[PATCH] dlmalloc: Add an option to default malloc to init
If a system wants the malloc to get moved around from one to another memory range it should call mem_malloc_init() with the updated memory ranges. However setting aside the new memory alone isn't enough. It should also bring the bins and static bookkeeping data to init.
One of the use cases could be SPL U-Boot that allocates first to the (limited) static memory and then when needs more memory, and the DDR memory becomes available, moves the pools around.
Note that defaulting the malloc to init discards all the memory previously allocated.
Signed-off-by: Marek Bykowski marek.bykowski@gmail.com --- Kconfig | 14 ++++++++++++++ common/dlmalloc.c | 41 ++++++++++++++++++++++++++++++++++++++--- 2 files changed, 52 insertions(+), 3 deletions(-)
diff --git a/Kconfig b/Kconfig index 1f0904f704..958553c90a 100644 --- a/Kconfig +++ b/Kconfig @@ -209,6 +209,20 @@ if EXPERT When disabling this, please check if malloc calls, maybe should be replaced by calloc - if one expects zeroed memory.
+config SYS_MALLOC_DEFAULT_TO_INIT + bool "Default malloc to init while reserving the memory for it" + default n + help + It may happen that one needs to move the dynamic allocation + from one to another memory range, eg. when moving the malloc + from the limited static to a potentially large dynamic (DDR) + memory. + + If so then on top of setting the updated memory aside one + needs to bring the malloc init. + + If such a scenario is sought choose yes. + config TOOLS_DEBUG bool "Enable debug information for tools" help diff --git a/common/dlmalloc.c b/common/dlmalloc.c index 6f12a18d54..8b2796e280 100644 --- a/common/dlmalloc.c +++ b/common/dlmalloc.c @@ -280,6 +280,7 @@ nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ | Unused space (may be 0 bytes long) . . . . | + nextchunk-> +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ `foot:' | Size of chunk, in bytes | +-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+ @@ -574,6 +575,10 @@ static void malloc_bin_reloc(void) static inline void malloc_bin_reloc(void) {} #endif
+#ifdef CONFIG_SYS_MALLOC_DEFAULT_TO_INIT +static void malloc_init(void); +#endif + ulong mem_malloc_start = 0; ulong mem_malloc_end = 0; ulong mem_malloc_brk = 0; @@ -604,6 +609,10 @@ void mem_malloc_init(ulong start, ulong size) mem_malloc_end = start + size; mem_malloc_brk = start;
+#ifdef CONFIG_SYS_MALLOC_DEFAULT_TO_INIT + malloc_init(); +#endif + debug("using memory %#lx-%#lx for malloc()\n", mem_malloc_start, mem_malloc_end); #ifdef CONFIG_SYS_MALLOC_CLEAR_ON_INIT @@ -708,7 +717,36 @@ static unsigned int max_n_mmaps = 0; static unsigned long max_mmapped_mem = 0; #endif
+#ifdef CONFIG_SYS_MALLOC_DEFAULT_TO_INIT +static void malloc_init(void) +{ + int i, j; + + debug("bins (av_ array) are at %p\n", (void *)av_); + + av_[0] = NULL; av_[1] = NULL; + for (i = 2, j = 2; i < NAV * 2 + 2; i += 2, j++) { + av_[i] = bin_at(j - 2); + av_[i + 1] = bin_at(j - 2); + + /* Just print the first few bins so that + * we can see there are alright. + */ + if (i < 10) + debug("av_[%d]=%lx av_[%d]=%lx\n", + i, (ulong)av_[i], + i + 1, (ulong)av_[i + 1]); + }
+ /* Init the static bookkeeping as well */ + sbrk_base = (char *)(-1); + max_sbrked_mem = 0; + max_total_mem = 0; +#ifdef DEBUG + memset((void *)¤t_mallinfo, 0, sizeof(struct mallinfo)); +#endif +} +#endif
/* Debugging support @@ -1051,9 +1089,6 @@ static mchunkptr mremap_chunk(p, new_size) mchunkptr p; size_t new_size;
#endif /* HAVE_MMAP */
- - - /* Extend the top-most chunk by obtaining memory from system. Main interface to sbrk (but see also malloc_trim).
- bool "Default malloc to init while reserving the memory for it"
- default n
- help
memory.
- malloc_init();
+#endif
- debug("using memory %#lx-%#lx for malloc()\n", mem_malloc_start, mem_malloc_end);
int i, j;
if (i < 10)
i, (ulong)av_[i],
max_sbrked_mem = 0;
max_total_mem = 0;
+#ifdef DEBUG
- memset((void *)¤t_mallinfo, 0, sizeof(struct mallinfo));
+#endif +} +#endif
Can you please showcase using this feature somewhere? Thanks!
Yes. First of all, sincere apology for such a massive delay in it. I got snowed with the corporation work of mine.
So here is my go at showcasing it. We are in SPL U-Boot running code from within the static memory: arch/arm/cpu/armv8/start.S:reset vector -> arch/arm/cpu/armv8/start.S:main() -> arch/arm/lib/crt0_64.S:board_init_f() -> /board/<my_board>/common/spl.c:board_init_f()
board_init_f() does mem_malloc_init(malloc_start_in_static, size). It needs the malloc for SPI flash to load off some proprietary stuff. Note the size of the static memory is limited, so is our malloc size.
Then along it does the DDR memory initialization. Now we have much greater memory and can move our malloc allocator onto it. So again it does mem_malloc_init() but this time with an address in the DDR memory and a much greater size. And this is where this feature comes in hand. Just calling in mem_malloc_init() with the updated start addr and the size isn't enough. It also mandates resetting the malloc, namely defaulting its bins, and some bookkeeping.
I know there is an early malloc available I can use as the first one but that requires managing the two mallocs. This patch proposes to use a single malloc suite (dlmalloc) and use it freely around when and how it is needed.
Marek
The previous message of mine went out of thread. It should be in thread now.
Marek
-- Tom
Marek
-- Tom
OK, thanks. Can you please re-send and include the above re-phrased to make sense in a commit message, in the body of the commit as well so it's documented more in-tree when this would be helpful? Thanks again!
Marek
-- Tom
Sure Tom. Will do that Monday/Tuesday.
Thanks, Marek
Marek
Marek Bykowski
