[PATCH v2 0/3] trivial printf patches
Apparently, improving the QoI of vsnprintf() is too controversial. So here are the uncontended parts of that series with Simon's R-bs added.
It's not a huge image reduction:
$ ../linux/scripts/bloat-o-meter lib/vsprintf.o.{0,1} add/remove: 0/0 grow/shrink: 0/2 up/down: 0/-218 (-218) Function old new delta printf 220 152 -68 vsnprintf_internal 2124 1974 -150 Total: Before=4878, After=4660, chg -4.47%
but still worth it.
Rasmus Villemoes (3): lib/vsprintf.c: implement printf() in terms of vprintf() lib/vsprintf.c: remove stale comment lib/vsprintf.c: remove unused ip6_addr_string()
lib/vsprintf.c | 22 ++++++---------------- 1 file changed, 6 insertions(+), 16 deletions(-)
This saves some code, both in terms of #LOC and .text size, and it is also the normal convention that foo(...) is implemented in terms of vfoo().
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- lib/vsprintf.c | 13 +------------ 1 file changed, 1 insertion(+), 12 deletions(-)
diff --git a/lib/vsprintf.c b/lib/vsprintf.c index 9dc96c81c6..cf3982eb03 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -787,22 +787,11 @@ int printf(const char *fmt, ...) { va_list args; uint i; - char printbuffer[CONFIG_SYS_PBSIZE];
va_start(args, fmt); - - /* - * For this to work, printbuffer must be larger than - * anything we ever want to print. - */ - i = vscnprintf(printbuffer, sizeof(printbuffer), fmt, args); + i = vprintf(fmt, args); va_end(args);
- /* Handle error */ - if (i <= 0) - return i; - /* Print the string */ - puts(printbuffer); return i; }
U-Boot doesn't support %pS/%pF or any other kind of kallsyms-like lookups. Remove the comment.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- lib/vsprintf.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/lib/vsprintf.c b/lib/vsprintf.c index cf3982eb03..af0a6e1dcf 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -434,9 +434,6 @@ static char *uuid_string(char *buf, char *end, u8 *addr, int field_width, * - 'i' [46] for 'raw' IPv4/IPv6 addresses, IPv6 omits the colons, IPv4 is * currently the same * - * Note: The difference between 'S' and 'F' is that on ia64 and ppc64 - * function pointers are really function descriptors, which contain a - * pointer to the real address. */ static char *pointer(const char *fmt, char *buf, char *end, void *ptr, int field_width, int precision, int flags)
There's currently no user of %p[iI]6, so including ip6_addr_string() in the image is a waste of bytes. It's easy enough to have the compiler elide it without removing the code completely.
The closest I can find to anybody "handling" ipv6 in U-Boot currently is in efi_net.c which does
if (ipv6) { ret = EFI_UNSUPPORTED;
As indicated in the comment, it can easily be put back, but preferably under a config knob.
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- lib/vsprintf.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/lib/vsprintf.c b/lib/vsprintf.c index af0a6e1dcf..c14176dd39 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -434,6 +434,9 @@ static char *uuid_string(char *buf, char *end, u8 *addr, int field_width, * - 'i' [46] for 'raw' IPv4/IPv6 addresses, IPv6 omits the colons, IPv4 is * currently the same * + * Note: IPv6 support is currently if(0)'ed out. If you ever need + * %pI6, please add an IPV6 Kconfig knob, make your code select or + * depend on that, and change the 0 below to CONFIG_IS_ENABLED(IPV6). */ static char *pointer(const char *fmt, char *buf, char *end, void *ptr, int field_width, int precision, int flags) @@ -478,7 +481,8 @@ static char *pointer(const char *fmt, char *buf, char *end, void *ptr, flags |= SPECIAL; /* Fallthrough */ case 'I': - if (fmt[1] == '6') + /* %pI6 currently unused */ + if (0 && fmt[1] == '6') return ip6_addr_string(buf, end, ptr, field_width, precision, flags); if (fmt[1] == '4')
Rasmus Villemoes
