[U-Boot] [PATCH MAKEALL coldfire] : Fix start.S:Error: Conversion of PC relative displacement to absolute
Hi all,
This fixes the following errors when running MAKEALL for coldfire : start.S: Assembler messages: start.S:320: Error: Conversion of PC relative displacement to absolute
Signed-off-by: Philippe De Muyter phdm@macqel.be
diff -ru a/cpu/mcf523x/start.S b/cpu/mcf523x/start.S --- a/cpu/mcf523x/start.S 2009-09-17 23:28:31.000000000 +0200 +++ b/cpu/mcf523x/start.S 2009-09-21 19:58:34.000000000 +0200 @@ -246,7 +246,7 @@ /* exception code */ .globl _fault _fault: - jmp _fault + bra _fault .globl _exc_handler
_exc_handler: diff -ru a/cpu/mcf52x2/start.S b/cpu/mcf52x2/start.S --- a/cpu/mcf52x2/start.S 2009-09-17 23:28:31.000000000 +0200 +++ b/cpu/mcf52x2/start.S 2009-09-21 19:47:40.000000000 +0200 @@ -317,7 +317,7 @@ /* exception code */ .globl _fault _fault: - jmp _fault + bra _fault
.globl _exc_handler _exc_handler: diff -ru a/cpu/mcf532x/start.S b/cpu/mcf532x/start.S --- a/cpu/mcf532x/start.S 2009-09-17 23:28:31.000000000 +0200 +++ b/cpu/mcf532x/start.S 2009-09-21 19:50:36.000000000 +0200 @@ -256,7 +256,7 @@ /* exception code */ .globl _fault _fault: - jmp _fault + bra _fault .globl _exc_handler
_exc_handler:
Hi all,
This fixes the following warnings when running MAKEALL for coldfire : tools/kwbimage.c: In function #kwbimage_checksum32#: tools/kwbimage.c:135: warning: format #%ld# expects type #long int#, but argument 4 has type #unsigned int#
diff -ru a/tools/kwbimage.c b/tools/kwbimage.c --- a/tools/kwbimage.c 2009-09-17 23:28:31.000000000 +0200 +++ b/tools/kwbimage.c 2009-09-21 19:40:19.000000000 +0200 @@ -131,7 +131,7 @@ return 0;
if (len % sizeof(uint32_t)) { - printf ("Error:%s[%d] - lenght is not in multiple of %ld\n", + printf ("Error:%s[%d] - length is not in multiple of %u\n", __FUNCTION__, len, sizeof(uint32_t)); return 0; }
Dear Philippe De Muyter,
In message 20090921200644.GA6670@frolo.macqel you wrote:
Hi all,
Seems you are using old code. This has long been fixed (using a %zu format).
Hi all,
That's surprising. I got a tarball last friday (3 days ago) using the snapshot button on the gitweb interface :
u-boot-3dc5e00454a58499d4f4c790b38036b0e873747e.tar.gz
Best regards
Philippe
You need this commit:
commit ceb2d57c2205db5bbd868577f756c74a2568160c Author: Wolfgang Denk wd@denx.de Date: Tue Sep 15 21:13:27 2009 +0200
kwbimage.c: Fix compile warning when building on 64 bit systems (again)
Commit 51003b89 attempted to fix a build problem on 64 bit systems, but just turned it into a build problem on 32 bit systems (silly me).
Now do the Right Thing (TM) and use a "%zu" printf format.
Also fix spelling error.
Signed-off-by: Wolfgang Denk wd@denx.de
It was merged into the master branch on 2009-09-18 23:20:12.
Dear Wolfgang,
You need this commit: ... Date: Tue Sep 15 21:13:27 2009 +0200 ... It was merged into the master branch on 2009-09-18 23:20:12.
OK, that's the explanation : I downloaded the snapshot on 2009-09-18 18:59
thanks and good night
Philippe
Hi all,
This fixes the following warnings when running MAKEALL for coldfire : cmd_bdinfo.c:354: warning: 'print_eth' defined but not used
diff -ru a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c --- a/common/cmd_bdinfo.c 2009-09-17 23:28:31.000000000 +0200 +++ b/common/cmd_bdinfo.c 2009-09-21 20:10:45.000000000 +0200 @@ -31,7 +31,7 @@
static void print_num(const char *, ulong);
-#if !defined(CONFIG_ARM) || defined(CONFIG_CMD_NET) +#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K)) || defined(CONFIG_CMD_NET) static void print_eth(int idx); #endif
@@ -349,7 +349,7 @@ printf ("%-12s= 0x%08lX\n", name, value); }
-#if !defined(CONFIG_ARM) || defined(CONFIG_CMD_NET) +#if !(defined(CONFIG_ARM) || defined(CONFIG_M68K)) || defined(CONFIG_CMD_NET) static void print_eth(int idx) { char name[10], *val;
Philippe,
The error that you encountered only happen when using linux cross compiler; however, if choosing uclinux cross compiler this will not be an issue.
Anyway, is an acked for me so that both compiler can be used without causing the problem.
Best Regards, TsiChung
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Philippe De Muyter Sent: Monday, September 21, 2009 2:49 PM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH MAKEALL coldfire] : Fix start.S:Error: Conversionof PC relative displacement to absolute
Hi all,
_exc_handler: _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Liew Tsi Chung-R5AAHP
Philippe De Muyter
