[U-Boot] [PATCH 1/2] drivers/rtc: prepare mvrtc for DM conversion
Split the rtc_{get,set,reset} functions so that the bodies can be used in a DM driver.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
drivers/rtc/mvrtc.c | 57 +++++++++++++++++++++++++++++++-------------- 1 file changed, 39 insertions(+), 18 deletions(-)
diff --git a/drivers/rtc/mvrtc.c b/drivers/rtc/mvrtc.c index f2a226650fc5..f7bf95c30292 100644 --- a/drivers/rtc/mvrtc.c +++ b/drivers/rtc/mvrtc.c @@ -17,19 +17,16 @@ /* This RTC does not support century, so we assume 20 */ #define CENTURY 20
-int rtc_get(struct rtc_time *t) +static int __mv_rtc_get(struct mvrtc_registers *regs, struct rtc_time *t) { u32 time; u32 date; - struct mvrtc_registers *mvrtc_regs; - - mvrtc_regs = (struct mvrtc_registers *)KW_RTC_BASE;
/* read the time register */ - time = readl(&mvrtc_regs->time); + time = readl(®s->time);
/* read the date register */ - date = readl(&mvrtc_regs->date); + date = readl(®s->date);
/* test for 12 hour clock (can't tell if it's am/pm) */ if (time & MVRTC_HRFMT_MSK) { @@ -57,13 +54,20 @@ int rtc_get(struct rtc_time *t) return 0; }
-int rtc_set(struct rtc_time *t) +#ifndef CONFIG_DM_RTC +int rtc_get(struct rtc_time *t) +{ + struct mvrtc_registers *regs; + + regs = (struct mvrtc_registers *)KW_RTC_BASE; + return __mv_rtc_get(regs, t); +} +#endif /* !CONFIG_DM_RTC */ + +static int __mv_rtc_set(struct mvrtc_registers *regs, const struct rtc_time *t) { u32 time = 0; /* sets hour format bit to zero, 24hr format. */ u32 date = 0; - struct mvrtc_registers *mvrtc_regs; - - mvrtc_regs = (struct mvrtc_registers *)KW_RTC_BASE;
/* check that this code isn't 80+ years old ;-) */ if ((t->tm_year / 100) != CENTURY) @@ -81,28 +85,45 @@ int rtc_set(struct rtc_time *t) date |= (bin2bcd(t->tm_year % 100) & MVRTC_YEAR_MSK) << MVRTC_YEAR_SFT;
/* write the time register */ - writel(time, &mvrtc_regs->time); + writel(time, ®s->time);
/* write the date register */ - writel(date, &mvrtc_regs->date); + writel(date, ®s->date);
return 0; }
-void rtc_reset(void) +#ifndef CONFIG_DM_RTC +int rtc_set(struct rtc_time *t) +{ + struct mvrtc_registers *regs; + + regs = (struct mvrtc_registers *)KW_RTC_BASE; + return __mv_rtc_set(regs, t); +} +#endif /* !CONFIG_DM_RTC */ + +static void __mv_rtc_reset(struct mvrtc_registers *regs) { u32 time; u32 sec; - struct mvrtc_registers *mvrtc_regs; - - mvrtc_regs = (struct mvrtc_registers *)KW_RTC_BASE;
/* no init routine for this RTC needed, just check that it's working */ - time = readl(&mvrtc_regs->time); + time = readl(®s->time); sec = bcd2bin((time >> MVRTC_SEC_SFT) & MVRTC_SEC_MSK); udelay(1000000); - time = readl(&mvrtc_regs->time); + time = readl(®s->time);
if (sec == bcd2bin((time >> MVRTC_SEC_SFT) & MVRTC_SEC_MSK)) printf("Error: RTC did not increment.\n"); } + +#ifndef CONFIG_DM_RTC +void rtc_reset(void) +{ + struct mvrtc_registers *regs; + + regs = (struct mvrtc_registers *)KW_RTC_BASE; + __mv_rtc_reset(regs); +} +#endif /* !CONFIG_DM_RTC */
Add DM support for the Marvell RTC driver.
drivers/rtc/Kconfig | 7 ++++++ drivers/rtc/mvrtc.c | 56 +++++++++++++++++++++++++++++++++++++++++++++ drivers/rtc/mvrtc.h | 5 ++++ 3 files changed, 68 insertions(+)
diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index 277dc3de737c..a3f8c8aecc74 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -48,6 +48,13 @@ config RTC_RX8010SJ help Support for Epson RX8010SJ Real Time Clock devices.
