[U-Boot] [RFC] Adding support for NI Ettus Research USRP E3XX series
Hi all,
this patch adds basic support for NI Ettus Research E3XX series boards. I tagged this RFC because I'm not sure if the boards/xilinx/zynq subdirectory is the correct place for this, as I'll have some follow up patches that read the devices EEPROM for ethernet address etc.
Would putting it under boards/ni/zynq be the correct way of integrating it? While technically a Zynq device there are a lot of custom modifications, that I wouldn't like to force into board/xilinx/zynq/board.c in my follow up patches. However duplicating the entire board.c doesn't seem like a good idea neither.
Any suggestions? For future reference do you want me to split out dts etc in a separate patch?
Thanks for your feedback & suggestions,
Moritz
Moritz Fischer (1): zynq: Add support for E3xx board.
arch/arm/dts/Makefile | 3 +- arch/arm/dts/zynq-e3xx.dts | 35 + arch/arm/mach-zynq/Kconfig | 4 + board/xilinx/zynq/Makefile | 2 + board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c | 13446 ++++++++++++++++++++ board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h | 130 + configs/zynq_e3xx_defconfig | 12 + include/configs/zynq_e3xx.h | 29 + 8 files changed, 13660 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/zynq-e3xx.dts create mode 100644 board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c create mode 100644 board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h create mode 100644 configs/zynq_e3xx_defconfig create mode 100644 include/configs/zynq_e3xx.h
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/zynq-e3xx.dts | 35 + arch/arm/mach-zynq/Kconfig | 4 + board/xilinx/zynq/Makefile | 2 + board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c | 13446 ++++++++++++++++++++ board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h | 130 + configs/zynq_e3xx_defconfig | 12 + include/configs/zynq_e3xx.h | 29 + 8 files changed, 13660 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c97f39d..bb5cb34 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -43,7 +43,8 @@ dtb-$(CONFIG_ARCH_UNIPHIER) += \ uniphier-ph1-pro4-ref.dtb \ uniphier-ph1-sld3-ref.dtb \ uniphier-ph1-sld8-ref.dtb -dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ +dtb-$(CONFIG_ARCH_ZYNQ) += zynq-e3xx.dtb \ + zynq-zc702.dtb \ zynq-zc706.dtb \ zynq-zed.dtb \ zynq-zybo.dtb \ diff --git a/arch/arm/dts/zynq-e3xx.dts b/arch/arm/dts/zynq-e3xx.dts new file mode 100644 index 0000000..3ee7927 --- /dev/null +++ b/arch/arm/dts/zynq-e3xx.dts @@ -0,0 +1,35 @@ +/* + * Copyright (C) 2015 National Instruments Corp. All rights reserved. + * + * This software is licensed under the terms of the GNU General Public + * License version 2, as published by the Free Software Foundation, and + * may be copied, distributed, and modified under those terms. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ +/dts-v1/; +#include "zynq-7000.dtsi" + +/ { + model = "NI Ettus Research USRP E3xx Embedded SDR"; + compatible = "ettus,zynq-e3xx", "xlnx,zynq-7000"; + + aliases { + ethernet0 = &gem0; + i2c0 = &i2c0; + serial0 = &uart0; + }; + + memory { + device_type = "memory"; + reg = <0 0x40000000>; + }; + + chosen { + bootargs = "earlyprintk"; + stdout-path = "serial0:115200n8"; + }; +}; diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index 7a1aec4..8fc0126 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -12,6 +12,9 @@ choice prompt "Xilinx Zynq board select" default TARGET_ZYNQ_ZC702
+config TARGET_ZYNQ_E3XX + bool "Zynq E3XX" + config TARGET_ZYNQ_ZED bool "Zynq ZedBoard"
@@ -54,6 +57,7 @@ config SYS_SOC default "zynq"
config SYS_CONFIG_NAME + default "zynq_e3xx" if TARGET_ZYNQ_E3XX default "zynq_zed" if TARGET_ZYNQ_ZED default "zynq_microzed" if TARGET_ZYNQ_MICROZED default "zynq_picozed" if TARGET_ZYNQ_PICOZED diff --git a/board/xilinx/zynq/Makefile b/board/xilinx/zynq/Makefile index fd5d6fe..746f405 100644 --- a/board/xilinx/zynq/Makefile +++ b/board/xilinx/zynq/Makefile @@ -1,6 +1,7 @@ # # (C) Copyright 2000-2006 # Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# Copyright (C) 2015 National Instruments Corp. # # SPDX-License-Identifier: GPL-2.0+ # @@ -12,6 +13,7 @@ hw-platform-$(CONFIG_TARGET_ZYNQ_ZED) := zed_hw_platform hw-platform-$(CONFIG_TARGET_ZYNQ_MICROZED) := MicroZed_hw_platform hw-platform-$(CONFIG_TARGET_ZYNQ_ZC702) := ZC702_hw_platform hw-platform-$(CONFIG_TARGET_ZYNQ_ZC706) := ZC706_hw_platform +hw-platform-$(CONFIG_TARGET_ZYNQ_E3XX) := e3xx_hw_platform # If you want to use customized ps7_init_gpl.c/h, # enable CONFIG_ZYNQ_CUSTOM_INIT and put them into custom_hw_platform/. # This line must be placed at the bottom of the list because diff --git a/board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c b/board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c new file mode 100644 index 0000000..fb10a36 --- /dev/null +++ b/board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c @@ -0,0 +1,13446 @@ +/****************************************************************************** +* (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. +* +* This program is free software; you can redistribute it and/or modify +* it under the terms of the GNU General Public License as published by +* the Free Software Foundation; either version 2 of the License, or +* (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License along +* with this program; if not, see http://www.gnu.org/licenses/ +* +* +******************************************************************************/ +/****************************************************************************/ +/** +* +* @file ps7_init_gpl.c +* +* This file is automatically generated +* +*****************************************************************************/ + +#include "ps7_init_gpl.h" + +unsigned long ps7_pll_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x3 + // .. .. ==> 0XF8000118[11:8] = 0x00000003U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000300U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000118[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x000FA3C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x2d + // .. .. .. ==> 0XF8000108[18:12] = 0x0000002DU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0002D000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0002D000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0x23 + // .. ==> 0XF8000128[13:8] = 0x00000023U + // .. ==> MASK : 0x00003F00U VAL : 0x00002300U + // .. DIVISOR1 = 0x3 + // .. ==> 0XF8000128[25:20] = 0x00000003U + // .. ==> MASK : 0x03F00000U VAL : 0x00300000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00302301U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000138[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000138[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000138, 0x00000011U ,0x00000001U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000140[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000140[6:4] = 0x00000000U + // .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. DIVISOR = 0xc + // .. ==> 0XF8000140[13:8] = 0x0000000CU + // .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. DIVISOR1 = 0x1 + // .. ==> 0XF8000140[25:20] = 0x00000001U + // .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U ,0x00100C01U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x0 + // .. ==> 0XF8000150[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xc + // .. ==> 0XF8000150[13:8] = 0x0000000CU + // .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00000C01U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000154[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xf + // .. ==> 0XF8000154[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000F03U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000158[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000158[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000158[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x9 + // .. ==> 0XF8000158[13:8] = 0x00000009U + // .. ==> MASK : 0x00003F00U VAL : 0x00000900U + // .. + EMIT_MASKWRITE(0XF8000158, 0x00003F33U ,0x00000903U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x8 + // .. .. ==> 0XF8000168[13:8] = 0x00000008U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000800U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000801U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x1e + // .. .. ==> 0XF8000170[13:8] = 0x0000001EU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00001E00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000170[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00101E00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000180[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xf + // .. .. ==> 0XF8000180[13:8] = 0x0000000FU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000180[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U ,0x00100F00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000190[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xc + // .. .. ==> 0XF8000190[13:8] = 0x0000000CU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000190[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U ,0x00100C00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF80001A0[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xa + // .. .. ==> 0XF80001A0[13:8] = 0x0000000AU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000A00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF80001A0[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U ,0x00100A00U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[6:6] = 0x00000001U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000040U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. SPI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. SPI1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[20:20] = 0x00000001U + // .. .. ==> MASK : 0x00100000U VAL : 0x00100000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x017CC44DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_3_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000080U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x81 + // .. .. ==> 0XF8006004[11:0] = 0x00000081U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000081U + // .. .. reserved_reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x0007FFFFU ,0x00001081U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1a + // .. .. ==> 0XF8006014[5:0] = 0x0000001AU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001AU + // .. .. reg_ddrc_t_rfc_min = 0xa0 + // .. .. ==> 0XF8006014[13:6] = 0x000000A0U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002800U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004281AU), + // .. .. reg_ddrc_wr2pre = 0x12 + // .. .. ==> 0XF8006018[4:0] = 0x00000012U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000012U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D2U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xe + // .. .. ==> 0XF800601C[14:10] = 0x0000000EU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003800U + // .. .. reg_ddrc_t_xp = 0x4 + // .. .. ==> 0XF800601C[19:15] = 0x00000004U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00020000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x4 + // .. .. ==> 0XF800601C[27:23] = 0x00000004U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02000000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x720238E5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_en_dfi_dram_clk_disable = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0x7FDFFFFCU ,0x270872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFC3U ,0x00000000U), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0x930 + // .. .. ==> 0XF8006030[15:0] = 0x00000930U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000930U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040930U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x105 + // .. .. ==> 0XF8006034[13:4] = 0x00000105U + // .. .. ==> MASK : 0x00003FF0U VAL : 0x00001050U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x00011054U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00000003U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x7 + // .. .. ==> 0XF800603C[3:0] = 0x00000007U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000007U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x7 + // .. .. ==> 0XF800603C[7:4] = 0x00000007U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000070U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x7 + // .. .. ==> 0XF800603C[11:8] = 0x00000007U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000700U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000777U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0x0 + // .. .. ==> 0XF8006040[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFF00000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x6 + // .. .. ==> 0XF8006044[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_row_b1 = 0x6 + // .. .. ==> 0XF8006044[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x6 + // .. .. ==> 0XF8006044[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_row_b12 = 0x6 + // .. .. ==> 0XF8006044[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x6 + // .. .. ==> 0XF8006044[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x6 + // .. .. ==> 0XF8006044[23:20] = 0x00000006U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00600000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F666666U), + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reserved_reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reserved_reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x0003F03FU ,0x0003C008U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x00010000U ,0x00000000U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. reg_ddrc_dfi_t_ctrl_delay = 0x1 + // .. .. ==> 0XF8006078[3:0] = 0x00000001U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000001U + // .. .. reg_ddrc_dfi_t_dram_clk_disable = 0x1 + // .. .. ==> 0XF8006078[7:4] = 0x00000001U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000010U + // .. .. reg_ddrc_dfi_t_dram_clk_enable = 0x1 + // .. .. ==> 0XF8006078[11:8] = 0x00000001U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000100U + // .. .. reg_ddrc_t_cksre = 0x6 + // .. .. ==> 0XF8006078[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_t_cksrx = 0x6 + // .. .. ==> 0XF8006078[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_t_ckesr = 0x4 + // .. .. ==> 0XF8006078[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU ,0x00466111U), + // .. .. reg_ddrc_t_ckpde = 0x2 + // .. .. ==> 0XF800607C[3:0] = 0x00000002U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000002U + // .. .. reg_ddrc_t_ckpdx = 0x2 + // .. .. ==> 0XF800607C[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. reg_ddrc_t_ckdpde = 0x2 + // .. .. ==> 0XF800607C[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_ckdpdx = 0x2 + // .. .. ==> 0XF800607C[15:12] = 0x00000002U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00002000U + // .. .. reg_ddrc_t_ckcsx = 0x3 + // .. .. ==> 0XF800607C[19:16] = 0x00000003U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00030000U + // .. .. + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU ,0x00032222U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x00000200U ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. START: RESET ECC ERROR + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 1 + // .. .. ==> 0XF80060C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. Clear_Correctable_DRAM_ECC_error = 1 + // .. .. ==> 0XF80060C4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000003U), + // .. .. FINISH: RESET ECC ERROR + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006120[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006124[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFCFU ,0x40000001U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF800612C[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF800612C[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006130[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006130[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006134[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006138[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006154[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006158[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF800615C[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006160[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006168[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF800616C[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006170[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006174[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF800617C[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006180[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006184[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006188[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0x6FFFFEFEU ,0x00040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000703FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF5U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000081U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B4C[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B4C[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B4C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B4C[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B4C[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000672U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B54[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B54[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCI_TYPE = 0x3 + // .. ==> 0XF8000B54[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B54[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B54[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000674U), + // .. reserved_INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE_B = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCI_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. reserved_SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. reserved_DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. reserved_DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. reserved_SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. reserved_SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. reserved_GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. reserved_RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x3 + // .. ==> 0XF8000B6C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. reserved_VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. reserved_REFIO_TEST = 0x0 + // .. ==> 0XF8000B6C[11:10] = 0x00000000U + // .. ==> MASK : 0x00000C00U VAL : 0x00000000U + // .. reserved_REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. reserved_DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. reserved_CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU ,0x00000260U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000001U ,0x00000001U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reserved_VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reserved_VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reserved_VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reserved_VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reserved_VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[15:14] = 0x00000000U + // .. .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reserved_INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reserved_TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reserved_TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reserved_TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. reserved_TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reserved_INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FEFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000700[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000700[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003F01U ,0x00001201U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000704[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000704[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000708[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000708[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800070C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800070C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000710[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000710[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000714[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000714[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000718[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000718[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800071C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000720[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000720[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000724[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000728[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000728[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800072C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800072C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000730[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000730[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000734[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000734[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000738[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF8000738[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000738[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF800073C[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800073C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000740[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000740[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000740[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000740[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000740[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000740[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000740[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000740[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000740[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000744[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000744[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000744[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000744[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000744[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000744[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000744[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000744[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000744[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000748[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000748[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000748[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000748[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000748[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000748[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000748[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000748[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000748[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800074C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800074C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800074C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800074C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800074C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800074C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800074C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800074C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800074C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000750[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000750[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000750[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000750[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000750[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000750[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000750[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000750[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000750[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000754[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000754[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000754[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000754[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000754[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000754[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000754[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000754[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000754[