[U-Boot] [PATCH v5 1/2] armv8/fsl-layerscape: fdt: fixup LS1043A rev1 GIC node
The LS1043A rev1.1 silicon supports two types of GIC offset: 4K alignment and 64K alignment. The bit SCFG_GIC400_ALIGN[GIC_ADDR_BIT] is used to choose which offset will be used. If GIC_ADDR_BIT bit is set, 4K alignment is used, or else 64K alignment is used. The rev1.0 silicon only supports the CIG offset with 4K alignment.
GIC offset is decided by SVR and GIC_ADDR_BIT bit.
Overriding the weak smp_kick_all_cpus, the new impletment is able to detect GIC offset.
Signed-off-by: Wenbin Song wenbin.song@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com --- Changes in v5: Replace fix_gic_off with get_gic_off. Add #if condition to check CONFIG_GICV2 and CONFIG_GICV3 on smp_kick_all_cpus. Fixup gic node with 64K alignment when running on rev1.1 with GIC_ADDR_BIT cleared. --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 4 ++ arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 62 ++++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 57 ++++++++++++++++++-- arch/arm/include/asm/arch-fsl-layerscape/config.h | 26 ++++++++- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 3 +- 5 files changed, 145 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 94ec8d5..f415868 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -135,4 +135,8 @@ config SYS_FSL_DDR4 help Enable Freescale DDR4 controller.
+config HAS_FEATURE_GIC4K_ALIGN + bool + default y if ARCH_LS1043A + endmenu diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index 1a8321b..e90adb0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -126,6 +126,65 @@ void fsl_fdt_disable_usb(void *blob) } }
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN +static void fdt_fixup_gic(void *blob) +{ + int offset, err; + u64 reg[8]; + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + unsigned int rev; + struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR; + int align_4k = 1; + + rev = gur_in32(&gur->svr) & 0xff; + + if (rev > REV1_0) { + rev = scfg_in32(&scfg->gic_align) & (0x01 << GIC_ADDR_BIT); + if (!rev) + align_4k = 0; + } + + offset = fdt_subnode_offset(blob, 0, "interrupt-controller@1400000"); + if (offset < 0) { + printf("WARNING: fdt_subnode_offset can't find node %s: %s\n", + "interrupt-controller@1400000", fdt_strerror(offset)); + return; + } + + /* Fixup gic node align with 4K */ + if (align_4k) { + reg[0] = cpu_to_fdt64(GICD_BASE_4K); + reg[1] = cpu_to_fdt64(GICD_SIZE_4K); + reg[2] = cpu_to_fdt64(GICC_BASE_4K); + reg[3] = cpu_to_fdt64(GICC_SIZE_4K); + reg[4] = cpu_to_fdt64(GICH_BASE_4K); + reg[5] = cpu_to_fdt64(GICH_SIZE_4K); + reg[6] = cpu_to_fdt64(GICV_BASE_4K); + reg[7] = cpu_to_fdt64(GICV_SIZE_4K); + } else { + /* Fixup gic node align with 64K */ + reg[0] = cpu_to_fdt64(GICD_BASE); + reg[1] = cpu_to_fdt64(GICD_SIZE); + reg[2] = cpu_to_fdt64(GICC_BASE); + reg[3] = cpu_to_fdt64(GICC_SIZE); + reg[4] = cpu_to_fdt64(GICH_BASE); + reg[5] = cpu_to_fdt64(GICH_SIZE); + reg[6] = cpu_to_fdt64(GICV_BASE); + reg[7] = cpu_to_fdt64(GICV_SIZE); + } + + err = fdt_setprop(blob, offset, "reg", reg, sizeof(reg)); + if (err < 0) { + printf("WARNING: fdt_setprop can't set %s from node %s: %s\n", + "reg", "interrupt-controller@1400000", + fdt_strerror(err)); + return; + } + + return; +} +#endif + void ft_cpu_setup(void *blob, bd_t *bd) { #ifdef CONFIG_FSL_LSCH2 @@ -170,4 +229,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #endif fsl_fdt_disable_usb(blob);
