[PATCH] net: Handle disabling of compilation for SPL builds
Whilst the net/ directory is excluded from libs-y when CONFIG_SPL_NET_SUPPORT is disabled, this does not prevent SPL builds trying to compile net/ objects. During SPL builds overwrite the value of CONFIG_NET with CONFIG_SPL_NET_SUPPORT to exclude compilation during SPL builds.
Signed-off-by: Nathan Rossi nathan@nathanrossi.com --- net/Makefile | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/net/Makefile b/net/Makefile index fef71b940a..0f57244015 100644 --- a/net/Makefile +++ b/net/Makefile @@ -5,6 +5,10 @@
#ccflags-y += -DDEBUG
+ifdef CONFIG_SPL_BUILD +CONFIG_NET = $(CONFIG_SPL_NET_SUPPORT) +endif + obj-$(CONFIG_NET) += arp.o obj-$(CONFIG_CMD_BOOTP) += bootp.o obj-$(CONFIG_CMD_CDP) += cdp.o --- 2.24.1
This needs to be fixed the same way we have in other cases and that is for CONFIG_SPL_NET_SUPPORT to become CONFIG_SPL_NET and then Makefiles use 'obj-$(CONFIG_$(SPL_)NET) += ...' and so forth. Thanks!
Will do, new series incoming.
Thanks, Nathan
Nathan Rossi