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000758[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000758[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000758[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000758[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000758[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000758[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000758[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000758[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000758[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800075C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800075C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800075C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800075C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800075C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800075C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800075C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800075C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800075C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000760[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000760[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000760[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000760[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000760[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000760[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000760[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000760[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000760[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000764[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000764[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000764[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000764[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000764[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000764[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000764[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000764[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000764[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000768[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000768[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000768[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000768[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000768[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000768[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000768[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000768[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000768[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800076C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800076C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800076C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800076C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800076C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800076C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800076C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800076C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800076C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000770[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000770[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000774[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000774[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000778[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000778[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800077C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800077C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000780[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000780[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000784[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000784[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000788[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000788[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800078C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800078C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000790[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000790[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000794[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000794[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000798[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000798[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800079C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800079C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A8[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007AC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007AC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007AC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007AC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007AC[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007AC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007AC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007AC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007AC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 2 + // .. ==> 0XF80007B8[7:5] = 0x00000002U + // .. ==> MASK : 0x000000E0U VAL : 0x00000040U + // .. Speed = 0 + // .. ==> 0XF80007B8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU ,0x00001240U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007BC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007BC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007BC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007BC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 2 + // .. ==> 0XF80007BC[7:5] = 0x00000002U + // .. ==> MASK : 0x000000E0U VAL : 0x00000040U + // .. Speed = 0 + // .. ==> 0XF80007BC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007BC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007BC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007BC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU ,0x00001240U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007C8[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007C8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007CC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007CC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007CC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007CC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007CC[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007CC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007CC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007CC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007CC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001280U), + // .. SDIO0_CD_SEL = 0 + // .. ==> 0XF8000830[21:16] = 0x00000000U + // .. ==> MASK : 0x003F0000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F0000U ,0x00000000U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000180U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x000003FFU ,0x00000020U), + // .. BDIV = 0x6 + // .. ==> 0XE0000034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0000034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0000018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0000000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0000000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0000000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0000000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0000000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0000000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0000000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0000000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0000000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0000000, 0x000001FFU ,0x00000017U), + // .. CHMODE = 0x0 + // .. ==> 0XE0000004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0000004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0000004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0000004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0000004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0000004, 0x000003FFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: TPIU WIDTH IN CASE OF EMIO + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0XC5ACCE55 + // .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. .. START: TRACE CURRENT PORT SIZE + // .. .. a = 2 + // .. .. ==> 0XF8803004[31:0] = 0x00000002U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU ,0x00000002U), + // .. .. FINISH: TRACE CURRENT PORT SIZE + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0X0 + // .. .. ==> 0XF8803FB0[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0x00000000U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. FINISH: TPIU WIDTH IN CASE OF EMIO + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0xa00 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x200 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000200U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000200U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0200U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0xa00 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x200 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000200U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000200U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0200U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. .. START: USB1 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB1 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. .. START: ENET0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0xa00 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x800 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000800U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000800U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0800U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0xa00 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x800 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000800U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000800U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0800U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: ENET0 RESET + // .. .. .. START: ENET1 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: ENET1 RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. .. START: I2C0 RESET + // .. .. .. .. START: DIR MODE GPIO BANK0 + // .. .. .. .. FINISH: DIR MODE GPIO BANK0 + // .. .. .. .. START: DIR MODE GPIO BANK1 + // .. .. .. .. FINISH: DIR MODE GPIO BANK1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: I2C0 RESET + // .. .. .. START: I2C1 RESET + // .. .. .. .. START: DIR MODE GPIO BANK0 + // .. .. .. .. FINISH: DIR MODE GPIO BANK0 + // .. .. .. .. START: DIR MODE GPIO BANK1 + // .. .. .. .. FINISH: DIR MODE GPIO BANK1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: I2C1 RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_3_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_LVL_INP_EN_0 = 1 + // .. ==> 0XF8000900[3:3] = 0x00000001U + // .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. USER_LVL_OUT_EN_0 = 1 + // .. ==> 0XF8000900[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. USER_LVL_INP_EN_1 = 1 + // .. ==> 0XF8000900[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. USER_LVL_OUT_EN_1 = 1 + // .. ==> 0XF8000900[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: TPIU WIDTH IN CASE OF EMIO + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0XC5ACCE55 + // .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. .. START: TRACE CURRENT PORT SIZE + // .. .. a = 2 + // .. .. ==> 0XF8803004[31:0] = 0x00000002U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU ,0x00000002U), + // .. .. FINISH: TRACE CURRENT PORT SIZE + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0X0 + // .. .. ==> 0XF8803FB0[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0x00000000U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. FINISH: TPIU WIDTH IN CASE OF EMIO + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. reserved_FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. reserved_FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. reserved_FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. reserved_FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. reserved_FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. reserved_FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. reserved_FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. reserved_FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. reserved_FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. reserved_FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_debug_3_0[] = { + // START: top + // .. START: CROSS TRIGGER CONFIGURATIONS + // .. .. START: UNLOCKING CTI REGISTERS + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8898FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8898FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8899FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8899FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8809FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8809FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: UNLOCKING CTI REGISTERS + // .. .. START: ENABLING CTI MODULES AND CHANNELS + // .. .. FINISH: ENABLING CTI MODULES AND CHANNELS + // .. .. START: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. .. FINISH: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. FINISH: CROSS TRIGGER CONFIGURATIONS + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_pll_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x3 + // .. .. ==> 0XF8000118[11:8] = 0x00000003U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000300U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000118[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x000FA3C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x2d + // .. .. .. ==> 0XF8000108[18:12] = 0x0000002DU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0002D000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0002D000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0x23 + // .. ==> 0XF8000128[13:8] = 0x00000023U + // .. ==> MASK : 0x00003F00U VAL : 0x00002300U + // .. DIVISOR1 = 0x3 + // .. ==> 0XF8000128[25:20] = 0x00000003U + // .. ==> MASK : 0x03F00000U VAL : 0x00300000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00302301U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000138[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000138[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000138, 0x00000011U ,0x00000001U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000140[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000140[6:4] = 0x00000000U + // .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. DIVISOR = 0xc + // .. ==> 0XF8000140[13:8] = 0x0000000CU + // .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. DIVISOR1 = 0x1 + // .. ==> 0XF8000140[25:20] = 0x00000001U + // .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U ,0x00100C01U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x0 + // .. ==> 0XF8000150[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xc + // .. ==> 0XF8000150[13:8] = 0x0000000CU + // .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00000C01U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000154[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xf + // .. ==> 0XF8000154[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000F03U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000158[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000158[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000158[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x9 + // .. ==> 0XF8000158[13:8] = 0x00000009U + // .. ==> MASK : 0x00003F00U VAL : 0x00000900U + // .. + EMIT_MASKWRITE(0XF8000158, 0x00003F33U ,0x00000903U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x8 + // .. .. ==> 0XF8000168[13:8] = 0x00000008U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000800U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000801U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x1e + // .. .. ==> 0XF8000170[13:8] = 0x0000001EU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00001E00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000170[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00101E00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000180[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xf + // .. .. ==> 0XF8000180[13:8] = 0x0000000FU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000180[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U ,0x00100F00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000190[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xc + // .. .. ==> 0XF8000190[13:8] = 0x0000000CU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000190[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U ,0x00100C00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF80001A0[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xa + // .. .. ==> 0XF80001A0[13:8] = 0x0000000AU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000A00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF80001A0[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U ,0x00100A00U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[6:6] = 0x00000001U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000040U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. SPI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. SPI1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[20:20] = 0x00000001U + // .. .. ==> MASK : 0x00100000U VAL : 0x00100000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x017CC44DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_2_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000080U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x81 + // .. .. ==> 0XF8006004[11:0] = 0x00000081U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000081U + // .. .. reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_block = 0x1 + // .. .. ==> 0XF8006004[20:19] = 0x00000001U + // .. .. ==> MASK : 0x00180000U VAL : 0x00080000U + // .. .. reg_ddrc_diff_rank_rd_2cycle_gap = 0x0 + // .. .. ==> 0XF8006004[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_cs_bit1 = 0x0 + // .. .. ==> 0XF8006004[26:22] = 0x00000000U + // .. .. ==> MASK : 0x07C00000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_open_bank = 0x0 + // .. .. ==> 0XF8006004[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_4bank_ram = 0x0 + // .. .. ==> 0XF8006004[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU ,0x00081081U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1a + // .. .. ==> 0XF8006014[5:0] = 0x0000001AU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001AU + // .. .. reg_ddrc_t_rfc_min = 0xa0 + // .. .. ==> 0XF8006014[13:6] = 0x000000A0U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002800U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004281AU), + // .. .. reg_ddrc_wr2pre = 0x12 + // .. .. ==> 0XF8006018[4:0] = 0x00000012U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000012U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D2U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xe + // .. .. ==> 0XF800601C[14:10] = 0x0000000EU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003800U + // .. .. reg_ddrc_t_xp = 0x4 + // .. .. ==> 0XF800601C[19:15] = 0x00000004U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00020000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x4 + // .. .. ==> 0XF800601C[27:23] = 0x00000004U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02000000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x720238E5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_sdram = 0x1 + // .. .. ==> 0XF8006020[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_clock_stop_en = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_ddrc_loopback = 0x0 + // .. .. ==> 0XF8006020[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU ,0x272872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_max_rank_rd = 0xf + // .. .. ==> 0XF8006024[5:2] = 0x0000000FU + // .. .. ==> MASK : 0x0000003CU VAL : 0x0000003CU + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU ,0x0000003CU), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0x930 + // .. .. ==> 0XF8006030[15:0] = 0x00000930U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000930U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040930U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x105 + // .. .. ==> 0XF8006034[13:4] = 0x00000105U + // .. .. ==> MASK : 0x00003FF0U VAL : 0x00001050U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x00011054U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_debug_mode = 0x0 + // .. .. ==> 0XF8006038[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_phy_wr_level_start = 0x0 + // .. .. ==> 0XF8006038[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_phy_rd_level_start = 0x0 + // .. .. ==> 0XF8006038[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_dq0_wait_t = 0x0 + // .. .. ==> 0XF8006038[12:9] = 0x00000000U + // .. .. ==> MASK : 0x00001E00U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x7 + // .. .. ==> 0XF800603C[3:0] = 0x00000007U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000007U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x7 + // .. .. ==> 0XF800603C[7:4] = 0x00000007U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000070U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x7 + // .. .. ==> 0XF800603C[11:8] = 0x00000007U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000700U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000777U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0x0 + // .. .. ==> 0XF8006040[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFF00000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x6 + // .. .. ==> 0XF8006044[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_row_b1 = 0x6 + // .. .. ==> 0XF8006044[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x6 + // .. .. ==> 0XF8006044[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_row_b12 = 0x6 + // .. .. ==> 0XF8006044[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x6 + // .. .. ==> 0XF8006044[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x6 + // .. .. ==> 0XF8006044[23:20] = 0x00000006U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00600000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F666666U), + // .. .. reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reg_ddrc_rank1_rd_odt = 0x1 + // .. .. ==> 0XF8006048[8:6] = 0x00000001U + // .. .. ==> MASK : 0x000001C0U VAL : 0x00000040U + // .. .. reg_ddrc_rank1_wr_odt = 0x1 + // .. .. ==> 0XF8006048[11:9] = 0x00000001U + // .. .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reg_ddrc_rank2_rd_odt = 0x0 + // .. .. ==> 0XF8006048[20:18] = 0x00000000U + // .. .. ==> MASK : 0x001C0000U VAL : 0x00000000U + // .. .. reg_ddrc_rank2_wr_odt = 0x0 + // .. .. ==> 0XF8006048[23:21] = 0x00000000U + // .. .. ==> MASK : 0x00E00000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_rd_odt = 0x0 + // .. .. ==> 0XF8006048[26:24] = 0x00000000U + // .. .