[U-Boot] [PATCH 1/5] Voipac PXA270 LCD Support
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 33 +++++++++++++++++++++++++++++++++ 1 files changed, 33 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index d56c5f0..0bd52d4 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -112,6 +112,39 @@ vidinfo_t panel_info = { vl_efw: 0, }; #endif /* CONFIG_SHARP_LM8V31 */ +/*----------------------------------------------------------------------*/ +#ifdef CONFIG_VOIPAC_LCD + +# define LCD_BPP LCD_COLOR8 +# define LCD_INVERT_COLORS + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x043008f8 +# define REG_LCCR3 0x0340FF08 + +vidinfo_t panel_info = { + vl_col: 640, + vl_row: 480, + vl_width: 157, + vl_height: 118, + vl_clkp: CONFIG_SYS_HIGH, + vl_oep: CONFIG_SYS_HIGH, + vl_hsp: CONFIG_SYS_HIGH, + vl_vsp: CONFIG_SYS_HIGH, + vl_dp: CONFIG_SYS_HIGH, + vl_bpix: LCD_BPP, + vl_lbw: 0, + vl_splt: 1, + vl_clor: 1, + vl_tft: 1, + vl_hpw: 32, + vl_blw: 144, + vl_elw: 32, + vl_vpw: 2, + vl_bfw: 13, + vl_efw: 30, +}; +#endif /* CONFIG_VOIPAC_LCD */
/*----------------------------------------------------------------------*/ #ifdef CONFIG_HITACHI_SX14
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxafb.c | 34 ++++++++++++++++++++++++++++++++++ 1 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxafb.c b/arch/arm/cpu/pxa/pxafb.c index 0bd52d4..b2d332c 100644 --- a/arch/arm/cpu/pxa/pxafb.c +++ b/arch/arm/cpu/pxa/pxafb.c @@ -180,6 +180,40 @@ vidinfo_t panel_info = { #endif /* CONFIG_HITACHI_SX14 */
/*----------------------------------------------------------------------*/ +#ifdef CONFIG_LMS283GF05 + +# define LCD_BPP LCD_COLOR8 +//# define LCD_INVERT_COLORS + +/* you have to set lccr0 and lccr3 (including pcd) */ +# define REG_LCCR0 0x043008f8 +# define REG_LCCR3 0x03b00009 + +vidinfo_t panel_info = { + vl_col: 240, + vl_row: 320, + vl_width: 240, + vl_height: 320, + vl_clkp: CONFIG_SYS_HIGH, + vl_oep: CONFIG_SYS_LOW, + vl_hsp: CONFIG_SYS_LOW, + vl_vsp: CONFIG_SYS_LOW, + vl_dp: CONFIG_SYS_HIGH, + vl_bpix: LCD_BPP, + vl_lbw: 0, + vl_splt: 1, + vl_clor: 1, + vl_tft: 1, + vl_hpw: 4, + vl_blw: 4, + vl_elw: 8, + vl_vpw: 4, + vl_bfw: 4, + vl_efw: 8, +}; +#endif /* CONFIG_LMS283GF05 */ + +/*----------------------------------------------------------------------*/
#if LCD_BPP == LCD_COLOR8 void lcd_setcolreg (ushort regno, ushort red, ushort green, ushort blue);
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 2 + Makefile | 9 + board/vpac270/Makefile | 48 ++++ board/vpac270/config.mk | 1 + board/vpac270/lowlevel_init.S | 40 +++ board/vpac270/u-boot.lds | 55 +++++ board/vpac270/vpac270.c | 127 ++++++++++ include/configs/vpac270.h | 328 ++++++++++++++++++++++++++ onenand_ipl/board/vpac270/Makefile | 83 +++++++ onenand_ipl/board/vpac270/config.mk | 1 + onenand_ipl/board/vpac270/lowlevel_init.S | 34 +++ onenand_ipl/board/vpac270/u-boot.onenand.lds | 51 ++++ onenand_ipl/board/vpac270/vpac270.c | 42 ++++ 13 files changed, 821 insertions(+), 0 deletions(-) create mode 100644 board/vpac270/Makefile create mode 100644 board/vpac270/config.mk create mode 100644 board/vpac270/lowlevel_init.S create mode 100644 board/vpac270/u-boot.lds create mode 100644 board/vpac270/vpac270.c create mode 100644 include/configs/vpac270.h create mode 100644 onenand_ipl/board/vpac270/Makefile create mode 100644 onenand_ipl/board/vpac270/config.mk create mode 100644 onenand_ipl/board/vpac270/lowlevel_init.S create mode 100644 onenand_ipl/board/vpac270/u-boot.onenand.lds create mode 100644 onenand_ipl/board/vpac270/vpac270.c
diff --git a/MAKEALL b/MAKEALL index 4637390..b5a6ee1 100755 --- a/MAKEALL +++ b/MAKEALL @@ -711,6 +711,8 @@ LIST_pxa=" \ polaris \ pxa255_idp \ trizepsiv \ + vpac270_nor \ + vpac270_onenand \ wepep250 \ xaeniax \ xm250 \ diff --git a/Makefile b/Makefile index 1d87f37..07ab532 100644 --- a/Makefile +++ b/Makefile @@ -2171,6 +2171,15 @@ trizepsiv_config : unconfig fi; @$(MKCONFIG) -n $@ -a trizepsiv arm pxa trizepsiv
+vpac270_nor_config \ +vpac270_onenand_config : unconfig + @mkdir -p $(obj)include + @if [ "$(findstring onenand,$@)" ] ; then \ + echo "#define CONFIG_ONENAND_U_BOOT" \ + >>$(obj)include/config.h ; \ + fi; + @$(MKCONFIG) -n $@ -a vpac270 arm pxa vpac270 + ######################################################################### ## ARM1136 Systems ######################################################################### diff --git a/board/vpac270/Makefile b/board/vpac270/Makefile new file mode 100644 index 0000000..0f3eacd --- /dev/null +++ b/board/vpac270/Makefile @@ -0,0 +1,48 @@ + +# +# (C) Copyright 2000 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = lib$(BOARD).a + +OBJS := vpac270.o +SOBJS := lowlevel_init.o + +$(LIB): $(OBJS) $(SOBJS) + $(AR) crv $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +.depend: Makefile $(SOBJS:.o=.S) $(OBJS:.o=.c) + $(CC) -M $(CPPFLAGS) $(SOBJS:.o=.S) $(OBJS:.o=.c) > $@ + +-include .depend + +######################################################################### diff --git a/board/vpac270/config.mk b/board/vpac270/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/vpac270/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/vpac270/lowlevel_init.S b/board/vpac270/lowlevel_init.S new file mode 100644 index 0000000..ec0d12c --- /dev/null +++ b/board/vpac270/lowlevel_init.S @@ -0,0 +1,40 @@ +/* + * Voipac PXA270 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/vpac270/u-boot.lds b/board/vpac270/u-boot.lds new file mode 100644 index 0000000..58c371d --- /dev/null +++ b/board/vpac270/u-boot.lds @@ -0,0 +1,55 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(.rodata) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +} diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c new file mode 100644 index 0000000..48e93ab --- /dev/null +++ b/board/vpac270/vpac270.c @@ -0,0 +1,127 @@ +/* + * (C) Copyright 2004 + * Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ + +/* + * Miscelaneous platform dependent initialisations + */ +extern struct serial_device serial_ffuart_device; +extern struct serial_device serial_btuart_device; +extern struct serial_device serial_stuart_device; + +struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + +int board_init (void) +{ + /* memory and cpu-speed are setup before relocation */ + /* so we do _nothing_ here */ + + /* arch number of vpac270 */ + gd->bd->bi_arch_number = MACH_TYPE_VPAC270; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + return 0; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + + return 0; +} + +int usb_board_init(void) +{ + UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + + UHCHR |= UHCHR_FSBIR; + + while (UHCHR & UHCHR_FSBIR); + + UHCHR &= ~UHCHR_SSE; + UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE); + + /* Clear any OTG Pin Hold */ + if (PSSR & PSSR_OTGPH) + PSSR |= PSSR_OTGPH; + + UHCRHDA &= ~(0x200); + UHCRHDA |= 0x100; + + /* Set port power control mask bits, only 3 ports. */ + UHCRHDB |= (0x7<<17); + + /* enable port 2 */ + UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE; + + return 0; +} + +void usb_board_init_fail(void) +{ + return; +} + +void usb_board_stop(void) +{ + UHCHR |= UHCHR_FHR; + udelay(11); + UHCHR &= ~UHCHR_FHR; + + UHCCOMS |= 1; + udelay(10); + + CKEN &= ~CKEN10_USBHOST; + + return; +} + +#ifdef CONFIG_DRIVER_DM9000 +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} +#endif diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h new file mode 100644 index 0000000..9724cfc --- /dev/null +++ b/include/configs/vpac270.h @@ -0,0 +1,328 @@ +/* + * Voipac PXA270 configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_VPAC270 1 /* Voipac PXA270 board */ + +#undef BOARD_LATE_INIT +#undef CONFIG_SKIP_RELOCATE_UBOOT +#undef CONFIG_USE_IRQ +#undef CONFIG_SKIP_LOWLEVEL_INIT + +/* + * Environment settings + */ +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_ENV_OVERWRITE /* override default environment */ + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ + "if usb reset && fatload usb 0 0xa4000000 uImage; then " \ + "bootm 0xa4000000; " \ + "fi; " \ + "bootm 0x40000;" +#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_USB +#undef CONFIG_LCD +#define CONFIG_CMD_IDE + +#ifdef CONFIG_ONENAND_U_BOOT +#undef CONFIG_CMD_FLASH +#define CONFIG_CMD_ONENAND +#else +#define CONFIG_CMD_FLASH +#undef CONFIG_CMD_ONENAND +#endif + +/* + * Networking Configuration + * chip on the Voipac PXA270 board + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP + +#define CONFIG_NET_MULTI 1 +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_BASE 0x08000300 /* CS2 */ +#define DM9000_IO (CONFIG_DM9000_BASE) +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_NET_RETRY_COUNT 10 + +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.1.52 +#define CONFIG_SERVERIP 192.168.1.51 +#define CONFIG_ETHADDR 00:11:22:33:44:55 +#endif + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#else +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#endif +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* We have 2 banks of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* 128 MB */ +#define PHYS_SDRAM_2 0x80000000 /* SDRAM Bank #2 */ +#define PHYS_SDRAM_2_SIZE 0x08000000 /* 128 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x10000000 /* 256 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR (0x5c000000) + +/* + * NOR FLASH + */ +#if defined(CONFIG_CMD_FLASH) /* NOR */ +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_2 0x02000000 /* Flash Bank #2 */ + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) +#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_FLASH_BANKS_LIST { PHYS_FLASH_1, PHYS_FLASH_2 } + +#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_PROTECTION 1 + +#define CONFIG_ENV_IS_IN_FLASH 1 + +#elif defined(CONFIG_CMD_ONENAND) /* OneNAND */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ONENAND_BASE 