[PATCH] Revert "common: spl_fit: Default to IH_OS_U_BOOT if FIT_IMAGE_TINY enabled"
The patch in commit cf8dcc5d02c32173b74bf1b7600dd2b990a90b13 is not correct, it will append fdt to each loadable image. Actually when using TINY FIT, the first loadable image is thought as u-boot and already have fdt appended.
Signed-off-by: Ye Li ye.li@nxp.com --- common/spl/spl_fit.c | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index aef1dbd..69dabd2 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -646,10 +646,6 @@ int spl_load_simple_fit(struct spl_image_info *spl_image,
if (!spl_fit_image_get_os(fit, node, &os_type)) debug("Loadable is %s\n", genimg_get_os_name(os_type)); -#if CONFIG_IS_ENABLED(FIT_IMAGE_TINY) - else - os_type = IH_OS_U_BOOT; -#endif
if (os_type == IH_OS_U_BOOT) { spl_fit_append_fdt(&image_info, info, sector,
Hi Ye Li,
1. "Patch in commit" is not correct. Please refer it to "commit" instead.
2. Please use the same kernel style to refer to commit: 12 SHA digit and the subject between (" xxx ")
So this would become:
Commit cf8dcc5d02c3 ("common: spl_fit: Default to IH_OS_U_BOOT if FIT_IMAGE_TINY enabled") is not correct...
Tested on a imx6q and imx6qp sabresd:
Tested-by: Fabio Estevam festevam@gmail.com
Thanks
On Tue, Mar 31, 2020 at 06:40:28AM -0300, Fabio Estevam wrote:
Hi Ye Li,
You should also mention that you're reverting the previous commit and I would really like Abel to confirm the problem they saw isn't reproducible. Thanks!
I just rebased an i.mx8mm board from v2020.04-rc4 to v2020.04-rc5 that I'm preparing for submission upstream and noticed that this commit broke start of U-Boot. Reverting this or disabling FIT_IMAGE_TINY fixes it.
-Matt
else
-#endif
-- 2.7.4
Hi Matt,
-----Original Message----- From: Matt Porter mporter@konsulko.com Sent: 2020年4月8日 5:38 To: Ye Li ye.li@nxp.com Cc: trini@konsulko.com; u-boot@lists.denx.de; Fabio Estevam fabio.estevam@nxp.com; Peng Fan peng.fan@nxp.com; Abel Vesa abel.vesa@nxp.com; dl-uboot-imx uboot-imx@nxp.com Subject: [EXT] Re: [PATCH] Revert "common: spl_fit: Default to IH_OS_U_BOOT if FIT_IMAGE_TINY enabled"
Caution: EXT Email
-Matt
The mkimage_fit_atf.sh has a bug. It reverses the u-boot and atf: atf is set as firmware, but u-boot as loadable. So when the commit is reverted, fdt is appended to atf only. Previously fdt was appended to both. I will send a patch to fix the bug.
Best regards, Ye Li
else
-#endif
-- 2.7.4
Fabio Estevam
Matt Porter
Ye Li
