[U-Boot] [PATCH 0/5] ARM: at91: improve peripheral and system clock handle functions
To reduce the duplicated code, rework the peripheral's and system's clock handle functions, use these functions to replace the clock handle code.
Wenyou Yang (5): ARM: at91: asm/at91_pmc.h: fix trival register offset ARM: at91: clock: add a new file to handle clock ARM: cpu: at91: clean up peripheral clock code board: atmel: clean up peripheral clock code drivers: at91: clean up peripheral clock code
arch/arm/mach-at91/Makefile | 1 + arch/arm/mach-at91/arm920t/at91rm9200_devices.c | 13 +--- arch/arm/mach-at91/arm920t/timer.c | 4 +- arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c | 36 +++------- arch/arm/mach-at91/arm926ejs/at91sam9261_devices.c | 28 ++------ arch/arm/mach-at91/arm926ejs/at91sam9263_devices.c | 37 +++------- .../mach-at91/arm926ejs/at91sam9m10g45_devices.c | 33 +++------ arch/arm/mach-at91/arm926ejs/at91sam9n12_devices.c | 40 +++-------- arch/arm/mach-at91/arm926ejs/at91sam9rl_devices.c | 28 ++------ arch/arm/mach-at91/arm926ejs/at91sam9x5_devices.c | 38 +++-------- arch/arm/mach-at91/arm926ejs/clock.c | 7 -- arch/arm/mach-at91/arm926ejs/cpu.c | 1 - arch/arm/mach-at91/arm926ejs/timer.c | 5 +- arch/arm/mach-at91/armv7/clock.c | 26 ------- arch/arm/mach-at91/armv7/cpu.c | 1 - arch/arm/mach-at91/armv7/timer.c | 1 - arch/arm/mach-at91/clock.c | 72 ++++++++++++++++++++ arch/arm/mach-at91/include/mach/at91_pmc.h | 8 +-- arch/arm/mach-at91/include/mach/clk.h | 2 + arch/arm/mach-at91/phy.c | 1 - arch/arm/mach-at91/sdram.c | 1 - board/atmel/at91rm9200ek/at91rm9200ek.c | 1 - board/atmel/at91rm9200ek/led.c | 5 +- board/atmel/at91sam9260ek/at91sam9260ek.c | 15 ++-- board/atmel/at91sam9261ek/at91sam9261ek.c | 8 +-- board/atmel/at91sam9261ek/led.c | 6 +- board/atmel/at91sam9263ek/at91sam9263ek.c | 23 ++----- board/atmel/at91sam9263ek/led.c | 9 +-- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 20 ++---- board/atmel/at91sam9m10g45ek/led.c | 7 +- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 6 +- board/atmel/at91sam9rlek/at91sam9rlek.c | 18 ++--- board/atmel/at91sam9rlek/led.c | 7 +- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 10 +-- board/atmel/sama5d2_xplained/sama5d2_xplained.c | 1 - board/atmel/sama5d3_xplained/sama5d3_xplained.c | 5 +- board/atmel/sama5d3xek/sama5d3xek.c | 5 +- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 5 +- board/atmel/sama5d4ek/sama5d4ek.c | 5 +- board/bluewater/snapper9260/snapper9260.c | 15 ++-- board/calao/usb_a9263/usb_a9263.c | 11 ++- board/egnite/ethernut5/ethernut5.c | 20 +++--- board/esd/meesc/meesc.c | 15 ++-- board/mini-box/picosam9g45/led.c | 7 +- board/mini-box/picosam9g45/picosam9g45.c | 17 ++--- board/ronetix/pm9261/led.c | 7 +- board/ronetix/pm9261/pm9261.c | 22 ++---- board/ronetix/pm9263/led.c | 7 +- board/ronetix/pm9263/pm9263.c | 19 ++---- board/ronetix/pm9g45/pm9g45.c | 20 ++---- board/siemens/corvus/board.c | 6 +- board/siemens/smartweb/smartweb.c | 3 +- board/siemens/taurus/taurus.c | 3 +- drivers/net/at91_emac.c | 9 ++- drivers/usb/host/ehci-atmel.c | 8 --- drivers/usb/host/ohci-at91.c | 20 ++---- 56 files changed, 252 insertions(+), 496 deletions(-) create mode 100644 arch/arm/mach-at91/clock.c
Remove unnecessary #ifdef CPU_HAS_PCR.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
arch/arm/mach-at91/include/mach/at91_pmc.h | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/at91_pmc.h b/arch/arm/mach-at91/include/mach/at91_pmc.h index 3f50f77..eb40194 100644 --- a/arch/arm/mach-at91/include/mach/at91_pmc.h +++ b/arch/arm/mach-at91/include/mach/at91_pmc.h @@ -51,19 +51,15 @@ typedef struct at91_pmc { u32 imr; /* 0x6C Interrupt Mask Register */ u32 reserved4[4]; u32 pllicpr; /* 0x80 Change Pump Current Register (SAM9) */ - u32 reserved5[21]; + u32 reserved5[24]; u32 wpmr; /* 0xE4 Write Protect Mode Register (CAP0) */ u32 wpsr; /* 0xE8 Write Protect Status Register (CAP0) */ -#ifdef CPU_HAS_PCR - u32 reserved6[8]; + u32 reserved6[5]; u32 pcer1; /* 0x100 Periperial Clock Enable Register 1 */ u32 pcdr1; /* 0x104 Periperial Clock Disable Register 1 */ u32 pcsr1; /* 0x108 Periperial Clock Status Register 1 */ u32 pcr; /* 0x10c Periperial Control Register */ u32 ocr; /* 0x110 Oscillator Calibration Register */ -#else - u32 reserved8[5]; -#endif } at91_pmc_t;
#endif /* end not assembly */
To reduce the duplicated code, add a new file to accommodate the peripheral's and system's clock handle code, shared with the SoCs with different ARM core.
arch/arm/mach-at91/Makefile | 1 + arch/arm/mach-at91/arm926ejs/clock.c | 7 ---- arch/arm/mach-at91/armv7/clock.c | 26 ------------ arch/arm/mach-at91/clock.c | 72 +++++++++++++++++++++++++++++++++ arch/arm/mach-at91/include/mach/clk.h | 2 + 5 files changed, 75 insertions(+), 33 deletions(-) create mode 100644 arch/arm/mach-at91/clock.c
diff --git a/arch/arm/mach-at91/Makefile b/arch/arm/mach-at91/Makefile index 5b89617..d071072 100644 --- a/arch/arm/mach-at91/Makefile +++ b/arch/arm/mach-at91/Makefile @@ -14,6 +14,7 @@ obj-$(CONFIG_SAMA5D4) += mpddrc.o spl_atmel.o matrix.o atmel_sfr.o obj-y += spl.o endif
+obj-y += clock.o obj-$(CONFIG_CPU_ARM920T) += arm920t/ obj-$(CONFIG_CPU_ARM926EJS) += arm926ejs/ obj-$(CONFIG_CPU_V7) += armv7/ diff --git a/arch/arm/mach-at91/arm926ejs/clock.c b/arch/arm/mach-at91/arm926ejs/clock.c index 8d6934e..c8b5e10 100644 --- a/arch/arm/mach-at91/arm926ejs/clock.c +++ b/arch/arm/mach-at91/arm926ejs/clock.c @@ -242,10 +242,3 @@ void at91_mck_init(u32 mckr) while (!(readl(&pmc->sr) & AT91_PMC_MCKRDY)) ; } - -void at91_periph_clk_enable(int id) -{ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - writel(1 << id, &pmc->pcer); -} diff --git a/arch/arm/mach-at91/armv7/clock.c b/arch/arm/mach-at91/armv7/clock.c index 41dbf16..81e9f69 100644 --- a/arch/arm/mach-at91/armv7/clock.c +++ b/arch/arm/mach-at91/armv7/clock.c @@ -150,32 +150,6 @@ void at91_mck_init(u32 mckr) ; }
-void at91_periph_clk_enable(int id) -{ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - u32 regval; - - if (id > AT91_PMC_PCR_PID_MASK) - return; - - regval = AT91_PMC_PCR_EN | AT91_PMC_PCR_CMD_WRITE | id; - - writel(regval, &pmc->pcr); -} - -void at91_periph_clk_disable(int id) -{ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - u32 regval; - - if (id > AT91_PMC_PCR_PID_MASK) - return; - - regval = AT91_PMC_PCR_CMD_WRITE | id; - - writel(regval, &pmc->pcr); -} - int at91_enable_periph_generated_clk(u32 id, u32 clk_source, u32 div) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; diff --git a/arch/arm/mach-at91/clock.c b/arch/arm/mach-at91/clock.c new file mode 100644 index 0000000..823d218 --- /dev/null +++ b/arch/arm/mach-at91/clock.c @@ -0,0 +1,72 @@ +/* + * Copyright (C) 2015 Atmel Corporation + * Wenyou Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/at91_pmc.h> + +void at91_periph_clk_enable(int id) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + +#ifdef CPU_HAS_PCR + u32 regval; + u32 div_value; + + if (id > AT91_PMC_PCR_PID_MASK) + return; + + writel(id, &pmc->pcr); + + div_value = readl(&pmc->pcr) & AT91_PMC_PCR_DIV; + + regval = AT91_PMC_PCR_EN | AT91_PMC_PCR_CMD_WRITE | id | div_value; + + writel(regval, &pmc->pcr); +#else + u32 mask = 0x01 << (id % 32); + u32 reg = (id / 32) ? pmc->pcer1 : pmc->pcer; + + writel(mask, ®); +#endif +} + +void at91_periph_clk_disable(int id) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + +#ifdef CPU_HAS_PCR + u32 regval; + + if (id > AT91_PMC_PCR_PID_MASK) + return; + + regval = AT91_PMC_PCR_CMD_WRITE | id; + + writel(regval, &pmc->pcr); +#else + u32 mask = 0x01 << (id % 32); + u32 reg = (id / 32) ? pmc->pcdr1 : pmc->pcdr; + + writel(mask, ®); +#endif +} + +void at91_system_clk_enable(int sys_clk) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + writel(sys_clk, &pmc->scer); +} + +void at91_system_clk_disable(int sys_clk) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + writel(sys_clk, &pmc->scdr); +} diff --git a/arch/arm/mach-at91/include/mach/clk.h b/arch/arm/mach-at91/include/mach/clk.h index ad83927..bef4e1c 100644 --- a/arch/arm/mach-at91/include/mach/clk.h +++ b/arch/arm/mach-at91/include/mach/clk.h @@ -128,5 +128,7 @@ void at91_periph_clk_enable(int id); void at91_periph_clk_disable(int id); int at91_enable_periph_generated_clk(u32 id, u32 clk_source, u32 div); u32 at91_get_periph_generated_clk(u32 id); +void at91_system_clk_enable(int sys_clk); +void at91_system_clk_disable(int sys_clk);
#endif /* __ASM_ARM_ARCH_CLK_H__ */
Due to introducing the new peripheral clock handle functions, use these functions to clean up the duplicated code.
