[U-Boot] arm, spl: add watchdog library to SPL
Signed-off-by: Heiko Schocher hs@denx.de Cc: Tom Rini trini@ti.com --- doc/README.SPL | 2 +- spl/Makefile | 1 + 2 Dateien geändert, 2 Zeilen hinzugefügt(+), 1 Zeile entfernt(-)
diff --git a/doc/README.SPL b/doc/README.SPL index 4e1cb28..64977e0 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -67,7 +67,7 @@ CONFIG_SPL_POST_MEM_SUPPORT (post/drivers/memory.o) CONFIG_SPL_NAND_LOAD (drivers/mtd/nand/nand_spl_load.o) CONFIG_SPL_SPI_LOAD (drivers/mtd/spi/spi_spl_load.o) CONFIG_SPL_RAM_DEVICE (common/spl/spl.c) - +CONFIG_SPL_WATCHDOG_SUPPORT (drivers/watchdog/libwatchdog.o)
Normally CPU is assumed to be the same between the SPL and normal u-boot build. However it is possible to specify a different CPU for diff --git a/spl/Makefile b/spl/Makefile index 8b655c4..94f763e 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -83,6 +83,7 @@ LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/libnet.o LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/phy/libphy.o LIBS-$(CONFIG_SPL_MUSB_NEW_SUPPORT) += drivers/usb/musb-new/libusb_musb-new.o LIBS-$(CONFIG_SPL_USBETH_SUPPORT) += drivers/usb/gadget/libusb_gadget.o +LIBS-$(CONFIG_SPL_WATCHDOG_SUPPORT) += drivers/watchdog/libwatchdog.o
ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TI814X),) LIBS-y += $(CPUDIR)/omap-common/libomap-common.o
Reviewed-by: Tom Rini trini@ti.com
Heiko Schocher
