[U-Boot] [PATCH 2/2][v2] armv8: ls2085a: Add support of LS2085A SoC
Freescale's LS2085A is a another personality of LS2080A SoC with support of AIOP and DP-DDR. This Patch adds support of LS2085A Personality.
Signed-off-by: Pratiyush Mohan Srivastava pratiyush.srivastava@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: Rebased on LS1043 patch set
arch/arm/cpu/armv8/fsl-layerscape/Makefile | 8 ++++++-- arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c | 5 +++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/spl.c | 4 ++-- arch/arm/include/asm/arch-fsl-layerscape/config.h | 8 +++++++- arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 +++- arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h | 2 +- configs/ls2080a_emu_defconfig | 2 +- configs/ls2080a_simu_defconfig | 2 +- configs/ls2080aqds_defconfig | 2 +- configs/ls2080aqds_nand_defconfig | 2 +- configs/ls2080ardb_defconfig | 2 +- configs/ls2080ardb_nand_defconfig | 2 +- configs/{ls2080a_emu_defconfig => ls2085a_emu_defconfig} | 2 +- configs/{ls2080a_simu_defconfig => ls2085a_simu_defconfig} | 2 +- configs/{ls2080aqds_defconfig => ls2085aqds_defconfig} | 2 +- configs/{ls2080aqds_nand_defconfig => ls2085aqds_nand_defconfig} | 2 +- configs/{ls2080ardb_defconfig => ls2085ardb_defconfig} | 2 +- configs/{ls2080ardb_nand_defconfig => ls2085ardb_nand_defconfig} | 2 +- drivers/ddr/fsl/fsl_ddr_gen4.c | 4 ++-- drivers/net/ldpaa_eth/Makefile | 1 + drivers/pci/pcie_layerscape.c | 2 +- include/configs/ls2080a_common.h | 9 +++++++-- include/configs/ls2080a_emu.h | 7 +++++++ include/configs/ls2080a_simu.h | 7 +++++++ include/linux/usb/xhci-fsl.h | 2 +- 26 files changed, 63 insertions(+), 26 deletions(-) copy configs/{ls2080a_emu_defconfig => ls2085a_emu_defconfig} (87%) copy configs/{ls2080a_simu_defconfig => ls2085a_simu_defconfig} (90%) copy configs/{ls2080aqds_defconfig => ls2085aqds_defconfig} (86%) copy configs/{ls2080aqds_nand_defconfig => ls2085aqds_nand_defconfig} (73%) copy configs/{ls2080ardb_defconfig => ls2085ardb_defconfig} (86%) copy configs/{ls2080ardb_nand_defconfig => ls2085ardb_nand_defconfig} (73%)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Makefile b/arch/arm/cpu/armv8/fsl-layerscape/Makefile index 1beb426..cce7405 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Makefile +++ b/arch/arm/cpu/armv8/fsl-layerscape/Makefile @@ -23,8 +23,12 @@ endif
ifneq ($(CONFIG_LS2080A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls2080a_serdes.o -else +endif + +ifneq ($(CONFIG_LS2085A),) +obj-$(CONFIG_SYS_HAS_SERDES) += ls2080a_serdes.o +endif + ifneq ($(CONFIG_LS1043A),) obj-$(CONFIG_SYS_HAS_SERDES) += ls1043a_serdes.o endif -endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c index ea3114c..8ef4f1c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls2080a_serdes.c @@ -28,7 +28,12 @@ static struct serdes_config serdes1_cfg_tbl[] = { SGMII1 } }, {0x26, {SGMII8, SGMII7, SGMII6, SGMII5, SGMII4, SGMII3, XFI2, XFI1 } }, {0x28, {SGMII8, SGMII7, SGMII6, SGMII5, XFI4, XFI3, XFI2, XFI1 } }, +#ifdef CONFIG_LS2080A + {0x2A, {NONE, NONE, NONE, XFI5, XFI4, XFI3, XFI2, XFI1 } }, +#endif +#ifdef CONFIG_LS2085A {0x2A, {XFI8, XFI7, XFI6, XFI5, XFI4, XFI3, XFI2, XFI1 } }, +#endif {0x2B, {SGMII8, SGMII7, SGMII6, SGMII5, XAUI1, XAUI1, XAUI1, XAUI1 } }, {0x32, {XAUI2, XAUI2, XAUI2, XAUI2, XAUI1, XAUI1, XAUI1, XAUI1 } }, {0x33, {PCIE2, PCIE2, PCIE2, PCIE2, QSGMII_C, QSGMII_D, QSGMII_A, diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 54c75e2..188dc7a 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -13,7 +13,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) #ifdef CONFIG_SYS_FSL_ERRATUM_A009635 #define PLATFORM_CYCLE_ENV_VAR "a009635_interval_val"
