DATA01 0x0184 0x0410 0x0000 0 0 #define MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x0184 0x0410 0x0680 1 2 #define MX6UL_PAD_NAND_DATA01__QSPI_B_DQS 0x0184 0x0410 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA01__KPP_COL01 0x0184 0x0410 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA01__KPP_COL01 0x0184 0x0410 0x05c8 3 1 #define MX6UL_PAD_NAND_DATA01__EIM_AD09 0x0184 0x0410 0x0000 4 0 #define MX6UL_PAD_NAND_DATA01__GPIO4_IO03 0x0184 0x0410 0x0000 5 0 #define MX6UL_PAD_NAND_DATA01__ECSPI4_SS1 0x0184 0x0410 0x0000 8 0 #define MX6UL_PAD_NAND_DATA02__RAWNAND_DATA02 0x0188 0x0414 0x0000 0 0 #define MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x0188 0x0414 0x0684 1 1 #define MX6UL_PAD_NAND_DATA02__QSPI_B_DATA00 0x0188 0x0414 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA02__KPP_ROW02 0x0188 0x0414 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA02__KPP_ROW02 0x0188 0x0414 0x05d8 3 1 #define MX6UL_PAD_NAND_DATA02__EIM_AD10 0x0188 0x0414 0x0000 4 0 #define MX6UL_PAD_NAND_DATA02__GPIO4_IO04 0x0188 0x0414 0x0000 5 0 #define MX6UL_PAD_NAND_DATA02__ECSPI4_SS2 0x0188 0x0414 0x0000 8 0 #define MX6UL_PAD_NAND_DATA03__RAWNAND_DATA03 0x018c 0x0418 0x0000 0 0 #define MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x018c 0x0418 0x0688 1 2 #define MX6UL_PAD_NAND_DATA03__QSPI_B_DATA01 0x018c 0x0418 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA03__KPP_COL02 0x018c 0x0418 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA03__KPP_COL02 0x018c 0x0418 0x05cc 3 1 #define MX6UL_PAD_NAND_DATA03__EIM_AD11 0x018c 0x0418 0x0000 4 0 #define MX6UL_PAD_NAND_DATA03__GPIO4_IO05 0x018c 0x0418 0x0000 5 0 #define MX6UL_PAD_NAND_DATA03__ECSPI4_SS3 0x018c 0x0418 0x0000 8 0 @@ -726,7 +747,7 @@ #define MX6UL_PAD_NAND_DATA07__RAWNAND_DATA07 0x019c 0x0428 0x0000 0 0 #define MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x019c 0x0428 0x0698 1 1 #define MX6UL_PAD_NAND_DATA07__QSPI_A_SS1_B 0x019c 0x0428 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA07__ECSPI4_SS0 0x019c 0x0428 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA07__ECSPI4_SS0 0x019c 0x0428 0x0570 3 1 #define MX6UL_PAD_NAND_DATA07__EIM_AD15 0x019c 0x0428 0x0000 4 0 #define MX6UL_PAD_NAND_DATA07__GPIO4_IO09 0x019c 0x0428 0x0000 5 0 #define MX6UL_PAD_NAND_DATA07__UART2_DCE_RTS 0x019c 0x0428 0x0628 8 5 @@ -748,7 +769,7 @@ #define MX6UL_PAD_NAND_READY_B__RAWNAND_READY_B 0x01a8 0x0434 0x0000 0 0 #define MX6UL_PAD_NAND_READY_B__USDHC1_DATA4 0x01a8 0x0434 0x0000 1 0 #define MX6UL_PAD_NAND_READY_B__QSPI_A_DATA00 0x01a8 0x0434 0x0000 2 0 -#define MX6UL_PAD_NAND_READY_B__ECSPI3_SS0 0x01a8 0x0434 0x0000 3 0 +#define MX6UL_PAD_NAND_READY_B__ECSPI3_SS0 0x01a8 0x0434 0x0560 3 1 #define MX6UL_PAD_NAND_READY_B__EIM_CS1_B 0x01a8 0x0434 0x0000 4 0 #define MX6UL_PAD_NAND_READY_B__GPIO4_IO12 0x01a8 0x0434 0x0000 5 0 #define MX6UL_PAD_NAND_READY_B__UART3_DCE_TX 0x01a8 0x0434 0x0000 8 0 @@ -783,7 +804,7 @@ #define MX6UL_PAD_NAND_DQS__PWM5_OUT 0x01b8 0x0444 0x0000 3 0 #define MX6UL_PAD_NAND_DQS__EIM_WAIT 0x01b8 0x0444 0x0000 4 0 #define MX6UL_PAD_NAND_DQS__GPIO4_IO16 0x01b8 0x0444 0x0000 5 0 -#define MX6UL_PAD_NAND_DQS__SDMA_EXT_EVENT01 0x01b8 0x0444 0x0000 6 0 +#define MX6UL_PAD_NAND_DQS__SDMA_EXT_EVENT01 0x01b8 0x0444 0x0614 6 1 #define MX6UL_PAD_NAND_DQS__SPDIF_EXT_CLK 0x01b8 0x0444 0x061c 8 1 #define MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x01bc 0x0448 0x0000 0 0 #define MX6UL_PAD_SD1_CMD__GPT2_COMPARE1 0x01bc 0x0448 0x0000 1 0 @@ -791,11 +812,11 @@ #define MX6UL_PAD_SD1_CMD__SPDIF_OUT 0x01bc 0x0448 0x0000 3 0 #define MX6UL_PAD_SD1_CMD__EIM_ADDR19 0x01bc 0x0448 0x0000 4 0 #define MX6UL_PAD_SD1_CMD__GPIO2_IO16 0x01bc 0x0448 0x0000 5 0 -#define MX6UL_PAD_SD1_CMD__SDMA_EXT_EVENT00 0x01bc 0x0448 0x0000 6 0 +#define MX6UL_PAD_SD1_CMD__SDMA_EXT_EVENT00 0x01bc 0x0448 0x0610 6 2 #define MX6UL_PAD_SD1_CMD__USB_OTG1_PWR 0x01bc 0x0448 0x0000 8 0 #define MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x01c0 0x044c 0x0000 0 0 #define MX6UL_PAD_SD1_CLK__GPT2_COMPARE2 0x01c0 0x044c 0x0000 1 0 -#define MX6UL_PAD_SD1_CLK__SAI2_MCLK 0x01c0 0x044c 0x0000 2 0 +#define MX6UL_PAD_SD1_CLK__SAI2_MCLK 0x01c0 0x044c 0x05f0 2 1 #define MX6UL_PAD_SD1_CLK__SPDIF_IN 0x01c0 0x044c 0x0618 3 3 #define MX6UL_PAD_SD1_CLK__EIM_ADDR20 0x01c0 0x044c 0x0000 4 0 #define MX6UL_PAD_SD1_CLK__GPIO2_IO17 0x01c0 0x044c 0x0000 5 0 @@ -878,10 +899,10 @@ #define MX6UL_PAD_CSI_DATA01__CSI_DATA03 0x01e8 0x0474 0x04c8 0 0 #define MX6UL_PAD_CSI_DATA01__USDHC2_DATA1 0x01e8 0x0474 0x0680 1 0 #define MX6UL_PAD_CSI_DATA01__SIM1_PORT1_SVEN 0x01e8 0x0474 0x0000 2 0 -#define MX6UL_PAD_CSI_DATA01__ECSPI2_SS0 0x01e8 0x0474 0x0000 3 0 +#define MX6UL_PAD_CSI_DATA01__ECSPI2_SS0 0x01e8 0x0474 0x0550 3 0 #define MX6UL_PAD_CSI_DATA01__EIM_AD01 0x01e8 0x0474 0x0000 4 0 #define MX6UL_PAD_CSI_DATA01__GPIO4_IO22 0x01e8 0x0474 0x0000 5 0 -#define MX6UL_PAD_CSI_DATA01__SAI1_MCLK 0x01e8 0x0474 0x0000 6 0 +#define MX6UL_PAD_CSI_DATA01__SAI1_MCLK 0x01e8 0x0474 0x05e0 6 0 #define MX6UL_PAD_CSI_DATA01__UART5_DCE_RX 0x01e8 0x0474 0x0644 8 1 #define MX6UL_PAD_CSI_DATA01__UART5_DTE_TX 0x01e8 0x0474 0x0000 8 0 #define MX6UL_PAD_CSI_DATA02__CSI_DATA04 0x01ec 0x0478 0x04d8 0 1 @@ -913,7 +934,7 @@ #define MX6UL_PAD_CSI_DATA05__CSI_DATA07 0x01f8 0x0484 0x04e0 0 1 #define MX6UL_PAD_CSI_DATA05__USDHC2_DATA5 0x01f8 0x0484 0x0690 1 2 #define MX6UL_PAD_CSI_DATA05__SIM2_PORT1_RST_B 0x01f8 0x0484 0x0000 2 0 -#define MX6UL_PAD_CSI_DATA05__ECSPI1_SS0 0x01f8 0x0484 0x0000 3 0 +#define MX6UL_PAD_CSI_DATA05__ECSPI1_SS0 0x01f8 0x0484 0x0540 3 1 #define MX6UL_PAD_CSI_DATA05__EIM_AD05 0x01f8 0x0484 0x0000 4 0 #define MX6UL_PAD_CSI_DATA05__GPIO4_IO26 0x01f8 0x0484 0x0000 5 0 #define MX6UL_PAD_CSI_DATA05__SAI1_TX_BCLK 0x01f8 0x0484 0x05e8 6 1 @@ -924,7 +945,7 @@ #define MX6UL_PAD_CSI_DATA06__ECSPI1_MOSI 0x01fc 0x0488 0x053c 3 1 #define MX6UL_PAD_CSI_DATA06__EIM_AD06 0x01fc 0x0488 0x0000 4 0 #define MX6UL_PAD_CSI_DATA06__GPIO4_IO27 0x01fc 0x0488 0x0000 5 0 -#define MX6UL_PAD_CSI_DATA06__SAI1_RX_DATA 0x01fc 0x0488 0x0000 6 0 +#define MX6UL_PAD_CSI_DATA06__SAI1_RX_DATA 0x01fc 0x0488 0x05e4 6 1 #define MX6UL_PAD_CSI_DATA06__USDHC1_RESET_B 0x01fc 0x0488 0x0000 8 0 #define MX6UL_PAD_CSI_DATA07__CSI_DATA09 0x0200 0x048c 0x04e8 0 1 #define MX6UL_PAD_CSI_DATA07__USDHC2_DATA7 0x0200 0x048c 0x0698 1 2 diff --git a/arch/arm/dts/imx6ul.dtsi b/arch/arm/dts/imx6ul.dtsi index 71b42d4a20..5644b0f34d 100644 --- a/arch/arm/dts/imx6ul.dtsi +++ b/arch/arm/dts/imx6ul.dtsi @@ -1,19 +1,23 @@ -/* - * Copyright 2015 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright 2015 Freescale Semiconductor, Inc.
#include <dt-bindings/clock/imx6ul-clock.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include "imx6ul-pinfunc.h" -#include "skeleton.dtsi"
/ { + #address-cells = <1>; + #size-cells = <1>; + /* + * The decompressor and also some bootloaders rely on a + * pre-existing /chosen node to be available to insert the + * command line and merge other ATAGS info. + */ + chosen {}; + aliases { ethernet0 = &fec1; ethernet1 = &fec2; @@ -59,14 +63,17 @@ device_type = "cpu"; reg = <0>; clock-latency = <61036>; /* two CLK32 periods */ + #cooling-cells = <2>; operating-points = < /* kHz uV */ + 696000 1275000 528000 1175000 396000 1025000 198000 950000 >; fsl,soc-operating-points = < /* KHz uV */ + 696000 1275000 528000 1175000 396000 1175000 198000 1175000 @@ -77,30 +84,39 @@ <&clks IMX6UL_CA7_SECONDARY_SEL>, <&clks IMX6UL_CLK_STEP>, <&clks IMX6UL_CLK_PLL1_SW>, - <&clks IMX6UL_CLK_PLL1_SYS>, - <&clks IMX6UL_PLL1_BYPASS>, - <&clks IMX6UL_CLK_PLL1>, - <&clks IMX6UL_PLL1_BYPASS_SRC>, - <&clks IMX6UL_CLK_OSC>; + <&clks IMX6UL_CLK_PLL1_SYS>; clock-names = "arm", "pll2_bus", "pll2_pfd2_396m", "secondary_sel", "step", "pll1_sw", - "pll1_sys", "pll1_bypass", "pll1", - "pll1_bypass_src", "osc"; + "pll1_sys"; arm-supply = <®_arm>; soc-supply = <®_soc>; + nvmem-cells = <&cpu_speed_grade>; + nvmem-cell-names = "speed_grade"; }; };
- intc: interrupt-controller@00a01000 { - compatible = "arm,cortex-a7-gic"; + intc: interrupt-controller@a01000 { + compatible = "arm,gic-400", "arm,cortex-a7-gic"; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_HIGH)>; #interrupt-cells = <3>; interrupt-controller; + interrupt-parent = <&intc>; reg = <0x00a01000 0x1000>, - <0x00a02000 0x1000>, + <0x00a02000 0x2000>, <0x00a04000 0x2000>, <0x00a06000 0x2000>; };
+ timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) | IRQ_TYPE_LEVEL_LOW)>; + interrupt-parent = <&intc>; + status = "disabled"; + }; + ckil: clock-cli { compatible = "fixed-clock"; #clock-cells = <0>; @@ -129,6 +145,22 @@ clock-output-names = "ipp_di1"; };
+ tempmon: tempmon { + compatible = "fsl,imx6ul-tempmon", "fsl,imx6sx-tempmon"; + interrupt-parent = <&gpc>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + fsl,tempmon = <&anatop>; + nvmem-cells = <&tempmon_calib>, <&tempmon_temp_grade>; + nvmem-cell-names = "calib", "temp_grade"; + clocks = <&clks IMX6UL_CLK_PLL3_USB_OTG>; + }; + + pmu { + compatible = "arm,cortex-a7-pmu"; + interrupt-parent = <&gpc>; + interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; + }; + soc { #address-cells = <1>; #size-cells = <1>; @@ -136,18 +168,12 @@ interrupt-parent = <&gpc>; ranges;
- pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - ocram: sram@00900000 { + ocram: sram@900000 { compatible = "mmio-sram"; reg = <0x00900000 0x20000>; };
- dma_apbh: dma-apbh@01804000 { + dma_apbh: dma-apbh@1804000 { compatible = "fsl,imx6q-dma-apbh", "fsl,imx28-dma-apbh"; reg = <0x01804000 0x2000>; interrupts = <0 13 IRQ_TYPE_LEVEL_HIGH>, @@ -160,7 +186,7 @@ clocks = <&clks IMX6UL_CLK_APBHDMA>; };
- gpmi: gpmi-nand@01806000 { + gpmi: gpmi-nand@1806000 { compatible = "fsl,imx6q-gpmi-nand"; #address-cells = <1>; #size-cells = <1>; @@ -180,22 +206,21 @@ status = "disabled"; };
- aips1: aips-bus@02000000 { + aips1: aips-bus@2000000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x100000>; ranges;
- spba-bus@02000000 { + spba-bus@2000000 { compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x40000>; ranges; - u-boot,dm-spl;
- ecspi1: ecspi@02008000 { + ecspi1: spi@2008000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; @@ -207,7 +232,7 @@ status = "disabled"; };
- ecspi2: ecspi@0200c000 { + ecspi2: spi@200c000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; @@ -219,7 +244,7 @@ status = "disabled"; };
- ecspi3: ecspi@02010000 { + ecspi3: spi@2010000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; @@ -231,7 +256,7 @@ status = "disabled"; };
- ecspi4: ecspi@02014000 { + ecspi4: spi@2014000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; @@ -243,7 +268,7 @@ status = "disabled"; };
- uart7: serial@02018000 { + uart7: serial@2018000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x02018000 0x4000>; @@ -254,7 +279,7 @@ status = "disabled"; };
- uart1: serial@02020000 { + uart1: serial@2020000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x02020000 0x4000>; @@ -265,7 +290,7 @@ status = "disabled"; };
- uart8: serial@02024000 { + uart8: serial@2024000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x02024000 0x4000>; @@ -276,7 +301,7 @@ status = "disabled"; };
- sai1: sai@02028000 { + sai1: sai@2028000 { #sound-dai-cells = <0>; compatible = "fsl,imx6ul-sai", "fsl,imx6sx-sai"; reg = <0x02028000 0x4000>; @@ -291,7 +316,7 @@ status = "disabled"; };
- sai2: sai@0202c000 { + sai2: sai@202c000 { #sound-dai-cells = <0>; compatible = "fsl,imx6ul-sai", "fsl,imx6sx-sai"; reg = <0x0202c000 0x4000>; @@ -306,7 +331,7 @@ status = "disabled"; };
- sai3: sai@02030000 { + sai3: sai@2030000 { #sound-dai-cells = <0>; compatible = "fsl,imx6ul-sai", "fsl,imx6sx-sai"; reg = <0x02030000 0x4000>; @@ -322,7 +347,7 @@ }; };
- tsc: tsc@02040000 { + tsc: tsc@2040000 { compatible = "fsl,imx6ul-tsc"; reg = <0x02040000 0x4000>, <0x0219c000 0x4000>; interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, @@ -333,10 +358,10 @@ status = "disabled"; };
- pwm1: pwm@02080000 { + pwm1: pwm@2080000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x02080000 0x4000>; - interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM1>, <&clks IMX6UL_CLK_PWM1>; clock-names = "ipg", "per"; @@ -344,10 +369,10 @@ status = "disabled"; };
- pwm2: pwm@02084000 { + pwm2: pwm@2084000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x02084000 0x4000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM2>, <&clks IMX6UL_CLK_PWM2>; clock-names = "ipg", "per"; @@ -355,10 +380,10 @@ status = "disabled"; };
- pwm3: pwm@02088000 { + pwm3: pwm@2088000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x02088000 0x4000>; - interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM3>, <&clks IMX6UL_CLK_PWM3>; clock-names = "ipg", "per"; @@ -366,10 +391,10 @@ status = "disabled"; };
- pwm4: pwm@0208c000 { + pwm4: pwm@208c000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x0208c000 0x4000>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM4>, <&clks IMX6UL_CLK_PWM4>; clock-names = "ipg", "per"; @@ -377,27 +402,29 @@ status = "disabled"; };
- can1: flexcan@02090000 { + can1: flexcan@2090000 { compatible = "fsl,imx6ul-flexcan", "fsl,imx6q-flexcan"; reg = <0x02090000 0x4000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_CAN1_IPG>, <&clks IMX6UL_CLK_CAN1_SERIAL>; clock-names = "ipg", "per"; + fsl,stop-mode = <&gpr 0x10 1 0x10 17>; status = "disabled"; };
- can2: flexcan@02094000 { + can2: flexcan@2094000 { compatible = "fsl,imx6ul-flexcan", "fsl,imx6q-flexcan"; reg = <0x02094000 0x4000>; interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_CAN2_IPG>, <&clks IMX6UL_CLK_CAN2_SERIAL>; clock-names = "ipg", "per"; + fsl,stop-mode = <&gpr 0x10 2 0x10 18>; status = "disabled"; };
- gpt1: gpt@02098000 { + gpt1: gpt@2098000 { compatible = "fsl,imx6ul-gpt", "fsl,imx6sx-gpt"; reg = <0x02098000 0x4000>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; @@ -406,11 +433,12 @@ clock-names = "ipg", "per"; };
- gpio1: gpio@0209c000 { + gpio1: gpio@209c000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x0209c000 0x4000>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_GPIO1>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -419,11 +447,12 @@ <&iomuxc 16 33 16>; };
- gpio2: gpio@020a0000 { + gpio2: gpio@20a0000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020a0000 0x4000>; interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_GPIO2>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -431,11 +460,12 @@ gpio-ranges = <&iomuxc 0 49 16>, <&iomuxc 16 111 6>; };
- gpio3: gpio@020a4000 { + gpio3: gpio@20a4000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020a4000 0x4000>; interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_GPIO3>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -443,11 +473,12 @@ gpio-ranges = <&iomuxc 0 65 29>; };
- gpio4: gpio@020a8000 { + gpio4: gpio@20a8000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020a8000 0x4000>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_GPIO4>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -455,11 +486,12 @@ gpio-ranges = <&iomuxc 0 94 17>, <&iomuxc 17 117 12>; };
- gpio5: gpio@020ac000 { + gpio5: gpio@20ac000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020ac000 0x4000>; interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_GPIO5>; gpio-controller; #gpio-cells = <2>; interrupt-controller; @@ -467,9 +499,10 @@ gpio-ranges = <&iomuxc 0 7 10>, <&iomuxc 10 5 2>; };
- fec2: ethernet@020b4000 { + fec2: ethernet@20b4000 { compatible = "fsl,imx6ul-fec", "fsl,imx6q-fec"; reg = <0x020b4000 0x4000>; + interrupt-names = "int0", "pps"; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_ENET>, @@ -484,7 +517,7 @@ status = "disabled"; };
- kpp: kpp@020b8000 { + kpp: kpp@20b8000 { compatible = "fsl,imx6ul-kpp", "fsl,imx6q-kpp", "fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; @@ -492,14 +525,14 @@ status = "disabled"; };
- wdog1: wdog@020bc000 { + wdog1: wdog@20bc000 { compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; reg = <0x020bc000 0x4000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_WDOG1>; };
- wdog2: wdog@020c0000 { + wdog2: wdog@20c0000 { compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; reg = <0x020c0000 0x4000>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; @@ -507,7 +540,7 @@ status = "disabled"; };
- clks: ccm@020c4000 { + clks: ccm@20c4000 { compatible = "fsl,imx6ul-ccm"; reg = <0x020c4000 0x4000>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, @@ -517,7 +550,7 @@ clock-names = "ckil", "osc", "ipp_di0", "ipp_di1"; };
- anatop: anatop@020c8000 { + anatop: anatop@20c8000 { compatible = "fsl,imx6ul-anatop", "fsl,imx6q-anatop", "syscon", "simple-bus"; reg = <0x020c8000 0x1000>; @@ -574,7 +607,7 @@ }; };
- usbphy1: usbphy@020c9000 { + usbphy1: usbphy@20c9000 { compatible = "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; reg = <0x020c9000 0x1000>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; @@ -583,7 +616,7 @@ fsl,anatop = <&anatop>; };
- usbphy2: usbphy@020ca000 { + usbphy2: usbphy@20ca000 { compatible = "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; reg = <0x020ca000 0x1000>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; @@ -592,7 +625,7 @@ fsl,anatop = <&anatop>; };
- snvs: snvs@020cc000 { + snvs: snvs@20cc000 { compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; reg = <0x020cc000 0x4000>;
@@ -608,6 +641,7 @@ compatible = "syscon-poweroff"; regmap = <&snvs>; offset = <0x38>; + value = <0x60>; mask = <0x60>; status = "disabled"; }; @@ -619,19 +653,23 @@ linux,keycode = <KEY_POWER>; wakeup-source; }; + + snvs_lpgpr: snvs-lpgpr { + compatible = "fsl,imx6ul-snvs-lpgpr"; + }; };
- epit1: epit@020d0000 { + epit1: epit@20d0000 { reg = <0x020d0000 0x4000>; interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; };
- epit2: epit@020d4000 { + epit2: epit@20d4000 { reg = <0x020d4000 0x4000>; interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; };
- src: src@020d8000 { + src: src@20d8000 { compatible = "fsl,imx6ul-src", "fsl,imx51-src"; reg = <0x020d8000 0x4000>; interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, @@ -639,7 +677,7 @@ #reset-cells = <1>; };
- gpc: gpc@020dc000 { + gpc: gpc@20dc000 { compatible = "fsl,imx6ul-gpc", "fsl,imx6q-gpc"; reg = <0x020dc000 0x4000>; interrupt-controller; @@ -648,18 +686,18 @@ interrupt-parent = <&intc>; };
- iomuxc: iomuxc@020e0000 { + iomuxc: iomuxc@20e0000 { compatible = "fsl,imx6ul-iomuxc"; reg = <0x020e0000 0x4000>; };
- gpr: iomuxc-gpr@020e4000 { + gpr: iomuxc-gpr@20e4000 { compatible = "fsl,imx6ul-iomuxc-gpr", "fsl,imx6q-iomuxc-gpr", "syscon"; reg = <0x020e4000 0x4000>; };
- gpt2: gpt@020e8000 { + gpt2: gpt@20e8000 { compatible = "fsl,imx6ul-gpt", "fsl,imx6sx-gpt"; reg = <0x020e8000 0x4000>; interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; @@ -668,19 +706,19 @@ clock-names = "ipg", "per"; };
- sdma: sdma@020ec000 { + sdma: sdma@20ec000 { compatible = "fsl,imx6ul-sdma", "fsl,imx6q-sdma", "fsl,imx35-sdma"; reg = <0x020ec000 0x4000>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_SDMA>, + clocks = <&clks IMX6UL_CLK_IPG>, <&clks IMX6UL_CLK_SDMA>; clock-names = "ipg", "ahb"; #dma-cells = <3>; fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; };
- pwm5: pwm@020f0000 { + pwm5: pwm@20f0000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020f0000 0x4000>; interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; @@ -691,7 +729,7 @@ status = "disabled"; };
- pwm6: pwm@020f4000 { + pwm6: pwm@20f4000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020f4000 0x4000>; interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; @@ -702,7 +740,7 @@ status = "disabled"; };
- pwm7: pwm@020f8000 { + pwm7: pwm@20f8000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020f8000 0x4000>; interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; @@ -713,7 +751,7 @@ status = "disabled"; };
- pwm8: pwm@020fc000 { + pwm8: pwm@20fc000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020fc000 0x4000>; interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; @@ -725,14 +763,44 @@ }; };
- aips2: aips-bus@02100000 { + aips2: aips-bus@2100000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02100000 0x100000>; ranges;
- usbotg1: usb@02184000 { + crypto: caam@2140000 { + compatible = "fsl,imx6ul-caam", "fsl,sec-v4.0"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x2140000 0x3c000>; + ranges = <0 0x2140000 0x3c000>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_CAAM_IPG>, <&clks IMX6UL_CLK_CAAM_ACLK>, + <&clks IMX6UL_CLK_CAAM_MEM>; + clock-names = "ipg", "aclk", "mem"; + + sec_jr0: jr0@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr1@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr2@3000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + usbotg1: usb@2184000 { compatible = "fsl,imx6ul-usb", "fsl,imx27-usb"; reg = <0x02184000 0x200>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; @@ -746,7 +814,7 @@ status = "disabled"; };
- usbotg2: usb@02184200 { + usbotg2: usb@2184200 { compatible = "fsl,imx6ul-usb", "fsl,imx27-usb"; reg = <0x02184200 0x200>; interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; @@ -759,15 +827,16 @@ status = "disabled"; };
- usbmisc: usbmisc@02184800 { + usbmisc: usbmisc@2184800 { #index-cells = <1>; compatible = "fsl,imx6ul-usbmisc", "fsl,imx6q-usbmisc"; reg = <0x02184800 0x200>; };
- fec1: ethernet@02188000 { + fec1: ethernet@2188000 { compatible = "fsl,imx6ul-fec", "fsl,imx6q-fec"; reg = <0x02188000 0x4000>; + interrupt-names = "int0", "pps"; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_ENET>, @@ -782,7 +851,7 @@ status = "disabled"; };
- usdhc1: usdhc@02190000 { + usdhc1: usdhc@2190000 { compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02190000 0x4000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; @@ -794,7 +863,7 @@ status = "disabled"; };
- usdhc2: usdhc@02194000 { + usdhc2: usdhc@2194000 { compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02194000 0x4000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; @@ -806,7 +875,7 @@ status = "disabled"; };
- adc1: adc@02198000 { + adc1: adc@2198000 { compatible = "fsl,imx6ul-adc", "fsl,vf610-adc"; reg = <0x02198000 0x4000>; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; @@ -818,7 +887,7 @@ status = "disabled"; };
- i2c1: i2c@021a0000 { + i2c1: i2c@21a0000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; @@ -828,7 +897,7 @@ status = "disabled"; };
- i2c2: i2c@021a4000 { + i2c2: i2c@21a4000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; @@ -838,7 +907,7 @@ status = "disabled"; };
- i2c3: i2c@021a8000 { + i2c3: i2c@21a8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; @@ -848,12 +917,44 @@ status = "disabled"; };
- mmdc: mmdc@021b0000 { + memory-controller@21b0000 { compatible = "fsl,imx6ul-mmdc", "fsl,imx6q-mmdc"; reg = <0x021b0000 0x4000>; + clocks = <&clks IMX6UL_CLK_MMDC_P0_IPG>; + }; + + weim: weim@21b8000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "fsl,imx6ul-weim", "fsl,imx6q-weim"; + reg = <0x021b8000 0x4000>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX6UL_CLK_EIM>; + fsl,weim-cs-gpr = <&gpr>; + status = "disabled"; + }; + + ocotp: ocotp-ctrl@21bc000 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "fsl,imx6ul-ocotp", "syscon"; + reg = <0x021bc000 0x4000>; + clocks = <&clks IMX6UL_CLK_OCOTP>; + + tempmon_calib: calib@38 { + reg = <0x38 4>; + }; + + tempmon_temp_grade: temp-grade@20 { + reg = <0x20 4>; + }; + + cpu_speed_grade: speed-grade@10 { + reg = <0x10 4>; + }; };
- lcdif: lcdif@021c8000 { + lcdif: lcdif@21c8000 { compatible = "fsl,imx6ul-lcdif", "fsl,imx28-lcdif"; reg = <0x021c8000 0x4000>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; @@ -864,7 +965,7 @@ status = "disabled"; };
- qspi: qspi@021e0000 { + qspi: spi@21e0000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-qspi", "fsl,imx6sx-qspi"; @@ -877,7 +978,7 @@ status = "disabled"; };
- wdog3: wdog@021e4000 { + wdog3: wdog@21e4000 { compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; reg = <0x021e4000 0x4000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; @@ -885,7 +986,7 @@ status = "disabled"; };
- uart2: serial@021e8000 { + uart2: serial@21e8000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021e8000 0x4000>; @@ -896,7 +997,7 @@ status = "disabled"; };
- uart3: serial@021ec000 { + uart3: serial@21ec000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021ec000 0x4000>; @@ -907,7 +1008,7 @@ status = "disabled"; };
- uart4: serial@021f0000 { + uart4: serial@21f0000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021f0000 0x4000>; @@ -918,7 +1019,7 @@ status = "disabled"; };
- uart5: serial@021f4000 { + uart5: serial@21f4000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021f4000 0x4000>; @@ -929,7 +1030,7 @@ status = "disabled"; };
- i2c4: i2c@021f8000 { + i2c4: i2c@21f8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; @@ -939,7 +1040,7 @@ status = "disabled"; };
