[PATCH] board: fsl_validate: Fix resource leak issue
Free dynamically allocated memory before every return statement in calc_img_key_hash() function. Verified the secure boot changes using ls1046afrwy board. Signed-off-by: Kshitiz Varshney kshitiz.varshney@nxp.com --- board/freescale/common/fsl_validate.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/board/freescale/common/fsl_validate.c b/board/freescale/common/fsl_validate.c index 564a8b3b54..d553bd88a0 100644 --- a/board/freescale/common/fsl_validate.c +++ b/board/freescale/common/fsl_validate.c @@ -498,8 +498,11 @@ static int calc_img_key_hash(struct fsl_secboot_img_priv *img) return ret;
ret = algo->hash_init(algo, &ctx); - if (ret) + if (ret) { + if (ctx) + free(ctx); return ret; + }
/* Update hash for ESBC key */ #ifdef CONFIG_KEY_REVOCATION @@ -518,8 +521,11 @@ static int calc_img_key_hash(struct fsl_secboot_img_priv *img)
/* Copy hash at destination buffer */ ret = algo->hash_finish(algo, ctx, hash_val, algo->digest_size); - if (ret) + if (ret) { + if (ctx) + free(ctx); return ret; + }
for (i = 0; i < SHA256_BYTES; i++) img->img_key_hash[i] = hash_val[i];
Kshitiz Varshney