0x00000000 +#define CONFIG_ENV_IS_IN_ONENAND 1 + +#else /* No flash */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SECT_SIZE 0x40000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + +/* + * IDE + */ +#ifdef CONFIG_CMD_IDE +#define CONFIG_LBA48 +#undef CONFIG_IDE_LED +#undef CONFIG_IDE_RESET + +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 + +#define CONFIG_SYS_ATA_BASE_ADDR 0x0c000000 +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0 + +#define CONFIG_SYS_ATA_DATA_OFFSET 0x120 +#define CONFIG_SYS_ATA_REG_OFFSET 0x120 +#define CONFIG_SYS_ATA_ALT_OFFSET 0x120 + +#define CONFIG_SYS_ATA_STRIDE 2 +#endif + +/* + * GPIO settings + */ +#define CONFIG_SYS_GPSR0_VAL 0x01308800 +#define CONFIG_SYS_GPSR1_VAL 0x00cf0000 +#define CONFIG_SYS_GPSR2_VAL 0x922ac000 +#define CONFIG_SYS_GPSR3_VAL 0x0161e800 + +#define CONFIG_SYS_GPCR0_VAL 0x00010000 +#define CONFIG_SYS_GPCR1_VAL 0x0 +#define CONFIG_SYS_GPCR2_VAL 0x0 +#define CONFIG_SYS_GPCR3_VAL 0x0 + +#define CONFIG_SYS_GPDR0_VAL 0xcbb18800 +#define CONFIG_SYS_GPDR1_VAL 0xfccfa981 +#define CONFIG_SYS_GPDR2_VAL 0x922affff +#define CONFIG_SYS_GPDR3_VAL 0x0161e904 + +#define CONFIG_SYS_GAFR0_L_VAL 0x00100000 +#define CONFIG_SYS_GAFR0_U_VAL 0xa5da8510 +#define CONFIG_SYS_GAFR1_L_VAL 0x6992901a +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa5a0aa +#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x4109a401 +#define CONFIG_SYS_GAFR3_L_VAL 0x54010310 +#define CONFIG_SYS_GAFR3_U_VAL 0x00025401 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x00500240 +#define CONFIG_SYS_CCCR 0x02000290 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x3ffc95fa +#define CONFIG_SYS_MSC1_VAL 0x02ccf974 +#define CONFIG_SYS_MSC2_VAL 0x00000000 +#define CONFIG_SYS_MDCNFG_VAL 0x8ad30ad3 +#define CONFIG_SYS_MDREFR_VAL 0x201fe01e +#define CONFIG_SYS_MDMRS_VAL 0x00000000 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 +#define CONFIG_SYS_MEM_BUF_IMP 0x0f + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000001 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +/* + * LCD + */ +#ifdef CONFIG_LCD +#define CONFIG_VOIPAC_LCD +#endif + +/* + * USB + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4C000000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "vpac270" +#define CONFIG_USB_STORAGE +#endif + +#endif /* __CONFIG_H */ diff --git a/onenand_ipl/board/vpac270/Makefile b/onenand_ipl/board/vpac270/Makefile new file mode 100644 index 0000000..22d0410 --- /dev/null +++ b/onenand_ipl/board/vpac270/Makefile @@ -0,0 +1,83 @@ +IPL =onenand_ipl +include $(TOPDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/onenand_ipl/board/$(BOARDDIR)/u-boot.onenand.lds +LDFLAGS = -Bstatic -T $(onenandobj)u-boot.lds -Ttext $(TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_PRELOADER -DCONFIG_ONENAND_IPL +CFLAGS += -DCONFIG_PRELOADER -DCONFIG_ONENAND_IPL +OBJCFLAGS += --gap-fill=0x00 + +SOBJS := lowlevel_init.o +SOBJS += start.o +COBJS := vpac270.o +COBJS += onenand_read.o +COBJS += onenand_boot.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/onenand_ipl/board/$(BOARDDIR) + +onenandobj := $(OBJTREE)/onenand_ipl/ + +ALL = $(onenandobj)onenand-ipl $(onenandobj)onenand-ipl.bin $(onenandobj)onenand-ipl-2k.bin + +all: $(obj).depend $(ALL) + +$(onenandobj)onenand-ipl-2k.bin: $(onenandobj)onenand-ipl + $(OBJCOPY) ${OBJCFLAGS} --pad-to=0x5c040400 -O binary $< $@ + +$(onenandobj)onenand-ipl.bin: $(onenandobj)onenand-ipl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(onenandobj)onenand-ipl: $(OBJS) $(onenandobj)u-boot.lds + cd $(LNDIR) && $(LD) $(LDFLAGS) $$UNDEF_SYM $(__OBJS) \ + -Map $@.map -o $@ + +$(onenandobj)u-boot.lds: $(LDSCRIPT) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + +# create symbolic links from common files + +# from cpu directory +$(obj)start.S: + @rm -f $@ + ln -s $(SRCTREE)/$(CPUDIR)/start.S $@ + +# from onenand_ipl directory +$(obj)onenand_ipl.h: + @rm -f $@ + ln -s $(SRCTREE)/onenand_ipl/onenand_ipl.h $@ + +$(obj)onenand_boot.c: $(obj)onenand_ipl.h + @rm -f $@ + ln -s $(SRCTREE)/onenand_ipl/onenand_boot.c $@ + +$(obj)onenand_read.c: $(obj)onenand_ipl.h + @rm -f $@ + ln -s $(SRCTREE)/onenand_ipl/onenand_read.c $@ + +ifneq ($(OBJTREE), $(SRCTREE)) +$(obj)vpac270.c: + @rm -f $@ + ln -s $(SRCTREE)/onenand_ipl/board/$(BOARDDIR)/vpac270.c $@ + +$(obj)lowlevel_init.S: + @rm -f $@ + ln -s $(SRCTREE)/onenand_ipl/board/$(BOARDDIR)/lowlevel_init.S $@ +endif + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)$.