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_wr_odt = 0x0 + // .. .. ==> 0XF8006048[29:27] = 0x00000000U + // .. .. ==> MASK : 0x38000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU ,0x0003C248U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dll_calib_to_min_x1024 = 0x1 + // .. .. ==> 0XF8006058[7:0] = 0x00000001U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000001U + // .. .. reg_ddrc_dll_calib_to_max_x1024 = 0x1 + // .. .. ==> 0XF8006058[15:8] = 0x00000001U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000100U + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU ,0x00000101U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. reg_ddrc_dfi_t_ctrl_delay = 0x1 + // .. .. ==> 0XF8006078[3:0] = 0x00000001U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000001U + // .. .. reg_ddrc_dfi_t_dram_clk_disable = 0x1 + // .. .. ==> 0XF8006078[7:4] = 0x00000001U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000010U + // .. .. reg_ddrc_dfi_t_dram_clk_enable = 0x1 + // .. .. ==> 0XF8006078[11:8] = 0x00000001U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000100U + // .. .. reg_ddrc_t_cksre = 0x6 + // .. .. ==> 0XF8006078[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_t_cksrx = 0x6 + // .. .. ==> 0XF8006078[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_t_ckesr = 0x4 + // .. .. ==> 0XF8006078[25:20] = 0x00000004U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00400000U + // .. .. + EMIT_MASKWRITE(0XF8006078, 0x03FFFFFFU ,0x00466111U), + // .. .. reg_ddrc_t_ckpde = 0x2 + // .. .. ==> 0XF800607C[3:0] = 0x00000002U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000002U + // .. .. reg_ddrc_t_ckpdx = 0x2 + // .. .. ==> 0XF800607C[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. reg_ddrc_t_ckdpde = 0x2 + // .. .. ==> 0XF800607C[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_ckdpdx = 0x2 + // .. .. ==> 0XF800607C[15:12] = 0x00000002U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00002000U + // .. .. reg_ddrc_t_ckcsx = 0x3 + // .. .. ==> 0XF800607C[19:16] = 0x00000003U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00030000U + // .. .. + EMIT_MASKWRITE(0XF800607C, 0x000FFFFFU ,0x00032222U), + // .. .. refresh_timer0_start_value_x32 = 0x0 + // .. .. ==> 0XF80060A0[11:0] = 0x00000000U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000000U + // .. .. refresh_timer1_start_value_x32 = 0x8 + // .. .. ==> 0XF80060A0[23:12] = 0x00000008U + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00008000U + // .. .. + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU ,0x00008000U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_2t_delay = 0x0 + // .. .. ==> 0XF80060B4[8:0] = 0x00000000U + // .. .. ==> MASK : 0x000001FFU VAL : 0x00000000U + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. reg_ddrc_dis_pre_bypass = 0x0 + // .. .. ==> 0XF80060B4[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. START: RESET ECC ERROR + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 1 + // .. .. ==> 0XF80060C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. Clear_Correctable_DRAM_ECC_error = 1 + // .. .. ==> 0XF80060C4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000003U), + // .. .. FINISH: RESET ECC ERROR + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006118[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006118[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF800611C[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF800611C[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006120[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006120[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006120[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006120[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006120[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006120[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006124[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006124[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006124[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF800612C[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF800612C[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006130[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006130[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006134[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006138[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006154[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006158[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF800615C[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006160[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006168[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF800616C[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006170[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006174[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF800617C[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006180[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006184[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006188[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_loopback = 0x0 + // .. .. ==> 0XF8006190[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_all_dq_mpr_rd_resp = 0x0 + // .. .. ==> 0XF8006190[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_use_rank0_delays = 0x1 + // .. .. ==> 0XF8006190[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_phy_int_lpbk = 0x0 + // .. .. ==> 0XF8006190[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU ,0x10040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006208[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF800620C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006210[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006214[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_per_bank_refresh = 0x0 + // .. .. ==> 0XF80062A8[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000081U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B4C[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B4C[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B4C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B4C[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B4C[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000672U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B54[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B54[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B54[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B54[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B54[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000674U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x3 + // .. ==> 0XF8000B6C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. REFIO_TEST = 0x0 + // .. ==> 0XF8000B6C[11:10] = 0x00000000U + // .. ==> MASK : 0x00000C00U VAL : 0x00000000U + // .. REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x00007FFFU ,0x00000260U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000021U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[16:14] = 0x00000000U + // .. .. ==> MASK : 0x0001C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000700[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000700[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003F01U ,0x00001201U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000704[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000704[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000708[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000708[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800070C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800070C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000710[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000710[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000714[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000714[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000718[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000718[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800071C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000720[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000720[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000724[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000728[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000728[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800072C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800072C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000730[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000730[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000734[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000734[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000738[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF8000738[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000738[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF800073C[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800073C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000740[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000740[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000740[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000740[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000740[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000740[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000740[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000740[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000740[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000744[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000744[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000744[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000744[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000744[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000744[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000744[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000744[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000744[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000748[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000748[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000748[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000748[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000748[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000748[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000748[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000748[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000748[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800074C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800074C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800074C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800074C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800074C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800074C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800074C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800074C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800074C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000750[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000750[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000750[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000750[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000750[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000750[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000750[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000750[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000750[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000754[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000754[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000754[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000754[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000754[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000754[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000754[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000754[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000754[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000758[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000758[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000758[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000758[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000758[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000758[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000758[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000758[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000758[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800075C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800075C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800075C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800075C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800075C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800075C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800075C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800075C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800075C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000760[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000760[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000760[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000760[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000760[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000760[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000760[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000760[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000760[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000764[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000764[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000764[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000764[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000764[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000764[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000764[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000764[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000764[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000768[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000768[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000768[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000768[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000768[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000768[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000768[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000768[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000768[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800076C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800076C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800076C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800076C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800076C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800076C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800076C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800076C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800076C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000770[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000770[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000774[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000774[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000778[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000778[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800077C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800077C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000780[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000780[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000784[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000784[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000788[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000788[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800078C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800078C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000790[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000790[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000794[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000794[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000798[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000798[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800079C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800079C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A8[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007AC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007AC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007AC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007AC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007AC[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007AC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007AC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007AC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007AC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 2 + // .. ==> 0XF80007B8[7:5] = 0x00000002U + // .. ==> MASK : 0x000000E0U VAL : 0x00000040U + // .. Speed = 0 + // .. ==> 0XF80007B8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU ,0x00001240U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007BC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007BC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007BC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007BC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 2 + // .. ==> 0XF80007BC[7:5] = 0x00000002U + // .. ==> MASK : 0x000000E0U VAL : 0x00000040U + // .. Speed = 0 + // .. ==> 0XF80007BC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007BC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007BC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007BC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU ,0x00001240U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007C8[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007C8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007CC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007CC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007CC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007CC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007CC[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007CC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007CC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007CC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007CC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001280U), + // .. SDIO0_CD_SEL = 0 + // .. ==> 0XF8000830[21:16] = 0x00000000U + // .. ==> MASK : 0x003F0000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F0000U ,0x00000000U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000180U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0001004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0001004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x00000FFFU ,0x00000020U), + // .. BDIV = 0x6 + // .. ==> 0XE0000034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0000034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0000018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0000000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0000000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0000000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0000000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0000000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0000000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0000000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0000000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0000000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0000000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0000004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0000004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0000004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0000004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0000004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0000004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0000004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: TPIU WIDTH IN CASE OF EMIO + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0XC5ACCE55 + // .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. .. START: TRACE CURRENT PORT SIZE + // .. .. a = 2 + // .. .. ==> 0XF8803004[31:0] = 0x00000002U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU ,0x00000002U), + // .. .. FINISH: TRACE CURRENT PORT SIZE + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0X0 + // .. .. ==> 0XF8803FB0[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0x00000000U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. FINISH: TPIU WIDTH IN CASE OF EMIO + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0xa00 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x200 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000200U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000200U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0200U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0xa00 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x200 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000200U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000200U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0200U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. .. START: USB1 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB1 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. .. START: ENET0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0xa00 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x800 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000800U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000800U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0800U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0xa00 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x800 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000800U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000800U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0800U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: ENET0 RESET + // .. .. .. START: ENET1 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: ENET1 RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. .. START: I2C0 RESET + // .. .. .. .. START: DIR MODE GPIO BANK0 + // .. .. .. .. FINISH: DIR MODE GPIO BANK0 + // .. .. .. .. START: DIR MODE GPIO BANK1 + // .. .. .. .. FINISH: DIR MODE GPIO BANK1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: I2C0 RESET + // .. .. .. START: I2C1 RESET + // .. .. .. .. START: DIR MODE GPIO BANK0 + // .. .. .. .. FINISH: DIR MODE GPIO BANK0 + // .. .. .. .. START: DIR MODE GPIO BANK1 + // .. .. .. .. FINISH: DIR MODE GPIO BANK1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: I2C1 RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_2_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_INP_ICT_EN_0 = 3 + // .. ==> 0XF8000900[1:0] = 0x00000003U + // .. ==> MASK : 0x00000003U VAL : 0x00000003U + // .. USER_INP_ICT_EN_1 = 3 + // .. ==> 0XF8000900[3:2] = 0x00000003U + // .. ==> MASK : 0x0000000CU VAL : 0x0000000CU + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: TPIU WIDTH IN CASE OF EMIO + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0XC5ACCE55 + // .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. .. START: TRACE CURRENT PORT SIZE + // .. .. a = 2 + // .. .. ==> 0XF8803004[31:0] = 0x00000002U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU ,0x00000002U), + // .. .. FINISH: TRACE CURRENT PORT SIZE + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0X0 + // .. .. ==> 0XF8803FB0[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0x00000000U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. FINISH: TPIU WIDTH IN CASE OF EMIO + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_debug_2_0[] = { + // START: top + // .. START: CROSS TRIGGER CONFIGURATIONS + // .. .. START: UNLOCKING CTI REGISTERS + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8898FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8898FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8899FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8899FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8809FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8809FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: UNLOCKING CTI REGISTERS + // .. .. START: ENABLING CTI MODULES AND CHANNELS + // .. .. FINISH: ENABLING CTI MODULES AND CHANNELS + // .. .. START: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. .. FINISH: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. FINISH: CROSS TRIGGER CONFIGURATIONS + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_pll_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: PLL SLCR REGISTERS + // .. .. START: ARM PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000110[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000110[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000110[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000110, 0x003FFFF0U ,0x000FA220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x28 + // .. .. .. ==> 0XF8000100[18:12] = 0x00000028U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00028000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x0007F000U ,0x00028000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000100[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. ARM_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000001U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000100[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000100, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. SRCSEL = 0x0 + // .. .. .. ==> 0XF8000120[5:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. .. DIVISOR = 0x2 + // .. .. .. ==> 0XF8000120[13:8] = 0x00000002U + // .. .. .. ==> MASK : 0x00003F00U VAL : 0x00000200U + // .. .. .. CPU_6OR4XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[24:24] = 0x00000001U + // .. .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. .. CPU_3OR2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[25:25] = 0x00000001U + // .. .. .. ==> MASK : 0x02000000U VAL : 0x02000000U + // .. .. .. CPU_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[26:26] = 0x00000001U + // .. .