[U-Boot] [PATCH 1/1] efi_loader: fix function comments in cmd/bootefi.c
Describe efi_set_bootdev().
Change function descriptions to Sphinx style.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 16 +++++++++++++--- 1 file changed, 13 insertions(+), 3 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 04d3e3e4a7..a45bfd139f 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -24,7 +24,7 @@ DECLARE_GLOBAL_DATA_PTR; static struct efi_device_path *bootefi_image_path; static struct efi_device_path *bootefi_device_path;
-/* +/** * Set the load options of an image from an environment variable. * * @handle: the image handle @@ -143,7 +143,7 @@ done: return ret; }
-/* +/** * efi_carve_out_dt_rsv() - Carve out DT reserved memory ranges * * The mem_rsv entries of the FDT are added to the memory map. Any failures are @@ -342,7 +342,7 @@ static int do_efibootmgr(void) return CMD_RET_SUCCESS; }
-/* +/** * do_bootefi_image() - execute EFI binary * * Set up memory image for the binary to be loaded, prepare device path, and @@ -612,6 +612,16 @@ U_BOOT_CMD( bootefi_help_text );
+/** + * efi_set_bootdev() - set boot device + * + * This function is called when a file is loaded, e.g. via the 'load' command. + * We use the path to this file to inform the UEFI binary about the boot device. + * + * @dev: device, e.g. "MMC" + * @devnr: number of the device, e.g. "1:2" + * @path: path to file loaded + */ void efi_set_bootdev(const char *dev, const char *devnr, const char *path) { struct efi_device_path *device, *image; -- 2.20.1