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/onenand_ipl/board/vpac270/config.mk b/onenand_ipl/board/vpac270/config.mk new file mode 100644 index 0000000..f071dea --- /dev/null +++ b/onenand_ipl/board/vpac270/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x5c03fc00 diff --git a/onenand_ipl/board/vpac270/lowlevel_init.S b/onenand_ipl/board/vpac270/lowlevel_init.S new file mode 100644 index 0000000..e79d8dd --- /dev/null +++ b/onenand_ipl/board/vpac270/lowlevel_init.S @@ -0,0 +1,34 @@ +/* + * Voipac PXA270 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_clock_setup + mov pc, lr diff --git a/onenand_ipl/board/vpac270/u-boot.onenand.lds b/onenand_ipl/board/vpac270/u-boot.onenand.lds new file mode 100644 index 0000000..b2e7557 --- /dev/null +++ b/onenand_ipl/board/vpac270/u-boot.onenand.lds @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/onenand_ipl/board/vpac270/vpac270.c b/onenand_ipl/board/vpac270/vpac270.c new file mode 100644 index 0000000..a1eb331 --- /dev/null +++ b/onenand_ipl/board/vpac270/vpac270.c @@ -0,0 +1,42 @@ +/* + * (C) Copyright 2004 + * Robert Whaley, Applied Data Systems, Inc. rwhaley@applieddata.net + * + * (C) Copyright 2002 + * Kyle Harris, Nexus Technologies, Inc. kharris@nexus-tech.net + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> + +int board_init (void) +{ + return 0; +} + +int s_init(int skip) +{ + return 0; +}
Hi Marek,
- Ethernet
- USB
- MMC
- NOR Booting
- OneNAND Booting
- LCD
- HDD
Signed-off-by: Marek Vasutmarek.vasut@gmail.com
<snip>
Please remove these. The same goes for the other boards.
regards, Ben
Dne Út 6. července 2010 20:41:56 Ben Warren napsal(a):
Hi Marek,
- USB
- MMC
- NOR Booting
- OneNAND Booting
- LCD
- HDD
<snip>
Ok, removed. I pushed the new patches without this into -next-plat. Thanks
regards, Ben
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 1 + board/colibri_pxa270/Makefile | 45 +++++ board/colibri_pxa270/colibri_pxa270.c | 118 ++++++++++++++ board/colibri_pxa270/config.mk | 1 + board/colibri_pxa270/lowlevel_init.S | 36 ++++ boards.cfg | 1 + include/configs/colibri_pxa270.h | 283 +++++++++++++++++++++++++++++++++ 7 files changed, 485 insertions(+), 0 deletions(-) create mode 100644 board/colibri_pxa270/Makefile create mode 100644 board/colibri_pxa270/colibri_pxa270.c create mode 100644 board/colibri_pxa270/config.mk create mode 100644 board/colibri_pxa270/lowlevel_init.S create mode 100644 include/configs/colibri_pxa270.h
diff --git a/MAKEALL b/MAKEALL index b5a6ee1..0e0e960 100755 --- a/MAKEALL +++ b/MAKEALL @@ -702,6 +702,7 @@ LIST_at91=" \
LIST_pxa=" \ cerf250 \ + colibri_pxa270 \ cradle \ csb226 \ delta \ diff --git a/board/colibri_pxa270/Makefile b/board/colibri_pxa270/Makefile new file mode 100644 index 0000000..44d73cc --- /dev/null +++ b/board/colibri_pxa270/Makefile @@ -0,0 +1,45 @@ +# +# Toradex Colibri PXA270 Support +# +# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = lib$(BOARD).a + +OBJS := colibri_pxa270.o +SOBJS := lowlevel_init.o + +$(LIB): $(OBJS) $(SOBJS) + $(AR) crv $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +.depend: Makefile $(SOBJS:.o=.S) $(OBJS:.o=.c) + $(CC) -M $(CPPFLAGS) $(SOBJS:.o=.S) $(OBJS:.o=.c) > $@ + +-include .depend + +######################################################################### diff --git a/board/colibri_pxa270/colibri_pxa270.c b/board/colibri_pxa270/colibri_pxa270.c new file mode 100644 index 0000000..d3822f0 --- /dev/null +++ b/board/colibri_pxa270/colibri_pxa270.c @@ -0,0 +1,118 @@ +/* + * Toradex Colibri PXA270 Support + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/hardware.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* ------------------------------------------------------------------------- */ + +/* + * Miscelaneous platform dependent initialisations + */ +extern struct serial_device serial_ffuart_device; +extern struct serial_device serial_btuart_device; +extern struct serial_device serial_stuart_device; + +struct serial_device *default_serial_console (void) +{ + return &serial_ffuart_device; +} + +int board_init (void) +{ + /* memory and cpu-speed are setup before relocation */ + /* so we do _nothing_ here */ + + /* arch number of vpac270 */ + gd->bd->bi_arch_number = MACH_TYPE_COLIBRI; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + return 0; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +#ifdef CONFIG_CMD_USB +int usb_board_init(void) +{ + UHCHR = (UHCHR | UHCHR_PCPL | UHCHR_PSPL) & + ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE); + + UHCHR |= UHCHR_FSBIR; + + while (UHCHR & UHCHR_FSBIR); + + UHCHR &= ~UHCHR_SSE; + UHCHIE = (UHCHIE_UPRIE | UHCHIE_RWIE); + + /* Clear any OTG Pin Hold */ + if (PSSR & PSSR_OTGPH) + PSSR |= PSSR_OTGPH; + + UHCRHDA &= ~(0x200); + UHCRHDA |= 0x100; + + /* Set port power control mask bits, only 3 ports. */ + UHCRHDB |= (0x7<<17); + + /* enable port 2 */ + UP2OCR |= UP2OCR_HXOE | UP2OCR_HXS | UP2OCR_DMPDE | UP2OCR_DPPDE; + + return 0; +} + +void usb_board_init_fail(void) +{ + return; +} + +void usb_board_stop(void) +{ + UHCHR |= UHCHR_FHR; + udelay(11); + UHCHR &= ~UHCHR_FHR; + + UHCCOMS |= 1; + udelay(10); + + CKEN &= ~CKEN10_USBHOST; + + return; +} +#endif + +#ifdef CONFIG_DRIVER_DM9000 +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} +#endif diff --git a/board/colibri_pxa270/config.mk