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + fdt_fixup_gic(blob); +#endif } diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 5d0b7a4..d50096c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -14,6 +14,55 @@ #include <asm/arch/mp.h> #endif
+ +/* Get GIC offset +* For LS1043a rev1.0, GIC base address align with 4k. +* For LS1043a rev1.1, if DCFG_GIC400_ALIGN[GIC_ADDR_BIT] +* is set, GIC base address align with 4K, or else align +* with 64k. +* output: +* for GICv2: +* x0-> the base address of GICD +* x1-> the base address of GICC +* for GICv3: +* x0-> the base address of GICD +*/ +ENTRY(get_gic_offset) + ldr x0, =GICD_BASE +#ifdef CONFIG_GICV2 + ldr x1, =GICC_BASE +#endif +#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN + ldr x3, =DCFG_CCSR_SVR + ldr w3, [x3] + rev w3, w3 + ands w3, w3, #0xff + cmp w3, #REV1_0 + b.eq 1f + ldr x3, =SCFG_GIC400_ALIGN + ldr w3, [x3] + rev w3, w3 + tbnz w3, #GIC_ADDR_BIT, 1f + ret +1: + ldr x0, =GICD_BASE_4K + ldr x1, =GICC_BASE_4K +#endif + ret +ENDPROC(get_gic_offset) + +ENTRY(smp_kick_all_cpus) + /* Kick secondary cpus up by SGI 0 interrupt */ +#if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) + mov x29, lr /* Save LR */ + bl get_gic_offset + bl gic_kick_secondary_cpus + mov lr, x29 /* Restore LR */ +#endif + ret +ENDPROC(smp_kick_all_cpus) + + ENTRY(lowlevel_init) mov x29, lr /* Save LR */
@@ -105,15 +154,14 @@ ENTRY(lowlevel_init) /* Initialize GIC Secure Bank Status */ #if defined(CONFIG_GICV2) || defined(CONFIG_GICV3) branch_if_slave x0, 1f - ldr x0, =GICD_BASE + bl get_gic_offset bl gic_init_secure 1: #ifdef CONFIG_GICV3 ldr x0, =GICR_BASE bl gic_init_secure_percpu #elif defined(CONFIG_GICV2) - ldr x0, =GICD_BASE - ldr x1, =GICC_BASE + bl get_gic_offset bl gic_init_secure_percpu #endif #endif @@ -335,7 +383,8 @@ ENTRY(secondary_boot_func) #if defined(CONFIG_GICV3) gic_wait_for_interrupt_m x0 #elif defined(CONFIG_GICV2) - ldr x0, =GICC_BASE + bl get_gic_offset + mov x0, x1 gic_wait_for_interrupt_m x0, w1 #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 4201e0f..35f67dd 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -172,8 +172,30 @@ #define SMMU_BASE 0x09000000
/* Generic Interrupt Controller Definitions */ -#define GICD_BASE 0x01401000 -#define GICC_BASE 0x01402000 +#define GICD_BASE 0x01410000 +#define GICC_BASE 0x01420000 +#define GICH_BASE 0x01440000 +#define GICV_BASE 0x01460000 +#define GICD_SIZE 0x10000 +#define GICC_SIZE 0x20000 +#define GICH_SIZE 0x20000 +#define GICV_SIZE 0x20000 +#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN +#define GICD_BASE_4K 0x01401000 +#define GICC_BASE_4K 0x01402000 +#define GICH_BASE_4K 0x01404000 +#define GICV_BASE_4K 0x01406000 +#define GICD_SIZE_4K 0x1000 +#define GICC_SIZE_4K 0x2000 +#define GICH_SIZE_4K 0x2000 +#define GICV_SIZE_4K 0x2000 +#endif + +#define DCFG_CCSR_SVR 0x1ee00a4 +#define REV1_0 0x10 +#define REV1_1 0x11 +#define GIC_ADDR_BIT 31 +#define SCFG_GIC400_ALIGN 0x1570188
#define CONFIG_SYS_FSL_ERRATUM_A008850 #define CONFIG_SYS_FSL_ERRATUM_A009663 diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index d88543d..1dfef53 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -359,7 +359,8 @@ struct ccsr_scfg { u32 qspi_cfg; u8 res_160[0x180-0x160]; u32 dmamcr; - u8 res_184[0x18c-0x184]; + u8 res_184[0x188-0x184]; + u32 gic_align; u32 debug_icid; u8 res_190[0x1a4-0x190]; u32 snpcnfgcr;
There are two types of msi node in kernel device tree, one is for LS1043A rev1.1 silicon, the other is for rev1.0.