Meanwhile, remove unneeded header file include, at91_pmc.h.
arch/arm/mach-at91/arm920t/at91rm9200_devices.c | 13 ++----- arch/arm/mach-at91/arm920t/timer.c | 4 +- arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c | 36 +++++------------- arch/arm/mach-at91/arm926ejs/at91sam9261_devices.c | 28 ++++---------- arch/arm/mach-at91/arm926ejs/at91sam9263_devices.c | 37 +++++------------- .../mach-at91/arm926ejs/at91sam9m10g45_devices.c | 33 ++++------------ arch/arm/mach-at91/arm926ejs/at91sam9n12_devices.c | 40 +++++--------------- arch/arm/mach-at91/arm926ejs/at91sam9rl_devices.c | 28 ++++---------- arch/arm/mach-at91/arm926ejs/at91sam9x5_devices.c | 38 +++++-------------- arch/arm/mach-at91/arm926ejs/cpu.c | 1 - arch/arm/mach-at91/arm926ejs/timer.c | 5 +-- arch/arm/mach-at91/armv7/cpu.c | 1 - arch/arm/mach-at91/armv7/timer.c | 1 - arch/arm/mach-at91/phy.c | 1 - arch/arm/mach-at91/sdram.c | 1 - 15 files changed, 65 insertions(+), 202 deletions(-)
diff --git a/arch/arm/mach-at91/arm920t/at91rm9200_devices.c b/arch/arm/mach-at91/arm920t/at91rm9200_devices.c index fc54327..a340122 100644 --- a/arch/arm/mach-at91/arm920t/at91rm9200_devices.c +++ b/arch/arm/mach-at91/arm920t/at91rm9200_devices.c @@ -14,7 +14,6 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h>
/* @@ -34,29 +33,23 @@
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 17, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTA, 18, PUP); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 20, PUP); /* RXD1 */ at91_set_a_periph(AT91_PIO_PORTB, 21, 1); /* TXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 22, PUP); /* RXD2 */ at91_set_a_periph(AT91_PIO_PORTA, 23, 1); /* TXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_seriald_hw_init(void) diff --git a/arch/arm/mach-at91/arm920t/timer.c b/arch/arm/mach-at91/arm920t/timer.c index 6aa2994..3190961 100644 --- a/arch/arm/mach-at91/arm920t/timer.c +++ b/arch/arm/mach-at91/arm920t/timer.c @@ -19,7 +19,6 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_tc.h> -#include <asm/arch/at91_pmc.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -31,8 +30,7 @@ int timer_init(void) at91_tc_t *tc = (at91_tc_t *) ATMEL_BASE_TC; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
- /* enables TC1.0 clock */ - writel(1 << ATMEL_ID_TC0, &pmc->pcer); /* enable clock */ + at91_periph_clk_enable(ATMEL_ID_TC0);
writel(0, &tc->bcr); writel(AT91_TC_BMR_TC0XC0S_NONE | AT91_TC_BMR_TC1XC1S_NONE | diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c index 5e0c0f5..912a966 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9260_devices.c @@ -11,8 +11,8 @@ #include <asm/io.h> #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91sam9_sdramc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
/* @@ -32,51 +32,40 @@
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTB, 5, PUP); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 6, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTB, 7, PUP); /* RXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 8, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTB, 9, PUP); /* RXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 14, PUP); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTB, 15, 1); /* DTXD */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS); }
#if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 0, PUP); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTA, 1, PUP); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTA, 2, PUP); /* SPI0_SPCK */
- /* Enable clock */ - writel(1 << ATMEL_ID_SPI0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SPI0);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTA, 3, 1); @@ -106,14 +95,11 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 0, PUP); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 1, PUP); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 2, PUP); /* SPI1_SPCK */
- /* Enable clock */ - writel(1 << ATMEL_ID_SPI1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SPI1);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 3, 1); @@ -145,9 +131,7 @@ void at91_spi1_hw_init(unsigned long cs_mask) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - /* Enable EMAC clock */ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC0);
at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* ETXCK_EREFCK */ at91_set_a_periph(AT91_PIO_PORTA, 17, 0); /* ERXDV */ @@ -190,9 +174,7 @@ void at91_macb_hw_init(void) #if defined(CONFIG_GENERIC_ATMEL_MCI) void at91_mci_hw_init(void) { - /* Enable mci clock */ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - writel(1 << ATMEL_ID_MCI, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_MCI);
at91_set_a_periph(AT91_PIO_PORTA, 8, 1); /* MCCK */ #if defined(CONFIG_ATMEL_MCI_PORTB) diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9261_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9261_devices.c index a445c75..4bd4e75 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9261_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9261_devices.c @@ -9,7 +9,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
/* @@ -29,51 +29,40 @@
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 8, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTC, 9, 0); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 12, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTC, 13, 0); /* RXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 14, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTC, 15, 0); /* RXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS); }
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTA, 3, 1); @@ -103,14 +92,11 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 30, PUP); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 31, PUP); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 29, PUP); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 28, 1); diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9263_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9263_devices.c index 6b51d5f..f3f4800 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9263_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9263_devices.c @@ -13,7 +13,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
/* @@ -33,51 +33,40 @@
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 26, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTA, 27, PUP); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTD, 0, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTD, 1, PUP); /* RXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTD, 2, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTD, 3, PUP); /* RXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 30, PUP); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTC, 31, 1); /* DTXD */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS); }
#if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_b_periph(AT91_PIO_PORTA, 0, PUP); /* SPI0_MISO */ at91_set_b_periph(AT91_PIO_PORTA, 1, PUP); /* SPI0_MOSI */ at91_set_b_periph(AT91_PIO_PORTA, 2, PUP); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { at91_set_b_periph(AT91_PIO_PORTA, 5, 1); @@ -107,14 +96,11 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 12, PUP); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 13, PUP); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 14, PUP); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 15, 1); @@ -146,9 +132,7 @@ void at91_spi1_hw_init(unsigned long cs_mask) #if defined(CONFIG_GENERIC_ATMEL_MCI) void at91_mci_hw_init(void) { - /* Enable mci clock */ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - writel(1 << ATMEL_ID_MCI1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_MCI1);
at91_set_a_periph(AT91_PIO_PORTA, 6, PUP); /* MCI1_CK */
@@ -207,12 +191,9 @@ void at91_uhp_hw_init(void) #ifdef CONFIG_AT91_CAN void at91_can_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* CAN_TX */ at91_set_a_periph(AT91_PIO_PORTA, 14, 1); /* CAN_RX */
- /* Enable clock */ - writel(1 << ATMEL_ID_CAN, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_CAN); } #endif diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9m10g45_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9m10g45_devices.c index 0e6c0da..0d83426 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9m10g45_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9m10g45_devices.c @@ -8,7 +8,7 @@
#include <common.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm/io.h>
@@ -29,51 +29,40 @@
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 19, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTB, 18, PUP); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 4, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTB, 5, PUP); /* RXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTD, 6, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTD, 7, PUP); /* RXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 12, 0); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTB, 13, 1); /* DTXD */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS); }
#if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 0, PUP); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 1, PUP); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 2, PUP); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 3, 1); @@ -103,14 +92,11 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 14, PUP); /* SPI1_MISO */ at91_set_a_periph(AT91_PIO_PORTB, 15, PUP); /* SPI1_MOSI */ at91_set_a_periph(AT91_PIO_PORTB, 16, PUP); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTB, 17, 1); @@ -169,8 +155,6 @@ void at91_macb_hw_init(void) #ifdef CONFIG_GENERIC_ATMEL_MCI void at91_mci_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* MCI0 CLK */ at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* MCI0 CDA */ at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* MCI0 DA0 */ @@ -178,7 +162,6 @@ void at91_mci_hw_init(void) at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* MCI0 DA2 */ at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* MCI0 DA3 */
