[U-Boot] [PATCH] board/t208x: update t2080qds/t2080rdb for errata A-007186
As errata A-007186, we need to use the alternate serdes protocol instead of those impacted protocols.
- add support for serdes protocols: 0x1b, 0x50, 0x5e, 0x64, 0x6a, 0xd2, 0x67, 0x70. - update t2080_rcw.cfg to adapt to new rcw_66_15 for t2080qds and t2080rdb.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@freescale.com --- arch/powerpc/cpu/mpc85xx/t2080_serdes.c | 26 +++++++++++++++++++++++--- board/freescale/t208xqds/eth_t208xqds.c | 8 ++++++++ board/freescale/t208xqds/t2080_rcw.cfg | 2 +- board/freescale/t208xqds/t208xqds.c | 12 +++++------- board/freescale/t208xrdb/t2080_rcw.cfg | 2 +- 5 files changed, 38 insertions(+), 12 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/t2080_serdes.c b/arch/powerpc/cpu/mpc85xx/t2080_serdes.c index 07e27de..2b7c698 100644 --- a/arch/powerpc/cpu/mpc85xx/t2080_serdes.c +++ b/arch/powerpc/cpu/mpc85xx/t2080_serdes.c @@ -43,6 +43,10 @@ static const struct serdes_config serdes1_cfg_tbl[] = { {0x6C, {XFI_FM1_MAC9, XFI_FM1_MAC10, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE4, PCIE4, PCIE4, PCIE4} }, + {0x1B, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC10, + SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, + SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, {0x1C, {SGMII_FM1_DTSEC9, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, @@ -59,18 +63,34 @@ static const struct serdes_config serdes1_cfg_tbl[] = { SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, SGMII_FM1_DTSEC3, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x50, {XAUI_FM1_MAC9, XAUI_FM1_MAC9, + XAUI_FM1_MAC9, XAUI_FM1_MAC9, + PCIE4, SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, {0x51, {XAUI_FM1_MAC9, XAUI_FM1_MAC9, XAUI_FM1_MAC9, XAUI_FM1_MAC9, PCIE4, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x5E, {HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, + HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, + PCIE4, SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, {0x5F, {HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, PCIE4, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x64, {HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, + HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, + PCIE4, SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, {0x65, {HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, HIGIG_FM1_MAC9, PCIE4, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0x6A, {XFI_FM1_MAC9, XFI_FM1_MAC10, + XFI_FM1_MAC1, XFI_FM1_MAC2, + PCIE4, SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, {0x6B, {XFI_FM1_MAC9, XFI_FM1_MAC10, XFI_FM1_MAC1, XFI_FM1_MAC2, PCIE4, SGMII_FM1_DTSEC4, @@ -115,6 +135,9 @@ static const struct serdes_config serdes1_cfg_tbl[] = { {0xD9, {PCIE3, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE4, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, + {0xD2, {PCIE3, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC1, + SGMII_FM1_DTSEC2, PCIE4, SGMII_FM1_DTSEC4, + SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, {0xD3, {PCIE3, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE4, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, @@ -127,8 +150,6 @@ static const struct serdes_config serdes1_cfg_tbl[] = { {0x66, {XFI_FM1_MAC9, XFI_FM1_MAC10, XFI_FM1_MAC1, XFI_FM1_MAC2, PCIE4, PCIE4, PCIE4, PCIE4} }, - -#if defined(CONFIG_PPC_T2081) {0xAA, {PCIE3, PCIE3, PCIE3, PCIE3, PCIE4, PCIE4, PCIE4, PCIE4} }, {0xCA, {PCIE3, SGMII_FM1_DTSEC10, SGMII_FM1_DTSEC1, @@ -137,7 +158,6 @@ static const struct serdes_config serdes1_cfg_tbl[] = { {0x70, {XFI_FM1_MAC9, XFI_FM1_MAC10, SGMII_FM1_DTSEC1, SGMII_FM1_DTSEC2, PCIE4, SGMII_FM1_DTSEC4, SGMII_FM1_DTSEC5, SGMII_FM1_DTSEC6} }, -#endif {} };
diff --git a/board/freescale/t208xqds/eth_t208xqds.c b/board/freescale/t208xqds/eth_t208xqds.c index d7a804d..5879198 100644 --- a/board/freescale/t208xqds/eth_t208xqds.c +++ b/board/freescale/t208xqds/eth_t208xqds.c @@ -416,6 +416,7 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC10, RGMII_PHY2_ADDR);
