[U-Boot] [PATCH] rockchip: use dummy byte only enable OF_PLATDATA
Add a condition to determine the rk3288_sdram_channel size.
This patch fixes read sdram_channel property failed from DT on rk3288 boards, which not enable OF_PLATDATA.
Signed-off-by: Ziyuan Xu xzy.xu@rock-chips.com ---
arch/arm/include/asm/arch-rockchip/sdram.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram.h b/arch/arm/include/asm/arch-rockchip/sdram.h index e08e28f..82c3d07 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram.h +++ b/arch/arm/include/asm/arch-rockchip/sdram.h @@ -24,12 +24,16 @@ struct rk3288_sdram_channel { u8 row_3_4; u8 cs0_row; u8 cs1_row; +#if CONFIG_IS_ENABLED(OF_PLATDATA) /* * For of-platdata, which would otherwise convert this into two * byte-swapped integers. With a size of 9 bytes, this struct will * appear in of-platdata as a byte array. + * + * If OF_PLATDATA enabled, need to add a dummy byte in dts.(i.e 0xff) */ u8 dummy; +#endif };
struct rk3288_sdram_pctl_timing {
Applied to u-boot-rockchip/next, thanks!
Ziyuan Xu