- /* Enable clock */ - writel(1 << ATMEL_ID_MCI0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_MCI0); } #endif diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9n12_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9n12_devices.c index 39f17a1..a03abfc 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9n12_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9n12_devices.c @@ -8,8 +8,8 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pio.h> +#include <asm/arch/clk.h>
unsigned int has_lcdc() { @@ -18,60 +18,47 @@ unsigned int has_lcdc()
void at91_serial0_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 0, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 5, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* RXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 7, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTA, 8, 0); /* RXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_serial3_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_b_periph(AT91_PIO_PORTC, 22, 1); /* TXD3 */ at91_set_b_periph(AT91_PIO_PORTC, 23, 0); /* RXD3 */ - writel(1 << ATMEL_ID_USART3, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART3); }
void at91_seriald_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 10, 1); /* DTXD */ at91_set_a_periph(AT91_PIO_PORTA, 9, 0); /* DRXD */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS); }
#ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) at91_set_pio_output(AT91_PIO_PORTA, 14, 1); @@ -85,14 +72,11 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_b_periph(AT91_PIO_PORTA, 21, 0); /* SPI1_MISO */ at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* SPI1_MOSI */ at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) at91_set_pio_output(AT91_PIO_PORTA, 8, 1); @@ -107,8 +91,6 @@ void at91_spi1_hw_init(unsigned long cs_mask)
void at91_mci_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 17, 0); /* MCCK */ at91_set_a_periph(AT91_PIO_PORTA, 16, 0); /* MCCDA */ at91_set_a_periph(AT91_PIO_PORTA, 15, 0); /* MCDA0 */ @@ -116,14 +98,12 @@ void at91_mci_hw_init(void) at91_set_a_periph(AT91_PIO_PORTA, 19, 0); /* MCDA2 */ at91_set_a_periph(AT91_PIO_PORTA, 20, 0); /* MCDA3 */
- writel(1 << ATMEL_ID_HSMCI0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_HSMCI0); }
#ifdef CONFIG_LCD void at91_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 24, 0); /* LCDDPWR */ at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDVSYNC */ at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDHSYNC */ @@ -156,6 +136,6 @@ void at91_lcd_hw_init(void) at91_set_a_periph(AT91_PIO_PORTC, 22, 0); /* LCDD22 */ at91_set_a_periph(AT91_PIO_PORTC, 23, 0); /* LCDD23 */
- writel(1 << ATMEL_ID_LCDC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_LCDC); } #endif diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9rl_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9rl_devices.c index 857c864..dbf9386 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9rl_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9rl_devices.c @@ -9,7 +9,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 6, 1); /* TXD0 */ at91_set_a_periph(AT91_PIO_PORTA, 7, PUP); /* RXD0 */ - writel(1 << ATMEL_ID_USART0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART0); }
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 11, 1); /* TXD1 */ at91_set_a_periph(AT91_PIO_PORTA, 12, PUP); /* RXD1 */ - writel(1 << ATMEL_ID_USART1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART1); }
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 13, 1); /* TXD2 */ at91_set_a_periph(AT91_PIO_PORTA, 14, PUP); /* RXD2 */ - writel(1 << ATMEL_ID_USART2, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_USART2); }
void at91_seriald_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 21, PUP); /* DRXD */ at91_set_a_periph(AT91_PIO_PORTA, 22, 1); /* DTXD */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS); }
#if defined(CONFIG_HAS_DATAFLASH) || defined(CONFIG_ATMEL_SPI) void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 25, PUP); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTA, 26, PUP); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTA, 27, PUP); /* SPI0_SPCK */
- /* Enable clock */ - writel(1 << ATMEL_ID_SPI, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SPI);
if (cs_mask & (1 << 0)) { at91_set_a_periph(AT91_PIO_PORTA, 28, 1); @@ -105,8 +94,6 @@ void at91_spi0_hw_init(unsigned long cs_mask) #ifdef CONFIG_GENERIC_ATMEL_MCI void at91_mci_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* MCI CLK */ at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* MCI CDA */ at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* MCI DA0 */ @@ -114,7 +101,6 @@ void at91_mci_hw_init(void) at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* MCI DA2 */ at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* MCI DA3 */
- /* Enable clock */ - writel(1 << ATMEL_ID_MCI, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_MCI); } #endif diff --git a/arch/arm/mach-at91/arm926ejs/at91sam9x5_devices.c b/arch/arm/mach-at91/arm926ejs/at91sam9x5_devices.c index 6d94572..3e4555a 100644 --- a/arch/arm/mach-at91/arm926ejs/at91sam9x5_devices.c +++ b/arch/arm/mach-at91/arm926ejs/at91sam9x5_devices.c @@ -6,7 +6,7 @@
@@ -64,42 +64,34 @@ char *get_cpu_name()
void at91_serial0_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 0, 1); /* TXD */ at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* RXD */
void at91_serial1_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 5, 1); /* TXD */ at91_set_a_periph(AT91_PIO_PORTA, 6, 0); /* RXD */
void at91_serial2_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 7, 1); /* TXD */ at91_set_a_periph(AT91_PIO_PORTA, 8, 0); /* RXD */
void at91_mci_hw_init(void) @@ -112,22 +104,17 @@ void at91_mci_hw_init(void) at91_set_a_periph(AT91_PIO_PORTA, 19, 1); /* MCDA2 */ at91_set_a_periph(AT91_PIO_PORTA, 20, 1); /* MCDA3 */
- /* Enable clock for MCI0 */ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - writel(1 << ATMEL_ID_HSMCI0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_HSMCI0); }
#ifdef CONFIG_ATMEL_SPI void at91_spi0_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTA, 11, 0); /* SPI0_MISO */ at91_set_a_periph(AT91_PIO_PORTA, 12, 0); /* SPI0_MOSI */ at91_set_a_periph(AT91_PIO_PORTA, 13, 0); /* SPI0_SPCK */
if (cs_mask & (1 << 0)) at91_set_a_periph(AT91_PIO_PORTA, 14, 0); @@ -149,14 +136,11 @@ void at91_spi0_hw_init(unsigned long cs_mask)
void at91_spi1_hw_init(unsigned long cs_mask) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_b_periph(AT91_PIO_PORTA, 21, 0); /* SPI1_MISO */ at91_set_b_periph(AT91_PIO_PORTA, 22, 0); /* SPI1_MOSI */ at91_set_b_periph(AT91_PIO_PORTA, 23, 0); /* SPI1_SPCK */
if (cs_mask & (1 << 0)) at91_set_b_periph(AT91_PIO_PORTA, 8, 0); @@ -193,11 +177,9 @@ void at91_uhp_hw_init(void) #ifdef CONFIG_MACB void at91_macb_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - if (has_emac0()) { /* Enable EMAC0 clock */ - writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC0); /* EMAC0 pins setup */ at91_set_a_periph(AT91_PIO_PORTB, 4, 0); /* ETXCK */ at91_set_a_periph(AT91_PIO_PORTB, 3, 0); /* ERXDV */ @@ -213,7 +195,7 @@ void at91_macb_hw_init(void)
if (has_emac1()) { /* Enable EMAC1 clock */ - writel(1 << ATMEL_ID_EMAC1, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC1); /* EMAC1 pins setup */ at91_set_b_periph(AT91_PIO_PORTC, 29, 0); /* ETXCK */ at91_set_b_periph(AT91_PIO_PORTC, 28, 0); /* ECRSDV */ diff --git a/arch/arm/mach-at91/arm926ejs/cpu.c b/arch/arm/mach-at91/arm926ejs/cpu.c index 990c689..9b9f8af 100644 --- a/arch/arm/mach-at91/arm926ejs/cpu.c +++ b/arch/arm/mach-at91/arm926ejs/cpu.c @@ -10,7 +10,6 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pit.h> #include <asm/arch/at91_gpbr.h> #include <asm/arch/clk.h> diff --git a/arch/arm/mach-at91/arm926ejs/timer.c b/arch/arm/mach-at91/arm926ejs/timer.c index 31ce646..c49d306 100644 --- a/arch/arm/mach-at91/arm926ejs/timer.c +++ b/arch/arm/mach-at91/arm926ejs/timer.c @@ -10,7 +10,6 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/clk.h> #include <div64.h>
@@ -38,11 +37,9 @@ DECLARE_GLOBAL_DATA_PTR; */ int timer_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; at91_pit_t *pit = (at91_pit_t *) ATMEL_BASE_PIT;
- /* Enable PITC Clock */ - writel(1 << ATMEL_ID_SYS, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_SYS);
/* Enable PITC */ writel(TIMER_LOAD_VAL | AT91_PIT_MR_EN , &pit->mr); diff --git a/arch/arm/mach-at91/armv7/cpu.c b/arch/arm/mach-at91/armv7/cpu.c index 7843aed..1865303 100644 --- a/arch/arm/mach-at91/armv7/cpu.c +++ b/arch/arm/mach-at91/armv7/cpu.c @@ -12,7 +12,6 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pit.h> #include <asm/arch/at91_gpbr.h> #include <asm/arch/clk.h> diff --git a/arch/arm/mach-at91/armv7/timer.c b/arch/arm/mach-at91/armv7/timer.c index a4a3817..6f91e22 100644 --- a/arch/arm/mach-at91/armv7/timer.c +++ b/arch/arm/mach-at91/armv7/timer.c @@ -13,7 +13,6 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pit.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/clk.h> #include <div64.h>
diff --git a/arch/arm/mach-at91/phy.c b/arch/arm/mach-at91/phy.c index 2cba716..ddd70f5 100644 --- a/arch/arm/mach-at91/phy.c +++ b/arch/arm/mach-at91/phy.c @@ -15,7 +15,6 @@ #include <common.h> #include <asm/io.h> #include <linux/sizes.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <watchdog.h>
diff --git a/arch/arm/mach-at91/sdram.c b/arch/arm/mach-at91/sdram.c index 5758b06..1dfc74f 100644 --- a/arch/arm/mach-at91/sdram.c +++ b/arch/arm/mach-at91/sdram.c @@ -13,7 +13,6 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91sam9_sdramc.h> #include <asm/arch/gpio.h>
Due to introducing the new peripheral clock handle functions, use these functions to reduce duplicated code.
