Please pull u-boot-x86/next to next branch
Hi Tom,
This PR includes the following changes for u-boot/next branch.
- Various x86 common codes updated for TPL/SPL - I2C designware driver updated for PCI - ICH SPI driver updated to support Apollo Lake - Add Intel FSP2 base support - Intel Apollo Lake platform specific drivers support - Add a new board Google Chromebook Coral
The following changes since commit 553cb06887825314e74a9bdac337467c77d1db88:
Merge tag 'dm-next-13dec19' of https://gitlab.denx.de/u-boot/custodians/u-boot-dm into next (2019-12-12 08:18:59 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-x86 next
for you to fetch changes up to a1d6dc3f84071f05574044f337dbdca70fae495d:
x86: Add chromebook_coral (2019-12-15 11:44:30 +0800)
---------------------------------------------------------------- Simon Glass (100): binman: Add a library to access binman entries dm: gpio: Allow control of GPIO uclass in SPL dm: core: Fix offset_to_ofnode() with invalid offset dm: pci: Allow delaying auto-config until after relocation dm: pci: Move pci_get_devfn() into a common file net: Move the checksum functions to lib/ i2c: designware: Tidy up PCI support i2c: designware: Avoid using static data i2c: designware: Support use in SPL x86: spi: Add helper functions for Intel Fast SPI fdt: Show the preprocessed .dts file on error dm: pinctrl: Allow enabling full pinctrl in SPL/TPL board_r: Move early-timer init later x86: timer: use a timer base of 0 x86: timer: Reduce timer code size in TPL on Intel CPUs x86: Drop unnecessary cpu code for TPL x86: Drop unnecessary interrupt code for TPL x86: power: Add an ACPI PMC uclass x86: sandbox: Add a PMC emulator and test pci: Add support for p2sb uclass sandbox: Disable mmio by default in tests sandbox: Add PCI driver and test for p2sb x86: Move UCLASS_IRQ into a separate file sandbox: Add a test for IRQ x86: Define the SPL image start x86: Reduce mrccache record alignment size x86: Correct mrccache find_next_mrc_cache() calculation x86: Adjust mrccache_get_region() to use livetree x86: Adjust mrccache_get_region() to support get_mmap() x86: Add a new global_data member for the cache record x86: Tidy up error handling in mrccache_save() x86: Update mrccache to support multiple caches x86: Add mrccache support for a 'variable' cache x86: Don't export mrccache_update() x86: Move fsp_prepare_mrc_cache() to fsp1 directory x86: Set the DRAM banks to reflect real location x86: Set up the MTRR for SDRAM x86: Don't imply libfdt or SPI flash in TPL x86: Allow removal of standard PCH drivers x86: Allow interrupt to happen once x86: fsp: Make graphics support common to FSP1/2 x86: fsp: Correct wrong header inlude in fsp_support.c x86: fsp: Add FSP2 base support x86: fsp: Set up an MTRR for the graphics frame buffer x86: fsp: Add a new arch_fsp_init_r() hook x86: fsp: Allow remembering the location of FSP-S x86: fsp: Make the notify API call common x86: Don't include the BIOS emulator in TPL x86: Add an option to include a FIT x86: Add support for newer CAR schemes x86: Disable microcode section for FSP2 x86: Update the fsp command for FSP2 x86: Update .dtsi file for FSP2 x86: Add an option to control the position of U-Boot x86: Add an option to control the position of SPL x86: Add an fdtmap and image-header x86: Don't repeat microcode in U-Boot if not needed x86: Separate out U-Boot and device tree in ROM