- uart6: serial@021fc000 { + uart6: serial@21fc000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021fc000 0x4000>; diff --git a/include/dt-bindings/clock/imx6ul-clock.h b/include/dt-bindings/clock/imx6ul-clock.h index 4623f170a8..79094338e6 100644 --- a/include/dt-bindings/clock/imx6ul-clock.h +++ b/include/dt-bindings/clock/imx6ul-clock.h @@ -1,10 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* - * Copyright (C) 2015-2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - * + * Copyright (C) 2015 Freescale Semiconductor, Inc. */
#ifndef __DT_BINDINGS_CLOCK_IMX6UL_H @@ -105,7 +101,7 @@ #define IMX6UL_CLK_LDB_DI1_DIV_SEL 92 #define IMX6UL_CLK_ARM 93 #define IMX6UL_CLK_PERIPH_CLK2 94 -#define IMX6UL_CLK_PERIPH2_CLK2 95 +#define IMX6UL_CLK_PERIPH2_CLK2 95 #define IMX6UL_CLK_AHB 96 #define IMX6UL_CLK_MMDC_PODF 97 #define IMX6UL_CLK_AXI_PODF 98 @@ -235,20 +231,32 @@ #define IMX6UL_CLK_CSI_PODF 222 #define IMX6UL_CLK_PLL3_120M 223 #define IMX6UL_CLK_KPP 224 -/* For i.MX6ULL */ -#define IMX6UL_CLK_ESAI_SEL 224 -#define IMX6UL_CLK_ESAI_PRED 225 -#define IMX6UL_CLK_ESAI_PODF 226 -#define IMX6UL_CLK_ESAI_EXTAL 227 -#define IMX6UL_CLK_ESAI_MEM 228 -#define IMX6UL_CLK_ESAI_IPG 229 -#define IMX6UL_CLK_DCP_CLK 230 -#define IMX6UL_CLK_EPDC_PRE_SEL 231 -#define IMX6UL_CLK_EPDC_SEL 232 -#define IMX6UL_CLK_EPDC_PODF 233 -#define IMX6UL_CLK_EPDC_ACLK 234 -#define IMX6UL_CLK_EPDC_PIX 235 +#define IMX6ULL_CLK_ESAI_PRED 225 +#define IMX6ULL_CLK_ESAI_PODF 226 +#define IMX6ULL_CLK_ESAI_EXTAL 227 +#define IMX6ULL_CLK_ESAI_MEM 228 +#define IMX6ULL_CLK_ESAI_IPG 229 +#define IMX6ULL_CLK_DCP_CLK 230 +#define IMX6ULL_CLK_EPDC_PRE_SEL 231 +#define IMX6ULL_CLK_EPDC_SEL 232 +#define IMX6ULL_CLK_EPDC_PODF 233 +#define IMX6ULL_CLK_EPDC_ACLK 234 +#define IMX6ULL_CLK_EPDC_PIX 235 +#define IMX6ULL_CLK_ESAI_SEL 236 +#define IMX6UL_CLK_CKO1_SEL 237 +#define IMX6UL_CLK_CKO1_PODF 238 +#define IMX6UL_CLK_CKO1 239 +#define IMX6UL_CLK_CKO2_SEL 240 +#define IMX6UL_CLK_CKO2_PODF 241 +#define IMX6UL_CLK_CKO2 242 +#define IMX6UL_CLK_CKO 243 +#define IMX6UL_CLK_GPIO1 244 +#define IMX6UL_CLK_GPIO2 245 +#define IMX6UL_CLK_GPIO3 246 +#define IMX6UL_CLK_GPIO4 247 +#define IMX6UL_CLK_GPIO5 248 +#define IMX6UL_CLK_MMDC_P1_IPG 249
-#define IMX6UL_CLK_END 236 +#define IMX6UL_CLK_END 250
#endif /* __DT_BINDINGS_CLOCK_IMX6UL_H */
Sync kernel dts for i.MX6ULL from commit <0a8ad0ffa4d8> ("Merge tag 'for-linus-5.3-ofs1' of git://git.kernel.org/pub/scm/linux/kernel/git/hubcap/linux")
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx6ull-14x14-evk.dts | 523 +--------------- arch/arm/dts/imx6ull-pinfunc-snvs.h | 7 +- arch/arm/dts/imx6ull-pinfunc.h | 116 ++-- arch/arm/dts/imx6ull.dtsi | 1184 ++--------------------------------- 4 files changed, 127 insertions(+), 1703 deletions(-)
diff --git a/arch/arm/dts/imx6ull-14x14-evk.dts b/arch/arm/dts/imx6ull-14x14-evk.dts index 9ebcfe1f4e..74aaa8a56a 100644 --- a/arch/arm/dts/imx6ull-14x14-evk.dts +++ b/arch/arm/dts/imx6ull-14x14-evk.dts @@ -1,527 +1,18 @@ -/* - * Copyright (C) 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// +// Copyright (C) 2016 Freescale Semiconductor, Inc.
/dts-v1/;
#include "imx6ull.dtsi" +#include "imx6ul-14x14-evk.dtsi"
/ { - model = "Freescale i.MX6 ULL 14x14 EVK Board"; + model = "Freescale i.MX6 UltraLiteLite 14x14 EVK Board"; compatible = "fsl,imx6ull-14x14-evk", "fsl,imx6ull"; - - chosen { - stdout-path = &uart1; - }; - - memory { - reg = <0x80000000 0x20000000>; - }; - - backlight { - compatible = "pwm-backlight"; - pwms = <&pwm1 0 5000000>; - brightness-levels = <0 4 8 16 32 64 128 255>; - default-brightness-level = <6>; - status = "okay"; - }; - - regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; - - reg_can_3v3: regulator@0 { - compatible = "regulator-fixed"; - reg = <0>; - regulator-name = "can-3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpios = <&gpio_spi 3 GPIO_ACTIVE_LOW>; - }; - - reg_sd1_vmmc: regulator@1 { - compatible = "regulator-fixed"; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio1 9 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_gpio_dvfs: regulator-gpio { - compatible = "regulator-gpio"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_dvfs>; - regulator-min-microvolt = <1300000>; - regulator-max-microvolt = <1400000>; - regulator-name = "gpio_dvfs"; - regulator-type = "voltage"; - gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>; - states = <1300000 0x1 1400000 0x0>; - }; - }; - - spi5 { - compatible = "spi-gpio"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_spi4>; - status = "okay"; - gpio-sck = <&gpio5 11 0>; - gpio-mosi = <&gpio5 10 0>; - cs-gpios = <&gpio5 7 0>; - num-chipselects = <1>; - #address-cells = <1>; - #size-cells = <0>; - - gpio_spi: gpio_spi@0 { - compatible = "fairchild,74hc595"; - gpio-controller; - oe-gpios = <&gpio5 8 0>; - #gpio-cells = <2>; - reg = <0>; - registers-number = <1>; - registers-default = /bits/ 8 <0x57>; - spi-max-frequency = <100000>; - }; - }; -}; - -&cpu0 { - arm-supply = <®_arm>; - soc-supply = <®_soc>; - dc-supply = <®_gpio_dvfs>; };
&clks { - assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>; - assigned-clock-rates = <786432000>; -}; - -&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_enet1>; - phy-mode = "rmii"; - phy-handle = <ðphy0>; - status = "okay"; -}; - -&fec2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_enet2>; - phy-mode = "rmii"; - phy-handle = <ðphy1>; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@2 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <2>; - }; - - ethphy1: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - }; - }; -}; - -&gpc { - fsl,cpu_pupscr_sw2iso = <0x1>; - fsl,cpu_pupscr_sw = <0x0>; - fsl,cpu_pdnscr_iso2sw = <0x1>; - fsl,cpu_pdnscr_iso = <0x1>; - fsl,ldo-bypass = <0>; /* DCDC, ldo-enable */ -}; - -&i2c1 { - clock-frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - status = "okay"; - - mag3110@0e { - compatible = "fsl,mag3110"; - reg = <0x0e>; - position = <2>; - }; - - fxls8471@1e { - compatible = "fsl,fxls8471"; - reg = <0x1e>; - position = <0>; - interrupt-parent = <&gpio5>; - interrupts = <0 8>; - }; -}; - -&i2c2 { - clock_frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c2>; - status = "okay"; -}; - -&iomuxc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog_1>; - imx6ul-evk { - pinctrl_hog_1: hoggrp-1 { - fsl,pins = < - MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 /* SD1 CD */ - MX6UL_PAD_GPIO1_IO05__USDHC1_VSELECT 0x17059 /* SD1 VSELECT */ - MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x17059 /* SD1 RESET */ - >; - }; - - pinctrl_csi1: csi1grp { - fsl,pins = < - MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088 - MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088 - MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088 - MX6UL_PAD_CSI_HSYNC__CSI_HSYNC 0x1b088 - MX6UL_PAD_CSI_DATA00__CSI_DATA02 0x1b088 - MX6UL_PAD_CSI_DATA01__CSI_DATA03 0x1b088 - MX6UL_PAD_CSI_DATA02__CSI_DATA04 0x1b088 - MX6UL_PAD_CSI_DATA03__CSI_DATA05 0x1b088 - MX6UL_PAD_CSI_DATA04__CSI_DATA06 0x1b088 - MX6UL_PAD_CSI_DATA05__CSI_DATA07 0x1b088 - MX6UL_PAD_CSI_DATA06__CSI_DATA08 0x1b088 - MX6UL_PAD_CSI_DATA07__CSI_DATA09 0x1b088 - >; - }; - - pinctrl_enet1: enet1grp { - fsl,pins = < - MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0 - MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0 - MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0 - MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0 - MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0 - MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0 - MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0 - MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x4001b031 - >; - }; - - pinctrl_enet2: enet2grp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 - MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 - MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 - MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 - MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 - MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 - MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 - MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 - MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 - MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b031 - >; - }; - - pinctrl_flexcan1: flexcan1grp{ - fsl,pins = < - MX6UL_PAD_UART3_RTS_B__FLEXCAN1_RX 0x1b020 - MX6UL_PAD_UART3_CTS_B__FLEXCAN1_TX 0x1b020 - >; - }; - - pinctrl_flexcan2: flexcan2grp{ - fsl,pins = < - MX6UL_PAD_UART2_RTS_B__FLEXCAN2_RX 0x1b020 - MX6UL_PAD_UART2_CTS_B__FLEXCAN2_TX 0x1b020 - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0 - MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0 - >; - }; - - pinctrl_i2c2: i2c2grp { - fsl,pins = < - MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0 - MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0 - >; - }; - - pinctrl_lcdif_dat: lcdifdatgrp { - fsl,pins = < - MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x79 - MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x79 - MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x79 - MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x79 - MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x79 - MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x79 - MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x79 - MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x79 - MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x79 - MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x79 - MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x79 - MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x79 - MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x79 - MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x79 - MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x79 - MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x79 - MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x79 - MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x79 - MX6UL_PAD_LCD_DATA18__LCDIF_DATA18 0x79 - MX6UL_PAD_LCD_DATA19__LCDIF_DATA19 0x79 - MX6UL_PAD_LCD_DATA20__LCDIF_DATA20 0x79 - MX6UL_PAD_LCD_DATA21__LCDIF_DATA21 0x79 - MX6UL_PAD_LCD_DATA22__LCDIF_DATA22 0x79 - MX6UL_PAD_LCD_DATA23__LCDIF_DATA23 0x79 - >; - }; - - pinctrl_lcdif_ctrl: lcdifctrlgrp { - fsl,pins = < - MX6UL_PAD_LCD_CLK__LCDIF_CLK 0x79 - MX6UL_PAD_LCD_ENABLE__LCDIF_ENABLE 0x79 - MX6UL_PAD_LCD_HSYNC__LCDIF_HSYNC 0x79 - MX6UL_PAD_LCD_VSYNC__LCDIF_VSYNC 0x79 - >; - }; - - pinctrl_pwm1: pwm1grp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO08__PWM1_OUT 0x110b0 - >; - }; - - pinctrl_qspi: qspigrp { - fsl,pins = < - MX6UL_PAD_NAND_WP_B__QSPI_A_SCLK 0x70a1 - MX6UL_PAD_NAND_READY_B__QSPI_A_DATA00 0x70a1 - MX6UL_PAD_NAND_CE0_B__QSPI_A_DATA01 0x70a1 - MX6UL_PAD_NAND_CE1_B__QSPI_A_DATA02 0x70a1 - MX6UL_PAD_NAND_CLE__QSPI_A_DATA03 0x70a1 - MX6UL_PAD_NAND_DQS__QSPI_A_SS0_B 0x70a1 - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 - MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 - >; - }; - - pinctrl_uart2: uart2grp { - fsl,pins = < - MX6UL_PAD_UART2_TX_DATA__UART2_DCE_TX 0x1b0b1 - MX6UL_PAD_UART2_RX_DATA__UART2_DCE_RX 0x1b0b1 - MX6UL_PAD_UART3_RX_DATA__UART2_DCE_RTS 0x1b0b1 - MX6UL_PAD_UART3_TX_DATA__UART2_DCE_CTS 0x1b0b1 - >; - }; - - pinctrl_uart2dte: uart2dtegrp { - fsl,pins = < - MX6UL_PAD_UART2_TX_DATA__UART2_DTE_RX 0x1b0b1 - MX6UL_PAD_UART2_RX_DATA__UART2_DTE_TX 0x1b0b1 - MX6UL_PAD_UART3_RX_DATA__UART2_DTE_CTS 0x1b0b1 - MX6UL_PAD_UART3_TX_DATA__UART2_DTE_RTS 0x1b0b1 - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 - MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10071 - MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 - MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 - MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 - MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x10069 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059 - >; - }; - - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX6UL_PAD_LCD_RESET__WDOG1_WDOG_ANY 0x30b0 - >; - }; - }; -}; - -&iomuxc_snvs { - pinctrl-names = "default_snvs"; - pinctrl-0 = <&pinctrl_hog_2>; - imx6ul-evk { - pinctrl_hog_2: hoggrp-2 { - fsl,pins = < - MX6ULL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x80000000 - >; - }; - - pinctrl_dvfs: dvfsgrp { - fsl,pins = < - MX6ULL_PAD_SNVS_TAMPER3__GPIO5_IO03 0x79 - >; - }; - - pinctrl_lcdif_reset: lcdifresetgrp { - fsl,pins = < - /* used for lcd reset */ - MX6ULL_PAD_SNVS_TAMPER9__GPIO5_IO09 0x79 - >; - }; - - pinctrl_spi4: spi4grp { - fsl,pins = < - MX6ULL_PAD_BOOT_MODE0__GPIO5_IO10 0x70a1 - MX6ULL_PAD_BOOT_MODE1__GPIO5_IO11 0x70a1 - MX6ULL_PAD_SNVS_TAMPER7__GPIO5_IO07 0x70a1 - MX6ULL_PAD_SNVS_TAMPER8__GPIO5_IO08 0x80000000 - >; - }; - - pinctrl_sai2_hp_det_b: sai2_hp_det_grp { - fsl,pins = < - MX6ULL_PAD_SNVS_TAMPER4__GPIO5_IO04 0x17059 - >; - }; - }; -}; - - -&lcdif { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lcdif_dat - &pinctrl_lcdif_ctrl - &pinctrl_lcdif_reset>; - display = <&display0>; - status = "okay"; - - display0: display { - bits-per-pixel = <16>; - bus-width = <24>; - - display-timings { - native-mode = <&timing0>; - timing0: timing0 { - clock-frequency = <9200000>; - hactive = <480>; - vactive = <272>; - hfront-porch = <8>; - hback-porch = <4>; - hsync-len = <41>; - vback-porch = <2>; - vfront-porch = <4>; - vsync-len = <10>; - - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <0>; - }; - }; - }; -}; - -&pwm1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pwm1>; - status = "okay"; -}; - -&qspi { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_qspi>; - status = "okay"; - ddrsmp=<0>; - - flash0: n25q256a@0 { - #address-cells = <1>; - #size-cells = <1>; - /* compatible = "micron,n25q256a"; */ - compatible = "jedec,spi-nor"; - spi-max-frequency = <29000000>; - spi-nor,ddr-quad-read-dummy = <6>; - reg = <0>; - }; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&uart2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - fsl,uart-has-rtscts; - /* for DTE mode, add below change */ - /* fsl,dte-mode; */ - /* pinctrl-0 = <&pinctrl_uart2dte>; */ - status = "okay"; -}; - -&usbotg1 { - dr_mode = "otg"; - srp-disable; - hnp-disable; - adp-disable; - status = "okay"; -}; - -&usbotg2 { - dr_mode = "host"; - disable-over-current; - status = "okay"; -}; - -&usbphy1 { - tx-d-cal = <0x5>; -}; - -&usbphy2 { - tx-d-cal = <0x5>; -}; - -&usdhc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc1>; - cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; - keep-power-in-suspend; - enable-sdio-wakeup; - vmmc-supply = <®_sd1_vmmc>; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc2>; - no-1-8-v; - non-removable; - keep-power-in-suspend; - enable-sdio-wakeup; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,wdog_b; + assigned-clocks = <&clks IMX6UL_CLK_PLL3_PFD2>; + assigned-clock-rates = <320000000>; }; diff --git a/arch/arm/dts/imx6ull-pinfunc-snvs.h b/arch/arm/dts/imx6ull-pinfunc-snvs.h index da3f412e42..54cfe72295 100644 --- a/arch/arm/dts/imx6ull-pinfunc-snvs.h +++ b/arch/arm/dts/imx6ull-pinfunc-snvs.h @@ -1,9 +1,7 @@ +/* SPDX-License-Identifier: GPL-2.0 */ /* * Copyright (C) 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. + * Copyright (C) 2017 NXP */
#ifndef __DTS_IMX6ULL_PINFUNC_SNVS_H @@ -26,4 +24,3 @@ #define MX6ULL_PAD_SNVS_TAMPER9__GPIO5_IO09 0x002C 0x0070 0x0000 0x5 0x0
#endif /* __DTS_IMX6ULL_PINFUNC_SNVS_H */ - diff --git a/arch/arm/dts/imx6ull-pinfunc.h b/arch/arm/dts/imx6ull-pinfunc.h index 7770ed39f6..eb025a9d47 100644 --- a/arch/arm/dts/imx6ull-pinfunc.h +++ b/arch/arm/dts/imx6ull-pinfunc.h @@ -1,9 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /* * Copyright (C) 2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. */
#ifndef __DTS_IMX6ULL_PINFUNC_H @@ -14,46 +11,77 @@ * The pin function ID is a tuple of * <mux_reg conf_reg input_reg mux_mode input_val> */ -#define MX6UL_PAD_GPIO1_IO03__OSC32K_32K_OUT 0x0068 0x02f4 0x0000 0x3 0x0 +/* signals common for i.MX6UL and i.MX6ULL */ +#undef MX6UL_PAD_UART5_TX_DATA__UART5_DTE_RX +#define MX6UL_PAD_UART5_TX_DATA__UART5_DTE_RX 0x00BC 0x0348 0x0644 0x0 0x6 +#undef MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX +#define MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX 0x00C0 0x034C 0x0644 0x0 0x7 +#undef MX6UL_PAD_ENET1_RX_EN__UART5_DCE_RTS +#define MX6UL_PAD_ENET1_RX_EN__UART5_DCE_RTS 0x00CC 0x0358 0x0640 0x1 0x5 +#undef MX6UL_PAD_ENET1_TX_DATA0__UART5_DTE_RTS +#define MX6UL_PAD_ENET1_TX_DATA0__UART5_DTE_RTS 0x00D0 0x035C 0x0640 0x1 0x6 +#undef MX6UL_PAD_CSI_DATA02__UART5_DCE_RTS +#define MX6UL_PAD_CSI_DATA02__UART5_DCE_RTS 0x01EC 0x0478 0x0640 0x8 0x7
-#define MX6UL_PAD_ENET2_RX_DATA0__EPDC_SDDO08 0x00E4 0x0370 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_RX_DATA1__EPDC_SDDO09 0x00E8 0x0374 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_RX_EN__EPDC_SDDO10 0x00EC 0x0378 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_TX_DATA0__EPDC_SDDO11 0x00F0 0x037C 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_TX_DATA1__EPDC_SDDO12 0x00F4 0x0380 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_TX_EN__EPDC_SDDO13 0x00F8 0x0384 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_TX_CLK__EPDC_SDDO14 0x00FC 0x0388 0x0000 0x9 0x0 -#define MX6UL_PAD_ENET2_RX_ER__EPDC_SDDO15 0x0100 0x038C 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_CLK__EPDC_SDCLK 0x0104 0x0390 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_ENABLE__EPDC_SDLE 0x0108 0x0394 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_HSYNC__EPDC_SDOE 0x010C 0x0398 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_VSYNC__EPDC_SDCE0 0x0110 0x039C 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_RESET__EPDC_GDOE 0x0114 0x03A0 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA00__EPDC_SDDO00 0x0118 0x03A4 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA01__EPDC_SDDO01 0x011C 0x03A8 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA02__EPDC_SDDO02 0x0120 0x03AC 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA03__EPDC_SDDO03 0x0124 0x03B0 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA04__EPDC_SDDO04 0x0128 0x03B4 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA05__EPDC_SDDO05 0x012C 0x03B8 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA06__EPDC_SDDO06 0x0130 0x03BC 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA07__EPDC_SDDO07 0x0134 0x03C0 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA14__EPDC_SDSHR 0x0150 0x03DC 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA15__EPDC_GDRL 0x0154 0x03E0 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA16__EPDC_GDCLK 0x0158 0x03E4 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA17__EPDC_GDSP 0x015C 0x03E8 0x0000 0x9 0x0 -#define MX6UL_PAD_LCD_DATA21__EPDC_SDCE1 0x016C 0x03F8 0x0000 0x9 0x0 - -#define MX6UL_PAD_CSI_MCLK__ESAI_TX3_RX2 0x01D4 0x0460 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_PIXCLK__ESAI_TX2_RX3 0x01D8 0x0464 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_VSYNC__ESAI_TX4_RX1 0x01DC 0x0468 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_HSYNC__ESAI_TX1 0x01E0 0x046C 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA00__ESAI_TX_HF_CLK 0x01E4 0x0470 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA01__ESAI_RX_HF_CLK 0x01E8 0x0474 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA02__ESAI_RX_FS 0x01EC 0x0478 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA03__ESAI_RX_CLK 0x01F0 0x047C 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA04__ESAI_TX_FS 0x01F4 0x0480 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA05__ESAI_TX_CLK 0x01F8 0x0484 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA06__ESAI_TX5_RX0 0x01FC 0x0488 0x0000 0x9 0x0 -#define MX6UL_PAD_CSI_DATA07__ESAI_T0 0x0200 0x048C 0x0000 0x9 0x0 +/* signals for i.MX6ULL only */ +#define MX6ULL_PAD_UART1_TX_DATA__UART5_DCE_TX 0x0084 0x0310 0x0000 0x9 0x0 +#define MX6ULL_PAD_UART1_TX_DATA__UART5_DTE_RX 0x0084 0x0310 0x0644 0x9 0x4 +#define MX6ULL_PAD_UART1_RX_DATA__UART5_DCE_RX 0x0088 0x0314 0x0644 0x9 0x5 +#define MX6ULL_PAD_UART1_RX_DATA__UART5_DTE_TX 0x0088 0x0314 0x0000 0x9 0x0 +#define MX6ULL_PAD_UART1_CTS_B__UART5_DCE_CTS 0x008C 0x0318 0x0000 0x9 0x0 +#define MX6ULL_PAD_UART1_CTS_B__UART5_DTE_RTS 0x008C 0x0318 0x0640 0x9 0x3 +#define MX6ULL_PAD_UART1_RTS_B__UART5_DCE_RTS 0x0090 0x031C 0x0640 0x9 0x4 +#define MX6ULL_PAD_UART1_RTS_B__UART5_DTE_CTS 0x0090 0x031C 0x0000 0x9 0x0 +#define MX6ULL_PAD_UART4_RX_DATA__EPDC_PWRCTRL01 0x00B8 0x0344 0x0000 0x9 0x0 +#define MX6ULL_PAD_UART5_TX_DATA__EPDC_PWRCTRL02 0x00BC 0x0348 0x0000 0x9 0x0 +#define MX6ULL_PAD_UART5_RX_DATA__EPDC_PWRCTRL03 0x00C0 0x034C 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_RX_DATA0__EPDC_SDCE04 0x00C4 0x0350 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_RX_DATA1__EPDC_SDCE05 0x00C8 0x0354 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_RX_EN__EPDC_SDCE06 0x00CC 0x0358 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_TX_DATA0__EPDC_SDCE07 0x00D0 0x035C 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_TX_DATA1__EPDC_SDCE08 0x00D4 0x0360 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_TX_EN__EPDC_SDCE09 0x00D8 0x0364 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_TX_CLK__EPDC_SDOED 0x00DC 0x0368 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET1_RX_ER__EPDC_SDOEZ 0x00E0 0x036C 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_RX_DATA0__EPDC_SDDO08 0x00E4 0x0370 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_RX_DATA1__EPDC_SDDO09 0x00E8 0x0374 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_RX_EN__EPDC_SDDO10 0x00EC 0x0378 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_TX_DATA0__EPDC_SDDO11 0x00F0 0x037C 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_TX_DATA1__EPDC_SDDO12 0x00F4 0x0380 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_TX_EN__EPDC_SDDO13 0x00F8 0x0384 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_TX_CLK__EPDC_SDDO14 0x00FC 0x0388 0x0000 0x9 0x0 +#define MX6ULL_PAD_ENET2_RX_ER__EPDC_SDDO15 0x0100 0x038C 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_CLK__EPDC_SDCLK 0x0104 0x0390 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_ENABLE__EPDC_SDLE 0x0108 0x0394 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_HSYNC__EPDC_SDOE 0x010C 0x0398 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_VSYNC__EPDC_SDCE0 0x0110 0x039C 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_RESET__EPDC_GDOE 0x0114 0x03A0 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA00__EPDC_SDDO00 0x0118 0x03A4 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA01__EPDC_SDDO01 0x011C 0x03A8 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA02__EPDC_SDDO02 0x0120 0x03AC 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA03__EPDC_SDDO03 0x0124 0x03B0 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA04__EPDC_SDDO04 0x0128 0x03B4 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA05__EPDC_SDDO05 0x012C 0x03B8 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA06__EPDC_SDDO06 0x0130 0x03BC 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA07__EPDC_SDDO07 0x0134 0x03C0 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA14__EPDC_SDSHR 0x0150 0x03DC 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA15__EPDC_GDRL 0x0154 0x03E0 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA16__EPDC_GDCLK 0x0158 0x03E4 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA17__EPDC_GDSP 0x015C 0x03E8 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA21__EPDC_SDCE1 0x016C 0x03F8 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA22__EPDC_SDCE02 0x0170 0x03FC 0x0000 0x9 0x0 +#define MX6ULL_PAD_LCD_DATA23__EPDC_SDCE03 0x0174 0x0400 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_MCLK__ESAI_TX3_RX2 0x01D4 0x0460 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_PIXCLK__ESAI_TX2_RX3 0x01D8 0x0464 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_VSYNC__ESAI_TX4_RX1 0x01DC 0x0468 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_HSYNC__ESAI_TX1 0x01E0 0x046C 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA00__ESAI_TX_HF_CLK 0x01E4 0x0470 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA01__ESAI_RX_HF_CLK 0x01E8 0x0474 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA02__ESAI_RX_FS 0x01EC 0x0478 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA03__ESAI_RX_CLK 0x01F0 0x047C 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA04__ESAI_TX_FS 0x01F4 0x0480 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA05__ESAI_TX_CLK 0x01F8 0x0484 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA06__ESAI_TX5_RX0 0x01FC 0x0488 0x0000 0x9 0x0 +#define MX6ULL_PAD_CSI_DATA07__ESAI_T0 0x0200 0x048C 0x0000 0x9 0x0
#endif /* __DTS_IMX6ULL_PINFUNC_H */ diff --git a/arch/arm/dts/imx6ull.dtsi b/arch/arm/dts/imx6ull.dtsi index 4598f2f411..22e4a307fa 100644 --- a/arch/arm/dts/imx6ull.dtsi +++ b/arch/arm/dts/imx6ull.dtsi @@ -1,1173 +1,81 @@ -/* - * Copyright 2015-2016 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License version 2 as - * published by the Free Software Foundation. - */ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// +// Copyright 2016 Freescale Semiconductor, Inc.