b/board/colibri_pxa270/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/colibri_pxa270/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/colibri_pxa270/lowlevel_init.S b/board/colibri_pxa270/lowlevel_init.S new file mode 100644 index 0000000..a43dac2 --- /dev/null +++ b/board/colibri_pxa270/lowlevel_init.S @@ -0,0 +1,36 @@ +/* + * Toradex Colibri PXA270 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/boards.cfg b/boards.cfg index da31c36..25c33d5 100644 --- a/boards.cfg +++ b/boards.cfg @@ -52,6 +52,7 @@ actux3 arm ixp actux4 arm ixp ixdp425 arm ixp cerf250 arm pxa +colibri_pxa270 arm pxa cradle arm pxa csb226 arm pxa delta arm pxa diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h new file mode 100644 index 0000000..e5bda22 --- /dev/null +++ b/include/configs/colibri_pxa270.h @@ -0,0 +1,283 @@ +/* + * Toradex Colibri PXA270 configuration file + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_VPAC270 1 /* Toradex Colibri PXA270 board */ + +#undef BOARD_LATE_INIT +#undef CONFIG_SKIP_RELOCATE_UBOOT +#undef CONFIG_USE_IRQ +#undef CONFIG_SKIP_LOWLEVEL_INIT + +/* + * Environment settings + */ +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128*1024) +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +#define CONFIG_ENV_OVERWRITE /* override default environment */ + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa0000000 uImage; then " \ + "bootm 0xa0000000; " \ + "fi; " \ + "if usb reset && fatload usb 0 0xa0000000 uImage; then " \ + "bootm 0xa0000000; " \ + "fi; " \ + "bootm 0x80000;" +#define CONFIG_BOOTARGS "console=tty0 console=ttyS0,115200" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_FFUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_USB +#define CONFIG_CMD_FLASH + +/* + * Networking Configuration + * chip on the Voipac PXA270 board + */ +#ifdef CONFIG_CMD_NET +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP + +#define CONFIG_NET_MULTI 1 +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_BASE 0x08000000 +#define DM9000_IO (CONFIG_DM9000_BASE) +#define DM9000_DATA (CONFIG_DM9000_BASE + 4) +#define CONFIG_NET_RETRY_COUNT 10 + +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME + +#define CONFIG_NETMASK 255.255.255.0 +#define CONFIG_IPADDR 192.168.1.52 +#define CONFIG_SERVERIP 192.168.1.51 +#define CONFIG_ETHADDR 00:11:22:33:44:55 +#endif + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#else +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#endif +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x290 /* 520 MHz */ + +/* + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR (0xa1000000) + +/* + * NOR FLASH + */ +#ifdef CONFIG_CMD_FLASH +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (25*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (25*CONFIG_SYS_HZ) + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 +#define CONFIG_SYS_FLASH_PROTECTION 1 + +#define CONFIG_ENV_IS_IN_FLASH 1 + +#else /* No flash */ +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_ENV_IS_NOWHERE +#endif + +#define CONFIG_SYS_MONITOR_BASE 0x000000 +#define CONFIG_SYS_MONITOR_LEN 0x40000 + +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SECT_SIZE 0x40000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) + + +/* + * GPIO settings + */ +#define CONFIG_SYS_GPSR0_VAL 0x00000000 +#define CONFIG_SYS_GPSR1_VAL 0x00020000 +#define CONFIG_SYS_GPSR2_VAL 0x0002C000 +#define CONFIG_SYS_GPSR3_VAL 0x00000000 + +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000000 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 +#define CONFIG_SYS_GPCR3_VAL 0x00000000 + +#define CONFIG_SYS_GPDR0_VAL 0x08000000 +#define CONFIG_SYS_GPDR1_VAL 0x0002A981 +#define CONFIG_SYS_GPDR2_VAL 0x0202FC00 +#define CONFIG_SYS_GPDR3_VAL 0x00000000 + +#define CONFIG_SYS_GAFR0_L_VAL 0x00100000 +#define CONFIG_SYS_GAFR0_U_VAL 0x00C00010 +#define CONFIG_SYS_GAFR1_L_VAL 0x999A901A +#define CONFIG_SYS_GAFR1_U_VAL 0xAAA00008 +#define CONFIG_SYS_GAFR2_L_VAL 0xAAAAAAAA +#define CONFIG_SYS_GAFR2_U_VAL 0x0109A000 +#define CONFIG_SYS_GAFR3_L_VAL 0x54000300 +#define CONFIG_SYS_GAFR3_U_VAL 0x00024001 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x00500240 +#define CONFIG_SYS_CCCR 0x02000290 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x000095f2 +#define CONFIG_SYS_MSC1_VAL 0x00007ff4 +#define CONFIG_SYS_MSC2_VAL 0x00000000 +#define CONFIG_SYS_MDCNFG_VAL 0x08000ac9 +#define CONFIG_SYS_MDREFR_VAL 0x2013e01e +#define CONFIG_SYS_MDMRS_VAL 0x00320032 +#define CONFIG_SYS_FLYCNFG_VAL 0x00000000 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000001 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +/* + * USB + */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_BOARD_INIT +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4C000000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "tdex270" +#define CONFIG_USB_STORAGE +#endif + +#endif /* __CONFIG_H */
This patch adds support for Aeronix Zipit Z2 handheld.