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. .. CPU_1XCLKACT = 0x1 + // .. .. .. ==> 0XF8000120[27:27] = 0x00000001U + // .. .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. .. CPU_PERI_CLKACT = 0x1 + // .. .. .. ==> 0XF8000120[28:28] = 0x00000001U + // .. .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000120, 0x1F003F30U ,0x1F000200U), + // .. .. FINISH: ARM PLL INIT + // .. .. START: DDR PLL INIT + // .. .. PLL_RES = 0x2 + // .. .. ==> 0XF8000114[7:4] = 0x00000002U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000020U + // .. .. PLL_CP = 0x2 + // .. .. ==> 0XF8000114[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. LOCK_CNT = 0x12c + // .. .. ==> 0XF8000114[21:12] = 0x0000012CU + // .. .. ==> MASK : 0x003FF000U VAL : 0x0012C000U + // .. .. + EMIT_MASKWRITE(0XF8000114, 0x003FFFF0U ,0x0012C220U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x20 + // .. .. .. ==> 0XF8000104[18:12] = 0x00000020U + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x00020000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x0007F000U ,0x00020000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000104[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. DDR_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000002U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000104[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000104, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. .. DDR_3XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. DDR_2XCLKACT = 0x1 + // .. .. .. ==> 0XF8000124[1:1] = 0x00000001U + // .. .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. .. DDR_3XCLK_DIVISOR = 0x2 + // .. .. .. ==> 0XF8000124[25:20] = 0x00000002U + // .. .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U + // .. .. .. DDR_2XCLK_DIVISOR = 0x3 + // .. .. .. ==> 0XF8000124[31:26] = 0x00000003U + // .. .. .. ==> MASK : 0xFC000000U VAL : 0x0C000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000124, 0xFFF00003U ,0x0C200003U), + // .. .. FINISH: DDR PLL INIT + // .. .. START: IO PLL INIT + // .. .. PLL_RES = 0xc + // .. .. ==> 0XF8000118[7:4] = 0x0000000CU + // .. .. ==> MASK : 0x000000F0U VAL : 0x000000C0U + // .. .. PLL_CP = 0x3 + // .. .. ==> 0XF8000118[11:8] = 0x00000003U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000300U + // .. .. LOCK_CNT = 0xfa + // .. .. ==> 0XF8000118[21:12] = 0x000000FAU + // .. .. ==> MASK : 0x003FF000U VAL : 0x000FA000U + // .. .. + EMIT_MASKWRITE(0XF8000118, 0x003FFFF0U ,0x000FA3C0U), + // .. .. .. START: UPDATE FB_DIV + // .. .. .. PLL_FDIV = 0x2d + // .. .. .. ==> 0XF8000108[18:12] = 0x0000002DU + // .. .. .. ==> MASK : 0x0007F000U VAL : 0x0002D000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x0007F000U ,0x0002D000U), + // .. .. .. FINISH: UPDATE FB_DIV + // .. .. .. START: BY PASS PLL + // .. .. .. PLL_BYPASS_FORCE = 1 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000001U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000010U), + // .. .. .. FINISH: BY PASS PLL + // .. .. .. START: ASSERT RESET + // .. .. .. PLL_RESET = 1 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000001U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000001U), + // .. .. .. FINISH: ASSERT RESET + // .. .. .. START: DEASSERT RESET + // .. .. .. PLL_RESET = 0 + // .. .. .. ==> 0XF8000108[0:0] = 0x00000000U + // .. .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000001U ,0x00000000U), + // .. .. .. FINISH: DEASSERT RESET + // .. .. .. START: CHECK PLL STATUS + // .. .. .. IO_PLL_LOCK = 1 + // .. .. .. ==> 0XF800010C[2:2] = 0x00000001U + // .. .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. .. + EMIT_MASKPOLL(0XF800010C, 0x00000004U), + // .. .. .. FINISH: CHECK PLL STATUS + // .. .. .. START: REMOVE PLL BY PASS + // .. .. .. PLL_BYPASS_FORCE = 0 + // .. .. .. ==> 0XF8000108[4:4] = 0x00000000U + // .. .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. .. + EMIT_MASKWRITE(0XF8000108, 0x00000010U ,0x00000000U), + // .. .. .. FINISH: REMOVE PLL BY PASS + // .. .. FINISH: IO PLL INIT + // .. FINISH: PLL SLCR REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_clock_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: CLOCK CONTROL SLCR REGISTERS + // .. CLKACT = 0x1 + // .. ==> 0XF8000128[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. DIVISOR0 = 0x23 + // .. ==> 0XF8000128[13:8] = 0x00000023U + // .. ==> MASK : 0x00003F00U VAL : 0x00002300U + // .. DIVISOR1 = 0x3 + // .. ==> 0XF8000128[25:20] = 0x00000003U + // .. ==> MASK : 0x03F00000U VAL : 0x00300000U + // .. + EMIT_MASKWRITE(0XF8000128, 0x03F03F01U ,0x00302301U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000138[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000138[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000138, 0x00000011U ,0x00000001U), + // .. CLKACT = 0x1 + // .. ==> 0XF8000140[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000140[6:4] = 0x00000000U + // .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. DIVISOR = 0xc + // .. ==> 0XF8000140[13:8] = 0x0000000CU + // .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. DIVISOR1 = 0x1 + // .. ==> 0XF8000140[25:20] = 0x00000001U + // .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. + EMIT_MASKWRITE(0XF8000140, 0x03F03F71U ,0x00100C01U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000150[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x0 + // .. ==> 0XF8000150[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000150[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xc + // .. ==> 0XF8000150[13:8] = 0x0000000CU + // .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. + EMIT_MASKWRITE(0XF8000150, 0x00003F33U ,0x00000C01U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000154[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000154[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000154[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0xf + // .. ==> 0XF8000154[13:8] = 0x0000000FU + // .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. + EMIT_MASKWRITE(0XF8000154, 0x00003F33U ,0x00000F03U), + // .. CLKACT0 = 0x1 + // .. ==> 0XF8000158[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. CLKACT1 = 0x1 + // .. ==> 0XF8000158[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. SRCSEL = 0x0 + // .. ==> 0XF8000158[5:4] = 0x00000000U + // .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. DIVISOR = 0x9 + // .. ==> 0XF8000158[13:8] = 0x00000009U + // .. ==> MASK : 0x00003F00U VAL : 0x00000900U + // .. + EMIT_MASKWRITE(0XF8000158, 0x00003F33U ,0x00000903U), + // .. .. START: TRACE CLOCK + // .. .. FINISH: TRACE CLOCK + // .. .. CLKACT = 0x1 + // .. .. ==> 0XF8000168[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000168[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR = 0x8 + // .. .. ==> 0XF8000168[13:8] = 0x00000008U + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000800U + // .. .. + EMIT_MASKWRITE(0XF8000168, 0x00003F31U ,0x00000801U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000170[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0x1e + // .. .. ==> 0XF8000170[13:8] = 0x0000001EU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00001E00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000170[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000170, 0x03F03F30U ,0x00101E00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000180[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xf + // .. .. ==> 0XF8000180[13:8] = 0x0000000FU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000F00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000180[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U ,0x00100F00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF8000190[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xc + // .. .. ==> 0XF8000190[13:8] = 0x0000000CU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000C00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF8000190[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U ,0x00100C00U), + // .. .. SRCSEL = 0x0 + // .. .. ==> 0XF80001A0[5:4] = 0x00000000U + // .. .. ==> MASK : 0x00000030U VAL : 0x00000000U + // .. .. DIVISOR0 = 0xa + // .. .. ==> 0XF80001A0[13:8] = 0x0000000AU + // .. .. ==> MASK : 0x00003F00U VAL : 0x00000A00U + // .. .. DIVISOR1 = 0x1 + // .. .. ==> 0XF80001A0[25:20] = 0x00000001U + // .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U + // .. .. + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U ,0x00100A00U), + // .. .. CLK_621_TRUE = 0x1 + // .. .. ==> 0XF80001C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. + EMIT_MASKWRITE(0XF80001C4, 0x00000001U ,0x00000001U), + // .. .. DMA_CPU_2XCLKACT = 0x1 + // .. .. ==> 0XF800012C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. USB0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[2:2] = 0x00000001U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. .. USB1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. GEM0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[6:6] = 0x00000001U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000040U + // .. .. GEM1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. SDI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[10:10] = 0x00000001U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000400U + // .. .. SDI1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. SPI0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. SPI1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. CAN0_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. CAN1_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. I2C0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[18:18] = 0x00000001U + // .. .. ==> MASK : 0x00040000U VAL : 0x00040000U + // .. .. I2C1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. UART0_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[20:20] = 0x00000001U + // .. .. ==> MASK : 0x00100000U VAL : 0x00100000U + // .. .. UART1_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. GPIO_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[22:22] = 0x00000001U + // .. .. ==> MASK : 0x00400000U VAL : 0x00400000U + // .. .. LQSPI_CPU_1XCLKACT = 0x0 + // .. .. ==> 0XF800012C[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. SMC_CPU_1XCLKACT = 0x1 + // .. .. ==> 0XF800012C[24:24] = 0x00000001U + // .. .. ==> MASK : 0x01000000U VAL : 0x01000000U + // .. .. + EMIT_MASKWRITE(0XF800012C, 0x01FFCCCDU ,0x017CC44DU), + // .. FINISH: CLOCK CONTROL SLCR REGISTERS + // .. START: THIS SHOULD BE BLANK + // .. FINISH: THIS SHOULD BE BLANK + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_ddr_init_data_1_0[] = { + // START: top + // .. START: DDR INITIALIZATION + // .. .. START: LOCK DDR + // .. .. reg_ddrc_soft_rstb = 0 + // .. .. ==> 0XF8006000[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 0x1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000080U), + // .. .. FINISH: LOCK DDR + // .. .. reg_ddrc_t_rfc_nom_x32 = 0x81 + // .. .. ==> 0XF8006004[11:0] = 0x00000081U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000081U + // .. .. reg_ddrc_active_ranks = 0x1 + // .. .. ==> 0XF8006004[13:12] = 0x00000001U + // .. .. ==> MASK : 0x00003000U VAL : 0x00001000U + // .. .. reg_ddrc_addrmap_cs_bit0 = 0x0 + // .. .. ==> 0XF8006004[18:14] = 0x00000000U + // .. .. ==> MASK : 0x0007C000U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_block = 0x1 + // .. .. ==> 0XF8006004[20:19] = 0x00000001U + // .. .. ==> MASK : 0x00180000U VAL : 0x00080000U + // .. .. reg_ddrc_diff_rank_rd_2cycle_gap = 0x0 + // .. .. ==> 0XF8006004[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_cs_bit1 = 0x0 + // .. .. ==> 0XF8006004[26:22] = 0x00000000U + // .. .. ==> MASK : 0x07C00000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_open_bank = 0x0 + // .. .. ==> 0XF8006004[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_4bank_ram = 0x0 + // .. .. ==> 0XF8006004[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006004, 0x1FFFFFFFU ,0x00081081U), + // .. .. reg_ddrc_hpr_min_non_critical_x32 = 0xf + // .. .. ==> 0XF8006008[10:0] = 0x0000000FU + // .. .. ==> MASK : 0x000007FFU VAL : 0x0000000FU + // .. .. reg_ddrc_hpr_max_starve_x32 = 0xf + // .. .. ==> 0XF8006008[21:11] = 0x0000000FU + // .. .. ==> MASK : 0x003FF800U VAL : 0x00007800U + // .. .. reg_ddrc_hpr_xact_run_length = 0xf + // .. .. ==> 0XF8006008[25:22] = 0x0000000FU + // .. .. ==> MASK : 0x03C00000U VAL : 0x03C00000U + // .. .. + EMIT_MASKWRITE(0XF8006008, 0x03FFFFFFU ,0x03C0780FU), + // .. .. reg_ddrc_lpr_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF800600C[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_lpr_max_starve_x32 = 0x2 + // .. .. ==> 0XF800600C[21:11] = 0x00000002U + // .. .. ==> MASK : 0x003FF800U VAL : 0x00001000U + // .. .. reg_ddrc_lpr_xact_run_length = 0x8 + // .. .. ==> 0XF800600C[25:22] = 0x00000008U + // .. .. ==> MASK : 0x03C00000U VAL : 0x02000000U + // .. .. + EMIT_MASKWRITE(0XF800600C, 0x03FFFFFFU ,0x02001001U), + // .. .. reg_ddrc_w_min_non_critical_x32 = 0x1 + // .. .. ==> 0XF8006010[10:0] = 0x00000001U + // .. .. ==> MASK : 0x000007FFU VAL : 0x00000001U + // .. .. reg_ddrc_w_xact_run_length = 0x8 + // .. .. ==> 0XF8006010[14:11] = 0x00000008U + // .. .. ==> MASK : 0x00007800U VAL : 0x00004000U + // .. .. reg_ddrc_w_max_starve_x32 = 0x2 + // .. .. ==> 0XF8006010[25:15] = 0x00000002U + // .. .. ==> MASK : 0x03FF8000U VAL : 0x00010000U + // .. .. + EMIT_MASKWRITE(0XF8006010, 0x03FFFFFFU ,0x00014001U), + // .. .. reg_ddrc_t_rc = 0x1a + // .. .. ==> 0XF8006014[5:0] = 0x0000001AU + // .. .. ==> MASK : 0x0000003FU VAL : 0x0000001AU + // .. .. reg_ddrc_t_rfc_min = 0xa0 + // .. .. ==> 0XF8006014[13:6] = 0x000000A0U + // .. .. ==> MASK : 0x00003FC0U VAL : 0x00002800U + // .. .. reg_ddrc_post_selfref_gap_x32 = 0x10 + // .. .. ==> 0XF8006014[20:14] = 0x00000010U + // .. .. ==> MASK : 0x001FC000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006014, 0x001FFFFFU ,0x0004281AU), + // .. .. reg_ddrc_wr2pre = 0x12 + // .. .. ==> 0XF8006018[4:0] = 0x00000012U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000012U + // .. .. reg_ddrc_powerdown_to_x32 = 0x6 + // .. .. ==> 0XF8006018[9:5] = 0x00000006U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000C0U + // .. .. reg_ddrc_t_faw = 0x16 + // .. .. ==> 0XF8006018[15:10] = 0x00000016U + // .. .. ==> MASK : 0x0000FC00U VAL : 0x00005800U + // .. .. reg_ddrc_t_ras_max = 0x24 + // .. .. ==> 0XF8006018[21:16] = 0x00000024U + // .. .. ==> MASK : 0x003F0000U VAL : 0x00240000U + // .. .. reg_ddrc_t_ras_min = 0x13 + // .. .. ==> 0XF8006018[26:22] = 0x00000013U + // .. .. ==> MASK : 0x07C00000U VAL : 0x04C00000U + // .. .. reg_ddrc_t_cke = 0x4 + // .. .. ==> 0XF8006018[31:28] = 0x00000004U + // .. .. ==> MASK : 0xF0000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006018, 0xF7FFFFFFU ,0x44E458D2U), + // .. .. reg_ddrc_write_latency = 0x5 + // .. .. ==> 0XF800601C[4:0] = 0x00000005U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000005U + // .. .. reg_ddrc_rd2wr = 0x7 + // .. .. ==> 0XF800601C[9:5] = 0x00000007U + // .. .. ==> MASK : 0x000003E0U VAL : 0x000000E0U + // .. .. reg_ddrc_wr2rd = 0xe + // .. .. ==> 0XF800601C[14:10] = 0x0000000EU + // .. .. ==> MASK : 0x00007C00U VAL : 0x00003800U + // .. .. reg_ddrc_t_xp = 0x4 + // .. .. ==> 0XF800601C[19:15] = 0x00000004U + // .. .. ==> MASK : 0x000F8000U VAL : 0x00020000U + // .. .. reg_ddrc_pad_pd = 0x0 + // .. .. ==> 0XF800601C[22:20] = 0x00000000U + // .. .. ==> MASK : 0x00700000U VAL : 0x00000000U + // .. .. reg_ddrc_rd2pre = 0x4 + // .. .. ==> 0XF800601C[27:23] = 0x00000004U + // .. .. ==> MASK : 0x0F800000U VAL : 0x02000000U + // .. .. reg_ddrc_t_rcd = 0x7 + // .. .. ==> 0XF800601C[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF800601C, 0xFFFFFFFFU ,0x720238E5U), + // .. .. reg_ddrc_t_ccd = 0x4 + // .. .. ==> 0XF8006020[4:2] = 0x00000004U + // .. .. ==> MASK : 0x0000001CU VAL : 0x00000010U + // .. .. reg_ddrc_t_rrd = 0x6 + // .. .. ==> 0XF8006020[7:5] = 0x00000006U + // .. .. ==> MASK : 0x000000E0U VAL : 0x000000C0U + // .. .. reg_ddrc_refresh_margin = 0x2 + // .. .. ==> 0XF8006020[11:8] = 0x00000002U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000200U + // .. .. reg_ddrc_t_rp = 0x7 + // .. .. ==> 0XF8006020[15:12] = 0x00000007U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00007000U + // .. .. reg_ddrc_refresh_to_x32 = 0x8 + // .. .. ==> 0XF8006020[20:16] = 0x00000008U + // .. .. ==> MASK : 0x001F0000U VAL : 0x00080000U + // .. .. reg_ddrc_sdram = 0x1 + // .. .. ==> 0XF8006020[21:21] = 0x00000001U + // .. .. ==> MASK : 0x00200000U VAL : 0x00200000U + // .. .. reg_ddrc_mobile = 0x0 + // .. .. ==> 0XF8006020[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. reg_ddrc_clock_stop_en = 0x0 + // .. .. ==> 0XF8006020[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. reg_ddrc_read_latency = 0x7 + // .. .. ==> 0XF8006020[28:24] = 0x00000007U + // .. .. ==> MASK : 0x1F000000U VAL : 0x07000000U + // .. .. reg_phy_mode_ddr1_ddr2 = 0x1 + // .. .. ==> 0XF8006020[29:29] = 0x00000001U + // .. .. ==> MASK : 0x20000000U VAL : 0x20000000U + // .. .. reg_ddrc_dis_pad_pd = 0x0 + // .. .. ==> 0XF8006020[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_ddrc_loopback = 0x0 + // .. .. ==> 0XF8006020[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006020, 0xFFFFFFFCU ,0x272872D0U), + // .. .. reg_ddrc_en_2t_timing_mode = 0x0 + // .. .. ==> 0XF8006024[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_prefer_write = 0x0 + // .. .. ==> 0XF8006024[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_max_rank_rd = 0xf + // .. .. ==> 0XF8006024[5:2] = 0x0000000FU + // .. .. ==> MASK : 0x0000003CU VAL : 0x0000003CU + // .. .. reg_ddrc_mr_wr = 0x0 + // .. .. ==> 0XF8006024[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_ddrc_mr_addr = 0x0 + // .. .. ==> 0XF8006024[8:7] = 0x00000000U + // .. .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. .. reg_ddrc_mr_data = 0x0 + // .. .. ==> 0XF8006024[24:9] = 0x00000000U + // .. .. ==> MASK : 0x01FFFE00U VAL : 0x00000000U + // .. .. ddrc_reg_mr_wr_busy = 0x0 + // .. .. ==> 0XF8006024[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_type = 0x0 + // .. .. ==> 0XF8006024[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. reg_ddrc_mr_rdata_valid = 0x0 + // .. .. ==> 0XF8006024[27:27] = 0x00000000U + // .. .. ==> MASK : 0x08000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006024, 0x0FFFFFFFU ,0x0000003CU), + // .. .. reg_ddrc_final_wait_x32 = 0x7 + // .. .. ==> 0XF8006028[6:0] = 0x00000007U + // .. .. ==> MASK : 0x0000007FU VAL : 0x00000007U + // .. .. reg_ddrc_pre_ocd_x32 = 0x0 + // .. .. ==> 0XF8006028[10:7] = 0x00000000U + // .. .. ==> MASK : 0x00000780U VAL : 0x00000000U + // .. .. reg_ddrc_t_mrd = 0x4 + // .. .. ==> 0XF8006028[13:11] = 0x00000004U + // .. .. ==> MASK : 0x00003800U VAL : 0x00002000U + // .. .. + EMIT_MASKWRITE(0XF8006028, 0x00003FFFU ,0x00002007U), + // .. .. reg_ddrc_emr2 = 0x8 + // .. .. ==> 0XF800602C[15:0] = 0x00000008U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000008U + // .. .. reg_ddrc_emr3 = 0x0 + // .. .. ==> 0XF800602C[31:16] = 0x00000000U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800602C, 0xFFFFFFFFU ,0x00000008U), + // .. .. reg_ddrc_mr = 0x930 + // .. .. ==> 0XF8006030[15:0] = 0x00000930U + // .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000930U + // .. .. reg_ddrc_emr = 0x4 + // .. .. ==> 0XF8006030[31:16] = 0x00000004U + // .. .. ==> MASK : 0xFFFF0000U VAL : 0x00040000U + // .. .. + EMIT_MASKWRITE(0XF8006030, 0xFFFFFFFFU ,0x00040930U), + // .. .. reg_ddrc_burst_rdwr = 0x4 + // .. .. ==> 0XF8006034[3:0] = 0x00000004U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U + // .. .. reg_ddrc_pre_cke_x1024 = 0x105 + // .. .. ==> 0XF8006034[13:4] = 0x00000105U + // .. .. ==> MASK : 0x00003FF0U VAL : 0x00001050U + // .. .. reg_ddrc_post_cke_x1024 = 0x1 + // .. .. ==> 0XF8006034[25:16] = 0x00000001U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U + // .. .. reg_ddrc_burstchop = 0x0 + // .. .. ==> 0XF8006034[28:28] = 0x00000000U + // .. .. ==> MASK : 0x10000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU ,0x00011054U), + // .. .. reg_ddrc_force_low_pri_n = 0x0 + // .. .. ==> 0XF8006038[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_dis_dq = 0x0 + // .. .. ==> 0XF8006038[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_debug_mode = 0x0 + // .. .. ==> 0XF8006038[6:6] = 0x00000000U + // .. .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. .. reg_phy_wr_level_start = 0x0 + // .. .. ==> 0XF8006038[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_phy_rd_level_start = 0x0 + // .. .. ==> 0XF8006038[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_dq0_wait_t = 0x0 + // .. .. ==> 0XF8006038[12:9] = 0x00000000U + // .. .. ==> MASK : 0x00001E00U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006038, 0x00001FC3U ,0x00000000U), + // .. .. reg_ddrc_addrmap_bank_b0 = 0x7 + // .. .. ==> 0XF800603C[3:0] = 0x00000007U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000007U + // .. .. reg_ddrc_addrmap_bank_b1 = 0x7 + // .. .. ==> 0XF800603C[7:4] = 0x00000007U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000070U + // .. .. reg_ddrc_addrmap_bank_b2 = 0x7 + // .. .. ==> 0XF800603C[11:8] = 0x00000007U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000700U + // .. .. reg_ddrc_addrmap_col_b5 = 0x0 + // .. .. ==> 0XF800603C[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b6 = 0x0 + // .. .. ==> 0XF800603C[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800603C, 0x000FFFFFU ,0x00000777U), + // .. .. reg_ddrc_addrmap_col_b2 = 0x0 + // .. .. ==> 0XF8006040[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b3 = 0x0 + // .. .. ==> 0XF8006040[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b4 = 0x0 + // .. .. ==> 0XF8006040[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b7 = 0x0 + // .. .. ==> 0XF8006040[15:12] = 0x00000000U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b8 = 0x0 + // .. .. ==> 0XF8006040[19:16] = 0x00000000U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00000000U + // .. .. reg_ddrc_addrmap_col_b9 = 0xf + // .. .. ==> 0XF8006040[23:20] = 0x0000000FU + // .. .. ==> MASK : 0x00F00000U VAL : 0x00F00000U + // .. .. reg_ddrc_addrmap_col_b10 = 0xf + // .. .. ==> 0XF8006040[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. reg_ddrc_addrmap_col_b11 = 0xf + // .. .. ==> 0XF8006040[31:28] = 0x0000000FU + // .. .. ==> MASK : 0xF0000000U VAL : 0xF0000000U + // .. .. + EMIT_MASKWRITE(0XF8006040, 0xFFFFFFFFU ,0xFFF00000U), + // .. .. reg_ddrc_addrmap_row_b0 = 0x6 + // .. .. ==> 0XF8006044[3:0] = 0x00000006U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000006U + // .. .. reg_ddrc_addrmap_row_b1 = 0x6 + // .. .. ==> 0XF8006044[7:4] = 0x00000006U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000060U + // .. .. reg_ddrc_addrmap_row_b2_11 = 0x6 + // .. .. ==> 0XF8006044[11:8] = 0x00000006U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000600U + // .. .. reg_ddrc_addrmap_row_b12 = 0x6 + // .. .. ==> 0XF8006044[15:12] = 0x00000006U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00006000U + // .. .. reg_ddrc_addrmap_row_b13 = 0x6 + // .. .. ==> 0XF8006044[19:16] = 0x00000006U + // .. .. ==> MASK : 0x000F0000U VAL : 0x00060000U + // .. .. reg_ddrc_addrmap_row_b14 = 0x6 + // .. .. ==> 0XF8006044[23:20] = 0x00000006U + // .. .. ==> MASK : 0x00F00000U VAL : 0x00600000U + // .. .. reg_ddrc_addrmap_row_b15 = 0xf + // .. .. ==> 0XF8006044[27:24] = 0x0000000FU + // .. .. ==> MASK : 0x0F000000U VAL : 0x0F000000U + // .. .. + EMIT_MASKWRITE(0XF8006044, 0x0FFFFFFFU ,0x0F666666U), + // .. .. reg_ddrc_rank0_rd_odt = 0x0 + // .. .. ==> 0XF8006048[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_rank0_wr_odt = 0x1 + // .. .. ==> 0XF8006048[5:3] = 0x00000001U + // .. .. ==> MASK : 0x00000038U VAL : 0x00000008U + // .. .. reg_ddrc_rank1_rd_odt = 0x1 + // .. .. ==> 0XF8006048[8:6] = 0x00000001U + // .. .. ==> MASK : 0x000001C0U VAL : 0x00000040U + // .. .. reg_ddrc_rank1_wr_odt = 0x1 + // .. .. ==> 0XF8006048[11:9] = 0x00000001U + // .. .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. .. reg_phy_rd_local_odt = 0x0 + // .. .. ==> 0XF8006048[13:12] = 0x00000000U + // .. .. ==> MASK : 0x00003000U VAL : 0x00000000U + // .. .. reg_phy_wr_local_odt = 0x3 + // .. .. ==> 0XF8006048[15:14] = 0x00000003U + // .. .. ==> MASK : 0x0000C000U VAL : 0x0000C000U + // .. .. reg_phy_idle_local_odt = 0x3 + // .. .. ==> 0XF8006048[17:16] = 0x00000003U + // .. .. ==> MASK : 0x00030000U VAL : 0x00030000U + // .. .. reg_ddrc_rank2_rd_odt = 0x0 + // .. .. ==> 0XF8006048[20:18] = 0x00000000U + // .. .. ==> MASK : 0x001C0000U VAL : 0x00000000U + // .. .. reg_ddrc_rank2_wr_odt = 0x0 + // .. .. ==> 0XF8006048[23:21] = 0x00000000U + // .. .. ==> MASK : 0x00E00000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_rd_odt = 0x0 + // .. .. ==> 0XF8006048[26:24] = 0x00000000U + // .. .