[U-Boot] [PATCH] mx6sxsabresd: Use 'int' for return values
The variable 'ret' is used to store the value returned by pfuze_mode_init(), so it should be of type 'int' instead of 'unsigned int' in order to correctly handle negative numbers.
Fix the variable type.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 2ff960e..d58a79a 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -199,7 +199,8 @@ static struct i2c_pads_info i2c_pad_info1 = { int power_init_board(void) { struct pmic *p; - unsigned int reg, ret; + unsigned int reg; + int ret;
p = pfuze_common_init(I2C_PMIC); if (!p)
Hi Fabio,
unsigned int reg;
int ret;
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