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- MAKEALL | 1 + board/zipitz2/Makefile | 54 +++++++++ board/zipitz2/config.mk | 1 + board/zipitz2/lowlevel_init.S | 40 +++++++ board/zipitz2/u-boot.lds | 56 +++++++++ board/zipitz2/zipitz2.c | 213 +++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/zipitz2.h | 259 +++++++++++++++++++++++++++++++++++++++++ 8 files changed, 625 insertions(+), 0 deletions(-) create mode 100644 board/zipitz2/Makefile create mode 100644 board/zipitz2/config.mk create mode 100644 board/zipitz2/lowlevel_init.S create mode 100644 board/zipitz2/u-boot.lds create mode 100644 board/zipitz2/zipitz2.c create mode 100644 include/configs/zipitz2.h
diff --git a/MAKEALL b/MAKEALL index 0e0e960..f720b2f 100755 --- a/MAKEALL +++ b/MAKEALL @@ -718,6 +718,7 @@ LIST_pxa=" \ xaeniax \ xm250 \ xsengine \ + zipitz2 \ zylonite \ "
diff --git a/board/zipitz2/Makefile b/board/zipitz2/Makefile new file mode 100644 index 0000000..2673835 --- /dev/null +++ b/board/zipitz2/Makefile @@ -0,0 +1,54 @@ + +# +# Copyright (C) 2009 +# Marek Vasut marek.vasut@gmail.com +# +# Heavily based on pxa255_idp platform +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := zipitz2.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/zipitz2/config.mk b/board/zipitz2/config.mk new file mode 100644 index 0000000..1d650ac --- /dev/null +++ b/board/zipitz2/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0xa1000000 diff --git a/board/zipitz2/lowlevel_init.S b/board/zipitz2/lowlevel_init.S new file mode 100644 index 0000000..82a52e8 --- /dev/null +++ b/board/zipitz2/lowlevel_init.S @@ -0,0 +1,40 @@ +/* + * Aeronix Zipit Z2 Lowlevel Hardware Initialization + * + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/pxa-regs.h> +#include <asm/arch/macro.h> + +.globl lowlevel_init +lowlevel_init: + pxa_gpio_setup + pxa_wait_ticks 0x8000 + pxa_mem_setup + pxa_wakeup + pxa_intr_setup + pxa_clock_setup + + mov pc, lr diff --git a/board/zipitz2/u-boot.lds b/board/zipitz2/u-boot.lds new file mode 100644 index 0000000..fb4358b --- /dev/null +++ b/board/zipitz2/u-boot.lds @@ -0,0 +1,56 @@ +/* + * (C) Copyright 2000-2005 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + cpu/pxa/start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { *(.data) } + + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss (NOLOAD) : { *(.bss) . = ALIGN(4); } + _end = .; +} diff --git a/board/zipitz2/zipitz2.c b/board/zipitz2/zipitz2.c new file mode 100644 index 0000000..14d1d76 --- /dev/null +++ b/board/zipitz2/zipitz2.c @@ -0,0 +1,213 @@ +/* + * Copyright (C) 2009 + * Marek Vasut marek.vasut@gmail.com + * + * Heavily based on pxa255_idp platform + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <serial.h> +#include <asm/arch/hardware.h> +#include <spi.h> + +DECLARE_GLOBAL_DATA_PTR; + +#ifdef CONFIG_CMD_SPI +void lcd_start(void); +#else +inline void lcd_start(void) {}; +#endif + +/* + * Miscelaneous platform dependent initialisations + */ + +int board_init (void) +{ + /* memory and cpu-speed are setup before relocation */ + /* so we do _nothing_ here */ + + /* arch number of Lubbock-Board */ + gd->bd->bi_arch_number = MACH_TYPE_ZIPIT2; + + /* adress of boot parameters */ + gd->bd->bi_boot_params = 0xa0000100; + + /* Enable LCD */ + lcd_start(); + + return 0; +} + +int board_late_init(void) +{ + setenv("stdout", "serial"); + setenv("stderr", "serial"); + return 0; +} + +struct serial_device *default_serial_console (void) +{ + return &serial_stuart_device; +} + +int dram_init (void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} + +#ifdef CONFIG_CMD_SPI + +struct { + unsigned char reg; + unsigned short data; + unsigned char mdelay; +} lcd_data[] = { + { 0x07, 0x0000, 0 }, + { 0x13, 0x0000, 10 }, + { 0x11, 0x3004, 0 }, + { 0x14, 0x200F, 0 }, + { 0x10, 0x1a20, 0 }, + { 0x13, 0x0040, 50 }, + { 0x13, 0x0060, 0 }, + { 0x13, 0x0070, 200 }, + { 0x01, 0x0127, 0 }, + { 0x02, 0x0700, 0 }, + { 0x03, 0x1030, 0 }, + { 0x08, 0x0208, 0 }, + { 0x0B, 0x0620, 0 }, + { 0x0C, 0x0110, 0 }, + { 0x30, 0x0120, 0 }, + { 0x31, 0x0127, 0 }, + { 0x32, 0x0000, 0 }, + { 0x33, 0x0503, 0 }, + { 0x34, 0x0727, 0 }, + { 0x35, 0x0124, 0 }, + { 