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. .. reg_ddrc_rank3_wr_odt = 0x0 + // .. .. ==> 0XF8006048[29:27] = 0x00000000U + // .. .. ==> MASK : 0x38000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006048, 0x3FFFFFFFU ,0x0003C248U), + // .. .. reg_phy_rd_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_wr_cmd_to_data = 0x0 + // .. .. ==> 0XF8006050[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_phy_rdc_we_to_re_delay = 0x8 + // .. .. ==> 0XF8006050[11:8] = 0x00000008U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000800U + // .. .. reg_phy_rdc_fifo_rst_disable = 0x0 + // .. .. ==> 0XF8006050[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_phy_use_fixed_re = 0x1 + // .. .. ==> 0XF8006050[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_rdc_fifo_rst_err_cnt_clr = 0x0 + // .. .. ==> 0XF8006050[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_dis_phy_ctrl_rstn = 0x0 + // .. .. ==> 0XF8006050[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_phy_clk_stall_level = 0x0 + // .. .. ==> 0XF8006050[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[27:24] = 0x00000007U + // .. .. ==> MASK : 0x0F000000U VAL : 0x07000000U + // .. .. reg_phy_wrlvl_num_of_dq0 = 0x7 + // .. .. ==> 0XF8006050[31:28] = 0x00000007U + // .. .. ==> MASK : 0xF0000000U VAL : 0x70000000U + // .. .. + EMIT_MASKWRITE(0XF8006050, 0xFF0F8FFFU ,0x77010800U), + // .. .. reg_ddrc_dll_calib_to_min_x1024 = 0x1 + // .. .. ==> 0XF8006058[7:0] = 0x00000001U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000001U + // .. .. reg_ddrc_dll_calib_to_max_x1024 = 0x1 + // .. .. ==> 0XF8006058[15:8] = 0x00000001U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000100U + // .. .. reg_ddrc_dis_dll_calib = 0x0 + // .. .. ==> 0XF8006058[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006058, 0x0001FFFFU ,0x00000101U), + // .. .. reg_ddrc_rd_odt_delay = 0x3 + // .. .. ==> 0XF800605C[3:0] = 0x00000003U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000003U + // .. .. reg_ddrc_wr_odt_delay = 0x0 + // .. .. ==> 0XF800605C[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. reg_ddrc_rd_odt_hold = 0x0 + // .. .. ==> 0XF800605C[11:8] = 0x00000000U + // .. .. ==> MASK : 0x00000F00U VAL : 0x00000000U + // .. .. reg_ddrc_wr_odt_hold = 0x5 + // .. .. ==> 0XF800605C[15:12] = 0x00000005U + // .. .. ==> MASK : 0x0000F000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF800605C, 0x0000FFFFU ,0x00005003U), + // .. .. reg_ddrc_pageclose = 0x0 + // .. .. ==> 0XF8006060[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_lpr_num_entries = 0x1f + // .. .. ==> 0XF8006060[6:1] = 0x0000001FU + // .. .. ==> MASK : 0x0000007EU VAL : 0x0000003EU + // .. .. reg_ddrc_auto_pre_en = 0x0 + // .. .. ==> 0XF8006060[7:7] = 0x00000000U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. .. reg_ddrc_refresh_update_level = 0x0 + // .. .. ==> 0XF8006060[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_ddrc_dis_wc = 0x0 + // .. .. ==> 0XF8006060[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_ddrc_dis_collision_page_opt = 0x0 + // .. .. ==> 0XF8006060[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_ddrc_selfref_en = 0x0 + // .. .. ==> 0XF8006060[12:12] = 0x00000000U + // .. .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006060, 0x000017FFU ,0x0000003EU), + // .. .. reg_ddrc_go2critical_hysteresis = 0x0 + // .. .. ==> 0XF8006064[12:5] = 0x00000000U + // .. .. ==> MASK : 0x00001FE0U VAL : 0x00000000U + // .. .. reg_arb_go2critical_en = 0x1 + // .. .. ==> 0XF8006064[17:17] = 0x00000001U + // .. .. ==> MASK : 0x00020000U VAL : 0x00020000U + // .. .. + EMIT_MASKWRITE(0XF8006064, 0x00021FE0U ,0x00020000U), + // .. .. reg_ddrc_wrlvl_ww = 0x41 + // .. .. ==> 0XF8006068[7:0] = 0x00000041U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000041U + // .. .. reg_ddrc_rdlvl_rr = 0x41 + // .. .. ==> 0XF8006068[15:8] = 0x00000041U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00004100U + // .. .. reg_ddrc_dfi_t_wlmrd = 0x28 + // .. .. ==> 0XF8006068[25:16] = 0x00000028U + // .. .. ==> MASK : 0x03FF0000U VAL : 0x00280000U + // .. .. + EMIT_MASKWRITE(0XF8006068, 0x03FFFFFFU ,0x00284141U), + // .. .. dfi_t_ctrlupd_interval_min_x1024 = 0x10 + // .. .. ==> 0XF800606C[7:0] = 0x00000010U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000010U + // .. .. dfi_t_ctrlupd_interval_max_x1024 = 0x16 + // .. .. ==> 0XF800606C[15:8] = 0x00000016U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00001600U + // .. .. + EMIT_MASKWRITE(0XF800606C, 0x0000FFFFU ,0x00001610U), + // .. .. refresh_timer0_start_value_x32 = 0x0 + // .. .. ==> 0XF80060A0[11:0] = 0x00000000U + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000000U + // .. .. refresh_timer1_start_value_x32 = 0x8 + // .. .. ==> 0XF80060A0[23:12] = 0x00000008U + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00008000U + // .. .. + EMIT_MASKWRITE(0XF80060A0, 0x00FFFFFFU ,0x00008000U), + // .. .. reg_ddrc_dis_auto_zq = 0x0 + // .. .. ==> 0XF80060A4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_ddr3 = 0x1 + // .. .. ==> 0XF80060A4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. reg_ddrc_t_mod = 0x200 + // .. .. ==> 0XF80060A4[11:2] = 0x00000200U + // .. .. ==> MASK : 0x00000FFCU VAL : 0x00000800U + // .. .. reg_ddrc_t_zq_long_nop = 0x200 + // .. .. ==> 0XF80060A4[21:12] = 0x00000200U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00200000U + // .. .. reg_ddrc_t_zq_short_nop = 0x40 + // .. .. ==> 0XF80060A4[31:22] = 0x00000040U + // .. .. ==> MASK : 0xFFC00000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060A4, 0xFFFFFFFFU ,0x10200802U), + // .. .. t_zq_short_interval_x1024 = 0xcb73 + // .. .. ==> 0XF80060A8[19:0] = 0x0000CB73U + // .. .. ==> MASK : 0x000FFFFFU VAL : 0x0000CB73U + // .. .. dram_rstn_x1024 = 0x69 + // .. .. ==> 0XF80060A8[27:20] = 0x00000069U + // .. .. ==> MASK : 0x0FF00000U VAL : 0x06900000U + // .. .. + EMIT_MASKWRITE(0XF80060A8, 0x0FFFFFFFU ,0x0690CB73U), + // .. .. deeppowerdown_en = 0x0 + // .. .. ==> 0XF80060AC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. deeppowerdown_to_x1024 = 0xff + // .. .. ==> 0XF80060AC[8:1] = 0x000000FFU + // .. .. ==> MASK : 0x000001FEU VAL : 0x000001FEU + // .. .. + EMIT_MASKWRITE(0XF80060AC, 0x000001FFU ,0x000001FEU), + // .. .. dfi_wrlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[11:0] = 0x00000FFFU + // .. .. ==> MASK : 0x00000FFFU VAL : 0x00000FFFU + // .. .. dfi_rdlvl_max_x1024 = 0xfff + // .. .. ==> 0XF80060B0[23:12] = 0x00000FFFU + // .. .. ==> MASK : 0x00FFF000U VAL : 0x00FFF000U + // .. .. ddrc_reg_twrlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. ddrc_reg_trdlvl_max_error = 0x0 + // .. .. ==> 0XF80060B0[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. reg_ddrc_dfi_wr_level_en = 0x1 + // .. .. ==> 0XF80060B0[26:26] = 0x00000001U + // .. .. ==> MASK : 0x04000000U VAL : 0x04000000U + // .. .. reg_ddrc_dfi_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF80060B0[27:27] = 0x00000001U + // .. .. ==> MASK : 0x08000000U VAL : 0x08000000U + // .. .. reg_ddrc_dfi_rd_data_eye_train = 0x1 + // .. .. ==> 0XF80060B0[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. + EMIT_MASKWRITE(0XF80060B0, 0x1FFFFFFFU ,0x1CFFFFFFU), + // .. .. reg_ddrc_2t_delay = 0x0 + // .. .. ==> 0XF80060B4[8:0] = 0x00000000U + // .. .. ==> MASK : 0x000001FFU VAL : 0x00000000U + // .. .. reg_ddrc_skip_ocd = 0x1 + // .. .. ==> 0XF80060B4[9:9] = 0x00000001U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. .. reg_ddrc_dis_pre_bypass = 0x0 + // .. .. ==> 0XF80060B4[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060B4, 0x000007FFU ,0x00000200U), + // .. .. reg_ddrc_dfi_t_rddata_en = 0x6 + // .. .. ==> 0XF80060B8[4:0] = 0x00000006U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000006U + // .. .. reg_ddrc_dfi_t_ctrlup_min = 0x3 + // .. .. ==> 0XF80060B8[14:5] = 0x00000003U + // .. .. ==> MASK : 0x00007FE0U VAL : 0x00000060U + // .. .. reg_ddrc_dfi_t_ctrlup_max = 0x40 + // .. .. ==> 0XF80060B8[24:15] = 0x00000040U + // .. .. ==> MASK : 0x01FF8000U VAL : 0x00200000U + // .. .. + EMIT_MASKWRITE(0XF80060B8, 0x01FFFFFFU ,0x00200066U), + // .. .. START: RESET ECC ERROR + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 1 + // .. .. ==> 0XF80060C4[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. Clear_Correctable_DRAM_ECC_error = 1 + // .. .. ==> 0XF80060C4[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000003U), + // .. .. FINISH: RESET ECC ERROR + // .. .. Clear_Uncorrectable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. Clear_Correctable_DRAM_ECC_error = 0x0 + // .. .. ==> 0XF80060C4[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C4, 0x00000003U ,0x00000000U), + // .. .. CORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060C8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. ECC_CORRECTED_BIT_NUM = 0x0 + // .. .. ==> 0XF80060C8[7:1] = 0x00000000U + // .. .. ==> MASK : 0x000000FEU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060C8, 0x000000FFU ,0x00000000U), + // .. .. UNCORR_ECC_LOG_VALID = 0x0 + // .. .. ==> 0XF80060DC[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060DC, 0x00000001U ,0x00000000U), + // .. .. STAT_NUM_CORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[15:8] = 0x00000000U + // .. .. ==> MASK : 0x0000FF00U VAL : 0x00000000U + // .. .. STAT_NUM_UNCORR_ERR = 0x0 + // .. .. ==> 0XF80060F0[7:0] = 0x00000000U + // .. .. ==> MASK : 0x000000FFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80060F0, 0x0000FFFFU ,0x00000000U), + // .. .. reg_ddrc_ecc_mode = 0x0 + // .. .. ==> 0XF80060F4[2:0] = 0x00000000U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000000U + // .. .. reg_ddrc_dis_scrub = 0x1 + // .. .. ==> 0XF80060F4[3:3] = 0x00000001U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000008U + // .. .. + EMIT_MASKWRITE(0XF80060F4, 0x0000000FU ,0x00000008U), + // .. .. reg_phy_dif_on = 0x0 + // .. .. ==> 0XF8006114[3:0] = 0x00000000U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000000U + // .. .. reg_phy_dif_off = 0x0 + // .. .. ==> 0XF8006114[7:4] = 0x00000000U + // .. .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006114, 0x000000FFU ,0x00000000U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006118[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006118[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006118[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006118[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006118[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006118[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006118[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006118, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF800611C[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF800611C[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF800611C[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF800611C[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF800611C[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF800611C[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF800611C[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF800611C, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006120[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006120[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006120[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006120[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006120[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006120[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006120[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006120, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_data_slice_in_use = 0x1 + // .. .. ==> 0XF8006124[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_phy_rdlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_gatelvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_wrlvl_inc_mode = 0x0 + // .. .. ==> 0XF8006124[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_tx = 0x0 + // .. .. ==> 0XF8006124[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_board_lpbk_rx = 0x0 + // .. .. ==> 0XF8006124[5:5] = 0x00000000U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. .. reg_phy_bist_shift_dq = 0x0 + // .. .. ==> 0XF8006124[14:6] = 0x00000000U + // .. .. ==> MASK : 0x00007FC0U VAL : 0x00000000U + // .. .. reg_phy_bist_err_clr = 0x0 + // .. .. ==> 0XF8006124[23:15] = 0x00000000U + // .. .. ==> MASK : 0x00FF8000U VAL : 0x00000000U + // .. .. reg_phy_dq_offset = 0x40 + // .. .. ==> 0XF8006124[30:24] = 0x00000040U + // .. .. ==> MASK : 0x7F000000U VAL : 0x40000000U + // .. .. + EMIT_MASKWRITE(0XF8006124, 0x7FFFFFFFU ,0x40000001U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF800612C[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF800612C[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF800612C, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006130[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006130[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006130, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006134[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006134[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006134, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_wrlvl_init_ratio = 0x0 + // .. .. ==> 0XF8006138[9:0] = 0x00000000U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000000U + // .. .. reg_phy_gatelvl_init_ratio = 0x60 + // .. .. ==> 0XF8006138[19:10] = 0x00000060U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00018000U + // .. .. + EMIT_MASKWRITE(0XF8006138, 0x000FFFFFU ,0x00018000U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006140[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006140[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006140[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006140, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006144[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006144[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006144[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006144, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF8006148[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006148[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006148[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006148, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_rd_dqs_slave_ratio = 0x35 + // .. .. ==> 0XF800614C[9:0] = 0x00000035U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000035U + // .. .. reg_phy_rd_dqs_slave_force = 0x0 + // .. .. ==> 0XF800614C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_rd_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800614C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800614C, 0x000FFFFFU ,0x00000035U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006154[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006154[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006154[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006154, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006158[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006158[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006158[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006158, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF800615C[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF800615C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF800615C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800615C, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_wr_dqs_slave_ratio = 0x80 + // .. .. ==> 0XF8006160[9:0] = 0x00000080U + // .. .. ==> MASK : 0x000003FFU VAL : 0x00000080U + // .. .. reg_phy_wr_dqs_slave_force = 0x0 + // .. .. ==> 0XF8006160[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_dqs_slave_delay = 0x0 + // .. .. ==> 0XF8006160[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006160, 0x000FFFFFU ,0x00000080U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006168[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006168[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006168[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006168, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF800616C[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF800616C[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF800616C[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800616C, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006170[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006170[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006170[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006170, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_fifo_we_slave_ratio = 0xb5 + // .. .. ==> 0XF8006174[10:0] = 0x000000B5U + // .. .. ==> MASK : 0x000007FFU VAL : 0x000000B5U + // .. .. reg_phy_fifo_we_in_force = 0x0 + // .. .. ==> 0XF8006174[11:11] = 0x00000000U + // .. .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. .. reg_phy_fifo_we_in_delay = 0x0 + // .. .. ==> 0XF8006174[20:12] = 0x00000000U + // .. .. ==> MASK : 0x001FF000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006174, 0x001FFFFFU ,0x000000B5U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF800617C[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF800617C[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF800617C[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800617C, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006180[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006180[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006180[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006180, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006184[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006184[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006184[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006184, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_wr_data_slave_ratio = 0xc0 + // .. .. ==> 0XF8006188[9:0] = 0x000000C0U + // .. .. ==> MASK : 0x000003FFU VAL : 0x000000C0U + // .. .. reg_phy_wr_data_slave_force = 0x0 + // .. .. ==> 0XF8006188[10:10] = 0x00000000U + // .. .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. .. reg_phy_wr_data_slave_delay = 0x0 + // .. .. ==> 0XF8006188[19:11] = 0x00000000U + // .. .. ==> MASK : 0x000FF800U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006188, 0x000FFFFFU ,0x000000C0U), + // .. .. reg_phy_loopback = 0x0 + // .. .. ==> 0XF8006190[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_phy_bl2 = 0x0 + // .. .. ==> 0XF8006190[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_phy_at_spd_atpg = 0x0 + // .. .. ==> 0XF8006190[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_phy_bist_enable = 0x0 + // .. .. ==> 0XF8006190[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. reg_phy_bist_force_err = 0x0 + // .. .. ==> 0XF8006190[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. reg_phy_bist_mode = 0x0 + // .. .. ==> 0XF8006190[6:5] = 0x00000000U + // .. .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. .. reg_phy_invert_clkout = 0x1 + // .. .. ==> 0XF8006190[7:7] = 0x00000001U + // .. .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. .. reg_phy_all_dq_mpr_rd_resp = 0x0 + // .. .. ==> 0XF8006190[8:8] = 0x00000000U + // .. .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. .. reg_phy_sel_logic = 0x0 + // .. .. ==> 0XF8006190[9:9] = 0x00000000U + // .. .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_ratio = 0x100 + // .. .. ==> 0XF8006190[19:10] = 0x00000100U + // .. .. ==> MASK : 0x000FFC00U VAL : 0x00040000U + // .. .. reg_phy_ctrl_slave_force = 0x0 + // .. .. ==> 0XF8006190[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006190[27:21] = 0x00000000U + // .. .. ==> MASK : 0x0FE00000U VAL : 0x00000000U + // .. .. reg_phy_use_rank0_delays = 0x1 + // .. .. ==> 0XF8006190[28:28] = 0x00000001U + // .. .. ==> MASK : 0x10000000U VAL : 0x10000000U + // .. .. reg_phy_lpddr = 0x0 + // .. .. ==> 0XF8006190[29:29] = 0x00000000U + // .. .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. .. reg_phy_cmd_latency = 0x0 + // .. .. ==> 0XF8006190[30:30] = 0x00000000U + // .. .. ==> MASK : 0x40000000U VAL : 0x00000000U + // .. .. reg_phy_int_lpbk = 0x0 + // .. .. ==> 0XF8006190[31:31] = 0x00000000U + // .. .. ==> MASK : 0x80000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006190, 0xFFFFFFFFU ,0x10040080U), + // .. .. reg_phy_wr_rl_delay = 0x2 + // .. .. ==> 0XF8006194[4:0] = 0x00000002U + // .. .. ==> MASK : 0x0000001FU VAL : 0x00000002U + // .. .. reg_phy_rd_rl_delay = 0x4 + // .. .. ==> 0XF8006194[9:5] = 0x00000004U + // .. .. ==> MASK : 0x000003E0U VAL : 0x00000080U + // .. .. reg_phy_dll_lock_diff = 0xf + // .. .. ==> 0XF8006194[13:10] = 0x0000000FU + // .. .. ==> MASK : 0x00003C00U VAL : 0x00003C00U + // .. .. reg_phy_use_wr_level = 0x1 + // .. .. ==> 0XF8006194[14:14] = 0x00000001U + // .. .. ==> MASK : 0x00004000U VAL : 0x00004000U + // .. .. reg_phy_use_rd_dqs_gate_level = 0x1 + // .. .. ==> 0XF8006194[15:15] = 0x00000001U + // .. .. ==> MASK : 0x00008000U VAL : 0x00008000U + // .. .. reg_phy_use_rd_data_eye_level = 0x1 + // .. .. ==> 0XF8006194[16:16] = 0x00000001U + // .. .. ==> MASK : 0x00010000U VAL : 0x00010000U + // .. .. reg_phy_dis_calib_rst = 0x0 + // .. .. ==> 0XF8006194[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_phy_ctrl_slave_delay = 0x0 + // .. .. ==> 0XF8006194[19:18] = 0x00000000U + // .. .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006194, 0x000FFFFFU ,0x0001FC82U), + // .. .. reg_arb_page_addr_mask = 0x0 + // .. .. ==> 0XF8006204[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006204, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006208[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006208[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006208[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006208[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006208[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006208, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF800620C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF800620C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF800620C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF800620C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF800620C[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF800620C, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006210[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006210[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006210[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006210[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006210[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006210, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_wr_portn = 0x3ff + // .. .. ==> 0XF8006214[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_wr_portn = 0x0 + // .. .. ==> 0XF8006214[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_wr_portn = 0x0 + // .. .. ==> 0XF8006214[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_wr_portn = 0x0 + // .. .. ==> 0XF8006214[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_dis_rmw_portn = 0x1 + // .. .. ==> 0XF8006214[19:19] = 0x00000001U + // .. .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. .. + EMIT_MASKWRITE(0XF8006214, 0x000F03FFU ,0x000803FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006218[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006218[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006218[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006218[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006218[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006218, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF800621C[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF800621C[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF800621C[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF800621C[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF800621C[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF800621C, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006220[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006220[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006220[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006220[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006220[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006220, 0x000F03FFU ,0x000003FFU), + // .. .. reg_arb_pri_rd_portn = 0x3ff + // .. .. ==> 0XF8006224[9:0] = 0x000003FFU + // .. .. ==> MASK : 0x000003FFU VAL : 0x000003FFU + // .. .. reg_arb_disable_aging_rd_portn = 0x0 + // .. .. ==> 0XF8006224[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. reg_arb_disable_urgent_rd_portn = 0x0 + // .. .. ==> 0XF8006224[17:17] = 0x00000000U + // .. .