[U-Boot] [PATCH] USB: Ethernet: asix.c: Added support for AX88178 based devices
Completed command definitions copied from linux driver source. Implemented support for AX88178 by copying and rewriting bits and pieces from the linux asix driver.
Signed-off-by: David Jander david@protonic.nl --- drivers/usb/eth/asix.c | 236 +++++++++++++++++++++++++++++++++++++++++++++--- include/usb_ether.h | 1 + 2 files changed, 224 insertions(+), 13 deletions(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index 9b012e4..cecbc76 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -24,6 +24,8 @@ #include <linux/mii.h> #include "usb_ether.h"
+#define ASIX_MODEL_AX88772 0 +#define ASIX_MODEL_AX88178 1
/* ASIX AX8817X based USB 2.0 Ethernet Devices */
@@ -31,14 +33,29 @@ #define AX_CMD_READ_MII_REG 0x07 #define AX_CMD_WRITE_MII_REG 0x08 #define AX_CMD_SET_HW_MII 0x0a +#define AX_CMD_READ_EEPROM 0x0b +#define AX_CMD_WRITE_EEPROM 0x0c +#define AX_CMD_WRITE_ENABLE 0x0d +#define AX_CMD_WRITE_DISABLE 0x0e #define AX_CMD_READ_RX_CTL 0x0f #define AX_CMD_WRITE_RX_CTL 0x10 +#define AX_CMD_READ_IPG012 0x11 #define AX_CMD_WRITE_IPG0 0x12 +#define AX_CMD_WRITE_IPG1 0x13 #define AX_CMD_READ_NODE_ID 0x13 +#define AX_CMD_WRITE_NODE_ID 0x14 +#define AX_CMD_WRITE_IPG2 0x14 +#define AX_CMD_WRITE_MULTI_FILTER 0x16 +#define AX88172_CMD_READ_NODE_ID 0x17 #define AX_CMD_READ_PHY_ID 0x19 +#define AX_CMD_READ_MEDIUM_STATUS 0x1a #define AX_CMD_WRITE_MEDIUM_MODE 0x1b +#define AX_CMD_READ_MONITOR_MODE 0x1c +#define AX_CMD_WRITE_MONITOR_MODE 0x1d +#define AX_CMD_READ_GPIOS 0x1e #define AX_CMD_WRITE_GPIOS 0x1f #define AX_CMD_SW_RESET 0x20 +#define AX_CMD_SW_PHY_STATUS 0x21 #define AX_CMD_SW_PHY_SELECT 0x22
#define AX_SWRESET_CLEAR 0x00 @@ -83,6 +100,10 @@ (AX_RX_CTL_SO | AX_RX_CTL_AB)
/* GPIO 2 toggles */ +#define AX_GPIO_GPO0EN 0x01 /* GPIO0 Output enable */ +#define AX_GPIO_GPO_0 0x02 /* GPIO0 Output value */ +#define AX_GPIO_GPO1EN 0x04 /* GPIO1 Output enable */ +#define AX_GPIO_GPO_1 0x08 /* GPIO1 Output value */ #define AX_GPIO_GPO2EN 0x10 /* GPIO2 Output enable */ #define AX_GPIO_GPO_2 0x20 /* GPIO2 Output value */ #define AX_GPIO_RSE 0x80 /* Reload serial EEPROM */ @@ -310,7 +331,7 @@ static int mii_nway_restart(struct ueth_data *dev) /* * Asix callbacks */ -static int asix_init(struct eth_device *eth, bd_t *bd) +static int asix_init_ax88772(struct eth_device *eth, bd_t *bd) { int embd_phy; unsigned char buf[ETH_ALEN]; @@ -419,6 +440,190 @@ out_err: return -1; }
+/** + * mii_check_media - check the MII interface for a duplex change + * @mii: the MII interface + * @ok_to_print: OK to print link up/down messages + * @init_media: OK to save duplex mode in @mii + * + * Returns 1 if the duplex mode changed, 0 if not. + * If the media type is forced, always returns 0. + */ +unsigned int mii_check_media (struct eth_device *eth, + unsigned int ok_to_print, + unsigned int init_media) +{ + int advertise, lpa, media, duplex; + int lpa2 = 0; + struct ueth_data *dev = (struct ueth_data *)eth->priv; + + /* get MII advertise and LPA values */ + advertise = asix_mdio_read(dev, dev->phy_id, MII_ADVERTISE); + lpa = asix_mdio_read(dev, dev->phy_id, MII_LPA); + lpa2 = asix_mdio_read(dev, dev->phy_id, MII_STAT1000); + + /* figure out media and duplex from advertise and LPA values */ + media = mii_nway_result(lpa & advertise); + duplex = (media & ADVERTISE_FULL) ? 