switch (srds_s1) { + case 0x1b: case 0x1c: case 0x95: case 0xa2: @@ -429,8 +430,11 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC5, SGMII_CARD_PORT3_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); break; + case 0x50: case 0x51: + case 0x5e: case 0x5f: + case 0x64: case 0x65: /* T2080QDS: XAUI/HiGig in Slot3; T2081QDS: in Slot2 */ fm_info_set_phy_address(FM1_10GEC1, FM1_10GEC1_PHY_ADDR); @@ -439,6 +443,7 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC6, SGMII_CARD_PORT4_PHY_ADDR); break; case 0x66: + case 0x67: /* * XFI does not need a PHY to work, but to avoid U-boot use * default PHY address which is zero to a MAC when it found @@ -453,6 +458,7 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_10GEC3, 6); fm_info_set_phy_address(FM1_10GEC4, 7); break; + case 0x6a: case 0x6b: fm_info_set_phy_address(FM1_10GEC1, 4); fm_info_set_phy_address(FM1_10GEC2, 5); @@ -470,6 +476,7 @@ int board_eth_init(bd_t *bis) fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); break; + case 0x70: case 0x71: /* SGMII in Slot3 */ fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT3_PHY_ADDR); @@ -625,6 +632,7 @@ int board_eth_init(bd_t *bis) fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i]));
if ((srds_s1 == 0x66) || (srds_s1 == 0x6b) || + (srds_s1 == 0x6a) || (srds_s1 == 0x70) || (srds_s1 == 0x6c) || (srds_s1 == 0x6d) || (srds_s1 == 0x71)) { /* As XFI is in cage intead of a slot, so diff --git a/board/freescale/t208xqds/t2080_rcw.cfg b/board/freescale/t208xqds/t2080_rcw.cfg index c2ad0fd..972dedc 100644 --- a/board/freescale/t208xqds/t2080_rcw.cfg +++ b/board/freescale/t208xqds/t2080_rcw.cfg @@ -3,6 +3,6 @@ aa55aa55 010e0100 #SerDes Protocol: 0x66_0x16 #Core/DDR: 1533Mhz/2133MT/s 12100017 15000000 00000000 00000000 -66160002 00008400 e8104000 c1000000 +66150002 00008400 e8104000 c1000000 00000000 00000000 00000000 000307fc 00000000 00000000 00000000 00000004 diff --git a/board/freescale/t208xqds/t208xqds.c b/board/freescale/t208xqds/t208xqds.c index 9cfc0bd..1353439 100644 --- a/board/freescale/t208xqds/t208xqds.c +++ b/board/freescale/t208xqds/t208xqds.c @@ -105,6 +105,7 @@ int brd_mux_lane_to_slot(void) /* SerDes1 is not enabled */ break; #if defined(CONFIG_T2080QDS) + case 0x1b: case 0x1c: case 0xa2: /* SD1(A:D) => SLOT3 SGMII @@ -126,6 +127,7 @@ int brd_mux_lane_to_slot(void) */ QIXIS_WRITE(brdcfg[12], 0x3a); break; + case 0x50: case 0x51: /* SD1(A:D) => SLOT3 XAUI * SD1(E) => SLOT1 PCIe4 @@ -140,6 +142,7 @@ int brd_mux_lane_to_slot(void) */ QIXIS_WRITE(brdcfg[12], 0xfe); break; + case 0x6a: case 0x6b: /* SD1(A:D) => XFI cage * SD1(E) => SLOT1 PCIe4 @@ -184,6 +187,7 @@ int brd_mux_lane_to_slot(void) QIXIS_WRITE(brdcfg[12], 0x1a); break; #elif defined(CONFIG_T2081QDS) + case 0x50: case 0x51: /* SD1(A:D) => SLOT2 XAUI * SD1(E) => SLOT1 PCIe4 x1 @@ -192,6 +196,7 @@ int brd_mux_lane_to_slot(void) QIXIS_WRITE(brdcfg[12], 0x98); QIXIS_WRITE(brdcfg[13], 0x70); break; + case 0x6a: case 0x6b: /* SD1(A:D) => XFI SFP Module * SD1(E) => SLOT1 PCIe4 x1 @@ -201,13 +206,6 @@ int brd_mux_lane_to_slot(void) QIXIS_WRITE(brdcfg[13], 0x70); break; case 0x6c: - /* SD1(A:B) => XFI SFP Module - * SD1(C:D) => SLOT2 SGMII - * SD1(E:H) => SLOT1 PCIe4 x4 - */ - QIXIS_WRITE(brdcfg[12], 0xe8); - QIXIS_WRITE(brdcfg[13], 0x0); - break; case 0x6d: /* SD1(A:B) => XFI SFP Module * SD1(C:D) => SLOT2 SGMII diff --git a/board/freescale/t208xrdb/t2080_rcw.cfg b/board/freescale/t208xrdb/t2080_rcw.cfg index cd62cc8..15e1bf4 100644 --- a/board/freescale/t208xrdb/t2080_rcw.cfg +++ b/board/freescale/t208xrdb/t2080_rcw.cfg @@ -3,6 +3,6 @@ aa55aa55 010e0100 #SerDes Protocol: 0x66_0x16 #Core/DDR: 1533Mhz/1600MT/s 120c0017 15000000 00000000 00000000 -66160002 00008400 ec104000 c1000000 +66150002 00008400 ec104000 c1000000 00000000 00000000 00000000 000307fc 00000000 00000000 00000000 00000004
Applied to u-boot-mpc85xx. Sorry for the late notice.
York
Shengzhou Liu
York Sun