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/spl.c b/arch/arm/cpu/armv8/fsl-layerscape/spl.c index a3410af..3dae228 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/spl.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/spl.c @@ -48,7 +48,7 @@ void board_init_f(ulong dummy) gd = &gdata; /* Clear global data */ memset((void *)gd, 0, sizeof(gd_t)); -#ifdef CONFIG_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) arch_cpu_init(); #endif #ifdef CONFIG_FSL_IFC @@ -56,7 +56,7 @@ void board_init_f(ulong dummy) #endif board_early_init_f(); timer_init(); -#ifdef CONFIG_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) env_init(); #endif get_clocks(); diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 1b700b3..9133425 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -17,10 +17,16 @@ #define CONFIG_SYS_FSL_DDR /* Freescale DDR driver */ #define CONFIG_SYS_FSL_DDR_VER FSL_DDR_VER_5_0
-#if defined(CONFIG_LS2080A) +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) #define CONFIG_MAX_CPUS 16 #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 +#ifdef CONFIG_LS2080A #define CONFIG_NUM_DDR_CONTROLLERS 2 +#endif +#ifdef CONFIG_LS2085A +#define CONFIG_NUM_DDR_CONTROLLERS 3 +#define CONFIG_SYS_FSL_HAS_DP_DDR +#endif #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 4, 4 } #define SRDS_MAX_LANES 8 #define CONFIG_SYS_FSL_SRDS_1 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index 5a91dcb..2c93589 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -11,8 +11,10 @@ static struct cpu_type cpu_type_list[] = { #ifdef CONFIG_LS2080A CPU_TYPE_ENTRY(LS2080, LS2080, 8), #endif +#ifdef CONFIG_LS2085A CPU_TYPE_ENTRY(LS2085, LS2085, 8), CPU_TYPE_ENTRY(LS2045, LS2045, 4), +#endif CPU_TYPE_ENTRY(LS1043, LS1043, 4), };
@@ -182,7 +184,7 @@ static const struct sys_mmu_table final_mmu_table[] = { CONFIG_SYS_PCIE2_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_PCIE3_PHYS_ADDR, CONFIG_SYS_PCIE3_PHYS_ADDR, CONFIG_SYS_PCIE3_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, -#ifdef CONFIG_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) { CONFIG_SYS_PCIE4_PHYS_ADDR, CONFIG_SYS_PCIE4_PHYS_ADDR, CONFIG_SYS_PCIE4_PHYS_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, #endif diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h index 4787eec..d1fbde7 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_serdes.h @@ -9,7 +9,7 @@
#include <config.h>
-#if defined(CONFIG_LS2080A) +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) enum srds_prtcl { NONE = 0, PCIE1, diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index ebdde04..0ab2528 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_EMU=y -CONFIG_SYS_EXTRA_OPTIONS="EMU,SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="EMU,SYS_FSL_DDR4, LS2080A" # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index eb8000b..fb62962 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_SIMU=y -CONFIG_SYS_EXTRA_OPTIONS="SIMU" +CONFIG_SYS_EXTRA_OPTIONS="SIMU, LS2080A" # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index afba06b..8523dc5 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -4,7 +4,7 @@ CONFIG_TARGET_LS2080AQDS=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 40cf883..e8e9697 