board/atmel/at91rm9200ek/at91rm9200ek.c | 1 - board/atmel/at91rm9200ek/led.c | 5 +---- board/atmel/at91sam9260ek/at91sam9260ek.c | 15 +++++---------- board/atmel/at91sam9261ek/at91sam9261ek.c | 8 ++------ board/atmel/at91sam9261ek/led.c | 6 ++---- board/atmel/at91sam9263ek/at91sam9263ek.c | 23 +++++++---------------- board/atmel/at91sam9263ek/led.c | 9 +++------ board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 20 +++++--------------- board/atmel/at91sam9m10g45ek/led.c | 7 ++----- board/atmel/at91sam9n12ek/at91sam9n12ek.c | 6 ++---- board/atmel/at91sam9rlek/at91sam9rlek.c | 18 ++++++------------ board/atmel/at91sam9rlek/led.c | 7 ++----- board/atmel/at91sam9x5ek/at91sam9x5ek.c | 10 +++------- board/atmel/sama5d2_xplained/sama5d2_xplained.c | 1 - board/atmel/sama5d3_xplained/sama5d3_xplained.c | 5 ++--- board/atmel/sama5d3xek/sama5d3xek.c | 5 ++--- board/atmel/sama5d4_xplained/sama5d4_xplained.c | 5 ++--- board/atmel/sama5d4ek/sama5d4ek.c | 5 ++--- board/bluewater/snapper9260/snapper9260.c | 15 +++++---------- board/calao/usb_a9263/usb_a9263.c | 11 ++++------- board/egnite/ethernut5/ethernut5.c | 20 ++++++++------------ board/esd/meesc/meesc.c | 15 ++++++--------- board/mini-box/picosam9g45/led.c | 7 ++----- board/mini-box/picosam9g45/picosam9g45.c | 17 ++++------------- board/ronetix/pm9261/led.c | 7 ++----- board/ronetix/pm9261/pm9261.c | 22 ++++++---------------- board/ronetix/pm9263/led.c | 7 ++----- board/ronetix/pm9263/pm9263.c | 19 +++++-------------- board/ronetix/pm9g45/pm9g45.c | 20 ++++++-------------- board/siemens/corvus/board.c | 6 ++---- board/siemens/smartweb/smartweb.c | 3 +-- board/siemens/taurus/taurus.c | 3 +-- 32 files changed, 102 insertions(+), 226 deletions(-)
diff --git a/board/atmel/at91rm9200ek/at91rm9200ek.c b/board/atmel/at91rm9200ek/at91rm9200ek.c index 64ab572..4ca8106 100644 --- a/board/atmel/at91rm9200ek/at91rm9200ek.c +++ b/board/atmel/at91rm9200ek/at91rm9200ek.c @@ -14,7 +14,6 @@ #include <netdev.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_pio.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_common.h> #include <asm/io.h>
diff --git a/board/atmel/at91rm9200ek/led.c b/board/atmel/at91rm9200ek/led.c index 6761b14..8b62035 100644 --- a/board/atmel/at91rm9200ek/led.c +++ b/board/atmel/at91rm9200ek/led.c @@ -12,7 +12,6 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/hardware.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pio.h> #include <status_led.h>
@@ -59,11 +58,9 @@ void red_led_off(void)
void coloured_LED_init (void) { - at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; at91_pio_t *pio = (at91_pio_t *)ATMEL_BASE_PIO;
- /* Enable PIOB clock */ - writel(1 << ATMEL_ID_PIOB, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOB);
/* Disable peripherals on LEDs */ writel(GREEN_LED | YELLOW_LED | RED_LED, &pio->piob.per); diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 7f14af1..98193bf 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -11,7 +11,7 @@ #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <atmel_mci.h>
@@ -70,11 +70,9 @@ static void at91sam9260ek_nand_hw_init(void) #ifdef CONFIG_MACB static void at91sam9260ek_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
- /* Enable EMAC clock */ - writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC0);
/* * Disable pull-up on: @@ -122,12 +120,9 @@ int board_mmc_init(bd_t *bd)
int board_early_init_f(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clocks for all PIOs */ - writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOC), - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC);
return 0; } diff --git a/board/atmel/at91sam9261ek/at91sam9261ek.c b/board/atmel/at91sam9261ek/at91sam9261ek.c index 5250474..7b7cd2c 100644 --- a/board/atmel/at91sam9261ek/at91sam9261ek.c +++ b/board/atmel/at91sam9261ek/at91sam9261ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9261_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> @@ -35,7 +34,6 @@ static void at91sam9261ek_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; unsigned long csa;
/* Enable CS3 */ @@ -74,7 +72,7 @@ static void at91sam9261ek_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(2), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOC);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -161,8 +159,6 @@ void lcd_disable(void)
static void at91sam9261ek_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_A_periph(AT91_PIN_PB1, 0); /* LCDHSYNC */ at91_set_A_periph(AT91_PIN_PB2, 0); /* LCDDOTCK */ at91_set_A_periph(AT91_PIN_PB3, 0); /* LCDDEN */ @@ -186,7 +182,7 @@ static void at91sam9261ek_lcd_hw_init(void) at91_set_B_periph(AT91_PIN_PB27, 0); /* LCDD22 */ at91_set_B_periph(AT91_PIN_PB28, 0); /* LCDD23 */
- writel(AT91_PMC_HCK1, &pmc->scer); + at91_system_clk_enable(AT91_PMC_HCK1);
/* For 9G10EK, let U-Boot allocate the framebuffer in SDRAM */ #ifdef CONFIG_AT91SAM9261EK diff --git a/board/atmel/at91sam9261ek/led.c b/board/atmel/at91sam9261ek/led.c index 18a68d8..485d7ea 100644 --- a/board/atmel/at91sam9261ek/led.c +++ b/board/atmel/at91sam9261ek/led.c @@ -8,17 +8,15 @@
#include <common.h> #include <asm/arch/at91sam9261.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> #include <asm/arch/at91_pio.h> +#include <asm/arch/clk.h> #include <asm/io.h>
void coloured_LED_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - /* Enable clock */ - writel(ATMEL_ID_PIOA, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA);
at91_set_gpio_output(CONFIG_RED_LED, 1); at91_set_gpio_output(CONFIG_GREEN_LED, 1); diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 927adb0..af68e10 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -11,7 +11,6 @@ #include <asm/arch/at91sam9263.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> @@ -39,7 +38,6 @@ static void at91sam9263ek_nand_hw_init(void) unsigned long csa; at91_smc_t *smc = (at91_smc_t *) ATMEL_BASE_SMC0; at91_matrix_t *matrix = (at91_matrix_t *) ATMEL_BASE_MATRIX; - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
/* Enable CS3 */ csa = readl(&matrix->csa[0]) | AT91_MATRIX_CSA_EBI_CS3A; @@ -68,8 +66,8 @@ static void at91sam9263ek_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(2), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOA | 1 << ATMEL_ID_PIOCDE, - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOCDE);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -82,11 +80,9 @@ static void at91sam9263ek_nand_hw_init(void) #ifdef CONFIG_MACB static void at91sam9263ek_macb_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO;
- /* Enable clock */ - writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC);
/* * Disable pull-up on: @@ -139,8 +135,6 @@ void lcd_disable(void)
static void at91sam9263ek_lcd_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDHSYNC */ at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* LCDDOTCK */ at91_set_a_periph(AT91_PIO_PORTC, 3, 0); /* LCDDEN */ @@ -164,7 +158,7 @@ static void at91sam9263ek_lcd_hw_init(void) at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDD22 */ at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDD23 */
- writel(1 << ATMEL_ID_LCDC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_LCDC); gd->fb_base = ATMEL_BASE_SRAM0; }
@@ -226,12 +220,9 @@ int board_mmc_init(bd_t *bd)
int board_early_init_f(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clocks for all PIOs */ - writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOCDE), - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOCDE);
