[U-Boot] Pull request: nand flash
The following changes since commit 662e2acb46250881ec26bc8366fc9eb1856cb7c2:
sunxi: UTOO_P66: Add missing MAINTAINERS entry (2015-03-29 14:56:48 +0200)
git://git.denx.de/u-boot-nand-flash.git
for you to fetch changes up to 55765b1842e7dcf22efa8d973c7d1b7498dd99fa:
mtd: vf610_nfc: specify transfer size before each transfer (2015-03-30 23:35:27 -0500)
---------------------------------------------------------------- Luca Ellero (2): mtd: nand: mxs: fix PIO_WORDs in mxs_nand_read_buf() mtd: nand: mxs: fix PIO_WORDs in mxs_nand_write_buf()
Peter Tyser (7): nand: Remove unused CONFIG_MTD_NAND_ECC_JFFS2 option nand: Remove unused read/write structures nand: Add verification functions cmd_nand: Verify writes to NAND dfu: nand: Verify writes nand: Remove CONFIG_MTD_NAND_VERIFY_WRITE nand: yaffs: Remove the "nand write.yaffs" command
Stefan Agner (2): mtd: vf610_nfc: mark page as dirty on block erase mtd: vf610_nfc: specify transfer size before each transfer
README | 3 - board/prodrive/alpr/nand.c | 16 ---- board/socrates/nand.c | 25 ------ common/cmd_nand.c | 27 ++----- doc/README.nand | 12 --- drivers/dfu/dfu_nand.c | 2 +- drivers/mtd/nand/davinci_nand.c | 12 --- drivers/mtd/nand/fsl_elbc_nand.c | 38 --------- drivers/mtd/nand/fsl_ifc_nand.c | 38 --------- drivers/mtd/nand/fsl_upm.c | 18 ----- drivers/mtd/nand/mpc5121_nfc.c | 26 ------ drivers/mtd/nand/mxc_nand.c | 33 -------- drivers/mtd/nand/mxs_nand.c | 4 +- drivers/mtd/nand/nand_base.c | 65 --------------- drivers/mtd/nand/nand_util.c | 156 +++++++++++++++++++++++------------- drivers/mtd/nand/ndfc.c | 18 ----- drivers/mtd/nand/vf610_nfc.c | 28 ++++--- include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/M54418TWR.h | 1 - include/configs/MPC8313ERDB.h | 1 - include/configs/MPC8315ERDB.h | 1 - include/configs/MPC837XEMDS.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8569MDS.h | 1 - include/configs/MPC8572DS.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/VCMA9.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/ethernut5.h | 1 - include/configs/ids8313.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls2085a_common.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/ve8313.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - include/linux/mtd/nand.h | 5 -- include/nand.h | 35 ++------ 53 files changed, 133 insertions(+), 462 deletions(-)
Scott Wood