image x86: Make MSR_PKG_POWER_SKU common spi: Correct operations check in dm_spi_xfer() x86: spi: Don't enable SPI_FLASH_BAR by default spi: ich: Move init function just above probe() spi: ich: Move the protection/lockdown code into a function spi: ich: Convert to livetree spi: ich: Fix header order spi: ich: Various small tidy-ups spi: ich: Add mmio_base to struct ich_spi_platdata dm: doc: Add a note about of-platdata and header files spi: ich: Correct max-size bug in ich_spi_adjust_size() spi: ich: Support of-platdata for fast-spi spi: ich: Support hardware sequencing spi: ich: Add support for get_mmap() method spi: ich: Add TPL support spi: ich: Add Apollo Lake support mtd: spi: Export spi_flash_std_probe() x86: Enable pinctrl in SPL and TPL x86: Add low-power subsystem (lpss) support x86: Add a generic Intel pinctrl driver x86: Add a generic Intel GPIO driver x86: Move qemu CPU fixup function into its own file x86: apl: Add basic IO addresses x86: apl: Add PMC driver x86: apl: Add UART driver x86: apl: Add pinctrl driver i2c: designware: Add Apollo Lake support x86: apl: Add systemagent driver x86: apl: Add hostbridge driver x86: apl: Add ITSS driver x86: apl: Add LPC driver x86: apl: Add PCH driver x86: apl: Add PUNIT driver spl: Add methods to find the position/size of next phase x86: apl: Add SPL loaders x86: apl: Add a CPU driver x86: apl: Add SPL/TPL init x86: apl: Add P2SB driver x86: apl: Add Kconfig and Makefile x86: apl: Add FSP structures x86: apl: Add FSP support x86: Add chromebook_coral
Kconfig | 9 +- arch/Kconfig | 9 +- arch/arm/include/asm/omap_gpio.h | 2 +- arch/arm/mach-at91/include/mach/at91sam9260.h | 2 +- arch/arm/mach-davinci/include/mach/gpio.h | 2 +- arch/arm/mach-omap2/am33xx/board.c | 4 +- arch/arm/mach-omap2/omap3/board.c | 2 +- arch/arm/mach-omap2/omap5/hwinit.c | 2 +- arch/sandbox/cpu/state.c | 1 + arch/sandbox/dts/sandbox.dtsi | 14 ++ arch/sandbox/dts/test.dts | 31 ++++ arch/sandbox/include/asm/test.h | 2 + arch/x86/Kconfig | 91 +++++++++++- arch/x86/cpu/Makefile | 4 +- arch/x86/cpu/apollolake/Kconfig | 96 +++++++++++++ arch/x86/cpu/apollolake/Makefile | 27 ++++ arch/x86/cpu/apollolake/cpu.c | 41 ++++++ arch/x86/cpu/apollolake/cpu_common.c | 17 +++ arch/x86/cpu/apollolake/cpu_spl.c | 271 +++++++++++++++++++++++++++++++++++ arch/x86/cpu/apollolake/fsp_m.c | 210 +++++++++++++++++++++++++++ arch/x86/cpu/apollolake/fsp_s.c | 661 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/apollolake/hostbridge.c | 179 +++++++++++++++++++++++ arch/x86/cpu/apollolake/itss.c | 214 ++++++++++++++++++++++++++++ arch/x86/cpu/apollolake/lpc.c | 122 ++++++++++++++++ arch/x86/cpu/apollolake/p2sb.c | 166 +++++++++++++++++++++ arch/x86/cpu/apollolake/pch.c | 36 +++++ arch/x86/cpu/apollolake/pmc.c | 216 ++++++++++++++++++++++++++++ arch/x86/cpu/apollolake/punit.c | 94 ++++++++++++ arch/x86/cpu/apollolake/spl.c | 178 +++++++++++++++++++++++ arch/x86/cpu/apollolake/systemagent.c | 23 +++ arch/x86/cpu/apollolake/uart.c | 133 +++++++++++++++++ arch/x86/cpu/broadwell/sdram.c | 8 +- arch/x86/cpu/coreboot/Kconfig | 1 + arch/x86/cpu/cpu.c | 4 + arch/x86/cpu/i386/Makefile | 2 + arch/x86/cpu/i386/cpu.c | 41 +++++- arch/x86/cpu/intel_common/Makefile | 10 ++ arch/x86/cpu/intel_common/car2.S | 448 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/intel_common/car2_uninit.S | 87 +++++++++++ arch/x86/cpu/intel_common/fast_spi.c | 