at91_seriald_hw_init(); return 0; diff --git a/board/atmel/at91sam9263ek/led.c b/board/atmel/at91sam9263ek/led.c index e317d99..21d81de 100644 --- a/board/atmel/at91sam9263ek/led.c +++ b/board/atmel/at91sam9263ek/led.c @@ -9,16 +9,13 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/gpio.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91sam9263.h> +#include <asm/arch/clk.h>
void coloured_LED_init(void) { - /* Enable clock */ - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - - writel(1 << ATMEL_ID_PIOB | 1 << ATMEL_ID_PIOCDE, - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOB);
at91_set_gpio_output(CONFIG_RED_LED, 1); at91_set_gpio_output(CONFIG_GREEN_LED, 1); diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 2fea56f..b67fd76 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> @@ -36,7 +35,6 @@ void at91sam9m10g45ek_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; unsigned long csa;
/* Enable CS3 */ @@ -63,7 +61,7 @@ void at91sam9m10g45ek_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -130,13 +128,11 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
void mem_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct atmel_mpddr ddr2;
ddr2_conf(&ddr2);
- /* enable DDR2 clock */ - writel(AT91_PMC_DDR, &pmc->scer); + at91_system_clk_enable(AT91_PMC_DDR);
/* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_DDRSDRC0, ATMEL_BASE_CS6, &ddr2); @@ -146,9 +142,7 @@ void mem_init(void) #ifdef CONFIG_CMD_USB static void at91sam9m10g45ek_usb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - writel(1 << ATMEL_ID_PIODE, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIODE);
at91_set_gpio_output(AT91_PIN_PD1, 0); at91_set_gpio_output(AT91_PIN_PD3, 0); @@ -158,11 +152,9 @@ static void at91sam9m10g45ek_usb_hw_init(void) #ifdef CONFIG_MACB static void at91sam9m10g45ek_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
/* * Disable pull-up on: @@ -222,8 +214,6 @@ void lcd_disable(void)
static void at91sam9m10g45ek_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_A_periph(AT91_PIN_PE0, 0); /* LCDDPWR */ at91_set_A_periph(AT91_PIN_PE2, 0); /* LCDCC */ at91_set_A_periph(AT91_PIN_PE3, 0); /* LCDVSYNC */ @@ -255,7 +245,7 @@ static void at91sam9m10g45ek_lcd_hw_init(void) at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */
gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; } diff --git a/board/atmel/at91sam9m10g45ek/led.c b/board/atmel/at91sam9m10g45ek/led.c index fe98723..866052e 100644 --- a/board/atmel/at91sam9m10g45ek/led.c +++ b/board/atmel/at91sam9m10g45ek/led.c @@ -9,15 +9,12 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91sam9g45.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
void coloured_LED_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clock */ - writel(1 << ATMEL_ID_PIODE, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIODE);
at91_set_gpio_output(CONFIG_RED_LED, 1); at91_set_gpio_output(CONFIG_GREEN_LED, 1); diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index 59bc535..49e34b2 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -10,7 +10,6 @@ #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> @@ -208,9 +207,8 @@ void at91sam9n12ek_usb_hw_init(void)
int board_early_init_f(void) { - /* Enable clocks for all PIOs */ - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - writel((1 << ATMEL_ID_PIOAB) | (1 << ATMEL_ID_PIOCD), &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOAB); + at91_periph_clk_enable(ATMEL_ID_PIOCD);
at91_seriald_hw_init(); return 0; diff --git a/board/atmel/at91sam9rlek/at91sam9rlek.c b/board/atmel/at91sam9rlek/at91sam9rlek.c index f995cef..9ef2864 100644 --- a/board/atmel/at91sam9rlek/at91sam9rlek.c +++ b/board/atmel/at91sam9rlek/at91sam9rlek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9rl_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> @@ -36,7 +35,6 @@ static void at91sam9rlek_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; unsigned long csa;
/* Enable CS3 */ @@ -64,7 +62,7 @@ static void at91sam9rlek_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(2), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOD, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOD);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -106,8 +104,6 @@ void lcd_disable(void) } static void at91sam9rlek_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_B_periph(AT91_PIN_PC1, 0); /* LCDPWR */ at91_set_A_periph(AT91_PIN_PC5, 0); /* LCDHSYNC */ at91_set_A_periph(AT91_PIN_PC6, 0); /* LCDDOTCK */ @@ -130,7 +126,7 @@ static void at91sam9rlek_lcd_hw_init(void) at91_set_B_periph(AT91_PIN_PC24, 0); /* LCDD22 */ at91_set_B_periph(AT91_PIN_PC25, 0); /* LCDD23 */
#ifdef CONFIG_LCD_INFO @@ -174,12 +170,10 @@ int board_mmc_init(bd_t *bis)
int board_early_init_f(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clocks for all PIOs */ - writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOC) | (1 << ATMEL_ID_PIOD), - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC); + at91_periph_clk_enable(ATMEL_ID_PIOD);
return 0; } diff --git a/board/atmel/at91sam9rlek/led.c b/board/atmel/at91sam9rlek/led.c index fede59c..d593aba 100644 --- a/board/atmel/at91sam9rlek/led.c +++ b/board/atmel/at91sam9rlek/led.c @@ -8,16 +8,13 @@
#include <common.h> #include <asm/arch/at91sam9rl.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm/io.h>
void coloured_LED_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clock */ - writel(ATMEL_ID_PIOD, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOD);
at91_set_gpio_output(CONFIG_RED_LED, 1); at91_set_gpio_output(CONFIG_GREEN_LED, 1); diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 1738a2b..23ca71a 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -9,10 +9,9 @@ #include <asm/arch/at91sam9x5_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> -#include <asm/arch/gpio.h> #include <asm/arch/clk.h> +#include <asm/arch/gpio.h> #include <lcd.h> #include <atmel_hlcdc.h> #include <atmel_mci.h> @@ -39,7 +38,6 @@ static void at91sam9x5ek_nand_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; unsigned long csa;
/* Enable CS3 */ @@ -72,7 +70,7 @@ static void at91sam9x5ek_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(1), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOCD, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOCD);
/* Configure RDY/BSY */ at91_set_gpio_input(CONFIG_SYS_NAND_READY_PIN, 1); @@ -141,8 +139,6 @@ void lcd_disable(void)
static void at91sam9x5ek_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - if (has_lcdc()) { at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDPWM */ at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDVSYNC */ @@ -176,7 +172,7 @@ static void at91sam9x5ek_lcd_hw_init(void) at91_set_a_periph(AT91_PIO_PORTC, 22, 0); /* LCDD22 */ at91_set_a_periph(AT91_PIO_PORTC, 23, 0); /* LCDD23 */
- writel(1 << ATMEL_ID_LCDC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_LCDC); } }
diff --git a/board/atmel/sama5d2_xplained/sama5d2_xplained.c b/board/atmel/sama5d2_xplained/sama5d2_xplained.c index 0b3397f..241c165 100644 --- a/board/atmel/sama5d2_xplained/sama5d2_xplained.c +++ b/board/atmel/sama5d2_xplained/sama5d2_xplained.c @@ -15,7 +15,6 @@ #include <version.h> #include <asm/io.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/atmel_pio4.h> #include <asm/arch/atmel_usba_udc.h> #include <asm/arch/atmel_sdhci.h> diff --git a/board/atmel/sama5d3_xplained/sama5d3_xplained.c b/board/atmel/sama5d3_xplained/sama5d3_xplained.c index 7a01149..d180b41 100644 --- a/board/atmel/sama5d3_xplained/sama5d3_xplained.c +++ b/board/atmel/sama5d3_xplained/sama5d3_xplained.c @@ -184,14 +184,13 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