-#include <dt-bindings/clock/imx6ul-clock.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> +#include "imx6ul.dtsi" #include "imx6ull-pinfunc.h" #include "imx6ull-pinfunc-snvs.h" -#include "skeleton.dtsi"
-/ { - aliases { - can0 = &flexcan1; - can1 = &flexcan2; - ethernet0 = &fec1; - ethernet1 = &fec2; - gpio0 = &gpio1; - gpio1 = &gpio2; - gpio2 = &gpio3; - gpio3 = &gpio4; - gpio4 = &gpio5; - i2c0 = &i2c1; - i2c1 = &i2c2; - i2c2 = &i2c3; - i2c3 = &i2c4; - mmc0 = &usdhc1; - mmc1 = &usdhc2; - serial0 = &uart1; - serial1 = &uart2; - serial2 = &uart3; - serial3 = &uart4; - serial4 = &uart5; - serial5 = &uart6; - serial6 = &uart7; - serial7 = &uart8; - spi0 = &qspi; - spi1 = &ecspi1; - spi2 = &ecspi2; - spi3 = &ecspi3; - spi4 = &ecspi4; - usbphy0 = &usbphy1; - usbphy1 = &usbphy2; - usb0 = &usbotg1; - usb1 = &usbotg2; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu0: cpu@0 { - compatible = "arm,cortex-a7"; - device_type = "cpu"; - reg = <0>; - clock-latency = <61036>; /* two CLK32 periods */ - operating-points = < - /* kHz uV */ - 528000 1175000 - 99000 950000 - >; - fsl,soc-operating-points = < - /* KHz uV */ - 528000 1175000 - 99000 1175000 - >; - clocks = <&clks IMX6UL_CLK_ARM>, - <&clks IMX6UL_CLK_PLL2_BUS>, - <&clks IMX6UL_CLK_PLL2_PFD2>, - <&clks IMX6UL_CA7_SECONDARY_SEL>, - <&clks IMX6UL_CLK_STEP>, - <&clks IMX6UL_CLK_PLL1_SW>, - <&clks IMX6UL_CLK_PLL1_SYS>, - <&clks IMX6UL_PLL1_BYPASS>, - <&clks IMX6UL_CLK_PLL1>, - <&clks IMX6UL_PLL1_BYPASS_SRC>, - <&clks IMX6UL_CLK_OSC>; - clock-names = "arm", "pll2_bus", "pll2_pfd2_396m", "secondary_sel", "step", - "pll1_sw", "pll1_sys", "pll1_bypass", "pll1", "pll1_bypass_src", "osc"; - }; - }; - - intc: interrupt-controller@00a01000 { - compatible = "arm,cortex-a7-gic"; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x00a01000 0x1000>, - <0x00a02000 0x100>; - }; - - clocks { - #address-cells = <1>; - #size-cells = <0>; - - ckil: clock@0 { - compatible = "fixed-clock"; - reg = <0>; - #clock-cells = <0>; - clock-frequency = <32768>; - clock-output-names = "ckil"; - }; +/* Delete UART8 in AIPS-1 (i.MX6UL specific) */ +/delete-node/ &uart8; +/* Delete CAAM node in AIPS-2 (i.MX6UL specific) */ +/delete-node/ &crypto; + +&cpu0 { + operating-points = < + /* kHz uV */ + 900000 1275000 + 792000 1225000 + 528000 1175000 + 396000 1025000 + 198000 950000 + >; + fsl,soc-operating-points = < + /* KHz uV */ + 900000 1250000 + 792000 1175000 + 528000 1175000 + 396000 1175000 + 198000 1175000 + >; +};
- osc: clock@1 { - compatible = "fixed-clock"; - reg = <1>; - #clock-cells = <0>; - clock-frequency = <24000000>; - clock-output-names = "osc"; - }; +&ocotp { + compatible = "fsl,imx6ull-ocotp", "syscon"; +};
- ipp_di0: clock@2 { - compatible = "fixed-clock"; - reg = <2>; - #clock-cells = <0>; - clock-frequency = <0>; - clock-output-names = "ipp_di0"; - }; +&usdhc1 { + compatible = "fsl,imx6ull-usdhc", "fsl,imx6sx-usdhc"; +};
- ipp_di1: clock@3 { - compatible = "fixed-clock"; - reg = <3>; - #clock-cells = <0>; - clock-frequency = <0>; - clock-output-names = "ipp_di1"; - }; - }; +&usdhc2 { + compatible = "fsl,imx6ull-usdhc", "fsl,imx6sx-usdhc"; +};
+/ { soc { - #address-cells = <1>; - #size-cells = <1>; - compatible = "simple-bus"; - interrupt-parent = <&gpc>; - ranges; - - busfreq { - compatible = "fsl,imx_busfreq"; - clocks = <&clks IMX6UL_CLK_PLL2_PFD2>, <&clks IMX6UL_CLK_PLL2_198M>, - <&clks IMX6UL_CLK_PLL2_BUS>, <&clks IMX6UL_CLK_ARM>, - <&clks IMX6UL_CLK_PLL3_USB_OTG>, <&clks IMX6UL_CLK_PERIPH>, - <&clks IMX6UL_CLK_PERIPH_PRE>, <&clks IMX6UL_CLK_PERIPH_CLK2>, - <&clks IMX6UL_CLK_PERIPH_CLK2_SEL>, <&clks IMX6UL_CLK_OSC>, - <&clks IMX6UL_CLK_AHB>, <&clks IMX6UL_CLK_AXI>, - <&clks IMX6UL_CLK_PERIPH2>, <&clks IMX6UL_CLK_PERIPH2_PRE>, - <&clks IMX6UL_CLK_PERIPH2_CLK2>, <&clks IMX6UL_CLK_PERIPH2_CLK2_SEL>, - <&clks IMX6UL_CLK_STEP>, <&clks IMX6UL_CLK_MMDC_P0_FAST>, <&clks IMX6UL_PLL1_BYPASS_SRC>, - <&clks IMX6UL_PLL1_BYPASS>, <&clks IMX6UL_CLK_PLL1_SYS>, <&clks IMX6UL_CLK_PLL1_SW>, - <&clks IMX6UL_CLK_PLL1>; - clock-names = "pll2_pfd2_396m", "pll2_198m", "pll2_bus", "arm", "pll3_usb_otg", - "periph", "periph_pre", "periph_clk2", "periph_clk2_sel", "osc", - "ahb", "ocram", "periph2", "periph2_pre", "periph2_clk2", "periph2_clk2_sel", - "step", "mmdc", "pll1_bypass_src", "pll1_bypass", "pll1_sys", "pll1_sw", "pll1"; - fsl,max_ddr_freq = <400000000>; - }; - - pmu { - compatible = "arm,cortex-a7-pmu"; - interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - ocrams: sram@00900000 { - compatible = "fsl,lpm-sram"; - reg = <0x00900000 0x4000>; - }; - - ocrams_ddr: sram@00904000 { - compatible = "fsl,ddr-lpm-sram"; - reg = <0x00904000 0x1000>; - }; - - ocram: sram@00905000 { - compatible = "mmio-sram"; - reg = <0x00905000 0x1B000>; - }; - - dma_apbh: dma-apbh@01804000 { - compatible = "fsl,imx6ul-dma-apbh", "fsl,imx28-dma-apbh"; - reg = <0x01804000 0x2000>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "gpmi0", "gpmi1", "gpmi2", "gpmi3"; - #dma-cells = <1>; - dma-channels = <4>; - clocks = <&clks IMX6UL_CLK_APBHDMA>; - }; - - gpmi: gpmi-nand@01806000{ - compatible = "fsl,imx6q-gpmi-nand"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x01806000 0x2000>, <0x01808000 0x4000>; - reg-names = "gpmi-nand", "bch"; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "bch"; - clocks = <&clks IMX6UL_CLK_GPMI_IO>, - <&clks IMX6UL_CLK_GPMI_APB>, - <&clks IMX6UL_CLK_GPMI_BCH>, - <&clks IMX6UL_CLK_GPMI_BCH_APB>, - <&clks IMX6UL_CLK_PER_BCH>; - clock-names = "gpmi_io", "gpmi_apb", "gpmi_bch", - "gpmi_bch_apb", "per1_bch"; - dmas = <&dma_apbh 0>; - dma-names = "rx-tx"; - status = "disabled"; - }; - - aips1: aips-bus@02000000 { - compatible = "fsl,aips-bus", "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x02000000 0x100000>; - ranges; - - spba-bus@02000000 { - compatible = "fsl,spba-bus", "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x02000000 0x40000>; - ranges; - - spdif: spdif@02004000 { - compatible = "fsl,imx6ul-spdif", "fsl,imx35-spdif"; - reg = <0x02004000 0x4000>; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&sdma 41 18 0>, - <&sdma 42 18 0>; - dma-names = "rx", "tx"; - clocks = <&clks IMX6UL_CLK_SPDIF_GCLK>, - <&clks IMX6UL_CLK_OSC>, - <&clks IMX6UL_CLK_SPDIF>, - <&clks IMX6UL_CLK_DUMMY>, <&clks IMX6UL_CLK_DUMMY>, <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_IPG>, - <&clks IMX6UL_CLK_DUMMY>, <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_SPBA>; - clock-names = "core", "rxtx0", - "rxtx1", "rxtx2", - "rxtx3", "rxtx4", - "rxtx5", "rxtx6", - "rxtx7", "dma"; - status = "disabled"; - }; - - ecspi1: ecspi@02008000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; - reg = <0x02008000 0x4000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ECSPI1>, - <&clks IMX6UL_CLK_ECSPI1>; - clock-names = "ipg", "per"; - dmas = <&sdma 3 7 1>, <&sdma 4 7 2>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - ecspi2: ecspi@0200c000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; - reg = <0x0200c000 0x4000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ECSPI2>, - <&clks IMX6UL_CLK_ECSPI2>; - clock-names = "ipg", "per"; - dmas = <&sdma 5 7 1>, <&sdma 6 7 2>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - ecspi3: ecspi@02010000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; - reg = <0x02010000 0x4000>; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ECSPI3>, - <&clks IMX6UL_CLK_ECSPI3>; - clock-names = "ipg", "per"; - dmas = <&sdma 7 7 1>, <&sdma 8 7 2>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - ecspi4: ecspi@02014000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi"; - reg = <0x02014000 0x4000>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ECSPI4>, - <&clks IMX6UL_CLK_ECSPI4>; - clock-names = "ipg", "per"; - dmas = <&sdma 9 7 1>, <&sdma 10 7 2>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart7: serial@02018000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x02018000 0x4000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART7_IPG>, - <&clks IMX6UL_CLK_UART7_SERIAL>; - clock-names = "ipg", "per"; - dmas = <&sdma 43 4 0>, <&sdma 44 4 0>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart1: serial@02020000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x02020000 0x4000>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART1_IPG>, - <&clks IMX6UL_CLK_UART1_SERIAL>; - clock-names = "ipg", "per"; - status = "disabled"; - }; - - esai: esai@02024000 { - compatible = "fsl,imx6ull-esai"; - reg = <0x02024000 0x4000>; - interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ESAI_IPG>, - <&clks IMX6UL_CLK_ESAI_MEM>, - <&clks IMX6UL_CLK_ESAI_EXTAL>, - <&clks IMX6UL_CLK_ESAI_IPG>, - <&clks IMX6UL_CLK_SPBA>; - clock-names = "core", "mem", "extal", - "fsys", "dma"; - dmas = <&sdma 0 21 0>, <&sdma 47 21 0>; - dma-names = "rx", "tx"; - dma-source = <&gpr 0 14 0 15>; - status = "disabled"; - }; - - sai1: sai@02028000 { - compatible = "fsl,imx6ul-sai", - "fsl,imx6sx-sai"; - reg = <0x02028000 0x4000>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_SAI1_IPG>, - <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_SAI1>, - <&clks 0>, <&clks 0>; - clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; - dma-names = "rx", "tx"; - dmas = <&sdma 35 24 0>, <&sdma 36 24 0>; - status = "disabled"; - }; - - sai2: sai@0202c000 { - compatible = "fsl,imx6ul-sai", - "fsl,imx6sx-sai"; - reg = <0x0202c000 0x4000>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_SAI2_IPG>, - <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_SAI2>, - <&clks 0>, <&clks 0>; - clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; - dma-names = "rx", "tx"; - dmas = <&sdma 37 24 0>, <&sdma 38 24 0>; - status = "disabled"; - }; - - sai3: sai@02030000 { - compatible = "fsl,imx6ul-sai", - "fsl,imx6sx-sai"; - reg = <0x02030000 0x4000>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_SAI3_IPG>, - <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_SAI3>, - <&clks 0>, <&clks 0>; - clock-names = "bus", "mclk0", "mclk1", "mclk2", "mclk3"; - dma-names = "rx", "tx"; - dmas = <&sdma 39 24 0>, <&sdma 40 24 0>; - status = "disabled"; - }; - - asrc: asrc@02034000 { - compatible = "fsl,imx53-asrc"; - reg = <0x02034000 0x4000>; - interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ASRC_IPG>, - <&clks IMX6UL_CLK_ASRC_MEM>, <&clks 0>, - <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, - <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, - <&clks 0>, <&clks 0>, <&clks 0>, <&clks 0>, - <&clks IMX6UL_CLK_SPDIF>, <&clks 0>, <&clks 0>, - <&clks IMX6UL_CLK_SPBA>; - clock-names = "mem", "ipg", "asrck_0", - "asrck_1", "asrck_2", "asrck_3", "asrck_4", - "asrck_5", "asrck_6", "asrck_7", "asrck_8", - "asrck_9", "asrck_a", "asrck_b", "asrck_c", - "asrck_d", "asrck_e", "asrck_f", "dma"; - dmas = <&sdma 17 23 1>, <&sdma 18 23 1>, <&sdma 19 23 1>, - <&sdma 20 23 1>, <&sdma 21 23 1>, <&sdma 22 23 1>; - dma-names = "rxa", "rxb", "rxc", - "txa", "txb", "txc"; - fsl,asrc-rate = <48000>; - fsl,asrc-width = <16>; - status = "okay"; - }; - }; - - tsc: tsc@02040000 { - compatible = "fsl,imx6ul-tsc"; - reg = <0x02040000 0x4000>, <0x0219c000 0x4000>; - interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_IPG>, - <&clks IMX6UL_CLK_ADC2>; - clock-names = "tsc", "adc"; - status = "disabled"; - }; - - pwm1: pwm@02080000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x02080000 0x4000>; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_PWM1>, - <&clks IMX6UL_CLK_PWM1>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - pwm2: pwm@02084000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x02084000 0x4000>; - interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - pwm3: pwm@02088000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x02088000 0x4000>; - interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_PWM3>, - <&clks IMX6UL_CLK_PWM3>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - pwm4: pwm@0208c000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x0208c000 0x4000>; - interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - flexcan1: can@02090000 { - compatible = "fsl,imx6ul-flexcan", "fsl,imx6q-flexcan"; - reg = <0x02090000 0x4000>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_CAN1_IPG>, - <&clks IMX6UL_CLK_CAN1_SERIAL>; - clock-names = "ipg", "per"; - stop-mode = <&gpr 0x10 1 0x10 17>; - status = "disabled"; - }; - - flexcan2: can@02094000 { - compatible = "fsl,imx6ul-flexcan", "fsl,imx6q-flexcan"; - reg = <0x02094000 0x4000>; - interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_CAN2_IPG>, - <&clks IMX6UL_CLK_CAN2_SERIAL>; - clock-names = "ipg", "per"; - stop-mode = <&gpr 0x10 2 0x10 18>; - status = "disabled"; - }; - - gpt1: gpt@02098000 { - compatible = "fsl,imx6ul-gpt", "fsl,imx31-gpt"; - reg = <0x02098000 0x4000>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_GPT1_BUS>, - <&clks IMX6UL_CLK_GPT1_SERIAL>; - clock-names = "ipg", "per"; - }; - - gpio1: gpio@0209c000 { - compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; - reg = <0x0209c000 0x4000>; - interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@020a0000 { - compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; - reg = <0x020a0000 0x4000>; - interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@020a4000 { - compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; - reg = <0x020a4000 0x4000>; - interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@020a8000 { - compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; - reg = <0x020a8000 0x4000>; - interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio5: gpio@020ac000 { - compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; - reg = <0x020ac000 0x4000>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - snvslp: snvs@020b0000 { - compatible = "fsl,imx6ul-snvs"; - reg = <0x020b0000 0x4000>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - }; - - fec2: ethernet@020b4000 { - compatible = "fsl,imx6ul-fec", "fsl,imx6q-fec"; - reg = <0x020b4000 0x4000>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ENET>, - <&clks IMX6UL_CLK_ENET_AHB>, - <&clks IMX6UL_CLK_ENET_PTP>, - <&clks IMX6UL_CLK_ENET2_REF_125M>, - <&clks IMX6UL_CLK_ENET2_REF_125M>; - clock-names = "ipg", "ahb", "ptp", - "enet_clk_ref", "enet_out"; - stop-mode = <&gpr 0x10 4>; - fsl,num-tx-queues=<1>; - fsl,num-rx-queues=<1>; - fsl,magic-packet; - fsl,wakeup_irq = <0>; - status = "disabled"; - }; - - kpp: kpp@020b8000 { - compatible = "fsl,imx6ul-kpp", "fsl,imx21-kpp"; - reg = <0x020b8000 0x4000>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>; - status = "disabled"; - }; - - wdog1: wdog@020bc000 { - compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; - reg = <0x020bc000 0x4000>; - interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_WDOG1>; - }; - - wdog2: wdog@020c0000 { - compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; - reg = <0x020c0000 0x4000>; - interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_WDOG2>; - status = "disabled"; - }; - - clks: ccm@020c4000 { - compatible = "fsl,imx6ul-ccm"; - reg = <0x020c4000 0x4000>; - interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>; - #clock-cells = <1>; - clocks = <&ckil>, <&osc>, <&ipp_di0>, <&ipp_di1>; - clock-names = "ckil", "osc", "ipp_di0", "ipp_di1"; - }; - - anatop: anatop@020c8000 { - compatible = "fsl,imx6ul-anatop", "fsl,imx6q-anatop", - "syscon", "simple-bus"; - reg = <0x020c8000 0x1000>; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - - reg_3p0: regulator-3p0@120 { - compatible = "fsl,anatop-regulator"; - regulator-name = "vdd3p0"; - regulator-min-microvolt = <2625000>; - regulator-max-microvolt = <3400000>; - anatop-reg-offset = <0x120>; - anatop-vol-bit-shift = <8>; - anatop-vol-bit-width = <5>; - anatop-min-bit-val = <0>; - anatop-min-voltage = <2625000>; - anatop-max-voltage = <3400000>; - anatop-enable-bit = <0>; - }; - - reg_arm: regulator-vddcore@140 { - compatible = "fsl,anatop-regulator"; - regulator-name = "cpu"; - regulator-min-microvolt = <725000>; - regulator-max-microvolt = <1450000>; - regulator-always-on; - anatop-reg-offset = <0x140>; - anatop-vol-bit-shift = <0>; - anatop-vol-bit-width = <5>; - anatop-delay-reg-offset = <0x170>; - anatop-delay-bit-shift = <24>; - anatop-delay-bit-width = <2>; - anatop-min-bit-val = <1>; - anatop-min-voltage = <725000>; - anatop-max-voltage = <1450000>; - }; - - reg_soc: regulator-vddsoc@140 { - compatible = "fsl,anatop-regulator"; - regulator-name = "vddsoc"; - regulator-min-microvolt = <725000>; - regulator-max-microvolt = <1450000>; - regulator-always-on; - anatop-reg-offset = <0x140>; - anatop-vol-bit-shift = <18>; - anatop-vol-bit-width = <5>; - anatop-delay-reg-offset = <0x170>; - anatop-delay-bit-shift = <28>; - anatop-delay-bit-width = <2>; - anatop-min-bit-val = <1>; - anatop-min-voltage = <725000>; - anatop-max-voltage = <1450000>; - }; - }; - - usbphy1: usbphy@020c9000 { - compatible = "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; - reg = <0x020c9000 0x1000>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_USBPHY1>; - phy-3p0-supply = <®_3p0>; - fsl,anatop = <&anatop>; - }; - - usbphy2: usbphy@020ca000 { - compatible = "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; - reg = <0x020ca000 0x1000>; - interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_USBPHY2>; - phy-3p0-supply = <®_3p0>; - fsl,anatop = <&anatop>; - }; - - tempmon: tempmon { - compatible = "fsl,imx6ul-tempmon", "fsl,imx6sx-tempmon"; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; - fsl,tempmon = <&anatop>; - fsl,tempmon-data = <&ocotp>; - clocks = <&clks IMX6UL_CLK_PLL3_USB_OTG>; - }; - - snvs: snvs@020cc000 { - compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; - reg = <0x020cc000 0x4000>; - - snvs_rtc: snvs-rtc-lp { - compatible = "fsl,sec-v4.0-mon-rtc-lp"; - regmap = <&snvs>; - offset = <0x34>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - }; - - snvs_poweroff: snvs-poweroff { - compatible = "syscon-poweroff"; - regmap = <&snvs>; - offset = <0x38>; - mask = <0x61>; - }; - - snvs_pwrkey: snvs-powerkey { - compatible = "fsl,sec-v4.0-pwrkey"; - regmap = <&snvs>; - interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; - linux,keycode = <KEY_POWER>; - wakeup; - }; - }; - - epit1: epit@020d0000 { - reg = <0x020d0000 0x4000>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - }; - - epit2: epit@020d4000 { - reg = <0x020d4000 0x4000>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - }; - - src: src@020d8000 { - compatible = "fsl,imx6ul-src", "fsl,imx51-src"; - reg = <0x020d8000 0x4000>; - interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - #reset-cells = <1>; - }; - - gpc: gpc@020dc000 { - compatible = "fsl,imx6ul-gpc", "fsl,imx6q-gpc"; - reg = <0x020dc000 0x4000>; - interrupt-controller; - #interrupt-cells = <3>; - interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; - interrupt-parent = <&intc>; - fsl,mf-mix-wakeup-irq = <0xfc00000 0x7d00 0x0 0x1400640>; - }; - - iomuxc: iomuxc@020e0000 { - compatible = "fsl,imx6ul-iomuxc"; - reg = <0x020e0000 0x4000>; - }; - - gpr: iomuxc-gpr@020e4000 { - compatible = "fsl,imx6ul-iomuxc-gpr", "syscon"; - reg = <0x020e4000 0x4000>; - }; - - mqs: mqs { - compatible = "fsl,imx6sx-mqs"; - gpr = <&gpr>; - status = "disabled"; - }; - - gpt2: gpt@020e8000 { - compatible = "fsl,imx6ul-gpt", "fsl,imx31-gpt"; - reg = <0x020e8000 0x4000>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - }; - - sdma: sdma@020ec000 { - compatible = "fsl,imx6ul-sdma", "fsl,imx35-sdma"; - reg = <0x020ec000 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_SDMA>, - <&clks IMX6UL_CLK_SDMA>; - clock-names = "ipg", "ahb"; - #dma-cells = <3>; - iram = <&ocram>; - fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; - }; - - pwm5: pwm@020f0000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x020f0000 0x4000>; - interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - pwm6: pwm@020f4000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x020f4000 0x4000>; - interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - pwm7: pwm@020f8000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x020f8000 0x4000>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - - pwm8: pwm@020fc000 { - compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; - reg = <0x020fc000 0x4000>; - interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "ipg", "per"; - #pwm-cells = <2>; - }; - }; - - aips2: aips-bus@02100000 { - compatible = "fsl,aips-bus", "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0x02100000 0x100000>; - ranges; - - usbotg1: usb@02184000 { - compatible = "fsl,imx6ul-usb", "fsl,imx27-usb"; - reg = <0x02184000 0x200>; - interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_USBOH3>; - fsl,usbphy = <&usbphy1>; - fsl,usbmisc = <&usbmisc 0>; - fsl,anatop = <&anatop>; - ahb-burst-config = <0x0>; - tx-burst-size-dword = <0x10>; - rx-burst-size-dword = <0x10>; - status = "disabled"; - }; - - usbotg2: usb@02184200 { - compatible = "fsl,imx6ul-usb", "fsl,imx27-usb"; - reg = <0x02184200 0x200>; - interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_USBOH3>; - fsl,usbphy = <&usbphy2>; - fsl,usbmisc = <&usbmisc 1>; - ahb-burst-config = <0x0>; - tx-burst-size-dword = <0x10>; - rx-burst-size-dword = <0x10>; - status = "disabled"; - }; - - usbmisc: usbmisc@02184800 { - #index-cells = <1>; - compatible = "fsl,imx6ul-usbmisc", "fsl,imx6q-usbmisc"; - reg = <0x02184800 0x200>; - }; - - fec1: ethernet@02188000 { - compatible = "fsl,imx6ul-fec", "fsl,imx6q-fec"; - reg = <0x02188000 0x4000>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ENET>, - <&clks IMX6UL_CLK_ENET_AHB>, - <&clks IMX6UL_CLK_ENET_PTP>, - <&clks IMX6UL_CLK_ENET_REF>, - <&clks IMX6UL_CLK_ENET_REF>; - clock-names = "ipg", "ahb", "ptp", - "enet_clk_ref", "enet_out"; - stop-mode = <&gpr 0x10 3>; - fsl,num-tx-queues=<1>; - fsl,num-rx-queues=<1>; - fsl,magic-packet; - fsl,wakeup_irq = <0>; - status = "disabled"; - }; - - usdhc1: usdhc@02190000 { - compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc"; - reg = <0x02190000 0x4000>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_USDHC1>, - <&clks IMX6UL_CLK_USDHC1>, - <&clks IMX6UL_CLK_USDHC1>; - clock-names = "ipg", "ahb", "per"; - bus-width = <4>; - fsl,tuning-step= <2>; - status = "disabled"; - }; - - usdhc2: usdhc@02194000 { - compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc"; - reg = <0x02194000 0x4000>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_USDHC2>, - <&clks IMX6UL_CLK_USDHC2>, - <&clks IMX6UL_CLK_USDHC2>; - clock-names = "ipg", "ahb", "per"; - bus-width = <4>; - fsl,tuning-step= <2>; - status = "disabled"; - }; - - adc1: adc@02198000 { - compatible = "fsl,imx6ul-adc", "fsl,vf610-adc"; - reg = <0x02198000 0x4000>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_ADC1>; - num-channels = <2>; - clock-names = "adc"; - status = "disabled"; - }; - - i2c1: i2c@021a0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; - reg = <0x021a0000 0x4000>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_I2C1>; - status = "disabled"; - }; - - i2c2: i2c@021a4000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; - reg = <0x021a4000 0x4000>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_I2C2>; - status = "disabled"; - }; - - i2c3: i2c@021a8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; - reg = <0x021a8000 0x4000>; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_I2C3>; - status = "disabled"; - }; - - romcp@021ac000 { - compatible = "fsl,imx6ul-romcp", "syscon"; - reg = <0x021ac000 0x4000>; - }; - - mmdc: mmdc@021b0000 { - compatible = "fsl,imx6ul-mmdc", "fsl,imx6q-mmdc"; - reg = <0x021b0000 0x4000>; - }; - - weim: weim@021b8000 { - compatible = "fsl,imx6ul-weim", "fsl,imx6q-weim"; - reg = <0x021b8000 0x4000>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>; - }; - - ocotp: ocotp-ctrl@021bc000 { - compatible = "fsl,imx6ull-ocotp", "syscon"; - reg = <0x021bc000 0x4000>; - clocks = <&clks IMX6UL_CLK_OCOTP>; - }; - - csu: csu@021c0000 { - compatible = "fsl,imx6ul-csu"; - reg = <0x021c0000 0x4000>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - csi: csi@021c4000 { - compatible = "fsl,imx6ul-csi", "fsl,imx6s-csi"; - reg = <0x021c4000 0x4000>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, - <&clks IMX6UL_CLK_CSI>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "disp-axi", "csi_mclk", "disp_dcic"; - status = "disabled"; - }; - - lcdif: lcdif@021c8000 { - compatible = "fsl,imx6ul-lcdif", "fsl,imx28-lcdif"; - reg = <0x021c8000 0x4000>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_LCDIF_PIX>, - <&clks IMX6UL_CLK_LCDIF_APB>, - <&clks IMX6UL_CLK_DUMMY>; - clock-names = "pix", "axi", "disp_axi"; - status = "disabled"; - }; - - pxp: pxp@021cc000 { - compatible = "fsl,imx6ull-pxp-dma", "fsl,imx7d-pxp-dma"; - reg = <0x021cc000 0x4000>; - interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_DUMMY>, <&clks IMX6UL_CLK_PXP>; - clock-names = "pxp_ipg", "pxp_axi"; - status = "disabled"; - }; - - qspi: qspi@021e0000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ull-qspi", "fsl,imx6ul-qspi"; - reg = <0x021e0000 0x4000>, <0x60000000 0x10000000>; - reg-names = "QuadSPI", "QuadSPI-memory"; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_QSPI>, - <&clks IMX6UL_CLK_QSPI>; - clock-names = "qspi_en", "qspi"; - status = "disabled"; - }; - - wdog3: wdog@021e4000 { - compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; - reg = <0x021e4000 0x4000>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_WDOG3>; - status = "disabled"; - }; - - uart2: serial@021e8000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x021e8000 0x4000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART2_IPG>, - <&clks IMX6UL_CLK_UART2_SERIAL>; - clock-names = "ipg", "per"; - dmas = <&sdma 27 4 0>, <&sdma 28 4 0>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart3: serial@021ec000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x021ec000 0x4000>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART3_IPG>, - <&clks IMX6UL_CLK_UART3_SERIAL>; - clock-names = "ipg", "per"; - dmas = <&sdma 29 4 0>, <&sdma 30 4 0>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart4: serial@021f0000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x021f0000 0x4000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART4_IPG>, - <&clks IMX6UL_CLK_UART4_SERIAL>; - clock-names = "ipg", "per"; - dmas = <&sdma 31 4 0>, <&sdma 32 4 0>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - uart5: serial@021f4000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x021f4000 0x4000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART5_IPG>, - <&clks IMX6UL_CLK_UART5_SERIAL>; - clock-names = "ipg", "per"; - dmas = <&sdma 33 4 0>, <&sdma 34 4 0>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - - i2c4: i2c@021f8000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c"; - reg = <0x021f8000 0x4000>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_I2C4>; - status = "disabled"; - }; - - uart6: serial@021fc000 { - compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; - reg = <0x021fc000 0x4000>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX6UL_CLK_UART6_IPG>, - <&clks IMX6UL_CLK_UART6_SERIAL>; - clock-names = "ipg", "per"; - dmas = <&sdma 0 4 0>, <&sdma 47 4 0>; - dma-names = "rx", "tx"; - status = "disabled"; - }; - }; - - aips3: aips-bus@02200000 { + aips3: aips-bus@2200000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02200000 0x100000>; ranges;
- dcp: dcp@02280000 { + dcp: crypto@2280000 { + compatible = "fsl,imx6ull-dcp", "fsl,imx28-dcp"; reg = <0x02280000 0x4000>; interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; - /*clocks = <&clks IMX6UL_CLK_DCP>;*/ + clocks = <&clks IMX6ULL_CLK_DCP_CLK>; clock-names = "dcp"; - status = "disabled"; };
- rngb: rngb@02284000 { - reg = <0x02284000 0x4000>; - interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + iomuxc_snvs: iomuxc-snvs@2290000 { + compatible = "fsl,imx6ull-iomuxc-snvs"; + reg = <0x02290000 0x4000>; };
- uart8: serial@02288000 { + uart8: serial@2288000 { compatible = "fsl,imx6ul-uart", - "fsl,imx6q-uart", "fsl,imx21-uart"; + "fsl,imx6q-uart"; reg = <0x02288000 0x4000>; interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_UART8_IPG>, <&clks IMX6UL_CLK_UART8_SERIAL>; clock-names = "ipg", "per"; - dmas = <&sdma 45 4 0>, <&sdma 46 4 0>; - dma-names = "rx", "tx"; status = "disabled"; }; - - epdc: epdc@0228c000 { - compatible = "fsl,imx7d-epdc"; - interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; - reg = <0x0228c000 0x4000>; - clocks = <&clks IMX6UL_CLK_EPDC_ACLK>, - <&clks IMX6UL_CLK_EPDC_PIX>; - clock-names = "epdc_axi", "epdc_pix"; - /* Need to fix epdc-ram */ - /* epdc-ram = <&gpr 0x4 30>; */ - status = "disabled"; - }; - - iomuxc_snvs: iomuxc-snvs@02290000 { - compatible = "fsl,imx6ull-iomuxc-snvs"; - reg = <0x02290000 0x10000>; - }; - - snvs_gpr: snvs-gpr@0x02294000 { - compatible = "fsl, imx6ull-snvs-gpr"; - reg = <0x02294000 0x10000>; - }; }; }; };
Import kernel dts for i.MX6ULZ from commit <0a8ad0ffa4d8> ("Merge tag 'for-linus-5.3-ofs1' of git://git.kernel.org/pub/scm/linux/kernel/git/hubcap/linux")
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 3 ++- arch/arm/dts/imx6ulz.dtsi | 37 +++++++++++++++++++++++++++++++++++++ 2 files changed, 39 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6ulz.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 39cf4c3b3d..2e942f70ad 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -594,7 +594,8 @@ dtb-$(CONFIG_MX6ULL) += \ imx6ull-14x14-evk.dtb \ imx6ull-colibri.dtb \ imx6ull-phycore-segin.dtb \ - imx6ull-dart-6ul.dtb + imx6ull-dart-6ul.dtb \ + imx6ulz-14x14-evk.dtb
dtb-$(CONFIG_ARCH_MX6) += \ imx6-apalis.dtb \ diff --git a/arch/arm/dts/imx6ulz.dtsi b/arch/arm/dts/imx6ulz.dtsi new file mode 100644 index 0000000000..aeb2ddc540 --- /dev/null +++ b/arch/arm/dts/imx6ulz.dtsi @@ -0,0 +1,37 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// +// Copyright 2018 NXP. + +#include "imx6ull.dtsi" + +/ { + aliases { + /delete-property/ ethernet0; + /delete-property/ ethernet1; + /delete-property/ i2c2; + /delete-property/ i2c3; + /delete-property/ serial4; + /delete-property/ serial5; + /delete-property/ serial6; + /delete-property/ serial7; + /delete-property/ spi2; + /delete-property/ spi3; + /delete-property/ spi4; + }; +}; + +/delete-node/ &adc1; +/delete-node/ &ecspi3; +/delete-node/ &ecspi4; +/delete-node/ &epit2; +/delete-node/ &gpt2; +/delete-node/ &i2c3; +/delete-node/ &i2c4; +/delete-node/ &pwm5; +/delete-node/ &pwm6; +/delete-node/ &pwm7; +/delete-node/ &pwm8; +/delete-node/ &uart5; +/delete-node/ &uart6; +/delete-node/ &uart7; +/delete-node/ &uart8;
Add i.MX6ULZ cpu type and helper.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx/cpu.h | 1 + arch/arm/include/asm/mach-imx/sys_proto.h | 1 + arch/arm/mach-imx/cpu.c | 2 ++ arch/arm/mach-imx/mx6/soc.c | 4 ++++ 4 files changed, 8 insertions(+)
diff --git a/arch/arm/include/asm/arch-imx/cpu.h b/arch/arm/include/asm/arch-imx/cpu.h index d4a83eef72..073efcd1b4 100644 --- a/arch/arm/include/asm/arch-imx/cpu.h +++ b/arch/arm/include/asm/arch-imx/cpu.h @@ -17,6 +17,7 @@ #define MXC_CPU_MX6Q 0x63 #define MXC_CPU_MX6UL 0x64 #define MXC_CPU_MX6ULL 0x65 +#define MXC_CPU_MX6ULZ 0x6B #define MXC_CPU_MX6SOLO 0x66 /* dummy */ #define MXC_CPU_MX6SLL 0x67 #define MXC_CPU_MX6D 0x6A diff --git a/arch/arm/include/asm/mach-imx/sys_proto.h b/arch/arm/include/asm/mach-imx/sys_proto.h index 4925dd7894..260608062e 100644 --- a/arch/arm/include/asm/mach-imx/sys_proto.h +++ b/arch/arm/include/asm/mach-imx/sys_proto.h @@ -38,6 +38,7 @@ #define is_mx6solo() (is_cpu_type(MXC_CPU_MX6SOLO)) #define is_mx6ul() (is_cpu_type(MXC_CPU_MX6UL)) #define is_mx6ull() (is_cpu_type(MXC_CPU_MX6ULL)) +#define is_mx6ulz() (is_cpu_type(MXC_CPU_MX6ULZ)) #define is_mx6sll() (is_cpu_type(MXC_CPU_MX6SLL))
#define is_mx7ulp() (is_cpu_type(MXC_CPU_MX7ULP)) diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index 3a8cf30c06..21d31ae65e 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -173,6 +173,8 @@ const char *get_imx_type(u32 imxtype) return "6UL"; /* Ultra-Lite version of the mx6 */ case MXC_CPU_MX6ULL: return "6ULL"; /* ULL version of the mx6 */ + case MXC_CPU_MX6ULZ: + return "6ULZ"; /* ULZ version of the mx6 */ case MXC_CPU_MX51: return "51"; case MXC_CPU_MX53: diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index e80f1d484b..e6a5bf4b40 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -85,6 +85,10 @@ u32 get_cpu_rev(void) type = MXC_CPU_MX6D; }
+ if (type == MXC_CPU_MX6ULL) { + if (readl(SRC_BASE_ADDR + 0x1c) & (1 << 6)) + type = MXC_CPU_MX6ULZ; + } } major = ((reg >> 8) & 0xff); if ((major >= 1) &&
Add i.MX6ULZ board support. the i.MX6ULZ is SW compatible with i.MX6ULL. so most code of i.MX6ULL can be reused by i.MX6ULZ.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx6ulz-14x14-evk.dts | 22 ++++++++++++++++++ board/freescale/mx6ullevk/mx6ullevk.c | 10 ++++++-- configs/mx6ulz_14x14_evk_defconfig | 44 +++++++++++++++++++++++++++++++++++ include/configs/mx6ullevk.h | 13 ++++++++++- 4 files changed, 86 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/imx6ulz-14x14-evk.dts create mode 100644 configs/mx6ulz_14x14_evk_defconfig
diff --git a/arch/arm/dts/imx6ulz-14x14-evk.dts b/arch/arm/dts/imx6ulz-14x14-evk.dts new file mode 100644 index 0000000000..483d9732c0 --- /dev/null +++ b/arch/arm/dts/imx6ulz-14x14-evk.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +// +// Copyright 2018 NXP. + +/dts-v1/; + +#include "imx6ulz.dtsi" +#include "imx6ul-14x14-evk.dtsi" + +/delete-node/ &fec1; +/delete-node/ &fec2; +/delete-node/ &can1; +/delete-node/ &can2; +/delete-node/ &lcdif; +/delete-node/ &tsc; + +/ { + model = "Freescale i.MX6 ULZ 14x14 EVK Board"; + compatible = "fsl,imx6ulz-14x14-evk", "fsl,imx6ull", "fsl,imx6ulz"; + + /delete-node/ panel; +}; diff --git a/board/freescale/mx6ullevk/mx6ullevk.c b/board/freescale/mx6ullevk/mx6ullevk.c index 1f0f70efbd..0a35eeb95e 100644 --- a/board/freescale/mx6ullevk/mx6ullevk.c +++ b/board/freescale/mx6ullevk/mx6ullevk.c @@ -83,7 +83,10 @@ int board_late_init(void) #endif
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG - env_set("board_name", "EVK"); + if (is_cpu_type(MXC_CPU_MX6ULZ)) + env_set("board_name", "ULZ-EVK"); + else + env_set("board_name", "EVK"); env_set("board_rev", "14X14"); #endif
@@ -92,7 +95,10 @@ int board_late_init(void)
int checkboard(void) { - puts("Board: MX6ULL 14x14 EVK\n"); + if (is_cpu_type(MXC_CPU_MX6ULZ)) + puts("Board: MX6ULZ 14x14 EVK\n"); + else + puts("Board: MX6ULL 14x14 EVK\n");
return 0; } diff --git a/configs/mx6ulz_14x14_evk_defconfig b/configs/mx6ulz_14x14_evk_defconfig new file mode 100644 index 0000000000..f647d72c6e --- /dev/null +++ b/configs/mx6ulz_14x14_evk_defconfig @@ -0,0 +1,44 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SYS_TEXT_BASE=0x87800000 +CONFIG_TARGET_MX6ULL_14X14_EVK=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6ullevk/imximage.cfg" +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_BOUNCE_BUFFER=y +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6ulz-14x14-evk" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM_GPIO=y +CONFIG_DM_74X164=y +CONFIG_DM_I2C=y +CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC_IMX=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_SF_DEFAULT_SPEED=40000000 +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y +CONFIG_DM_REGULATOR=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 1fc5c24dec..f5f3de6cd4 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -55,7 +55,7 @@ "console=ttymxc0\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "fdt_file=imx6ull-14x14-evk.dtb\0" \ + "fdt_file=undefined\0" \ "fdt_addr=0x83000000\0" \ "boot_fdt=try\0" \ "ip_dyn=yes\0" \ @@ -87,6 +87,16 @@ "else " \ "bootz; " \ "fi;\0" \ + "findfdt="\ + "if test $fdt_file = undefined; then " \ + "if test $board_name = ULZ-EVK && test $board_rev = 14X14; then " \ + "setenv fdt_file imx6ulz-14x14-evk.dtb; fi; " \ + "if test $board_name = EVK && test $board_rev = 14X14; then " \ + "setenv fdt_file imx6ull-14x14-evk.dtb; fi; " \ + "if test $fdt_file = undefined; then " \ + "echo WARNING: Could not determine dtb to use; " \ + "fi; " \ + "fi;\0" \ "netargs=setenv bootargs console=${console},${baudrate} " \ "root=/dev/nfs " \ "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ @@ -113,6 +123,7 @@ "fi;\0" \
#define CONFIG_BOOTCOMMAND \ + "run findfdt;" \ "mmc dev ${mmcdev};" \ "mmc dev ${mmcdev}; if mmc rescan; then " \ "if run loadbootscript; then " \
Subject: [PATCH 1/5] arm: dts: sync dts for i.MX6UL
Ping..
Thanks, Peng.
Sync kernel dts for i.MX6UL from commit <0a8ad0ffa4d8> ("Merge tag 'for-linus-5.3-ofs1' of git://git.kernel.org/pub/scm/linux/kernel/git/hubcap/linux")
arch/arm/dts/imx6ul-14x14-evk.dts | 422 +----------------------- arch/arm/dts/imx6ul-14x14-evk.dtsi | 531 +++++++++++++++++++++++++++++++ arch/arm/dts/imx6ul-pinfunc.h | 175 +++++----- arch/arm/dts/imx6ul.dtsi | 301 ++++++++++++------ include/dt-bindings/clock/imx6ul-clock.h | 50 +-- 5 files changed, 863 insertions(+), 616 deletions(-) create mode 100644 arch/arm/dts/imx6ul-14x14-evk.dtsi
diff --git a/arch/arm/dts/imx6ul-14x14-evk.dts b/arch/arm/dts/imx6ul-14x14-evk.dts index a642d77654..2438669f14 100644 --- a/arch/arm/dts/imx6ul-14x14-evk.dts +++ b/arch/arm/dts/imx6ul-14x14-evk.dts @@ -1,427 +1,13 @@ -// SPDX-License-Identifier: GPL-2.0+ -/*
- Copyright (C) 2015 Freescale Semiconductor, Inc.
- Copyright 2017-2018 NXP
+// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2015 Freescale Semiconductor, Inc.
/dts-v1/;
#include "imx6ul.dtsi" +#include "imx6ul-14x14-evk.dtsi"
/ { model = "Freescale i.MX6 UltraLite 14x14 EVK Board"; compatible = "fsl,imx6ul-14x14-evk", "fsl,imx6ul";
- aliases {
spi5 = &soft_spi;
- chosen {
stdout-path = &uart1;
- memory {
reg = <0x80000000 0x20000000>;
- regulators {
#size-cells = <0>;
reg_sd1_vmmc: regulator@1 {
compatible = "regulator-fixed";
regulator-name = "VSD_3V3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
gpio = <&gpio1 9 GPIO_ACTIVE_HIGH>;
off-on-delay = <20000>;
enable-active-high;
reg_can_3v3: regulator@0 {
reg = <0>;
regulator-name = "can-3v3";
gpios = <&gpio_spi 3 GPIO_ACTIVE_LOW>;
reg_gpio_dvfs: regulator-gpio {
compatible = "regulator-gpio";
pinctrl-0 = <&pinctrl_dvfs>;
regulator-min-microvolt = <1300000>;
regulator-max-microvolt = <1400000>;
regulator-name = "gpio_dvfs";
regulator-type = "voltage";
gpios = <&gpio5 3 GPIO_ACTIVE_HIGH>;
states = <1300000 0x1 1400000 0x0>;
- soft_spi: soft-spi {
compatible = "spi-gpio";
pinctrl-0 = <&pinctrl_spi4>;
pinctrl-assert-gpios = <&gpio5 8 GPIO_ACTIVE_LOW>;
status = "okay";
gpio-sck = <&gpio5 11 0>;
gpio-mosi = <&gpio5 10 0>;
cs-gpios = <&gpio5 7 0>;
num-chipselects = <1>;
#size-cells = <0>;
gpio_spi: gpio_spi@0 {
compatible = "fairchild,74hc595";
gpio-controller;
#gpio-cells = <2>;
reg = <0>;
registers-number = <1>;
registers-default = /bits/ 8 <0x57>;
spi-max-frequency = <100000>;
-&fec1 {
- pinctrl-0 = <&pinctrl_enet1>;
- phy-mode = "rmii";
- phy-handle = <ðphy0>;
- status = "okay";
-&fec2 {
- pinctrl-0 = <&pinctrl_enet2>;
- phy-handle = <ðphy1>;
- status = "okay";
- mdio {
#size-cells = <0>;
ethphy0: ethernet-phy@2 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <2>;
ethphy1: ethernet-phy@1 {
reg = <1>;
-&i2c1 {
- clock-frequency = <100000>;
- pinctrl-names = "default", "gpio";
- pinctrl-0 = <&pinctrl_i2c1>;
- pinctrl-1 = <&pinctrl_i2c1_gpio>;
- scl-gpios = <&gpio1 28 GPIO_ACTIVE_HIGH>;
- sda-gpios = <&gpio1 29 GPIO_ACTIVE_HIGH>;
- status = "okay";
- mag3110@0e {
compatible = "fsl,mag3110";
reg = <0x0e>;
position = <2>;
- fxls8471@1e {
compatible = "fsl,fxls8471";
reg = <0x1e>;
position = <0>;
interrupt-parent = <&gpio5>;
interrupts = <0 8>;
-&i2c2 {
- clock_frequency = <100000>;
- pinctrl-0 = <&pinctrl_i2c2>;
- pinctrl-1 = <&pinctrl_i2c2_gpio>;
- scl-gpios = <&gpio1 30 GPIO_ACTIVE_HIGH>;
- sda-gpios = <&gpio1 31 GPIO_ACTIVE_HIGH>;
- status = "okay";
-&iomuxc {
- pinctrl-0 = <&pinctrl_hog_1>;
- imx6ul-evk {
pinctrl_hog_1: hoggrp-1 {
fsl,pins = <
MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x17059 /*
SD1 CD */
MX6UL_PAD_GPIO1_IO05__USDHC1_VSELECT 0x17059
/* SD1 VSELECT */
MX6UL_PAD_GPIO1_IO09__GPIO1_IO09
0x17059 /* SD1 RESET */
0x80000000MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00
fsl,pins = <
MX6UL_PAD_SNVS_TAMPER3__GPIO5_IO03 0x79
pinctrl_enet1: enet1grp {
fsl,pins = <
MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x1b0b0
MX6UL_PAD_ENET1_RX_ER__ENET1_RX_ER 0x1b0b0
0x1b0b0MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00
0x1b0b0MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01
MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x1b0b0
0x1b0b0MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00
0x1b0b0MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01
0x4001b031MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1
pinctrl_enet2: enet2grp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0
MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0
MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0
MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0
0x1b0b0MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00
0x1b0b0MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01
MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0
0x1b0b0MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00
0x1b0b0MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01
0x4001b031MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2
pinctrl_i2c1: i2c1grp {
fsl,pins = <
MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x4001b8b0
MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x4001b8b0
pinctrl_i2c1_gpio: i2c1grp_gpio {
fsl,pins = <
MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x1b8b0
MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x1b8b0
pinctrl_i2c2: i2c2grp {
fsl,pins = <
MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x4001b8b0
MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x4001b8b0
pinctrl_i2c2_gpio: i2c2grp_gpio {
fsl,pins = <
MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30 0x1b8b0
MX6UL_PAD_UART5_RX_DATA__GPIO1_IO31 0x1b8b0
pinctrl_qspi: qspigrp {
fsl,pins = <
MX6UL_PAD_NAND_WP_B__QSPI_A_SCLK 0x70a1
MX6UL_PAD_NAND_READY_B__QSPI_A_DATA00 0x70a1
MX6UL_PAD_NAND_CE0_B__QSPI_A_DATA01 0x70a1
MX6UL_PAD_NAND_CE1_B__QSPI_A_DATA02 0x70a1
MX6UL_PAD_NAND_CLE__QSPI_A_DATA03 0x70a1
MX6UL_PAD_NAND_DQS__QSPI_A_SS0_B 0x70a1
fsl,pins = <
MX6UL_PAD_BOOT_MODE0__GPIO5_IO10 0x70a1
MX6UL_PAD_BOOT_MODE1__GPIO5_IO11 0x70a1
MX6UL_PAD_SNVS_TAMPER7__GPIO5_IO07 0x70a1
0x80000000MX6UL_PAD_SNVS_TAMPER8__GPIO5_IO08
pinctrl_uart1: uart1grp {
fsl,pins = <
MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1
MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX
0x1b0b1
pinctrl_usb_otg1_id: usbotg1idgrp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO00__ANATOP_OTG1_ID
0x17059
pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059
MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10071
MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059
MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059
MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059
MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059
pinctrl_usdhc1_100mhz: usdhc1grp100mhz {
fsl,pins = <
MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x170b9
MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x100b9
MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170b9
MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170b9
MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170b9
MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170b9
pinctrl_usdhc1_200mhz: usdhc1grp200mhz {
fsl,pins = <
MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x170f9
MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x100f9
MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x170f9
MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x170f9
MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x170f9
MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x170f9
pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x10069
MX6UL_PAD_NAND_WE_B__USDHC2_CMD
0x17059
MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059
MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059
MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059
MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059
pinctrl_usdhc2_8bit: usdhc2grp_8bit {
fsl,pins = <
0x17059
MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x17059
MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x17059
MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x17059
MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x17059
pinctrl_usdhc2_8bit_100mhz: usdhc2grp_8bit_100mhz {
fsl,pins = <
MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x100b9
0x170b9
MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x170b9
MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x170b9
MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x170b9
MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x170b9
MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x170b9
MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x170b9
MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x170b9
MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x170b9
pinctrl_usdhc2_8bit_200mhz: usdhc2grp_8bit_200mhz {
fsl,pins = <
MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x100f9
0x170f9
MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x170f9
MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x170f9
MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x170f9
MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x170f9
MX6UL_PAD_NAND_DATA04__USDHC2_DATA4 0x170f9
MX6UL_PAD_NAND_DATA05__USDHC2_DATA5 0x170f9
MX6UL_PAD_NAND_DATA06__USDHC2_DATA6 0x170f9
MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x170f9
pinctrl_wdog: wdoggrp {
fsl,pins = <
MX6UL_PAD_LCD_RESET__WDOG1_WDOG_ANY
0x30b0
-&qspi {
- pinctrl-0 = <&pinctrl_qspi>;
- status = "okay";
- ddrsmp=<0>;
- flash0: n25q256a@0 {
#size-cells = <1>;
compatible = "micron,n25q256a";
spi-max-frequency = <29000000>;
spi-nor,ddr-quad-read-dummy = <6>;
reg = <0>;
-&uart1 {
- pinctrl-0 = <&pinctrl_uart1>;
- status = "okay";
-&usbotg1 {
- pinctrl-0 = <&pinctrl_usb_otg1_id>;
- dr_mode = "otg";
- srp-disable;
- hnp-disable;
- adp-disable;
- status = "okay";
-&usbotg2 {
- dr_mode = "host";
- disable-over-current;
- status = "okay";
-&usbphy1 {
- tx-d-cal = <0x5>;
-&usbphy2 {
- tx-d-cal = <0x5>;
-&usdhc1 {
- pinctrl-names = "default", "state_100mhz", "state_200mhz";
- pinctrl-0 = <&pinctrl_usdhc1>;
- pinctrl-1 = <&pinctrl_usdhc1_100mhz>;
- pinctrl-2 = <&pinctrl_usdhc1_200mhz>;
- cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>;
- keep-power-in-suspend;
- wakeup-source;
- vmmc-supply = <®_sd1_vmmc>;
- status = "okay";
-&usdhc2 {
- pinctrl-names = "default";
- pinctrl-0 = <&pinctrl_usdhc2>;
- non-removable;
- status = "okay";
-&wdog1 {
- pinctrl-0 = <&pinctrl_wdog>;
- fsl,ext-reset-output;
}; diff --git a/arch/arm/dts/imx6ul-14x14-evk.dtsi b/arch/arm/dts/imx6ul-14x14-evk.dtsi new file mode 100644 index 0000000000..d1baf0f081 --- /dev/null +++ b/arch/arm/dts/imx6ul-14x14-evk.dtsi @@ -0,0 +1,531 @@ +// SPDX-License-Identifier: GPL-2.0 +// +// Copyright (C) 2015 Freescale Semiconductor, Inc.