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 301cd7f..35b570c 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -4,7 +4,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 658c9ff..dc6692f 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2085a_emu_defconfig similarity index 87% copy from configs/ls2080a_emu_defconfig copy to configs/ls2085a_emu_defconfig index ebdde04..5f5fba9 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2085a_emu_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_EMU=y -CONFIG_SYS_EXTRA_OPTIONS="EMU,SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="EMU,SYS_FSL_DDR4, LS2085A" # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2085a_simu_defconfig similarity index 90% copy from configs/ls2080a_simu_defconfig copy to configs/ls2085a_simu_defconfig index eb8000b..d3867e5 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2085a_simu_defconfig @@ -1,6 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080A_SIMU=y -CONFIG_SYS_EXTRA_OPTIONS="SIMU" +CONFIG_SYS_EXTRA_OPTIONS="SIMU, LS2085A" # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2080aqds_defconfig b/configs/ls2085aqds_defconfig similarity index 86% copy from configs/ls2080aqds_defconfig copy to configs/ls2085aqds_defconfig index afba06b..b09d704 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2085aqds_defconfig @@ -4,7 +4,7 @@ CONFIG_TARGET_LS2080AQDS=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2085A" # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2085aqds_nand_defconfig similarity index 73% copy from configs/ls2080aqds_nand_defconfig copy to configs/ls2085aqds_nand_defconfig index 40cf883..918bec2 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2085aqds_nand_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080AQDS=y CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND,LS2085A" # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2085ardb_defconfig similarity index 86% copy from configs/ls2080ardb_defconfig copy to configs/ls2085ardb_defconfig index 301cd7f..561c412 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2085ardb_defconfig @@ -4,7 +4,7 @@ CONFIG_TARGET_LS2080ARDB=y CONFIG_DM_SPI=y CONFIG_DM_SPI_FLASH=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2085A" # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2085ardb_nand_defconfig similarity index 73% copy from configs/ls2080ardb_nand_defconfig copy to configs/ls2085ardb_nand_defconfig index 658c9ff..fd070f9 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2085ardb_nand_defconfig @@ -1,7 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_LS2080ARDB=y CONFIG_SPL=y -CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND" +CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,NAND,LS2085A" # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y diff --git a/drivers/ddr/fsl/fsl_ddr_gen4.c b/drivers/ddr/fsl/fsl_ddr_gen4.c index eefe709..7881a20 100644 --- a/drivers/ddr/fsl/fsl_ddr_gen4.c +++ b/drivers/ddr/fsl/fsl_ddr_gen4.c @@ -107,14 +107,14 @@ void fsl_ddr_set_memctl_regs(const fsl_ddr_cfg_regs_t *regs, goto step2;
