[PATCH] arm: kirkwood: Enable bootstd for Pogo V4 board
Enable bootstd for Pogo V4 board, and remove distroboot.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
configs/pogo_v4_defconfig | 3 ++- include/configs/pogo_v4.h | 35 ++--------------------------------- 2 files changed, 4 insertions(+), 34 deletions(-)
diff --git a/configs/pogo_v4_defconfig b/configs/pogo_v4_defconfig index 2747c3c72d..ff6411d894 100644 --- a/configs/pogo_v4_defconfig +++ b/configs/pogo_v4_defconfig @@ -17,7 +17,8 @@ CONFIG_IDENT_STRING="\nPogoplug V4" CONFIG_SYS_LOAD_ADDR=0x800000 CONFIG_PCI=y CONFIG_LTO=y -CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y CONFIG_BOOTSTAGE=y CONFIG_SHOW_BOOT_PROGRESS=y CONFIG_BOOTDELAY=10 diff --git a/include/configs/pogo_v4.h b/include/configs/pogo_v4.h index 3371579023..d5003538da 100644 --- a/include/configs/pogo_v4.h +++ b/include/configs/pogo_v4.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright (C) 2014-2022 Tony Dinh mibodhi@gmail.com + * Copyright (C) 2014-2023 Tony Dinh mibodhi@gmail.com * * Based on * Copyright (C) 2012 @@ -21,33 +21,6 @@ */ #include "mv-common.h"
-/* Include the common distro boot environment */ -#ifndef CONFIG_SPL_BUILD - -#ifdef CONFIG_MMC -#define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) -#else -#define BOOT_TARGET_DEVICES_MMC(func) -#endif - -#ifdef CONFIG_SATA -#define BOOT_TARGET_DEVICES_SATA(func) func(SATA, sata, 0) -#else -#define BOOT_TARGET_DEVICES_SATA(func) -#endif - -#ifdef CONFIG_USB_STORAGE -#define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) -#else -#define BOOT_TARGET_DEVICES_USB(func) -#endif - -#define BOOT_TARGET_DEVICES(func) \ - BOOT_TARGET_DEVICES_MMC(func) \ - BOOT_TARGET_DEVICES_USB(func) \ - BOOT_TARGET_DEVICES_SATA(func) \ - func(DHCP, dhcp, na) - #define KERNEL_ADDR_R __stringify(0x800000) #define FDT_ADDR_R __stringify(0x2c00000) #define RAMDISK_ADDR_R __stringify(0x01100000) @@ -59,14 +32,10 @@ "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \ "scriptaddr=" SCRIPT_ADDR_R "\0"
-#include <config_distro_bootcmd.h> - #define CFG_EXTRA_ENV_SETTINGS \ LOAD_ADDRESS_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ - "console=ttyS0,115200\0" \ - BOOTENV -#endif /* CONFIG_SPL_BUILD */ + "console=ttyS0,115200\0"
#endif /* _CONFIG_POGO_V4_H */
Thanks, Stefan
- Copyright (C) 2014-2022 Tony Dinh mibodhi@gmail.com
- Copyright (C) 2014-2023 Tony Dinh mibodhi@gmail.com
- Based on
- Copyright (C) 2012
- BOOTENV
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
Thanks, Stefan
* * Based on * Copyright (C) 2012 @@ -21,33 +21,6 @@ */ #include "mv-common.h" -/* Include the common distro boot environment */ -#ifndef CONFIG_SPL_BUILD
#define KERNEL_ADDR_R __stringify(0x800000) #define FDT_ADDR_R __stringify(0x2c00000) #define RAMDISK_ADDR_R __stringify(0x01100000) @@ -59,14 +32,10 @@ "ramdisk_addr_r=" RAMDISK_ADDR_R "\0" \ "scriptaddr=" SCRIPT_ADDR_R "\0" -#include <config_distro_bootcmd.h>
#define CFG_EXTRA_ENV_SETTINGS \ LOAD_ADDRESS_ENV_SETTINGS \ "fdtfile=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ - "console=ttyS0,115200\0" \ - BOOTENV -#endif /* CONFIG_SPL_BUILD */ + "console=ttyS0,115200\0" #endif /* _CONFIG_POGO_V4_H */
Stefan Roese
Tony Dinh
