[U-Boot] [PATCH 1/3] fsl_sec: fix register layout on Layerscape architectures
On Layerscape architectures the SEC memory map is 1MB and the register blocks contained in it are 64KB aligned, not 4KB as the ccsr_sec structure currently assumes. Fix the layout of the structure for these architectures.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- include/fsl_sec.h | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/include/fsl_sec.h b/include/fsl_sec.h index 16e3fcb5a1..be08a2b88b 100644 --- a/include/fsl_sec.h +++ b/include/fsl_sec.h @@ -121,10 +121,18 @@ typedef struct ccsr_sec { u32 chanum_ls; /* CHA Number Register, LS */ u32 secvid_ms; /* SEC Version ID Register, MS */ u32 secvid_ls; /* SEC Version ID Register, LS */ +#if defined(CONFIG_FSL_LSCH2) || defined(CONFIG_FSL_LSCH3) + u8 res9[0x6f020]; +#else u8 res9[0x6020]; +#endif u32 qilcr_ms; /* Queue Interface LIODN CFG Register, MS */ u32 qilcr_ls; /* Queue Interface LIODN CFG Register, LS */ +#if defined(CONFIG_FSL_LSCH2) || defined(CONFIG_FSL_LSCH3) + u8 res10[0x8ffd8]; +#else u8 res10[0x8fd8]; +#endif } ccsr_sec_t;
#define SEC_CTPR_MS_AXI_LIODN 0x08000000
Certain PCI scenarios have more dynamic requirements, e.g. endpoints are "hot-plugged" later in the system lifetime. Add a Kconfig option that allows specifying a maximum number of end-points, per PCI controller and allocate a StreamID for each one.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 28 +++++++++++++++++ drivers/pci/pcie_layerscape_fixup.c | 38 +++++++++++++++++++++++ 2 files changed, 66 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 2b086da79b..1d633d71a8 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -571,3 +571,31 @@ config TFABOOT help Enabling this will make a U-Boot binary that is capable of being booted via TFA. + +menuconfig FSL_PCIE_STATIC_STREAM_IDS + bool "Allocate PCI streamIDs statically" + default n + depends on PCIE_LAYERSCAPE + help + Statically allocate a certain number of StreamIDs for each PCI + controller, instead of enumerating the connected endpoints and + allocate a StreamID for each one. This allocation method can + be used in more dynamic PCI scenarios, e.g. where endpoints are + "hot-plugged" later in the system bringup, by statically specifying + a maximum number of StreamIDs expected for each PCI controller. + +if FSL_PCIE_STATIC_STREAM_IDS + +config FSL_PCIE1_STREAM_IDS_COUNT + default 3 + int "Maximum number of streamIDs to allocate for PCI1 controller" + +config FSL_PCIE2_STREAM_IDS_COUNT + default 3 + int "Maximum number of streamIDs to allocate for PCI2 controller" + +config FSL_PCIE3_STREAM_IDS_COUNT + default 3 + int "Maximum number of streamIDs to allocate for PCI3 controller" + +endif diff --git a/drivers/pci/pcie_layerscape_fixup.c b/drivers/pci/pcie_layerscape_fixup.c index 1a17bd98aa..32355cbf2e 100644 --- a/drivers/pci/pcie_layerscape_fixup.c +++ b/drivers/pci/pcie_layerscape_fixup.c @@ -177,6 +177,7 @@ static void fdt_pcie_set_iommu_map_entry(void *blob, struct ls_pcie *pcie,