+config RTC_MV + bool "Enable Marvell RTC driver" + depends on DM_RTC + help + Enable Marvell RTC driver. This driver supports the rtc that is present + on some Marvell SoCs. + config RTC_S35392A bool "Enable S35392A driver" select BITREVERSE diff --git a/drivers/rtc/mvrtc.c b/drivers/rtc/mvrtc.c index f7bf95c30292..94a065379c91 100644 --- a/drivers/rtc/mvrtc.c +++ b/drivers/rtc/mvrtc.c @@ -10,6 +10,7 @@
#include <common.h> #include <command.h> +#include <dm.h> #include <rtc.h> #include <asm/io.h> #include "mvrtc.h" @@ -127,3 +128,58 @@ void rtc_reset(void) __mv_rtc_reset(regs); } #endif /* !CONFIG_DM_RTC */ + +#ifdef CONFIG_DM_RTC +static int mv_rtc_get(struct udevice *dev, struct rtc_time *tm) +{ + struct mvrtc_pdata *pdata = dev_get_platdata(dev); + struct mvrtc_registers *regs = (struct mvrtc_registers *)pdata->iobase; + + return __mv_rtc_get(regs, tm); +} + +static int mv_rtc_set(struct udevice *dev, const struct rtc_time *tm) +{ + struct mvrtc_pdata *pdata = dev_get_platdata(dev); + struct mvrtc_registers *regs = (struct mvrtc_registers *)pdata->iobase; + + return __mv_rtc_set(regs, tm); +} + +static int mv_rtc_reset(struct udevice *dev) +{ + struct mvrtc_pdata *pdata = dev_get_platdata(dev); + struct mvrtc_registers *regs = (struct mvrtc_registers *)pdata->iobase; + + __mv_rtc_reset(regs); + return 0; +} + +static const struct rtc_ops mv_rtc_ops = { + .get = mv_rtc_get, + .set = mv_rtc_set, + .reset = mv_rtc_reset, +}; + +static const struct udevice_id mv_rtc_ids[] = { + { .compatible = "marvell,kirkwood-rtc" }, + { .compatible = "marvell,orion-rtc" }, + { } +}; + +static int mv_rtc_ofdata_to_platdata(struct udevice *dev) +{ + struct mvrtc_pdata *pdata = dev_get_platdata(dev); + + pdata->iobase = devfdt_get_addr(dev); + return 0; +} + +U_BOOT_DRIVER(rtc_mv) = { + .name = "rtc-mv", + .id = UCLASS_RTC, + .ofdata_to_platdata = mv_rtc_ofdata_to_platdata, + .of_match = mv_rtc_ids, + .ops = &mv_rtc_ops, +}; +#endif /* CONFIG_DM_RTC */ diff --git a/drivers/rtc/mvrtc.h b/drivers/rtc/mvrtc.h index dc470a9b73c9..87ff43299cad 100644 --- a/drivers/rtc/mvrtc.h +++ b/drivers/rtc/mvrtc.h @@ -20,6 +20,11 @@ struct mvrtc_registers { u32 date; };
+/* Platform data */ +struct mvrtc_pdata { + phys_addr_t iobase; +}; + /* time register */ #define MVRTC_SEC_SFT 0 #define MVRTC_SEC_MSK 0x7f
Thanks, Stefan
Signed-off-by: Chris Packham judge.packham@gmail.com Reviewed-by: Stefan Roese sr@denx.de
Thanks, Stefan
Chris Packham
Stefan Roese