ddr2_conf(&ddr2);
- /* enable MPDDR clock */ + /* Enable MPDDR clock */ at91_periph_clk_enable(ATMEL_ID_MPDDRC); - writel(AT91_PMC_DDR, &pmc->scer); + at91_system_clk_enable(AT91_PMC_DDR);
/* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddr2); diff --git a/board/atmel/sama5d3xek/sama5d3xek.c b/board/atmel/sama5d3xek/sama5d3xek.c index 7c95f33..777e57e 100644 --- a/board/atmel/sama5d3xek/sama5d3xek.c +++ b/board/atmel/sama5d3xek/sama5d3xek.c @@ -443,14 +443,13 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
ddr2_conf(&ddr2);
/* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddr2); diff --git a/board/atmel/sama5d4_xplained/sama5d4_xplained.c b/board/atmel/sama5d4_xplained/sama5d4_xplained.c index db45331..e95310c 100644 --- a/board/atmel/sama5d4_xplained/sama5d4_xplained.c +++ b/board/atmel/sama5d4_xplained/sama5d4_xplained.c @@ -383,14 +383,13 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
ddr2_conf(&ddr2);
/* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddr2); diff --git a/board/atmel/sama5d4ek/sama5d4ek.c b/board/atmel/sama5d4ek/sama5d4ek.c index 357b223..c92e2588 100644 --- a/board/atmel/sama5d4ek/sama5d4ek.c +++ b/board/atmel/sama5d4ek/sama5d4ek.c @@ -379,14 +379,13 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
ddr2_conf(&ddr2);
/* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_MPDDRC, ATMEL_BASE_DDRCS, &ddr2); diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c index 95633b0..2d1a89e 100644 --- a/board/bluewater/snapper9260/snapper9260.c +++ b/board/bluewater/snapper9260/snapper9260.c @@ -15,7 +15,7 @@ #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm/arch/atmel_serial.h> #include <net.h> @@ -31,11 +31,9 @@ DECLARE_GLOBAL_DATA_PTR;
static void macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
- /* Enable clock */ - writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC0);
/* Disable pull-ups to prevent PHY going into test mode */ writel(pin_to_mask(AT91_PIN_PA14) | @@ -108,12 +106,9 @@ static void nand_hw_init(void)
int board_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable PIO clocks */ - writel((1 << ATMEL_ID_PIOA) | - (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOC), &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC);
/* The mach-type is the same for both Snapper 9260 and 9G20 */ gd->bd->bi_arch_number = MACH_TYPE_SNAPPER_9260; diff --git a/board/calao/usb_a9263/usb_a9263.c b/board/calao/usb_a9263/usb_a9263.c index 266e950..d627b24 100644 --- a/board/calao/usb_a9263/usb_a9263.c +++ b/board/calao/usb_a9263/usb_a9263.c @@ -12,7 +12,7 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_matrix.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm-generic/gpio.h> #include <asm/io.h> @@ -43,7 +43,6 @@ static void usb_a9263_nand_hw_init(void) unsigned long csa; at91_smc_t *smc = (at91_smc_t *)ATMEL_BASE_SMC0; at91_matrix_t *matrix = (at91_matrix_t *)ATMEL_BASE_MATRIX; - at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC;
/* Enable CS3 */ csa = readl(&matrix->csa[0]) | AT91_MATRIX_CSA_EBI_CS3A; @@ -66,7 +65,8 @@ static void usb_a9263_nand_hw_init(void) AT91_SMC_MODE_DBW_8 | AT91_SMC_MODE_TDF_CYCLE(2), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOA | 1 << ATMEL_ID_PIOCDE, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOCDE);
/* Configure RDY/BSY */ gpio_request(CONFIG_SYS_NAND_READY_PIN, "NAND ready/busy"); @@ -81,10 +81,7 @@ static void usb_a9263_nand_hw_init(void) #ifdef CONFIG_MACB static void usb_a9263_macb_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC; - - /* Enable clock */ - writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC);
/* * Disable pull-up on: diff --git a/board/egnite/ethernut5/ethernut5.c b/board/egnite/ethernut5/ethernut5.c index 67d3984..2c8e978 100644 --- a/board/egnite/ethernut5/ethernut5.c +++ b/board/egnite/ethernut5/ethernut5.c @@ -67,8 +67,8 @@ #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_spi.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm/io.h> #include <asm/gpio.h> @@ -151,12 +151,10 @@ static void ethernut5_nand_hw_init(void) */ int board_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC);
- /* Enable clocks for all PIOs */ - writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOC), - &pmc->pcer); /* Set adress of boot parameters. */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; /* Initialize UARTs and power management. */ @@ -179,10 +177,9 @@ int board_eth_init(bd_t *bis) { const char *devname; unsigned short mode; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- /* Enable on-chip EMAC clock. */ - writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC0); + /* Need to reset PHY via power management. */ ethernut5_phy_reset(); /* Set peripheral pins. */ @@ -211,10 +208,8 @@ int board_eth_init(bd_t *bis) #ifdef CONFIG_GENERIC_ATMEL_MCI int board_mmc_init(bd_t *bd) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + at91_periph_clk_enable(ATMEL_ID_MCI);
- /* Enable MCI clock. */ - writel(1 << ATMEL_ID_MCI, &pmc->pcer); /* Initialize MCI hardware. */ at91_mci_hw_init(); /* Register the device. */ @@ -229,6 +224,7 @@ int board_mmc_getcd(struct mmc *mmc)
#ifdef CONFIG_ATMEL_SPI /* + * Note, that u-boot uses different code for SPI bus access. While * memory routines use automatic chip select control, the serial * flash support requires 'manual' GPIO control. Thus, we switch diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index b7f9f90..fe781dc 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -87,9 +87,8 @@ static void meesc_nand_hw_init(void) #ifdef CONFIG_MACB static void meesc_macb_hw_init(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - /* Enable clock */ - writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC); + at91_macb_hw_init(); } #endif @@ -244,12 +243,10 @@ int misc_init_r(void)
int board_early_init_f(void) { - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - - /* enable all clocks */ - writel((1 << ATMEL_ID_PIOA) | (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOCDE) | (1 << ATMEL_ID_UHP), - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOCDE); + at91_periph_clk_enable(ATMEL_ID_UHP);
diff --git a/board/mini-box/picosam9g45/led.c b/board/mini-box/picosam9g45/led.c index dc1013a..3fb6a7b 100644 --- a/board/mini-box/picosam9g45/led.c +++ b/board/mini-box/picosam9g45/led.c @@ -9,15 +9,12 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/at91sam9g45.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
diff --git a/board/mini-box/picosam9g45/picosam9g45.c b/board/mini-box/picosam9g45/picosam9g45.c index afbd6ce..b768fbf 100644 --- a/board/mini-box/picosam9g45/picosam9g45.c +++ b/board/mini-box/picosam9g45/picosam9g45.c @@ -17,7 +17,6 @@ #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> @@ -80,15 +79,13 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
void mem_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_matrix *mat = (struct at91_matrix *)ATMEL_BASE_MATRIX; struct atmel_mpddr ddr2; unsigned long csa;
ddr2_conf(&ddr2);
/* Chip select 1 is for DDR2/SDRAM */ csa = readl(&mat->ebicsa); @@ -105,9 +102,7 @@ void mem_init(void) #ifdef CONFIG_CMD_USB static void picosam9g45_usb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - writel(1 << ATMEL_ID_PIODE, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIODE);