According to revision number, fixup the msi node.
Signed-off-by: Wenbin Song wenbin.song@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com --- Change in v5: Fixup the msi node used on rev1.0 when running on rev1.1. --- arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 + arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 115 ++++++++++++++++++++++++++++++ 2 files changed, 118 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index f415868..34ac867 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -139,4 +139,7 @@ config HAS_FEATURE_GIC4K_ALIGN bool default y if ARCH_LS1043A
+config HAS_FEATURE_ENHANCED_MSI + bool + default y if ARCH_LS1043A endmenu diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index e90adb0..5bac380 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -185,6 +185,118 @@ static void fdt_fixup_gic(void *blob) } #endif
+#ifdef CONFIG_HAS_FEATURE_ENHANCED_MSI +static int _fdt_fixup_msi_subnode(void *blob, int offset, const char *name, + int irq_0, int irq_1, int rev) +{ + int err, sub_offset, len; + u32 tmp[4][3]; + + sub_offset = fdt_subnode_offset(blob, offset, name); + if (offset < 0) { + printf("WARNING: fdt_subnode_offset can't find %s: %s\n", + name, fdt_strerror(sub_offset)); + return 0; + } + + tmp[0][0] = cpu_to_fdt32(0x0); + tmp[0][1] = cpu_to_fdt32(irq_0); + tmp[0][2] = cpu_to_fdt32(0x4); + + if (rev > REV1_0) { + tmp[1][0] = cpu_to_fdt32(0x0); + tmp[1][1] = cpu_to_fdt32(irq_1); + tmp[1][2] = cpu_to_fdt32(0x4); + tmp[2][0] = cpu_to_fdt32(0x0); + tmp[2][1] = cpu_to_fdt32(irq_1 + 1); + tmp[2][2] = cpu_to_fdt32(0x4); + tmp[3][0] = cpu_to_fdt32(0x0); + tmp[3][1] = cpu_to_fdt32(irq_1 + 2); + tmp[3][2] = cpu_to_fdt32(0x4); + len = sizeof(tmp); + } else { + len = sizeof(tmp[0]); + } + + err = fdt_setprop(blob, sub_offset, "interrupts", tmp, len); + if (err < 0) { + printf("WARNING: fdt_setprop can't set %s from node %s: %s\n", + "interrupts", name, fdt_strerror(err)); + return 0; + } + + return 1; +} + +static int _fdt_fixup_pci_msi(void *blob, const char *name, int rev) +{ + int offset, len, err; + void *p; + int val; + u32 tmp[4][8]; + + offset = fdt_path_offset(blob, name); + if (offset < 0) { + printf("WARNING: fdt_path_offset can't find path %s: %s\n", + name, fdt_strerror(offset)); + return 0; + } + + p = (char *)fdt_getprop(blob, offset, "interrupt-map", &len); + if (!p || len != sizeof(tmp)) { + printf("WARNING: fdt_getprop can't get %s from node %s\n", + "interrupt-map", name); + return 0; + } + + memcpy((char *)tmp, p, len); + + val = fdt32_to_cpu(tmp[0][6]); + if (rev > REV1_0) { + tmp[1][6] = cpu_to_fdt32(val + 1); + tmp[2][6] = cpu_to_fdt32(val + 2); + tmp[3][6] = cpu_to_fdt32(val + 3); + } else { + tmp[1][6] = cpu_to_fdt32(val); + tmp[2][6] = cpu_to_fdt32(val); + tmp[3][6] = cpu_to_fdt32(val); + } + + err = fdt_setprop(blob, offset, "interrupt-map", tmp, sizeof(tmp)); + if (err < 0) { + printf("WARNING: fdt_setprop can't set %s from node %s: %s.