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. .. reg_arb_dis_page_match_rd_portn = 0x0 + // .. .. ==> 0XF8006224[18:18] = 0x00000000U + // .. .. ==> MASK : 0x00040000U VAL : 0x00000000U + // .. .. reg_arb_set_hpr_rd_portn = 0x0 + // .. .. ==> 0XF8006224[19:19] = 0x00000000U + // .. .. ==> MASK : 0x00080000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006224, 0x000F03FFU ,0x000003FFU), + // .. .. reg_ddrc_lpddr2 = 0x0 + // .. .. ==> 0XF80062A8[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. reg_ddrc_per_bank_refresh = 0x0 + // .. .. ==> 0XF80062A8[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_derate_enable = 0x0 + // .. .. ==> 0XF80062A8[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. reg_ddrc_mr4_margin = 0x0 + // .. .. ==> 0XF80062A8[11:4] = 0x00000000U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062A8, 0x00000FF7U ,0x00000000U), + // .. .. reg_ddrc_mr4_read_interval = 0x0 + // .. .. ==> 0XF80062AC[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF80062AC, 0xFFFFFFFFU ,0x00000000U), + // .. .. reg_ddrc_min_stable_clock_x1 = 0x5 + // .. .. ==> 0XF80062B0[3:0] = 0x00000005U + // .. .. ==> MASK : 0x0000000FU VAL : 0x00000005U + // .. .. reg_ddrc_idle_after_reset_x32 = 0x12 + // .. .. ==> 0XF80062B0[11:4] = 0x00000012U + // .. .. ==> MASK : 0x00000FF0U VAL : 0x00000120U + // .. .. reg_ddrc_t_mrw = 0x5 + // .. .. ==> 0XF80062B0[21:12] = 0x00000005U + // .. .. ==> MASK : 0x003FF000U VAL : 0x00005000U + // .. .. + EMIT_MASKWRITE(0XF80062B0, 0x003FFFFFU ,0x00005125U), + // .. .. reg_ddrc_max_auto_init_x1024 = 0xa8 + // .. .. ==> 0XF80062B4[7:0] = 0x000000A8U + // .. .. ==> MASK : 0x000000FFU VAL : 0x000000A8U + // .. .. reg_ddrc_dev_zqinit_x32 = 0x12 + // .. .. ==> 0XF80062B4[17:8] = 0x00000012U + // .. .. ==> MASK : 0x0003FF00U VAL : 0x00001200U + // .. .. + EMIT_MASKWRITE(0XF80062B4, 0x0003FFFFU ,0x000012A8U), + // .. .. START: POLL ON DCI STATUS + // .. .. DONE = 1 + // .. .. ==> 0XF8000B74[13:13] = 0x00000001U + // .. .. ==> MASK : 0x00002000U VAL : 0x00002000U + // .. .. + EMIT_MASKPOLL(0XF8000B74, 0x00002000U), + // .. .. FINISH: POLL ON DCI STATUS + // .. .. START: UNLOCK DDR + // .. .. reg_ddrc_soft_rstb = 0x1 + // .. .. ==> 0XF8006000[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. reg_ddrc_powerdown_en = 0x0 + // .. .. ==> 0XF8006000[1:1] = 0x00000000U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. .. reg_ddrc_data_bus_width = 0x0 + // .. .. ==> 0XF8006000[3:2] = 0x00000000U + // .. .. ==> MASK : 0x0000000CU VAL : 0x00000000U + // .. .. reg_ddrc_burst8_refresh = 0x0 + // .. .. ==> 0XF8006000[6:4] = 0x00000000U + // .. .. ==> MASK : 0x00000070U VAL : 0x00000000U + // .. .. reg_ddrc_rdwr_idle_gap = 1 + // .. .. ==> 0XF8006000[13:7] = 0x00000001U + // .. .. ==> MASK : 0x00003F80U VAL : 0x00000080U + // .. .. reg_ddrc_dis_rd_bypass = 0x0 + // .. .. ==> 0XF8006000[14:14] = 0x00000000U + // .. .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_act_bypass = 0x0 + // .. .. ==> 0XF8006000[15:15] = 0x00000000U + // .. .. ==> MASK : 0x00008000U VAL : 0x00000000U + // .. .. reg_ddrc_dis_auto_refresh = 0x0 + // .. .. ==> 0XF8006000[16:16] = 0x00000000U + // .. .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8006000, 0x0001FFFFU ,0x00000081U), + // .. .. FINISH: UNLOCK DDR + // .. .. START: CHECK DDR STATUS + // .. .. ddrc_reg_operating_mode = 1 + // .. .. ==> 0XF8006054[2:0] = 0x00000001U + // .. .. ==> MASK : 0x00000007U VAL : 0x00000001U + // .. .. + EMIT_MASKPOLL(0XF8006054, 0x00000007U), + // .. .. FINISH: CHECK DDR STATUS + // .. FINISH: DDR INITIALIZATION + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_mio_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: OCM REMAPPING + // .. FINISH: OCM REMAPPING + // .. START: DDRIOB SETTINGS + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B40[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B40[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B40[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B40[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B40[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B40[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B40[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B40[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B40, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B44[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B44[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B44[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B44[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B44[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B44[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B44[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B44[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B44, 0x00000FFFU ,0x00000600U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B48[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B48[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B48[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B48[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B48[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B48[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B48[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B48[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000FFFU ,0x00000672U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B4C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x1 + // .. ==> 0XF8000B4C[2:1] = 0x00000001U + // .. ==> MASK : 0x00000006U VAL : 0x00000002U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B4C[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B4C[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B4C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B4C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B4C[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B4C[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000FFFU ,0x00000672U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B50[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B50[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B50[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B50[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B50[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B50[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B50[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B50[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000FFFU ,0x00000674U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B54[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x2 + // .. ==> 0XF8000B54[2:1] = 0x00000002U + // .. ==> MASK : 0x00000006U VAL : 0x00000004U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B54[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x1 + // .. ==> 0XF8000B54[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. DCR_TYPE = 0x3 + // .. ==> 0XF8000B54[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. IBUF_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0 + // .. ==> 0XF8000B54[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B54[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B54[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000FFFU ,0x00000674U), + // .. INP_POWER = 0x0 + // .. ==> 0XF8000B58[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. INP_TYPE = 0x0 + // .. ==> 0XF8000B58[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. DCI_UPDATE = 0x0 + // .. ==> 0XF8000B58[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. TERM_EN = 0x0 + // .. ==> 0XF8000B58[4:4] = 0x00000000U + // .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. DCR_TYPE = 0x0 + // .. ==> 0XF8000B58[6:5] = 0x00000000U + // .. ==> MASK : 0x00000060U VAL : 0x00000000U + // .. IBUF_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. TERM_DISABLE_MODE = 0x0 + // .. ==> 0XF8000B58[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. OUTPUT_EN = 0x3 + // .. ==> 0XF8000B58[10:9] = 0x00000003U + // .. ==> MASK : 0x00000600U VAL : 0x00000600U + // .. PULLUP_EN = 0x0 + // .. ==> 0XF8000B58[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B58, 0x00000FFFU ,0x00000600U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B5C[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B5C[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x3 + // .. ==> 0XF8000B5C[18:14] = 0x00000003U + // .. ==> MASK : 0x0007C000U VAL : 0x0000C000U + // .. SLEW_N = 0x3 + // .. ==> 0XF8000B5C[23:19] = 0x00000003U + // .. ==> MASK : 0x00F80000U VAL : 0x00180000U + // .. GTL = 0x0 + // .. ==> 0XF8000B5C[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B5C[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B5C, 0xFFFFFFFFU ,0x0018C068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B60[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B60[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B60[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B60[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B60[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B60[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B60, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B64[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B64[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B64[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B64[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B64[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B64[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B64, 0xFFFFFFFFU ,0x00F98068U), + // .. DRIVE_P = 0x68 + // .. ==> 0XF8000B68[6:0] = 0x00000068U + // .. ==> MASK : 0x0000007FU VAL : 0x00000068U + // .. DRIVE_N = 0x0 + // .. ==> 0XF8000B68[13:7] = 0x00000000U + // .. ==> MASK : 0x00003F80U VAL : 0x00000000U + // .. SLEW_P = 0x6 + // .. ==> 0XF8000B68[18:14] = 0x00000006U + // .. ==> MASK : 0x0007C000U VAL : 0x00018000U + // .. SLEW_N = 0x1f + // .. ==> 0XF8000B68[23:19] = 0x0000001FU + // .. ==> MASK : 0x00F80000U VAL : 0x00F80000U + // .. GTL = 0x0 + // .. ==> 0XF8000B68[26:24] = 0x00000000U + // .. ==> MASK : 0x07000000U VAL : 0x00000000U + // .. RTERM = 0x0 + // .. ==> 0XF8000B68[31:27] = 0x00000000U + // .. ==> MASK : 0xF8000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B68, 0xFFFFFFFFU ,0x00F98068U), + // .. VREF_INT_EN = 0x0 + // .. ==> 0XF8000B6C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. VREF_SEL = 0x0 + // .. ==> 0XF8000B6C[4:1] = 0x00000000U + // .. ==> MASK : 0x0000001EU VAL : 0x00000000U + // .. VREF_EXT_EN = 0x3 + // .. ==> 0XF8000B6C[6:5] = 0x00000003U + // .. ==> MASK : 0x00000060U VAL : 0x00000060U + // .. VREF_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[8:7] = 0x00000000U + // .. ==> MASK : 0x00000180U VAL : 0x00000000U + // .. REFIO_EN = 0x1 + // .. ==> 0XF8000B6C[9:9] = 0x00000001U + // .. ==> MASK : 0x00000200U VAL : 0x00000200U + // .. REFIO_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DRST_B_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. CKE_PULLUP_EN = 0x0 + // .. ==> 0XF8000B6C[14:14] = 0x00000000U + // .. ==> MASK : 0x00004000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000B6C, 0x000073FFU ,0x00000260U), + // .. .. START: ASSERT RESET + // .. .. RESET = 1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000021U), + // .. .. FINISH: ASSERT RESET + // .. .. START: DEASSERT RESET + // .. .. RESET = 0 + // .. .. ==> 0XF8000B70[0:0] = 0x00000000U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x00000021U ,0x00000020U), + // .. .. FINISH: DEASSERT RESET + // .. .. RESET = 0x1 + // .. .. ==> 0XF8000B70[0:0] = 0x00000001U + // .. .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. .. ENABLE = 0x1 + // .. .. ==> 0XF8000B70[1:1] = 0x00000001U + // .. .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. .. VRP_TRI = 0x0 + // .. .. ==> 0XF8000B70[2:2] = 0x00000000U + // .. .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. .. VRN_TRI = 0x0 + // .. .. ==> 0XF8000B70[3:3] = 0x00000000U + // .. .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. .. VRP_OUT = 0x0 + // .. .. ==> 0XF8000B70[4:4] = 0x00000000U + // .. .. ==> MASK : 0x00000010U VAL : 0x00000000U + // .. .. VRN_OUT = 0x1 + // .. .. ==> 0XF8000B70[5:5] = 0x00000001U + // .. .. ==> MASK : 0x00000020U VAL : 0x00000020U + // .. .. NREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[7:6] = 0x00000000U + // .. .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. .. NREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[10:8] = 0x00000000U + // .. .. ==> MASK : 0x00000700U VAL : 0x00000000U + // .. .. NREF_OPT4 = 0x1 + // .. .. ==> 0XF8000B70[13:11] = 0x00000001U + // .. .. ==> MASK : 0x00003800U VAL : 0x00000800U + // .. .. PREF_OPT1 = 0x0 + // .. .. ==> 0XF8000B70[16:14] = 0x00000000U + // .. .. ==> MASK : 0x0001C000U VAL : 0x00000000U + // .. .. PREF_OPT2 = 0x0 + // .. .. ==> 0XF8000B70[19:17] = 0x00000000U + // .. .. ==> MASK : 0x000E0000U VAL : 0x00000000U + // .. .. UPDATE_CONTROL = 0x0 + // .. .. ==> 0XF8000B70[20:20] = 0x00000000U + // .. .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. .. INIT_COMPLETE = 0x0 + // .. .. ==> 0XF8000B70[21:21] = 0x00000000U + // .. .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. .. TST_CLK = 0x0 + // .. .. ==> 0XF8000B70[22:22] = 0x00000000U + // .. .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. .. TST_HLN = 0x0 + // .. .. ==> 0XF8000B70[23:23] = 0x00000000U + // .. .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. .. TST_HLP = 0x0 + // .. .. ==> 0XF8000B70[24:24] = 0x00000000U + // .. .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. .. TST_RST = 0x0 + // .. .. ==> 0XF8000B70[25:25] = 0x00000000U + // .. .. ==> MASK : 0x02000000U VAL : 0x00000000U + // .. .. INT_DCI_EN = 0x0 + // .. .. ==> 0XF8000B70[26:26] = 0x00000000U + // .. .. ==> MASK : 0x04000000U VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8000B70, 0x07FFFFFFU ,0x00000823U), + // .. FINISH: DDRIOB SETTINGS + // .. START: MIO PROGRAMMING + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000700[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. Speed = 0 + // .. ==> 0XF8000700[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000700[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000700[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000700[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000700, 0x00003F01U ,0x00001201U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000704[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000704[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000704[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000704[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000704[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000704[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000704[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000704[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000704[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000704, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000708[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000708[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000708[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000708[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000708[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000708[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000708[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000708[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000708[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000708, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800070C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800070C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800070C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800070C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800070C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800070C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800070C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF800070C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800070C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800070C, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000710[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000710[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000710[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000710[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000710[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000710[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000710[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000710[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000710[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000710, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000714[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000714[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000714[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000714[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000714[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000714[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000714[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000714[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000714[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000714, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000718[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000718[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000718[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000718[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000718[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000718[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000718[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000718[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000718[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000718, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800071C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800071C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800071C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800071C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800071C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800071C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800071C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF800071C[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF800071C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000720[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000720[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000720[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000720[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000720[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000720[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000720[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 0 + // .. ==> 0XF8000720[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000720[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU ,0x00000200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000724[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000724[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000724[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000724[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000724[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000724[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000724[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000724[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000724[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000728[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000728[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000728[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000728[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000728[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000728[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000728[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000728[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000728[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800072C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800072C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800072C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800072C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800072C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800072C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800072C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800072C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800072C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000730[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000730[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000730[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000730[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000730[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000730[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000730[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000730[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000730[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000734[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000734[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000734[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000734[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000734[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000734[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000734[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000734[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000734[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000738[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000738[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF8000738[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000738[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF8000738[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF8000738[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000738[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000738[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000738[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800073C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800073C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF800073C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800073C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF800073C[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF800073C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800073C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800073C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800073C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000740[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000740[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000740[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000740[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000740[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000740[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000740[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000740[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000740[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000740, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000744[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000744[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000744[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000744[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000744[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000744[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000744[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000744[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000744[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000744, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000748[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000748[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000748[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000748[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000748[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000748[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000748[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000748[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000748[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000748, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800074C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF800074C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800074C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800074C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800074C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800074C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800074C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800074C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800074C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800074C, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000750[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000750[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000750[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000750[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000750[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000750[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000750[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000750[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000750[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000750, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000754[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 