[U-Boot] [PATCH v2 2/2] image: Protect against overflow in unknown_msg()
Coverity complains that this can overflow. If we later increase the size of one of the strings in the table, it could happen.
Adjust the code to protect against this.
Signed-off-by: Simon Glass sjg@chromium.org Reported-by: Coverity (CID: 150964) ---
Changes in v2: - Drop unwanted #include
common/image.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/image.c b/common/image.c index 0e86c13..4255267 100644 --- a/common/image.c +++ b/common/image.c @@ -590,7 +590,7 @@ static const char *unknown_msg(enum ih_category category) static char msg[30];
strcpy(msg, "Unknown "); - strcat(msg, table_info[category].desc); + strncat(msg, table_info[category].desc, sizeof(msg) - 1);
return msg; }
Changes in v2:
- strncat(msg, table_info[category].desc, sizeof(msg) - 1);
"man strncat" on my system says:
char *strncat(char *dest, const char *src, size_t n);
If src contains n or more bytes, strncat() writes n+1 bytes to dest (n from src plus the terminating null byte). Therefore, the size of dest must be at least strlen(dest)+n+1.
return msg; }
On 27 October 2016 at 18:22, Siarhei Siamashka siarhei.siamashka@gmail.com wrote:
Changes in v2:
char *strncat(char *dest, const char *src, size_t n); ... If src contains n or more bytes, strncat() writes n+1 bytes to dest (n from src plus the terminating null byte). Therefore, the size of dest must be at least strlen(dest)+n+1.
return msg;
That's odd as it does not seem to match the U-Boot implementation. But neither does my code in fact. I'll try v3.
I suspect U-Boot's string functions could use some tests!
Siarhei Siamashka
