[PATCH] Check curve_name for null to avoid crash
If mixed rsa and ecdsa keys are specified in dtsi, an rsa key can be sent into the ecdsa verify. Without the ecdsa,curve property, this function will crash due to lack of checking the null pointer return. Signed-off-by: Bob Wolff bob.wolff68@gmail.com ---
lib/ecdsa/ecdsa-verify.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/lib/ecdsa/ecdsa-verify.c b/lib/ecdsa/ecdsa-verify.c index 0601700c4f..4d1835b598 100644 --- a/lib/ecdsa/ecdsa-verify.c +++ b/lib/ecdsa/ecdsa-verify.c @@ -31,6 +31,11 @@ static int fdt_get_key(struct ecdsa_public_key *key, const void *fdt, int node) int x_len, y_len;
key->curve_name = fdt_getprop(fdt, node, "ecdsa,curve", NULL); + if (!key->curve_name) { + debug("Error: ecdsa cannot get 'ecdsa,curve' property from key. Likely not an ecdsa key.\n"); + return -ENOMSG; + } + key->size_bits = ecdsa_key_size(key->curve_name); if (key->size_bits == 0) { debug("Unknown ECDSA curve '%s'", key->curve_name);
nit: there should be a blank line here
- if (!key->curve_name) {
return -ENOMSG;
- key->size_bits = ecdsa_key_size(key->curve_name); if (key->size_bits == 0) { debug("Unknown ECDSA curve '%s'", key->curve_name);
Reviewed-by: Sean Anderson seanga2@gmail.com
Bob Wolff
Sean Anderson
