[U-Boot] [PATCH v8 5/9] x86: slimbootloader: Add serial driver
Slim Bootloader provides serial port info thru its HOB list pointer. All these HOBs are eligible for Slim Bootloader based board only. - Get serial port information from the serial port info HOB - Leverage ns16550 driver with slimbootloader specific platform data
Signed-off-by: Aiden Park aiden.park@intel.com Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Andy Shevchenko andy.shevchenko@gmail.com --- Changes in v6: * Use EFI_GUID * Apply code-review comments
Changes in v4: * Add static keyword in static function
Changes in v3: * Use HOB function from the common HOB library
arch/x86/cpu/slimbootloader/Makefile | 2 +- arch/x86/cpu/slimbootloader/serial.c | 67 +++++++++++++++++++ .../asm/arch-slimbootloader/slimbootloader.h | 34 ++++++++++ 3 files changed, 102 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/slimbootloader/serial.c
diff --git a/arch/x86/cpu/slimbootloader/Makefile b/arch/x86/cpu/slimbootloader/Makefile index 9e6822a6ec..aac9fa3db8 100644 --- a/arch/x86/cpu/slimbootloader/Makefile +++ b/arch/x86/cpu/slimbootloader/Makefile @@ -2,4 +2,4 @@ # # Copyright (C) 2019 Intel Corporation <www.intel.com>
-obj-y += car.o slimbootloader.o sdram.o +obj-y += car.o slimbootloader.o sdram.o serial.o diff --git a/arch/x86/cpu/slimbootloader/serial.c b/arch/x86/cpu/slimbootloader/serial.c new file mode 100644 index 0000000000..7b44a59bff --- /dev/null +++ b/arch/x86/cpu/slimbootloader/serial.c @@ -0,0 +1,67 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <dm.h> +#include <ns16550.h> +#include <serial.h> +#include <asm/arch/slimbootloader.h> + +/** + * The serial port info hob is generated by Slim Bootloader, so eligible for + * Slim Bootloader based boards only. + */ +static int slimbootloader_serial_ofdata_to_platdata(struct udevice *dev) +{ + const efi_guid_t guid = SBL_SERIAL_PORT_INFO_GUID; + struct sbl_serial_port_info *data; + struct ns16550_platdata *plat = dev->platdata; + + if (!gd->arch.hob_list) + panic("hob list not found!"); + + data = hob_get_guid_hob_data(gd->arch.hob_list, NULL, &guid); + if (!data) { + debug("failed to get serial port information\n"); + return -ENOENT; + } + debug("type:%d base=0x%08x baudrate=%d stride=%d clk=%d\n", + data->type, + data->base, + data->baud, + data->stride, + data->clk); + + /* + * The data->type provides port io or mmio access type info, + * but the access type will be controlled by + * CONFIG_SYS_NS16550_PORT_MAPPED or CONFIG_SYS_NS16550_MEM32. + * + * TBD: ns16550 access type configuration in runtime. + * ex) plat->access_type = data->type + */ + plat->base = data->base; + /* ns16550 uses reg_shift, then covert stride to shift */ + plat->reg_shift = data->stride >> 1; + plat->clock = data->clk; + + return 0; +} + +static const struct udevice_id slimbootloader_serial_ids[] = { + { .compatible = "intel,slimbootloader-uart" }, + {} +}; + +U_BOOT_DRIVER(serial_slimbootloader) = { + .name = "serial_slimbootloader", + .id = UCLASS_SERIAL, + .of_match = slimbootloader_serial_ids, + .ofdata_to_platdata = slimbootloader_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), + .priv_auto_alloc_size = sizeof(struct NS16550), + .probe = ns16550_serial_probe, + .ops = &ns16550_serial_ops, +}; diff --git a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h index 4ee8a0627e..174a341d32 100644 --- a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h +++ b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h @@ -16,6 +16,13 @@ EFI_GUID(0xa1ff7424, 0x7a1a, 0x478e, \ 0xa9, 0xe4, 0x92, 0xf3, 0x57, 0xd1, 0x28, 0x32)
+/** + * A GUID to get SerialPort info hob which is provided by Slim Bootloader + */ +#define SBL_SERIAL_PORT_INFO_GUID \ + EFI_GUID(0x6c6872fe, 0x56a9, 0x4403, \ + 0xbb, 0x98, 0x95, 0x8d, 0x62, 0xde, 0x87, 0xf1) + /** * A single entry of memory map information * @@ -50,4 +57,31 @@ struct sbl_memory_map_info { struct sbl_memory_map_entry entry[0]; };
+/** + * This includes serial port info which has already been initialized in previous + * Slim Bootloader stage. + * The Slim Bootloader initializes serial port regardless of debug/release build + * modes, and it passes the information to a payload thru hob. So, a payload can + * re-use the serial information without re-initializing serial port. + * + * @rev : revision of serial_port_info structure. currently 1. + * @rsvd : padding for alignment + * @type : port io: 1, mmio: 2 + * @base : io base address. ex) 0x3f8, 0x80001000 + * @baud : uart baud rate + * @stride: register stride in Bytes + * @clk : uart frequency in Hz + * @rsvd1 : reserved + */ +struct sbl_serial_port_info { + u8 rev; + u8 rsvd[3]; + u32 type; + u32 base; + u32 baud; + u32 stride; + u32 clk; + u32 rsvd1; +}; + #endif /* __SLIMBOOTLOADER_ARCH_H__ */
Park, Aiden