73 ++++++++++ arch/x86/cpu/intel_common/lpss.c | 44 ++++++ arch/x86/cpu/irq.c | 13 -- arch/x86/cpu/ivybridge/sdram.c | 8 +- arch/x86/cpu/mp_init.c | 73 +--------- arch/x86/cpu/qfw_cpu.c | 73 ++++++++++ arch/x86/cpu/quark/dram.c | 8 +- arch/x86/cpu/slimbootloader/Kconfig | 1 + arch/x86/cpu/u-boot-spl.lds | 5 +- arch/x86/dts/Makefile | 1 + arch/x86/dts/chromebook_coral.dts | 831 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/dts/u-boot.dtsi | 91 +++++++++--- arch/x86/include/asm/arch-apollolake/cpu.h | 20 +++ arch/x86/include/asm/arch-apollolake/fsp/fsp_configs.h | 14 ++ arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h | 123 ++++++++++++++++ arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h | 292 +++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-apollolake/fsp/fsp_vpd.h | 11 ++ arch/x86/include/asm/arch-apollolake/gpio.h | 485 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-apollolake/iomap.h | 29 ++++ arch/x86/include/asm/arch-apollolake/itss.h | 43 ++++++ arch/x86/include/asm/arch-apollolake/lpc.h | 82 +++++++++++ arch/x86/include/asm/arch-apollolake/pch.h | 9 ++ arch/x86/include/asm/arch-apollolake/pm.h | 19 +++ arch/x86/include/asm/arch-apollolake/systemagent.h | 37 +++++ arch/x86/include/asm/arch-apollolake/uart.h | 20 +++ arch/x86/include/asm/arch-broadwell/cpu.h | 1 - arch/x86/include/asm/arch-ivybridge/model_206ax.h | 1 - arch/x86/include/asm/fast_spi.h | 68 +++++++++ arch/x86/include/asm/fsp/fsp_api.h | 24 ++++ arch/x86/include/asm/fsp/fsp_support.h | 7 - arch/x86/include/asm/fsp1/fsp_api.h | 21 +-- arch/x86/include/asm/fsp2/fsp_api.h | 63 ++++++++ arch/x86/include/asm/fsp2/fsp_internal.h | 97 +++++++++++++ arch/x86/include/asm/global_data.h | 25 +++- arch/x86/include/asm/intel_pinctrl.h | 306 +++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/intel_pinctrl_defs.h | 373 ++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/lpss.h | 36 +++++ arch/x86/include/asm/mrccache.h | 29 ++-- arch/x86/include/asm/msr-index.h | 10 +- arch/x86/include/asm/processor.h | 12 +- arch/x86/include/asm/spl.h | 1 + arch/x86/lib/Makefile | 2 + arch/x86/lib/fsp/Makefile | 3 + arch/x86/lib/fsp/fsp_common.c | 20 --- arch/x86/lib/fsp/fsp_dram.c | 35 ++++- arch/x86/lib/{fsp1 => fsp}/fsp_graphics.c | 6 +- arch/x86/lib/fsp/fsp_support.c | 2 +- arch/x86/lib/fsp1/Makefile | 1 - arch/x86/lib/fsp1/fsp_common.c | 20 +++ arch/x86/lib/fsp1/fsp_dram.c | 8 +- arch/x86/lib/fsp2/Makefile | 10 ++ arch/x86/lib/fsp2/fsp_common.c | 13 ++ arch/x86/lib/fsp2/fsp_dram.c | 78 ++++++++++ arch/x86/lib/fsp2/fsp_init.c | 191 +++++++++++++++++++++++++ arch/x86/lib/fsp2/fsp_meminit.c | 97 +++++++++++++ arch/x86/lib/fsp2/fsp_silicon_init.c | 54 +++++++ arch/x86/lib/fsp2/fsp_support.c | 131 +++++++++++++++++ arch/x86/lib/mrccache.c | 204 ++++++++++++++++---------- arch/x86/lib/pirq_routing.c | 10 ++ board/freescale/imx8qm_mek/imx8qm_mek.c | 2 +- board/freescale/imx8qxp_mek/imx8qxp_mek.c | 2 +- board/gateworks/gw_ventana/Kconfig | 3 + board/google/Kconfig | 15 ++ board/google/chromebook_coral/Kconfig | 43 ++++++ board/google/chromebook_coral/MAINTAINERS | 6 + board/google/chromebook_coral/Makefile | 5 + board/google/chromebook_coral/coral.c | 19 +++ board/toradex/apalis-imx8/apalis-imx8.c | 2 +- cmd/Kconfig | 8 ++ cmd/Makefile | 1 + cmd/pmc.c | 81 +++++++++++ cmd/x86/fsp.c | 65 ++++++--- common/board_r.c | 32 ++++- common/spl/spl.c | 20 +++ configs/chromebook_coral_defconfig | 102 +++++++++++++ configs/chromebook_samus_tpl_defconfig | 3 + configs/omap35_logic_defconfig | 1 + configs/qemu-x86_64_defconfig | 1 + configs/sandbox64_defconfig | 4 + configs/sandbox_defconfig | 2 + configs/sandbox_flattree_defconfig | 4 + configs/sandbox_spl_defconfig | 4 + configs/tools-only_defconfig | 2 + doc/board/google/chromebook_coral.rst | 241 +++++++++++++++++++++++++++++++ doc/board/google/index.rst | 1 + doc/device-tree-bindings/gpio/intel,apl-gpio.txt | 55 +++++++ doc/device-tree-bindings/pci/x86-pci.txt | 24 ++++ doc/device-tree-bindings/pinctrl/intel,apl-pinctrl.txt | 39 +++++ doc/driver-model/of-plat.rst | 6 + drivers/Makefile | 1 + drivers/core/util.c | 20 +++ drivers/gpio/Kconfig | 31 ++++ drivers/gpio/Makefile | 5 +- drivers/gpio/at91_gpio.c | 6 +- drivers/gpio/atmel_pio4.c | 2 +- drivers/gpio/da8xx_gpio.c | 7 +- drivers/gpio/da8xx_gpio.h | 2 +- drivers/gpio/intel_gpio.c | 161 +++++++++++++++++++++ drivers/gpio/mxc_gpio.c | 4 +- drivers/gpio/mxs_gpio.c | 4 +- drivers/gpio/omap_gpio.c | 6 +- drivers/gpio/sunxi_gpio.c | 8 +- drivers/i2c/Makefile | 3 + drivers/i2c/designware_i2c.c | 106 +++----------- drivers/i2c/designware_i2c.h | 35 +++++ drivers/i2c/designware_i2c_pci.c | 144 +++++++++++++++++++ drivers/i2c/i2c-uclass.c | 6 +- drivers/i2c/muxes/pca954x.c | 4 +- drivers/misc/Kconfig | 42 ++++++ drivers/misc/Makefile | 5 + drivers/misc/irq-uclass.c | 53 +++++++ drivers/misc/irq_sandbox.c | 55 +++++++ drivers/misc/p2sb-uclass.c | 216 ++++++++++++++++++++++++++++ drivers/misc/p2sb_emul.c | 272 +++++++++++++++++++++++++++++++++++ drivers/misc/p2sb_sandbox.c | 39 +++++ drivers/misc/sandbox_adder.c | 60 ++++++++ drivers/mmc/fsl_esdhc_imx.c | 13 +- drivers/mmc/omap_hsmmc.c | 2 +- drivers/mtd/spi/sf_probe.c | 2 +- drivers/net/designware.c | 10 +- drivers/net/designware.h | 4 +- drivers/net/fec_mxc.c | 6 +- drivers/net/fec_mxc.h | 2 +- drivers/net/mvneta.c | 4 +- drivers/net/mvpp2.c | 9 +- drivers/net/sun8i_emac.c | 12 +- drivers/pch/Kconfig | 18 +++ drivers/pch/Makefile | 4 +- drivers/pci/pci-aardvark.c | 4 +- drivers/pci/pci-uclass.c | 31 ++-- drivers/pci/pcie_dw_mvebu.c | 4 +- drivers/pinctrl/Kconfig | 23 +++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/intel/Kconfig | 26 ++++ drivers/pinctrl/intel/Makefile | 6 + drivers/pinctrl/intel/pinctrl.c | 636 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/pinctrl/intel/pinctrl_apl.c | 192 +++++++++++++++++++++++++ drivers/power/Kconfig | 2 + drivers/power/acpi_pmc/Kconfig | 34 +++++ drivers/power/acpi_pmc/Makefile | 6 + drivers/power/acpi_pmc/acpi-pmc-uclass.c | 244 +++++++++++++++++++++++++++++++ drivers/power/acpi_pmc/pmc_emul.c | 246 ++++++++++++++++++++++++++++++++ drivers/power/acpi_pmc/sandbox.c | 97 +++++++++++++ drivers/spi/Kconfig | 1 - drivers/spi/atmel_spi.c | 10 +- drivers/spi/designware_spi.c | 4 +- drivers/spi/ich.c | 534 +++++++++++++++++++++++++++++++++++++++++++++++++++++--------------- drivers/spi/ich.h | 46 +++++- drivers/spi/spi-uclass.c | 5 +- drivers/timer/Kconfig | 23 +++ drivers/timer/tsc_timer.c | 10 +- drivers/tpm/tpm2_tis_spi.c | 2 +- include/binman.h | 45 ++++++ include/bootstage.h | 3 + include/config_uncmd_spl.h | 1 - include/configs/at91-sama5_common.h | 5 +- include/configs/chromebook_coral.h | 32 +++++ include/configs/gw_ventana.