[PATCH] arm: dts: imx8mp: Generate single bootable binary
binman conversion made flashing flash.bin and u-boot.itb necessary. Update binman config to create a single flash.bin image again.
This updates imx8mp_evk and phyCORE-i.MX8MP as they share the same binman config.
Updated also imx8mp_evk documentation.
Tested on phyCORE-i.MX8MP.
Signed-off-by: Teresa Remmet t.remmet@phytec.de --- arch/arm/dts/imx8mp-u-boot.dtsi | 17 ++++++++++++++++- .../imx8mp_evk/imximage-8mp-lpddr4.cfg | 2 +- board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg | 2 +- doc/board/nxp/imx8mp_evk.rst | 1 - 4 files changed, 18 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index a6ede2ed6e30..ace7b2051e7f 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -82,7 +82,7 @@ }; };
- flash { + spl { mkimage { args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x920000";
@@ -149,4 +149,19 @@ }; }; }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + filename = "spl.bin"; + offset = <0x0>; + }; + + uboot: blob-ext@2 { + filename = "u-boot.itb"; + offset = <0x58000>; + }; + }; }; diff --git a/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg b/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg index b2920b4908ed..2be18de674ba 100644 --- a/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg +++ b/board/freescale/imx8mp_evk/imximage-8mp-lpddr4.cfg @@ -7,4 +7,4 @@
ROM_VERSION v2 BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x920000 +LOADER mkimage.spl.mkimage 0x920000 diff --git a/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg b/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg index b2920b4908ed..2be18de674ba 100644 --- a/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg +++ b/board/phytec/phycore_imx8mp/imximage-8mp-sd.cfg @@ -7,4 +7,4 @@
ROM_VERSION v2 BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x920000 +LOADER mkimage.spl.mkimage 0x920000 diff --git a/doc/board/nxp/imx8mp_evk.rst b/doc/board/nxp/imx8mp_evk.rst index 609a29f3ebc3..b996ae055e69 100644 --- a/doc/board/nxp/imx8mp_evk.rst +++ b/doc/board/nxp/imx8mp_evk.rst @@ -52,7 +52,6 @@ Burn the flash.bin to the MicroSD card at offset 32KB: .. code-block:: bash
$sudo dd if=build/flash.bin of=/dev/sd[x] bs=1K seek=32 conv=notrunc; sync - $sudo dd if=build/u-boot.itb of=/dev/sd[x] bs=1K seek=384 conv=notrunc; sync
Boot ----
Hi Teresa,
Thanks for taking care of this.
flash {
spl {
To make this more standard, could you please also pass 'filename = "spl.bin" here too?
Please check: https://lists.denx.de/pipermail/u-boot/2021-August/458754.html
Please use "LOADER u-boot-spl-ddr.bin 0x920000" here instead.
Ditto.
With these changes, you can add:
Reviewed-by: Fabio Estevam festevam@gmail.com
Thanks
Am Mittwoch, den 25.08.2021, 12:56 -0300 schrieb Fabio Estevam:
Hi Teresa,
diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp- u-boot.dtsi index a6ede2ed6e30..ace7b2051e7f 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -82,7 +82,7 @@ }; };
flash {
spl {
Oh, I missed the latest version of your patch. I will update this accordingly. Thanks.
Teresa
Ditto.
Thanks
Hello Teresa,
No more comments beside Fabios, so
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Fabio Estevam
Heiko Schocher
Teresa Remmet
Teresa Remmet