0x36, 0x0706, 0 }, + { 0x37, 0x0701, 0 }, + { 0x38, 0x0F00, 0 }, + { 0x39, 0x0F00, 0 }, + { 0x40, 0x0000, 0 }, + { 0x41, 0x0000, 0 }, + { 0x42, 0x013f, 0 }, + { 0x43, 0x0000, 0 }, + { 0x44, 0x013f, 0 }, + { 0x45, 0x0000, 0 }, + { 0x46, 0xef00, 0 }, + { 0x47, 0x013f, 0 }, + { 0x48, 0x0000, 0 }, + { 0x07, 0x0015, 30 }, + { 0x07, 0x0017, 0 }, + { 0x20, 0x0000, 0 }, + { 0x21, 0x0000, 0 }, + { 0x22, 0x0000, 0 }, +}; + +void zipitz2_spi_sda(int set) +{ + /* GPIO 13 */ + if (set) + GPSR0 = (1 << 13); + else + GPCR0 = (1 << 13); +} + +void zipitz2_spi_scl(int set) +{ + /* GPIO 22 */ + if (set) + GPCR0 = (1 << 22); + else + GPSR0 = (1 << 22); +} + +unsigned char zipitz2_spi_read(void) +{ + /* GPIO 40 */ + return !!(GPLR1 & (1 << 8)); +} + +int spi_cs_is_valid(unsigned int bus, unsigned int cs) +{ + /* Always valid */ + return 1; +} + +void spi_cs_activate(struct spi_slave *slave) +{ + /* GPIO 88 low */ + GPCR2 = (1 << 24); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + /* GPIO 88 high */ + GPSR2 = (1 << 24); + +} + +void lcd_start(void) +{ + int i; + unsigned char reg[3] = { 0x74, 0x00, 0 }; + unsigned char data[3] = { 0x76, 0, 0 }; + unsigned char dummy[3] = { 0, 0, 0 }; + + /* PWM2 AF */ + GAFR0_L |= 0x00800000; + /* Enable clock to all PWM */ + CKEN |= 0x3; + /* Configure PWM2 */ + PWM_CTRL2 = 0x4f; + PWM_PWDUTY2 = 0x2ff; + PWM_PERVAL2 = 792; + + /* Toggle the reset pin to reset the LCD */ + GPSR0 = (1 << 19); + udelay(100000); + GPCR0 = (1 << 19); + udelay(20000); + GPSR0 = (1 << 19); + udelay(20000); + + /* Program the LCD init sequence */ + for (i = 0; i < sizeof(lcd_data) / sizeof(lcd_data[0]); i++) { + reg[0] = 0x74; + reg[1] = 0x0; + reg[2] = lcd_data[i].reg; + spi_xfer(NULL, 24, reg, dummy, SPI_XFER_BEGIN | SPI_XFER_END); + + data[0] = 0x76; + data[1] = lcd_data[i].data >> 8; + data[2] = lcd_data[i].data & 0xff; + spi_xfer(NULL, 24, data, dummy, SPI_XFER_BEGIN | SPI_XFER_END); + + if (lcd_data[i].mdelay) + udelay(lcd_data[i].mdelay * 1000); + } + + GPSR0 = (1 << 11); +} +#endif diff --git a/boards.cfg b/boards.cfg index 25c33d5..0e73bf4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -62,6 +62,7 @@ lubbock arm pxa pleb2 arm pxa xaeniax arm pxa xm250 arm pxa +zipitz2 arm pxa B2 arm s3c44b0 - dave assabet arm sa1100 dnp1110 arm sa1100 diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h new file mode 100644 index 0000000..a5a873b --- /dev/null +++ b/include/configs/zipitz2.h @@ -0,0 +1,259 @@ +/* + * Aeronix Zipit Z2 configuration file + * + * Copyright (C) 2009-2010 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Board Configuration Options + */ +#define CONFIG_PXA27X 1 /* Marvell PXA270 CPU */ +#define CONFIG_ZIPITZ2 1 /* Zipit Z2 board */ + +#undef BOARD_LATE_INIT +#undef CONFIG_SKIP_RELOCATE_UBOOT +#undef CONFIG_USE_IRQ +#undef CONFIG_SKIP_LOWLEVEL_INIT + +/* + * Environment settings + */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_ADDR 0x40000 +#define CONFIG_ENV_SIZE 0x20000 + +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + CONFIG_STACKSIZE) +#define CONFIG_SYS_GBL_DATA_SIZE 512 + +#define CONFIG_BOOTCOMMAND \ + "if mmc init && fatload mmc 0 0xa0000000 uboot.script ; then " \ + "source 0xa0000000; " \ + "else " \ + "bootm 0x60000; " \ + "fi; " +#define CONFIG_BOOTARGS \ + "console=tty0 console=ttyS2,115200 fbcon=rotate:3" +#define CONFIG_TIMESTAMP +#define CONFIG_BOOTDELAY 2 /* Autoboot delay */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS + +#define CONFIG_LZMA /* LZMA compression support */ + +/* + * Serial Console Configuration + * STUART - the lower serial port on Colibri board + */ +#define CONFIG_PXA_SERIAL +#define CONFIG_STUART 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* + * Bootloader Components Configuration + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_NET +#define CONFIG_CMD_ENV +#undef CONFIG_CMD_IMLS +#define CONFIG_CMD_MMC +#define CONFIG_CMD_SPI + +/* + * MMC Card Configuration + */ +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_PXA_MMC +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_DOS_PARTITION +#endif + +/* + * SPI and LCD + */ +#ifdef CONFIG_CMD_SPI +#define CONFIG_SOFT_SPI +#define CONFIG_LCD +#define CONFIG_LMS283GF05 +#define CONFIG_VIDEO_LOGO +#define CONFIG_CMD_BMP +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (2 << 20) +#undef SPI_INIT + +#define SPI_DELAY udelay(10) +#define SPI_SDA(val) zipitz2_spi_sda(val) +#define SPI_SCL(val) zipitz2_spi_scl(val) +#define SPI_READ zipitz2_spi_read() +#ifndef __ASSEMBLY__ +void zipitz2_spi_sda(int); +void zipitz2_spi_scl(int); +unsigned char zipitz2_spi_read(void); +#endif +#endif + +/* + * KGDB + */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * HUSH Shell Configuration + */ +#define CONFIG_SYS_HUSH_PARSER 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ +#else +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#endif +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_DEVICE_NULLDEV 1 + +/* + * Clock Configuration + */ +#undef CONFIG_SYS_CLKS_IN_HZ +#define CONFIG_SYS_HZ 3250000 /* Timer @ 3250000 Hz */ +#define CONFIG_SYS_CPUSPEED 0x190 /* standard setting for 312MHz; L=16, N=1.5, A=0, SDCLK!=SystemBus */ + +/* + * Stack sizes + */ +#define CONFIG_STACKSIZE (128*1024) /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +/* + * DRAM Map + */ +#define CONFIG_NR_DRAM_BANKS 1 /* We have 1 bank of DRAM */ +#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ +#define PHYS_SDRAM_1_SIZE 0x02000000 /* 32 MB */ + +#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ +#define CONFIG_SYS_DRAM_SIZE 0x02000000 /* 32 MB DRAM */ + +#define CONFIG_SYS_MEMTEST_START 0xa0400000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0xa0800000 /* 4 ... 8 MB in DRAM */ + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_DRAM_BASE + +/* + * NOR FLASH + */ +#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ +#define PHYS_FLASH_SIZE 0x00800000 /* 8 MB */ +#define PHYS_FLASH_SECT_SIZE 0x00010000 /* 64 KB sectors */ +#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 + +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT + +#define CONFIG_SYS_MONITOR_BASE PHYS_FLASH_1 +#define CONFIG_SYS_MONITOR_LEN PHYS_FLASH_SECT_SIZE + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 + +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 + +#define CONFIG_SYS_FLASH_ERASE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_WRITE_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_LOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_UNLOCK_TOUT (2*CONFIG_SYS_HZ) +#define CONFIG_SYS_FLASH_PROTECTION + +/* + * GPIO settings + */ +#define CONFIG_SYS_GAFR0_L_VAL 0x02000140 +#define CONFIG_SYS_GAFR0_U_VAL 0x59188000 +#define CONFIG_SYS_GAFR1_L_VAL 0x63900002 +#define CONFIG_SYS_GAFR1_U_VAL 0xaaa03950 +#define CONFIG_SYS_GAFR2_L_VAL 0x0aaaaaaa +#define CONFIG_SYS_GAFR2_U_VAL 0x29000308 +#define CONFIG_SYS_GAFR3_L_VAL 0x54000000 +#define CONFIG_SYS_GAFR3_U_VAL 0x000000d5 +#define CONFIG_SYS_GPCR0_VAL 0x00000000 +#define CONFIG_SYS_GPCR1_VAL 0x00000020 +#define CONFIG_SYS_GPCR2_VAL 0x00000000 +#define CONFIG_SYS_GPCR3_VAL 0x00000000 +#define CONFIG_SYS_GPDR0_VAL 0xdafcee00 +#define CONFIG_SYS_GPDR1_VAL 0xffa3aaab +#define CONFIG_SYS_GPDR2_VAL 0x8fe1ffff +#define CONFIG_SYS_GPDR3_VAL 0x001b1f8a +#define CONFIG_SYS_GPSR0_VAL 0x06080400 +#define CONFIG_SYS_GPSR1_VAL 0x007f0000 +#define CONFIG_SYS_GPSR2_VAL 0x032a0000 +#define CONFIG_SYS_GPSR3_VAL 0x00000180 + +#define CONFIG_SYS_PSSR_VAL 0x30 + +/* + * Clock settings + */ +#define CONFIG_SYS_CKEN 0x00511220 +#define CONFIG_SYS_CCCR 0x00000190 + +/* + * Memory settings + */ +#define CONFIG_SYS_MSC0_VAL 0x2ffc38f8 +#define CONFIG_SYS_MSC1_VAL 0x0000ccd1 +#define CONFIG_SYS_MSC2_VAL 0x0000b884 +#define CONFIG_SYS_MDCNFG_VAL 0x08000ba9 +#define CONFIG_SYS_MDREFR_VAL 0x2011a01e +#define CONFIG_SYS_MDMRS_VAL 0x00000000 +#define CONFIG_SYS_FLYCNFG_VAL 0x00010001 +#define CONFIG_SYS_SXCNFG_VAL 0x40044004 + +/* + * PCMCIA and CF Interfaces + */ +#define CONFIG_SYS_MECR_VAL 0x00000001 +#define CONFIG_SYS_MCMEM0_VAL 0x00014307 +#define CONFIG_SYS_MCMEM1_VAL 0x00014307 +#define CONFIG_SYS_MCATT0_VAL 0x0001c787 +#define CONFIG_SYS_MCATT1_VAL 0x0001c787 +#define CONFIG_SYS_MCIO0_VAL 0x0001430f +#define CONFIG_SYS_MCIO1_VAL 0x0001430f + +#endif /* __CONFIG_H */
Ben Warren