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 + include/dm/ofnode.h | 2 +- include/dm/pci.h | 43 ++++++ include/dm/uclass-id.h | 2 + include/init.h | 11 ++ include/irq.h | 88 ++++++++++++ include/p2sb.h | 135 ++++++++++++++++++ include/pci.h | 21 ++- include/power/acpi_pmc.h | 185 ++++++++++++++++++++++++ include/qfw.h | 8 ++ include/spi.h | 2 +- include/spi_flash.h | 12 ++ include/spl.h | 21 ++- lib/Kconfig | 10 ++ lib/Makefile | 3 +- lib/binman.c | 48 +++++++ lib/efi/Kconfig | 1 + lib/net_utils.c | 48 +++++++ net/Makefile | 1 - net/checksum.c | 59 -------- scripts/Makefile.lib | 4 +- scripts/Makefile.uncmd_spl | 1 - test/dm/Makefile | 3 + test/dm/irq.c | 32 +++++ test/dm/p2sb.c | 28 ++++ test/dm/pmc.c | 33 +++++ 223 files changed, 12370 insertions(+), 706 deletions(-) create mode 100644 arch/x86/cpu/apollolake/Kconfig create mode 100644 arch/x86/cpu/apollolake/Makefile create mode 100644 arch/x86/cpu/apollolake/cpu.c create mode 100644 arch/x86/cpu/apollolake/cpu_common.c create mode 100644 arch/x86/cpu/apollolake/cpu_spl.c create mode 100644 arch/x86/cpu/apollolake/fsp_m.c create mode 100644 arch/x86/cpu/apollolake/fsp_s.c create mode 100644 arch/x86/cpu/apollolake/hostbridge.c create mode 100644 arch/x86/cpu/apollolake/itss.c create mode 100644 arch/x86/cpu/apollolake/lpc.c create mode 100644 arch/x86/cpu/apollolake/p2sb.c create mode 100644 arch/x86/cpu/apollolake/pch.c create mode 100644 arch/x86/cpu/apollolake/pmc.c create mode 100644 arch/x86/cpu/apollolake/punit.c create mode 100644 arch/x86/cpu/apollolake/spl.c create mode 100644 arch/x86/cpu/apollolake/systemagent.c create mode 100644 arch/x86/cpu/apollolake/uart.c create mode 100644 arch/x86/cpu/intel_common/car2.S create mode 100644 arch/x86/cpu/intel_common/car2_uninit.S create mode 100644 arch/x86/cpu/intel_common/fast_spi.c create mode 100644 arch/x86/cpu/intel_common/lpss.c create mode 100644 arch/x86/cpu/qfw_cpu.c create mode 100644 arch/x86/dts/chromebook_coral.dts create mode 100644 arch/x86/include/asm/arch-apollolake/cpu.h create mode 100644 arch/x86/include/asm/arch-apollolake/fsp/fsp_configs.h create mode 100644 arch/x86/include/asm/arch-apollolake/fsp/fsp_m_upd.h create mode 100644 arch/x86/include/asm/arch-apollolake/fsp/fsp_s_upd.h create mode 100644 arch/x86/include/asm/arch-apollolake/fsp/fsp_vpd.h create mode 100644 arch/x86/include/asm/arch-apollolake/gpio.h create mode 100644 arch/x86/include/asm/arch-apollolake/iomap.h create mode 100644 arch/x86/include/asm/arch-apollolake/itss.h create mode 100644 arch/x86/include/asm/arch-apollolake/lpc.h create mode 100644 arch/x86/include/asm/arch-apollolake/pch.h create mode 100644 arch/x86/include/asm/arch-apollolake/pm.h create mode 100644 arch/x86/include/asm/arch-apollolake/systemagent.h create mode 100644 arch/x86/include/asm/arch-apollolake/uart.h create mode 100644 arch/x86/include/asm/fast_spi.h create mode 100644 arch/x86/include/asm/fsp/fsp_api.h create mode 100644 arch/x86/include/asm/fsp2/fsp_api.h create mode 100644 arch/x86/include/asm/fsp2/fsp_internal.h create mode 100644 arch/x86/include/asm/intel_pinctrl.h create mode 100644 arch/x86/include/asm/intel_pinctrl_defs.h create mode 100644 arch/x86/include/asm/lpss.h rename arch/x86/lib/{fsp1 => fsp}/fsp_graphics.c (95%) create mode 100644 arch/x86/lib/fsp2/Makefile create mode 100644 arch/x86/lib/fsp2/fsp_common.c create mode 100644 arch/x86/lib/fsp2/fsp_dram.c create mode 100644 