[U-Boot] [PATCH] main: Drop more #ifdefs
Now that many things are converted to Kconfig we can drop most of the
Signed-off-by: Simon Glass sjg@chromium.org ---
common/main.c | 22 ++++++++++------------ 1 file changed, 10 insertions(+), 12 deletions(-)
diff --git a/common/main.c b/common/main.c index 9802bed229c..07b34bf2b05 100644 --- a/common/main.c +++ b/common/main.c @@ -24,15 +24,15 @@ static void run_preboot_environment_command(void)
p = env_get("preboot"); if (p != NULL) { -# ifdef CONFIG_AUTOBOOT_KEYED - int prev = disable_ctrlc(1); /* disable Control C checking */ -# endif + int prev = 0; + + if (IS_ENABLED(CONFIG_AUTOBOOT_KEYED)) + prev = disable_ctrlc(1); /* disable Ctrl-C checking */
run_command_list(p, -1, 0);
-# ifdef CONFIG_AUTOBOOT_KEYED - disable_ctrlc(prev); /* restore Control C checking */ -# endif + if (IS_ENABLED(CONFIG_AUTOBOOT_KEYED)) + disable_ctrlc(prev); /* restore Ctrl-C checking */ } #endif /* CONFIG_PREBOOT */ } @@ -44,17 +44,15 @@ void main_loop(void)
bootstage_mark_name(BOOTSTAGE_ID_MAIN_LOOP, "main_loop");
-#ifdef CONFIG_VERSION_VARIABLE - env_set("ver", version_string); /* set version variable */ -#endif /* CONFIG_VERSION_VARIABLE */ + if (IS_ENABLED(CONFIG_VERSION_VARIABLE)) + env_set("ver", version_string); /* set version variable */
cli_init();
run_preboot_environment_command();
-#if defined(CONFIG_UPDATE_TFTP) - update_tftp(0UL, NULL, NULL); -#endif /* CONFIG_UPDATE_TFTP */ + if (IS_ENABLED(CONFIG_UPDATE_TFTP)) + update_tftp(0UL, NULL, NULL);
s = bootdelay_process(); if (cli_process_fdt(&s))