1 : 0; + if (lpa2 & LPA_1000FULL) + duplex = 1; + + printf("link up, %uMbps, %s-duplex, lpa 0x%04X\n", + lpa2 & (LPA_1000FULL | LPA_1000HALF) ? 1000 : + media & (ADVERTISE_100FULL | ADVERTISE_100HALF) ? + 100 : 10, + duplex ? "full" : "half", + lpa); + + return 0; /* duplex did not change */ +} + +static int ax88178_link_reset(struct eth_device *eth) +{ + u16 mode; + struct ueth_data *dev = (struct ueth_data *)eth->priv; + + debug("ax88178_link_reset()\n"); + + mii_check_media(eth, 1, 1); + mode = AX88178_MEDIUM_DEFAULT; + + /* All supported ax88178 dongles have GMII */ + mode |= AX_MEDIUM_GM; + mode |= AX_MEDIUM_ENCK; + mode |= AX_MEDIUM_FD; + + asix_write_medium_mode(dev, mode); + + return 0; +} + +static int asix_init_ax88178(struct eth_device *eth, bd_t *bd) +{ + unsigned char buf[ETH_ALEN]; + int phymode, ledmode; + int gpio0 = 0; + u8 status; + __le16 eeprom; + struct ueth_data *dev = (struct ueth_data *)eth->priv; + int timeout = 0; +#define TIMEOUT_RESOLUTION 50 /* ms */ + int link_detected; + + debug("** %s()\n", __func__); + + asix_read_cmd(dev, AX_CMD_READ_GPIOS, 0, 0, 1, &status); + debug("GPIO Status: 0x%04x\n", status); + + asix_write_cmd(dev, AX_CMD_WRITE_ENABLE, 0, 0, 0, NULL); + asix_read_cmd(dev, AX_CMD_READ_EEPROM, 0x0017, 0, 2, &eeprom); + asix_write_cmd(dev, AX_CMD_WRITE_DISABLE, 0, 0, 0, NULL); + + debug("EEPROM index 0x17 is 0x%04x\n", eeprom); + if (eeprom == cpu_to_le16(0xffff)) { + printf("Error: Marvell phy not supported\n"); + return -1; + } else { + phymode = le16_to_cpu(eeprom) & 7; + ledmode = le16_to_cpu(eeprom) >> 8; + gpio0 = (le16_to_cpu(eeprom) & 0x80) ? 0 : 1; + } + debug("GPIO0: %d, PhyMode: %d\n", gpio0, phymode); + + asix_write_gpio(dev, AX_GPIO_RSE | AX_GPIO_GPO_1 | AX_GPIO_GPO1EN, 40); + if ((le16_to_cpu(eeprom) >> 8) != 1) { + asix_write_gpio(dev, 0x003c, 30); + asix_write_gpio(dev, 0x001c, 300); + asix_write_gpio(dev, 0x003c, 30); + } else { + debug("gpio phymode == 1 path\n"); + asix_write_gpio(dev, AX_GPIO_GPO1EN, 30); + asix_write_gpio(dev, AX_GPIO_GPO1EN | AX_GPIO_GPO_1, 30); + } + + asix_sw_reset(dev, 0); + udelay(150000); + + asix_sw_reset(dev, AX_SWRESET_PRL | AX_SWRESET_IPPD); + udelay(150000); + + asix_write_rx_ctl(dev, 0); + + /* Get the MAC address */ + if (asix_read_cmd(dev, AX_CMD_READ_NODE_ID, + 0, 0, ETH_ALEN, buf) < 0) { + debug("Failed to read MAC address.\n"); + goto out_err; + } + memcpy(eth->enetaddr, buf, ETH_ALEN); + debug("MAC %02x:%02x:%02x:%02x:%02x:%02x\n", + eth->enetaddr[0], eth->enetaddr[1], + eth->enetaddr[2], eth->enetaddr[3], + eth->enetaddr[4], eth->enetaddr[5]); + + dev->phy_id = asix_get_phy_addr(dev); + if (dev->phy_id < 0) + debug("Failed to read phy id\n"); + + asix_mdio_write(dev, dev->phy_id, MII_BMCR, + BMCR_RESET | BMCR_ANENABLE); + asix_mdio_write(dev, dev->phy_id, MII_ADVERTISE, + ADVERTISE_ALL | ADVERTISE_CSMA | ADVERTISE_PAUSE_CAP); + asix_mdio_write(dev, dev->phy_id, MII_CTRL1000, + ADVERTISE_1000FULL); + + mii_nway_restart(dev); + + if (asix_write_medium_mode(dev, AX88178_MEDIUM_DEFAULT) < 0) + goto out_err; + + if (asix_write_rx_ctl(dev, AX_DEFAULT_RX_CTL) < 0) + goto out_err; + + do { + link_detected = asix_mdio_read(dev, dev->phy_id, MII_BMSR) & + BMSR_LSTATUS; + if (!link_detected) { + if (timeout == 0) + printf("Waiting for Ethernet connection... "); + udelay(TIMEOUT_RESOLUTION * 1000); + timeout += TIMEOUT_RESOLUTION; + } + } while (!link_detected && timeout < PHY_CONNECT_TIMEOUT); + if (link_detected) { + if (timeout != 0) + printf("done.