static void fdt_fixup_pcie(void *blob) { +#if !CONFIG_FSL_PCIE_STATIC_STREAM_IDS struct udevice *dev, *bus; struct ls_pcie *pcie; int streamid; @@ -215,6 +216,43 @@ static void fdt_fixup_pcie(void *blob) fdt_pcie_set_iommu_map_entry(blob, pcie, bdf >> 8, streamid); } +#else + static const int streamid_cnt[] = { + CONFIG_FSL_PCIE1_STREAM_IDS_COUNT, + CONFIG_FSL_PCIE2_STREAM_IDS_COUNT, + CONFIG_FSL_PCIE3_STREAM_IDS_COUNT + }; + struct ls_pcie *pcie; + int i, streamid, index; + pci_dev_t bdf; + + list_for_each_entry(pcie, &ls_pcie_list, list) { + for (i = 0; i < streamid_cnt[pcie->idx]; i++) { + streamid = ls_pcie_next_streamid(); + if (streamid < 0) { + debug("ERROR: no stream ids free\n"); + continue; + } + + index = ls_pcie_next_lut_index(pcie); + if (index < 0) { + debug("ERROR: no LUT indexes free\n"); + continue; + } + + bdf = PCI_BDF(i, 0, 0); + /* map PCI b.d.f to streamID in LUT */ + ls_pcie_lut_set_mapping(pcie, index, bdf >> 8, + streamid); + /* update msi-map in device tree */ + fdt_pcie_set_msi_map_entry(blob, pcie, bdf >> 8, + streamid); + /* update iommu-map in device tree */ + fdt_pcie_set_iommu_map_entry(blob, pcie, bdf >> 8, + streamid); + } + } +#endif /* !CONFIG_FSL_PCIE_STATIC_STREAM_IDS */ } #endif
-----Original Message----- From: upstream-release-bounces@linux.nxdi.nxp.com <upstream-release- bounces@linux.nxdi.nxp.com> On Behalf Of laurentiu.tudor@nxp.com Sent: Wednesday, January 30, 2019 5:31 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; York Sun york.sun@nxp.com Cc: Laurentiu Tudor laurentiu.tudor@nxp.com Subject: [upstream-release] [PATCH] pci: layerscape: add option to statically allocate PCI StreamIDs
- bool "Allocate PCI streamIDs statically"
- default n
- depends on PCIE_LAYERSCAPE
- help
- default 3
- int "Maximum number of streamIDs to allocate for PCI1 controller"
- default 3
- int "Maximum number of streamIDs to allocate for PCI2 controller"
- default 3
- int "Maximum number of streamIDs to allocate for PCI3 controller"
- static const int streamid_cnt[] = {
Why 3 controllers?
- struct ls_pcie *pcie;
- int i, streamid, index;
- pci_dev_t bdf;
- list_for_each_entry(pcie, &ls_pcie_list, list) {
if (streamid < 0) {
continue;
Why to continue if we are out of stream-ids?
if (index < 0) {
continue;
We can error out when out of LUT entry
streamid);
streamid);
8,
streamid);
-- 2.17.1
upstream-release mailing list upstream-release@linux.nxdi.nxp.com https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flin ux.nxdi.nxp.com%2Fmailman%2Flistinfo%2Fupstream- release&data=02%7C01%7Cbharat.bhushan%40nxp.com%7C58a43424e 5724733c5f908d686aa9f3f%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0 %7C636844464703698542&sdata=TZpx5GzIpO%2FUoGWMzDNPIy5SpH UZFkSIDQLkZn%2FZMJE%3D&reserved=0
Hi Bharat,
Actually I've sent this patch by mistake, sorry for that. I'll drop it and resend the patch series.
--- Best Regards, Laurentiu
- default n
- help
- default 3
- default 3
- default 3
Why 3 controllers?
- pci_dev_t bdf;
if (streamid < 0) {
continue;
if (index < 0) {
continue;
streamid);
streamid);
8,
streamid);
-- 2.17.1
Hi Laurentiu,
-----Original Message----- From: u-boot-bounces@linux.nxdi.nxp.com [mailto:u-boot- bounces@linux.nxdi.nxp.com] On Behalf Of laurentiu.tudor@nxp.com Sent: Wednesday, 30 January, 2019 05:31 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; York Sun york.sun@nxp.com Subject: [u-boot] [PATCH] pci: layerscape: add option to statically allocate PCI StreamIDs
Certain PCI scenarios have more dynamic requirements, e.g. endpoints are "hot- plugged" later in the system lifetime. Add a Kconfig option that allows specifying a maximum number of end-points, per PCI controller and allocate a StreamID for each one.