- aliases {
spi5 = &{/spi4};
- chosen {
- memory@80000000 {
device_type = "memory";
- backlight_display: backlight-display {
compatible = "pwm-backlight";
pwms = <&pwm1 0 5000000>;
brightness-levels = <0 4 8 16 32 64 128 255>;
default-brightness-level = <6>;
status = "okay";
- reg_sd1_vmmc: regulator-sd1-vmmc {
enable-active-high;
- reg_can_3v3: regulator-can-3v3 {
- spi4 {
status = "okay";
#size-cells = <0>;
gpio_spi: gpio@0 {
gpio-controller;
#gpio-cells = <2>;
reg = <0>;
- panel {
compatible = "innolux,at043tn24";
backlight = <&backlight_display>;
port {
panel_in: endpoint {
remote-endpoint = <&display_out>;
+&clks {
- assigned-clocks = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;
- assigned-clock-rates = <786432000>;
+&i2c2 {
- status = "okay";
- codec: wm8960@1a {
#sound-dai-cells = <0>;
compatible = "wlf,wm8960";
reg = <0x1a>;
wlf,shared-lrclk;
+&fec1 {
- status = "okay";
+&fec2 {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <2>;
micrel,led-mode = <1>;
clocks = <&clks IMX6UL_CLK_ENET_REF>;
clock-names = "rmii-ref";
reg = <1>;
clocks = <&clks IMX6UL_CLK_ENET2_REF>;
+&can1 {
- pinctrl-0 = <&pinctrl_flexcan1>;
- xceiver-supply = <®_can_3v3>;
- status = "okay";
+&can2 {
- pinctrl-0 = <&pinctrl_flexcan2>;
- status = "okay";
+&i2c1 {
- status = "okay";
- mag3110@e {
reg = <0x0e>;
+&lcdif {
- assigned-clocks = <&clks IMX6UL_CLK_LCDIF_PRE_SEL>;
- assigned-clock-parents = <&clks IMX6UL_CLK_PLL5_VIDEO_DIV>;
- pinctrl-0 = <&pinctrl_lcdif_dat
&pinctrl_lcdif_ctrl>;
- status = "okay";
- port {
display_out: endpoint {
remote-endpoint = <&panel_in>;
+&pwm1 {
- pinctrl-0 = <&pinctrl_pwm1>;
- status = "okay";
+&qspi {
- status = "okay";
#size-cells = <1>;
spi-rx-bus-width = <4>;
spi-tx-bus-width = <4>;
reg = <0>;
+&sai2 {
- pinctrl-0 = <&pinctrl_sai2>;
- assigned-clocks = <&clks IMX6UL_CLK_SAI2_SEL>,
<&clks IMX6UL_CLK_SAI2>;
- assigned-clock-parents = <&clks IMX6UL_CLK_PLL4_AUDIO_DIV>;
- assigned-clock-rates = <0>, <12288000>;
- fsl,sai-mclk-direction-output;
- status = "okay";
+&snvs_poweroff {
- status = "okay";
+&tsc {
- pinctrl-0 = <&pinctrl_tsc>;
- xnur-gpio = <&gpio1 3 GPIO_ACTIVE_LOW>;
- measure-delay-time = <0xffff>;
- pre-charge-time = <0xfff>;
- status = "okay";
+&uart1 {
- status = "okay";
+&uart2 {
- pinctrl-0 = <&pinctrl_uart2>;
- uart-has-rtscts;
- status = "okay";
+&usbotg1 {
- dr_mode = "otg";
- status = "okay";
+&usbotg2 {
- dr_mode = "host";
- status = "okay";
+&usbphy1 {
- fsl,tx-d-cal = <106>;
+&usbphy2 {
+&usdhc1 {
- wakeup-source;
- status = "okay";
+&usdhc2 {
- no-1-8-v;
- wakeup-source;
- status = "okay";
+&wdog1 {
+&iomuxc {
- pinctrl_csi1: csi1grp {
fsl,pins = <
MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088
MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088
MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088
MX6UL_PAD_CSI_HSYNC__CSI_HSYNC 0x1b088
MX6UL_PAD_CSI_DATA00__CSI_DATA02 0x1b088
MX6UL_PAD_CSI_DATA01__CSI_DATA03 0x1b088
MX6UL_PAD_CSI_DATA02__CSI_DATA04 0x1b088
MX6UL_PAD_CSI_DATA03__CSI_DATA05 0x1b088
MX6UL_PAD_CSI_DATA04__CSI_DATA06 0x1b088
MX6UL_PAD_CSI_DATA05__CSI_DATA07 0x1b088
MX6UL_PAD_CSI_DATA06__CSI_DATA08 0x1b088
MX6UL_PAD_CSI_DATA07__CSI_DATA09 0x1b088
- pinctrl_enet1: enet1grp {
fsl,pins = <
MX6UL_PAD_ENET1_RX_DATA0__ENET1_RDATA00 0x1b0b0
MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x1b0b0
MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x1b0b0
MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x1b0b0
- pinctrl_enet2: enet2grp {
fsl,pins = <
MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0
MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0
MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0
MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0
- pinctrl_flexcan1: flexcan1grp{
fsl,pins = <
MX6UL_PAD_UART3_RTS_B__FLEXCAN1_RX 0x1b020
MX6UL_PAD_UART3_CTS_B__FLEXCAN1_TX 0x1b020
- pinctrl_flexcan2: flexcan2grp{
fsl,pins = <
MX6UL_PAD_UART2_RTS_B__FLEXCAN2_RX 0x1b020
MX6UL_PAD_UART2_CTS_B__FLEXCAN2_TX 0x1b020
- pinctrl_i2c1: i2c1grp {
fsl,pins = <
- pinctrl_i2c1_gpio: i2c1grp_gpio {
fsl,pins = <
- pinctrl_i2c2: i2c2grp {
fsl,pins = <
- pinctrl_lcdif_dat: lcdifdatgrp {
fsl,pins = <
MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x79
MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x79
MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x79
MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x79
MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x79
MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x79
MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x79
MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x79
MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x79
MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x79
MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x79
MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x79
MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x79
MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x79
MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x79
MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x79
MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x79
MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x79
MX6UL_PAD_LCD_DATA18__LCDIF_DATA18 0x79
MX6UL_PAD_LCD_DATA19__LCDIF_DATA19 0x79
MX6UL_PAD_LCD_DATA20__LCDIF_DATA20 0x79
MX6UL_PAD_LCD_DATA21__LCDIF_DATA21 0x79
MX6UL_PAD_LCD_DATA22__LCDIF_DATA22 0x79
MX6UL_PAD_LCD_DATA23__LCDIF_DATA23 0x79
- pinctrl_lcdif_ctrl: lcdifctrlgrp {
fsl,pins = <
MX6UL_PAD_LCD_CLK__LCDIF_CLK 0x79
MX6UL_PAD_LCD_ENABLE__LCDIF_ENABLE 0x79
MX6UL_PAD_LCD_HSYNC__LCDIF_HSYNC 0x79
MX6UL_PAD_LCD_VSYNC__LCDIF_VSYNC 0x79
/* used for lcd reset */
MX6UL_PAD_SNVS_TAMPER9__GPIO5_IO09 0x79
- pinctrl_qspi: qspigrp {
fsl,pins = <
- pinctrl_sai2: sai2grp {
fsl,pins = <
MX6UL_PAD_JTAG_TDI__SAI2_TX_BCLK 0x17088
MX6UL_PAD_JTAG_TDO__SAI2_TX_SYNC 0x17088
MX6UL_PAD_JTAG_TRST_B__SAI2_TX_DATA 0x11088
MX6UL_PAD_JTAG_TCK__SAI2_RX_DATA 0x11088
MX6UL_PAD_JTAG_TMS__SAI2_MCLK 0x17088
MX6UL_PAD_SNVS_TAMPER4__GPIO5_IO04 0x17059
- pinctrl_pwm1: pwm1grp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO08__PWM1_OUT 0x110b0
- pinctrl_sim2: sim2grp {
fsl,pins = <
MX6UL_PAD_CSI_DATA03__SIM2_PORT1_PD 0xb808
MX6UL_PAD_CSI_DATA04__SIM2_PORT1_CLK 0x31
0xb808MX6UL_PAD_CSI_DATA05__SIM2_PORT1_RST_B
MX6UL_PAD_CSI_DATA06__SIM2_PORT1_SVEN 0xb808
MX6UL_PAD_CSI_DATA07__SIM2_PORT1_TRXD 0xb809
MX6UL_PAD_CSI_DATA02__GPIO4_IO23 0x3008
- pinctrl_spi4: spi4grp {
fsl,pins = <
MX6UL_PAD_SNVS_TAMPER8__GPIO5_IO08 0x80000000
- pinctrl_tsc: tscgrp {
fsl,pins = <
MX6UL_PAD_GPIO1_IO01__GPIO1_IO01 0xb0
MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0xb0
MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0xb0
MX6UL_PAD_GPIO1_IO04__GPIO1_IO04 0xb0
- pinctrl_uart1: uart1grp {
fsl,pins = <
MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1
- pinctrl_uart2: uart2grp {
fsl,pins = <
MX6UL_PAD_UART2_TX_DATA__UART2_DCE_TX 0x1b0b1
MX6UL_PAD_UART2_RX_DATA__UART2_DCE_RX 0x1b0b1
MX6UL_PAD_UART3_RX_DATA__UART2_DCE_RTS 0x1b0b1
MX6UL_PAD_UART3_TX_DATA__UART2_DCE_CTS 0x1b0b1
- pinctrl_usdhc1: usdhc1grp {
fsl,pins = <
MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10059
/* SD1 CD */
/* SD1 VSELECT */
MX6UL_PAD_GPIO1_IO09__GPIO1_IO09 0x17059 /*
SD1 RESET */
- pinctrl_usdhc1_100mhz: usdhc1grp100mhz {
fsl,pins = <
- pinctrl_usdhc1_200mhz: usdhc1grp200mhz {
fsl,pins = <
- pinctrl_usdhc2: usdhc2grp {
fsl,pins = <
MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x17059
MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059
- pinctrl_wdog: wdoggrp {
fsl,pins = <
MX6UL_PAD_LCD_RESET__WDOG1_WDOG_ANY 0x30b0
+}; diff --git a/arch/arm/dts/imx6ul-pinfunc.h b/arch/arm/dts/imx6ul-pinfunc.h index 0034eeb845..380d2db13a 100644 --- a/arch/arm/dts/imx6ul-pinfunc.h +++ b/arch/arm/dts/imx6ul-pinfunc.h @@ -1,10 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /*
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- Copyright 2014 - 2015 Freescale Semiconductor, Inc.
#ifndef __DTS_IMX6UL_PINFUNC_H @@ -34,14 +30,14 @@ #define MX6UL_PAD_JTAG_MOD__ENET1_REF_CLK_25M 0x0044 0x02d0 0x0000 3 0 #define MX6UL_PAD_JTAG_MOD__CCM_PMIC_RDY 0x0044 0x02d0 0x04c0 4 0 #define MX6UL_PAD_JTAG_MOD__GPIO1_IO10 0x0044 0x02d0 0x0000 5 0 -#define MX6UL_PAD_JTAG_MOD__SDMA_EXT_EVENT00 0x0044 0x02d0 0x0000 6 0 +#define MX6UL_PAD_JTAG_MOD__SDMA_EXT_EVENT00 0x0044 0x02d0 0x0610 6 0 #define MX6UL_PAD_JTAG_TMS__SJC_TMS 0x0048 0x02d4 0x0000 0 0 #define MX6UL_PAD_JTAG_TMS__GPT2_CAPTURE1 0x0048 0x02d4 0x0598 1 0 -#define MX6UL_PAD_JTAG_TMS__SAI2_MCLK 0x0048 0x02d4 0x0000 2 0 +#define MX6UL_PAD_JTAG_TMS__SAI2_MCLK 0x0048 0x02d4 0x05f0 2 0 #define MX6UL_PAD_JTAG_TMS__CCM_CLKO1 0x0048 0x02d4 0x0000 3 0 #define MX6UL_PAD_JTAG_TMS__CCM_WAIT 0x0048 0x02d4 0x0000 4 0 #define MX6UL_PAD_JTAG_TMS__GPIO1_IO11 0x0048 0x02d4 0x0000 5 0 -#define MX6UL_PAD_JTAG_TMS__SDMA_EXT_EVENT01 0x0048 0x02d4 0x0000 6 0 +#define MX6UL_PAD_JTAG_TMS__SDMA_EXT_EVENT01 0x0048 0x02d4 0x0614 6 0 #define MX6UL_PAD_JTAG_TMS__EPIT1_OUT 0x0048 0x02d4 0x0000 8 0 #define MX6UL_PAD_JTAG_TDO__SJC_TDO 0x004c 0x02d8 0x0000 0 0 #define MX6UL_PAD_JTAG_TDO__GPT2_CAPTURE2 0x004c 0x02d8 0x059c 1 0 @@ -63,12 +59,14 @@ #define MX6UL_PAD_JTAG_TCK__SAI2_RX_DATA 0x0054 0x02e0 0x05f4 2 0 #define MX6UL_PAD_JTAG_TCK__PWM7_OUT 0x0054 0x02e0 0x0000 4 0 #define MX6UL_PAD_JTAG_TCK__GPIO1_IO14 0x0054 0x02e0 0x0000 5 0 +#define MX6UL_PAD_JTAG_TCK__OSC32K_32K_OUT 0x0054 0x02e0 0x0000 6 0 #define MX6UL_PAD_JTAG_TCK__SIM2_POWER_FAIL 0x0054 0x02e0 0x0000 8 0 #define MX6UL_PAD_JTAG_TRST_B__SJC_TRSTB 0x0058 0x02e4 0x0000 0 0 #define MX6UL_PAD_JTAG_TRST_B__GPT2_COMPARE3 0x0058 0x02e4 0x0000 1 0 #define MX6UL_PAD_JTAG_TRST_B__SAI2_TX_DATA 0x0058 0x02e4 0x0000 2 0 #define MX6UL_PAD_JTAG_TRST_B__PWM8_OUT 0x0058 0x02e4 0x0000 4 0 #define MX6UL_PAD_JTAG_TRST_B__GPIO1_IO15 0x0058 0x02e4 0x0000 5 0 +#define MX6UL_PAD_JTAG_TRST_B__REF_CLK_24M 0x0058 0x02e4 0x0000 6 0 #define MX6UL_PAD_JTAG_TRST_B__CAAM_RNG_OSC_OBS 0x0058 0x02e4 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO00__I2C2_SCL 0x005c 0x02e8 0x05ac 0 1 #define MX6UL_PAD_GPIO1_IO00__GPT1_CAPTURE1 0x005c 0x02e8 0x058c 1 0 @@ -94,22 +92,24 @@ #define MX6UL_PAD_GPIO1_IO02__ENET1_REF_CLK_25M 0x0064 0x02f0 0x0000 3 0 #define MX6UL_PAD_GPIO1_IO02__USDHC1_WP 0x0064 0x02f0 0x066c 4 0 #define MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0x0064 0x02f0 0x0000 5 0 -#define MX6UL_PAD_GPIO1_IO02__SDMA_EXT_EVENT00 0x0064 0x02f0 0x0000 6 0 +#define MX6UL_PAD_GPIO1_IO02__SDMA_EXT_EVENT00 0x0064 0x02f0 0x0610 6 1 #define MX6UL_PAD_GPIO1_IO02__SRC_ANY_PU_RESET 0x0064 0x02f0 0x0000 7 0 #define MX6UL_PAD_GPIO1_IO02__UART1_DCE_TX 0x0064 0x02f0 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO02__UART1_DTE_RX 0x0064 0x02f0 0x0624 8 0 #define MX6UL_PAD_GPIO1_IO03__I2C1_SDA 0x0068 0x02f4 0x05a8 0 1 #define MX6UL_PAD_GPIO1_IO03__GPT1_COMPARE3 0x0068 0x02f4 0x0000 1 0 #define MX6UL_PAD_GPIO1_IO03__USB_OTG2_OC 0x0068 0x02f4 0x0660 2 0 +#define MX6UL_PAD_GPIO1_IO03__OSC32K_32K_OUT 0x0068 0x02f4 0x0000 3 0 #define MX6UL_PAD_GPIO1_IO03__USDHC1_CD_B 0x0068 0x02f4 0x0668 4 0 #define MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0x0068 0x02f4 0x0000 5 0 -#define MX6UL_PAD_GPIO1_IO03__CCM_DI0_eXT_CLK 0x0068 0x02f4 0x0000 6 0 +#define MX6UL_PAD_GPIO1_IO03__CCM_DI0_EXT_CLK 0x0068 0x02f4 0x0000 6 0 #define MX6UL_PAD_GPIO1_IO03__SRC_TESTER_ACK 0x0068 0x02f4 0x0000 7 0 -#define MX6UL_PAD_GPIO1_IO03__UART1_DTE_TX 0x0068 0x02f4 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO03__UART1_DCE_RX 0x0068 0x02f4 0x0624 8 1 +#define MX6UL_PAD_GPIO1_IO03__UART1_DTE_TX 0x0068 0x02f4 0x0000 8 0 #define MX6UL_PAD_GPIO1_IO04__ENET1_REF_CLK1 0x006c 0x02f8 0x0574 0 1 #define MX6UL_PAD_GPIO1_IO04__PWM3_OUT 0x006c 0x02f8 0x0000 1 0 #define MX6UL_PAD_GPIO1_IO04__USB_OTG1_PWR 0x006c 0x02f8 0x0000 2 0 +#define MX6UL_PAD_GPIO1_IO04__REF_CLK_24M 0x006c 0x02f8 0x0000 3 0 #define MX6UL_PAD_GPIO1_IO04__USDHC1_RESET_B 0x006c 0x02f8 0x0000 4 0 #define MX6UL_PAD_GPIO1_IO04__GPIO1_IO04 0x006c 0x02f8 0x0000 5 0 #define MX6UL_PAD_GPIO1_IO04__ENET2_1588_EVENT0_IN 0x006c 0x02f8 0x0000 6 0 @@ -200,7 +200,7 @@ #define MX6UL_PAD_UART2_TX_DATA__CSI_DATA06 0x0094 0x0320 0x04dc 3 0 #define MX6UL_PAD_UART2_TX_DATA__GPT1_CAPTURE1 0x0094 0x0320 0x058c 4 1 #define MX6UL_PAD_UART2_TX_DATA__GPIO1_IO20 0x0094 0x0320 0x0000 5 0 -#define MX6UL_PAD_UART2_TX_DATA__ECSPI3_SS0 0x0094 0x0320 0x0000 8 0 +#define MX6UL_PAD_UART2_TX_DATA__ECSPI3_SS0 0x0094 0x0320 0x0560 8 0 #define MX6UL_PAD_UART2_RX_DATA__UART2_DCE_RX 0x0098 0x0324 0x062c 0 1 #define MX6UL_PAD_UART2_RX_DATA__UART2_DTE_TX 0x0098 0x0324 0x0000 0 0 #define MX6UL_PAD_UART2_RX_DATA__ENET1_TDATA03 0x0098 0x0324 0x0000 1 0 @@ -232,7 +232,7 @@ #define MX6UL_PAD_UART3_TX_DATA__UART3_DTE_RX 0x00a4 0x0330 0x0634 0 0 #define MX6UL_PAD_UART3_TX_DATA__ENET2_RDATA02 0x00a4 0x0330 0x0000 1 0 #define MX6UL_PAD_UART3_TX_DATA__SIM1_PORT0_PD 0x00a4 0x0330 0x0000 2 0 -#define MX6UL_PAD_UART3_TX_DATA__CSI_DATA01 0x00a4 0x0330 0x0000 3 0 +#define MX6UL_PAD_UART3_TX_DATA__CSI_DATA01 0x00a4 0x0330 0x04d4 3 0 #define MX6UL_PAD_UART3_TX_DATA__UART2_DCE_CTS 0x00a4 0x0330 0x0000 4 0 #define MX6UL_PAD_UART3_TX_DATA__UART2_DTE_RTS 0x00a4 0x0330 0x0628 4 2 #define MX6UL_PAD_UART3_TX_DATA__GPIO1_IO24 0x00a4 0x0330 0x0000 5 0 @@ -242,7 +242,7 @@ #define MX6UL_PAD_UART3_RX_DATA__UART3_DTE_TX 0x00a8 0x0334 0x0000 0 0 #define MX6UL_PAD_UART3_RX_DATA__ENET2_RDATA03 0x00a8 0x0334 0x0000 1 0 #define MX6UL_PAD_UART3_RX_DATA__SIM2_PORT0_PD 0x00a8 0x0334 0x0000 2 0 -#define MX6UL_PAD_UART3_RX_DATA__CSI_DATA00 0x00a8 0x0334 0x0000 3 0 +#define MX6UL_PAD_UART3_RX_DATA__CSI_DATA00 0x00a8 0x0334 0x04d0 3 0 #define MX6UL_PAD_UART3_RX_DATA__UART2_DCE_RTS 0x00a8 0x0334 0x0628 4 3 #define MX6UL_PAD_UART3_RX_DATA__UART2_DTE_CTS 0x00a8 0x0334 0x0000 4 0 #define MX6UL_PAD_UART3_RX_DATA__GPIO1_IO25 0x00a8 0x0334 0x0000 5 0 @@ -251,7 +251,7 @@ #define MX6UL_PAD_UART3_CTS_B__UART3_DTE_RTS 0x00ac 0x0338 0x0630 0 0 #define MX6UL_PAD_UART3_CTS_B__ENET2_RX_CLK 0x00ac 0x0338 0x0000 1 0 #define MX6UL_PAD_UART3_CTS_B__FLEXCAN1_TX 0x00ac 0x0338 0x0000 2 0 -#define MX6UL_PAD_UART3_CTS_B__CSI_DATA10 0x00ac 0x0338 0x0000 3 0 +#define MX6UL_PAD_UART3_CTS_B__CSI_DATA10 0x00ac 0x0338 0x04ec 3 0 #define MX6UL_PAD_UART3_CTS_B__ENET1_1588_EVENT1_IN 0x00ac 0x0338 0x0000 4 0 #define MX6UL_PAD_UART3_CTS_B__GPIO1_IO26 0x00ac 0x0338 0x0000 5 0 #define MX6UL_PAD_UART3_CTS_B__EPIT2_OUT 0x00ac 0x0338 0x0000 8 0 @@ -259,7 +259,7 @@ #define MX6UL_PAD_UART3_RTS_B__UART3_DTE_CTS 0x00b0 0x033c 0x0000 0 0 #define MX6UL_PAD_UART3_RTS_B__ENET2_TX_ER 0x00b0 0x033c 0x0000 1 0 #define MX6UL_PAD_UART3_RTS_B__FLEXCAN1_RX 0x00b0 0x033c 0x0584 2 0 -#define MX6UL_PAD_UART3_RTS_B__CSI_DATA11 0x00b0 0x033c 0x0000 3 0 +#define MX6UL_PAD_UART3_RTS_B__CSI_DATA11 0x00b0 0x033c 0x04f0 3 0 #define MX6UL_PAD_UART3_RTS_B__ENET1_1588_EVENT1_OUT 0x00b0 0x033c 0x0000 4 0 #define MX6UL_PAD_UART3_RTS_B__GPIO1_IO27 0x00b0 0x033c 0x0000 5 0 #define MX6UL_PAD_UART3_RTS_B__WDOG1_WDOG_B 0x00b0 0x033c 0x0000 8 0 @@ -267,7 +267,7 @@ #define MX6UL_PAD_UART4_TX_DATA__UART4_DTE_RX 0x00b4 0x0340 0x063c 0 0 #define MX6UL_PAD_UART4_TX_DATA__ENET2_TDATA02 0x00b4 0x0340 0x0000 1 0 #define MX6UL_PAD_UART4_TX_DATA__I2C1_SCL 0x00b4 0x0340 0x05a4 2 1 -#define MX6UL_PAD_UART4_TX_DATA__CSI_DATA12 0x00b4 0x0340 0x0000 3 0 +#define MX6UL_PAD_UART4_TX_DATA__CSI_DATA12 0x00b4 0x0340 0x04f4 3 0 #define MX6UL_PAD_UART4_TX_DATA__CSU_CSU_ALARM_AUT02 0x00b4 0x0340 0x0000 4 0 #define MX6UL_PAD_UART4_TX_DATA__GPIO1_IO28 0x00b4 0x0340 0x0000 5 0 #define MX6UL_PAD_UART4_TX_DATA__ECSPI2_SCLK 0x00b4 0x0340 0x0544 8 1 @@ -275,23 +275,23 @@ #define MX6UL_PAD_UART4_RX_DATA__UART4_DTE_TX 0x00b8 0x0344 0x0000 0 0 #define MX6UL_PAD_UART4_RX_DATA__ENET2_TDATA03 0x00b8 0x0344 0x0000 1 0 #define MX6UL_PAD_UART4_RX_DATA__I2C1_SDA 0x00b8 0x0344 0x05a8 2 2 -#define MX6UL_PAD_UART4_RX_DATA__CSI_DATA13 0x00b8 0x0344 0x0000 3 0 +#define MX6UL_PAD_UART4_RX_DATA__CSI_DATA13 0x00b8 0x0344 0x04f8 3 0 #define MX6UL_PAD_UART4_RX_DATA__CSU_CSU_ALARM_AUT01 0x00b8 0x0344 0x0000 4 0 #define MX6UL_PAD_UART4_RX_DATA__GPIO1_IO29 0x00b8 0x0344 0x0000 5 0 -#define MX6UL_PAD_UART4_RX_DATA__ECSPI2_SS0 0x00b8 0x0344 0x0000 8 0 +#define MX6UL_PAD_UART4_RX_DATA__ECSPI2_SS0 0x00b8 0x0344 0x0550 8 1 #define MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30 0x00bc 0x0348 0x0000 5 0 #define MX6UL_PAD_UART5_TX_DATA__ECSPI2_MOSI 0x00bc 0x0348 0x054c 8 0 #define MX6UL_PAD_UART5_TX_DATA__UART5_DCE_TX 0x00bc 0x0348 0x0000 0 0 #define MX6UL_PAD_UART5_TX_DATA__UART5_DTE_RX 0x00bc 0x0348 0x0644 0 4 #define MX6UL_PAD_UART5_TX_DATA__ENET2_CRS 0x00bc 0x0348 0x0000 1 0 #define MX6UL_PAD_UART5_TX_DATA__I2C2_SCL 0x00bc 0x0348 0x05ac 2 2 -#define MX6UL_PAD_UART5_TX_DATA__CSI_DATA14 0x00bc 0x0348 0x0000 3 0 +#define MX6UL_PAD_UART5_TX_DATA__CSI_DATA14 0x00bc 0x0348 