[U-Boot-Users] [PATCH] Clean up dependency in bit-banged MDIO
Hello,
Attached is a patch that allows use of memory-mapped devices other than CPU GPIO on boards when bit-banging MDIO. The config option MDIO_PORT is now the differentiator as to whether the memory mapped device is on a CPU port or not.
CHANGELOG:
* Changed conditional inclusion of ioport variable to boards that define the MDIO_PORT macro.
regards, Ben
diff --git a/include/configs/ep8248.h b/include/configs/ep8248.h index 04147a5..f6515b3 100644 --- a/include/configs/ep8248.h +++ b/include/configs/ep8248.h @@ -102,7 +102,7 @@ /* * GPIO pins used for bit-banged MII communications */ -#define MDIO_PORT 0 /* Not used - implemented in BCSR */ +#undef MDIO_PORT /* Not used - implemented in BCSR */ #define MDIO_ACTIVE (*(vu_char *)(CFG_BCSR + 8) &= 0xFB) #define MDIO_TRISTATE (*(vu_char *)(CFG_BCSR + 8) |= 0x04) #define MDIO_READ (*(vu_char *)(CFG_BCSR + 8) & 1) diff --git a/common/miiphybb.c b/common/miiphybb.c index adb697c..9ea5636 100644 --- a/common/miiphybb.c +++ b/common/miiphybb.c @@ -41,7 +41,7 @@ static void miiphy_pre (char read, unsigned char addr, unsigned char reg) { int j; /* counter */ -#ifndef CONFIG_EP8248 +#if defined(MDIO_PORT) volatile ioport_t *iop = ioport_addr ((immap_t *) CFG_IMMR, MDIO_PORT); #endif
@@ -126,7 +126,7 @@ int bb_miiphy_read (char *devname, unsig { short rdreg; /* register working value */ int j; /* counter */ -#ifndef CONFIG_EP8248 +#if defined(MDIO_PORT) volatile ioport_t *iop = ioport_addr ((immap_t *) CFG_IMMR, MDIO_PORT); #endif
@@ -193,7 +193,7 @@ int bb_miiphy_write (char *devname, unsi unsigned char reg, unsigned short value) { int j; /* counter */ -#ifndef CONFIG_EP8248 +#if defined(MDIO_PORT) volatile ioport_t *iop = ioport_addr ((immap_t *) CFG_IMMR, MDIO_PORT); #endif
Ben Warren