- default n
- help
- default 3
- default 3
- default 3
- pci_dev_t bdf;
if (streamid < 0) {
continue;
if (index < 0) {
continue;
As per my understanding, the BUS number in our SOCs would always be 0 for each PCIE controller. Only the device number and function number would change depending on the device(s) attached to PCIE controller.
streamid);
streamid);
streamid);
Wouldn't the better alternative is to fix some stream IDs against BDF in device tree itself for all the PCIE devices that we know for sure would be attached to board. And limit the available streamIDs to be used by bootloader for dynamically discovered PCIE devices.
-- 2.17.1
u-boot mailing list u-boot@linux.nxdi.nxp.com https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flinux.n xdi.nxp.com%2Fmailman%2Flistinfo%2Fu- boot&data=02%7C01%7Cpankaj.bansal%40nxp.com%7C8f02f086ad484f22 ec9608d686aaa058%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0%7C63 6844464748371835&sdata=1ls1cXUJ0AmJfqDgVxKM3FX6kpep%2F1Pvx1M ByOKl0Qc%3D&reserved=0
The SEC QI ICID setup in the QIIC_LS register is actually an offset that is being added to the ICID coming from the qman portal. Setting it with a non-zero value breaks SMMU setup as the resulting ICID is not known. On top of that, the SEC QI ICID must match the qman portal ICIDs in order to share the isolation context.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c | 2 +- arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h | 3 +-- 3 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c index 0e8649427e..3bd993bebf 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1043_ids.c @@ -43,7 +43,7 @@ struct icid_id_table icid_tbl[] = { SET_DEBUG_ICID(FSL_DEBUG_STREAM_ID), SET_QE_ICID(FSL_QE_STREAM_ID), #ifdef CONFIG_FSL_CAAM - SET_SEC_QI_ICID(FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_QI_ICID(FSL_DPAA1_STREAM_ID_END), SET_SEC_JR_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 3), SET_SEC_JR_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 4), SET_SEC_JR_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 5), diff --git a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c index 2da9adab5b..abd847b5be 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/ls1046_ids.c @@ -41,7 +41,7 @@ struct icid_id_table icid_tbl[] = { SET_ETR_ICID(FSL_ETR_STREAM_ID), SET_DEBUG_ICID(FSL_DEBUG_STREAM_ID), #ifdef CONFIG_FSL_CAAM - SET_SEC_QI_ICID(FSL_DPAA1_STREAM_ID_START + 2), + SET_SEC_QI_ICID(FSL_DPAA1_STREAM_ID_END), SET_SEC_JR_ICID_ENTRY(0, FSL_DPAA1_STREAM_ID_START + 3), SET_SEC_JR_ICID_ENTRY(1, FSL_DPAA1_STREAM_ID_START + 4), SET_SEC_JR_ICID_ENTRY(2, FSL_DPAA1_STREAM_ID_START + 5), diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index f375fe7115..e7a8801262 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -93,8 +93,7 @@ void fdt_fixup_icid(void *blob);
#define SET_SEC_QI_ICID(streamid) \ SET_ICID_ENTRY("fsl,sec-v4.0", streamid, \ - (((streamid) << 16) | (streamid)), \ - offsetof(ccsr_sec_t, qilcr_ls) + \ + 0, offsetof(ccsr_sec_t, qilcr_ls) + \ CONFIG_SYS_FSL_SEC_ADDR, \ CONFIG_SYS_FSL_SEC_ADDR)
sec_firmware reserves JR3 for it's own usage and deletes the JR3 node from the device tree. This causes this warning to be issued when doing the device tree fixup:
WARNING could not find node fsl,sec-v4.0-job-ring: FDT_ERR_NOTFOUND.
Fix it by excluding the device tree fixup for the JR reserved by sec_firmware.
