[U-Boot] [PATCH] PXA: Fix building for lubbock board
Fix: drivers/mmc/libmmc.o: In function `mmc_legacy_init': drivers/mmc/pxa_mmc.c:565: undefined reference to `set_GPIO_mode' drivers/mmc/pxa_mmc.c:566: undefined reference to `set_GPIO_mode'
Re-add set_GPIO_mode() which has been removed by commit d10237d275300562bbfecbbe2f59a97cfb9dc180 (PXA: Separate PXA2xx CPU init).
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Marek Vasut marek.vasut@gmail.com --- arch/arm/cpu/pxa/pxa2xx.c | 25 +++++++++++++++++++++++++ 1 files changed, 25 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/pxa/pxa2xx.c b/arch/arm/cpu/pxa/pxa2xx.c index 09e8177..42fb4fc 100644 --- a/arch/arm/cpu/pxa/pxa2xx.c +++ b/arch/arm/cpu/pxa/pxa2xx.c @@ -299,3 +299,28 @@ void reset_cpu(ulong ignored) for (;;) ; } + +#ifndef CONFIG_CPU_MONAHANS +void set_GPIO_mode(int gpio_mode) +{ + int gpio = gpio_mode & GPIO_MD_MASK_NR; + int fn = (gpio_mode & GPIO_MD_MASK_FN) >> 8; + int val; + + /* This below changes direction setting of GPIO "gpio" */ + val = readl(GPDR(gpio)); + + if (gpio_mode & GPIO_MD_MASK_DIR) + val |= GPIO_bit(gpio); + else + val &= ~GPIO_bit(gpio); + + writel(val, GPDR(gpio)); + + /* This below updates only AF of GPIO "gpio" */ + val = readl(GAFR(gpio)); + val &= ~(0x3 << (((gpio) & 0xf) * 2)); + val |= fn << (((gpio) & 0xf) * 2); + writel(val, GAFR(gpio)); +} +#endif /* CONFIG_CPU_MONAHANS */
- int gpio = gpio_mode & GPIO_MD_MASK_NR;
- int fn = (gpio_mode & GPIO_MD_MASK_FN) >> 8;
- int val;
- /* This below changes direction setting of GPIO "gpio" */
- val = readl(GPDR(gpio));
- if (gpio_mode & GPIO_MD_MASK_DIR)
- else
- writel(val, GPDR(gpio));
- /* This below updates only AF of GPIO "gpio" */
- val = readl(GAFR(gpio));
- val &= ~(0x3 << (((gpio) & 0xf) * 2));
- val |= fn << (((gpio) & 0xf) * 2);
- writel(val, GAFR(gpio));
NAK, this is insane and should die. I'll submit a proper patch.
M
GPIO configuration shall never be done inside a driver, never.
Signed-off-by: Marek Vasut marek.vasut@gmail.com Cc: Anatolij Gustschin agust@denx.de Cc: Albert ARIBAUD albert.u.boot@aribaud.net --- board/lubbock/lubbock.c | 6 ++++++ drivers/mmc/pxa_mmc.c | 5 ----- 2 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/board/lubbock/lubbock.c b/board/lubbock/lubbock.c index 437f944..3527b38 100644 --- a/board/lubbock/lubbock.c +++ b/board/lubbock/lubbock.c @@ -28,6 +28,8 @@ #include <common.h> #include <netdev.h> #include <asm/arch/pxa.h> +#include <asm/arch/pxa-regs.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -47,6 +49,10 @@ int board_init (void) /* adress of boot parameters */ gd->bd->bi_boot_params = 0xa0000100;
+ /* Configure GPIO6 and GPIO8 as OUT, AF1. */ + setbits_le32(GPDR0, (1 << 6) | (1 << 8)); + clrsetbits_le32(GAFR0_L, (3 << 12) | (3 << 16), (1 << 12) | (1 << 16)); + return 0; }
diff --git a/drivers/mmc/pxa_mmc.c b/drivers/mmc/pxa_mmc.c index 2b58a98..80c4445 100644 --- a/drivers/mmc/pxa_mmc.c +++ b/drivers/mmc/pxa_mmc.c @@ -560,11 +560,6 @@ mmc_legacy_init(int verbose) /* Reset device interface type */ mmc_dev.if_type = IF_TYPE_UNKNOWN;
-#if defined(CONFIG_LUBBOCK) || \ - (defined(CONFIG_GUMSTIX) && !defined(CONFIG_CPU_PXA27X)) - set_GPIO_mode(GPIO6_MMCCLK_MD); - set_GPIO_mode(GPIO8_MMCCS0_MD); -#endif #ifdef CONFIG_CPU_MONAHANS /* pxa3xx */ writel(readl(CKENA) | CKENA_12_MMC0 | CKENA_13_MMC1, CKENA); #else /* pxa2xx */
Hi Marek, Albert,
This patch should go into v2011.12 release. Who is going to apply it? Or should I push it via my staging branch?
Thanks, Anatolij
Le 19/12/2011 16:57, Anatolij Gustschin a écrit :
Hi Marek, Albert,
Signed-off-by: Marek Vasutmarek.vasut@gmail.com Cc: Anatolij Gustschinagust@denx.de Cc: Albert ARIBAUDalbert.u.boot@aribaud.net
Thanks, Anatolij
How was this patch tested?
Amicalement,
On Mon, 19 Dec 2011 17:15:03 +0100 Albert ARIBAUD albert.u.boot@aribaud.net wrote:
Hi Marek, Albert,
Thanks, Anatolij
I only compile-tested it.
Marek, do you have this board? Did you test this patch on real hardware?
Anatolij
Hi Marek, Albert,
Thanks, Anatolij
Amicalement,
It wasn't ... only compile-tested. Does someone have a lubbock?
M
Dear Marek Vasut,
Lubbock is orphaned, no testers are known.
If it's compile clean, that should be good enough.
Hi Wolfgang,
Le 19/12/2011 17:33, Wolfgang Denk a écrit :
Dear Marek Vasut,
Ok, I'll pull it in then; but if Lubbock is orphaned, then maybe we should throw a call for a new maintainer to step forward during next release cycle, and if none shows, then remove the board rather and try and keep it alive.
Amicalement,
Hi Wolfgang,
Dear Marek Vasut,
Amicalement,
That's indeed the plan.
M
Albert ARIBAUD
Anatolij Gustschin