1 + // .. ==> 0XF8000754[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000754[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000754[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000754[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000754[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000754[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000754[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000754[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000754, 0x00003FFFU ,0x00001202U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000758[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000758[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000758[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000758[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000758[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000758[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000758[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000758[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000758[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000758, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800075C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800075C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800075C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800075C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800075C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800075C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800075C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800075C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800075C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800075C, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000760[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000760[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000760[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000760[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000760[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000760[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000760[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000760[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000760[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000760, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000764[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000764[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000764[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000764[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000764[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000764[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000764[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000764[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000764[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000764, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000768[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF8000768[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF8000768[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF8000768[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000768[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000768[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000768[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000768[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000768[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000768, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800076C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 1 + // .. ==> 0XF800076C[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. L1_SEL = 0 + // .. ==> 0XF800076C[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF800076C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800076C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800076C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800076C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800076C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800076C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800076C, 0x00003FFFU ,0x00001203U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000770[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000770[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000770[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000770[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000770[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000770[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000770[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000770[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000770[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000770, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000774[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000774[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000774[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000774[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000774[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000774[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000774[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000774[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000774[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000774, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000778[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000778[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000778[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000778[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000778[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000778[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000778[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000778[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000778[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000778, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF800077C[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF800077C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800077C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800077C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800077C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800077C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800077C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800077C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800077C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800077C, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000780[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000780[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000780[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000780[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000780[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000780[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000780[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000780[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000780[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000780, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000784[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000784[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000784[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000784[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000784[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000784[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000784[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000784[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000784[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000784, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000788[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000788[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000788[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000788[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000788[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000788[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000788[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000788[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000788[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000788, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800078C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800078C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800078C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800078C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800078C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800078C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800078C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800078C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800078C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800078C, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF8000790[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF8000790[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000790[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000790[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000790[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000790[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000790[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000790[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000790[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000790, 0x00003FFFU ,0x00001205U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000794[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000794[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000794[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000794[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000794[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000794[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000794[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000794[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000794[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000794, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF8000798[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF8000798[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF8000798[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF8000798[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF8000798[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF8000798[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF8000798[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF8000798[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF8000798[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000798, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF800079C[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF800079C[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 1 + // .. ==> 0XF800079C[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. L2_SEL = 0 + // .. ==> 0XF800079C[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF800079C[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF800079C[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF800079C[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF800079C[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF800079C[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF800079C, 0x00003FFFU ,0x00001204U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007A8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007A8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007A8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007A8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007A8[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007A8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007A8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007A8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007A8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007A8, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007AC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007AC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007AC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007AC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007AC[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007AC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007AC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007AC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007AC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007AC, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007B4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007B4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007B8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007B8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007B8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007B8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 2 + // .. ==> 0XF80007B8[7:5] = 0x00000002U + // .. ==> MASK : 0x000000E0U VAL : 0x00000040U + // .. Speed = 0 + // .. ==> 0XF80007B8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007B8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007B8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007B8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU ,0x00001240U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007BC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007BC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007BC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007BC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 2 + // .. ==> 0XF80007BC[7:5] = 0x00000002U + // .. ==> MASK : 0x000000E0U VAL : 0x00000040U + // .. Speed = 0 + // .. ==> 0XF80007BC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007BC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007BC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007BC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007BC, 0x00003FFFU ,0x00001240U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C0[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C0, 0x00003FFFU ,0x000012E0U), + // .. TRI_ENABLE = 1 + // .. ==> 0XF80007C4[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. L0_SEL = 0 + // .. ==> 0XF80007C4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 7 + // .. ==> 0XF80007C4[7:5] = 0x00000007U + // .. ==> MASK : 0x000000E0U VAL : 0x000000E0U + // .. Speed = 0 + // .. ==> 0XF80007C4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU ,0x000012E1U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007C8[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007C8[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007C8[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007C8[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007C8[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007C8[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007C8[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007C8[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007C8[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007CC[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007CC[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007CC[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007CC[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 0 + // .. ==> 0XF80007CC[7:5] = 0x00000000U + // .. ==> MASK : 0x000000E0U VAL : 0x00000000U + // .. Speed = 0 + // .. ==> 0XF80007CC[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007CC[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007CC[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007CC[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU ,0x00001200U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D0[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D0[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D0[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D0[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D0[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D0[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D0[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D0[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D0[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D0, 0x00003FFFU ,0x00001280U), + // .. TRI_ENABLE = 0 + // .. ==> 0XF80007D4[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. L0_SEL = 0 + // .. ==> 0XF80007D4[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. L1_SEL = 0 + // .. ==> 0XF80007D4[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. L2_SEL = 0 + // .. ==> 0XF80007D4[4:3] = 0x00000000U + // .. ==> MASK : 0x00000018U VAL : 0x00000000U + // .. L3_SEL = 4 + // .. ==> 0XF80007D4[7:5] = 0x00000004U + // .. ==> MASK : 0x000000E0U VAL : 0x00000080U + // .. Speed = 0 + // .. ==> 0XF80007D4[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. IO_Type = 1 + // .. ==> 0XF80007D4[11:9] = 0x00000001U + // .. ==> MASK : 0x00000E00U VAL : 0x00000200U + // .. PULLUP = 1 + // .. ==> 0XF80007D4[12:12] = 0x00000001U + // .. ==> MASK : 0x00001000U VAL : 0x00001000U + // .. DisableRcvr = 0 + // .. ==> 0XF80007D4[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF80007D4, 0x00003FFFU ,0x00001280U), + // .. SDIO0_CD_SEL = 0 + // .. ==> 0XF8000830[21:16] = 0x00000000U + // .. ==> MASK : 0x003F0000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000830, 0x003F0000U ,0x00000000U), + // .. FINISH: MIO PROGRAMMING + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_peripherals_init_data_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B48[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B48, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B4C[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B4C, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B50[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B50, 0x00000180U ,0x00000180U), + // .. IBUF_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[7:7] = 0x00000001U + // .. ==> MASK : 0x00000080U VAL : 0x00000080U + // .. TERM_DISABLE_MODE = 0x1 + // .. ==> 0XF8000B54[8:8] = 0x00000001U + // .. ==> MASK : 0x00000100U VAL : 0x00000100U + // .. + EMIT_MASKWRITE(0XF8000B54, 0x00000180U ,0x00000180U), + // .. FINISH: DDR TERM/IBUF_DISABLE_MODE SETTINGS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // .. START: SRAM/NOR SET OPMODE + // .. FINISH: SRAM/NOR SET OPMODE + // .. START: UART REGISTERS + // .. BDIV = 0x6 + // .. ==> 0XE0001034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0001034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0001018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0001000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0001000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0001000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0001000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0001000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0001000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0001000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0001000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0001000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0001000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0001004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0001004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0001004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0001004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0001004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0001004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0001004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0001004, 0x00000FFFU ,0x00000020U), + // .. BDIV = 0x6 + // .. ==> 0XE0000034[7:0] = 0x00000006U + // .. ==> MASK : 0x000000FFU VAL : 0x00000006U + // .. + EMIT_MASKWRITE(0XE0000034, 0x000000FFU ,0x00000006U), + // .. CD = 0x7c + // .. ==> 0XE0000018[15:0] = 0x0000007CU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU + // .. + EMIT_MASKWRITE(0XE0000018, 0x0000FFFFU ,0x0000007CU), + // .. STPBRK = 0x0 + // .. ==> 0XE0000000[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. STTBRK = 0x0 + // .. ==> 0XE0000000[7:7] = 0x00000000U + // .. ==> MASK : 0x00000080U VAL : 0x00000000U + // .. RSTTO = 0x0 + // .. ==> 0XE0000000[6:6] = 0x00000000U + // .. ==> MASK : 0x00000040U VAL : 0x00000000U + // .. TXDIS = 0x0 + // .. ==> 0XE0000000[5:5] = 0x00000000U + // .. ==> MASK : 0x00000020U VAL : 0x00000000U + // .. TXEN = 0x1 + // .. ==> 0XE0000000[4:4] = 0x00000001U + // .. ==> MASK : 0x00000010U VAL : 0x00000010U + // .. RXDIS = 0x0 + // .. ==> 0XE0000000[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. RXEN = 0x1 + // .. ==> 0XE0000000[2:2] = 0x00000001U + // .. ==> MASK : 0x00000004U VAL : 0x00000004U + // .. TXRES = 0x1 + // .. ==> 0XE0000000[1:1] = 0x00000001U + // .. ==> MASK : 0x00000002U VAL : 0x00000002U + // .. RXRES = 0x1 + // .. ==> 0XE0000000[0:0] = 0x00000001U + // .. ==> MASK : 0x00000001U VAL : 0x00000001U + // .. + EMIT_MASKWRITE(0XE0000000, 0x000001FFU ,0x00000017U), + // .. IRMODE = 0x0 + // .. ==> 0XE0000004[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. UCLKEN = 0x0 + // .. ==> 0XE0000004[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. CHMODE = 0x0 + // .. ==> 0XE0000004[9:8] = 0x00000000U + // .. ==> MASK : 0x00000300U VAL : 0x00000000U + // .. NBSTOP = 0x0 + // .. ==> 0XE0000004[7:6] = 0x00000000U + // .. ==> MASK : 0x000000C0U VAL : 0x00000000U + // .. PAR = 0x4 + // .. ==> 0XE0000004[5:3] = 0x00000004U + // .. ==> MASK : 0x00000038U VAL : 0x00000020U + // .. CHRL = 0x0 + // .. ==> 0XE0000004[2:1] = 0x00000000U + // .. ==> MASK : 0x00000006U VAL : 0x00000000U + // .. CLKS = 0x0 + // .. ==> 0XE0000004[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XE0000004, 0x00000FFFU ,0x00000020U), + // .. FINISH: UART REGISTERS + // .. START: TPIU WIDTH IN CASE OF EMIO + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0XC5ACCE55 + // .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. .. START: TRACE CURRENT PORT SIZE + // .. .. a = 2 + // .. .. ==> 0XF8803004[31:0] = 0x00000002U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU ,0x00000002U), + // .. .. FINISH: TRACE CURRENT PORT SIZE + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0X0 + // .. .. ==> 0XF8803FB0[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0x00000000U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. FINISH: TPIU WIDTH IN CASE OF EMIO + // .. START: QSPI REGISTERS + // .. Holdb_dr = 1 + // .. ==> 0XE000D000[19:19] = 0x00000001U + // .. ==> MASK : 0x00080000U VAL : 0x00080000U + // .. + EMIT_MASKWRITE(0XE000D000, 0x00080000U ,0x00080000U), + // .. FINISH: QSPI REGISTERS + // .. START: PL POWER ON RESET REGISTERS + // .. PCFG_POR_CNT_4K = 0 + // .. ==> 0XF8007000[29:29] = 0x00000000U + // .. ==> MASK : 0x20000000U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8007000, 0x20000000U ,0x00000000U), + // .. FINISH: PL POWER ON RESET REGISTERS + // .. START: SMC TIMING CALCULATION REGISTER UPDATE + // .. .. START: NAND SET CYCLE + // .. .. FINISH: NAND SET CYCLE + // .. .. START: OPMODE + // .. .. FINISH: OPMODE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: SRAM/NOR CS0 SET CYCLE + // .. .. FINISH: SRAM/NOR CS0 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS0 BASE ADDRESS + // .. .. FINISH: NOR CS0 BASE ADDRESS + // .. .. START: SRAM/NOR CS1 SET CYCLE + // .. .. FINISH: SRAM/NOR CS1 SET CYCLE + // .. .. START: DIRECT COMMAND + // .. .. FINISH: DIRECT COMMAND + // .. .. START: NOR CS1 BASE ADDRESS + // .. .. FINISH: NOR CS1 BASE ADDRESS + // .. .. START: USB RESET + // .. .. .. START: USB0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0xa00 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x200 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000200U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000200U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0200U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0xa00 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xfdff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000FDFFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xFDFF0000U + // .. .. .. .. DATA_0_LSW = 0x200 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000200U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000200U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xFDFF0200U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB0 RESET + // .. .. .. START: USB1 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: USB1 RESET + // .. .. FINISH: USB RESET + // .. .. START: ENET RESET + // .. .. .. START: ENET0 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. DIRECTION_0 = 0xa00 + // .. .. .. .. ==> 0XE000A204[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A204, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x800 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000800U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000800U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0800U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. OP_ENABLE_0 = 0xa00 + // .. .. .. .. ==> 0XE000A208[31:0] = 0x00000A00U + // .. .. .