at91_set_gpio_output(AT91_PIN_PD1, 0); at91_set_gpio_output(AT91_PIN_PD3, 0); @@ -117,11 +112,9 @@ static void picosam9g45_usb_hw_init(void) #ifdef CONFIG_MACB static void picosam9g45_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA;
/* * Disable pull-up on: @@ -181,8 +174,6 @@ void lcd_disable(void)
static void picosam9g45_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_A_periph(AT91_PIN_PE0, 0); /* LCDDPWR */ at91_set_A_periph(AT91_PIN_PE2, 0); /* LCDCC */ at91_set_A_periph(AT91_PIN_PE3, 0); /* LCDVSYNC */ @@ -214,7 +205,7 @@ static void picosam9g45_lcd_hw_init(void) at91_set_A_periph(AT91_PIN_PE29, 0); /* LCDD22 */ at91_set_A_periph(AT91_PIN_PE30, 0); /* LCDD23 */
gd->fb_base = CONFIG_AT91SAM9G45_LCD_BASE; } diff --git a/board/ronetix/pm9261/led.c b/board/ronetix/pm9261/led.c index cc4c2a0..53e353a 100644 --- a/board/ronetix/pm9261/led.c +++ b/board/ronetix/pm9261/led.c @@ -9,15 +9,12 @@
#include <common.h> #include <asm/gpio.h> -#include <asm/arch/at91_pmc.h> +#include <asm/arch/clk.h> #include <asm/arch/gpio.h>
void coloured_LED_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clock */ - writel(1 << ATMEL_ID_PIOC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOC);
gpio_direction_output(CONFIG_RED_LED, 1); gpio_direction_output(CONFIG_GREEN_LED, 1); diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index b96f745..e709c45 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -14,7 +14,6 @@ #include <asm/gpio.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/clk.h> @@ -41,7 +40,6 @@ static void pm9261_nand_hw_init(void) unsigned long csa; struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* Enable CS3 */ csa = readl(&matrix->csa) | AT91_MATRIX_CSA_EBI_CS3A; @@ -69,9 +67,8 @@ static void pm9261_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(2), &smc->cs[3].mode);
- writel(1 << ATMEL_ID_PIOA | - 1 << ATMEL_ID_PIOC, - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOC);
/* Configure RDY/BSY */ gpio_direction_input(CONFIG_SYS_NAND_READY_PIN); @@ -89,7 +86,6 @@ static void pm9261_nand_hw_init(void) static void pm9261_dm9000_hw_init(void) { struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* Configure SMC CS2 for DM9000 */ writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | @@ -110,7 +106,7 @@ static void pm9261_dm9000_hw_init(void) &smc->cs[2].mode);
/* Configure Interrupt pin as input, no pull-up */ - writel(1 << ATMEL_ID_PIOA, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); at91_set_pio_input(AT91_PIO_PORTA, 24, 0); } #endif @@ -145,8 +141,6 @@ void lcd_disable(void)
static void pm9261_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTB, 1, 0); /* LCDHSYNC */ at91_set_a_periph(AT91_PIO_PORTB, 2, 0); /* LCDDOTCK */ at91_set_a_periph(AT91_PIO_PORTB, 3, 0); /* LCDDEN */ @@ -170,7 +164,7 @@ static void pm9261_lcd_hw_init(void) at91_set_b_periph(AT91_PIO_PORTB, 27, 0); /* LCDD22 */ at91_set_b_periph(AT91_PIO_PORTB, 28, 0); /* LCDD23 */
- writel(1 << 17, &pmc->scer); /* LCD controller Clock, AT91SAM9261 only */ + at91_system_clk_enable(AT91_PMC_HCK1); /* LCD controller Clock, AT91SAM9261 only */
gd->fb_base = ATMEL_BASE_SRAM; } @@ -224,12 +218,8 @@ void lcd_show_board_info(void)
int board_early_init_f(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clocks for some PIOs */ - writel(1 << ATMEL_ID_PIOA | - 1 << ATMEL_ID_PIOC, - &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOC);
diff --git a/board/ronetix/pm9263/led.c b/board/ronetix/pm9263/led.c index bfc2310..8025a20 100644 --- a/board/ronetix/pm9263/led.c +++ b/board/ronetix/pm9263/led.c @@ -9,15 +9,12 @@
void coloured_LED_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clock */ - writel(1 << ATMEL_ID_PIOB, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOB);
gpio_direction_output(CONFIG_RED_LED, 1); gpio_direction_output(CONFIG_GREEN_LED, 1); diff --git a/board/ronetix/pm9263/pm9263.c b/board/ronetix/pm9263/pm9263.c index 1b00f08..276ff80 100644 --- a/board/ronetix/pm9263/pm9263.c +++ b/board/ronetix/pm9263/pm9263.c @@ -14,7 +14,6 @@ #include <asm/gpio.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/clk.h> @@ -78,8 +77,6 @@ static void pm9263_nand_hw_init(void) #ifdef CONFIG_MACB static void pm9263_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - /* * PB27 enables the 50MHz oscillator for Ethernet PHY * 1 - enable @@ -88,8 +85,7 @@ static void pm9263_macb_hw_init(void) at91_set_pio_output(AT91_PIO_PORTB, 27, 1); at91_set_pio_value(AT91_PIO_PORTB, 27, 1); /* 1- enable, 0 - disable */
/* * Disable pull-up on: @@ -231,8 +227,6 @@ static int pm9263_lcd_hw_psram_init(void)
static void pm9263_lcd_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - at91_set_a_periph(AT91_PIO_PORTC, 0, 0); /* LCDVSYNC */ at91_set_a_periph(AT91_PIO_PORTC, 1, 0); /* LCDHSYNC */ at91_set_a_periph(AT91_PIO_PORTC, 2, 0); /* LCDDOTCK */ @@ -257,7 +251,7 @@ static void pm9263_lcd_hw_init(void) at91_set_a_periph(AT91_PIO_PORTC, 26, 0); /* LCDD22 */ at91_set_a_periph(AT91_PIO_PORTC, 27, 0); /* LCDD23 */
/* Power Control */ at91_set_pio_output(AT91_PIO_PORTA, 22, 1); @@ -323,12 +317,9 @@ void lcd_show_board_info(void)
diff --git a/board/ronetix/pm9g45/pm9g45.c b/board/ronetix/pm9g45/pm9g45.c index efc4133..c2707e0 100644 --- a/board/ronetix/pm9g45/pm9g45.c +++ b/board/ronetix/pm9g45/pm9g45.c @@ -17,7 +17,6 @@ #include <asm/gpio.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/gpio.h> @@ -39,7 +38,6 @@ static void pm9g45_nand_hw_init(void) unsigned long csa; struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; struct at91_matrix *matrix = (struct at91_matrix *)ATMEL_BASE_MATRIX; - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
/* Enable CS3 */ csa = readl(&matrix->ccr[6]) | AT91_MATRIX_CSA_EBI_CS3A; @@ -63,7 +61,7 @@ static void pm9g45_nand_hw_init(void) AT91_SMC_MODE_TDF_CYCLE(3), &smc->cs[3].mode);
#ifdef CONFIG_SYS_NAND_READY_PIN /* Configure RDY/BSY */ @@ -78,8 +76,6 @@ static void pm9g45_nand_hw_init(void) #ifdef CONFIG_MACB static void pm9g45_macb_hw_init(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - /* * PD2 enables the 50MHz oscillator for Ethernet PHY * 1 - enable @@ -88,8 +84,7 @@ static void pm9g45_macb_hw_init(void) at91_set_pio_output(AT91_PIO_PORTD, 2, 1); at91_set_pio_value(AT91_PIO_PORTD, 2, 1); /* 1- enable, 0 - disable */
/* * Disable pull-up on: @@ -114,13 +109,10 @@ static void pm9g45_macb_hw_init(void)
int board_early_init_f(void) { - struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; - - /* Enable clocks for all PIOs */ - writel((1 << ATMEL_ID_PIOA) | - (1 << ATMEL_ID_PIOB) | - (1 << ATMEL_ID_PIOC) | - (1 << ATMEL_ID_PIODE), &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_PIOA); + at91_periph_clk_enable(ATMEL_ID_PIOB); + at91_periph_clk_enable(ATMEL_ID_PIOC); + at91_periph_clk_enable(ATMEL_ID_PIODE);
diff --git a/board/siemens/corvus/board.c b/board/siemens/corvus/board.c index 28985b8..8729fe9 100644 --- a/board/siemens/corvus/board.c +++ b/board/siemens/corvus/board.c @@ -17,7 +17,6 @@ #include <asm/arch/at91sam9g45_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> @@ -147,13 +146,11 @@ static void ddr2_conf(struct atmel_mpddr *ddr2)
ddr2_conf(&ddr2);
/* DDRAM2 Controller initialize */ ddr2_init(ATMEL_BASE_DDRSDRC0, ATMEL_BASE_CS6, &ddr2); @@ -214,6 +211,7 @@ void at91_udp_hw_init(void)