#ifdef CONFIG_SYS_FSL_ERRATUM_A008336 -#ifdef CONFIG_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) /* A008336 only applies to general DDR controllers */ if ((ctrl_num == 0) || (ctrl_num == 1)) #endif ddr_out32(eddrtqcr1, 0x63b30002); #endif #ifdef CONFIG_SYS_FSL_ERRATUM_A008514 -#ifdef CONFIG_LS2080A +#if defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) /* A008514 only applies to DP-DDR controler */ if (ctrl_num == 2) #endif diff --git a/drivers/net/ldpaa_eth/Makefile b/drivers/net/ldpaa_eth/Makefile index 5587aa6..74c4916 100644 --- a/drivers/net/ldpaa_eth/Makefile +++ b/drivers/net/ldpaa_eth/Makefile @@ -7,3 +7,4 @@ obj-y += ldpaa_wriop.o obj-y += ldpaa_eth.o obj-$(CONFIG_LS2080A) += ls2080a.o +obj-$(CONFIG_LS2085A) += ls2080a.o diff --git a/drivers/pci/pcie_layerscape.c b/drivers/pci/pcie_layerscape.c index 8af6531..c1e3627 100644 --- a/drivers/pci/pcie_layerscape.c +++ b/drivers/pci/pcie_layerscape.c @@ -665,7 +665,7 @@ void ft_pci_setup(void *blob, bd_t *bd) } #endif
void pcie_set_available_streamids(void *blob, const char *pcie_path, u32 *stream_ids, int count) diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index de542c2..e3f51f7 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -11,7 +11,6 @@ #define CONFIG_REMAKE_ELF #define CONFIG_FSL_LAYERSCAPE #define CONFIG_FSL_LSCH3 -#define CONFIG_LS2080A #define CONFIG_MP #define CONFIG_GICV3 #define CONFIG_FSL_TZPC_BP147 @@ -185,7 +184,7 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_LS_MC_DRAM_DPC_OFFSET 0x00F00000 #define CONFIG_SYS_LS_MC_DPL_MAX_LENGTH 0x20000 #define CONFIG_SYS_LS_MC_DRAM_DPL_OFFSET 0x00F20000 -#ifndef CONFIG_LS2080A +#ifdef CONFIG_LS2085A #define CONFIG_SYS_LS_MC_AIOP_IMG_MAX_LENGTH 0x200000 #define CONFIG_SYS_LS_MC_DRAM_AIOP_IMG_OFFSET 0x07000000 #endif @@ -209,7 +208,13 @@ unsigned long long get_qixis_addr(void); #define CONFIG_PCIE3 /* PCIE controler 3 */ #define CONFIG_PCIE4 /* PCIE controler 4 */ #define CONFIG_PCIE_LAYERSCAPE /* Use common FSL Layerscape PCIe code */ +#ifdef CONFIG_LS2080A #define FSL_PCIE_COMPAT "fsl,ls2080a-pcie" +#endif + +#ifdef CONFIG_LS2085A +#define FSL_PCIE_COMPAT "fsl,ls2085a-pcie" +#endif
#define CONFIG_SYS_PCI_64BIT
diff --git a/include/configs/ls2080a_emu.h b/include/configs/ls2080a_emu.h index 6400f4f..4a7ba24 100644 --- a/include/configs/ls2080a_emu.h +++ b/include/configs/ls2080a_emu.h @@ -9,8 +9,15 @@
#include "ls2080a_common.h"
+#ifdef CONFIG_LS2080A #define CONFIG_IDENT_STRING " LS2080A-EMU" #define CONFIG_BOOTP_VCI_STRING "U-boot.LS2080A-EMU" +#endif + +#ifdef CONFIG_LS2085A +#define CONFIG_IDENT_STRING " LS2085A-EMU" +#define CONFIG_BOOTP_VCI_STRING "U-boot.LS2085A-EMU" +#endif
#define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 133333333 diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index 666df80..876ee30 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -9,8 +9,15 @@
+#ifdef CONFIG_LS2080A #define CONFIG_IDENT_STRING " LS2080A-SIMU" #define CONFIG_BOOTP_VCI_STRING "U-boot.LS2080A-SIMU" +#endif + +#ifdef CONFIG_LS2085A +#define CONFIG_IDENT_STRING " LS2085A-SIMU" +#define CONFIG_BOOTP_VCI_STRING "U-boot.LS2085A-SIMU" +#endif
#define CONFIG_SYS_CLK_FREQ 100000000 #define CONFIG_DDR_CLK_FREQ 133333333 diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index 80b7718..f665bf1 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -54,7 +54,7 @@ struct fsl_xhci { #if defined(CONFIG_LS102XA) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS102XA_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR 0 -#elif defined(CONFIG_LS2080A) +#elif defined(CONFIG_LS2080A) || defined(CONFIG_LS2085A) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_LS2080A_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_LS2080A_XHCI_USB2_ADDR #endif
Dropped #ifdef in cpu.h. Applied to fsl-qoriq master. Thanks.
York
Prabhakar Kushwaha
York Sun