\n"); + } else { + printf("unable to connect.\n"); + goto out_err; + } + + udelay(50000); + ax88178_link_reset(eth); + udelay(50000); + + return 0; +out_err: + return -1; +} + +static int asix_init(struct eth_device *eth, bd_t *bd) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + + switch (dev->asix_model) { + case ASIX_MODEL_AX88772 : + return asix_init_ax88772(eth, bd); + break; + case ASIX_MODEL_AX88178 : + return asix_init_ax88178(eth, bd); + break; + default: + printf("Unsupported asix model!\n"); + return -1; + } +} + static int asix_send(struct eth_device *eth, volatile void *packet, int length) { struct ueth_data *dev = (struct ueth_data *)eth->priv; @@ -530,19 +735,21 @@ void asix_eth_before_probe(void) struct asix_dongle { unsigned short vendor; unsigned short product; + unsigned int asix_model; };
static struct asix_dongle asix_dongles[] = { - { 0x05ac, 0x1402 }, /* Apple USB Ethernet Adapter */ - { 0x07d1, 0x3c05 }, /* D-Link DUB-E100 H/W Ver B1 */ - { 0x0b95, 0x772a }, /* Cables-to-Go USB Ethernet Adapter */ - { 0x0b95, 0x7720 }, /* Trendnet TU2-ET100 V3.0R */ - { 0x0b95, 0x1720 }, /* SMC */ - { 0x0db0, 0xa877 }, /* MSI - ASIX 88772a */ - { 0x13b1, 0x0018 }, /* Linksys 200M v2.1 */ - { 0x1557, 0x7720 }, /* 0Q0 cable ethernet */ - { 0x2001, 0x3c05 }, /* DLink DUB-E100 H/W Ver B1 Alternate */ - { 0x0000, 0x0000 } /* END - Do not remove */ + { 0x05ac, 0x1402, ASIX_MODEL_AX88772 }, /* Apple USB Ethernet Adapter */ + { 0x07d1, 0x3c05, ASIX_MODEL_AX88772 }, /* D-Link DUB-E100 H/W Ver B1 */ + { 0x0b95, 0x772a, ASIX_MODEL_AX88772 }, /* Cables-to-Go USB Ethernet Adapter */ + { 0x0b95, 0x7720, ASIX_MODEL_AX88772 }, /* Trendnet TU2-ET100 V3.0R */ + { 0x0b95, 0x1720, ASIX_MODEL_AX88772 }, /* SMC FIXME: isn't this AX88178? */ + { 0x0db0, 0xa877, ASIX_MODEL_AX88772 }, /* MSI - ASIX 88772a */ + { 0x13b1, 0x0018, ASIX_MODEL_AX88772 }, /* Linksys 200M v2.1 */ + { 0x1557, 0x7720, ASIX_MODEL_AX88772 }, /* 0Q0 cable ethernet */ + { 0x2001, 0x3c05, ASIX_MODEL_AX88772 }, /* DLink DUB-E100 H/W Ver B1 Alternate */ + { 0x050d, 0x5055, ASIX_MODEL_AX88178 }, /* Belkin F5D5055 Gig USB */ + { 0x0000, 0x0000, 0 } /* END - Do not remove */ };
/* Probe to see if a new device is actually an asix device */ @@ -569,9 +776,12 @@ int asix_eth_probe(struct usb_device *dev, unsigned int ifnum,
memset(ss, 0, sizeof(struct ueth_data));
+ ss->asix_model = asix_dongles[i].asix_model; + /* At this point, we know we've got a live one */ - debug("\n\nUSB Ethernet device detected: %#04x:%#04x\n", - dev->descriptor.idVendor, dev->descriptor.idProduct); + debug("\n\nUSB Ethernet device detected: %#04x:%#04x model AX88%s\n", + dev->descriptor.idVendor, dev->descriptor.idProduct, + ss->asix_model? "772" : "178");
/* Initialize the ueth_data structure with some useful info */ ss->ifnum = ifnum; diff --git a/include/usb_ether.h b/include/usb_ether.h index 825c275..28144f1 100644 --- a/include/usb_ether.h +++ b/include/usb_ether.h @@ -51,6 +51,7 @@ struct ueth_data { unsigned char irqinterval; /* Intervall for IRQ Pipe */
/* private fields for each driver can go here if needed */ + unsigned int asix_model; };
Hi David,
Thanks for the patch - I have tried this and things still work, but I don't think I have a Belkin F5D5055 Gig USB to test with. No matter.