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000A00U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A208, 0xFFFFFFFFU ,0x00000A00U), + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x0 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000000U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0000U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. MASK_0_LSW = 0xf7ff + // .. .. .. .. ==> 0XE000A000[31:16] = 0x0000F7FFU + // .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xF7FF0000U + // .. .. .. .. DATA_0_LSW = 0x800 + // .. .. .. .. ==> 0XE000A000[15:0] = 0x00000800U + // .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000800U + // .. .. .. .. + EMIT_MASKWRITE(0XE000A000, 0xFFFFFFFFU ,0xF7FF0800U), + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: ENET0 RESET + // .. .. .. START: ENET1 RESET + // .. .. .. .. START: DIR MODE BANK 0 + // .. .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. .. START: DIR MODE BANK 1 + // .. .. .. .. FINISH: DIR MODE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. .. .. START: OUTPUT ENABLE BANK 1 + // .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: ENET1 RESET + // .. .. FINISH: ENET RESET + // .. .. START: I2C RESET + // .. .. .. START: I2C0 RESET + // .. .. .. .. START: DIR MODE GPIO BANK0 + // .. .. .. .. FINISH: DIR MODE GPIO BANK0 + // .. .. .. .. START: DIR MODE GPIO BANK1 + // .. .. .. .. FINISH: DIR MODE GPIO BANK1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: I2C0 RESET + // .. .. .. START: I2C1 RESET + // .. .. .. .. START: DIR MODE GPIO BANK0 + // .. .. .. .. FINISH: DIR MODE GPIO BANK0 + // .. .. .. .. START: DIR MODE GPIO BANK1 + // .. .. .. .. FINISH: DIR MODE GPIO BANK1 + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: OUTPUT ENABLE + // .. .. .. .. FINISH: OUTPUT ENABLE + // .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] + // .. .. .. .. START: ADD 1 MS DELAY + // .. .. .. .. + EMIT_MASKDELAY(0XF8F00200, 1), + // .. .. .. .. FINISH: ADD 1 MS DELAY + // .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] + // .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] + // .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] + // .. .. .. FINISH: I2C1 RESET + // .. .. FINISH: I2C RESET + // .. .. START: NOR CHIP SELECT + // .. .. .. START: DIR MODE BANK 0 + // .. .. .. FINISH: DIR MODE BANK 0 + // .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] + // .. .. .. START: OUTPUT ENABLE BANK 0 + // .. .. .. FINISH: OUTPUT ENABLE BANK 0 + // .. .. FINISH: NOR CHIP SELECT + // .. FINISH: SMC TIMING CALCULATION REGISTER UPDATE + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_post_config_1_0[] = { + // START: top + // .. START: SLCR SETTINGS + // .. UNLOCK_KEY = 0XDF0D + // .. ==> 0XF8000008[15:0] = 0x0000DF0DU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000DF0DU + // .. + EMIT_MASKWRITE(0XF8000008, 0x0000FFFFU ,0x0000DF0DU), + // .. FINISH: SLCR SETTINGS + // .. START: ENABLING LEVEL SHIFTER + // .. USER_INP_ICT_EN_0 = 3 + // .. ==> 0XF8000900[1:0] = 0x00000003U + // .. ==> MASK : 0x00000003U VAL : 0x00000003U + // .. USER_INP_ICT_EN_1 = 3 + // .. ==> 0XF8000900[3:2] = 0x00000003U + // .. ==> MASK : 0x0000000CU VAL : 0x0000000CU + // .. + EMIT_MASKWRITE(0XF8000900, 0x0000000FU ,0x0000000FU), + // .. FINISH: ENABLING LEVEL SHIFTER + // .. START: TPIU WIDTH IN CASE OF EMIO + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0XC5ACCE55 + // .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. .. START: TRACE CURRENT PORT SIZE + // .. .. a = 2 + // .. .. ==> 0XF8803004[31:0] = 0x00000002U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U + // .. .. + EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU ,0x00000002U), + // .. .. FINISH: TRACE CURRENT PORT SIZE + // .. .. START: TRACE LOCK ACCESS REGISTER + // .. .. a = 0X0 + // .. .. ==> 0XF8803FB0[31:0] = 0x00000000U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U + // .. .. + EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU ,0x00000000U), + // .. .. FINISH: TRACE LOCK ACCESS REGISTER + // .. FINISH: TPIU WIDTH IN CASE OF EMIO + // .. START: FPGA RESETS TO 0 + // .. reserved_3 = 0 + // .. ==> 0XF8000240[31:25] = 0x00000000U + // .. ==> MASK : 0xFE000000U VAL : 0x00000000U + // .. FPGA_ACP_RST = 0 + // .. ==> 0XF8000240[24:24] = 0x00000000U + // .. ==> MASK : 0x01000000U VAL : 0x00000000U + // .. FPGA_AXDS3_RST = 0 + // .. ==> 0XF8000240[23:23] = 0x00000000U + // .. ==> MASK : 0x00800000U VAL : 0x00000000U + // .. FPGA_AXDS2_RST = 0 + // .. ==> 0XF8000240[22:22] = 0x00000000U + // .. ==> MASK : 0x00400000U VAL : 0x00000000U + // .. FPGA_AXDS1_RST = 0 + // .. ==> 0XF8000240[21:21] = 0x00000000U + // .. ==> MASK : 0x00200000U VAL : 0x00000000U + // .. FPGA_AXDS0_RST = 0 + // .. ==> 0XF8000240[20:20] = 0x00000000U + // .. ==> MASK : 0x00100000U VAL : 0x00000000U + // .. reserved_2 = 0 + // .. ==> 0XF8000240[19:18] = 0x00000000U + // .. ==> MASK : 0x000C0000U VAL : 0x00000000U + // .. FSSW1_FPGA_RST = 0 + // .. ==> 0XF8000240[17:17] = 0x00000000U + // .. ==> MASK : 0x00020000U VAL : 0x00000000U + // .. FSSW0_FPGA_RST = 0 + // .. ==> 0XF8000240[16:16] = 0x00000000U + // .. ==> MASK : 0x00010000U VAL : 0x00000000U + // .. reserved_1 = 0 + // .. ==> 0XF8000240[15:14] = 0x00000000U + // .. ==> MASK : 0x0000C000U VAL : 0x00000000U + // .. FPGA_FMSW1_RST = 0 + // .. ==> 0XF8000240[13:13] = 0x00000000U + // .. ==> MASK : 0x00002000U VAL : 0x00000000U + // .. FPGA_FMSW0_RST = 0 + // .. ==> 0XF8000240[12:12] = 0x00000000U + // .. ==> MASK : 0x00001000U VAL : 0x00000000U + // .. FPGA_DMA3_RST = 0 + // .. ==> 0XF8000240[11:11] = 0x00000000U + // .. ==> MASK : 0x00000800U VAL : 0x00000000U + // .. FPGA_DMA2_RST = 0 + // .. ==> 0XF8000240[10:10] = 0x00000000U + // .. ==> MASK : 0x00000400U VAL : 0x00000000U + // .. FPGA_DMA1_RST = 0 + // .. ==> 0XF8000240[9:9] = 0x00000000U + // .. ==> MASK : 0x00000200U VAL : 0x00000000U + // .. FPGA_DMA0_RST = 0 + // .. ==> 0XF8000240[8:8] = 0x00000000U + // .. ==> MASK : 0x00000100U VAL : 0x00000000U + // .. reserved = 0 + // .. ==> 0XF8000240[7:4] = 0x00000000U + // .. ==> MASK : 0x000000F0U VAL : 0x00000000U + // .. FPGA3_OUT_RST = 0 + // .. ==> 0XF8000240[3:3] = 0x00000000U + // .. ==> MASK : 0x00000008U VAL : 0x00000000U + // .. FPGA2_OUT_RST = 0 + // .. ==> 0XF8000240[2:2] = 0x00000000U + // .. ==> MASK : 0x00000004U VAL : 0x00000000U + // .. FPGA1_OUT_RST = 0 + // .. ==> 0XF8000240[1:1] = 0x00000000U + // .. ==> MASK : 0x00000002U VAL : 0x00000000U + // .. FPGA0_OUT_RST = 0 + // .. ==> 0XF8000240[0:0] = 0x00000000U + // .. ==> MASK : 0x00000001U VAL : 0x00000000U + // .. + EMIT_MASKWRITE(0XF8000240, 0xFFFFFFFFU ,0x00000000U), + // .. FINISH: FPGA RESETS TO 0 + // .. START: AFI REGISTERS + // .. .. START: AFI0 REGISTERS + // .. .. FINISH: AFI0 REGISTERS + // .. .. START: AFI1 REGISTERS + // .. .. FINISH: AFI1 REGISTERS + // .. .. START: AFI2 REGISTERS + // .. .. FINISH: AFI2 REGISTERS + // .. .. START: AFI3 REGISTERS + // .. .. FINISH: AFI3 REGISTERS + // .. FINISH: AFI REGISTERS + // .. START: LOCK IT BACK + // .. LOCK_KEY = 0X767B + // .. ==> 0XF8000004[15:0] = 0x0000767BU + // .. ==> MASK : 0x0000FFFFU VAL : 0x0000767BU + // .. + EMIT_MASKWRITE(0XF8000004, 0x0000FFFFU ,0x0000767BU), + // .. FINISH: LOCK IT BACK + // FINISH: top + // + EMIT_EXIT(), + + // +}; + +unsigned long ps7_debug_1_0[] = { + // START: top + // .. START: CROSS TRIGGER CONFIGURATIONS + // .. .. START: UNLOCKING CTI REGISTERS + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8898FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8898FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8899FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8899FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. KEY = 0XC5ACCE55 + // .. .. ==> 0XF8809FB0[31:0] = 0xC5ACCE55U + // .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U + // .. .. + EMIT_MASKWRITE(0XF8809FB0, 0xFFFFFFFFU ,0xC5ACCE55U), + // .. .. FINISH: UNLOCKING CTI REGISTERS + // .. .. START: ENABLING CTI MODULES AND CHANNELS + // .. .. FINISH: ENABLING CTI MODULES AND CHANNELS + // .. .. START: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. .. FINISH: MAPPING CPU0, CPU1 AND FTM EVENTS TO CTM CHANNELS + // .. FINISH: CROSS TRIGGER CONFIGURATIONS + // FINISH: top + // + EMIT_EXIT(), + + // +}; + + +#include "xil_io.h" +#define PS7_MASK_POLL_TIME 100000000 + +char* +getPS7MessageInfo(unsigned key) { + + char* err_msg = ""; + switch (key) { + case PS7_INIT_SUCCESS: err_msg = "PS7 initialization successful"; break; + case PS7_INIT_CORRUPT: err_msg = "PS7 init Data Corrupted"; break; + case PS7_INIT_TIMEOUT: err_msg = "PS7 init mask poll timeout"; break; + case PS7_POLL_FAILED_DDR_INIT: err_msg = "Mask Poll failed for DDR Init"; break; + case PS7_POLL_FAILED_DMA: err_msg = "Mask Poll failed for PLL Init"; break; + case PS7_POLL_FAILED_PLL: err_msg = "Mask Poll failed for DMA done bit"; break; + default: err_msg = "Undefined error status"; break; + } + + return err_msg; +} + +unsigned long +ps7GetSiliconVersion () { + // Read PS version from MCTRL register [31:28] + unsigned long mask = 0xF0000000; + unsigned long *addr = (unsigned long*) 0XF8007080; + unsigned long ps_version = (*addr & mask) >> 28; + return ps_version; +} + +void mask_write (unsigned long add , unsigned long mask, unsigned long val ) { + unsigned long *addr = (unsigned long*) add; + *addr = ( val & mask ) | ( *addr & ~mask); + //xil_printf("MaskWrite : 0x%x--> 0x%x \n \r" ,add, *addr); +} + + +int mask_poll(unsigned long add , unsigned long mask ) { + volatile unsigned long *addr = (volatile unsigned long*) add; + int i = 0; + while (!(*addr & mask)) { + if (i == PS7_MASK_POLL_TIME) { + return -1; + } + i++; + } + return 1; + //xil_printf("MaskPoll : 0x%x --> 0x%x \n \r" , add, *addr); +} + +unsigned long mask_read(unsigned long add , unsigned long mask ) { + unsigned long *addr = (unsigned long*) add; + unsigned long val = (*addr & mask); + //xil_printf("MaskRead : 0x%x --> 0x%x \n \r" , add, val); + return val; +} + + + +int +ps7_config(unsigned long * ps7_config_init) +{ + unsigned long *ptr = ps7_config_init; + + unsigned long opcode; // current instruction .. + unsigned long args[16]; // no opcode has so many args ... + int numargs; // number of arguments of this instruction + int j; // general purpose index + + volatile unsigned long *addr; // some variable to make code readable + unsigned long val,mask; // some variable to make code readable + + int finish = -1 ; // loop while this is negative ! + int i = 0; // Timeout variable + + while( finish < 0 ) { + numargs = ptr[0] & 0xF; + opcode = ptr[0] >> 4; + + for( j = 0 ; j < numargs ; j ++ ) + args[j] = ptr[j+1]; + ptr += numargs + 1; + + + switch ( opcode ) { + + case OPCODE_EXIT: + finish = PS7_INIT_SUCCESS; + break; + + case OPCODE_CLEAR: + addr = (unsigned long*) args[0]; + *addr = 0; + break; + + case OPCODE_WRITE: + addr = (unsigned long*) args[0]; + val = args[1]; + *addr = val; + break; + + case OPCODE_MASKWRITE: + addr = (unsigned long*) args[0]; + mask = args[1]; + val = args[2]; + *addr = ( val & mask ) | ( *addr & ~mask); + break; + + case OPCODE_MASKPOLL: + addr = (unsigned long*) args[0]; + mask = args[1]; + i = 0; + while (!(*addr & mask)) { + if (i == PS7_MASK_POLL_TIME) { + finish = PS7_INIT_TIMEOUT; + break; + } + i++; + } + break; + case OPCODE_MASKDELAY: + addr = (unsigned long*) args[0]; + mask = args[1]; + int delay = get_number_of_cycles_for_delay(mask); + perf_reset_and_start_timer(); + while ((*addr < delay)) { + } + break; + default: + finish = PS7_INIT_CORRUPT; + break; + } + } + return finish; +} + +unsigned long *ps7_mio_init_data = ps7_mio_init_data_3_0; +unsigned long *ps7_pll_init_data = ps7_pll_init_data_3_0; +unsigned long *ps7_clock_init_data = ps7_clock_init_data_3_0; +unsigned long *ps7_ddr_init_data = ps7_ddr_init_data_3_0; +unsigned long *ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + +int +ps7_post_config() +{ + // Get the PS_VERSION on run time + unsigned long si_ver = ps7GetSiliconVersion (); + int ret = -1; + if (si_ver == PCW_SILICON_VERSION_1) { + ret = ps7_config (ps7_post_config_1_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else if (si_ver == PCW_SILICON_VERSION_2) { + ret = ps7_config (ps7_post_config_2_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else { + ret = ps7_config (ps7_post_config_3_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } + return PS7_INIT_SUCCESS; +} + +int +ps7_debug() +{ + // Get the PS_VERSION on run time + unsigned long si_ver = ps7GetSiliconVersion (); + int ret = -1; + if (si_ver == PCW_SILICON_VERSION_1) { + ret = ps7_config (ps7_debug_1_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else if (si_ver == PCW_SILICON_VERSION_2) { + ret = ps7_config (ps7_debug_2_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } else { + ret = ps7_config (ps7_debug_3_0); + if (ret != PS7_INIT_SUCCESS) return ret; + } + return PS7_INIT_SUCCESS; +} + +int +ps7_init() +{ + // Get the PS_VERSION on run time + unsigned long si_ver = ps7GetSiliconVersion (); + int ret; + //int pcw_ver = 0; + + if (si_ver == PCW_SILICON_VERSION_1) { + ps7_mio_init_data = ps7_mio_init_data_1_0; + ps7_pll_init_data = ps7_pll_init_data_1_0; + ps7_clock_init_data = ps7_clock_init_data_1_0; + ps7_ddr_init_data = ps7_ddr_init_data_1_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_1_0; + //pcw_ver = 1; + + } else if (si_ver == PCW_SILICON_VERSION_2) { + ps7_mio_init_data = ps7_mio_init_data_2_0; + ps7_pll_init_data = ps7_pll_init_data_2_0; + ps7_clock_init_data = ps7_clock_init_data_2_0; + ps7_ddr_init_data = ps7_ddr_init_data_2_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_2_0; + //pcw_ver = 2; + + } else { + ps7_mio_init_data = ps7_mio_init_data_3_0; + ps7_pll_init_data = ps7_pll_init_data_3_0; + ps7_clock_init_data = ps7_clock_init_data_3_0; + ps7_ddr_init_data = ps7_ddr_init_data_3_0; + ps7_peripherals_init_data = ps7_peripherals_init_data_3_0; + //pcw_ver = 3; + } + + // MIO init + ret = ps7_config (ps7_mio_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // PLL init + ret = ps7_config (ps7_pll_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // Clock init + ret = ps7_config (ps7_clock_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + // DDR init + ret = ps7_config (ps7_ddr_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + + + + // Peripherals init + ret = ps7_config (ps7_peripherals_init_data); + if (ret != PS7_INIT_SUCCESS) return ret; + //xil_printf ("\n PCW Silicon Version : %d.0", pcw_ver); + return PS7_INIT_SUCCESS; +} + + + + +/* For delay calculation using global timer */ + +/* start timer */ + void perf_start_clock(void) +{ + *(volatile unsigned int*)SCU_GLOBAL_TIMER_CONTROL = ((1 << 0) | // Timer Enable + (1 << 3) | // Auto-increment + (0 << 8) // Pre-scale + ); +} + +/* stop timer and reset timer count regs */ + void perf_reset_clock(void) +{ + perf_disable_clock(); + *(volatile unsigned int*)SCU_GLOBAL_TIMER_COUNT_L32 = 0; + *(volatile unsigned int*)SCU_GLOBAL_TIMER_COUNT_U32 = 0; +} + +/* Compute mask for given delay in miliseconds*/ +int get_number_of_cycles_for_delay(unsigned int delay) +{ + // GTC is always clocked at 1/2 of the CPU frequency (CPU_3x2x) + return (APU_FREQ*delay/(2*1000)); + +} + +/* stop timer */ + void perf_disable_clock(void) +{ + *(volatile unsigned int*)SCU_GLOBAL_TIMER_CONTROL = 0; +} + +void perf_reset_and_start_timer() +{ + perf_reset_clock(); + perf_start_clock(); +} + + + + diff --git a/board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h b/board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h new file mode 100644 index 0000000..9a9c694 --- /dev/null +++ b/board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h @@ -0,0 +1,130 @@ + +/****************************************************************************** +* +* (c) Copyright 2010-2014 Xilinx, Inc. All rights reserved. +* +* This program is free software; you can redistribute it and/or modify +* it under the terms of the GNU General Public License as published by +* the Free Software Foundation; either version 2 of the License, or +* (at your option) any later version. +* +* This program is distributed in the hope that it will be useful, +* but WITHOUT ANY WARRANTY; without even the implied warranty of +* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +* GNU General Public License for more details. +* +* You should have received a copy of the GNU General Public License along +* with this program; if not, see http://www.gnu.org/licenses/ +* +* +*******************************************************************************/ +/****************************************************************************/ +/** +* +* @file ps7_init.h +* +* This file can be included in FSBL code +* to get prototype of ps7_init() function +* and error codes +* +*****************************************************************************/ + +#ifdef __cplusplus +extern "C" { +#endif + + +//typedef unsigned int u32; + + +/** do we need to make this name more unique ? **/ +//extern u32 ps7_init_data[]; +extern unsigned long * ps7_ddr_init_data; +extern unsigned long * ps7_mio_init_data; +extern unsigned long * ps7_pll_init_data; +extern unsigned long * ps7_clock_init_data; +extern unsigned long * ps7_peripherals_init_data; + + + +#define OPCODE_EXIT 0U +#define OPCODE_CLEAR 1U +#define OPCODE_WRITE 2U +#define OPCODE_MASKWRITE 3U +#define OPCODE_MASKPOLL 4U +#define OPCODE_MASKDELAY 5U +#define NEW_PS7_ERR_CODE 1 + +/* Encode number of arguments in last nibble */ +#define EMIT_EXIT() ( (OPCODE_EXIT << 4 ) | 0 ) +#define EMIT_CLEAR(addr) ( (OPCODE_CLEAR << 4 ) | 1 ) , addr +#define EMIT_WRITE(addr,val) ( (OPCODE_WRITE << 4 ) | 2 ) , addr, val +#define EMIT_MASKWRITE(addr,mask,val) ( (OPCODE_MASKWRITE << 4 ) | 3 ) , addr, mask, val +#define EMIT_MASKPOLL(addr,mask) ( (OPCODE_MASKPOLL << 4 ) | 2 ) , addr, mask +#define EMIT_MASKDELAY(addr,mask) ( (OPCODE_MASKDELAY << 4 ) | 2 ) , addr, mask + +/* Returns codes of PS7_Init */ +#define PS7_INIT_SUCCESS (0) // 0 is success in good old C +#define PS7_INIT_CORRUPT (1) // 1 the data is corrupted, and slcr reg are in corrupted state now +#define PS7_INIT_TIMEOUT (2) // 2 when a poll operation timed out +#define PS7_POLL_FAILED_DDR_INIT (3) // 3 when a poll operation timed out for ddr init +#define PS7_POLL_FAILED_DMA (4) // 4 when a poll operation timed out for dma done bit +#define PS7_POLL_FAILED_PLL (5) // 5 when a poll operation timed out for pll sequence init + + +/* Silicon Versions */ +#define PCW_SILICON_VERSION_1 0 +#define PCW_SILICON_VERSION_2 1 +#define PCW_SILICON_VERSION_3 2 + +/* This flag to be used by FSBL to check whether ps7_post_config() proc exixts */ +#define PS7_POST_CONFIG + +/* Freq of all peripherals */ + +#define APU_FREQ 666666687 +#define DDR_FREQ 533333374 +#define DCI_FREQ 10158731 +#define QSPI_FREQ 10000000 +#define SMC_FREQ 10000000 +#define ENET0_FREQ 125000000 +#define ENET1_FREQ 10000000 +#define USB0_FREQ 60000000 +#define USB1_FREQ 60000000 +#define SDIO_FREQ 125000000 +#define UART_FREQ 100000000 +#define SPI_FREQ 166666672 +#define I2C_FREQ 111111115 +#define WDT_FREQ 111111115 +#define TTC_FREQ 50000000 +#define CAN_FREQ 10000000 +#define PCAP_FREQ 187500000 +#define TPIU_FREQ 200000000 +#define FPGA0_FREQ 50000000 +#define FPGA1_FREQ 100000000 +#define FPGA2_FREQ 125000000 +#define FPGA3_FREQ 150000000 + + +/* For delay calculation using global registers*/ +#define SCU_GLOBAL_TIMER_COUNT_L32 0xF8F00200 +#define SCU_GLOBAL_TIMER_COUNT_U32 0xF8F00204 +#define SCU_GLOBAL_TIMER_CONTROL 0xF8F00208 +#define SCU_GLOBAL_TIMER_AUTO_INC 0xF8F00218 + +int ps7_config( unsigned long*); +int ps7_init(); +int ps7_post_config(); +int ps7_debug(); +char* getPS7MessageInfo(unsigned key); + +void perf_start_clock(void); +void perf_disable_clock(void); +void perf_reset_clock(void); +void perf_reset_and_start_timer(); +int get_number_of_cycles_for_delay(unsigned int delay); +#ifdef __cplusplus +} +#endif + + diff --git a/configs/zynq_e3xx_defconfig b/configs/zynq_e3xx_defconfig new file mode 100644 index 0000000..213c34c --- /dev/null +++ b/configs/zynq_e3xx_defconfig @@ -0,0 +1,12 @@ +CONFIG_ARM=y +CONFIG_ARCH_ZYNQ=y +CONFIG_TARGET_ZYNQ_E3XX=y +CONFIG_DEFAULT_DEVICE_TREE="zynq-e3xx" +# CONFIG_SYS_MALLOC_F is not set +CONFIG_SPL=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_FIT_SIGNATURE=y +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_SETEXPR is not set diff --git a/include/configs/zynq_e3xx.h b/include/configs/zynq_e3xx.h new file mode 100644 index 0000000..feb1739 --- /dev/null +++ b/include/configs/zynq_e3xx.h @@ -0,0 +1,29 @@ +/* + * (C) Copyright 2015 National Instruments Corp. + * + * Configuration settings for the NI Ettus Research USRP E3XX boards + * See zynq-common.h for Zynq common configs + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_ZYNQ_E3XX_H +#define __CONFIG_ZYNQ_E3XX_H + +#define CONFIG_SYS_SDRAM_SIZE (1024 * 1024 * 1024) + +#define CONFIG_ZYNQ_SERIAL_UART0 +#define CONFIG_ZYNQ_GEM0 +#define CONFIG_ZYNQ_GEM_PHY_ADDR0 0 + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_ZYNQ_SDHCI0 +#define CONFIG_ZYNQ_USB +#define CONFIG_ZYNQ_I2C0 +#define CONFIG_ZYNQ_EEPROM +#define CONFIG_ZYNQ_BOOT_FREEBSD + +#include <configs/zynq-common.h> + +#endif /* __CONFIG_ZYNQ_E3XX_H */
On Thu, Sep 3, 2015 at 11:44 AM, Moritz Fischer moritz.fischer@ettus.com wrote:
Signed-off-by: Moritz Fischer moritz.fischer@ettus.com
arch/arm/dts/Makefile | 3 +- arch/arm/dts/zynq-e3xx.dts | 35 + arch/arm/mach-zynq/Kconfig | 4 + board/xilinx/zynq/Makefile | 2 + board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c | 13446 ++++++++++++++++++++ board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h | 130 +
Can we consolidate this with other ps7_init_gpl.[ch] files using smaller diffs rather than commit the generated files verbatim?
Regards, Peter
configs/zynq_e3xx_defconfig | 12 + include/configs/zynq_e3xx.h | 29 + 8 files changed, 13660 insertions(+), 1 deletion(-)
Hi Moritz,
arch/arm/dts/Makefile | 3 +- arch/arm/dts/zynq-e3xx.dts | 35 + arch/arm/mach-zynq/Kconfig | 4 + board/xilinx/zynq/Makefile | 2 + board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.c | 13446 ++++++++++++++++++++ board/xilinx/zynq/e3xx_hw_platform/ps7_init_gpl.h | 130 + configs/zynq_e3xx_defconfig | 12 + include/configs/zynq_e3xx.h | 29 + 8 files changed, 13660 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c97f39d..bb5cb34 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -43,7 +43,8 @@ dtb-$(CONFIG_ARCH_UNIPHIER) += \ uniphier-ph1-pro4-ref.dtb \ uniphier-ph1-sld3-ref.dtb \ uniphier-ph1-sld8-ref.dtb -dtb-$(CONFIG_ARCH_ZYNQ) += zynq-zc702.dtb \ +dtb-$(CONFIG_ARCH_ZYNQ) += zynq-e3xx.dtb \
- zynq-zc702.dtb \
Just a nit, but should we make this +dtb-$(CONFIG_ARCH_ZYNQ) += \ + zynq-e3xx.dtb \ + zynq-zc702.dtb \ ...
Then, when more boards are added we have just simple additions of lines and get rid of the removal in the diffs.
Sören
On Thursday, September 03, 2015 at 08:44:00 PM, Moritz Fischer wrote:
Hi all,
Hi!
this patch adds basic support for NI Ettus Research E3XX series boards. I tagged this RFC because I'm not sure if the boards/xilinx/zynq subdirectory is the correct place for this, as I'll have some follow up patches that read the devices EEPROM for ethernet address etc.
It's not, it should be board/ettus/e3xx/ .
Would putting it under boards/ni/zynq be the correct way of integrating it? While technically a Zynq device there are a lot of custom modifications, that I wouldn't like to force into board/xilinx/zynq/board.c in my follow up patches. However duplicating the entire board.c doesn't seem like a good idea neither.
Any suggestions? For future reference do you want me to split out dts etc in a separate patch?
It's always boards/VENDOR/BOARD/ .
Best regards, Marek Vasut
Hi all,
Hi!
Oh btw, I'm not gonna review that patch you send, I ran checkpatch on it and these are the results:
./scripts/checkpatch.pl /tmp/[RFC]\ zynq_Add\ support\ for\ E3xx\ board..mbox [...] total: 13937 errors, 13285 warnings, 14 checks, 13691 lines checked
NOTE: whitespace errors detected, you may wish to use scripts/cleanpatch or scripts/cleanfile
NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE
/tmp/[RFC] zynq_Add support for E3xx board..mbox has style problems, please review.
If any of these errors are false positives, please report them to the maintainer, see CHECKPATCH in MAINTAINERS.
I'd suggest you drop all the useless generated documentation and fix the patch so that it follows kernel coding style [1]. Then, make sure it's checkpatch clean (see invocation above or use ./scripts/checkpatch.pl -f FILE to check separate files).
[1] https://www.kernel.org/doc/Documentation/CodingStyle
Moritz Fischer
Peter Crosthwaite
Sören Brinkmann