\n", + "interrupt-map", name, fdt_strerror(err)); + return 0; + } + return 1; +} + +/* Fixup msi to v1_0*/ + +static void fdt_fixup_msi(void *blob) +{ + int nodeoffset; + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + unsigned int rev; + + rev = gur_in32(&gur->svr) & 0xff; + + nodeoffset = fdt_path_offset(blob, "/soc/msi-controller"); + if (nodeoffset < 0) { + printf("WARNING: fdt_path_offset can't find path %s: %s\n", + "/soc/msi-controller", fdt_strerror(nodeoffset)); + return; + } + _fdt_fixup_msi_subnode(blob, nodeoffset, "msi0@1571000", 116, 111, rev); + _fdt_fixup_msi_subnode(blob, nodeoffset, "msi1@1572000", 126, 121, rev); + _fdt_fixup_msi_subnode(blob, nodeoffset, "msi2@1573000", 160, 155, rev); + + _fdt_fixup_pci_msi(blob, "/soc/pcie@3400000", rev); + _fdt_fixup_pci_msi(blob, "/soc/pcie@3500000", rev); + _fdt_fixup_pci_msi(blob, "/soc/pcie@3600000", rev); +} +#endif + void ft_cpu_setup(void *blob, bd_t *bd) { #ifdef CONFIG_FSL_LSCH2 @@ -232,4 +344,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) #ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN fdt_fixup_gic(blob); #endif +#ifdef CONFIG_HAS_FEATURE_ENHANCED_MSI + fdt_fixup_msi(blob); +#endif }
<snip>
- int offset, err;
- u64 reg[8];
- struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR);
- unsigned int rev;
- struct ccsr_scfg __iomem *scfg = (void *)CONFIG_SYS_FSL_SCFG_ADDR;
- int align_4k = 1;
- rev = gur_in32(&gur->svr) & 0xff;
- if (rev > REV1_0) {
if (!rev)
align_4k = 0;
Does this register scfg->gic_align exist for other SoCs? Can you get a consistent reading from this register if not set by PBI? If yes, can you revert the logic in PBI command to set this bit in backward compatible way?
York
Hi york:
Best Regards Wenbin Song
-----Original Message----- From: york sun Sent: Friday, October 28, 2016 11:40 PM To: Wenbin Song wenbin.song@nxp.com; albert.u.boot@aribaud.net; Mingkai Hu mingkai.hu@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH v5 1/2] armv8/fsl-layerscape: fdt: fixup LS1043A rev1 GIC node
smp_kick_all_cpus.
<snip>
+#ifdef CONFIG_HAS_FEATURE_GIC4K_ALIGN static void fdt_fixup_gic(void +*blob) {
- int offset, err;
- u64 reg[8];
- unsigned int rev;
- int align_4k = 1;
if (!rev)
align_4k = 0;
[] scfg->gic_align is a new added register on ls1043a rev1.1 or more higher to select the GIC offset by PBI. If it is set by PBI, GIC offset is 4K alignment. If it is cleared by PBI, GIC offset is 64K alignment. The reset value is cleared.
So for ls1043a rev1.1 or more higher , we are be able to select the GIC offset by using different rcw. If not set by PBI, reading from it always gets 0.
And the scfg->gic_align is reserved for other SoCs.
York
On 10/30/2016 07:10 PM, Wenbin Song wrote:
Hi york:
smp_kick_all_cpus.
<snip>
- int offset, err;
- u64 reg[8];
- unsigned int rev;
- int align_4k = 1;
if (!rev)
align_4k = 0;
So it is hard-wired to 0 for 64K. Keep you code to check the revision then. Maybe put a comment around checking the revision to warn later use for other SoCs?
York
Wenbin Song
Wenbin song
york sun