arch/x86/lib/fsp2/fsp_init.c create mode 100644 arch/x86/lib/fsp2/fsp_meminit.c create mode 100644 arch/x86/lib/fsp2/fsp_silicon_init.c create mode 100644 arch/x86/lib/fsp2/fsp_support.c create mode 100644 board/google/chromebook_coral/Kconfig create mode 100644 board/google/chromebook_coral/MAINTAINERS create mode 100644 board/google/chromebook_coral/Makefile create mode 100644 board/google/chromebook_coral/coral.c create mode 100644 cmd/pmc.c create mode 100644 configs/chromebook_coral_defconfig create mode 100644 doc/board/google/chromebook_coral.rst create mode 100644 doc/device-tree-bindings/gpio/intel,apl-gpio.txt create mode 100644 doc/device-tree-bindings/pci/x86-pci.txt create mode 100644 doc/device-tree-bindings/pinctrl/intel,apl-pinctrl.txt create mode 100644 drivers/gpio/intel_gpio.c create mode 100644 drivers/i2c/designware_i2c_pci.c create mode 100644 drivers/misc/irq-uclass.c create mode 100644 drivers/misc/irq_sandbox.c create mode 100644 drivers/misc/p2sb-uclass.c create mode 100644 drivers/misc/p2sb_emul.c create mode 100644 drivers/misc/p2sb_sandbox.c create mode 100644 drivers/misc/sandbox_adder.c create mode 100644 drivers/pinctrl/intel/Kconfig create mode 100644 drivers/pinctrl/intel/Makefile create mode 100644 drivers/pinctrl/intel/pinctrl.c create mode 100644 drivers/pinctrl/intel/pinctrl_apl.c create mode 100644 drivers/power/acpi_pmc/Kconfig create mode 100644 drivers/power/acpi_pmc/Makefile create mode 100644 drivers/power/acpi_pmc/acpi-pmc-uclass.c create mode 100644 drivers/power/acpi_pmc/pmc_emul.c create mode 100644 drivers/power/acpi_pmc/sandbox.c create mode 100644 include/binman.h create mode 100644 include/configs/chromebook_coral.h create mode 100644 include/dm/pci.h create mode 100644 include/irq.h create mode 100644 include/p2sb.h create mode 100644 include/power/acpi_pmc.h create mode 100644 lib/binman.c delete mode 100644 net/checksum.c create mode 100644 test/dm/irq.c create mode 100644 test/dm/p2sb.c create mode 100644 test/dm/pmc.c
Regards, Bin
On Sun, Dec 15, 2019 at 09:16:29PM +0800, Bin Meng wrote:
Hi Tom,
+(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) ../drivers/misc/p2sb_emul.c: In function 'sandbox_p2sb_emul_map_physmem': +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) ../drivers/misc/p2sb_emul.c:236:6: error: 'child' may be used uninitialized in this function [-Werror=maybe-uninitialized] +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) ret = axi_read(child, offset, priv->regs, AXI_SIZE_32); +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) ^ +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) cc1: all warnings being treated as errors +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) make[3]: *** [drivers/misc/p2sb_emul.o] Error 1 +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) make[2]: *** [drivers/misc] Error 2 +(sandbox,sandbox64,sandbox_flattree,sandbox_spl,tools-only) make[1]: *** [drivers] Error 2
Is what I see with this applied, please address, thanks!
Hi Tom,
Hi Tom,
That's weird. As both GitLab and Azure did not complain anything. See:
https://gitlab.denx.de/u-boot/custodians/u-boot-x86/pipelines/1647 https://dev.azure.com/bmeng/GitHub/_build/results?buildId=146&view=resul...
Regards, Bin
On Tue, Dec 17, 2019 at 09:24:14PM +0800, Bin Meng wrote:
Hi Tom,
Hi Tom,
I'm pretty sure it's a local merge problem, so, sorry about that.
Bin Meng