0x04fc 3 0 #define MX6UL_PAD_UART5_TX_DATA__CSU_CSU_ALARM_AUT00 0x00bc 0x0348 0x0000 4 0 #define MX6UL_PAD_UART5_RX_DATA__UART5_DCE_RX 0x00c0 0x034c 0x0644 0 5 #define MX6UL_PAD_UART5_RX_DATA__UART5_DTE_TX 0x00c0 0x034c 0x0000 0 0 #define MX6UL_PAD_UART5_RX_DATA__ENET2_COL 0x00c0 0x034c 0x0000 1 0 #define MX6UL_PAD_UART5_RX_DATA__I2C2_SDA 0x00c0 0x034c 0x05b0 2 2 -#define MX6UL_PAD_UART5_RX_DATA__CSI_DATA15 0x00c0 0x034c 0x0000 3 0 +#define MX6UL_PAD_UART5_RX_DATA__CSI_DATA15 0x00c0 0x034c 0x0500 3 0 #define MX6UL_PAD_UART5_RX_DATA__CSU_CSU_INT_DEB 0x00c0 0x034c 0x0000 4 0 #define MX6UL_PAD_UART5_RX_DATA__GPIO1_IO31 0x00c0 0x034c 0x0000 5 0 #define MX6UL_PAD_UART5_RX_DATA__ECSPI2_MISO 0x00c0 0x034c 0x0548 8 1 @@ -299,59 +299,61 @@ #define MX6UL_PAD_ENET1_RX_DATA0__UART4_DCE_RTS 0x00c4 0x0350 0x0638 1 0 #define MX6UL_PAD_ENET1_RX_DATA0__UART4_DTE_CTS 0x00c4 0x0350 0x0000 1 0 #define MX6UL_PAD_ENET1_RX_DATA0__PWM1_OUT 0x00c4 0x0350 0x0000 2 0 -#define MX6UL_PAD_ENET1_RX_DATA0__CSI_DATA16 0x00c4 0x0350 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_DATA0__CSI_DATA16 0x00c4 0x0350 0x0504 3 0 #define MX6UL_PAD_ENET1_RX_DATA0__FLEXCAN1_TX 0x00c4 0x0350 0x0000 4 0 #define MX6UL_PAD_ENET1_RX_DATA0__GPIO2_IO00 0x00c4 0x0350 0x0000 5 0 -#define MX6UL_PAD_ENET1_RX_DATA0__KPP_ROW00 0x00c4 0x0350 0x0000 6 0 +#define MX6UL_PAD_ENET1_RX_DATA0__KPP_ROW00 0x00c4 0x0350 0x05d0 6 0 #define MX6UL_PAD_ENET1_RX_DATA0__USDHC1_LCTL 0x00c4 0x0350 0x0000 8 0 #define MX6UL_PAD_ENET1_RX_DATA1__ENET1_RDATA01 0x00c8 0x0354 0x0000 0 0 #define MX6UL_PAD_ENET1_RX_DATA1__UART4_DCE_CTS 0x00c8 0x0354 0x0000 1 0 #define MX6UL_PAD_ENET1_RX_DATA1__UART4_DTE_RTS 0x00c8 0x0354 0x0638 1 1 #define MX6UL_PAD_ENET1_RX_DATA1__PWM2_OUT 0x00c8 0x0354 0x0000 2 0 -#define MX6UL_PAD_ENET1_RX_DATA1__CSI_DATA17 0x00c8 0x0354 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_DATA1__CSI_DATA17 0x00c8 0x0354 0x0508 3 0 #define MX6UL_PAD_ENET1_RX_DATA1__FLEXCAN1_RX 0x00c8 0x0354 0x0584 4 1 #define MX6UL_PAD_ENET1_RX_DATA1__GPIO2_IO01 0x00c8 0x0354 0x0000 5 0 -#define MX6UL_PAD_ENET1_RX_DATA1__KPP_COL00 0x00c8 0x0354 0x0000 6 0 +#define MX6UL_PAD_ENET1_RX_DATA1__KPP_COL00 0x00c8 0x0354 0x05c4 6 0 #define MX6UL_PAD_ENET1_RX_DATA1__USDHC2_LCTL 0x00c8 0x0354 0x0000 8 0 #define MX6UL_PAD_ENET1_RX_EN__ENET1_RX_EN 0x00cc 0x0358 0x0000 0 0 #define MX6UL_PAD_ENET1_RX_EN__UART5_DCE_RTS 0x00cc 0x0358 0x0640 1 3 #define MX6UL_PAD_ENET1_RX_EN__UART5_DTE_CTS 0x00cc 0x0358 0x0000 1 0 -#define MX6UL_PAD_ENET1_RX_EN__CSI_DATA18 0x00cc 0x0358 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_EN__OSC32K_32K_OUT 0x00cc 0x0358 0x0000 2 0 +#define MX6UL_PAD_ENET1_RX_EN__CSI_DATA18 0x00cc 0x0358 0x050c 3 0 #define MX6UL_PAD_ENET1_RX_EN__FLEXCAN2_TX 0x00cc 0x0358 0x0000 4 0 #define MX6UL_PAD_ENET1_RX_EN__GPIO2_IO02 0x00cc 0x0358 0x0000 5 0 -#define MX6UL_PAD_ENET1_RX_EN__KPP_ROW01 0x00cc 0x0358 0x0000 6 0 +#define MX6UL_PAD_ENET1_RX_EN__KPP_ROW01 0x00cc 0x0358 0x05d4 6 0 #define MX6UL_PAD_ENET1_RX_EN__USDHC1_VSELECT 0x00cc 0x0358 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_DATA0__ENET1_TDATA00 0x00d0 0x035c 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_DATA0__UART5_DCE_CTS 0x00d0 0x035c 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_DATA0__UART5_DTE_RTS 0x00d0 0x035c 0x0640 1 4 -#define MX6UL_PAD_ENET1_TX_DATA0__CSI_DATA19 0x00d0 0x035c 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_DATA0__REF_CLK_24M 0x00d0 0x035c 0x0000 2 0 +#define MX6UL_PAD_ENET1_TX_DATA0__CSI_DATA19 0x00d0 0x035c 0x0510 3 0 #define MX6UL_PAD_ENET1_TX_DATA0__FLEXCAN2_RX 0x00d0 0x035c 0x0588 4 1 #define MX6UL_PAD_ENET1_TX_DATA0__GPIO2_IO03 0x00d0 0x035c 0x0000 5 0 -#define MX6UL_PAD_ENET1_TX_DATA0__KPP_COL01 0x00d0 0x035c 0x0000 6 0 +#define MX6UL_PAD_ENET1_TX_DATA0__KPP_COL01 0x00d0 0x035c 0x05c8 6 0 #define MX6UL_PAD_ENET1_TX_DATA0__USDHC2_VSELECT 0x00d0 0x035c 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_DATA1__ENET1_TDATA01 0x00d4 0x0360 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_DATA1__UART6_DCE_CTS 0x00d4 0x0360 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_DATA1__UART6_DTE_RTS 0x00d4 0x0360 0x0648 1 2 #define MX6UL_PAD_ENET1_TX_DATA1__PWM5_OUT 0x00d4 0x0360 0x0000 2 0 -#define MX6UL_PAD_ENET1_TX_DATA1__CSI_DATA20 0x00d4 0x0360 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_DATA1__CSI_DATA20 0x00d4 0x0360 0x0514 3 0 #define MX6UL_PAD_ENET1_TX_DATA1__ENET2_MDIO 0x00d4 0x0360 0x0580 4 1 #define MX6UL_PAD_ENET1_TX_DATA1__GPIO2_IO04 0x00d4 0x0360 0x0000 5 0 -#define MX6UL_PAD_ENET1_TX_DATA1__KPP_ROW02 0x00d4 0x0360 0x0000 6 0 +#define MX6UL_PAD_ENET1_TX_DATA1__KPP_ROW02 0x00d4 0x0360 0x05d8 6 0 #define MX6UL_PAD_ENET1_TX_DATA1__WDOG1_WDOG_RST_B_DEB 0x00d4 0x0360 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_EN__ENET1_TX_EN 0x00d8 0x0364 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_EN__UART6_DCE_RTS 0x00d8 0x0364 0x0648 1 3 #define MX6UL_PAD_ENET1_TX_EN__UART6_DTE_CTS 0x00d8 0x0364 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_EN__PWM6_OUT 0x00d8 0x0364 0x0000 2 0 -#define MX6UL_PAD_ENET1_TX_EN__CSI_DATA21 0x00d8 0x0364 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_EN__CSI_DATA21 0x00d8 0x0364 0x0518 3 0 #define MX6UL_PAD_ENET1_TX_EN__ENET2_MDC 0x00d8 0x0364 0x0000 4 0 #define MX6UL_PAD_ENET1_TX_EN__GPIO2_IO05 0x00d8 0x0364 0x0000 5 0 -#define MX6UL_PAD_ENET1_TX_EN__KPP_COL02 0x00d8 0x0364 0x0000 6 0 +#define MX6UL_PAD_ENET1_TX_EN__KPP_COL02 0x00d8 0x0364 0x05cc 6 0 #define MX6UL_PAD_ENET1_TX_EN__WDOG2_WDOG_RST_B_DEB 0x00d8 0x0364 0x0000 8 0 #define MX6UL_PAD_ENET1_TX_CLK__ENET1_TX_CLK 0x00dc 0x0368 0x0000 0 0 #define MX6UL_PAD_ENET1_TX_CLK__UART7_DCE_CTS 0x00dc 0x0368 0x0000 1 0 #define MX6UL_PAD_ENET1_TX_CLK__UART7_DTE_RTS 0x00dc 0x0368 0x0650 1 0 #define MX6UL_PAD_ENET1_TX_CLK__PWM7_OUT 0x00dc 0x0368 0x0000 2 0 -#define MX6UL_PAD_ENET1_TX_CLK__CSI_DATA22 0x00dc 0x0368 0x0000 3 0 +#define MX6UL_PAD_ENET1_TX_CLK__CSI_DATA22 0x00dc 0x0368 0x051c 3 0 #define MX6UL_PAD_ENET1_TX_CLK__ENET1_REF_CLK1 0x00dc 0x0368 0x0574 4 2 #define MX6UL_PAD_ENET1_TX_CLK__GPIO2_IO06 0x00dc 0x0368 0x0000 5 0 #define MX6UL_PAD_ENET1_TX_CLK__KPP_ROW03 0x00dc 0x0368 0x0000 6 0 @@ -360,7 +362,7 @@ #define MX6UL_PAD_ENET1_RX_ER__UART7_DCE_RTS 0x00e0 0x036c 0x0650 1 1 #define MX6UL_PAD_ENET1_RX_ER__UART7_DTE_CTS 0x00e0 0x036c 0x0000 1 0 #define MX6UL_PAD_ENET1_RX_ER__PWM8_OUT 0x00e0 0x036c 0x0000 2 0 -#define MX6UL_PAD_ENET1_RX_ER__CSI_DATA23 0x00e0 0x036c 0x0000 3 0 +#define MX6UL_PAD_ENET1_RX_ER__CSI_DATA23 0x00e0 0x036c 0x0520 3 0 #define MX6UL_PAD_ENET1_RX_ER__EIM_CRE 0x00e0 0x036c 0x0000 4 0 #define MX6UL_PAD_ENET1_RX_ER__GPIO2_IO07 0x00e0 0x036c 0x0000 5 0 #define MX6UL_PAD_ENET1_RX_ER__KPP_COL03 0x00e0 0x036c 0x0000 6 0 @@ -377,7 +379,7 @@ #define MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x00e8 0x0374 0x0000 0 0 #define MX6UL_PAD_ENET2_RX_DATA1__UART6_DCE_RX 0x00e8 0x0374 0x064c 1 2 #define MX6UL_PAD_ENET2_RX_DATA1__UART6_DTE_TX 0x00e8 0x0374 0x0000 1 0 -#define MX6UL_PAD_ENET2_RX_DATA1__SIM1_PORT0_cLK 0x00e8 0x0374 0x0000 2 0 +#define MX6UL_PAD_ENET2_RX_DATA1__SIM1_PORT0_CLK 0x00e8 0x0374 0x0000 2 0 #define MX6UL_PAD_ENET2_RX_DATA1__I2C3_SDA 0x00e8 0x0374 0x05b8 3 1 #define MX6UL_PAD_ENET2_RX_DATA1__ENET1_MDC 0x00e8 0x0374 0x0000 4 0 #define MX6UL_PAD_ENET2_RX_DATA1__GPIO2_IO09 0x00e8 0x0374 0x0000 5 0 @@ -400,6 +402,7 @@ #define MX6UL_PAD_ENET2_TX_DATA0__EIM_EB_B02 0x00f0 0x037c 0x0000 4 0 #define MX6UL_PAD_ENET2_TX_DATA0__GPIO2_IO11 0x00f0 0x037c 0x0000 5 0 #define MX6UL_PAD_ENET2_TX_DATA0__KPP_COL05 0x00f0 0x037c 0x0000 6 0 +#define MX6UL_PAD_ENET2_TX_DATA0__REF_CLK_24M 0x00f0 0x037c 0x0000 8 0 #define MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x00f4 0x0380 0x0000 0 0 #define MX6UL_PAD_ENET2_TX_DATA1__UART8_DCE_TX 0x00f4 0x0380 0x0000 1 0 #define MX6UL_PAD_ENET2_TX_DATA1__UART8_DTE_RX 0x00f4 0x0380 0x065c 1 0 @@ -412,7 +415,7 @@ #define MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x00f8 0x0384 0x0000 0 0 #define MX6UL_PAD_ENET2_TX_EN__UART8_DCE_RX 0x00f8 0x0384 0x065c 1 1 #define MX6UL_PAD_ENET2_TX_EN__UART8_DTE_TX 0x00f8 0x0384 0x0000 1 0 -#define MX6UL_PAD_ENET2_TX_EN__SIM2_PORT0_cLK 0x00f8 0x0384 0x0000 2 0 +#define MX6UL_PAD_ENET2_TX_EN__SIM2_PORT0_CLK 0x00f8 0x0384 0x0000 2 0 #define MX6UL_PAD_ENET2_TX_EN__ECSPI4_MOSI 0x00f8 0x0384 0x056c 3 0 #define MX6UL_PAD_ENET2_TX_EN__EIM_ACLK_FREERUN 0x00f8 0x0384 0x0000 4 0 #define MX6UL_PAD_ENET2_TX_EN__GPIO2_IO13 0x00f8 0x0384 0x0000 5 0 @@ -431,7 +434,7 @@ #define MX6UL_PAD_ENET2_RX_ER__UART8_DCE_RTS 0x0100 0x038c 0x0658 1 1 #define MX6UL_PAD_ENET2_RX_ER__UART8_DTE_CTS 0x0100 0x038c 0x0000 1 0 #define MX6UL_PAD_ENET2_RX_ER__SIM2_PORT0_SVEN 0x0100 0x038c 0x0000 2 0 -#define MX6UL_PAD_ENET2_RX_ER__ECSPI4_SS0 0x0100 0x038c 0x0000 3 0 +#define MX6UL_PAD_ENET2_RX_ER__ECSPI4_SS0 0x0100 0x038c 0x0570 3 0 #define MX6UL_PAD_ENET2_RX_ER__EIM_ADDR25 0x0100 0x038c 0x0000 4 0 #define MX6UL_PAD_ENET2_RX_ER__GPIO2_IO15 0x0100 0x038c 0x0000 5 0 #define MX6UL_PAD_ENET2_RX_ER__KPP_COL07 0x0100 0x038c 0x0000 6 0 @@ -440,7 +443,7 @@ #define MX6UL_PAD_LCD_CLK__LCDIF_WR_RWN 0x0104 0x0390 0x0000 1 0 #define MX6UL_PAD_LCD_CLK__UART4_DCE_TX 0x0104 0x0390 0x0000 2 0 #define MX6UL_PAD_LCD_CLK__UART4_DTE_RX 0x0104 0x0390 0x063c 2 2 -#define MX6UL_PAD_LCD_CLK__SAI3_MCLK 0x0104 0x0390 0x0000 3 0 +#define MX6UL_PAD_LCD_CLK__SAI3_MCLK 0x0104 0x0390 0x0600 3 0 #define MX6UL_PAD_LCD_CLK__EIM_CS2_B 0x0104 0x0390 0x0000 4 0 #define MX6UL_PAD_LCD_CLK__GPIO3_IO00 0x0104 0x0390 0x0000 5 0 #define MX6UL_PAD_LCD_CLK__WDOG1_WDOG_RST_B_DEB 0x0104 0x0390 0x0000 8 0 @@ -464,7 +467,7 @@ #define MX6UL_PAD_LCD_VSYNC__LCDIF_BUSY 0x0110 0x039c 0x05dc 1 1 #define MX6UL_PAD_LCD_VSYNC__UART4_DCE_RTS 0x0110 0x039c 0x0638 2 3 #define MX6UL_PAD_LCD_VSYNC__UART4_DTE_CTS 0x0110 0x039c 0x0000 2 0 -#define MX6UL_PAD_LCD_VSYNC__SAI3_RX_DATA 0x0110 0x039c 0x0000 3 0 +#define MX6UL_PAD_LCD_VSYNC__SAI3_RX_DATA 0x0110 0x039c 0x0604 3 0 #define MX6UL_PAD_LCD_VSYNC__WDOG2_WDOG_B 0x0110 0x039c 0x0000 4 0 #define MX6UL_PAD_LCD_VSYNC__GPIO3_IO03 0x0110 0x039c 0x0000 5 0 #define MX6UL_PAD_LCD_VSYNC__ECSPI2_SS2 0x0110 0x039c 0x0000 8 0 @@ -477,13 +480,15 @@ #define MX6UL_PAD_LCD_RESET__ECSPI2_SS3 0x0114 0x03a0 0x0000 8 0 #define MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x0118 0x03a4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA00__PWM1_OUT 0x0118 0x03a4 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA00__CA7_MX6UL_TRACE0 0x0118 0x03a4 0x0000 2 0 #define MX6UL_PAD_LCD_DATA00__ENET1_1588_EVENT2_IN 0x0118 0x03a4 0x0000 3 0 #define MX6UL_PAD_LCD_DATA00__I2C3_SDA 0x0118 0x03a4 0x05b8 4 2 #define MX6UL_PAD_LCD_DATA00__GPIO3_IO05 0x0118 0x03a4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA00__SRC_BT_CFG00 0x0118 0x03a4 0x0000 6 0 -#define MX6UL_PAD_LCD_DATA00__SAI1_MCLK 0x0118 0x03a4 0x0000 8 0 +#define MX6UL_PAD_LCD_DATA00__SAI1_MCLK 0x0118 0x03a4 0x05e0 8 1 #define MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x011c 0x03a8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA01__PWM2_OUT 0x011c 0x03a8 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA01__CA7_MX6UL_TRACE1 0x011c 0x03a8 0x0000 2 0 #define MX6UL_PAD_LCD_DATA01__ENET1_1588_EVENT2_OUT 0x011c 0x03a8 0x0000 3 0 #define MX6UL_PAD_LCD_DATA01__I2C3_SCL 0x011c 0x03a8 0x05b4 4 2 #define MX6UL_PAD_LCD_DATA01__GPIO3_IO06 0x011c 0x03a8 0x0000 5 0 @@ -491,6 +496,7 @@ #define MX6UL_PAD_LCD_DATA01__SAI1_TX_SYNC 0x011c 0x03a8 0x05ec 8 0 #define MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x0120 0x03ac 0x0000 0 0 #define MX6UL_PAD_LCD_DATA02__PWM3_OUT 0x0120 0x03ac 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA02__CA7_MX6UL_TRACE2 0x0120 0x03ac 0x0000 2 0 #define MX6UL_PAD_LCD_DATA02__ENET1_1588_EVENT3_IN 0x0120 0x03ac 0x0000 3 0 #define MX6UL_PAD_LCD_DATA02__I2C4_SDA 0x0120 0x03ac 0x05c0 4 2 #define MX6UL_PAD_LCD_DATA02__GPIO3_IO07 0x0120 0x03ac 0x0000 5 0 @@ -498,14 +504,16 @@ #define MX6UL_PAD_LCD_DATA02__SAI1_TX_BCLK 0x0120 0x03ac 0x05e8 8 0 #define MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x0124 0x03b0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA03__PWM4_OUT 0x0124 0x03b0 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA03__CA7_MX6UL_TRACE3 0x0124 0x03b0 0x0000 2 0 #define MX6UL_PAD_LCD_DATA03__ENET1_1588_EVENT3_OUT 0x0124 0x03b0 0x0000 3 0 #define MX6UL_PAD_LCD_DATA03__I2C4_SCL 0x0124 0x03b0 0x05bc 4 2 #define MX6UL_PAD_LCD_DATA03__GPIO3_IO08 0x0124 0x03b0 0x0000 5 0 #define MX6UL_PAD_LCD_DATA03__SRC_BT_CFG03 0x0124 0x03b0 0x0000 6 0 -#define MX6UL_PAD_LCD_DATA03__SAI1_RX_DATA 0x0124 0x03b0 0x0000 8 0 +#define MX6UL_PAD_LCD_DATA03__SAI1_RX_DATA 0x0124 0x03b0 0x05e4 8 0 #define MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x0128 0x03b4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA04__UART8_DCE_CTS 0x0128 0x03b4 0x0000 1 0 #define MX6UL_PAD_LCD_DATA04__UART8_DTE_RTS 0x0128 0x03b4 0x0658 1 2 +#define MX6UL_PAD_LCD_DATA04__CA7_MX6UL_TRACE4 0x0128 0x03b4 0x0000 2 0 #define MX6UL_PAD_LCD_DATA04__ENET2_1588_EVENT2_IN 0x0128 0x03b4 0x0000 3 0 #define MX6UL_PAD_LCD_DATA04__SPDIF_SR_CLK 0x0128 0x03b4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA04__GPIO3_IO09 0x0128 0x03b4 0x0000 5 0 @@ -514,6 +522,7 @@ #define MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x012c 0x03b8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA05__UART8_DCE_RTS 0x012c 0x03b8 0x0658 1 3 #define MX6UL_PAD_LCD_DATA05__UART8_DTE_CTS 0x012c 0x03b8 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA05__CA7_MX6UL_TRACE5 0x012c 0x03b8 0x0000 2 0 #define MX6UL_PAD_LCD_DATA05__ENET2_1588_EVENT2_OUT 0x012c 0x03b8 0x0000 3 0 #define MX6UL_PAD_LCD_DATA05__SPDIF_OUT 0x012c 0x03b8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA05__GPIO3_IO10 0x012c 0x03b8 0x0000 5 0 @@ -522,6 +531,7 @@ #define MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x0130 0x03bc 0x0000 0 0 #define MX6UL_PAD_LCD_DATA06__UART7_DCE_CTS 0x0130 0x03bc 0x0000 1 0 #define MX6UL_PAD_LCD_DATA06__UART7_DTE_RTS 0x0130 0x03bc 0x0650 1 2 +#define MX6UL_PAD_LCD_DATA06__CA7_MX6UL_TRACE6 0x0130 0x03bc 0x0000 2 0 #define MX6UL_PAD_LCD_DATA06__ENET2_1588_EVENT3_IN 0x0130 0x03bc 0x0000 3 0 #define MX6UL_PAD_LCD_DATA06__SPDIF_LOCK 0x0130 0x03bc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA06__GPIO3_IO11 0x0130 0x03bc 0x0000 5 0 @@ -530,6 +540,7 @@ #define MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x0134 0x03c0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA07__UART7_DCE_RTS 0x0134 0x03c0 0x0650 1 3 #define MX6UL_PAD_LCD_DATA07__UART7_DTE_CTS 0x0134 0x03c0 0x0000 1 0 +#define MX6UL_PAD_LCD_DATA07__CA7_MX6UL_TRACE7 0x0134 0x03c0 0x0000 2 0 #define MX6UL_PAD_LCD_DATA07__ENET2_1588_EVENT3_OUT 0x0134 0x03c0 0x0000 3 0 #define MX6UL_PAD_LCD_DATA07__SPDIF_EXT_CLK 0x0134 0x03c0 0x061c 4 0 #define MX6UL_PAD_LCD_DATA07__GPIO3_IO12 0x0134 0x03c0 0x0000 5 0 @@ -537,56 +548,64 @@ #define MX6UL_PAD_LCD_DATA07__ECSPI1_SS3 0x0134 0x03c0 0x0000 8 0 #define MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x0138 0x03c4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA08__SPDIF_IN 0x0138 0x03c4 0x0618 1 2 -#define MX6UL_PAD_LCD_DATA08__CSI_DATA16 0x0138 0x03c4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA08__CA7_MX6UL_TRACE8 0x0138 0x03c4 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA08__CSI_DATA16 0x0138 0x03c4 0x0504 3 1 #define MX6UL_PAD_LCD_DATA08__EIM_DATA00 0x0138 0x03c4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA08__GPIO3_IO13 0x0138 0x03c4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA08__SRC_BT_CFG08 0x0138 0x03c4 0x0000 6 0 #define MX6UL_PAD_LCD_DATA08__FLEXCAN1_TX 0x0138 0x03c4 0x0000 8 0 #define MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x013c 0x03c8 0x0000 0 0 -#define MX6UL_PAD_LCD_DATA09__SAI3_MCLK 0x013c 0x03c8 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA09__CSI_DATA17 0x013c 0x03c8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA09__SAI3_MCLK 0x013c 0x03c8 0x0600 1 1 +#define MX6UL_PAD_LCD_DATA09__CA7_MX6UL_TRACE9 0x013c 0x03c8 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA09__CSI_DATA17 0x013c 0x03c8 0x0508 3 1 #define MX6UL_PAD_LCD_DATA09__EIM_DATA01 0x013c 0x03c8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA09__GPIO3_IO14 0x013c 0x03c8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA09__SRC_BT_CFG09 0x013c 0x03c8 0x0000 6 0 #define MX6UL_PAD_LCD_DATA09__FLEXCAN1_RX 0x013c 0x03c8 0x0584 8 2 #define MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x0140 0x03cc 0x0000 0 0 #define MX6UL_PAD_LCD_DATA10__SAI3_RX_SYNC 0x0140 0x03cc 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA10__CSI_DATA18 0x0140 0x03cc 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA10__CA7_MX6UL_TRACE10 0x0140 0x03cc 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA10__CSI_DATA18 0x0140 0x03cc 