/* Enable UPLL clock */ writel(AT91_PMC_UPLLEN | AT91_PMC_BIASEN, &pmc->uckr); + /* Enable UDPHS clock */ at91_periph_clk_enable(ATMEL_ID_UDPHS); } diff --git a/board/siemens/smartweb/smartweb.c b/board/siemens/smartweb/smartweb.c index d82f1b7..e7ee65c 100644 --- a/board/siemens/smartweb/smartweb.c +++ b/board/siemens/smartweb/smartweb.c @@ -22,7 +22,6 @@ #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_spi.h> #include <spi.h> #include <asm/arch/clk.h> @@ -126,7 +125,7 @@ void at91_udp_hw_init(void) /* Enable UDPCK clock, MCK is enabled in at91_clock_init() */ at91_periph_clk_enable(ATMEL_ID_UDP);
- writel(AT91SAM926x_PMC_UDP, &pmc->scer); + at91_system_clk_enable(AT91SAM926x_PMC_UDP); }
struct at91_udc_data board_udc_data = { diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 72c5e60..9374064 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -18,7 +18,6 @@ #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/at91sam9_sdramc.h> @@ -300,7 +299,7 @@ void at91_udp_hw_init(void) /* Enable UDPCK clock, MCK is enabled in at91_clock_init() */ at91_periph_clk_enable(ATMEL_ID_UDP);
Hello Wenyou,
Am 09.12.2015 um 04:45 schrieb Wenyou Yang:
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com
Sorry this patch has checkpatcherrors:
2015-12-09 07:49:38,661: hs@pollux [ 7:49:38] ttbott > 2015-12-09 07:49:39,790: wget http://patchwork.ozlabs.org/patch/554219/mbox 2015-12-09 07:49:39,791: --2015-12-09 07:49:39-- http://patchwork.ozlabs.org/patch/554219/mbox 2015-12-09 07:49:39,791: Resolving patchwork.ozlabs.org (patchwork.ozlabs.org)... 103.22.144.67, 2401:3900:2:1::2 2015-12-09 07:49:40,106: Connecting to patchwork.ozlabs.org (patchwork.ozlabs.org)|103.22.144.67|:80... connected. 2015-12-09 07:49:40,420: HTTP request sent, awaiting response... 301 MOVED PERMANENTLY 2015-12-09 07:49:40,421: Location: http://patchwork.ozlabs.org/patch/554219/mbox/ [following] 2015-12-09 07:49:40,421: --2015-12-09 07:49:40-- http://patchwork.ozlabs.org/patch/554219/mbox/ 2015-12-09 07:49:40,421: Reusing existing connection to patchwork.ozlabs.org:80. 2015-12-09 07:49:40,786: HTTP request sent, awaiting response... 200 OK 2015-12-09 07:49:40,786: Length: unspecified [text/plain] 2015-12-09 07:49:40,786: Saving to: ‘mbox’ 2015-12-09 07:49:40,786: 2015-12-09 07:49:40,787: 2015-12-09 07:49:41,101: mbox [<=> ] 0 --.-KB/s 2015-12-09 07:49:41,133: mbox [ <=> ] 15.15K 45.0KB/s 2015-12-09 07:49:41,134: mbox [ <=> ] 41.60K 111KB/s in 0.4s 2015-12-09 07:49:41,134: 2015-12-09 07:49:41,134: 2015-12-09 07:49:41 (111 KB/s) - ‘mbox’ saved [42603] 2015-12-09 07:49:41,134: 2015-12-09 07:49:41,134: hs@pollux [ 7:49:41] ttbott > 2015-12-09 07:49:42,235: if [ $? -ne 0 ]; then echo 'FAILED'; fi 2015-12-09 07:49:42,235: hs@pollux [ 7:49:42] ttbott > 2015-12-09 07:49:43,333: scripts/checkpatch.pl mbox 2015-12-09 07:49:43,698: WARNING: line over 80 characters 2015-12-09 07:49:43,698: #1029: FILE: board/ronetix/pm9261/pm9261.c:167: 2015-12-09 07:49:43,699: + at91_system_clk_enable(AT91_PMC_HCK1); /* LCD controller Clock, AT91SAM9261 only */ 2015-12-09 07:49:43,699: 2015-12-09 07:49:43,699: total: 0 errors, 1 warnings, 0 checks, 1000 lines checked 2015-12-09 07:49:43,699: 2015-12-09 07:49:43,699: NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE NETWORKING_BLOCK_COMMENT_STYLE USLEEP_RANGE 2015-12-09 07:49:43,700: 2015-12-09 07:49:43,700: mbox has style problems, please review. 2015-12-09 07:49:43,700: 2015-12-09 07:49:43,700: If any of these errors are false positives, please report 2015-12-09 07:49:43,700: them to the maintainer, see CHECKPATCH in MAINTAINERS. 2015-12-09 07:49:43,701: hs@pollux [ 7:49:43] ttbott >
bye, Heiko
Hello Heiko,
Thank you for your review.
-----Original Message----- From: Heiko Schocher [mailto:hs@denx.de] Sent: 2015年12月9日 14:56 To: Yang, Wenyou Wenyou.Yang@atmel.com Cc: U-Boot Mailing List u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 4/5] board: atmel: clean up peripheral clock code
Hello Wenyou,
Fix it in the next version. Thanks
bye, Heiko -- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany
Best Regards, Wenyou Yang
Due to introducing the new peripheral clock handle functions, use these functions to reduce the duplicated code.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
drivers/net/at91_emac.c | 9 ++++----- drivers/usb/host/ehci-atmel.c | 8 -------- drivers/usb/host/ohci-at91.c | 20 ++++---------------- 3 files changed, 8 insertions(+), 29 deletions(-)
diff --git a/drivers/net/at91_emac.c b/drivers/net/at91_emac.c index d51e098..bb6866d 100644 --- a/drivers/net/at91_emac.c +++ b/drivers/net/at91_emac.c @@ -12,7 +12,6 @@ #include <asm/io.h> #include <asm/arch/hardware.h> #include <asm/arch/at91_emac.h> -#include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pio.h> #include <net.h> #include <netdev.h> @@ -321,7 +320,6 @@ static int at91emac_init(struct eth_device *netdev, bd_t *bd) emac_device *dev; at91_emac_t *emac; at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC;
emac = (at91_emac_t *) netdev->iobase; dev = (emac_device *) netdev->priv; @@ -347,7 +345,8 @@ static int at91emac_init(struct eth_device *netdev, bd_t *bd) writel(value, &pio->piob.pdr); writel(value, &pio->piob.bsr);
- writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC); + writel(readl(&emac->ctl) | AT91_EMAC_CTL_CSR, &emac->ctl);
/* Init Ethernet buffers */ @@ -452,10 +451,10 @@ static int at91emac_recv(struct eth_device *netdev) static int at91emac_write_hwaddr(struct eth_device *netdev) { at91_emac_t *emac; - at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; emac = (at91_emac_t *) netdev->iobase;
- writel(1 << ATMEL_ID_EMAC, &pmc->pcer); + at91_periph_clk_enable(ATMEL_ID_EMAC); + debug_cond(DEBUG_AT91EMAC, "init MAC-ADDR %02x:%02x:%02x:%02x:%02x:%02x\n", netdev->enetaddr[5], netdev->enetaddr[4], netdev->enetaddr[3], diff --git a/drivers/usb/host/ehci-atmel.c b/drivers/usb/host/ehci-atmel.c index 9a8f004..a33fb49 100644 --- a/drivers/usb/host/ehci-atmel.c +++ b/drivers/usb/host/ehci-atmel.c @@ -40,11 +40,7 @@ int ehci_hcd_init(int index, enum usb_init_type init, }
/* Enable USB Host clock */ -#ifdef CPU_HAS_PCR at91_periph_clk_enable(ATMEL_ID_UHPHS); -#else - writel(1 << ATMEL_ID_UHPHS, &pmc->pcer); -#endif
*hccr = (struct ehci_hccr *)ATMEL_BASE_EHCI; *hcor = (struct ehci_hcor *)((uint32_t)*hccr + @@ -59,11 +55,7 @@ int ehci_hcd_stop(int index) ulong start_time, tmp_time;
/* Disable USB Host Clock */ -#ifdef CPU_HAS_PCR at91_periph_clk_disable(ATMEL_ID_UHPHS); -#else - writel(1 << ATMEL_ID_UHPHS, &pmc->pcdr); -#endif
start_time = get_timer(0); /* Disable UTMI PLL */ diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 820e2e5..da85111 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -37,17 +37,11 @@ int usb_cpu_init(void) writel(AT91_PMC_USBS_USB_UPLL | AT91_PMC_USBDIV_10, &pmc->usb); #endif
- /* Enable USB host clock. */ -#ifdef CPU_HAS_PCR at91_periph_clk_enable(ATMEL_ID_UHP); -#else - writel(1 << ATMEL_ID_UHP, &pmc->pcer); -#endif
+ at91_system_clk_enable(ATMEL_PMC_UHP); #if defined(CONFIG_AT91SAM9261) || defined(CONFIG_AT91SAM9G10) - writel(ATMEL_PMC_UHP | AT91_PMC_HCK0, &pmc->scer); -#else - writel(ATMEL_PMC_UHP, &pmc->scer); + at91_system_clk_enable(AT91_PMC_HCK0); #endif
return 0; @@ -57,17 +51,11 @@ int usb_cpu_stop(void) { at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC;
- /* Disable USB host clock. */ -#ifdef CPU_HAS_PCR at91_periph_clk_disable(ATMEL_ID_UHP); -#else - writel(1 << ATMEL_ID_UHP, &pmc->pcdr); -#endif
+ at91_system_clk_disable(ATMEL_PMC_UHP); #if defined(CONFIG_AT91SAM9261) || defined(CONFIG_AT91SAM9G10) - writel(ATMEL_PMC_UHP | AT91_PMC_HCK0, &pmc->scdr); -#else - writel(ATMEL_PMC_UHP, &pmc->scdr); + at91_system_clk_disable(AT91_PMC_HCK0); #endif
#ifdef CONFIG_USB_ATMEL_CLK_SEL_PLLB
Heiko Schocher
Wenyou Yang
Yang, Wenyou