Please see below form comments.
- mii_check_media - check the MII interface for a duplex change
- @mii: the MII interface
- @ok_to_print: OK to print link up/down messages
- @init_media: OK to save duplex mode in @mii
- Returns 1 if the duplex mode changed, 0 if not.
- If the media type is forced, always returns 0.
Please remove space before (
- unsigned int ok_to_print,
- unsigned int init_media)
- int advertise, lpa, media, duplex;
- int lpa2 = 0;
- struct ueth_data *dev = (struct ueth_data *)eth->priv;
- /* get MII advertise and LPA values */
- advertise = asix_mdio_read(dev, dev->phy_id, MII_ADVERTISE);
- lpa = asix_mdio_read(dev, dev->phy_id, MII_LPA);
- lpa2 = asix_mdio_read(dev, dev->phy_id, MII_STAT1000);
- /* figure out media and duplex from advertise and LPA values */
- media = mii_nway_result(lpa & advertise);
- duplex = (media & ADVERTISE_FULL) ? 1 : 0;
- if (lpa2 & LPA_1000FULL)
- duplex = 1;
- printf("link up, %uMbps, %s-duplex, lpa 0x%04X\n",
- lpa2 & (LPA_1000FULL | LPA_1000HALF) ? 1000 :
- media & (ADVERTISE_100FULL | ADVERTISE_100HALF) ?
- 100 : 10,
- duplex ? "full" : "half",
- lpa);
- return 0; /* duplex did not change */
- u16 mode;
- debug("ax88178_link_reset()\n");
- mii_check_media(eth, 1, 1);
- mode = AX88178_MEDIUM_DEFAULT;
- /* All supported ax88178 dongles have GMII */
- mode |= AX_MEDIUM_GM;
- mode |= AX_MEDIUM_ENCK;
- mode |= AX_MEDIUM_FD;
- asix_write_medium_mode(dev, mode);
- unsigned char buf[ETH_ALEN];
- int phymode, ledmode;
- int gpio0 = 0;
- u8 status;
- __le16 eeprom;
- int timeout = 0;
- int link_detected;
- debug("** %s()\n", __func__);
- asix_read_cmd(dev, AX_CMD_READ_GPIOS, 0, 0, 1, &status);
- debug("GPIO Status: 0x%04x\n", status);
- asix_write_cmd(dev, AX_CMD_WRITE_ENABLE, 0, 0, 0, NULL);
- asix_read_cmd(dev, AX_CMD_READ_EEPROM, 0x0017, 0, 2, &eeprom);
- asix_write_cmd(dev, AX_CMD_WRITE_DISABLE, 0, 0, 0, NULL);
- debug("EEPROM index 0x17 is 0x%04x\n", eeprom);
- if (eeprom == cpu_to_le16(0xffff)) {
- printf("Error: Marvell phy not supported\n");
- return -1;
- } else {
- phymode = le16_to_cpu(eeprom) & 7;
- ledmode = le16_to_cpu(eeprom) >> 8;
- gpio0 = (le16_to_cpu(eeprom) & 0x80) ? 0 : 1;
- debug("GPIO0: %d, PhyMode: %d\n", gpio0, phymode);
- asix_write_gpio(dev, AX_GPIO_RSE | AX_GPIO_GPO_1 | AX_GPIO_GPO1EN, 40);
- if ((le16_to_cpu(eeprom) >> 8) != 1) {
- asix_write_gpio(dev, 0x003c, 30);
- asix_write_gpio(dev, 0x001c, 300);
- } else {
- debug("gpio phymode == 1 path\n");
- asix_write_gpio(dev, AX_GPIO_GPO1EN, 30);
- asix_write_gpio(dev, AX_GPIO_GPO1EN | AX_GPIO_GPO_1, 30);
- asix_sw_reset(dev, 0);
- udelay(150000);
- asix_sw_reset(dev, AX_SWRESET_PRL | AX_SWRESET_IPPD);
- udelay(150000);
- asix_write_rx_ctl(dev, 0);
- /* Get the MAC address */
- if (asix_read_cmd(dev, AX_CMD_READ_NODE_ID,
- 0, 0, ETH_ALEN, buf) < 0) {
- debug("Failed to read MAC address.\n");