0x050c 3 1 #define MX6UL_PAD_LCD_DATA10__EIM_DATA02 0x0140 0x03cc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA10__GPIO3_IO15 0x0140 0x03cc 0x0000 5 0 #define MX6UL_PAD_LCD_DATA10__SRC_BT_CFG10 0x0140 0x03cc 0x0000 6 0 #define MX6UL_PAD_LCD_DATA10__FLEXCAN2_TX 0x0140 0x03cc 0x0000 8 0 #define MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x0144 0x03d0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA11__SAI3_RX_BCLK 0x0144 0x03d0 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA11__CSI_DATA19 0x0144 0x03d0 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA11__CA7_MX6UL_TRACE11 0x0144 0x03d0 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA11__CSI_DATA19 0x0144 0x03d0 0x0510 3 1 #define MX6UL_PAD_LCD_DATA11__EIM_DATA03 0x0144 0x03d0 0x0000 4 0 #define MX6UL_PAD_LCD_DATA11__GPIO3_IO16 0x0144 0x03d0 0x0000 5 0 #define MX6UL_PAD_LCD_DATA11__SRC_BT_CFG11 0x0144 0x03d0 0x0000 6 0 #define MX6UL_PAD_LCD_DATA11__FLEXCAN2_RX 0x0144 0x03d0 0x0588 8 2 #define MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x0148 0x03d4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA12__SAI3_TX_SYNC 0x0148 0x03d4 0x060c 1 1 -#define MX6UL_PAD_LCD_DATA12__CSI_DATA20 0x0148 0x03d4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA12__CA7_MX6UL_TRACE12 0x0148 0x03d4 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA12__CSI_DATA20 0x0148 0x03d4 0x0514 3 1 #define MX6UL_PAD_LCD_DATA12__EIM_DATA04 0x0148 0x03d4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA12__GPIO3_IO17 0x0148 0x03d4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA12__SRC_BT_CFG12 0x0148 0x03d4 0x0000 6 0 #define MX6UL_PAD_LCD_DATA12__ECSPI1_RDY 0x0148 0x03d4 0x0000 8 0 #define MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x014c 0x03d8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA13__SAI3_TX_BCLK 0x014c 0x03d8 0x0608 1 1 -#define MX6UL_PAD_LCD_DATA13__CSI_DATA21 0x014c 0x03d8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA13__CA7_MX6UL_TRACE13 0x014c 0x03d8 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA13__CSI_DATA21 0x014c 0x03d8 0x0518 3 1 #define MX6UL_PAD_LCD_DATA13__EIM_DATA05 0x014c 0x03d8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA13__GPIO3_IO18 0x014c 0x03d8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA13__SRC_BT_CFG13 0x014c 0x03d8 0x0000 6 0 #define MX6UL_PAD_LCD_DATA13__USDHC2_RESET_B 0x014c 0x03d8 0x0000 8 0 #define MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x0150 0x03dc 0x0000 0 0 -#define MX6UL_PAD_LCD_DATA14__SAI3_RX_DATA 0x0150 0x03dc 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA14__CSI_DATA22 0x0150 0x03dc 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA14__SAI3_RX_DATA 0x0150 0x03dc 0x0604 1 1 +#define MX6UL_PAD_LCD_DATA14__CA7_MX6UL_TRACE14 0x0150 0x03dc 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA14__CSI_DATA22 0x0150 0x03dc 0x051c 3 1 #define MX6UL_PAD_LCD_DATA14__EIM_DATA06 0x0150 0x03dc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA14__GPIO3_IO19 0x0150 0x03dc 0x0000 5 0 #define MX6UL_PAD_LCD_DATA14__SRC_BT_CFG14 0x0150 0x03dc 0x0000 6 0 #define MX6UL_PAD_LCD_DATA14__USDHC2_DATA4 0x0150 0x03dc 0x068c 8 0 #define MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x0154 0x03e0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA15__SAI3_TX_DATA 0x0154 0x03e0 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA15__CSI_DATA23 0x0154 0x03e0 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA15__CA7_MX6UL_TRACE15 0x0154 0x03e0 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA15__CSI_DATA23 0x0154 0x03e0 0x0520 3 1 #define MX6UL_PAD_LCD_DATA15__EIM_DATA07 0x0154 0x03e0 0x0000 4 0 #define MX6UL_PAD_LCD_DATA15__GPIO3_IO20 0x0154 0x03e0 0x0000 5 0 #define MX6UL_PAD_LCD_DATA15__SRC_BT_CFG15 0x0154 0x03e0 0x0000 6 0 @@ -594,7 +613,8 @@ #define MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x0158 0x03e4 0x0000 0 0 #define MX6UL_PAD_LCD_DATA16__UART7_DCE_TX 0x0158 0x03e4 0x0000 1 0 #define MX6UL_PAD_LCD_DATA16__UART7_DTE_RX 0x0158 0x03e4 0x0654 1 2 -#define MX6UL_PAD_LCD_DATA16__CSI_DATA01 0x0158 0x03e4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA16__CA7_MX6UL_TRACE_CLK 0x0158 0x03e4 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA16__CSI_DATA01 0x0158 0x03e4 0x04d4 3 1 #define MX6UL_PAD_LCD_DATA16__EIM_DATA08 0x0158 0x03e4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA16__GPIO3_IO21 0x0158 0x03e4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA16__SRC_BT_CFG24 0x0158 0x03e4 0x0000 6 0 @@ -602,7 +622,8 @@ #define MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x015c 0x03e8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA17__UART7_DCE_RX 0x015c 0x03e8 0x0654 1 3 #define MX6UL_PAD_LCD_DATA17__UART7_DTE_TX 0x015c 0x03e8 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA17__CSI_DATA00 0x015c 0x03e8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA17__CA7_MX6UL_TRACE_CTL 0x015c 0x03e8 0x0000 2 0 +#define MX6UL_PAD_LCD_DATA17__CSI_DATA00 0x015c 0x03e8 0x04d0 3 1 #define MX6UL_PAD_LCD_DATA17__EIM_DATA09 0x015c 0x03e8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA17__GPIO3_IO22 0x015c 0x03e8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA17__SRC_BT_CFG25 0x015c 0x03e8 0x0000 6 0 @@ -610,7 +631,7 @@ #define MX6UL_PAD_LCD_DATA18__LCDIF_DATA18 0x0160 0x03ec 0x0000 0 0 #define MX6UL_PAD_LCD_DATA18__PWM5_OUT 0x0160 0x03ec 0x0000 1 0 #define MX6UL_PAD_LCD_DATA18__CA7_MX6UL_EVENTO 0x0160 0x03ec 0x0000 2 0 -#define MX6UL_PAD_LCD_DATA18__CSI_DATA10 0x0160 0x03ec 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA18__CSI_DATA10 0x0160 0x03ec 0x04ec 3 1 #define MX6UL_PAD_LCD_DATA18__EIM_DATA10 0x0160 0x03ec 0x0000 4 0 #define MX6UL_PAD_LCD_DATA18__GPIO3_IO23 0x0160 0x03ec 0x0000 5 0 #define MX6UL_PAD_LCD_DATA18__SRC_BT_CFG26 0x0160 0x03ec 0x0000 6 0 @@ -622,7 +643,7 @@ #define MX6UL_PAD_LCD_DATA19__LCDIF_DATA19 0x0164 0x03f0 0x0000 0 0 #define MX6UL_PAD_LCD_DATA19__PWM6_OUT 0x0164 0x03f0 0x0000 1 0 #define MX6UL_PAD_LCD_DATA19__WDOG1_WDOG_ANY 0x0164 0x03f0 0x0000 2 0 -#define MX6UL_PAD_LCD_DATA19__CSI_DATA11 0x0164 0x03f0 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA19__CSI_DATA11 0x0164 0x03f0 0x04f0 3 1 #define MX6UL_PAD_LCD_DATA20__EIM_DATA12 0x0168 0x03f4 0x0000 4 0 #define MX6UL_PAD_LCD_DATA20__GPIO3_IO25 0x0168 0x03f4 0x0000 5 0 #define MX6UL_PAD_LCD_DATA20__SRC_BT_CFG28 0x0168 0x03f4 0x0000 6 0 @@ -631,12 +652,12 @@ #define MX6UL_PAD_LCD_DATA20__UART8_DCE_TX 0x0168 0x03f4 0x0000 1 0 #define MX6UL_PAD_LCD_DATA20__UART8_DTE_RX 0x0168 0x03f4 0x065c 1 2 #define MX6UL_PAD_LCD_DATA20__ECSPI1_SCLK 0x0168 0x03f4 0x0534 2 0 -#define MX6UL_PAD_LCD_DATA20__CSI_DATA12 0x0168 0x03f4 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA20__CSI_DATA12 0x0168 0x03f4 0x04f4 3 1 #define MX6UL_PAD_LCD_DATA21__LCDIF_DATA21 0x016c 0x03f8 0x0000 0 0 #define MX6UL_PAD_LCD_DATA21__UART8_DCE_RX 0x016c 0x03f8 0x065c 1 3 #define MX6UL_PAD_LCD_DATA21__UART8_DTE_TX 0x016c 0x03f8 0x0000 1 0 -#define MX6UL_PAD_LCD_DATA21__ECSPI1_SS0 0x016c 0x03f8 0x0000 2 0 -#define MX6UL_PAD_LCD_DATA21__CSI_DATA13 0x016c 0x03f8 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA21__ECSPI1_SS0 0x016c 0x03f8 0x0540 2 0 +#define MX6UL_PAD_LCD_DATA21__CSI_DATA13 0x016c 0x03f8 0x04f8 3 1 #define MX6UL_PAD_LCD_DATA21__EIM_DATA13 0x016c 0x03f8 0x0000 4 0 #define MX6UL_PAD_LCD_DATA21__GPIO3_IO26 0x016c 0x03f8 0x0000 5 0 #define MX6UL_PAD_LCD_DATA21__SRC_BT_CFG29 0x016c 0x03f8 0x0000 6 0 @@ -644,7 +665,7 @@ #define MX6UL_PAD_LCD_DATA22__LCDIF_DATA22 0x0170 0x03fc 0x0000 0 0 #define MX6UL_PAD_LCD_DATA22__MQS_RIGHT 0x0170 0x03fc 0x0000 1 0 #define MX6UL_PAD_LCD_DATA22__ECSPI1_MOSI 0x0170 0x03fc 0x053c 2 0 -#define MX6UL_PAD_LCD_DATA22__CSI_DATA14 0x0170 0x03fc 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA22__CSI_DATA14 0x0170 0x03fc 0x04fc 3 1 #define MX6UL_PAD_LCD_DATA22__EIM_DATA14 0x0170 0x03fc 0x0000 4 0 #define MX6UL_PAD_LCD_DATA22__GPIO3_IO27 0x0170 0x03fc 0x0000 5 0 #define MX6UL_PAD_LCD_DATA22__SRC_BT_CFG30 0x0170 0x03fc 0x0000 6 0 @@ -652,7 +673,7 @@ #define MX6UL_PAD_LCD_DATA23__LCDIF_DATA23 0x0174 0x0400 0x0000 0 0 #define MX6UL_PAD_LCD_DATA23__MQS_LEFT 0x0174 0x0400 0x0000 1 0 #define MX6UL_PAD_LCD_DATA23__ECSPI1_MISO 0x0174 0x0400 0x0538 2 0 -#define MX6UL_PAD_LCD_DATA23__CSI_DATA15 0x0174 0x0400 0x0000 3 0 +#define MX6UL_PAD_LCD_DATA23__CSI_DATA15 0x0174 0x0400 0x0500 3 1 #define MX6UL_PAD_LCD_DATA23__EIM_DATA15 0x0174 0x0400 0x0000 4 0 #define MX6UL_PAD_LCD_DATA23__GPIO3_IO28 0x0174 0x0400 0x0000 5 0 #define MX6UL_PAD_LCD_DATA23__SRC_BT_CFG31 0x0174 0x0400 0x0000 6 0 @@ -660,42 +681,42 @@ #define MX6UL_PAD_NAND_RE_B__RAWNAND_RE_B 0x0178 0x0404 0x0000 0 0 #define MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x0178 0x0404 0x0670 1 2 #define MX6UL_PAD_NAND_RE_B__QSPI_B_SCLK 0x0178 0x0404 0x0000 2 0 -#define MX6UL_PAD_NAND_RE_B__KPP_ROW00 0x0178 0x0404 0x0000 3 0 +#define MX6UL_PAD_NAND_RE_B__KPP_ROW00 0x0178 0x0404 0x05d0 3 1 #define MX6UL_PAD_NAND_RE_B__EIM_EB_B00 0x0178 0x0404 0x0000 4 0 #define MX6UL_PAD_NAND_RE_B__GPIO4_IO00 0x0178 0x0404 0x0000 5 0 #define MX6UL_PAD_NAND_RE_B__ECSPI3_SS2 0x0178 0x0404 0x0000 8 0 #define MX6UL_PAD_NAND_WE_B__RAWNAND_WE_B 0x017c 0x0408 0x0000 0 0 #define MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x017c 0x0408 0x0678 1 2 #define MX6UL_PAD_NAND_WE_B__QSPI_B_SS0_B 0x017c 0x0408 0x0000 2 0 -#define MX6UL_PAD_NAND_WE_B__KPP_COL00 0x017c 0x0408 0x0000 3 0 +#define MX6UL_PAD_NAND_WE_B__KPP_COL00 0x017c 0x0408 0x05c4 3 1 #define MX6UL_PAD_NAND_WE_B__EIM_EB_B01 0x017c 0x0408 0x0000 4 0 #define MX6UL_PAD_NAND_WE_B__GPIO4_IO01 0x017c 0x0408 0x0000 5 0 #define MX6UL_PAD_NAND_WE_B__ECSPI3_SS3 0x017c 0x0408 0x0000 8 0 #define MX6UL_PAD_NAND_DATA00__RAWNAND_DATA00 0x0180 0x040c 0x0000 0 0 #define MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x0180 0x040c 0x067c 1 2 #define MX6UL_PAD_NAND_DATA00__QSPI_B_SS1_B 0x0180 0x040c 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA00__KPP_ROW01 0x0180 0x040c 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA00__KPP_ROW01 0x0180 0x040c 0x05d4 3 1 #define MX6UL_PAD_NAND_DATA00__EIM_AD08 0x0180 0x040c 0x0000 4 0 #define MX6UL_PAD_NAND_DATA00__GPIO4_IO02 0x0180 0x040c 0x0000 5 0 #define MX6UL_PAD_NAND_DATA00__ECSPI4_RDY 0x0180 0x040c 0x0000 8 0 #define MX6UL_PAD_NAND_DATA01__RAWNAND_DATA01 0x0184 0x0410 0x0000 0 0 #define MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x0184 0x0410 0x0680 1 2 #define MX6UL_PAD_NAND_DATA01__QSPI_B_DQS 0x0184 0x0410 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA01__KPP_COL01 0x0184 0x0410 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA01__KPP_COL01 0x0184 0x0410 0x05c8 3 1 #define MX6UL_PAD_NAND_DATA01__EIM_AD09 0x0184 0x0410 0x0000 4 0 #define MX6UL_PAD_NAND_DATA01__GPIO4_IO03 0x0184 0x0410 0x0000 5 0 #define MX6UL_PAD_NAND_DATA01__ECSPI4_SS1 0x0184 0x0410 0x0000 8 0 #define MX6UL_PAD_NAND_DATA02__RAWNAND_DATA02 0x0188 0x0414 0x0000 0 0 #define MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x0188 0x0414 0x0684 1 1 #define MX6UL_PAD_NAND_DATA02__QSPI_B_DATA00 0x0188 0x0414 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA02__KPP_ROW02 0x0188 0x0414 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA02__KPP_ROW02 0x0188 0x0414 0x05d8 3 1 #define MX6UL_PAD_NAND_DATA02__EIM_AD10 0x0188 0x0414 0x0000 4 0 #define MX6UL_PAD_NAND_DATA02__GPIO4_IO04 0x0188 0x0414 0x0000 5 0 #define MX6UL_PAD_NAND_DATA02__ECSPI4_SS2 0x0188 0x0414 0x0000 8 0 #define MX6UL_PAD_NAND_DATA03__RAWNAND_DATA03 0x018c 0x0418 0x0000 0 0 #define MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x018c 0x0418 0x0688 1 2 #define MX6UL_PAD_NAND_DATA03__QSPI_B_DATA01 0x018c 0x0418 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA03__KPP_COL02 0x018c 0x0418 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA03__KPP_COL02 0x018c 0x0418 0x05cc 3 1 #define MX6UL_PAD_NAND_DATA03__EIM_AD11 0x018c 0x0418 0x0000 4 0 #define MX6UL_PAD_NAND_DATA03__GPIO4_IO05 0x018c 0x0418 0x0000 5 0 #define MX6UL_PAD_NAND_DATA03__ECSPI4_SS3 0x018c 0x0418 0x0000 8 0 @@ -726,7 +747,7 @@ #define MX6UL_PAD_NAND_DATA07__RAWNAND_DATA07 0x019c 0x0428 0x0000 0 0 #define MX6UL_PAD_NAND_DATA07__USDHC2_DATA7 0x019c 0x0428 0x0698 1 1 #define MX6UL_PAD_NAND_DATA07__QSPI_A_SS1_B 0x019c 0x0428 0x0000 2 0 -#define MX6UL_PAD_NAND_DATA07__ECSPI4_SS0 0x019c 0x0428 0x0000 3 0 +#define MX6UL_PAD_NAND_DATA07__ECSPI4_SS0 0x019c 0x0428 0x0570 3 1 #define MX6UL_PAD_NAND_DATA07__EIM_AD15 0x019c 0x0428 0x0000 4 0 #define MX6UL_PAD_NAND_DATA07__GPIO4_IO09 0x019c 0x0428 0x0000 5 0 #define MX6UL_PAD_NAND_DATA07__UART2_DCE_RTS 0x019c 0x0428 0x0628 8 5 @@ -748,7 +769,7 @@ #define MX6UL_PAD_NAND_READY_B__RAWNAND_READY_B 0x01a8 0x0434 0x0000 0 0 #define MX6UL_PAD_NAND_READY_B__USDHC1_DATA4 0x01a8 0x0434 0x0000 1 0 #define MX6UL_PAD_NAND_READY_B__QSPI_A_DATA00 0x01a8 0x0434 0x0000 2 0 -#define MX6UL_PAD_NAND_READY_B__ECSPI3_SS0 0x01a8 0x0434 0x0000 3 0 +#define MX6UL_PAD_NAND_READY_B__ECSPI3_SS0 0x01a8 0x0434 0x0560 3 1 #define MX6UL_PAD_NAND_READY_B__EIM_CS1_B 0x01a8 0x0434 0x0000 4 0 #define MX6UL_PAD_NAND_READY_B__GPIO4_IO12 0x01a8 0x0434 0x0000 5 0 #define MX6UL_PAD_NAND_READY_B__UART3_DCE_TX 0x01a8 0x0434 0x0000 8 0 @@ -783,7 +804,7 @@ #define MX6UL_PAD_NAND_DQS__PWM5_OUT 0x01b8 0x0444 0x0000 3 0 #define MX6UL_PAD_NAND_DQS__EIM_WAIT 0x01b8 0x0444 0x0000 4 0 #define MX6UL_PAD_NAND_DQS__GPIO4_IO16 0x01b8 0x0444 0x0000 5 0 -#define MX6UL_PAD_NAND_DQS__SDMA_EXT_EVENT01 0x01b8 0x0444 0x0000 6 0 +#define MX6UL_PAD_NAND_DQS__SDMA_EXT_EVENT01 0x01b8 0x0444 0x0614 6 1 #define MX6UL_PAD_NAND_DQS__SPDIF_EXT_CLK 0x01b8 0x0444 0x061c 8 1 #define MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x01bc 0x0448 0x0000 0 0 #define MX6UL_PAD_SD1_CMD__GPT2_COMPARE1 0x01bc 0x0448 0x0000 1 0 @@ -791,11 +812,11 @@ #define MX6UL_PAD_SD1_CMD__SPDIF_OUT 0x01bc 0x0448 0x0000 3 0 #define MX6UL_PAD_SD1_CMD__EIM_ADDR19 0x01bc 0x0448 0x0000 4 0 #define MX6UL_PAD_SD1_CMD__GPIO2_IO16 0x01bc 0x0448 0x0000 5 0 -#define MX6UL_PAD_SD1_CMD__SDMA_EXT_EVENT00 0x01bc 0x0448 0x0000 6 0 +#define MX6UL_PAD_SD1_CMD__SDMA_EXT_EVENT00 0x01bc 0x0448 0x0610 6 2 #define MX6UL_PAD_SD1_CMD__USB_OTG1_PWR 0x01bc 0x0448 0x0000 8 0 #define MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x01c0 0x044c 0x0000 0 0 #define MX6UL_PAD_SD1_CLK__GPT2_COMPARE2 0x01c0 0x044c 0x0000 1 0 -#define MX6UL_PAD_SD1_CLK__SAI2_MCLK 0x01c0 0x044c 0x0000 2 0 +#define MX6UL_PAD_SD1_CLK__SAI2_MCLK 0x01c0 0x044c 0x05f0 2 1 #define MX6UL_PAD_SD1_CLK__SPDIF_IN 0x01c0 0x044c 0x0618 3 3 #define MX6UL_PAD_SD1_CLK__EIM_ADDR20 0x01c0 0x044c 0x0000 4 0 #define MX6UL_PAD_SD1_CLK__GPIO2_IO17 0x01c0 0x044c 0x0000 5 0 @@ -878,10 +899,10 @@ #define MX6UL_PAD_CSI_DATA01__CSI_DATA03 0x01e8 0x0474 0x04c8 0 0 #define MX6UL_PAD_CSI_DATA01__USDHC2_DATA1 0x01e8 0x0474 0x0680 1 0 #define MX6UL_PAD_CSI_DATA01__SIM1_PORT1_SVEN 0x01e8 0x0474 0x0000 2 0 -#define MX6UL_PAD_CSI_DATA01__ECSPI2_SS0 0x01e8 0x0474 0x0000 3 0 +#define MX6UL_PAD_CSI_DATA01__ECSPI2_SS0 0x01e8 0x0474 0x0550 3 0 #define MX6UL_PAD_CSI_DATA01__EIM_AD01 0x01e8 0x0474 0x0000 4 0 #define MX6UL_PAD_CSI_DATA01__GPIO4_IO22 0x01e8 0x0474 0x0000 5 0 -#define MX6UL_PAD_CSI_DATA01__SAI1_MCLK 0x01e8 0x0474 0x0000 6 0 +#define MX6UL_PAD_CSI_DATA01__SAI1_MCLK 0x01e8 0x0474 0x05e0 6 0 #define MX6UL_PAD_CSI_DATA01__UART5_DCE_RX 0x01e8 0x0474 0x0644 8 1 #define MX6UL_PAD_CSI_DATA01__UART5_DTE_TX 0x01e8 0x0474 0x0000 8 0 #define MX6UL_PAD_CSI_DATA02__CSI_DATA04 0x01ec 0x0478 0x04d8 0 1 @@ -913,7 +934,7 @@ #define MX6UL_PAD_CSI_DATA05__CSI_DATA07 0x01f8 0x0484 0x04e0 0 1 #define MX6UL_PAD_CSI_DATA05__USDHC2_DATA5 0x01f8 0x0484 0x0690 1 2 #define MX6UL_PAD_CSI_DATA05__SIM2_PORT1_RST_B 0x01f8 0x0484 0x0000 2 0 -#define MX6UL_PAD_CSI_DATA05__ECSPI1_SS0 0x01f8 0x0484 0x0000 3 0 +#define MX6UL_PAD_CSI_DATA05__ECSPI1_SS0 0x01f8 0x0484 0x0540 3 1 #define MX6UL_PAD_CSI_DATA05__EIM_AD05 0x01f8 0x0484 0x0000 4 0 #define MX6UL_PAD_CSI_DATA05__GPIO4_IO26 0x01f8 0x0484 0x0000 5 0 #define MX6UL_PAD_CSI_DATA05__SAI1_TX_BCLK 0x01f8 0x0484 0x05e8 6 1 @@ -924,7 +945,7 @@ #define MX6UL_PAD_CSI_DATA06__ECSPI1_MOSI 0x01fc 0x0488 0x053c 3 1 #define MX6UL_PAD_CSI_DATA06__EIM_AD06 0x01fc 0x0488 0x0000 4 0 #define MX6UL_PAD_CSI_DATA06__GPIO4_IO27 0x01fc 0x0488 0x0000 5 0 -#define MX6UL_PAD_CSI_DATA06__SAI1_RX_DATA 0x01fc 0x0488 0x0000 6 0 +#define MX6UL_PAD_CSI_DATA06__SAI1_RX_DATA 0x01fc 0x0488 0x05e4 6 1 #define MX6UL_PAD_CSI_DATA06__USDHC1_RESET_B 0x01fc 0x0488 0x0000 8 0 #define MX6UL_PAD_CSI_DATA07__CSI_DATA09 0x0200 0x048c 0x04e8 0 1 #define MX6UL_PAD_CSI_DATA07__USDHC2_DATA7 0x0200 0x048c 0x0698 1 2 diff --git a/arch/arm/dts/imx6ul.dtsi b/arch/arm/dts/imx6ul.dtsi index 71b42d4a20..5644b0f34d 100644 --- a/arch/arm/dts/imx6ul.dtsi +++ b/arch/arm/dts/imx6ul.dtsi @@ -1,19 +1,23 @@ -/*
- Copyright 2015 Freescale Semiconductor, Inc.
