[U-Boot] [PATCH] x86: fix broken qemu and edison builds
Commit 2407183f98cf130b008125ef1718ccf89a192998 breaks the qemu-x86 and edison builds.
Move ucode_base and ucode_size into common startup code, except for configs with FSP.
Signed-off-by: Ivan Gorinov ivan.gorinov@intel.com --- arch/x86/cpu/intel_common/car.S | 10 ---------- arch/x86/cpu/start.S | 10 ++++++++++ 2 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/x86/cpu/intel_common/car.S b/arch/x86/cpu/intel_common/car.S index 52a77bb..7295e0f 100644 --- a/arch/x86/cpu/intel_common/car.S +++ b/arch/x86/cpu/intel_common/car.S @@ -232,13 +232,3 @@ mtrr_table: .word 0x20C, 0x20D, 0x20E, 0x20F .word 0x210, 0x211, 0x212, 0x213 mtrr_table_end: - - .align 4 -_dt_ucode_base_size: - /* These next two fields are filled in by ifdtool */ -.globl ucode_base -ucode_base: /* Declared in microcode.h */ - .long 0 /* microcode base */ -.globl ucode_size -ucode_size: /* Declared in microcode.h */ - .long 0 /* microcode size */ diff --git a/arch/x86/cpu/start.S b/arch/x86/cpu/start.S index e4e997e..1fdd82a 100644 --- a/arch/x86/cpu/start.S +++ b/arch/x86/cpu/start.S @@ -291,3 +291,13 @@ gdt_rom2: .byte 0xcf /* flags + limit_high */ .byte 0x00 /* base_high */ #endif + +#ifndef CONFIG_HAVE_FSP + .align 4 +.globl ucode_base +ucode_base: /* Declared in microcode.h */ + .long 0 /* microcode base */ +.globl ucode_size +ucode_size: /* Declared in microcode.h */ + .long 0 /* microcode size */ +#endif
Hi Ivan,
.align 4
.align 4
The _dt_ucode_base_size symbol is dropped here, so it causes build failures on several targets.
I will squash this commit into your previous commit, and fix the build issues and sent it to the ML for review.
Regards, Bin
On Fri, Jun 22, 2018 at 10:59 AM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Ivan,
.align 4
.align 4
This patch is dropped. Found another way.
Regards, Bin
Bin Meng
Ivan Gorinov