- goto out_err;
- memcpy(eth->enetaddr, buf, ETH_ALEN);
- debug("MAC %02x:%02x:%02x:%02x:%02x:%02x\n",
- eth->enetaddr[0], eth->enetaddr[1],
- eth->enetaddr[2], eth->enetaddr[3],
- eth->enetaddr[4], eth->enetaddr[5]);
- dev->phy_id = asix_get_phy_addr(dev);
- if (dev->phy_id < 0)
- debug("Failed to read phy id\n");
- asix_mdio_write(dev, dev->phy_id, MII_BMCR,
- BMCR_RESET | BMCR_ANENABLE);
- asix_mdio_write(dev, dev->phy_id, MII_ADVERTISE,
- ADVERTISE_ALL | ADVERTISE_CSMA | ADVERTISE_PAUSE_CAP);
- asix_mdio_write(dev, dev->phy_id, MII_CTRL1000,
- ADVERTISE_1000FULL);
- mii_nway_restart(dev);
- if (asix_write_medium_mode(dev, AX88178_MEDIUM_DEFAULT) < 0)
- goto out_err;
- if (asix_write_rx_ctl(dev, AX_DEFAULT_RX_CTL) < 0)
- goto out_err;
- do {
- link_detected = asix_mdio_read(dev, dev->phy_id, MII_BMSR) &
- BMSR_LSTATUS;
- if (!link_detected) {
- if (timeout == 0)
- printf("Waiting for Ethernet connection... ");
- udelay(TIMEOUT_RESOLUTION * 1000);
- timeout += TIMEOUT_RESOLUTION;
- } while (!link_detected && timeout < PHY_CONNECT_TIMEOUT);
- if (link_detected) {
- if (timeout != 0)
- printf("done.\n");
- } else {
- printf("unable to connect.\n");
- goto out_err;
- udelay(50000);
- ax88178_link_reset(eth);
- udelay(50000);
+out_err:
- return -1;
- switch (dev->asix_model) {
- case ASIX_MODEL_AX88772 :
I don't think you should have space before : here
- return asix_init_ax88772(eth, bd);
- break;
- case ASIX_MODEL_AX88178 :
and here
- return asix_init_ax88178(eth, bd);
- break;
- default:
- printf("Unsupported asix model!\n");
- return -1;
- unsigned int asix_model;
- { 0x05ac, 0x1402, ASIX_MODEL_AX88772 }, /* Apple USB Ethernet Adapter */
- { 0x07d1, 0x3c05, ASIX_MODEL_AX88772 }, /* D-Link DUB-E100 H/W Ver B1 */
- { 0x0b95, 0x772a, ASIX_MODEL_AX88772 }, /* Cables-to-Go USB Ethernet Adapter */
A few lines over 80cols here - can you reduce? Maybe ASIX_MODEL_AX... to MODEL_AX...?
- { 0x0b95, 0x7720, ASIX_MODEL_AX88772 }, /* Trendnet TU2-ET100 V3.0R */
- { 0x0b95, 0x1720, ASIX_MODEL_AX88772 }, /* SMC FIXME: isn't this AX88178? */
- { 0x0db0, 0xa877, ASIX_MODEL_AX88772 }, /* MSI - ASIX 88772a */
- { 0x13b1, 0x0018, ASIX_MODEL_AX88772 }, /* Linksys 200M v2.1 */
- { 0x1557, 0x7720, ASIX_MODEL_AX88772 }, /* 0Q0 cable ethernet */
- { 0x2001, 0x3c05, ASIX_MODEL_AX88772 }, /* DLink DUB-E100 H/W Ver B1 Alternate */
- { 0x050d, 0x5055, ASIX_MODEL_AX88178 }, /* Belkin F5D5055 Gig USB */
- { 0x0000, 0x0000, 0 } /* END - Do not remove */
- ss->asix_model = asix_dongles[i].asix_model;
- debug("\n\nUSB Ethernet device detected: %#04x:%#04x model AX88%s\n",
- dev->descriptor.idVendor, dev->descriptor.idProduct,
- ss->asix_model? "772" : "178");
Space before ?
Hi David,
On Thu, Jun 23, 2011 at 5:03 PM, Simon Glass sjg@chromium.org wrote:
Hi David,
[snip]
Are you going to update resend this? We should get it merged I think.
David Jander