+// SPDX-License-Identifier: GPL-2.0 +// +// Copyright 2015 Freescale Semiconductor, Inc.
#include <dt-bindings/clock/imx6ul-clock.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include "imx6ul-pinfunc.h" -#include "skeleton.dtsi"
- #address-cells = <1>;
- #size-cells = <1>;
* The decompressor and also some bootloaders rely on a
* pre-existing /chosen node to be available to insert the
* command line and merge other ATAGS info.
- chosen {};
- aliases { ethernet0 = &fec1; ethernet1 = &fec2;
@@ -59,14 +63,17 @@ device_type = "cpu"; reg = <0>; clock-latency = <61036>; /* two CLK32 periods */
#cooling-cells = <2>; operating-points = < /* kHz uV */
696000 1275000 528000 1175000 396000 1025000 198000 950000 >; fsl,soc-operating-points = < /* KHz uV */
696000 1275000 528000 1175000 396000 1175000 198000 1175000
@@ -77,30 +84,39 @@ <&clks IMX6UL_CA7_SECONDARY_SEL>, <&clks IMX6UL_CLK_STEP>, <&clks IMX6UL_CLK_PLL1_SW>,
<&clks IMX6UL_CLK_PLL1_SYS>,
<&clks IMX6UL_PLL1_BYPASS>,
<&clks IMX6UL_CLK_PLL1>,
<&clks IMX6UL_PLL1_BYPASS_SRC>,
<&clks IMX6UL_CLK_OSC>;
<&clks IMX6UL_CLK_PLL1_SYS>; clock-names = "arm", "pll2_bus", "pll2_pfd2_396m", "secondary_sel", "step", "pll1_sw",
"pll1_sys", "pll1_bypass", "pll1",
"pll1_bypass_src", "osc";
"pll1_sys"; arm-supply = <®_arm>; soc-supply = <®_soc>;
nvmem-cells = <&cpu_speed_grade>;
}; };nvmem-cell-names = "speed_grade";
- intc: interrupt-controller@00a01000 {
compatible = "arm,cortex-a7-gic";
- intc: interrupt-controller@a01000 {
compatible = "arm,gic-400", "arm,cortex-a7-gic";
interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(1) |
IRQ_TYPE_LEVEL_HIGH)>; #interrupt-cells = <3>; interrupt-controller;
reg = <0x00a01000 0x1000>,interrupt-parent = <&intc>;
<0x00a02000 0x1000>,
<0x00a02000 0x2000>, <0x00a04000 0x2000>, <0x00a06000 0x2000>;
timer {
compatible = "arm,armv7-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(1) |
IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(1) |
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(1) |
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(1) |
IRQ_TYPE_LEVEL_LOW)>;
status = "disabled";
- ckil: clock-cli { compatible = "fixed-clock"; #clock-cells = <0>;
@@ -129,6 +145,22 @@ clock-output-names = "ipp_di1"; };
- tempmon: tempmon {
compatible = "fsl,imx6ul-tempmon", "fsl,imx6sx-tempmon";
interrupt-parent = <&gpc>;
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;
fsl,tempmon = <&anatop>;
nvmem-cells = <&tempmon_calib>, <&tempmon_temp_grade>;
nvmem-cell-names = "calib", "temp_grade";
clocks = <&clks IMX6UL_CLK_PLL3_USB_OTG>;
- pmu {
compatible = "arm,cortex-a7-pmu";
interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>;
- soc { #address-cells = <1>; #size-cells = <1>;
@@ -136,18 +168,12 @@ interrupt-parent = <&gpc>; ranges;
pmu {
ocram: sram@00900000 {
};ocram: sram@900000 { compatible = "mmio-sram"; reg = <0x00900000 0x20000>;
dma_apbh: dma-apbh@01804000 {
dma_apbh: dma-apbh@1804000 { compatible = "fsl,imx6q-dma-apbh", "fsl,imx28-dma-apbh"; reg = <0x01804000 0x2000>; interrupts = <0 13 IRQ_TYPE_LEVEL_HIGH>,
@@ -160,7 +186,7 @@ clocks = <&clks IMX6UL_CLK_APBHDMA>; };
gpmi: gpmi-nand@01806000 {
gpmi: gpmi-nand@1806000 { compatible = "fsl,imx6q-gpmi-nand"; #address-cells = <1>; #size-cells = <1>;
@@ -180,22 +206,21 @@ status = "disabled"; };
aips1: aips-bus@02000000 {
aips1: aips-bus@2000000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x100000>; ranges;
spba-bus@02000000 {
spba-bus@2000000 { compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02000000 0x40000>; ranges;
u-boot,dm-spl;
ecspi1: ecspi@02008000 {
ecspi1: spi@2008000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi";
@@ -207,7 +232,7 @@ status = "disabled"; };
ecspi2: ecspi@0200c000 {
ecspi2: spi@200c000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi";
@@ -219,7 +244,7 @@ status = "disabled"; };
ecspi3: ecspi@02010000 {
ecspi3: spi@2010000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi";
@@ -231,7 +256,7 @@ status = "disabled"; };
ecspi4: ecspi@02014000 {
ecspi4: spi@2014000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi";
@@ -243,7 +268,7 @@ status = "disabled"; };
uart7: serial@02018000 {
uart7: serial@2018000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x02018000 0x4000>;
@@ -254,7 +279,7 @@ status = "disabled"; };
uart1: serial@02020000 {
uart1: serial@2020000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x02020000 0x4000>;
@@ -265,7 +290,7 @@ status = "disabled"; };
uart8: serial@02024000 {
uart8: serial@2024000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x02024000 0x4000>;
@@ -276,7 +301,7 @@ status = "disabled"; };
sai1: sai@02028000 {
sai1: sai@2028000 { #sound-dai-cells = <0>; compatible = "fsl,imx6ul-sai", "fsl,imx6sx-sai"; reg = <0x02028000 0x4000>;
@@ -291,7 +316,7 @@ status = "disabled"; };
sai2: sai@0202c000 {
sai2: sai@202c000 { #sound-dai-cells = <0>; compatible = "fsl,imx6ul-sai", "fsl,imx6sx-sai"; reg = <0x0202c000 0x4000>;
@@ -306,7 +331,7 @@ status = "disabled"; };
sai3: sai@02030000 {
sai3: sai@2030000 { #sound-dai-cells = <0>; compatible = "fsl,imx6ul-sai", "fsl,imx6sx-sai"; reg = <0x02030000 0x4000>;
@@ -322,7 +347,7 @@ }; };
tsc: tsc@02040000 {
tsc: tsc@2040000 { compatible = "fsl,imx6ul-tsc"; reg = <0x02040000 0x4000>, <0x0219c000 0x4000>; interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>,
@@ -333,10 +358,10 @@ status = "disabled"; };
pwm1: pwm@02080000 {
pwm1: pwm@2080000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x02080000 0x4000>;
interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM1>, <&clks IMX6UL_CLK_PWM1>; clock-names = "ipg", "per";
@@ -344,10 +369,10 @@ status = "disabled"; };
pwm2: pwm@02084000 {
pwm2: pwm@2084000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x02084000 0x4000>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM2>, <&clks IMX6UL_CLK_PWM2>; clock-names = "ipg", "per";
@@ -355,10 +380,10 @@ status = "disabled"; };
pwm3: pwm@02088000 {
pwm3: pwm@2088000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x02088000 0x4000>;
interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM3>, <&clks IMX6UL_CLK_PWM3>; clock-names = "ipg", "per";
@@ -366,10 +391,10 @@ status = "disabled"; };
pwm4: pwm@0208c000 {
pwm4: pwm@208c000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x0208c000 0x4000>;
interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>;
interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_PWM4>, <&clks IMX6UL_CLK_PWM4>; clock-names = "ipg", "per";
@@ -377,27 +402,29 @@ status = "disabled"; };
can1: flexcan@02090000 {
can1: flexcan@2090000 { compatible = "fsl,imx6ul-flexcan", "fsl,imx6q-flexcan"; reg = <0x02090000 0x4000>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_CAN1_IPG>, <&clks IMX6UL_CLK_CAN1_SERIAL>; clock-names = "ipg", "per";
fsl,stop-mode = <&gpr 0x10 1 0x10 17>; status = "disabled"; };
can2: flexcan@02094000 {
can2: flexcan@2094000 { compatible = "fsl,imx6ul-flexcan", "fsl,imx6q-flexcan"; reg = <0x02094000 0x4000>; interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_CAN2_IPG>, <&clks IMX6UL_CLK_CAN2_SERIAL>; clock-names = "ipg", "per";
fsl,stop-mode = <&gpr 0x10 2 0x10 18>; status = "disabled"; };
gpt1: gpt@02098000 {
gpt1: gpt@2098000 { compatible = "fsl,imx6ul-gpt", "fsl,imx6sx-gpt"; reg = <0x02098000 0x4000>; interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
@@ -406,11 +433,12 @@ clock-names = "ipg", "per"; };
gpio1: gpio@0209c000 {
gpio1: gpio@209c000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x0209c000 0x4000>; interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_GPIO1>; gpio-controller; #gpio-cells = <2>; interrupt-controller;
@@ -419,11 +447,12 @@ <&iomuxc 16 33 16>; };
gpio2: gpio@020a0000 {
gpio2: gpio@20a0000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020a0000 0x4000>; interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_GPIO2>; gpio-controller; #gpio-cells = <2>; interrupt-controller;
@@ -431,11 +460,12 @@ gpio-ranges = <&iomuxc 0 49 16>, <&iomuxc 16 111 6>; };
gpio3: gpio@020a4000 {
gpio3: gpio@20a4000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020a4000 0x4000>; interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_GPIO3>; gpio-controller; #gpio-cells = <2>; interrupt-controller;
@@ -443,11 +473,12 @@ gpio-ranges = <&iomuxc 0 65 29>; };
gpio4: gpio@020a8000 {
gpio4: gpio@20a8000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020a8000 0x4000>; interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_GPIO4>; gpio-controller; #gpio-cells = <2>; interrupt-controller;
@@ -455,11 +486,12 @@ gpio-ranges = <&iomuxc 0 94 17>, <&iomuxc 17 117 12>; };
gpio5: gpio@020ac000 {
gpio5: gpio@20ac000 { compatible = "fsl,imx6ul-gpio", "fsl,imx35-gpio"; reg = <0x020ac000 0x4000>; interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_GPIO5>; gpio-controller; #gpio-cells = <2>; interrupt-controller;
@@ -467,9 +499,10 @@ gpio-ranges = <&iomuxc 0 7 10>, <&iomuxc 10 5 2>; };
fec2: ethernet@020b4000 {
fec2: ethernet@20b4000 { compatible = "fsl,imx6ul-fec", "fsl,imx6q-fec"; reg = <0x020b4000 0x4000>;
interrupt-names = "int0", "pps"; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_ENET>,
@@ -484,7 +517,7 @@ status = "disabled"; };
kpp: kpp@020b8000 {
kpp: kpp@20b8000 { compatible = "fsl,imx6ul-kpp", "fsl,imx6q-kpp",
"fsl,imx21-kpp"; reg = <0x020b8000 0x4000>; interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; @@ -492,14 +525,14 @@ status = "disabled"; };
wdog1: wdog@020bc000 {
wdog1: wdog@20bc000 { compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; reg = <0x020bc000 0x4000>; interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_WDOG1>; };
wdog2: wdog@020c0000 {
wdog2: wdog@20c0000 { compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; reg = <0x020c0000 0x4000>; interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>;
@@ -507,7 +540,7 @@ status = "disabled"; };
clks: ccm@020c4000 {
clks: ccm@20c4000 { compatible = "fsl,imx6ul-ccm"; reg = <0x020c4000 0x4000>; interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>,
@@ -517,7 +550,7 @@ clock-names = "ckil", "osc", "ipp_di0", "ipp_di1"; };
anatop: anatop@020c8000 {
anatop: anatop@20c8000 { compatible = "fsl,imx6ul-anatop", "fsl,imx6q-anatop", "syscon", "simple-bus"; reg = <0x020c8000 0x1000>;
@@ -574,7 +607,7 @@ }; };
usbphy1: usbphy@020c9000 {
usbphy1: usbphy@20c9000 { compatible = "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; reg = <0x020c9000 0x1000>; interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>;
@@ -583,7 +616,7 @@ fsl,anatop = <&anatop>; };
usbphy2: usbphy@020ca000 {
usbphy2: usbphy@20ca000 { compatible = "fsl,imx6ul-usbphy", "fsl,imx23-usbphy"; reg = <0x020ca000 0x1000>; interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>;
@@ -592,7 +625,7 @@ fsl,anatop = <&anatop>; };
snvs: snvs@020cc000 {
snvs: snvs@20cc000 { compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd"; reg = <0x020cc000 0x4000>;
@@ -608,6 +641,7 @@ compatible = "syscon-poweroff"; regmap = <&snvs>; offset = <0x38>;
value = <0x60>; mask = <0x60>; status = "disabled"; };
@@ -619,19 +653,23 @@ linux,keycode = <KEY_POWER>; wakeup-source; };
snvs_lpgpr: snvs-lpgpr {
compatible = "fsl,imx6ul-snvs-lpgpr";
epit1: epit@020d0000 {
epit1: epit@20d0000 { reg = <0x020d0000 0x4000>; interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; };
epit2: epit@020d4000 {
epit2: epit@20d4000 { reg = <0x020d4000 0x4000>; interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; };
src: src@020d8000 {
src: src@20d8000 { compatible = "fsl,imx6ul-src", "fsl,imx51-src"; reg = <0x020d8000 0x4000>; interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,
@@ -639,7 +677,7 @@ #reset-cells = <1>; };
gpc: gpc@020dc000 {
gpc: gpc@20dc000 { compatible = "fsl,imx6ul-gpc", "fsl,imx6q-gpc"; reg = <0x020dc000 0x4000>; interrupt-controller;
@@ -648,18 +686,18 @@ interrupt-parent = <&intc>; };
iomuxc: iomuxc@020e0000 {
iomuxc: iomuxc@20e0000 { compatible = "fsl,imx6ul-iomuxc"; reg = <0x020e0000 0x4000>; };
gpr: iomuxc-gpr@020e4000 {
gpr: iomuxc-gpr@20e4000 { compatible = "fsl,imx6ul-iomuxc-gpr", "fsl,imx6q-iomuxc-gpr", "syscon"; reg = <0x020e4000 0x4000>; };
gpt2: gpt@020e8000 {
gpt2: gpt@20e8000 { compatible = "fsl,imx6ul-gpt", "fsl,imx6sx-gpt"; reg = <0x020e8000 0x4000>; interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>;
@@ -668,19 +706,19 @@ clock-names = "ipg", "per"; };
sdma: sdma@020ec000 {
sdma: sdma@20ec000 { compatible = "fsl,imx6ul-sdma", "fsl,imx6q-sdma", "fsl,imx35-sdma"; reg = <0x020ec000 0x4000>; interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_SDMA>,
clocks = <&clks IMX6UL_CLK_IPG>, <&clks IMX6UL_CLK_SDMA>; clock-names = "ipg", "ahb"; #dma-cells = <3>; fsl,sdma-ram-script-name = "imx/sdma/sdma-imx6q.bin"; };
pwm5: pwm@020f0000 {
pwm5: pwm@20f0000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020f0000 0x4000>; interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>;
@@ -691,7 +729,7 @@ status = "disabled"; };
pwm6: pwm@020f4000 {
pwm6: pwm@20f4000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020f4000 0x4000>; interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>;
@@ -702,7 +740,7 @@ status = "disabled"; };
pwm7: pwm@020f8000 {
pwm7: pwm@20f8000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020f8000 0x4000>; interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
@@ -713,7 +751,7 @@ status = "disabled"; };
pwm8: pwm@020fc000 {
pwm8: pwm@20fc000 { compatible = "fsl,imx6ul-pwm", "fsl,imx27-pwm"; reg = <0x020fc000 0x4000>; interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>;
@@ -725,14 +763,44 @@ }; };
aips2: aips-bus@02100000 {
aips2: aips-bus@2100000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; #size-cells = <1>; reg = <0x02100000 0x100000>; ranges;
usbotg1: usb@02184000 {
crypto: caam@2140000 {
compatible = "fsl,imx6ul-caam", "fsl,sec-v4.0";
#size-cells = <1>;
reg = <0x2140000 0x3c000>;
ranges = <0 0x2140000 0x3c000>;
interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_CAAM_IPG>, <&clks
IMX6UL_CLK_CAAM_ACLK>,
<&clks IMX6UL_CLK_CAAM_MEM>;
clock-names = "ipg", "aclk", "mem";
sec_jr0: jr0@1000 {
compatible = "fsl,sec-v4.0-job-ring";
reg = <0x1000 0x1000>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
sec_jr1: jr1@2000 {
reg = <0x2000 0x1000>;
interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>;
sec_jr2: jr2@3000 {
reg = <0x3000 0x1000>;
interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
usbotg1: usb@2184000 { compatible = "fsl,imx6ul-usb", "fsl,imx27-usb"; reg = <0x02184000 0x200>; interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;
@@ -746,7 +814,7 @@ status = "disabled"; };
usbotg2: usb@02184200 {
usbotg2: usb@2184200 { compatible = "fsl,imx6ul-usb", "fsl,imx27-usb"; reg = <0x02184200 0x200>; interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
@@ -759,15 +827,16 @@ status = "disabled"; };
usbmisc: usbmisc@02184800 {
usbmisc: usbmisc@2184800 { #index-cells = <1>; compatible = "fsl,imx6ul-usbmisc", "fsl,imx6q-usbmisc"; reg = <0x02184800 0x200>; };
fec1: ethernet@02188000 {
fec1: ethernet@2188000 { compatible = "fsl,imx6ul-fec", "fsl,imx6q-fec"; reg = <0x02188000 0x4000>;
interrupt-names = "int0", "pps"; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX6UL_CLK_ENET>,
@@ -782,7 +851,7 @@ status = "disabled"; };
usdhc1: usdhc@02190000 {
usdhc1: usdhc@2190000 { compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02190000 0x4000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>;
@@ -794,7 +863,7 @@ status = "disabled"; };
usdhc2: usdhc@02194000 {
usdhc2: usdhc@2194000 { compatible = "fsl,imx6ul-usdhc", "fsl,imx6sx-usdhc"; reg = <0x02194000 0x4000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
@@ -806,7 +875,7 @@ status = "disabled"; };
adc1: adc@02198000 {
adc1: adc@2198000 { compatible = "fsl,imx6ul-adc", "fsl,vf610-adc"; reg = <0x02198000 0x4000>; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
@@ -818,7 +887,7 @@ status = "disabled"; };
i2c1: i2c@021a0000 {
i2c1: i2c@21a0000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c";
@@ -828,7 +897,7 @@ status = "disabled"; };
i2c2: i2c@021a4000 {
i2c2: i2c@21a4000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c";
@@ -838,7 +907,7 @@ status = "disabled"; };
i2c3: i2c@021a8000 {
i2c3: i2c@21a8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c";
@@ -848,12 +917,44 @@ status = "disabled"; };
mmdc: mmdc@021b0000 {
memory-controller@21b0000 { compatible = "fsl,imx6ul-mmdc", "fsl,imx6q-mmdc"; reg = <0x021b0000 0x4000>;
clocks = <&clks IMX6UL_CLK_MMDC_P0_IPG>;
weim: weim@21b8000 {
#address-cells = <2>;
#size-cells = <1>;
compatible = "fsl,imx6ul-weim", "fsl,imx6q-weim";
reg = <0x021b8000 0x4000>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_EIM>;
fsl,weim-cs-gpr = <&gpr>;
ocotp: ocotp-ctrl@21bc000 {
#size-cells = <1>;
compatible = "fsl,imx6ul-ocotp", "syscon";
reg = <0x021bc000 0x4000>;
clocks = <&clks IMX6UL_CLK_OCOTP>;
tempmon_calib: calib@38 {
reg = <0x38 4>;
tempmon_temp_grade: temp-grade@20 {
reg = <0x20 4>;
cpu_speed_grade: speed-grade@10 {
reg = <0x10 4>;
lcdif: lcdif@021c8000 {
lcdif: lcdif@21c8000 { compatible = "fsl,imx6ul-lcdif", "fsl,imx28-lcdif"; reg = <0x021c8000 0x4000>; interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
@@ -864,7 +965,7 @@ status = "disabled"; };
qspi: qspi@021e0000 {
qspi: spi@21e0000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-qspi", "fsl,imx6sx-qspi";
@@ -877,7 +978,7 @@ status = "disabled"; };
wdog3: wdog@021e4000 {
wdog3: wdog@21e4000 { compatible = "fsl,imx6ul-wdt", "fsl,imx21-wdt"; reg = <0x021e4000 0x4000>; interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
@@ -885,7 +986,7 @@ status = "disabled"; };
uart2: serial@021e8000 {
uart2: serial@21e8000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021e8000 0x4000>;
@@ -896,7 +997,7 @@ status = "disabled"; };
uart3: serial@021ec000 {
uart3: serial@21ec000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021ec000 0x4000>;
@@ -907,7 +1008,7 @@ status = "disabled"; };
uart4: serial@021f0000 {
uart4: serial@21f0000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021f0000 0x4000>;
@@ -918,7 +1019,7 @@ status = "disabled"; };
uart5: serial@021f4000 {
uart5: serial@21f4000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021f4000 0x4000>;
@@ -929,7 +1030,7 @@ status = "disabled"; };
i2c4: i2c@021f8000 {
i2c4: i2c@21f8000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx6ul-i2c", "fsl,imx21-i2c";
@@ -939,7 +1040,7 @@ status = "disabled"; };
uart6: serial@021fc000 {
uart6: serial@21fc000 { compatible = "fsl,imx6ul-uart", "fsl,imx6q-uart"; reg = <0x021fc000 0x4000>;
diff --git a/include/dt-bindings/clock/imx6ul-clock.h b/include/dt-bindings/clock/imx6ul-clock.h index 4623f170a8..79094338e6 100644 --- a/include/dt-bindings/clock/imx6ul-clock.h +++ b/include/dt-bindings/clock/imx6ul-clock.h @@ -1,10 +1,6 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ /*
- Copyright (C) 2015-2016 Freescale Semiconductor, Inc.
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
- published by the Free Software Foundation.
- Copyright (C) 2015 Freescale Semiconductor, Inc.
#ifndef __DT_BINDINGS_CLOCK_IMX6UL_H @@ -105,7 +101,7 @@ #define IMX6UL_CLK_LDB_DI1_DIV_SEL 92 #define IMX6UL_CLK_ARM 93 #define IMX6UL_CLK_PERIPH_CLK2 94 -#define IMX6UL_CLK_PERIPH2_CLK2 95 +#define IMX6UL_CLK_PERIPH2_CLK2 95 #define IMX6UL_CLK_AHB 96 #define IMX6UL_CLK_MMDC_PODF 97 #define IMX6UL_CLK_AXI_PODF 98 @@ -235,20 +231,32 @@ #define IMX6UL_CLK_CSI_PODF 222 #define IMX6UL_CLK_PLL3_120M 223 #define IMX6UL_CLK_KPP 224 -/* For i.MX6ULL */ -#define IMX6UL_CLK_ESAI_SEL 224 -#define IMX6UL_CLK_ESAI_PRED 225 -#define IMX6UL_CLK_ESAI_PODF 226 -#define IMX6UL_CLK_ESAI_EXTAL 227 -#define IMX6UL_CLK_ESAI_MEM 228 -#define IMX6UL_CLK_ESAI_IPG 229 -#define IMX6UL_CLK_DCP_CLK 230 -#define IMX6UL_CLK_EPDC_PRE_SEL 231 -#define IMX6UL_CLK_EPDC_SEL 232 -#define IMX6UL_CLK_EPDC_PODF 233 -#define IMX6UL_CLK_EPDC_ACLK 234 -#define IMX6UL_CLK_EPDC_PIX 235 +#define IMX6ULL_CLK_ESAI_PRED 225 +#define IMX6ULL_CLK_ESAI_PODF 226 +#define IMX6ULL_CLK_ESAI_EXTAL 227 +#define IMX6ULL_CLK_ESAI_MEM 228 +#define IMX6ULL_CLK_ESAI_IPG 229 +#define IMX6ULL_CLK_DCP_CLK 230 +#define IMX6ULL_CLK_EPDC_PRE_SEL 231 +#define IMX6ULL_CLK_EPDC_SEL 232 +#define IMX6ULL_CLK_EPDC_PODF 233 +#define IMX6ULL_CLK_EPDC_ACLK 234 +#define IMX6ULL_CLK_EPDC_PIX 235 +#define IMX6ULL_CLK_ESAI_SEL 236 +#define IMX6UL_CLK_CKO1_SEL 237 +#define IMX6UL_CLK_CKO1_PODF 238 +#define IMX6UL_CLK_CKO1 239 +#define IMX6UL_CLK_CKO2_SEL 240 +#define IMX6UL_CLK_CKO2_PODF 241 +#define IMX6UL_CLK_CKO2 242 +#define IMX6UL_CLK_CKO 243 +#define IMX6UL_CLK_GPIO1 244 +#define IMX6UL_CLK_GPIO2 245 +#define IMX6UL_CLK_GPIO3 246 +#define IMX6UL_CLK_GPIO4 247 +#define IMX6UL_CLK_GPIO5 248 +#define IMX6UL_CLK_MMDC_P1_IPG 249
-#define IMX6UL_CLK_END 236 +#define IMX6UL_CLK_END 250
#endif /* __DT_BINDINGS_CLOCK_IMX6UL_H */
2.16.4
Peng Fan