Signed-off-by: Laurentiu Tudor laurentiu.tudor@nxp.com --- arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h index e7a8801262..f971af8d26 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/fsl_icid.h @@ -9,6 +9,7 @@ #include <asm/types.h> #include <fsl_qbman.h> #include <fsl_sec.h> +#include <asm/armv8/sec_firmware.h>
struct icid_id_table { const char *compat; @@ -98,7 +99,13 @@ void fdt_fixup_icid(void *blob); CONFIG_SYS_FSL_SEC_ADDR)
#define SET_SEC_JR_ICID_ENTRY(jr_num, streamid) \ - SET_ICID_ENTRY("fsl,sec-v4.0-job-ring", streamid, \ + SET_ICID_ENTRY( \ + (CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT && \ + (FSL_SEC_JR##jr_num##_OFFSET == \ + SEC_JR3_OFFSET + CONFIG_SYS_FSL_SEC_OFFSET) \ + ? NULL \ + : "fsl,sec-v4.0-job-ring"), \ + streamid, \ (((streamid) << 16) | (streamid)), \ offsetof(ccsr_sec_t, jrliodnr[jr_num].ls) + \ CONFIG_SYS_FSL_SEC_ADDR, \
-----Original Message----- From: upstream-release-bounces@linux.nxdi.nxp.com <upstream-release- bounces@linux.nxdi.nxp.com> On Behalf Of laurentiu.tudor@nxp.com Sent: Wednesday, January 30, 2019 5:31 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; York Sun york.sun@nxp.com Cc: Laurentiu Tudor laurentiu.tudor@nxp.com Subject: [upstream-release] [PATCH 3/3] armv8: fsl-layerscape: avoid DT fixup warning
Do you think it is fair to assume that firmware will always reserve JR3?
Thanks -Bharat
- SET_ICID_ENTRY( \
? NULL \
(((streamid) << 16) | (streamid)), \ offsetof(ccsr_sec_t, jrliodnr[jr_num].ls) + \ CONFIG_SYS_FSL_SEC_ADDR, \streamid, \
-- 2.17.1
upstream-release mailing list upstream-release@linux.nxdi.nxp.com https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flin ux.nxdi.nxp.com%2Fmailman%2Flistinfo%2Fupstream- release&data=02%7C01%7Cbharat.bhushan%40nxp.com%7C13292681c 0d54b7bf07e08d686aaa051%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7 C0%7C636844464719708439&sdata=XaF8UOqcTBaARb3wQuQjE%2BY7u 4VspHD2qodYvvrXXw8%3D&reserved=0
For the series: Reviewed-by: Horia Geantă horia.geanta@nxp.com
Thanks, Horia
-----Original Message----- From: upstream-release-bounces@linux.nxdi.nxp.com <upstream-release- bounces@linux.nxdi.nxp.com> On Behalf Of laurentiu.tudor@nxp.com Sent: Wednesday, January 30, 2019 5:31 PM To: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; York Sun york.sun@nxp.com Cc: Laurentiu Tudor laurentiu.tudor@nxp.com Subject: [upstream-release] [PATCH 1/3] fsl_sec: fix register layout on Layerscape architectures
Reviewed-by: Bharat Bhushan bharat.bhushan@nxp.com
- u8 res9[0x6f020];
- u8 res10[0x8ffd8];
2.17.1
upstream-release mailing list upstream-release@linux.nxdi.nxp.com https://emea01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flin ux.nxdi.nxp.com%2Fmailman%2Flistinfo%2Fupstream- release&data=02%7C01%7Cbharat.bhushan%40nxp.com%7C4ce1e3290 6cf486d062508d686aa9f4f%7C686ea1d3bc2b4c6fa92cd99c5c301635%7C0%7C0 %7C636844464713844776&sdata=siuiBHEwywauPP22fsYTU98mMJP2dS3 %2BDAAGIl0MPfM%3D&reserved=0
participants (5)
Bharat Bhushan
Horia Geanta
Laurentiu Tudor
Pankaj Bansal
